We are trying to port linux BSP on our coustom board of DM8148. We are able to successfully port U-boot and Kernel, but while I run load.sh script, board hangs.
Please see my below log. Could anyone please guide me to resolve this issue?
Linux version 2.6.37 (rakesh@EIDLCPU1013) (gcc version 4.3.3 (Sourcery G++ Lite 2009q1-203) ) #8 Mon Jan 28 17:02:49 IST 2013
CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c53c7f
CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine: ti8148_rigel
vram size = 88080384 at 0x0
ti81xx_reserve: ### Reserved DDR region @87f00000
reserved size = 88080384 at 0x0
FB: Reserving 88080384 bytes SDRAM for VRAM
Memory policy: ECC disabled, Data cache writeback
OMAP chip is TI8148 2.1
SRAM: Mapped pa 0x402f1000 to va 0xfe400000 size: 0xf000
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 10752
Kernel command line: console=ttyO0,115200n8 rootwait root=/dev/nfs nfsroot=10.99.14.35:/home_cvic/shabbir/8148_rdk/DVRRDK_03.00.00.00/target/rfs_814x rw mem=128M notifyk.vpssm3_sva=0xBFD00000 vram=84M ip=dhcp noinitrd
PID hash table entries: 256 (order: -2, 1024 bytes)
Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
Memory: 42MB 1MB = 43MB total
Memory: 36648k/36648k available, 94424k reserved, 0K highmem
Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
DMA : 0xffc00000 - 0xffe00000 ( 2 MB)
vmalloc : 0xc8800000 - 0xf8000000 ( 760 MB)
lowmem : 0xc0000000 - 0xc8000000 ( 128 MB)
pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
.init : 0xc0008000 - 0xc0044000 ( 240 kB)
.text : 0xc0044000 - 0xc0589000 (5396 kB)
.data : 0xc058a000 - 0xc05dfac0 ( 343 kB)
SLUB: Genslabs=11, HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
NR_IRQS:407
omap_hwmod: gpio1: softreset failed (waited 10000 usec)
omap_hwmod: gpio2: softreset failed (waited 10000 usec)
omap_hwmod: gpio3: softreset failed (waited 10000 usec)
omap_hwmod: gpio4: softreset failed (waited 10000 usec)
IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts
Total of 128 interrupts on 1 active controller
GPMC revision 6.0
Trying to install interrupt handler for IRQ400
Trying to install interrupt handler for IRQ401
Trying to install interrupt handler for IRQ402
Trying to install interrupt handler for IRQ403
Trying to install interrupt handler for IRQ404
Trying to install interrupt handler for IRQ405
Trying to install interrupt handler for IRQ406
Trying to install type control for IRQ407
Trying to set irq flags for IRQ407
OMAP clockevent source: GPTIMER1 at 20000000 Hz
Console: colour dummy device 80x30
Calibrating delay loop... 599.65 BogoMIPS (lpj=2998272)
pid_max: default: 32768 minimum: 301
Security Framework initialized
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
devtmpfs: initialized
TI81XX: Map 0x87f00000 to 0xfe500000 for dram barrier
TI81XX: Map 0x40300000 to 0xfe600000 for sram barrier
omap_voltage_early_init: voltage driver support not added
regulator: core version 0.5
regulator: dummy:
NET: Registered protocol family 16
omap_voltage_domain_lookup: Voltage driver init not yet happened.Faulting!
omap_voltage_add_dev: VDD specified does not exist!
OMAP GPIO hardware version 0.1
omap_mux_init: Add partition: #1: core, flags: 4
clk get on i2c3 fck failed
Cannot clk_get ck_32
Debugfs: Only enabling/disabling deep sleep and wakeup timer is supported now
registered ti81xx_vpss device
registered ti81xx_vidout device
registered ti81xx on-chip HDMI device
registered ti81xx_fb device
registered ti81xx_vin device
ti81xx_pcie: Invoking PCI BIOS...
ti81xx_pcie: Setting up Host Controller...
ti81xx_pcie: Register base mapped @0xc8820000
ti81xx_pcie: forcing link width - x1
ti81xx_pcie: Starting PCI scan...
PCI: bus0: Fast back to back transfers enabled
ti81xx_pcie: PCI scan done.
bio: create slab <bio-0> at 0
vgaarb: loaded
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
USBSS revision 4ea2080b
registerd cppi-dma Intr @ IRQ 17
Cppi41 Init Done
omap_i2c omap_i2c.1: bus 1 rev4.0 at 100 kHz
Found IO-expander TCA6424
Found IO-expander MCP23009
Advanced Linux Sound Architecture Driver Version 1.0.23.
