L137 SDRAM vs L138 DDR2 comparison
Other Parts Discussed in Thread: OMAPL138
Hi guys.
I had been working with c6747 for quite some time, and I am also familiar with L137. I am considering C6748 and L138 for my future work( because of upp, 2 sd card support,  475 Mhz possibility).
I need performance data access of "133 Mhz 32 bit SDRAM access in C6747" (and 16 bit version if you can) against "150 Mhz 16 bit DDR2 access in C6748", with code in L2 ram , doing multiplication and addition of 32 bit float variables residing in external memory, when two dsp's have same clock (300 Mhz). Caching of SDRAM should be closed(with MAR registers). . If you can provide code performance residing in external RAM( with no code caching),  that will also be beneficial to my work.
I currently have none of the EVM's in my reach, therefore cannot produce these results.
Any application note, benchmark , experience is more than welcomed.
Thanks for the enlightenment :)
