Bluetooth with the C5535 eZdsp USB Stick Development Kit
Hello experts,
I've purchased the C5535 eZdsp USB Stick Development Kit (see http://www.ti.com/tool/tmdx5535ezdsp ) and I've read in the documentation that it has a Bluetooth Chipcon expansion connector.
My question: Is there any ready-made expansion board that I can plug into the development kit to easily use Bluetooth to talk to any bluetooth headset? I would like to receive and send audio at the same time.
Looking forward to your replies, and thanks in advance!
Florian
  • Try this link:
    http://www.ti.com/tool/pan1323emk
    Regards.
  • Thank you, Steve!
    Now I have a solution for the hardware. But what about the software/BT stack?
    My application would require that I can send and receive audio to/from a normal bluetooth headset. In other words, the DSP and module should work together as a Headset Profile (HSP) source.
    On another thread I read that www.stonestreetone.com makes a BT stack that can be licensed free of charge if I use TI components. Does this cover the HSP that I would require? Because of the expected low volume of the finished hardware product, I want to avoid paying huge upfront and one time costs. Per-unit royalties of up to US$50 should be OK though. Does TI have the right offer for me?
    Thanks again, for your time!
  • You have to contact StoneStreet One for the BT stack and to make sure they can support your requirements. There will be a licensing fee. Please work directly with StoneStreet One.
    Also, can you forward me the thread about free licensing so I can update it?
    Regards.
  •  Hello Steve,
    I was referring to this thread: http://e2e.ti.com/support/dsp/c5000/f/109/t/119763.aspx
    Thank you for your support, I've accepted your answer.
    Florian
  • Thanks. Confiremd that thread has no mention of free BT stack.
    For any interests in Bluetooth stack, please contact StoneStreet One and to make sure they can support your requirements. There will be a licensing fee. Please work directly with StoneStreet One.
    Regards.
