Other Parts Discussed in Thread: AM3359
I`m trying to use the dmtimers of the am3359 as clocks for external devices.
In order to do this I`ve been trying to use "mmap" in order to alter the registers with the values I require.
I began by toggling pins and that seems to be working. However, when I try to alter the pin mux registers or the clock register, I am not able to write (I read the values before and after I do the writing and they are the same).
Here are the steps I took:
1. define the start address of the register I want to alter (ex 0x44E00000 - clock module peripheral registers)
2. int fd = ("/dev/mem", O_RDWR)
3. volatile * u_int32_t register = mmap(0, LENGTH, PROT_READ | PROT_WRITE, MAP_SHARED, fd, ADDRESS)
4. read the area I`m interested in: printf("%X\n",register[OFFSET/4]
5. write my value: register[OFFSET/4] = my_value
6. 4. read the area I`m interested in again: printf("%X\n",register[OFFSET/4]
Any ideas on what I`m doing wrong?!
Anybody has some info on how I can set the dmtimers (timer4,5,6,7) other than mmap (while in linux)?
Bogdan S
