I'm using am335x and samsung K9F4G08U0B. The problem is that it often create bad blocks when write to nand. I can copy some small files to nand, but can't copy big files. It doesn't work if I tar a tar ball in to it.
But It works in another board which is using MT29F2G08.
I tried to double the timing value in the am335x_nand_timings structure. the problem is not fixed.
why this happens? Is it a ubifs problem or a nand timing problem?
I post the error message here, please help me. Thank you very much.
U-Boot SPL 2011.09-svn (Jan 24 2013 - 11:34:11) Texas Instruments Revision detection unimplemented U-Boot 2011.09-svn (Jan 30 2013 - 17:27:19) I2C: ready DRAM: 256 MiB WARNING: Caches not enabled NAND: HW ECC Hamming Code selected 512 MiB MMC: OMAP SD/MMC: 0 Net: cpsw Hit any key to stop autoboot: 3 2 1 0 Card did not respond to voltage select! Booting from nand ... HW ECC BCH8 Selected NAND read: device 0 offset 0x280000, size 0x300000 3145728 bytes read: OK HW ECC Hamming Code selected NAND read: device 0 offset 0x700000, size 0x80000 524288 bytes read: OK ## Booting kernel from Legacy Image at 80007fc0 ... Image Name: Linux-3.2.0 Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 3043216 Bytes = 2.9 MiB Load Address: 80008000 Entry Point: 80008000 Verifying Checksum ... OK XIP Kernel Image ... OK OK Starting kernel ... Uncompressing Linux... done, booting the kernel. [ 0.000000] Linux version 3.2.0 (zlh@zlh-Desktop) (gcc version 4.5.3 20110311 (prerelease) (GCC) ) #336 Thu Jan 31 22:17:39 CST 2013 [ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c53c7d [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache [ 0.000000] Machine: am335xevm [ 0.000000] Memory policy: ECC disabled, Data cache writeback [ 0.000000] AM335X ES1.0 (neon ) [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 64262 [ 0.000000] Kernel command line: console=ttyO0,115200n8 root=ubi0:rootfs rw ubi.mtd=7,2048 noinitrd rootfstype=ubifs rootwait=1 ip=none mem=253M [ 0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes) [ 0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes) [ 0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes) [ 0.000000] Memory: 253MB = 253MB total [ 0.000000] Memory: 250468k/250468k available, 8604k reserved, 0K highmem [ 0.000000] Virtual kernel memory layout: [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB) [ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) [ 0.000000] vmalloc : 0xd0000000 - 0xff000000 ( 752 MB) [ 0.000000] lowmem : 0xc0000000 - 0xcfd00000 ( 253 MB) [ 0.000000] modules : 0xbf000000 - 0xc0000000 ( 16 MB) [ 0.000000] .text : 0xc0008000 - 0xc056d000 (5524 kB) [ 0.000000] .init : 0xc056d000 - 0xc05aa000 ( 244 kB) [ 0.000000] .data : 0xc05aa000 - 0xc0604c88 ( 364 kB) [ 0.000000] .bss : 0xc0604cac - 0xc062a0fc ( 150 kB) [ 0.000000] NR_IRQS:396 [ 0.000000] IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts [ 0.000000] Total of 128 interrupts on 1 active controller [ 0.000000] OMAP clockevent source: GPTIMER2 at 24000000 Hz [ 0.000000] OMAP clocksource: GPTIMER1 at 32768 Hz [ 0.000000] sched_clock: 32 bits at 32kHz, resolution 30517ns, wraps every 131071999ms [ 0.000000] Console: colour dummy device 80x30 [ 0.000152] Calibrating delay loop... 718.02 BogoMIPS (lpj=3590144) [ 0.058959] pid_max: default: 32768 minimum: 301 [ 0.059082] Security Framework initialized [ 0.059204] Mount-cache hash table entries: 512 [ 0.059600] CPU: Testing write buffer coherency: ok [ 0.079620] omap_hwmod: gfx: failed to hardreset [ 0.095886] omap_hwmod: pruss: failed to hardreset [ 0.097015] print_constraints: dummy: [ 0.097381] NET: Registered protocol family 16 [ 0.099578] OMAP GPIO hardware version 0.1 [ 0.102142] omap_mux_init: Add partition: #1: core, flags: 0 [ 0.104003] omap_i2c.1: alias fck already exists [ 0.104217] Detected a daughter card on AM335x EVM.. [ 0.104248] The board is general purpose EVM in profile 0 [ 0.104248] Found invalid GP EVM revision, falling back to Rev1.1Alcdc_init, 1070 [ 0.104492] lcdc_init, 1072 [ 0.104553] da8xx_lcdc.0: alias fck already exists [ 0.104766] TSC connected to beta GP EVM [ 0.105926] *************am335x_register_mcasp, 208 [ 0.105987] davinci-mcasp.1: alias fck already exists [ 0.106262] omap_hsmmc.0: alias fck already exists [ 0.108154] omap2_mcspi.1: alias fck already exists [ 0.108367] omap2_mcspi.2: alias fck already exists [ 0.108642] edma.0: alias fck already exists [ 0.108642] edma.0: alias fck already exists [ 0.108673] edma.0: alias fck already exists [ 0.133880] bio: create slab <bio-0> at 0 [ 0.136108] SCSI subsystem initialized [ 0.137756] usbcore: registered new interface driver usbfs [ 0.138061] usbcore: registered new interface driver hub [ 0.138244] usbcore: registered new device driver usb [ 0.138397] musb-ti81xx musb-ti81xx: musb0, board_mode=0x31, plat_mode=0x1 [ 0.138702] musb-ti81xx musb-ti81xx: musb1, board_mode=0x31, plat_mode=0x3 [ 0.139892] omap_i2c omap_i2c.1: bus 1 rev2.4.0 at 100 kHz [ 0.141387] Advanced Linux Sound Architecture Driver Version 1.0.24. [ 0.142486] Switching to clocksource gp timer [ 0.157928] musb-hdrc: version 6.0, ?dma?, otg (peripheral+host) [ 0.158111] musb-hdrc musb-hdrc.0: dma type: pio [ 0.158569] musb-hdrc musb-hdrc.0: MUSB HDRC host driver [ 0.158691] musb-hdrc musb-hdrc.0: new USB bus registered, assigned bus number 1 [ 0.158813] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 [ 0.158843] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 0.158843] usb usb1: Product: MUSB HDRC host driver [ 0.158874] usb usb1: Manufacturer: Linux 3.2.0 musb-hcd [ 0.158874] usb usb1: SerialNumber: musb-hdrc.0 [ 0.159729] hub 1-0:1.0: USB hub found [ 0.159759] hub 1-0:1.0: 1 port detected [ 0.160339] musb-hdrc musb-hdrc.0: USB Host mode controller at d0034000 using PIO, IRQ 18 [ 0.160522] musb-hdrc musb-hdrc.1: dma type: pio [ 0.161407] musb-hdrc musb-hdrc.1: USB OTG mode controller at d0036800 using PIO, IRQ 19 [ 0.161804] NET: Registered protocol family 2 [ 0.162017] IP route cache hash table entries: 2048 (order: 1, 8192 bytes) [ 0.162322] TCP established hash table entries: 8192 (order: 4, 65536 bytes) [ 0.162475] TCP bind hash table entries: 8192 (order: 3, 32768 bytes) [ 0.162628] TCP: Hash tables configured (established 8192 bind 8192) [ 0.162658] TCP reno registered [ 0.162658] UDP hash table entries: 256 (order: 0, 4096 bytes) [ 0.162689] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes) [ 0.162872] NET: Registered protocol family 1 [ 0.163146] RPC: Registered named UNIX socket transport module. [ 0.163177] RPC: Registered udp transport module. [ 0.163177] RPC: Registered tcp transport module. [ 0.163177] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.163421] NetWinder Floating Point Emulator V0.97 (double precision) [ 0.163665] omap-gpmc omap-gpmc: GPMC revision 6.0 [ 0.163665] Registering NAND on CS0 [ 0.175903] VFS: Disk quotas dquot_6.5.2 [ 0.175964] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) [ 0.176452] msgmni has been set to 489 [ 0.177185] io scheduler noop registered [ 0.177215] io scheduler deadline registered [ 0.177276] io scheduler cfq registered (default) [ 0.178741] da8xx_lcdc da8xx_lcdc.0: GLCD: Found TFC_S9700RTWV35TR_01B panel [ 0.274475] Console: switching to colour frame buffer device 100x30 [ 0.287780] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled [ 0.310546] serial8250.0: ttyE0 at MMIO 0x2000040 (irq = 277) is a 16550A [ 0.331146] serial8250.0: ttyE1 at MMIO 0x2000080 (irq = 273) is a 16550A [ 0.351715] serial8250.0: ttyE2 at MMIO 0x2000100 (irq = 269) is a 16550A [ 0.372344] serial8250.0: ttyE3 at MMIO 0x2000200 (irq = 178) is a 16550A [ 0.373901] omap_uart.0: ttyO0 at MMIO 0x44e09000 (irq = 72) is a OMAP UART0 [ 1.008514] console [ttyO0] enabled [ 1.012756] omap_uart.1: ttyO1 at MMIO 0x48022000 (irq = 73) is a OMAP UART1 [ 1.020568] omap_uart.2: ttyO2 at MMIO 0x48024000 (irq = 74) is a OMAP UART2 [ 1.028381] omap_uart.3: ttyO3 at MMIO 0x481a6000 (irq = 44) is a OMAP UART3 [ 1.036193] omap_uart.4: ttyO4 at MMIO 0x481a8000 (irq = 45) is a OMAP UART4 [ 1.044128] omap_uart.5: ttyO5 at MMIO 0x481aa000 (irq = 46) is a OMAP UART5 [ 1.061279] brd: module loaded [ 1.069427] loop: module loaded [ 1.072937] i2c-core: driver [tsl2550] using legacy suspend method [ 1.079406] i2c-core: driver [tsl2550] using legacy resume method [ 1.087402] mtdoops: mtd device (mtddev=name/number) must be supplied [ 1.094726] omap2-nand driver initializing [ 1.099395] NAND device: Manufacturer ID: 0xec, Chip ID: 0xdc (Samsung NAND 512MiB 3,3V 8-bit) [ 1.108642] Creating 8 MTD partitions on "omap2-nand.0": [ 1.114257] 0x000000000000-0x000000020000 : "SPL" [ 1.120635] 0x000000020000-0x000000040000 : "SPL.backup1" [ 1.127746] 0x000000040000-0x000000060000 : "SPL.backup2" [ 1.134735] 0x000000060000-0x000000080000 : "SPL.backup3" [ 1.141662] 0x000000080000-0x000000260000 : "U-Boot" [ 1.148956] 0x000000260000-0x000000280000 : "U-Boot Env" [ 1.155792] 0x000000280000-0x000000780000 : "Kernel" [ 1.164337] 0x000000780000-0x000020000000 : "File System" [ 1.381286] UBI: attaching mtd7 to ubi0 [ 1.385345] UBI: physical eraseblock size: 131072 bytes (128 KiB) [ 1.391876] UBI: logical eraseblock size: 126976 bytes [ 1.397521] UBI: smallest flash I/O unit: 2048 [ 1.402404] UBI: sub-page size: 512 [ 1.407257] UBI: VID header offset: 2048 (aligned 2048) [ 1.413513] UBI: data offset: 4096 [ 1.583251] usb 1-1: new high-speed USB device number 2 using musb-hdrc [ 1.742767] usb 1-1: New USB device found, idVendor=0951, idProduct=1653 [ 1.749786] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [ 1.757232] usb 1-1: Product: DT 100 G2 [ 1.761230] usb 1-1: Manufacturer: Kingston [ 1.765594] usb 1-1: SerialNumber: 001CC0EC321ABB3117160012 [ 6.418823] UBI: max. sequence number: 1623 [ 6.441558] UBI warning: print_rsvd_warning: cannot reserve enough PEBs for bad PEB handling, reserved 16, need 40 [ 6.455139] UBI: attached mtd7 to ubi0 [ 6.459075] UBI: MTD device name: "File System" [ 6.464843] UBI: MTD device size: 504 MiB [ 6.470031] UBI: number of good PEBs: 4012 [ 6.474945] UBI: number of bad PEBs: 24 [ 6.479644] UBI: number of corrupted PEBs: 0 [ 6.484283] UBI: max. allowed volumes: 128 [ 6.489105] UBI: wear-leveling threshold: 4096 [ 6.494018] UBI: number of internal volumes: 1 [ 6.498657] UBI: number of user volumes: 3 [ 6.503295] UBI: available PEBs: 0 [ 6.507904] UBI: total number of reserved PEBs: 4012 [ 6.513092] UBI: number of PEBs reserved for bad PEB handling: 16 [ 6.519439] UBI: max/mean erase counter: 5/1 [ 6.523895] UBI: image sequence number: 531848417 [ 6.529022] UBI: background thread "ubi_bgt0d" started, PID 566 [ 6.535858] CAN device driver interface [ 6.539855] CAN bus driver for Bosch D_CAN controller 1.0 [ 6.593200] davinci_mdio davinci_mdio.0: davinci mdio revision 1.6 [ 6.599639] davinci_mdio davinci_mdio.0: detected phy mask fffffffd [ 6.606933] davinci_mdio.0: probed [ 6.610504] davinci_mdio davinci_mdio.0: phy[1]: device 0:01, driver unknown [ 6.618255] usbcore: registered new interface driver zd1201 [ 6.624298] usbcore: registered new interface driver cdc_ether [ 6.630523] usbcore: registered new interface driver cdc_eem [ 6.636596] usbcore: registered new interface driver dm9601 [ 6.642456] cdc_ncm: 04-Aug-2011 [ 6.645996] usbcore: registered new interface driver cdc_ncm [ 6.651916] Initializing USB Mass Storage driver... [ 6.657287] scsi0 : usb-storage 1-1:1.0 [ 6.662231] usbcore: registered new interface driver usb-storage [ 6.668518] USB Mass Storage support registered. [ 6.673828] mousedev: PS/2 mouse device common for all mice [ 6.680755] input: ti-tsc-adcc as /devices/platform/omap/tsc/input/input0 [ 6.691955] rtc-ds1307 1-0068: rtc core: registered ds1340 as rtc0 [ 6.698608] i2c /dev entries driver [ 6.702667] Linux video capture interface: v2.00 [ 6.707855] usbcore: registered new interface driver uvcvideo [ 6.713867] USB Video Class driver (1.1.1) [ 6.720153] OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec [ 6.726684] _regulator_get: deviceless supply vdd_mpu not found, using dummy regulator [ 6.735412] cpuidle: using governor ladder [ 6.740173] cpuidle: using governor menu [ 6.748321] usbcore: registered new interface driver usbhid [ 6.754180] usbhid: USB HID core driver [ 6.758758] usbcore: registered new interface driver snd-usb-audio [ 6.766021] ****************aic3x_i2c_probe, 1527 [ 6.770996] *****************aic3x_i2c_probe, 1548, 0 [ 6.776672] **************davinci_mcasp_probe, 918 [ 6.781738] ***************snd_soc_register_dai, 2942 [ 6.787017] ***************snd_soc_register_dai, 2965 [ 6.792297] *********ret: 0 [ 6.795684] ALSA device list: [ 6.798797] No soundcards found. [ 6.802337] oprofile: hardware counters not available [ 6.807647] oprofile: using timer interrupt. [ 6.812103] nf_conntrack version 0.5.0 (3913 buckets, 15652 max) [ 6.818908] ip_tables: (C) 2000-2006 Netfilter Core Team [ 6.824584] TCP cubic registered [ 6.827941] NET: Registered protocol family 17 [ 6.832611] can: controller area network core (rev 20090105 abi 8) [ 6.839141] NET: Registered protocol family 29 [ 6.843811] can: raw protocol (rev 20090105) [ 6.848266] can: broadcast manager protocol (rev 20090105 t) [ 6.854217] 8021q: 802.1Q VLAN Support v1.8 [ 6.858581] Registering the dns_resolver key type [ 6.863586] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3 [ 6.871582] ThumbEE CPU extension supported. [ 6.876098] mux: Failed to setup hwmod io irq -22 [ 6.881652] Power Management for AM33XX family [ 6.886535] Trying to load am335x-pm-firmware.bin (60 secs timeout) [ 6.893218] Copied the M3 firmware to UMEM [ 6.897491] omap_hwmod: wkup_m3: wkup_m3: hwmod data error: OMAP4 does not support st_shift [ 6.911499] clock: disabling unused clocks to save power [ 6.919036] Detected MACID=0:18:30:a:d3:bf [ 6.924377] cpsw: Detected MACID = 00:18:30:0a:d3:c0 [ 6.931701] rtc-ds1307 1-0068: setting system clock to 2013-01-31 17:33:49 UTC (1359653629) [ 7.017242] UBIFS: recovery needed [ 7.334381] UBIFS: recovery completed [ 7.338226] UBIFS: mounted UBI device 0, volume 0, name "rootfs" [ 7.344512] UBIFS: file system size: 3809280 bytes (3720 KiB, 3 MiB, 30 LEBs) [ 7.352142] UBIFS: journal size: 1142785 bytes (1116 KiB, 1 MiB, 8 LEBs) [ 7.359680] UBIFS: media format: w4/r0 (latest is w4/r0) [ 7.365783] UBIFS: default compressor: lzo [ 7.370056] UBIFS: reserved for root: 0 bytes (0 KiB) [ 7.376159] VFS: Mounted root (ubifs filesystem) on device 0:13. [ 7.382781] Freeing init memory: 244K wait please,prepare the system... mount: can't find / in /proc/mounts unknow platform...,please check your setting! configuring network parameters and ENV VAR... route: SIOCADDRT: Network is unreachable mounting app partition,wait please... [ 7.747406] UBIFS: recovery needed [ 7.841125] scsi 