Initialize Encoder resolution 720x576
Other Parts Discussed in Thread: TVP5158
We use DVR RDK 03.00.00.00 usecase VSYS_USECASE_MULTICHN_PROGRESSIVE_VCAP_VDIS_VENC_VDEC.
Main task of our application is recording of analouge camera (PAL) in h264.
We expect encoding in 720x576 D1 format.
But encoding is initialized with 704x576.
(See log file [m3video]  20298: ENCODE: Creating CHx of 704 x 576, pitch = (16384, 32768) [PROGRESSIVE] [TILED      ], bitrate = 2000 Kbps ...)
How can we achieve a resolution of 720x576 ?
In structure VENC_CHN_PARAMS_S videoWidth and videoHeight are read only.
  • Sorry, I forgot the log file.
    U-Boot 2010.06-svn169 (Jan 21 2013 - 14:26:17)
    TI8168-GP rev 1.1
    MAIN_N: 56, MAIN_P: 1, OSC_FREQ: 27, FAPLL_K: 8
    ARM clk: 987MHz
    DDR clk: 796MHz
    HDVICP clk: 600MHz
    L3 Fast clk: 500MHz
    HDVPSS clk: 250MHz
    Ducati M3 clk: 250MHz
    DSS clk: 250MHz
    DSP clk: 1000MHz
    I2C:   ready
    DRAM:  2 GiB
    NAND:  HW ECC BCH8 Selected
    256 MiB
    MMC:   OMAP SD/MMC: 0
    Net:   Ethernet PHY: GENERIC @ 0x01
    DaVinci EMAC
    Hit any key to stop autoboot:  1  0
    Connect speed 100M Full
    Using DaVinci EMAC device
    host 192.168.1.20 is alive
    TFTP from server 192.168.1.20; our IP address is 192.168.1.10
    Filename 'uImage_DM816X_DVR'.
    Load address: 0x81000000
    Loading: *#################################################################
    done
    Bytes transferred = 2560808 (0x271328)
    ## Booting kernel from Legacy Image at 81000000 ...
       Image Name:   Linux-2.6.37
       Created:      2013-01-22  10:52:27 UTC
       Image Type:   ARM Linux Kernel Image (uncompressed)
       Data Size:    2560744 Bytes = 2.4 MiB
       Load Address: 80008000
       Entry Point:  80008000
       Verifying Checksum ... OK
       Loading Kernel Image ... OK
    OK
    Starting kernel ...
    Linux version 2.6.37 (heb@heb) (gcc version 4.3.3 (Sourcery G++ Lite 2009q1-203) ) #1 Tue Jan 22 11:52:23 CET 2013
    CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c53c7f
    CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
    Machine: ti8168_dvr
    vram size = 20971520 at 0x0
    reserved size = 20971520 at 0x0
    FB: Reserving 20971520 bytes SDRAM for VRAM
    Memory policy: ECC disabled, Data cache writeback
    OMAP chip is TI8168 1.1
    Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 145488
    Kernel command line: rootdelay=1 console=ttyO2,115200n8 init=/linuxrc root=/dev/nfs rw nfsroot=192.168.1.20:/home/heb/tftpboot/rfs_816x ip=192.168.1.10:192.168.1.20:192.168.1.1:255.255.255.0::eth0:off vram=20M notifyk.vpssm3_sva=0xBEE00000 mem=128M mem=472M@0xC0000000 vmalloc=580M
    PID hash table entries: 2048 (order: 1, 8192 bytes)
    Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
    Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
    Memory: 128MB 452MB = 580MB total
    Memory: 583184k/583184k available, 31216k reserved, 139264K highmem
    Virtual kernel memory layout:
        vector  : 0xffff0000 - 0xffff1000   (   4 kB)
        fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
        DMA     : 0xffc00000 - 0xffe00000   (   2 MB)
        vmalloc : 0xd4000000 - 0xf8000000   ( 576 MB)
        lowmem  : 0x80000000 - 0xd3c00000   (1340 MB)
        pkmap   : 0x7fe00000 - 0x80000000   (   2 MB)
        modules : 0x7f000000 - 0x7fe00000   (  14 MB)
          .init : 0x80008000 - 0x8003b000   ( 204 kB)
          .text : 0x8003b000 - 0x804d8000   (4724 kB)
          .data : 0x804d8000 - 0x80520d80   ( 292 kB)
    SLUB: Genslabs=11, HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
    NR_IRQS:407
    IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts
    Total of 128 interrupts on 1 active controller
    GPMC revision 6.0
    Trying to install interrupt handler for IRQ400
    Trying to install interrupt handler for IRQ401
    Trying to install interrupt handler for IRQ402
    Trying to install interrupt handler for IRQ403
    Trying to install interrupt handler for IRQ404
    Trying to install interrupt handler for IRQ405
    Trying to install interrupt handler for IRQ406
    Trying to install type control for IRQ407
    Trying to set irq flags for IRQ407
    OMAP clockevent source: GPTIMER1 at 27000000 Hz
    Console: colour dummy device 80x30
    Calibrating delay loop... 986.31 BogoMIPS (lpj=4931584)
    pid_max: default: 32768 minimum: 301
    Security Framework initialized
    Mount-cache hash table entries: 512
    CPU: Testing write buffer coherency: ok
    devtmpfs: initialized
    omap_voltage_early_init: voltage driver support not added
    regulator: core version 0.5
    regulator: dummy:
    NET: Registered protocol family 16
    omap_voltage_domain_lookup: Voltage driver init not yet happened.Faulting!
    omap_voltage_add_dev: VDD specified does not exist!
    OMAP GPIO hardware version 0.1
    omap_mux_init: Add partition: #1: core, flags: 0
    3-wired eeprom init done. (H/W ver:ff)
    _omap_mux_get_by_name: Could not find signal i2c2_scl.i2c2_scl
    _omap_mux_get_by_name: Could not find signal i2c2_sda.i2c2_sda
    registered ti816x_sr device
    pm_dbg_init: only OMAP3 supported
    registered ti81xx_vpss device
    registered ti81xx_vidout device
    registered ti81xx on-chip HDMI device
    registered ti81xx_fb device
    bio: create slab <bio-0> at 0
    vgaarb: loaded
    SCSI subsystem initialized
    usbcore: registered new interface driver usbfs
    usbcore: registered new interface driver hub
    usbcore: registered new device driver usb
    USBSS revision 4ea20808
    registerd cppi-dma Intr @ IRQ 17
    Cppi41 Init Done
    omap_i2c omap_i2c.1: bus 1 rev4.0 at 400 kHz
    regulator: pmbus_vr: 800 <--> 1050 mV at 0 mV
    regulator: tps40400 probe done.
    omap_i2c omap_i2c.2: bus 2 rev4.0 at 400 kHz
    Advanced Linux Sound Architecture Driver Version 1.0.23.
