Other Parts Discussed in Thread: AM1808
We are using a TI AM1808 on a custom board with ti-linux 2.6.33-rc4.
We have successfully connected some webcams (old Philips and Logitech) to its USB port, but both uvc compatible camera modules we have have around fail the same way:
musb_urb_enqueue: maxpacket=5096/13e8 ok=1 type=1 pipe=408280 in=80 out=0 iso_rx=0 iso_tx=0 (trace we have added)
uvcvideo: Failed to submit URB 0 (-90).
libv4l2: error turning on stream: Message too long
I have found similar errors (related to high bandwidth ISO transfer not supported) on this forum but have not found a fix for this problem.
Do you think there is a software solution to this problem ?
Thank you in advance,
Laurent Brard.
PS: attached lsusb output
Bus 001 Device 001: ID 1d6b:0002
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 9
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
idVendor 0x1d6b
idProduct 0x0002
bcdDevice 2.06
iManufacturer 3 Linux 2.6.33-rc4 musb-hcd
iProduct 2 MUSB HDRC host driver
iSerial 1 musb_hdrc
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 25
bNumInterfaces 1
bConfigurationValue 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 0mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 9
bInterfaceSubClass 0
bInterfaceProtocol 0
iInterface 0
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 3
Transfer Type Interrupt
Synch Type None
Usage Type Data
wMaxPacketSize 0x0004 1x 4 bytes
bInterval 12
Hub Descriptor:
bLength 9
bDescriptorType 41
nNbrPorts 1
wHubCharacteristic 0x0011
Per-port power switching
No overcurrent protection
bPwrOn2PwrGood 5 * 2 milli seconds
bHubContrCurrent 0 milli Ampere
DeviceRemovable 0x02
PortPwrCtrlMask 0xff
Hub Port Status:
Port 1: 0000.0503 highspeed power enable connect
Device Status: 0x0003
Self Powered
Remote Wakeup Enabled
Bus 001 Device 002: ID 04f2:b016
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 239
bDeviceSubClass 2
bDeviceProtocol 1
bMaxPacketSize0 64
idVendor 0x04f2
idProduct 0xb016
bcdDevice 6.04
iManufacturer 2 Chicony Electronics Co., Ltd.
iProduct 1 HP Webcam
iSerial 3 SN0001
bLength 9
bDescriptorType 2
wTotalLength 543
bNumInterfaces 2
iConfiguration 0
bmAttributes 0x80
(Bus Powered)
MaxPower 500mA
Interface Association:
bLength 8
bDescriptorType 11
bFirstInterface 0
bInterfaceCount 2
bFunctionClass 14
bFunctionSubClass 3
bFunctionProtocol 0
iFunction 1 HP Webcam
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 14
bInterfaceSubClass 1
iInterface 1 HP Webcam
VideoControl Interface Descriptor:
bLength 13
bDescriptorType 36
bDescriptorSubtype 1 (HEADER)
bcdUVC 1.00
wTotalLength 77
dwClockFrequency 15.000000MHz
bInCollection 1
baInterfaceNr( 0) 1
bLength 9
bDescriptorType 36
bDescriptorSubtype 3 (OUTPUT_TERMINAL)
bTerminalID 2
wTerminalType 0x0101
bAssocTerminal 0
bSourceID 4
iTerminal 0
bLength 26
bDescriptorType 36
bDescriptorSubtype 6 (EXTENSION_UNIT)
bUnitID 4
guidExtensionCode {7033f028-1163-2e4a-ba2c-6890eb334016}
bNumControl 1
bNrPins 1
baSourceID( 0) 3
bControlSize 1
bmControls( 0) 0x01
iExtension 0
bLength 18
bDescriptorType 36
bDescriptorSubtype 2 (INPUT_TERMINAL)
bTerminalID 1
wTerminalType 0x0201
bAssocTerminal 0
iTerminal 0
wObjectiveFocalLengthMin 0
wObjectiveFocalLengthMax 0
wOcularFocalLength 0
bControlSize 3
bmControls 0x00000000
bLength 11
bDescriptorType 36
bDescriptorSubtype 5 (PROCESSING_UNIT)
Warning: Descriptor too short
bUnitID 3
bSourceID 1
wMaxMultiplier 0
bControlSize 2
bmControls 0x0000053f
Brightness
Contrast
Hue
Saturation
Sharpness
Gamma
Backlight Compensation
Power Line Frequency
iProcessing 0
bmVideoStandards 0x 1
None
bLength 7
bDescriptorType 5
bEndpointAddress 0x83 EP 3 IN
bmAttributes 3
Synch Type None
Usage Type Data
wMaxPacketSize 0x0010 1x 16 bytes
bInterval 6
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 0