0:0:0:0: Direct-Access Kingston DT 100 G2 PMAP PQ: 0 ANSI: 0 CCS [ 7.932098] UBIFS: recovery completed [ 7.935974] UBIFS: mounted UBI device 0, volume 1, name "app" [ 7.941986] UBIFS: file system size: 49520640 bytes (48360 KiB, 47 MiB, 390 LEBs) [ 7.949981] UBIFS: journal size: 6729728 bytes (6572 KiB, 6 MiB, 53 LEBs) [ 7.957611] UBIFS: media format: w4/r0 (latest is w4/r0) [ 7.963714] UBIFS: default compressor: lzo [ 7.967956] UBIFS: reserved for root: 0 bytes (0 KiB) success!go on... mounting database partition,wait please... [ 8.065063] UBIFS: recovery needed [ 8.240203] UBIFS: recovery completed [ 8.244079] UBIFS: mounted UBI device 0, volume 2, name "db" [ 8.250000] UBIFS: file system size: 447590400 bytes (437100 KiB, 426 MiB, 3525 LEBs) [ 8.258361] UBIFS: journal size: 9023488 bytes (8812 KiB, 8 MiB, 72 LEBs) [ 8.265991] UBIFS: media format: w4/r0 (latest is w4/r0) [ 8.272064] UBIFS: default compressor: lzo [ 8.276336] UBIFS: reserved for root: 0 bytes (0 KiB) success!,go on... unknow platform...,please check your setting! starting our applications... product unknow platform...,please check your setting! unknow platform...,please check your setting! ~ # crond[689]: crond: crond (busybox 1.19.4) started, log level 8 unknow platform...,please check your setting! httpd: chdir(/usr/app_install/www/): No such file or directory [ 8.456573] sd 0:0:0:0: [sda] 15430464 512-byte logical blocks: (7.90 GB/7.35 GiB) starting system done,enjoy it! vsftpd: error wh[ 8.468872] sd 0:0:0:0: [sda] Write Protect is off ile loading shar[ 8.475402] sd 0:0:0:0: [sda] No Caching mode page present ed libraries: /u[ 8.482116] sd 0:0:0:0: [sda] Assuming drive cache: write through sr/app_install//common/lib/libcr[ 8.492279] sd 0:0:0:0: [sda] No Caching mode page present ypt.so.1: file t[ 8.498413] sd 0:0:0:0: [sda] Assuming drive cache: write through oo short [ 8.519989] sda: sda1 [ 8.524566] sd 0:0:0:0: [sda] No Caching mode page present [ 8.530273] sd 0:0:0:0: [sda] Assuming drive cache: write through [ 8.536651] sd 0:0:0:0: [sda] Attached SCSI removable disk ~ # ~ # df Filesystem 1K-blocks Used Available Use% Mounted on ubi0:rootfs 2752 2228 524 81% / ubi0:app 44036 136 43900 0% /usr/app_install ubi0:db 403580 28 403552 0% /usr/app_install/db/database ~ # mount -t fvfat /dvev/sda1 /mnt ~ # cd /usr/a /usr # tar zxvf /mnt/app/usr # tar zxvf /mnt/app_lc/usr # tar zxvf /mnt/app_lcd7/usr # tar zxvf /mnt/app_lcd70.tar.gz app_install/ app_install/protocol/ app_install/protocol/cfg/ app_install/protocol/bin/ app_install/protocol/bin/analog app_install/protocol/log/ app_install/main/ app_install/main/bin/ app_install/main/bin/main app_install/db/ app_install/db/database/ app_install/db/bin/ app_install/db/bin/db app_install/common/ app_install/common/drivers/ app_install/common/drivers/do_802.ko app_install/common/drivers/do_704.ko app_install/common/drivers/do.ko app_install/common/lib/ app_install/common/lib/libutil.so.1 app_install/common/lib/libz.so.1 app_install/common/lib/libnss_nisplus.so.2 app_install/common/lib/libnss_hesiod-2.3.2.so app_install/common/lib/libW5100HB.so.0.0.6 app_install/common/lib/libcrypt.so.1 app_install/common/lib/libttf.so app_install/common/lib/libnss_dns.so.2 app_install/common/lib/libnss_nis-2.3.2.so app_install/common/lib/libnsl.so.1 app_install/common/lib/libsqlite3.so.0 app_install/common/lib/libresolv.so.2 app_install/common/lib/libnss_files.so app_install/common/lib/libresolv-2.3.2.so app_install/common/lib/libnss_compat-2.3.2.so app_install/common/lib/libpng.so.2.1.0.10rc1 app_install/common/lib/libnss_nisplus.so app_install/common/lib/libstdc++.so.6 app_install/common/lib/libdl.so.2 app_install/common/lib/libjpeg.so.62 app_install/common/lib/libnss_nis.so.2 app_install/common/lib/libnss_nisplus-2.3.2.so app_install/common/lib/libgcc_s.so app_install/common/lib/libsqlite3.so.0.8.6 app_install/common/lib/libz.so.1.2.3 app_install/common/lib/libnss_dns-2.3.2.so app_install/common/lib/libxml2.so.2.7.2 app_install/common/lib/libW5100HB.so.0.0.5 app_install/common/lib/libnss_compat.so.2 app_install/common/lib/libnss_dns.so app_install/common/lib/libxml2.so.2 app_install/common/lib/libpng.so.2 app_install/common/lib/libutil-2.3.2.so app_install/common/lib/libnss_compat.so app_install/common/lib/libnss_files-2.3.2.so app_install/common/lib/libnss_files.so.2 app_install/common/lib/libstdc++.so.6.0.1 app_install/common/lib/libgcc_s.so.1 app_install/common/lib/libW5100HB.so app_install/common/lib/libpthread.so.0 app_install/common/lib/libstdc++.so app_install/common/lib/librt.so app_install/common/lib/librt.so.1 app_install/common/lib/libc-2.3.2.so app_install/common/lib/libnss_hesiod.so app_install/common/lib/libc.so.6 app_install/common/lib/librt-2.3.2.so app_install/common/lib/libnss_nis.so app_install/common/lib/libjpeg.so.62.0.0 app_install/common/lib/libnss_hesiod.so.2 app_install/common/lib/libm.so.6 app_install/common/lib/libcrypt-2.3.2.so app_install/common/lib/libdl-2.3.2.so app_install/common/cfg/ app_install/common/cfg/W5100HB.xml app_install/common/cfg/report app_install/common/cfg/R&D_version.xml app_install/common/cfg/wtd app_install/common/cfg/root app_install/common/bin/ app_install/common/bin/power_heartbeat app_install/common/bin/timesync app_install/common/bin/wtd app_install/common/bin/set_ip app_install/common/dev/ app_install/common/dev/usb app_install/common/tools/ app_install/common/tools/serialtest_arm_static app_install/test/ app_install/gui/ app_install/gui/tslib/ app_install/gui/tslib/lib/ app_install/gui/tslib/lib/libts-0.0.so.0.1.1 app_install/gui/tslib/lib/libts.so app_install/gui/tslib/lib/pkgconfig/ app_install/gui/tslib/lib/pkgconfig/tslib-0.0.pc app_install/gui/tslib/lib/libts-1.0.so.0.0.0 app_install/gui/tslib/lib/libts-1.0.so.0 app_install/gui/tslib/lib/libts-0.0.so.0 app_install/gui/tslib/cfg/ app_install/gui/tslib/cfg/ts.conf app_install/gui/tslib/cfg/plugins/ app_install/gui/tslib/cfg/plugins/linear.so app_install/gui/tslib/cfg/plugins/mk712.so app_install/gui/tslib/cfg/plugins/dejitter.so app_install/gui/tslib/cfg/plugins/variance.so app_install/gui/tslib/cfg/plugins/corgi.so app_install/gui/tslib/cfg/plugins/h3600.so app_install/gui/tslib/cfg/plugins/input.so app_install/gui/tslib/cfg/plugins/ucb1x00.so app_install/gui/tslib/cfg/plugins/arctic2.so app_install/gui/tslib/cfg/plugins/pthres.so app_install/gui/tslib/cfg/plugins/collie.so app_install/gui/tslib/cfg/plugins/linear_h2200.so app_install/gui/tslib/bin/ app_install/gui/tslib/bin/ts_test app_install/gui/tslib/bin/ts_harvest app_install/gui/tslib/bin/ts_print_raw app_install/gui/tslib/bin/ts_calibrate app_install/gui/tslib/bin/ts_print app_install/gui/tslib/bin/ts_harvest.out app_install/gui/qt/ app_install/gui/qt/lib/ app_install/gui/qt/lib/libQtNetwork.so.4.5 app_install/gui/qt/lib/libQtTest.so.4.5 app_install/gui/qt/lib/libQtSvg.so.4.5.3 app_install/gui/qt/lib/libQtXml.so.4.5 app_install/gui/qt/lib/libQtScript.so.4.5 app_install/gui/qt/lib/libQtSql.so.4.5.3 app_install/gui/qt/lib/libQtCore.so.4.5.3 app_install/gui/qt/lib/libQtCore.so app_install/gui/qt/lib/libQtSvg.so.4.5 app_install/gui/qt/lib/libQtSql.so.4.5 app_install/gui/qt/lib/libQtGui.so.4.5.3 app_install/gui/qt/lib/libQtScript.so.4.5.3 app_install/gui/qt/lib/libQtSql.so.4 app_install/gui/qt/lib/libQtScriptTools.so.4 app_install/gui/qt/lib/libQtScript.so app_install/gui/qt/lib/libQtSvg.so