Hi Team,
I have been searching the AM3359 datasheet for information regarding DDR2 Signal Termination. I have found a good souce in Section 5.5.2.2.2.9 (page 157) regarding the amount of resistance necessary. Unfortunately, the documentation goes on to state:
"Placement of serial terminations for ADDC_CTRL net class signals should be close to the AM335x device."
It does not specify a recommended distance between the resistor and the device. I have also searched within the TRM but have not found any information on the proper spacing. I would like to be sure the resistors are the proper distance from the device. Can you please provide me with some recommended spacing measurments (in mm or mils)?
Thanks in advance,
-- Emmanuel
