C6678 Initial Smart Reflex VID Value
I wanted to clarify what the initial VID value for the C6678 should be.  I believe the thinking on this has changed as I see some posts with 0.949 and some with a higher value.  The hardware design guide and datasheet are rather ambiguous on this point.
Please can you specify the initial CVDD in VID Code and Voltage, for use in the "Vid Code Init" setting in Fusion.   I am using a 1.25GHz chip.
Cheers,
Richard
