as you know, my program used DSP/BIOS file called xxx.tcf, while now I want to my program *.c file reference some var defined in xxx.tcf, such as bios.GBL.CLKIN=24Mhz.
how can I realize it?
anybody, thank you!
anybody, thank you!
Thomas,
how you access properties defined in the configuration script depends on which variable you are accessing. For bios.GBL.CLKIN, you can call the C function GBL_getClkin(Void) to get the required value. In other cases, you would do something else. Let me know if CLKIN is the only value you need, or you need to access others.