Bluetooth: Core ver 2.15
NET: Registered protocol family 31
Bluetooth: HCI device and connection manager initialized
Bluetooth: HCI socket layer initialized
Switching to clocksource gp timer
musb-hdrc: version 6.0, host, debug=0
musb-hdrc musb-hdrc.0: dma type: dma-cppi41
MUSB controller-0 revision 4ea20800
usb2phy: computed values rxcalib(15)DACs(27 13 13)
usb2phy: override computed values rxcalib(15)DACs(27 13 13)
usb2phy_config: musb(0) rxcalib done, rxcalib read value 6f6ddb6e
musb-hdrc musb-hdrc.0: MUSB HDRC host driver
musb-hdrc musb-hdrc.0: new USB bus registered, assigned bus number 1
usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb1: Product: MUSB HDRC host driver
usb usb1: Manufacturer: Linux 2.6.37 musb-hcd
usb usb1: SerialNumber: musb-hdrc.0
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
musb-hdrc musb-hdrc.0: USB Host mode controller at c881e000 using DMA, IRQ 18
musb-hdrc musb-hdrc.1: dma type: dma-cppi41
MUSB controller-1 revision 4ea20800
usb2phy: computed values rxcalib(15)DACs(31 13 14)
usb2phy: override computed values rxcalib(15)DACs(31 13 14)
usb2phy_config: musb(1) rxcalib done, rxcalib read value 6f6fdb76
musb-hdrc musb-hdrc.1: MUSB HDRC host driver
musb-hdrc musb-hdrc.1: new USB bus registered, assigned bus number 2
usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb2: Product: MUSB HDRC host driver
usb usb2: Manufacturer: Linux 2.6.37 musb-hcd
usb usb2: SerialNumber: musb-hdrc.1
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
musb-hdrc musb-hdrc.1: USB Host mode controller at c8826800 using DMA, IRQ 19
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 2048 (order: 2, 16384 bytes)
TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
TCP: Hash tables configured (established 2048 bind 2048)
TCP reno registered
UDP hash table entries: 256 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
NetWinder Floating Point Emulator V0.97 (double precision)
PMU: registered new PMU device of type 0
omap-iommu omap-iommu.0: ducati registered
omap-iommu omap-iommu.1: sys registered
msgmni has been set to 71
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
omap_uart.0: ttyO0 at MMIO 0x48020000 (irq = 72) is a OMAP UART0
console [ttyO0] enabled
omap_uart.1: ttyO1 at MMIO 0x48022000 (irq = 73) is a OMAP UART1
omap_uart.2: ttyO2 at MMIO 0x48024000 (irq = 74) is a OMAP UART2
omap_uart.3: ttyO3 at MMIO 0x481a6000 (irq = 44) is a OMAP UART3
omap_uart.4: ttyO4 at MMIO 0x481a8000 (irq = 45) is a OMAP UART4
omap_uart.5: ttyO5 at MMIO 0x481aa000 (irq = 46) is a OMAP UART5
brd: module loaded
loop: module loaded
ahci probe: devid name is ahci
ahci CAP register dump =0x6726ff80
Modified ahci CAP register dump =0x6f26ff80
ahci ahci.0: forcing PORTS_IMPL to 0x1
ahci: SSS flag set, parallel bus scan disabled
ahci ahci.0: AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl platform mode
ahci ahci.0: flags: ncq sntf stag pm led clo only pmp pio slum part ccc apst
scsi0 : ahci_platform
ata1: SATA max UDMA/133 irq_stat 0x00400040, connection status changed irq 16
omap2-nand driver initializing
ONFI flash detected
ONFI param page 0 valid
NAND device: Maf ID: 0x2c, Chip ID: 0xdc (Micron, NAND 512MiB 3,3V 8-bit)
erasesize: 0x20000, writesize: 2048, oobsize: 64
Creating 6 MTD partitions on "omap2-nand.0":
0x000000000000-0x000000020000 : "U-Boot-min"
0x000000020000-0x000000260000 : "U-Boot"
0x000000260000-0x000000280000 : "U-Boot Env"
0x000000280000-0x0000006c0000 : "Kernel"
0x0000006c0000-0x00000cee0000 : "File System"
0x00000cee0000-0x000020000000 : "Reserved"
davinci_mdio davinci_mdio.0: davinci mdio revision 1.6
davinci_mdio davinci_mdio.0: detected phy mask fffffffe
davinci_mdio.0: probed
davinci_mdio davinci_mdio.0: phy[0]: device 0:00, driver unknown
CAN device driver interface