    Switching to clocksource gp timer
    musb-hdrc: version 6.0, host, debug=0
    musb-hdrc musb-hdrc.0: dma type: dma-cppi41
    MUSB controller-0 revision 4ea20800
    musb-hdrc: kernel must blacklist external hubs
    musb-hdrc musb-hdrc.0: MUSB HDRC host driver
    musb-hdrc musb-hdrc.0: new USB bus registered, assigned bus number 1
    usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
    usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    usb usb1: Product: MUSB HDRC host driver
    usb usb1: Manufacturer: Linux 2.6.37 musb-hcd
    usb usb1: SerialNumber: musb-hdrc.0
    hub 1-0:1.0: USB hub found
    hub 1-0:1.0: 1 port detected
    musb-hdrc musb-hdrc.0: USB Host mode controller at d401e000 using DMA, IRQ 18
    musb-hdrc musb-hdrc.1: dma type: dma-cppi41
    MUSB controller-1 revision 4ea20800
    musb-hdrc musb-hdrc.1: MUSB HDRC host driver
    musb-hdrc musb-hdrc.1: new USB bus registered, assigned bus number 2
    usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
    usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    usb usb2: Product: MUSB HDRC host driver
    usb usb2: Manufacturer: Linux 2.6.37 musb-hcd
    usb usb2: SerialNumber: musb-hdrc.1
    hub 2-0:1.0: USB hub found
    hub 2-0:1.0: 1 port detected
    musb-hdrc musb-hdrc.1: USB Host mode controller at d4028800 using DMA, IRQ 19
    NET: Registered protocol family 2
    IP route cache hash table entries: 16384 (order: 4, 65536 bytes)
    TCP established hash table entries: 65536 (order: 7, 524288 bytes)
    TCP bind hash table entries: 65536 (order: 6, 262144 bytes)
    TCP: Hash tables configured (established 65536 bind 65536)
    TCP reno registered
    UDP hash table entries: 256 (order: 0, 4096 bytes)
    UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
    RPC: Registered udp transport module.
    RPC: Registered tcp transport module.
    RPC: Registered tcp NFSv4.1 backchannel transport module.
    NetWinder Floating Point Emulator V0.97 (double precision)
    PMU: registered new PMU device of type 0
    omap-iommu omap-iommu.0: ducati registered
    omap-iommu omap-iommu.1: sys registered
    highmem bounce pool size: 64 pages
    JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
    msgmni has been set to 867
    io scheduler noop registered
    io scheduler deadline registered
    io scheduler cfq registered (default)
    Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
    omap_uart.0: ttyO0 at MMIO 0x48020000 (irq = 72) is a OMAP UART0
    omap_uart.1: ttyO1 at MMIO 0x48022000 (irq = 73) is a OMAP UART1
    omap_uart.2: ttyO2 at MMIO 0x48024000 (irq = 74) is a OMAP UART2
    console [ttyO2] enabled
    brd: module loaded
    loop: module loaded
    ahci ahci.0: forcing PORTS_IMPL to 0x3
    ahci ahci.0: AHCI 0001.0100 32 slots 2 ports 3 Gbps 0x3 impl platform mode
    ahci ahci.0: flags: ncq sntf pm led clo only pmp pio slum part ccc
    scsi0 : ahci_platform
    scsi1 : ahci_platform
    ata1: SATA max UDMA/133 irq_stat 0x00400040, connection status changed irq 16
    ata2: SATA max UDMA/133 irq_stat 0x00400040, connection status changed irq 16
    omap2-nand driver initializing
    NAND device: Maf ID: 0xec, Chip ID: 0xda (Samsung, )
     erasesize: 0x20000, writesize: 2048, oobsize: 64
    Creating 6 MTD partitions on "omap2-nand.0":
    0x000000000000-0x000000240000 : "U-Boot"
    0x000000240000-0x000000280000 : "U-Boot Env"
    0x000000280000-0x000000580000 : "U-Boot Logo"
    0x000000580000-0x0000009c0000 : "Kernel"
    0x0000009c0000-0x00000d1e0000 : "File System"
    0x00000d1e0000-0x000010000000 : "Reserved"
    davinci_mdio davinci_mdio.0: davinci mdio revision 1.6
    davinci_mdio davinci_mdio.0: detected phy mask fffffff8
    davinci_mdio.0: probed
    davinci_mdio davinci_mdio.0: phy[0]: device 0:00, driver unknown
    davinci_mdio davinci_mdio.0: phy[1]: device 0:01, driver unknown
    davinci_mdio davinci_mdio.0: phy[2]: device 0:02, driver unknown
    usbcore: registered new interface driver cdc_ether
    usbcore: registered new interface driver dm9601
    Initializing USB Mass Storage driver...
    usbcore: registered new interface driver usb-storage
    USB Mass Storage support registered.
    mice: PS/2 mouse device common for all mice
    usb 1-1: new high speed USB device using musb-hdrc and address 2
    rtc-ds1307 1-0068: rtc core: registered ds1337 as rtc0
    omap_rtc omap_rtc: rtc core: registered omap_rtc as rtc1
    i2c /dev entries driver
    Linux video capture interface: v2.00
    usbcore: registered new interface driver uvcvideo
    USB Video Class driver (v1.0.0)
    OMAP Watchdog Timer Rev 0x00: initial timeout 60 sec
    usbcore: registered new interface driver usbhid
    usbhid: USB HID core driver
    notify_init : notify drivercreated  for  remote proc id 2 at physical Address 0xbee00000
    usbcore: registered new interface driver snd-usb-audio
    Registered tvp5158 audio codec
    asoc: tvp5158-hifi <-> davinci-mcasp.0 mapping ok
    asoc: tlv320aic3x-hifi <-> davinci-mcasp.2 mapping ok
    asoc: HDMI-DAI-CODEC <-> hdmi-dai mapping ok
    ALSA device list:
      #0: TI81XX DVR
    TCP cubic registered
    NET: Registered protocol family 17
    VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
    omap_voltage_late_init: Voltage driver support not added
    Power Management for TI81XX.
    smartreflex-ti816x: ti816x_sr_probe done!
    rtc-ds1307 1-0068: setting system clock to 2013-02-11 07:38:10 UTC (1360568290)
    usb 1-1: New USB device found, idVendor=0409, idProduct=005a
    usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
    hub 1-1:1.0: USB hub found
    hub 1-1:1.0: 4 ports detected
    davinci_mdio davinci_mdio.0: resetting idled controller
    net eth0: attached PHY driver [Generic PHY] (mii_bus:phy_addr=0:01, id=1cc915)
    IP-Config: Complete:
         device=eth0, addr=192.168.1.10, mask=255.255.255.0, gw=192.168.1.1,
         host=192.168.1.10, domain=, nis-domain=(none),
         bootserver=192.168.1.20, rootserver=192.168.1.20, rootpath=
    Waiting 1sec before mounting root device...