app_install/gui/qt/lib/libQtScriptTools.so.4.5.3 app_install/gui/qt/lib/libQtTest.so.4 app_install/gui/qt/lib/libQtTest.so.4.5.3 app_install/gui/qt/lib/libQtGui.so app_install/gui/qt/lib/libQtNetwork.so app_install/gui/qt/lib/libQtXml.so.4.5.3 app_install/gui/qt/lib/libQtTest.so app_install/gui/qt/lib/libQtCore.so.4.5 app_install/gui/qt/lib/libQtXml.so app_install/gui/qt/lib/libQtGui.so.4 app_install/gui/qt/lib/libQtScript.so.4 app_install/gui/qt/lib/libQtSql.so app_install/gui/qt/lib/libQtNetwork.so.4.5.3 app_install/gui/qt/lib/libQtGui.so.4.5 app_install/gui/qt/lib/libQtXml.so.4 app_install/gui/qt/lib/libQtSvg.so.4 app_install/gui/qt/lib/libQtCore.so.4 app_install/gui/qt/lib/libQtScriptTools.so app_install/gui/qt/lib/libQtScriptTools.so.4.5 app_install/gui/qt/lib/libQtNetwork.so.4 app_install/gui/qt/cfg/ app_install/gui/qt/cfg/factors_name_unit.xml app_install/gui/qt/cfg/report app_install/gui/qt/cfg/process_show.xml app_install/gui/qt/bin/ app_install/gui/qt/bin/sqldrivers/ app_install/gui/qt/bin/sqldrivers/libqsqlite.so app_install/gui/qt/bin/gui app_install/gui/qt/res/ app_install/gui/qt/res/fonts/ app_install/gui/qt/res/fonts/wenquanyi.ttf [ 87.418426] UBI error: ubi_io_write: error -5 while writing 2048 bytes to PEB 1578:116736, written 0 bytes [ 87.428558] UBI warning: ubi_eba_write_leb: failed to write data to PEB 1578 [ 87.435943] UBI: recover PEB 1578, move data to PEB 3693 [ 87.469818] UBI error: ubi_io_write: error -5 while writing 512 bytes to PEB 3693:2048, written 0 bytes [ 87.479675] UBI warning: recover_peb: failed to write to PEB 3693 [ 87.486053] UBI: try again [ 87.488891] UBI: recover PEB 1578, move data to PEB 3694 [ 87.495635] UBI: run torture test for PEB 3693 [ 87.522155] UBI error: ubi_io_write: error -5 while writing 512 bytes to PEB 3694:2048, written 0 bytes [ 87.532104] UBI warning: recover_peb: failed to write to PEB 3694 [ 87.538604] UBI: try again [ 87.541503] UBI: recover PEB 1578, move data to PEB 3695 [ 87.695556] UBI error: ubi_io_write: error -5 while writing 131072 bytes to PEB 3693:0, written 120832 bytes [ 87.705993] UBI error: erase_worker: failed to erase PEB 3693, error -5 [ 87.712921] UBI: mark PEB 3693 as bad [ 87.730194] UBI: 15 PEBs left in the reserve [ 87.767791] UBI: run torture test for PEB 3694 [ 87.811981] UBI error: ubi_io_write: error -5 while writing 114688 bytes to PEB 3695:4096, written 0 bytes [ 87.822143] UBI warning: recover_peb: failed to write to PEB 3695 [ 87.828491] UBI: try again [ 87.831329] UBI: recover PEB 1578, move data to PEB 3696 [ 87.942504] UBI error: ubi_io_write: error -5 while writing 131072 bytes to PEB 3694:0, written 0 bytes [ 87.952392] UBI error: erase_worker: failed to erase PEB 3694, error -5 [ 87.959289] UBI: mark PEB 3694 as bad [ 87.974670] UBI: 14 PEBs left in the reserve [ 88.014495] UBI: run torture test for PEB 3695 [ 88.105010] UBI error: ubi_io_write: error -5 while writing 114688 bytes to PEB 3696:4096, written 106496 bytes [ 88.115600] UBI warning: recover_peb: failed to write to PEB 3696 [ 88.121948] UBI warning: ubi_ro_mode: switch to read-only mode [ 88.128051] UBIFS error (pid 711): ubifs_leb_write: writing 2048 bytes to LEB 13:112640 failed, error -5 [ 88.137969] UBIFS warning (pid 711): ubifs_ro_mode: switched to read-only mode, error -5 [ 88.146423] Backtrace: [ 88.149017] [<c00178f8>] (dump_backtrace+0x0/0x110) from [<c0404b24>] (dump_stack+0x18/0x1c) [ 88.157836] r6:0000000d r5:fffffffb r4:60008400 r3:c05cad08 [ 88.163757] [<c0404b0c>] (dump_stack+0x0/0x1c) from [<c01699cc>] (ubifs_ro_mode+0x74/0x78) [ 88.172393] [<c0169958>] (ubifs_ro_mode+0x0/0x78) from [<c0169bc0>] (ubifs_leb_write+0x9c/0xa4) [ 88.181488] r4:cf1a9000 r3:c05cad08 [ 88.185241] [<c0169b24>] (ubifs_leb_write+0x0/0xa4) from [<c016a860>] (ubifs_wbuf_write_nolock+0x228/0x350) [ 88.195404] r8:00000771 r7:00000771 r6:cf1a9000 r5:00000778 r4:cf144130 [ 88.202453] [<c016a638>] (ubifs_wbuf_write_nolock+0x0/0x350) from [<c01600cc>] (ubifs_jnl_write_data+0x17c/0x204) [ 88.213195] [<c015ff50>] (ubifs_jnl_write_data+0x0/0x204) from [<c0161738>] (do_writepage+0x118/0x180) [ 88.222900] [<c0161620>] (do_writepage+0x0/0x180) from [<c016186c>] (ubifs_writepage+0xcc/0x17c) [ 88.232086] r7:cf4899a8 r6:c063d920 r5:00000000 r4:00027b3e [ 88.238037] [<c01617a0>] (ubifs_writepage+0x0/0x17c) from [<c00807a0>] (__writepage+0x1c/0x64) [ 88.247039] [<c0080784>] (__writepage+0x0/0x64) from [<c0080f30>] (write_cache_pages+0x208/0x3d4) [ 88.256317] r4:ffffffff r3:c0080784 [ 88.260040] [<c0080d28>] (write_cache_pages+0x0/0x3d4) from [<c0081148>] (generic_writepages+0x4c/0x64) [ 88.269866] [<c00810fc>] (generic_writepages+0x0/0x64) from [<c0082174>] (do_writepages+0x3c/0x40) [ 88.279205] r5:cf1a9088 r4:cf4899a8 [ 88.282958] [<c0082138>] (do_writepages+0x0/0x40) from [<c00c63c4>] (writeback_single_inode+0xac/0x2c4) [ 88.292785] [<c00c6318>] (writeback_single_inode+0x0/0x2c4) from [<c00c693c>] (writeback_sb_inodes+0x1d8/0x2dc) [ 88.303314] r8:cf144400 r7:cf1a90c0 r6:cf309f34 r5:cf1a9088 r4:cf4899a8 [ 88.310150] r3:00000400 [ 88.312896] [<c00c6764>] (writeback_sb_inodes+0x0/0x2dc) from [<c00c6b1c>] (__writeback_inodes_wb+0xdc/0x114) [ 88.323242] [<c00c6a40>] (__writeback_inodes_wb+0x0/0x114) from [<c00c6d20>] (wb_writeback+0x1cc/0x1dc) [ 88.333068] [<c00c6b54>] (wb_writeback+0x0/0x1dc) from [<c00c7348>] (wb_do_writeback+0x124/0x1e4) [ 88.342346] [<c00c7224>] (wb_do_writeback+0x0/0x1e4) from [<c00c7494>] (bdi_writeback_thread+0x8c/0x16c) [ 88.352233] [<c00c7408>] (bdi_writeback_thread+0x0/0x16c) from [<c0054b34>] (kthread+0x90/0x94) [ 88.361358] [<c0054aa4>] (kthread+0x0/0x94) from [<c003f290>] (do_exit+0x0/0x67c) [ 88.369171] r6:c003f290 r5:c0054aa4 r4:cf89ff18 [ 88.373992] UBIFS error (pid 711): ubifs_wbuf_write_nolock: cannot write 1905 bytes to LEB 13:112640, error -5 [ 88.384460] UBIFS error (pid 711): do_writepage: cannot write page 14 of inode 11067, error -5 [ 88.393463] UBI error: do_sync_erase: read-only mode [ 88.398651] UBI error: erase_worker: failed to erase PEB 3695, error -30 [ 88.405670] UBI error: do_work: work failed with error code -30 [ 88.411834] UBI error: ubi_thread: ubi_bgt0d: work failed with error code -30 tar: write error: Read-only file system /usr # [ 88.427703] UBIFS error (pid 711): make_reservation: cannot reserve 160 bytes in jhead 1, error -30 [ 88.437194] UBIFS error (pid 711): ubifs_write_inode: can't write inode 11069, error -30 [ 88.445678] UBIFS error (pid 711): make_reservation: cannot reserve 160 bytes in jhead 1, error -30 [ 88.455139] UBIFS error (pid 711): ubifs_write_inode: can't write inode 11071, error -30 [ 88.463592] UBIFS error (pid 711): make_reservation: cannot reserve 160 bytes in jhead 1, error -30 [ 88.473052] UBIFS error (pid 711): ubifs_write_inode: can't write inode 11072, error -30 [ 88.481506] UBIFS error (pid 711): make_reservation: cannot reserve 160 bytes in jhead 1, error -30 [ 88.490936] UBIFS error (pid 711): ubifs_write_inode: can't write inode 11076, error -30 [ 88.499420] UBIFS error (pid 711): make_reservation: cannot reserve 160 bytes in jhead 1, error -30 [ 88.508850] UBIFS error (pid 711): ubifs_write_inode: can't write inode 11077, error -30 [ 88.517333] UBIFS error (pid 711): make_reservation: cannot reserve 160 bytes in jhead 1, error -30 [ 88.526763] UBIFS error (pid 711): ubifs_write_inode: can't write inode 11078, error -30 [ 88.535247] UBIFS error (pid 