CAN bus driver for Bosch D_CAN controller 1.0
d_can d_can: d_can device registered (irq=52, irq_obj=53)
usbcore: registered new interface driver cdc_ether
usbcore: registered new interface driver dm9601
usbcore: registered new interface driver cdc_acm
cdc_acm: v0.26:USB Abstract Control Model driver for USB modems and ISDN adapters
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
mice: PS/2 mouse device common for all mice
input: gpio-keys as /devices/platform/gpio-keys/input/input0
input: TSC2004 Touchscreen as /devices/virtual/input/input1
input: power-button as /devices/platform/power-button/input/input2
rtc-ds1672 1-0068: chip found, driver version 0.4
rtc-ds1672 1-0068: rtc core: registered rtc-ds1672 as rtc0
i2c /dev entries driver
lirc_dev: IR Remote Control driver registered, major 252
IR NEC protocol handler initialized
IR RC5(x) protocol handler initialized
IR RC6 protocol handler initialized
IR JVC protocol handler initialized
IR Sony protocol handler initialized
IR RC5 (streamzap) protocol handler initialized
IR LIRC bridge handler initialized
Linux video capture interface: v2.00
usbcore: registered new interface driver uvcvideo
USB Video Class driver (v1.0.0)
lm75 1-0048: hwmon0: sensor 'tmp75'
lm75 1-004c: hwmon1: sensor 'tmp75'
OMAP Watchdog Timer Rev 0x00: initial timeout 60 sec
Bluetooth: HCI UART driver ver 2.2
Bluetooth: HCI H4 protocol initialized
Bluetooth: HCI BCSP protocol initialized
Bluetooth: HCILL protocol initialized
Bluetooth: HCIATH3K protocol initialized
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
notify_init : notify drivercreated for remote proc id 2 at physical Address 0xbfd00000
usbcore: registered new interface driver snd-usb-audio
*** Forcing SW CTS!
asoc: tlv320aic3x-hifi <-> davinci-mcasp.1 mapping ok
asoc: HDMI-DAI-CODEC <-> hdmi-dai mapping ok
asoc: sii9135-codec-dai <-> davinci-mcasp.0 mapping ok
ALSA device list:
#0: TI81XX EVM
TCP cubic registered
NET: Registered protocol family 10
IPv6 over IPv4 tunneling driver
NET: Registered protocol family 17
can: controller area network core (rev 20090105 abi 8)
NET: Registered protocol family 29
can: raw protocol (rev 20090105)
can: broadcast manager protocol (rev 20090105 t)
Bluetooth: L2CAP ver 2.15
Bluetooth: L2CAP socket layer initialized
Bluetooth: SCO (Voice Link) ver 0.6
Bluetooth: SCO socket layer initialized
Bluetooth: RFCOMM TTY layer initialized
Bluetooth: RFCOMM socket layer initialized
Bluetooth: RFCOMM ver 1.11
Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Bluetooth: HIDP (Human Interface Emulation) ver 1.2
Registering the dns_resolver key type
VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
omap_voltage_late_init: Voltage driver support not added
Power Management for TI81XX.
Detected MACID=0:17:eb:f8:40:94
Detected MACID=0:17:eb:f8:40:95
rtc-ds1672 1-0068: setting system clock to 2037-10-10 05:00:35 UTC (2138763635)
mmc0: host does not support reading read-only switch. assuming write-enable.
mmc0: new high speed SDHC card at address aaaa
mmcblk0: mmc0:aaaa SU04G 3.69 GiB
mmcblk0: p1 p2
PHY 0:01 not found
ADDRCONF(NETDEV_UP): eth0: link is not ready
CPSW phy found : id is : 0x70431
ADDRCONF(NETDEV_UP): eth1: link is not ready
ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
ata1.00: ATA-8: ST9250315AS, 0001SDM1, max UDMA/133
ata1.00: 488397168 sectors, multi 16: LBA48 NCQ (depth 31/32)
ata1.00: configured for UDMA/133
scsi 0:0:0:0: Direct-Access ATA ST9250315AS 0001 PQ: 0 ANSI: 5
sd 0:0:0:0: Attached scsi generic sg0 type 0
sd 0:0:0:0: [sda] 488397168 512-byte logical blocks: (250 GB/232 GiB)
sd 0:0:0:0: [sda] Write Protect is off
sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
sda: sda1 sda2
sd 0:0:0:0: [sda] Attached SCSI disk
Sending DHCP requests .