    PHY: 0:01 - Link is Up - 100/Full
    ata2: link is slow to respond, please be patient (ready=0)
    ata1: link is slow to respond, please be patient (ready=0)
    ata2: softreset failed (device not ready)
    ata1: softreset failed (device not ready)
    ata2: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
    ata2.00: ATA-8: TOSHIBA MK5065GSX, GJ003A, max UDMA/100
    ata2.00: 976773168 sectors, multi 16: LBA48 NCQ (depth 31/32)
    ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
    ata2.00: configured for UDMA/100
    ata1.00: ATA-8: TOSHIBA MK5065GSX, GJ003A, max UDMA/100
    ata1.00: 976773168 sectors, multi 16: LBA48 NCQ (depth 31/32)
    ata1.00: configured for UDMA/100
    scsi 0:0:0:0: Direct-Access     ATA      TOSHIBA MK5065GS GJ00 PQ: 0 ANSI: 5
    sd 0:0:0:0: Attached scsi generic sg0 type 0
    scsi 1:0:0:0: Direct-Access     ATA      TOSHIBA MK5065GS GJ00 PQ: 0 ANSI: 5
    sd 1:0:0:0: Attached scsi generic sg1 type 0
    sd 0:0:0:0: [sda] 976773168 512-byte logical blocks: (500 GB/465 GiB)
    sd 0:0:0:0: [sda] Write Protect is off
    sd 1:0:0:0: [sdb] 976773168 512-byte logical blocks: (500 GB/465 GiB)
    sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
    sd 1:0:0:0: [sdb] Write Protect is off
    sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
     sda: sda1
    sd 0:0:0:0: [sda] Attached SCSI disk
     sdb: sdb1
    sd 1:0:0:0: [sdb] Attached SCSI disk
    VFS: Mounted root (nfs filesystem) on device 0:15.
    devtmpfs: mounted
    Freeing init memory: 204K
     Mounting /proc             : [SUCCESS]
     Mounting /sys              : [SUCCESS]
     Mounting /dev              : [SUCCESS]
     Mounting /dev/pts          : [SUCCESS]
     Enabling hot-plug          : [SUCCESS]
     Populating /dev            : EXT3-fs: barriers not enabled
    kjournald starting.  Commit interval 5 seconds
    EXT3-fs (sda1): using internal journal
    EXT3-fs (sda1): recovery complete
    EXT3-fs (sda1): mounted filesystem with writeback data mode
    EXT3-fs (sdb1): using internal journal
    EXT3-fs (sdb1): recovery complete
    EXT3-fs (sdb1): mounted filesystem with writeback data mode
    [SUCCESS]
    Starting telnet daemon.
    Starting syslogd/klogd: done
    Starting pure-ftpd daemon.
    Starting smbd daemon.
    Starting nmbd daemonFeb 11 07:38:29 192 syslog.info syslogd started: BusyBox v1.19.4
    *** Bootargs Validated for mem param ***
    *** Bootargs Validated for notifyk.vpssm3 params ***
    Kernel bootargs validated
    ./init.sh: line 22: amixer: not found
    ./init.sh: line 23: amixer: not found
     [c6xdsp ] RemotSysLink version : 2.10.02.17
    SysLink module created on Date:Jan 22 2013 Time:08:56:16
    e Debug Shared MTrace enabled
    emory @ 0xbf0000Trace SetFailureReason enabled
    00
     [m3video] Remote Debug Shared Memory @ 0xbf005020
     [m3vpss ] Remote Debug Shared Memory @ 0xbf00a040
    Feb 11 07:38:36 192 user.alert kernel: SysLink version : 2.10.02.17
    Feb 11 07:38:36 192 user.alert kernel: SysLink module created on Date:Jan 22 2013 Time:08:56:16
    Feb 11 07:38:36 192 user.alert kernel: Trace enabled
    Feb 11 07:38:36 192 user.alert kernel: Trace SetFailureReason enabled
     Setting DMM priority for [DUCATI  ] to [0] ( 0x4e000624 = 0x08000000 )
     Setting DMM priority for [HDVICP0 ] to [2] ( 0x4e000634 = 0x0000000a )
     Setting DMM priority for [HDVICP1 ] to [2] ( 0x4e000634 = 0x000a0000 )
     Setting DMM priority for [HDVICP2 ] to [2] ( 0x4e000634 = 0x00a00000 )
     *** TVP5158 probe : START ***
     TI VS EVM : TVP5158 device address : 0x58, 0x5a, 0x5c, 0x5e
     TI DVR    : TVP5158 device address : 0x5c, 0x5d, 0x5e, 0x5f
     Device found     : I2C (0xXX): 0x08 = 0x51
                        I2C (0xXX): 0x09 = 0x58
     Device NOT found : I2C (0xXX): Read ERROR !!! (reg[0x08], count = 2)
     I2C (0x58): Read ERROR !!! (reg[0x08], count = 2)
     I2C (0x5a): Read ERROR !!! (reg[0x08], count = 2)
     I2C (0x5c): 0x08 = 0x51
     I2C (0x5c): 0x09 = 0x58
     I2C (0x5d): 0x08 = 0x51
     I2C (0x5d): 0x09 = 0x58
     I2C (0x5e): 0x08 = 0x51
     I2C (0x5e): 0x09 = 0x58
     I2C (0x5f): 0x08 = 0x51
     I2C (0x5f): 0x09 = 0x58
     *** TVP5158 probe : END ***
    /opt/ti816x
    Attached to slave procId 2.
    Loaded file ../firmware/dvr_rdk_fw_m3vpss.xem3 on slave procId 2.
    Started slave procId 2.
    After Ipc_loadcallback status [0x00000000]
     [m3vpss ] ***** SYSTEM  : Frequency <ORG> - 250000000, <NEW> - 250000000
     [m3vpss ] notify_attach  rtnVal  0
     [m3vpss ] initProxyServer  rtnVal  0
     [m3vpss ]
     [m3vpss ]  *** UTILS: CPU KHz = 500000 Khz ***
     [m3vpss ]
     [m3vpss ]  47: SYSTEM  : System Common Init in progress !!!
     [m3vpss ]  47: SYSTEM: IPC init in progress !!!
     [m3vpss ]  47: SYSTEM: Attaching to [HOST] ...
     [m3vpss ]  1047: SYSTEM: Attaching to [HOST] ...
     [m3vpss ]  1049: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
     [m3vpss ]  1049: SYSTEM: Attaching to [DSP] ...
    After Ipc_startcallback status [0x097d2000]
    Attached to slave procId 1.
    Loaded file ../firmware/dvr_rdk_fw_m3video.xem3 on slave procId 1.
    Started slave procId 1.
     [m3video] ***** SYSTEM  : Frequency <ORG> - 250000000, <NEW> - 250000000
     [m3vpss ]  2049: SYSTEM: Attaching to [DSP] ...
     [m3video]
     [m3video]  *** UTILS: CPU KHz = 500000 Khz ***
     [m3video]
     [m3video]  1965: SYSTEM  : System Common Init in progress !!!