711): make_reservation: cannot reserve 160 bytes in jhead 1, error -30 [ 88.544677] UBIFS error (pid 711): ubifs_write_inode: can't write inode 11084, error -30 [ 88.553131] UBIFS error (pid 711): make_reservation: cannot reserve 160 bytes in jhead 1, error -30 [ 88.562591] UBIFS error (pid 711): ubifs_write_inode: can't write inode 11086, error -30 [ 88.571044] UBIFS error (pid 711): make_reservation: cannot reserve 160 bytes in jhead 1, error -30 [ 88.580505] UBIFS error (pid 711): ubifs_write_inode: can't write inode 11087, error -30 [ 88.588958] UBIFS error (pid 711): make_reservation: cannot reserve 160 bytes in jhead 1, error -30 [ 88.598388] UBIFS error (pid 711): ubifs_write_inode: can't write inode 11088, error -30 [ 88.606933] UBIFS error (pid 711): make_reservation: cannot reserve 160 bytes in jhead 1, error -30 [ 88.616394] UBIFS error (pid 711): ubifs_write_inode: can't write inode 11089, error -30 [ 88.624847] UBIFS error (pid 711): make_reservation: cannot reserve 160 bytes in jhead 1, error -30 [ 88.634307] UBIFS error (pid 711): ubifs_write_inode: can't write inode 11090, error -30 [ 88.642761] UBIFS error (pid 711): make_reservation: cannot reserve 160 bytes in jhead 1, error -30 [ 88.652191] UBIFS error (pid 711): ubifs_write_inode: can't write inode 11095, error -30 [ 88.660675] UBIFS error (pid 711): make_reservation: cannot reserve 160 bytes in jhead 1, error -30 [ 88.670104] UBIFS error (pid 711): ubifs_write_inode: can't write inode 11097, error -30 [ 88.678558] UBIFS error (pid 711): make_reservation: cannot reserve 160 bytes in jhead 1, error -30 [ 88.688110] UBIFS error (pid 711): ubifs_write_inode: can't write inode 11099, error -30 [ 88.696655] UBIFS error (pid 711): make_reservation: cannot reserve 160 bytes in jhead 1, error -30 [ 88.706176] UBIFS error (pid 711): ubifs_write_inode: can't write inode 11100, error -30 [ 88.714843] UBIFS error (pid 711): make_reservation: cannot reserve 160 bytes in jhead 1, error -30 [ 88.724365] UBIFS error (pid 711): ubifs_write_inode: can't write inode 11102, error -30 [ 88.733001] UBIFS error (pid 711): make_reservation: cannot reserve 160 bytes in jhead 1, error -30 [ 88.742492] UBIFS error (pid 711): ubifs_write_inode: can't write inode 11106, error -30 [ 88.751037] UBIFS error (pid 711): make_reservation: cannot reserve 160 bytes in jhead 1, error -30 [ 88.760559] UBIFS error (pid 711): ubifs_write_inode: can't write inode 11109, error -30 [ 88.769165] UBIFS error (pid 711): make_reservation: cannot reserve 160 bytes in jhead 1, error -30 [ 88.778686] UBIFS error (pid 711): ubifs_write_inode: can't write inode 11111, error -30 [ 88.787231] UBIFS error (pid 711): make_reservation: cannot reserve 160 bytes in jhead 1, error -30 [ 88.796752] UBIFS error (pid 711): ubifs_write_inode: can't write inode 11113, error -30 [ 88.805480] UBIFS error (pid 711): make_reservation: cannot reserve 160 bytes in jhead 1, error -30 [ 88.815002] UBIFS error (pid 711): ubifs_write_inode: can't write inode 11114, error -30 [ 88.823577] UBIFS error (pid 711): make_reservation: cannot reserve 160 bytes in jhead 1, error -30 [ 88.833099] UBIFS error (pid 711): ubifs_write_inode: can't write inode 11115, error -30 [ 88.841705] UBIFS error (pid 711): make_reservation: cannot reserve 160 bytes in jhead 1, error -30 [ 88.851226] UBIFS error (pid 711): ubifs_write_inode: can't write inode 11116, error -30 [ 88.859832] UBIFS error (pid 711): make_reservation: cannot reserve 160 bytes in jhead 1, error -30 [ 88.869354] UBIFS error (pid 711): ubifs_write_inode: can't write inode 11117, error -30 [ 88.877960] UBIFS error (pid 711): make_reservation: cannot reserve 160 bytes in jhead 1, error -30 [ 88.887481] UBIFS error (pid 711): ubifs_write_inode: can't write inode 11118, error -30 [ 88.897033] UBIFS error (pid 711): make_reservation: cannot reserve 160 bytes in jhead 1, error -30 [ 88.906585] UBIFS error (pid 711): ubifs_write_inode: can't write inode 11119, error -30 [ 88.915222] UBIFS error (pid 711): make_reservation: cannot reserve 160 bytes in jhead 1, error -30 [ 88.924743] UBIFS error (pid 711): ubifs_write_inode: can't write inode 11120, error -30 [ 88.933258] UBIFS error (pid 711): make_reservation: cannot reserve 160 bytes in jhead 1, error -30 [ 88.942779] UBIFS error (pid 711): ubifs_write_inode: can't write inode 11121, error -30 [ 88.951416] UBIFS error (pid 711): make_reservation: cannot reserve 160 bytes in jhead 1, error -30 [ 88.960937] UBIFS error (pid 711): ubifs_write_inode: can't write inode 11122, error -30 [ 88.969512] UBIFS error (pid 711): make_reservation: cannot reserve 160 bytes in jhead 1, error -30 [ 88.979034] UBIFS error (pid 711): ubifs_write_inode: can't write inode 11123, error -30 [ 88.987609] UBIFS error (pid 711): make_reservation: cannot reserve 160 bytes in jhead 1, error -30 [ 88.997100] UBIFS error (pid 711): ubifs_write_inode: can't write inode 11124, error -30 [ 89.005767] UBIFS error (pid 711): make_reservation: cannot reserve 160 bytes in jhead 1, error -30 [ 89.015289] UBIFS error (pid 711): ubifs_write_inode: can't write inode 11126, error -30 [ 89.023834] UBIFS error (pid 711): make_reservation: cannot reserve 160 bytes in jhead 1, error -30 [ 89.033355] UBIFS error (pid 711): ubifs_write_inode: can't write inode 10978, error -30 [ 89.041900] UBIFS error (pid 711): make_reservation: cannot reserve 160 bytes in jhead 1, error -30 [ 89.051452] UBIFS error (pid 711): ubifs_write_inode: can't write inode 10979, error -30 [ 89.060852] UBIFS error (pid 711): make_reservation: cannot reserve 160 bytes in jhead 1, error -30 [ 89.070373] UBIFS error (pid 711): ubifs_write_inode: can't write inode 10980, error -30 [ 89.079040] UBIFS error (pid 711): make_reservation: cannot reserve 160 bytes in jhead 1, error -30 [ 89.088562] UBIFS error (pid 711): ubifs_write_inode: can't write inode 11127, error -30 [ 89.097198] UBIFS error (pid 711): make_reservation: cannot reserve 160 bytes in jhead 1, error -30 [ 89.106719] UBIFS error (pid 711): ubifs_write_inode: can't write inode 11129, error -30 [ 89.115264] UBIFS error (pid 711): make_reservation: cannot reserve 160 bytes in jhead 1, error -30 [ 89.124786] UBIFS error (pid 711): ubifs_write_inode: can't write inode 11130, error -30 [ 89.133392] UBIFS error (pid 711): make_reservation: cannot reserve 160 bytes in jhead 1, error -30 [ 89.142913] UBIFS error (pid 711): ubifs_write_inode: can't write inode 11133, error -30 [ 89.151458] UBIFS error (pid 711): make_reservation: cannot reserve 160 bytes in jhead 1, error -30 [ 89.160949] UBIFS error (pid 711): ubifs_write_inode: can't write inode 11134, error -30 [ 89.169525] UBIFS error (pid 711): make_reservation: cannot reserve 160 bytes in jhead 1, error -30 [ 89.179046] UBIFS error (pid 711): ubifs_write_inode: can't write inode 11135, error -30 [ 89.187561] UBIFS error (pid 711): make_reservation: cannot reserve 160 bytes in jhead 1, error -30 [ 89.197082] UBIFS error (pid 711): ubifs_write_inode: can't write inode 11136, error -30 [ 89.205749] UBIFS error (pid 711): make_reservation: cannot reserve 160 bytes in jhead 1, error -30 [ 89.215270] UBIFS error (pid 711): ubifs_write_inode: can't write inode 11137, error -30 [ 89.223815] UBIFS error (pid 711): make_reservation: cannot reserve 160 bytes in jhead 1, error -30 [ 89.233337] UBIFS error (pid 711): ubifs_write_inode: can't write inode 11138, error -30 [ 89.241882] UBIFS error (pid 711): make_reservation: cannot reserve 160 bytes in jhead 1, error -30 [ 89.251403] UBIFS error (pid 711): ubifs_write_inode: can't write inode 11139, error -30 [ 89.259979] UBIFS error (pid 711): make_reservation: cannot reserve 160 bytes in jhead 1, error -30 [ 89.269439] UBIFS error (pid 711): ubifs_write_inode: can't write inode 11140, error -30 [ 89.277954] UBIFS error (pid 711): make_reservation: cannot reserve 160 bytes in jhead 1, error -30 [ 89.287475] UBIFS error (pid 711): ubifs_write_inode: can't write inode 11141, error -30 [ 89.295989] UBIFS error (pid 711): make_reservation: cannot reserve 160 bytes in jhead 1, error -30 [ 89.305511] UBIFS error (pid 711): ubifs_write_inode: can't write inode 11142, error -30 [ 89.314025] UBIFS error (pid 711): make_reservation: cannot reserve 160 bytes in jhead 1, error -30 [ 89.323547] UBIFS error (pid 711): ubifs_write_inode: can't write inode 11143, error -30 [ 89.332122] UBIFS error (pid 711): make_reservation: cannot reserve 160 bytes in jhead 1, error -30 [ 89.341644] UBIFS error (pid 711): ubifs_write_inode: can't write inode 11144, error -30 [ 89.350219] UBIFS error (pid 711): make_reservation: cannot reserve 160 bytes in jhead 1, error -30 [ 89.359680] UBIFS error (pid 711): ubifs_write_inode: can't write inode 11145, error -30 [ 89.368255] UBIFS error (pid 711): make_reservation: cannot reserve 160 bytes in jhead 1, error -30 [ 89.377777] UBIFS error (pid 711): ubifs_write_inode: can't write inode 11146, error -30 [ 89.386322] UBIFS error (pid 711): make_reservation: cannot reserve 160 bytes in jhead 1, error -30 [ 89.395843] UBIFS error (pid 711): ubifs_write_inode: can't write inode 11147, error -30 [ 89.404449] UBIFS error (pid 711): make_reservation: cannot reserve 160 bytes in jhead 1, error -30 [ 89.413940] UBIFS error (pid 711): ubifs_write_inode: can't write inode 11148, error -30 [ 89.422729] UBIFS error (pid 711): make_reservation: cannot reserve 160 bytes in jhead 1, error -30 [ 89.432281] UBIFS error (pid 711): ubifs_write_inode: can't write inode 11149, error -30 [ 89.441009] UBIFS error (pid 711): make_reservation: cannot reserve 160 bytes in jhead 1, error -30 [ 89.450531] UBIFS error (pid 711): ubifs_write_inode: can't write inode 11150, error -30 [ 89.459106] UBIFS error (pid 711): make_reservation: cannot reserve 160 bytes in jhead 1, error -30 [ 89.468597] UBIFS error (pid 711): ubifs_write_inode: can't write inode 11151, error -30 [ 89.477233] UBIFS error (pid 711): make_reservation: cannot reserve 160 bytes in jhead 1, error -30 [ 89.486694] UBIFS error (pid 711): ubifs_write_inode: can't write inode 11154, error -30 [ 89.495147] UBIFS error (pid 711): make_reservation: cannot reserve 160 bytes in jhead 1, error -30 [ 89.504608] UBIFS error (pid 711): ubifs_write_inode: can't write inode 11157, error -30 [ 89.513061] UBIFS error (pid 711): make_reservation: cannot reserve 160 bytes in jhead 1, error -30 [ 89.522491] UBIFS error (pid 711): ubifs_write_inode: can't write inode 11158, error -30 [ 89.530944] UBIFS error (pid 711): make_reservation: cannot reserve 160 bytes in jhead 1, error -30 [ 89.540405] UBIFS error (pid 711): ubifs_write_inode: can't write inode 11162, error -30 [ 89.548858] UBIFS error (pid 711): make_reservation: cannot reserve 160 bytes in jhead 1, error -30 [ 89.558319] UBIFS error (pid 711): ubifs_write_inode: can't write inode 11163, error -30 [ 89.566772] UBIFS error (pid 711): make_reservation: cannot reserve 160 bytes in jhead 1, error -30 [ 89.576202] UBIFS error (pid 711): ubifs_write_inode: can't write inode 11168, error -30 [ 89.584686] UBIFS error (pid 711): make_reservation: cannot reserve 160 bytes in jhead 1, error -30 [ 89.594116] UBIFS error (pid 711): ubifs_write_inode: can't write inode 11170, error -30 [ 89.602569] UBIFS error (pid 711): make_reservation: cannot reserve 160 bytes in jhead 1, error -30 [ 89.612030] UBIFS error (pid 711): ubifs_write_inode: can't write inode 11173, error -30 [ 89.620513] UBIFS error (pid 711): make_reservation: cannot reserve 160 bytes in jhead 1, error -30 [ 89.629974] UBIFS error (pid 711): ubifs_write_inode: can't write inode 11180, error -30 CCCCCCCC U-Boot SPL 2011.09-svn (Jan 24 2013 - 11:34:11) Texas Instruments Revision detection unimplemented U-Boot 2011.09-svn (Jan 30 2013 - 17:27:19) I2C: ready DRAM: 256 MiB WARNING: Caches not enabled NAND: HW ECC Hamming Code selected 512 MiB MMC: OMAP SD/MMC: 0 Net: cpsw Hit any key to stop autoboot: 3 2 1 0 Card did not respond to voltage select! Booting from nand ... HW ECC BCH8 Selected NAND read: device 0 offset 0x280000, size 0x300000 3145728 bytes read: OK HW ECC Hamming Code selected NAND read: device 0 offset 0x700000, size 0x80000 524288 bytes read: OK ## Booting kernel from Legacy Image at 80007fc0 ... Image Name: Linux-3.2.0 Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 3043216 Bytes = 2.9 MiB Load Address: 80008000 Entry Point: 80008000 Verifying Checksum ... OK XIP Kernel Image ... OK OK Starting kernel ... Uncompressing Linux... done, booting the kernel. [ 0.000000] Linux version 3.2.0 (zlh@zlh-Desktop) (gcc version 4.5.3 20110311 (prerelease) (GCC) ) #336 Thu Jan 31 22:17:39 CST 2013 [ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c53c7d [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache [ 0.000000] Machine: am335xevm [ 0.000000] Memory policy: ECC disabled, Data cache writeback [ 0.000000] AM335X ES1.0 (neon ) [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 64262 [ 0.000000] Kernel command line: console=ttyO0,115200n8 root=ubi0:rootfs rw ubi.mtd=7,2048 noinitrd rootfstype=ubifs rootwait=1 ip=none mem=253M [ 0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes) [ 0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes) [ 0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes) [ 0.000000] Memory: 253MB = 253MB total [ 0.000000] Memory: 250468k/250468k available, 8604k reserved, 0K highmem [ 0.000000] Virtual kernel memory layout: [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB) [ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) [ 0.000000] vmalloc : 0xd0000000 - 0xff000000 ( 752 MB) [ 0.000000] lowmem : 0xc0000000 - 0xcfd00000 ( 253 MB) [ 0.000000] modules : 0xbf000000 - 0xc0000000 ( 16 MB) [ 0.000000] .text : 0xc0008000 - 0xc056d000 (5524 kB) [ 0.000000] .init : 0xc056d000 - 0xc05aa000 ( 244 kB) [ 0.000000] .data : 0xc05aa000 - 0xc0604c88 ( 364 kB) [ 0.000000] .bss : 0xc0604cac - 0xc062a0fc ( 150 kB) [ 0.000000] NR_IRQS:396 [ 0.000000] IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts [ 0.000000] Total of 128 interrupts on 1 active controller [ 0.000000] OMAP clockevent source: GPTIMER2 at 24000000 Hz [ 0.000000] OMAP clocksource: GPTIMER1 at 32768 Hz [ 0.000000] sched_clock: 32 bits at 32kHz, resolution 30517ns, wraps every 131071999ms [ 0.000000] Console: colour dummy device 80x30 [ 0.000152] Calibrating delay loop... 718.02 BogoMIPS (lpj=3590144) [ 0.058929] pid_max: default: 32768 minimum: 301 [ 0.059082] Security Framework initialized [ 0.059173] Mount-cache hash table entries: 512 [ 0.059570] CPU: Testing write buffer coherency: ok [ 0.079589] omap_hwmod: gfx: failed to hardreset [ 0.095855] omap_hwmod: pruss: failed to hardreset [ 0.096954] print_constraints: dummy: [ 0.097320] NET: Registered protocol family 16 [ 0.099517] OMAP GPIO hardware version 0.1 [ 0.102050] omap_mux_init: Add partition: #1: core, flags: 0 [ 0.103912] omap_i2c.1: alias fck already exists [ 0.104125] Detected a daughter card on AM335x EVM.. [ 0.104156] The board is general purpose EVM in profile 0 [ 0.104156] Found invalid GP EVM revision, falling back to Rev1.1Alcdc_init, 1070 [ 0.104400] lcdc_init, 1072 [ 0.104461] da8xx_lcdc.0: alias fck already exists [ 0.104675] TSC connected to beta GP EVM [ 0.105834] *************am335x_register_mcasp, 208 [ 0.105895] davinci-mcasp.1: alias fck already exists [ 0.106170] omap_hsmmc.0: alias fck already exists [ 0.108062] omap2_mcspi.1: alias fck already exists [ 0.108276] omap2_mcspi.2: alias fck already exists [ 0.108551] edma.0: alias fck already exists [ 0.108581] edma.0: alias fck already exists [ 0.108581] edma.0: alias fck already exists [ 0.133819] bio: create slab <bio-0> at 0 [ 0.136016] SCSI subsystem initialized [ 0.137664] usbcore: registered new interface driver usbfs [ 0.137969] usbcore: registered new interface driver hub [ 0.138183] usbcore: registered new device driver usb [ 0.138336] musb-ti81xx musb-ti81xx: musb0, board_mode=0x31, plat_mode=0x1 [ 0.138610] musb-ti81xx musb-ti81xx: musb1, board_mode=0x31, plat_mode=0x3 [ 0.139831] omap_i2c omap_i2c.1: bus 1 rev2.4.0 at 100 kHz [ 0.141357] Advanced Linux Sound Architecture Driver Version 1.0.24. [ 0.142425] Switching to clocksource gp timer [ 0.157836] musb-hdrc: version 6.0, ?dma?, otg (peripheral+host) [ 0.158020] musb-hdrc musb-hdrc.0: dma type: pio [ 0.158477] musb-hdrc musb-hdrc.0: MUSB HDRC host driver [ 0.158599] musb-hdrc musb-hdrc.0: new USB bus registered, assigned bus number 1 [ 0.158721] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 [ 0.158752] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 0.158752] usb usb1: Product: MUSB HDRC host driver [ 0.158782] usb usb1: Manufacturer: Linux 3.2.0 musb-hcd [ 0.158782] usb usb1: SerialNumber: musb-hdrc.0 [ 0.159637] hub 1-0:1.0: USB hub found [ 0.159667] hub 1-0:1.0: 1 port detected [ 0.160217] musb-hdrc musb-hdrc.0: USB Host mode controller at d0034000 using PIO, IRQ 18 [ 0.160400] musb-hdrc musb-hdrc.1: dma type: pio [ 0.161285] musb-hdrc musb-hdrc.1: USB OTG mode controller at d0036800 using PIO, IRQ 19 [ 0.161682] NET: Registered protocol family 2 [ 0.161865] IP route cache hash table entries: 2048 (order: 1, 8192 bytes) [ 0.162170] TCP established hash table entries: 8192 (order: 4, 65536 bytes) [ 0.162322] TCP bind hash table entries: 8192 (order: 3, 32768 bytes) [ 0.162414] TCP: Hash tables configured (established 8192 bind 8192) [ 0.162445] TCP reno registered [ 0.162445] UDP hash table entries: 256 (order: 0, 4096 bytes) [ 0.162536] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes) [ 0.162750] NET: Registered protocol family 1 [ 0.162994] RPC: Registered named UNIX socket transport module. [ 0.163024] RPC: Registered udp transport module. [ 0.163024] RPC: Registered tcp transport module. [ 0.163024] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.163269] NetWinder Floating Point Emulator V0.97 (double precision) [ 0.163513] omap-gpmc omap-gpmc: GPMC revision 6.0 [ 0.163513] Registering NAND on CS0 [ 0.175750] VFS: Disk quotas dquot_6.5.2 [ 0.175842] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) [ 0.176330] msgmni has been set to 489 [ 0.177032] io scheduler noop registered [ 0.177062] io scheduler deadline registered [ 0.177124] io scheduler cfq registered (default) [ 0.178588] da8xx_lcdc da8xx_lcdc.0: GLCD: Found TFC_S9700RTWV35TR_01B panel [ 0.274322] Console: switching to colour frame buffer device 100x30 [ 0.287628] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled [ 0.310363] serial8250.0: ttyE0 at MMIO 0x2000040 (irq = 277) is a 16550A [ 0.330993] serial8250.0: ttyE1 at MMIO 0x2000080 (irq = 273) is a 16550A [ 0.351562] serial8250.0: ttyE2 at MMIO 0x2000100 (irq = 269) is a 16550A [ 0.372192] serial8250.0: ttyE3 at MMIO 0x2000200 (irq = 178) is a 16550A [ 0.373718] omap_uart.0: ttyO0 at MMIO 0x44e09000 (irq = 72) is a OMAP UART0 [ 1.008331] console [ttyO0] enabled [ 1.012573] omap_uart.1: ttyO1 at MMIO 0x48022000 (irq = 73) is a OMAP UART1 [ 1.020385] omap_uart.2: ttyO2 at MMIO 0x48024000 (irq = 74) is a OMAP UART2 [ 1.028198] omap_uart.3: ttyO3 at MMIO 0x481a6000 (irq = 44) is a OMAP UART3 [ 1.036010] omap_uart.4: ttyO4 at MMIO 0x481a8000 (irq = 45) is a OMAP UART4 [ 1.043975] omap_uart.5: ttyO5 at MMIO 0x481aa000 (irq = 46) is a OMAP UART5 [ 1.061126] brd: module loaded [ 1.069274] loop: module loaded [ 1.072753] i2c-core: driver [tsl2550] using legacy suspend method [ 1.079254] i2c-core: driver [tsl2550] using legacy resume method [ 1.087219] mtdoops: mtd device (mtddev=name/number) must be supplied [ 1.094573] omap2-nand driver initializing [ 1.099243] NAND device: Manufacturer ID: 0xec, Chip ID: 0xdc (Samsung NAND 512MiB 3,3V 8-bit) [ 1.108489] Creating 8 MTD partitions on "omap2-nand.0": [ 1.114074] 0x000000000000-0x000000020000 : "SPL" [ 1.120452] 0x000000020000-0x000000040000 : "SPL.backup1" [ 1.127593] 0x000000040000-0x000000060000 : "SPL.backup2" [ 1.134582] 0x000000060000-0x000000080000 : "SPL.backup3" [ 1.141540] 0x000000080000-0x000000260000 : "U-Boot" [ 1.148834] 0x000000260000-0x000000280000 : "U-Boot Env" [ 1.155670] 0x000000280000-0x000000780000 : "Kernel" [ 1.164184] 0x000000780000-0x000020000000 : "File System" [ 1.381134] UBI: attaching mtd7 to ubi0 [ 1.385192] UBI: physical eraseblock size: 131072 bytes (128 KiB) [ 1.391723] UBI: logical eraseblock size: 126976 bytes [ 1.397369] UBI: smallest flash I/O unit: 2048 [ 1.402282] UBI: sub-page size: 512 [ 1.407104] UBI: VID header offset: 2048 (aligned 2048) [ 1.413391] UBI: data offset: 4096 [ 1.583099] usb 1-1: new high-speed USB device number 2 using musb-hdrc [ 1.742706] usb 1-1: New USB device found, idVendor=0951, idProduct=1653 [ 1.749725] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [ 1.757171] usb 1-1: Product: DT 100 G2 [ 1.761169] usb 1-1: Manufacturer: Kingston [ 1.765533] usb 1-1: SerialNumber: 001CC0EC321ABB3117160012 [ 6.416534] UBI: max. sequence number: 1642 [ 6.439239] UBI warning: print_rsvd_warning: cannot reserve enough PEBs for bad PEB handling, reserved 14, need 40 [ 6.452819] UBI: attached mtd7 to ubi0 [ 6.456787] UBI: MTD device name: "File System" [ 6.462524] UBI: MTD device size: 504 MiB [ 6.467712] UBI: number of good PEBs: 4010 [ 6.472625] UBI: number of bad PEBs: 26 [ 6.477355] UBI: number of corrupted PEBs: 0 [ 6.481994] UBI: max. allowed volumes: 128 [ 6.486816] UBI: wear-leveling threshold: 4096 [ 6.491699] UBI: number of internal volumes: 1 [ 6.496337] UBI: number of user volumes: 3 [ 6.500976] UBI: available PEBs: 0 [ 6.505615] UBI: total number of reserved PEBs: 4010 [ 6.510803] UBI: number of PEBs reserved for bad PEB handling: 14 [ 6.517150] UBI: max/mean erase counter: 5/1 [ 6.521606] UBI: image sequence number: 531848417 [ 6.526733] UBI: background thread "ubi_bgt0d" started, PID 566 [ 6.537231] CAN device driver interface [ 6.541229] CAN bus driver for Bosch D_CAN controller 1.0 [ 6.593109] davinci_mdio davinci_mdio.0: davinci mdio revision 1.6 [ 6.599578] davinci_mdio davinci_mdio.0: detected phy mask fffffffd [ 6.606842] davinci_mdio.0: probed [ 6.610412] davinci_mdio davinci_mdio.0: phy[1]: device 0:01, driver unknown [ 6.618164] usbcore: registered new interface driver zd1201 [ 6.624176] usbcore: registered new