PHY: 0:00 - Link is Up - 100/Full
ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
., OK
IP-Config: Got DHCP answer from 192.168.6.59, my address is 10.99.19.211
IP-Config: Complete:
device=eth1, addr=10.99.19.211, mask=255.255.252.0, gw=10.99.17.1,
host=10.99.19.211, domain=, nis-domain=(none),
bootserver=192.168.6.59, rootserver=10.99.14.35, rootpath=
VFS: Mounted root (nfs filesystem) on device 0:15.
devtmpfs: mounted
Freeing init memory: 240K
INIT: version 2.86 booting
Error opening /dev/fb0: No such file or directory
Please wait: booting...
Starting udev
udevd (86): /proc/86/oom_adj is deprecated, please use /proc/86/oom_score_adj instead.
udev: starting version 141
udev: renamed network interface eth0 to eth2
udevd-event[97]: error changing netif name eth1 to eth3: Device or resource busy
Root filesystem already rw, not remounting
Caching udev devnodes
Populating dev cacheFAT: bogus number of reserved sectors
VFS: Can't find a valid FAT filesystem on dev sda.
VFS: Can't find a valid FAT filesystem on dev mmcblk0.
EXT3-fs: barriers not enabled
kjournald starting. Commit interval 5 seconds
EXT3-fs (mmcblk0p2): warning: maximal mount count reached, running e2fsck is recommended
EXT3-fs (sda1): warning: maximal mount count reached, running e2fsck is recommended
EXT3-fs (mmcblk0p2): using internal journal
EXT3-fs (mmcblk0p2): recovery complete
EXT3-fs (mmcblk0p2): mounted filesystem with writeback data mode
EXT3-fs (sda1): using internal journal
EXT3-fs (sda1): recovery complete
EXT3-fs (sda1): mounted filesystem with writeback data mode
EXT3-fs (sda2): warning: maximal mount count reached, running e2fsck is recommended
EXT3-fs (sda2): using internal journal
EXT3-fs (sda2): recovery complete
EXT3-fs (sda2): mounted filesystem with writeback data mode
ALSA: Restoring mixer settings...
NOT configuring network interfaces: / is an NFS mount
No state is present for card EVM
INIT: Entering runlevel: 5
Unknown hardware: "" "" "" "" ""
Hardware is initialized using a guess method
/usr/share/alsa/init/default:53: control element not found
Starting system message bus: dbus.
Starting telnet daemon.
Starting syslogd/klogd: done
Starting thttpd.
Applying sync command
_____ _____ _ _
| _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_
| | _| .'| . | . | | __| _| . | | | -_| _| _|
|__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_|
|___| |___|
Arago Project http://arago-project.org dm814x ttyO0
Arago 2010.11 dm814x ttyO0
dm814x login: root
root@dm814x:~#
root@dm814x:~#
root@dm814x:~# cd /opt/dvr_rdk/ti814x/
root@dm814x:/opt/dvr_rdk/ti814x# ls -l
drwxrwxr-x 2 27562 3355 4096 Dec 24 2012 bin
drwxrwxr-x 2 27562 3355 4096 Dec 21 2012 demo_ini
-rwxr-xr-x 1 27562 3355 1038 Dec 25 2012 env.sh
-rwxr-xr-x 1 27562 3355 1038 Sep 5 2012 env_512M_128M.sh
drwxrwxr-x 2 27562 3355 4096 Dec 25 2012 firmware
-rwxr-xr-x 1 27562 3355 1581 Dec 25 2012 init.sh
drwxrwxr-x 2 27562 3355 4096 Jul 11 2012 kermod
-rwxr-xr-x 1 27562 3355 563 Dec 25 2012 load.sh
-rwxr-xr-x 1 27562 3355 32 Dec 25 2012 run.sh
drwxrwxr-x 2 27562 3355 4096 Dec 20 2012 scripts
-rwxr-xr-x 1 27562 3355 522 Dec 25 2012 unload.sh
-rwxr-xr-x 1 27562 3355 568 Dec 25 2012 validate.sh
root@dm814x:/opt/dvr_rdk/ti814x# ./init.sh
*** Bootargs Validated for mem param ***
*** Bootargs Validated for notifyk.vpssm3 params ***
Kernel bootargs validated