     [m3video]  1965: SYSTEM: IPC init in progress !!!
     [m3video]  1965: SYSTEM: Attaching to [HOST] ...
     [m3video]  2965: SYSTEM: Attaching to [HOST] ...
     [m3video]  2967: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
     [m3video]  2967: SYSTEM: Attaching to [DSP] ...
    After Ipc_startcallback status [0x00000000]
     [m3vpss ]  3049: SYSTEM: Attaching to [DSP] ...
    Attached to slave procId 0.
    Loaded file ../firmware/dvr_rdk_fw_c6xdsp.xe674 on slave procId 0.
    Started slave procId 0.
     [c6xdsp ] ***** SYSTEM  : Frequency <ORG> - 800000000, <NEW> - 800000000
     [m3video]  3967: SYSTEM: Attaching to [DSP] ...
     [m3vpss ]  4049: SYSTEM: Attaching to [DSP] ...
     [c6xdsp ]
     [c6xdsp ]  *** UTILS: CPU KHz = 800000 Khz ***
     [c6xdsp ]
     [c6xdsp ]  7: SYSTEM  : System Common Init in progress !!!
     [c6xdsp ]  7: SYSTEM: IPC init in progress !!!
     [c6xdsp ]  7: SYSTEM: Attaching to [HOST] ...
     [c6xdsp ]  1265: SYSTEM: Attaching to [HOST] ...
     [c6xdsp ]  1268: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
     [c6xdsp ]  1268: SYSTEM: Attaching to [VIDEO-M3] ...
    DMA: Module install successful, device major num = 251
    DRV: Module install successful
    DRV: Module built on Feb  8 2013 08:09:52
    Feb 11 07:38:45 192 user.info kernel: DMA: Module install successful, device major num = 251
    Feb 11 07:38:45 192 user.info kernel: DRV: Module install successful
    Feb 11 07:38:45 192 user.info kernel: DRV: Module built on Feb  8 2013 08:09:52
     [m3video]  4967: SYSTEM: Attaching to [DSP] ...
     [m3vpss ]  5049: SYSTEM: Attaching to [DSP] ...
     [c6xdsp ] Remote Debug Shared Memory @ 0xbf000000
     [c6xdsp ]  2527: SYSTEM: Attaching to [VIDEO-M3] ...
     [c6xdsp ]  2860: SYSTEM: Attaching to [VIDEO-M3] ... SUCCESS !!!
     [m3video]  5967: SYSTEM: Attaching to [DSP] ...
     [c6xdsp ]  2860: SYSTEM: Attaching to [VPSS-M3] ...
     [m3video]  5967: SYSTEM: Attaching to [DSP] ... SUCCESS !!!
     [m3video]  5968: SYSTEM: Attaching to [VPSS-M3] ...
     [m3vpss ]  6049: SYSTEM: Attaching to [DSP] ...
     [m3video]  6967: SYSTEM: Attaching to [VPSS-M3] ...
     [c6xdsp ]  4118: SYSTEM: Attaching to [VPSS-M3] ...
     [c6xdsp ]  4213: SYSTEM: Attaching to [VPSS-M3] ... SUCCESS !!!
     [m3vpss ]  7049: SYSTEM: Attaching to [DSP] ...
     [c6xdsp ]  4213: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
     [m3vpss ]  7049: SYSTEM: Attaching to [DSP] ... SUCCESS !!!
     [m3vpss ]  7050: SYSTEM: Attaching to [VIDEO-M3] ...
     [m3video]  7967: SYSTEM: Attaching to [VPSS-M3] ...
     [m3video]  8050: SYSTEM: Attaching to [VPSS-M3] ... SUCCESS !!!
     [m3vpss ]  8049: SYSTEM: Attaching to [VIDEO-M3] ...
     [m3video]  8050: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
     [m3vpss ]  8050: SYSTEM: Attaching to [VIDEO-M3] ... SUCCESS !!!
     [m3video]  8050: SYSTEM: Creating MsgQ [VIDEO-M3_MSGQ] ...
     [m3vpss ]  8050: SYSTEM: Creating MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
     [m3video]  8050: SYSTEM: Creating MsgQ [VIDEO-M3_ACK_MSGQ] ...
     [m3vpss ]  8050: SYSTEM: Creating MsgQ [VPSS-M3_MSGQ] ...
     [m3video]  8052: SYSTEM: Notify register to [HOST] line 0, event 15 ...
     [m3vpss ]  8050: SYSTEM: Creating MsgQ [VPSS-M3_ACK_MSGQ] ...
     [m3video]  8052: SYSTEM: Notify register to [DSP] line 0, event 15 ...
     [m3vpss ]  8052: SYSTEM: Notify register to [HOST] line 0, event 15 ...
     [m3video]  8052: SYSTEM: Notify register to [VPSS-M3] line 0, event 15 ...
     [m3vpss ]  8052: SYSTEM: Notify register to [DSP] line 0, event 15 ...
     [m3video]  8052: SYSTEM: IPC init DONE !!!
     [m3vpss ]  8052: SYSTEM: Notify register to [VIDEO-M3] line 0, event 15 ...
     [m3vpss ]  8052: SYSTEM: IPC init DONE !!!
     [c6xdsp ]  5471: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
     [c6xdsp ]  5471: SYSTEM: Creating MsgQ [DSP_MSGQ] ...
     [c6xdsp ]  5471: SYSTEM: Creating MsgQ [DSP_ACK_MSGQ] ...
     [c6xdsp ]  5472: SYSTEM: Notify register to [HOST] line 0, event 15 ...
     [c6xdsp ]  5472: SYSTEM: Notify register to [VIDEO-M3] line 0, event 15 ...
     [c6xdsp ]  5472: SYSTEM: Notify register to [VPSS-M3] line 0, event 15 ...
     [c6xdsp ]  5472: SYSTEM: IPC init DONE !!!
     [c6xdsp ]  5474: MEM: Shared Region 2: Base = 0xb0000000, Length = 0x0e9c0000 (233 MB)
     [m3video]  8059: MEM: Shared Region 2: Base = 0xb0000000, Length = 0x0e9c0000 (233 MB)
     [m3vpss ]  8058: MEM: Shared Region 2: Base = 0xb0000000, Length = 0x0e9c0000 (233 MB)
     [c6xdsp ]  5474: MEM: ERROR: SharedRegion_setEntry (2, 0x9ff3855c) FAILED !!!  (status=-1)
     [m3video]  8059: MEM: Shared Region 1: Base = 0x88000000, Length = 0x15000000 (336 MB)
     [m3vpss ]  8059: MEM: Shared Region 1: Base = 0x88000000, Length = 0x15000000 (336 MB)
     [m3video]  8061: SYSTEM  : System Common Init Done !!!
     [m3vpss ]  8061: SYSTEM  : System Common Init Done !!!