bNumEndpoints 0
bInterfaceClass 14
bInterfaceSubClass 2
iInterface 0
VideoStreaming Interface Descriptor:
bLength 14
bDescriptorType 36
bDescriptorSubtype 1 (INPUT_HEADER)
bNumFormats 1
wTotalLength 323
bEndPointAddress 129
bmInfo 0
bTerminalLink 2
bStillCaptureMethod 2
bTriggerSupport 1
bTriggerUsage 0
bControlSize 1
bmaControls( 0) 27
bLength 27
bDescriptorType 36
bDescriptorSubtype 4 (FORMAT_UNCOMPRESSED)
bFormatIndex 1
bNumFrameDescriptors 5
guidFormat {59555932-0000-1000-8000-00aa00389b71}
bBitsPerPixel 16
bDefaultFrameIndex 1
bAspectRatioX 0
bAspectRatioY 0
bmInterlaceFlags 0x00
Interlaced stream or variable: No
Fields per frame: 1 fields
Field 1 first: No
Field pattern: Field 1 only
bCopyProtect 0
bLength 50
bDescriptorType 36
bDescriptorSubtype 5 (FRAME_UNCOMPRESSED)
bFrameIndex 1
bmCapabilities 0x00
Still image unsupported
wWidth 640
wHeight 480
dwMinBitRate 614400
dwMaxBitRate 18432000
dwMaxVideoFrameBufferSize 614400
dwDefaultFrameInterval 333333
bFrameIntervalType 6
dwFrameInterval( 0) 333333
dwFrameInterval( 1) 500000
dwFrameInterval( 2) 666666
dwFrameInterval( 3) 1000000
dwFrameInterval( 4) 2000000
dwFrameInterval( 5) 10000000
bLength 50
bDescriptorType 36
bFrameIndex 2
bmCapabilities 0x00
wWidth 352
wHeight 288
dwMinBitRate 202752
dwMaxBitRate 6082560
dwMaxVideoFrameBufferSize 202752
bLength 50
bDescriptorType 36
bFrameIndex 3
bmCapabilities 0x00
wWidth 320
wHeight 240
dwMinBitRate 153600
dwMaxBitRate 4608000
dwMaxVideoFrameBufferSize 153600
bLength 50
bDescriptorType 36
bFrameIndex 4
bmCapabilities 0x00
wWidth 176
wHeight 144
dwMinBitRate 50688
dwMaxBitRate 1520640
dwMaxVideoFrameBufferSize 50688
bLength 50
bDescriptorType 36
bFrameIndex 5
bmCapabilities 0x00
wWidth 160
wHeight 120
dwMinBitRate 38400
dwMaxBitRate 1152000
dwMaxVideoFrameBufferSize 38400
bLength 26
bDescriptorType 36
bDescriptorSubtype 3 (STILL_IMAGE_FRAME)
bEndpointAddress 0
bNumImageSizePatterns 5
wWidth( 0) 640
wHeight( 0) 480
wWidth( 1) 352
wHeight( 1) 288
wWidth( 2) 320
wHeight( 2) 240
wWidth( 3) 176
wHeight( 3) 144
wWidth( 4) 160
wHeight( 4) 120
bNumCompressionPatterns 5
bLength 6
bDescriptorType 36
bDescriptorSubtype 13 (COLORFORMAT)
bColorPrimaries 1 (BT.709,sRGB)
bTransferCharacteristics 1 (BT.709)
bMatrixCoefficients 4 (SMPTE 170M (BT.601))
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 1
bNumEndpoints 1
bInterfaceClass 14
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 5
Transfer Type Isochronous
Synch Type Asynchronous
Usage Type Data
wMaxPacketSize 0x0080 1x 128 bytes
bInterval 1
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 2
bNumEndpoints 1
bInterfaceClass 14
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 5
Usage Type Data
wMaxPacketSize 0x0100 1x 256 bytes
bInterval 1
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 3
bNumEndpoints 1
bInterfaceClass 14
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 5
Usage Type Data
wMaxPacketSize 0x0320 1x 800 bytes
bInterval 1
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 4
bNumEndpoints 1
bInterfaceClass 14
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 5
Usage Type Data
wMaxPacketSize 0x0b20 2x 800 bytes
bInterval 1
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 5
bNumEndpoints 1
bInterfaceClass 14
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 5
Usage Type Data
wMaxPacketSize 0x1320 3x 800 bytes
bInterval 1
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 6
bNumEndpoints 1
bInterfaceClass 14
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 5
Usage Type Data
wMaxPacketSize 0x13e8 3x 1000 bytes
bInterval 1
Device Qualifier (for other device speed):
bLength 10
bDescriptorType 6
bcdUSB 2.00
bDeviceClass 239
bDeviceSubClass 2
bDeviceProtocol 1
bMaxPacketSize0 64
Device Status: 0x0000
(Bus Powered)