numid=1,iface=MIXER,name='PCM Playback Volume'
; type=INTEGER,access=rw---R--,values=2,min=0,max=127,step=0
: values=127,127
| dBscale-min=-63.50dB,step=0.50dB,mute=0
[c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[m3video] Remote Debug Shared Memory @ 0xbff05020
[m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
SysLink version : 2.10.02.17
SysLink module created on Date:Dec 20 2012 Time:12:47:20
Trace enabled
Trace SetFailureReason enabled
Setting DMM priority for [DUCATI ] to [0] ( 0x4e000624 = 0x08000000 )
Setting DMM priority for [HDVICP0 ] to [2] ( 0x4e000634 = 0x0000000a )
*** TVP5158 probe : START ***
TI VS EVM : TVP5158 device address : 0x58, 0x5a, 0x5c, 0x5e
TI DVR : TVP5158 device address : 0x58, 0x59, 0x5a, 0x5b
Device found : I2C (0xXX): 0x08 = 0x51
I2C (0xXX): 0x09 = 0x58
Device NOT found : I2C (0xXX): Read ERROR !!! (reg[0x08], count = 2)
ERROR (osa_i2c.c|OSA_i2cTestMain|263): OSA_i2cOpen( instId = 3 )
*** TVP5158 probe : END ***
/opt/dvr_rdk/ti814x
root@dm814x:/opt/dvr_rdk/ti814x# ./load.sh
Attached to slave procId 2.
Loaded file ../firmware/dvr_rdk_fw_m3vpss.xem3 on slave procId 2.
Started slave procId 2.
After Ipc_loadcallback status [0x00000000]
[m3vpss ] ***** SYSTEM : Frequency <ORG> - 200000000, <NEW> - 240000000
[m3vpss ] notify_attach rtnVal 0
[m3vpss ] initProxyServer rtnVal 0
[m3vpss ]
[m3vpss ] *** UTILS: CPU KHz = 480000 Khz ***
[m3vpss ]
[m3vpss ] 53: SYSTEM : System Common Init in progress !!!
[m3vpss ] 53: SYSTEM: IPC init in progress !!!
[m3vpss ] 53: SYSTEM: Attaching to [HOST] ...
[m3vpss ] 1052: SYSTEM: Attaching to [HOST] ...
[m3vpss ] 1054: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
[m3vpss ] 1054: SYSTEM: Attaching to [DSP] ...
After Ipc_startcallback status [0x097d2000]
Attached to slave procId 1.
Loaded file ../firmware/dvr_rdk_fw_m3video.xem3 on slave procId 1.
Started slave procId 1.
[m3video] main start on M3 video*******************
[m3vpss ] 2054: SYSTEM: Attaching to [DSP] ...
[m3video] ***** SYSTEM : Frequency <ORG> - 200000000, <NEW> - 240000000
[m3video]
[m3video] *** UTILS: CPU KHz = 480000 Khz ***
[m3video]
[m3video] 1320: SYSTEM : System Common Init in progress !!!
[m3video] 1320: SYSTEM: IPC init in progress !!!
[m3video] 1320: SYSTEM: Attaching to [HOST] ...
[m3video] 2320: SYSTEM: Attaching to [HOST] ...
[m3video] 2322: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
[m3video] 2323: SYSTEM: Attaching to [DSP] ...
After Ipc_startcallback status [0x00000000]
Attached to slave procId 0.
Loaded file ../firmware/dvr_rdk_fw_c6xdsp.xe674 on slave procId 0.
Started slave procId 0.
[c6xdsp ] ***** SYSTEM : Frequency <ORG> - 500000000, <NEW> - 750000000
[m3video] 3322: SYSTEM: Attaching to [DSP] ...
[m3vpss ] 3054: SYSTEM: Attaching to [DSP] ...
[c6xdsp ]
[c6xdsp ] *** UTILS: CPU KHz = 750000 Khz ***
[c6xdsp ]
[c6xdsp ] 0: SYSTEM : System Common Init in progress !!!
[c6xdsp ] 0: SYSTEM: IPC init in progress !!!
[c6xdsp ] 0: SYSTEM: Attaching to [HOST] ...
[c6xdsp ] 667: SYSTEM: Attaching to [HOST] ...
[c6xdsp ] 669: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
[c6xdsp ] 669: SYSTEM: Attaching to [VIDEO-M3] ...
DMA: Module install successful, device major num = 250
DRV: Module install successful
DRV: Module built on Dec 24 2012 11:35:31