     [m3video]  8061: SYSTEM  : System Video Init in progress !!!
     [m3vpss ]  8061: SYSTEM  : System VPSS Init in progress !!!
     [m3video]  8061: SYSTEM  : System Video Init Done !!!
     [m3vpss ] === HDVPSS Clocks are enabled ===
     [m3video]  8061: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_0] in region 0 ...
     [m3vpss ] === HDVPSS is fully functional ===
     [m3video]  8062: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_0] in region 0 ...
     [m3vpss ] === HDVPSS module is not in standby ===
     [m3video]  8062: SYSTEM: ListElem Shared Addr = 0xbf18b680
     [c6xdsp ]  5486: MEM: Shared Region 1: Base = 0x88000000, Length = 0x15000000 (336 MB)
     [m3video]  8064: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_1] in region 0 ...
     [m3vpss ] === I2C1 Clk is active ===
     [m3video]  8064: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_1] in region 0 ...
     [m3vpss ]  8066: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_0] in region 0 ...
     [m3video]  8064: SYSTEM: ListElem Shared Addr = 0xbf18eb80
     [m3vpss ]  8066: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_0] in region 0 ...
     [c6xdsp ]  5487: SYSTEM  : System Common Init Done !!!
     [m3vpss ]  8066: SYSTEM: ListElem Shared Addr = 0xbf192080
     [c6xdsp ]  4353: SYSTEM  : System DSP Init in progress !!!
     [m3vpss ]  8068: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_1] in region 0 ...
     [m3vpss ]  8068: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_1] in region 0 ...
     [m3vpss ]  8068: SYSTEM: ListElem Shared Addr = 0xbf195580
     [c6xdsp ]  4353: SYSTEM  : RpeServer_init() done... Ret Val 0!!!
     [m3video]  8070: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_19] in region 0 ...
     [c6xdsp ]  5490: SYSTEM: Creating ListMP [DSP_IPC_OUT_19] in region 0 ...
     [m3video]  8070: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_19] in region 0 ...
     [c6xdsp ]  5490: SYSTEM: Creating ListMP [DSP_IPC_IN_19] in region 0 ...
     [m3video]  8070: SYSTEM: ListElem Shared Addr = 0xbf198a80
     [c6xdsp ]  5490: SYSTEM: ListElem Shared Addr = 0xbf1b8480
     [m3video]  8073: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_20] in region 0 ...
     [c6xdsp ]  5491: SYSTEM: Creating ListMP [DSP_IPC_OUT_20] in region 0 ...
     [m3video]  8073: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_20] in region 0 ...
     [m3vpss ]  8081: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_19] in region 0 ...
     [c6xdsp ]  5491: SYSTEM: Creating ListMP [DSP_IPC_IN_20] in region 0 ...
     [m3video]  8073: SYSTEM: ListElem Shared Addr = 0xbf217280
     [m3vpss ]  8081: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_19] in region 0 ...
     [c6xdsp ]  5491: SYSTEM: ListElem Shared Addr = 0xbf1d7e80
     [m3video]  8075: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_21] in region 0 ...
     [m3vpss ]  8081: SYSTEM: ListElem Shared Addr = 0xbf291c80
     [c6xdsp ]  5492: SYSTEM: Creating ListMP [DSP_IPC_OUT_21] in region 0 ...
     [m3video]  8075: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_21] in region 0 ...
     [m3vpss ]  8083: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_20] in region 0 ...
     [c6xdsp ]  5492: SYSTEM: Creating ListMP [DSP_IPC_IN_21] in region 0 ...
     [m3video]  8076: SYSTEM: ListElem Shared Addr = 0xbf272280
     [m3vpss ]  8084: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_20] in region 0 ...
     [c6xdsp ]  5492: SYSTEM: ListElem Shared Addr = 0xbf1f7b80
     [m3video]  8087: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_24] in region 0 ...
     [m3vpss ]  8084: SYSTEM: ListElem Shared Addr = 0xbf2b1680
     [c6xdsp ]  5492: SYSTEM: Creating ListMP [DSP_IPC_OUT_24] in region 0 ...
     [m3video]  8088: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_24] in region 0 ...
     [m3vpss ]  8086: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_21] in region 0 ...
     [c6xdsp ]  5492: SYSTEM: Creating ListMP [DSP_IPC_IN_24] in region 0 ...
     [m3video]  8088: SYSTEM: ListElem Shared Addr = 0xbf2f0a80
     [m3vpss ]  8086: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_21] in region 0 ...
     [c6xdsp ]  5492: SYSTEM: ListElem Shared Addr = 0xbf236c80
     [m3video]  8090: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_25] in region 0 ...
     [m3vpss ]  8086: SYSTEM: ListElem Shared Addr = 0xbf2d1080
     [c6xdsp ]  5493: SYSTEM: Creating ListMP [DSP_IPC_OUT_25] in region 0 ...
     [m3video]  8090: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_25] in region 0 ...
     [m3vpss ]  8088: SYSTEM : HDVPSS Drivers Version: HDVPSS_01_00_01_37
     [c6xdsp ]  5493: SYSTEM: Creating ListMP [DSP_IPC_IN_25] in region 0 ...
     [m3video]  8090: SYSTEM: ListElem Shared Addr = 0xbf30e580
     [m3vpss ]  8088: SYSTEM  : FVID2 Init in progress !!!
     [c6xdsp ]  5493: SYSTEM: ListElem Shared Addr = 0xbf254780
     [m3video]  8092: HDVICP: Doing PRCM for IVAHD[0] ...
     [m3vpss ]  8167: SYSTEM  : FVID2 Init in progress DONE !!!
     [c6xdsp ] !!WARNING.Resource already registered:2
     [c6xdsp ]  4359: SYSTEM  : Initializing Links !!!
     [m3video]  8092: HDVICP: PRCM for IVAHD[0] ... DONE.
     [m3vpss ]  8168: SYSTEM  : Device Init in progress !!!
     [m3video]  8092: HDVICP: Doing PRCM for IVAHD[1] ...
     [c6xdsp ]  5494: SYSTEM  : FREE SPACE : System Heap      = 10268448 B, Mbx = 10240 msgs)
     [m3video]  8092: HDVICP: PRCM for IVAHD[1] ... DONE.
     [m3vpss ] initPrms.isI2cInitReq = 0
     [m3video]  8093: HDVICP: Doing PRCM for IVAHD[2] ...
     [c6xdsp ]  4367: SYSTEM  : Initializing Links ... DONE !!!
     [m3video]  8093: HDVICP: PRCM for IVAHD[2] ... DONE.
     [m3video]  8093: SYSTEM  : Initializing Links !!!
     [m3vpss ]  8170: SYSTEM  : Device Init in progress DONE !!!
     [c6xdsp ]  4367: SYSTEM  : System DSP Init Done !!!
     [m3vpss ]  8302: SYSTEM  : System VPSS Init Done !!!