interface driver cdc_ether [ 6.630432] usbcore: registered new interface driver cdc_eem [ 6.636505] usbcore: registered new interface driver dm9601 [ 6.642364] cdc_ncm: 04-Aug-2011 [ 6.645904] usbcore: registered new interface driver cdc_ncm [ 6.651824] Initializing USB Mass Storage driver... [ 6.657196] scsi0 : usb-storage 1-1:1.0 [ 6.662139] usbcore: registered new interface driver usb-storage [ 6.668457] USB Mass Storage support registered. [ 6.673736] mousedev: PS/2 mouse device common for all mice [ 6.680694] input: ti-tsc-adcc as /devices/platform/omap/tsc/input/input0 [ 6.691864] rtc-ds1307 1-0068: rtc core: registered ds1340 as rtc0 [ 6.698516] i2c /dev entries driver [ 6.702575] Linux video capture interface: v2.00 [ 6.707763] usbcore: registered new interface driver uvcvideo [ 6.713775] USB Video Class driver (1.1.1) [ 6.720062] OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec [ 6.726623] _regulator_get: deviceless supply vdd_mpu not found, using dummy regulator [ 6.735351] cpuidle: using governor ladder [ 6.740081] cpuidle: using governor menu [ 6.748229] usbcore: registered new interface driver usbhid [ 6.754089] usbhid: USB HID core driver [ 6.758666] usbcore: registered new interface driver snd-usb-audio [ 6.765930] ****************aic3x_i2c_probe, 1527 [ 6.770904] *****************aic3x_i2c_probe, 1548, 0 [ 6.776580] **************davinci_mcasp_probe, 918 [ 6.781646] ***************snd_soc_register_dai, 2942 [ 6.786956] ***************snd_soc_register_dai, 2965 [ 6.792205] *********ret: 0 [ 6.795623] ALSA device list: [ 6.798706] No soundcards found. [ 6.802246] oprofile: hardware counters not available [ 6.807556] oprofile: using timer interrupt. [ 6.812042] nf_conntrack version 0.5.0 (3913 buckets, 15652 max) [ 6.818817] ip_tables: (C) 2000-2006 Netfilter Core Team [ 6.824493] TCP cubic registered [ 6.827880] NET: Registered protocol family 17 [ 6.832519] can: controller area network core (rev 20090105 abi 8) [ 6.839080] NET: Registered protocol family 29 [ 6.843719] can: raw protocol (rev 20090105) [ 6.848175] can: broadcast manager protocol (rev 20090105 t) [ 6.854125] 8021q: 802.1Q VLAN Support v1.8 [ 6.858520] Registering the dns_resolver key type [ 6.863525] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3 [ 6.871520] ThumbEE CPU extension supported. [ 6.876037] mux: Failed to setup hwmod io irq -22 [ 6.881591] Power Management for AM33XX family [ 6.886474] Trying to load am335x-pm-firmware.bin (60 secs timeout) [ 6.893157] Copied the M3 firmware to UMEM [ 6.897430] omap_hwmod: wkup_m3: wkup_m3: hwmod data error: OMAP4 does not support st_shift [ 6.911468] clock: disabling unused clocks to save power [ 6.918975] Detected MACID=0:18:30:a:d3:bf [ 6.924316] cpsw: Detected MACID = 00:18:30:0a:d3:c0 [ 6.931640] rtc-ds1307 1-0068: setting system clock to 2013-01-31 17:35:41 UTC (1359653741) [ 7.017120] UBIFS: recovery needed [ 7.254455] UBIFS: recovery completed [ 7.258300] UBIFS: mounted UBI device 0, volume 0, name "rootfs" [ 7.264587] UBIFS: file system size: 3809280 bytes (3720 KiB, 3 MiB, 30 LEBs) [ 7.272216] UBIFS: journal size: 1142785 bytes (1116 KiB, 1 MiB, 8 LEBs) [ 7.279754] UBIFS: media format: w4/r0 (latest is w4/r0) [ 7.285858] UBIFS: default compressor: lzo [ 7.290100] UBIFS: reserved for root: 0 bytes (0 KiB) [ 7.296813] VFS: Mounted root (ubifs filesystem) on device 0:13. [ 7.303497] Freeing init memory: 244K wait please,prepare the system... mount: can't find / in /proc/mounts unknow platform...,please check your setting! configuring network parameters and ENV VAR... route: SIOCADDRT: Network is unreachable mounting app partition,wait please... [ 7.667785] UBIFS: recovery needed [ 7.825927] scsi 0:0:0:0: Direct-Access Kingston DT 100 G2 PMAP PQ: 0 ANSI: 0 CCS [ 8.447235] sd 0:0:0:0: [sda] 15430464 512-byte logical blocks: (7.90 GB/7.35 GiB) [ 8.464172] sd 0:0:0:0: [sda] Write Protect is off [ 8.473632] sd 0:0:0:0: [sda] No Caching mode page present [ 8.479370] sd 0:0:0:0: [sda] Assuming drive cache: write through [ 8.486083] UBI error: ubi_io_write: error -5 while writing 126976 bytes to PEB 3713:4096, written 38912 bytes [ 8.496520] UBI warning: ubi_eba_atomic_leb_change: failed to write 126976 bytes of data to PEB 3713 [ 8.506072] UBI: try another PEB [ 8.513000] sd 0:0:0:0: [sda] No Caching mode page present [ 8.518768] sd 0:0:0:0: [sda] Assuming drive cache: write through [ 8.525421] UBI error: ubi_io_write: error -5 while writing 126976 bytes to PEB 3714:4096, written 4096 bytes [ 8.535888] UBI warning: ubi_eba_atomic_leb_change: failed to write 126976 bytes of data to PEB 3714 [ 8.545501] UBI: try another PEB [ 8.573791] sda: sda1 [ 8.586517] sd 0:0:0:0: [sda] No Caching mode page present [ 8.592254] sd 0:0:0:0: [sda] Assuming drive cache: write through [ 8.598663] sd 0:0:0:0: [sda] Attached SCSI removable disk [ 8.604431] UBI error: ubi_io_write: error -5 while writing 126976 bytes to PEB 3715:4096, written 88064 bytes [ 8.614898] UBI warning: ubi_eba_atomic_leb_change: failed to write 126976 bytes of data to PEB 3715 [ 8.624420] UBI: try another PEB [ 8.766082] UBI: run torture test for PEB 3713 [ 9.151275] UBI: PEB 3713 passed torture test, do not mark it as bad [ 9.159881] UBI: run torture test for PEB 3714 [ 9.544342] UBI: PEB 3714 passed torture test, do not mark it as bad [ 9.552917] UBI: run torture test for PEB 3715 [ 9.937377] UBI: PEB 3715 passed torture test, do not mark it as bad [ 9.960266] UBIFS: recovery completed [ 9.964111] UBIFS: mounted UBI device 0, volume 1, name "app" [ 9.970123] UBIFS: file system size: 49520640 bytes (48360 KiB, 47 MiB, 390 LEBs) [ 9.978118] UBIFS: journal size: 6729728 bytes (6572 KiB, 6 MiB, 53 LEBs) [ 9.985748] UBIFS: media format: w4/r0 (latest is w4/r0) [ 9.991821] UBIFS: default compressor: lzo [ 9.996093] UBIFS: reserved for root: 0 bytes (0 KiB) success!go on... mounting database partition,wait please... [ 10.088836] UBIFS: recovery needed [ 10.264282] UBIFS: recovery completed [ 10.268127] UBIFS: mounted UBI device 0, volume 2, name "db" [ 10.274047] UBIFS: file system size: 447590400 bytes (437100 KiB, 426 MiB, 3525 LEBs) [ 10.282409] UBIFS: journal size: 9023488 bytes (8812 KiB, 8 MiB, 72 LEBs) [ 10.290039] UBIFS: media format: w4/r0 (latest is w4/r0) [ 10.296142] UBIFS: default compressor: lzo [ 10.300384] UBIFS: reserved for root: 0 bytes (0 KiB) success!,go on... unknow platform...,please check your setting! starting our applications... product unknow platform...,please check your setting! unknow platform...,please check your setting! ~ # crond[692]: crond: crond (busybox 1.19.4) started, log level 8 unknow platform...,please check your setting! ./main: error while loading shared libraries: /usr/app_install//common/lib/libxml2.so.2: file too short httpd: chdir(/usr/app_install/www/): No such file or directory starting system done,enjoy it! vsftpd: error while loading shared libraries: /usr/app_install//common/lib/libcrypt.so.1: file too short ./db: error while loading shared libraries: /usr/app_install//common/lib/libxml2.so.2: file too short ~ # ~ # df Filesystem 1K-blocks Used Available Use% Mounted on ubi0:rootfs 2752 2224 528 81% / ubi0:app 44036 444 43592 1% /usr/app_install ubi0:db 403580 28 403552 0% /usr/app_install/db/database ~ #
You can see error occurs when extract files. It seems IO errors when write. and after reboot, bad PEB count increased.