     [m3video]  8093: SYSTEM  : FREE SPACE : System Heap      = 6280232 B, Mbx = 10240 msgs)
     [m3vpss ]  8303: UTILS: DMA: HWI Create for INT63 !!!
     [m3vpss ]  8303: SYSTEM  : Initializing Links !!!
     [m3video]  8093: SYSTEM  : FREE SPACE : SR0 Heap         = 13452672 B (12 MB)
     [m3vpss ]  8303: SYSTEM  : FREE SPACE : System Heap      = 13024 B, Mbx = 10240 msgs)
     [m3video]  8093: SYSTEM  : FREE SPACE : Frame Buffer     = 245104512 B (233 MB)
     [m3vpss ]  8303: SYSTEM  : FREE SPACE : SR0 Heap         = 13452672 B (12 MB)
     [m3video]  8094: SYSTEM  : FREE SPACE : Bitstream Buffer = 352321408 B (335 MB)
     [m3vpss ]  8304: SYSTEM  : FREE SPACE : Frame Buffer     = 240794496 B (229 MB)
     [m3video]  8094: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
     [m3video]  8094: SYSTEM  : FREE SPACE : Tiler 8-bit      = 134217728 B (128 MB)  - TILER ON
     [m3vpss ]  8304: SYSTEM  : FREE SPACE : Bitstream Buffer = 352321408 B (335 MB)
     [m3vpss ] Received character 's'
     [m3video]  8095: SYSTEM  : FREE SPACE : Tiler 16-bit     = 134217728 B (128 MB)  - TILER ON
     [m3vpss ]  8304: SYSTEM  : FREE SPACE : Tiler 8-bit      = 134217728 B (128 MB)  - TILER ON
     [m3video]  8126: SYSTEM  : Initializing Links ... DONE !!!
     [m3vpss ]  8304: SYSTEM  : FREE SPACE : Tiler 16-bit     = 134217728 B (128 MB)  - TILER ON
     [m3vpss ]  8413: SYSTEM  : Initializing Links ... DONE !!!
     [m3video] Received character 's'
     [m3vpss ]  8413: SYSTEM  : Set Static L3 pressure for HDVPSS as High
     [c6xds[module] vpss probe done.
     [c6xdsp ] Received character 's'
    /opt/ti816x
    Feb 11 07:38:49 192 user.warn kernel: [module] vpss probe done.
    [module] ti81xxfb probe done.
    HDMI W1 rev 2.0
    [module] ti81xx_hdmi probe done.
    Feb 11 07:38:49 192 user.warn kernel: [module] ti81xxfb probe done.
    Feb 11 07:38:49 192 user.info kernel: HDMI W1 rev 2.0
    Feb 11 07:38:49 192 user.warn kernel: [module] ti81xx_hdmi probe done.
    Feb 11 07:38:50 192 user.debug kernel: hdmi: Enter HDMI_W1_StopVideoFrame()
    Feb 11 07:38:50 192 user.debug kernel: found best resolution: 1400x1050 (30)
    Feb 11 07:38:50 192 user.debug kernel: hdmi: Enter HDMI_W1_GlobalInitVars()
    Feb 11 07:38:50 192 user.debug kernel: hdmi: Enter HDMI_Core_GlobalInitVars()
    Feb 11 07:38:50 192 user.debug kernel: hdmi: Enter HDMI_W1_ConfigVideoResolutionTiming()
    Feb 11 07:38:50 192 user.debug kernel: hdmi: Enter HDMI_W1_ConfigVideoInterface()
    Feb 11 07:38:50 192 user.debug kernel: hdmi: HDMI_WP_AUDIO_CFG = 0x1030006
    Feb 11 07:38:50 192 user.debug kernel: hdmi: HDMI_WP_AUDIO_CFG2 = 0x20c0
    Feb 11 07:38:50 192 user.debug kernel: hdmi: HDMI_WP_AUDIO_CTRL = 0x20
    Feb 11 07:38:50 192 user.debug kernel: hdmi: Enter DSS_HDMI_CORE_SW_RESET_ASSERT ()
    Feb 11 07:38:50 192 user.debug kernel: hdmi: Enter DSS_HDMI_CORE_POWER_DOWN_DISABLE()
    Feb 11 07:38:50 192 user.debug kernel: hdmi: Enter DSS_HDMI_CORE_SW_RESET_RELEASE()
    Feb 11 07:38:50 192 user.debug kernel: hdmi: Enter HDMI_W1_StartVideoFrame  ()
    Feb 11 07:38:50 192 user.debug kernel: hdmi: Irqenable 60000011
    Feb 11 07:38:50 192 user.debug kernel: hdmi: 40 hpd
    Feb 11 07:38:50 192 user.debug kernel: hdmi: -------------DEBUG-------------------
    Feb 11 07:38:50 192 user.debug kernel: hdmi: 1 hdmi_wp_irqstatus
    Feb 11 07:38:50 192 user.debug kernel: hdmi: 1 hdmi_core_intr_state
    Feb 11 07:38:50 192 user.debug kernel: hdmi: 60 hdmi_core_intr1
    Feb 11 07:38:50 192 user.debug kernel: hdmi: 3 hdmi_core_intr2
    Feb 11 07:38:50 192 user.debug kernel: hdmi: f hdmi_core_intr3
    Feb 11 07:38:50 192 user.debug kernel: hdmi: 87 hdmi_core_sys_sys_stat
     ORG 0x46c00524: 0
     NEW 0x46c00524: 2
    Feb 11 07:38:52 192 daemon.info linuxrc: starting pid 198, tty '': '/opt/ti816x/bin/launcher.out'
    Feb 11 07:38:52 192 daemon.info linuxrc: starting pid 199, tty '': '/sbin/syslogd -n'
    Feb 11 07:38:52 192 daemon.info linuxrc: starting pid 200, tty '': '/sbin/klogd -n'
    Feb 11 07:38:52 192 daemon.info linuxrc: starting pid 201, tty '': '-/bin/sh'
    Feb 11 07:38:52 192 user.info LAUNCHER : startup: starting DMP
    Feb 11 07:38:52 192 user.notice kernel: klogd started: BusyBox v1.19.4 (2013-01-22 10:53:38 CET)
    [BOP13] $ Feb 11 07:38:53 192 syslog.info syslogd started: BusyBox v1.19.4
    --------------- CHANNEL DETAILS-------------
    Capture Channels => 16
    Enc Channels => Primary 16, Secondary 16
    Dec Channels => 16
    Disp Channels => 32
     0: SYSTEM: System Common Init in progress !!!
     0: SYSTEM: IPC init in progress !!!
     22: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
     23: SYSTEM: Creating MsgQ [HOST_MSGQ] ...
     25: SYSTEM: Creating MsgQ [HOST_ACK_MSGQ] ...
     26: SYSTEM: Opening MsgQ [DSP_MSGQ] ...
     27: SYSTEM: Opening MsgQ [VIDEO-M3_MSGQ] ...
     27: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
     28: SYSTEM: Notify register to [DSP] line 0, event 15 ...
     28: SYSTEM: Notify register to [VIDEO-M3] line 0, event 15 ...
     29: SYSTEM: Notify register to [VPSS-M3] line 0, event 15 ...
     29: SYSTEM: IPC init DONE !!!
     31: SYSTEM: Creating ListMP [HOST_IPC_OUT_24] in region 0 ...
     33: SYSTEM: Creating ListMP [HOST_IPC_IN_24] in region 0 ...
     34: SYSTEM: ListElem Shared Addr = 0x2b90e080
     35: SYSTEM: Creating ListMP [HOST_IPC_OUT_25] in region 0 ...
     37: SYSTEM: Creating ListMP [HOST_IPC_IN_25] in region 0 ...
     38: SYSTEM: ListElem Shared Addr = 0x2b92bb80
     40: SYSTEM: Creating ListMP [HOST_IPC_OUT_19] in region 0 ...
     42: SYSTEM: Creating ListMP [HOST_IPC_IN_19] in region 0 ...
     44: SYSTEM: ListElem Shared Addr = 0x2b949680
     45: SYSTEM: Creating ListMP [HOST_IPC_OUT_20] in region 0 ...
     47: SYSTEM: Creating ListMP [HOST_IPC_IN_20] in region 0 ...
     49: SYSTEM: ListElem Shared Addr = 0x2b969080
     50: SYSTEM: Creating ListMP [HOST_IPC_OUT_21] in region 0 ...
     52: SYSTEM: Creating ListMP [HOST_IPC_IN_21] in region 0 ...
     53: SYSTEM: ListElem Shared Addr = 0x2b988a80
     71: SYSTEM: System Common Init Done !!!
    ********* Entered usecase 16CH Progressive <816x> Cap/Enc/Dec/Dis
     312: MCFW  : CPU Revision [ES1.1] !!!
     312: MCFW  : Detected [(null)] Board !!!
     312: MCFW  : Base Board Revision [DVR] !!!
     312: MCFW  : Daughter Card Revision [DVR] !!!
    Feb 11 07:38:54 192 user.notice TI_VCAP :  Vcap_configVideoDecoder: TVP5158-0 (0x5c): Detected video (720x288@50Hz, 1)
    Feb 11 07:38:54 192 user.err TI_VCAP : Vcap_configVideoDecoder: ti_vcap.c 2223
    Feb 11 07:38:54 192 user.notice TI_VCAP :  Vcap_configVideoDecoder: TVP5158-1 (0x5d): Detected video (720x288@50Hz, 1)
    Feb 11 07:38:54 192 user.notice TI_VCAP :  Vcap_configVideoDecoder: TVP5158-2 (0x5e): Detected video (720x288@50Hz, 1)
    Feb 11 07:38:54 192 user.notice TI_VCAP :  Vcap_configVideoDecoder: TVP5158-3 (0x5f): Detected video (720x288@50Hz, 1)
     TVP5158: 0x5c: Downloading patch ...
     TVP5158: 0x5c: Downloading patch ... DONE !!!
     TVP5158: 0x5c: 5158:0002:0302
     TVP5158: 0x5d: Downloading patch ...
     TVP5158: 0x5d: Downloading patch ... DONE !!!
     TVP5158: 0x5d: 5158:0002:0302
     TVP5158: 0x5e: Downloading patch ...
     TVP5158: 0x5e: Downloading patch ... DONE !!!
     TVP5158: 0x5e: 5158:0002:0302
     TVP5158: 0x5f: Downloading patch ...
     TVP5158: 0x5f: Downloading patch ... DONE !!!
     TVP5158: 0x5f: 5158:0002:0302
     [m3vpss ]  19009: CAPTURE: Create in progress !!!
     [m3vpss ]  19041: CAPTURE: VIP0 PortA capture mode is [ 8-bit, Pixel-mux Embedded Sync] !!!
     [m3vpss ]  19129: CAPTURE: VIP0 PortB capture mode is [ 8-bit, Pixel-mux Embedded Sync] !!!
     [m3vpss ]  19216: CAPTURE: VIP1 PortA capture mode is [ 8-bit, Pixel-mux Embedded Sync] !!!
     [m3vpss ]  19304: CAPTURE: VIP1 PortB capture mode is [ 8-bit, Pixel-mux Embedded Sync] !!!
     [m3vpss ]  19405: CAPTURE: 0: 0xb48c0c80, 736 x 288, 00067800 B --> Extra Frames
     [m3vpss ]  19405: CAPTURE: 1: 0xb4928480, 736 x 288, 00067800 B --> Extra Frames
     [m3vpss ]  19405: CAPTURE: 2: 0xb498fc80, 736 x 288, 00067800 B --> Extra Frames
     [m3vpss ]  19405: CAPTURE: 3: 0xb49f7480, 736 x 288, 00067800 B --> Extra Frames
     [m3vpss ]  19405: CAPTURE: 4: 0xb4a5ec80, 736 x 288, 00067800 B --> Extra Frames
     [m3vpss ]  19405: CAPTURE: 5: 0xb4ac6480, 736 x 288, 00067800 B --> Extra Frames
     [m3vpss ]  UTILS: DMA: Allocated CH (TCC) = 58 (58)
     [c6xdsp ]  19666: IPC_FRAMES_IN   : Create in progress !!!
     [c6xdsp ]  19666: SYSTEM: Opening ListMP [VPSS-M3_IPC_OUT_19] ...
     [m3vpss ] CAPTURE::HEAPID:0	USED:1136
     [c6xdsp ]  19666: SYSTEM: Opening ListMP [VPSS-M3_IPC_IN_19] ...
     [m3vpss ] CAPTURE::HEAPID:4	USED:74520576
     [m3vpss ]  19406: CAPTURE: Create Done !!!
     [m3vpss ]  19410: DUP   : Create Done !!!
     [m3vpss ]  19410: IPC_FRAMES_OUT   : Create in progress !!!
     [c6xdsp ]  19667: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
     [m3vpss ]  19412: IPC_FRAMES_OUT   : Create Done !!!
     [c6xdsp ] IPC_FRAMES_IN:HEAPID:0	USED:304
     [c6xdsp ]  19668: IPC_FRAMES_IN   : Create Done !!!
     [c6xdsp ]  19670: ALG : Create in progress !!!
     [m3vpss ]  19424: DEI    : Create in progress !!!
     [c6xdsp ] ALGLINK:HEAPID:0	USED:2616
     [c6xdsp ] ALGLINK:HEAPID:1	USED:5904
     [c6xdsp ]  19678: ALG : Create Done !!!
     [m3vpss ]  19769: DEI     : Loading Up-scaling Co-effs
     [m3vpss ]  19769: DEI     : Co-effs Loading ... DONE !!!
     [m3vpss ] DEI:HEAPID:0	USED:64
     [m3vpss ] DEI:HEAPID:1	USED:17472
     [m3vpss ] DEI:HEAPID:4	USED:65286144
     [m3vpss ]  19769: DEI    : Create Done !!!
     [m3vpss ]  19770: DEI    : Create in progress !!!
     [m3vpss ]  20114: DEI     : Loading Up-scaling Co-effs
     [m3vpss ]  20114: DEI     : Co-effs Loading ... DONE !!!
     [m3video]  20126: IPC_IN_M3   : Create in progress !!!
     [m3video]  20126: SYSTEM: Opening ListMP [VPSS-M3_IPC_OUT_0] ...
     [m3vpss ] DEI:HEAPID:1	USED:16448
     [m3video]  20126: SYSTEM: Opening ListMP [VPSS-M3_IPC_IN_0] ...
     [m3video]  20128: IPC_IN_M3   : Create Done !!!
     [m3vpss ]  20115: DEI    : Create Done !!!
     [m3video]  20128: ENCODE: Create in progress ... !!!
     [m3vpss ]  20115: MERGE   : Create Done !!!
     [m3vpss ]  20119: DUP   : Create Done !!!
     [m3vpss ]  20120: MERGE   : Create Done !!!
     [m3vpss ]  20123: DUP   : Create Done !!!
     [m3vpss ]  20124: MERGE   : Create Done !!!
     [m3vpss ]  20124: IPC_OUT_M3   : Create in progress !!!
     [m3vpss ]  20125: IPC_OUT_M3   : Create Done !!!
     [m3video]  20268: ENCODE: Creating CH0 of 704 x 576, pitch = (16384, 32768) [PROGRESSIVE] [TILED      ], bitrate = 2000 Kbps ...
     [m3video] ENCLINK_H264:HEAPID:0	USED:13808
     [m3video] ENCLINK_H264:HEAPID:3	USED:49152
     [m3video]  20271: ENCODE: Creating CH1 of 704 x 576, pitch = (16384, 32768) [PROGRESSIVE] [TILED      ], bitrate = 2000 Kbps ...
     [m3video] ENCLINK_H264:HEAPID:0	USED:11912
     [m3video]  20273: ENCODE: Creating CH2 of 704 x 576, pitch = (16384, 32768) [PROGRESSIVE] [TILED      ], bitrate = 2000 Kbps ...
     [m3video]  20276: ENCODE: Creating CH3 of 704 x 576, pitch = (16384, 32768) [PROGRESSIVE] [TILED      ], bitrate = 2000 Kbps ...
     [m3video]  20278: ENCODE: Creating CH4 of 704 x 576, pitch = (16384, 32768) [PROGRESSIVE] [TILED      ], bitrate = 2000 Kbps ...
     [m3video]  20281: ENCODE: Creating CH5 of 704 x 576, pitch = (16384, 32768) [PROGRESSIVE] [TILED      ], bitrate = 2000 Kbps ...
     [m3video]  20283: ENCODE: Creating CH6 of 704 x 576, pitch = (16384, 32768) [PROGRESSIVE] [TILED      ], bitrate = 2000 Kbps ...
     [m3video]  20286: ENCODE: Creating CH7 of 704 x 576, pitch = (16384, 32768) [PROGRESSIVE] [TILED      ], bitrate = 2000 Kbps ...
     [m3video]  20288: ENCODE: Creating CH8 of 704 x 576, pitch = (16384, 32768) [PROGRESSIVE] [TILED      ], bitrate = 2000 Kbps ...
     [m3video]  20291: ENCODE: Creating CH9 of 704 x 576, pitch = (16384, 32768) [PROGRESSIVE] [TILED      ], bitrate = 2000 Kbps ...
     [m3video]  20293: ENCODE: Creating CH10 of 704 x 576, pitch = (16384, 32768) [PROGRESSIVE] [TILED      ], bitrate = 2000 Kbps ...
     6750: SYSTEM: Opening ListMP [VIDEO-M3_IPC_IN_24] ...
    Feb 11 07:39:01 192 user.notice [host] : IpcBitsInLink_tskMain:Entered
    Feb 11 07:39:01 192 user.notice [host] :  6747: IPC_BITS_IN   : Create in progress !!!
     [m3video]  20296: ENCODE: Creating CH11 of 704 x 576, pitch = (16384, 32768) [PROGRESSIVE] [TILED      ], bitrate = 2000 Kbps ...
    Feb 11 07:39:01 192 user.notice [host] :  6747: IPC_BITS_IN   : ListMPOpen start !!!
    Feb 11 07:39:01 192 user.notice [host] :  6747: SYSTEM: Opening ListMP [VIDEO-M3_IPC_OUT_24] ...
    Feb 11 07:39:01 192 user.notice [host] :  6752: IPC_BITS_IN   : ListMPOpen done !!!
    Feb 11 07:39:01 192 user.notice [host] :  6754: IPC_BITS_IN   : System_linkGetInfo done !!!
    Feb 11 07:39:01 192 user.notice [host] :  6754: IPC_BITS_IN   : Create Done !!!
    Reducing bitsProducerLinkInfo.numCh to 16
    ###Bit buff of size from the SR # 1 : 53084160
    Feb 11 07:39:01 192 user.notice [host] :  6756: IPC_BITS_OUT   : Create in progress !!!
    Feb 11 07:39:01 192 user.notice [host] : IPC_BITSOUT:BitBuffer Alloc.PoolID:0,Size:0x32A0000
    Feb 11 07:39:01 192 user.notice [host] : IPCBITSOUTLINK:Translated Addr Virt:0x2e07d880 To Phy:0x899ae880
    Feb 11 07:39:01 192 user.notice [host] :  6758: IPC_BITS_OUT   : Create Done !!!
     [m3video]  20298: ENCODE: Creating CH12 of 704 x 576, pitch = (16384, 32768) [PROGRESSIVE] [TILED      ], bitrate = 2000 Kbps ...
     [m3video]  20301: ENCODE: Creating CH13 of 704 x 576, pitch = (16384, 32768) [PROGRESSIVE] [TILED      ], bitrate = 2000 Kbps ...
     [m3video]  20303: ENCODE: Creating CH14 of 704 x 576, pitch = (16384, 32768) [PROGRESSIVE] [TILED      ], bitrate = 2000 Kbps ...
     [m3video]  20306: ENCODE: Creating CH15 of 704 x 576, pitch = (16384, 32768) [PROGRESSIVE] [TILED      ], bitrate = 2000 Kbps ...
     [m3video]  20308: ENCODE: Creating CH16 of 352 x 288, pitch = (352, 352) [PROGRESSIVE] [NON-TILED  ], bitrate = 500 Kbps ...
     [m3video] ENCLINK_H264:HEAPID:3	USED:577536
     [m3video]  20313: ENCODE: Creating CH17 of 352 x 288, pitch = (352, 352) [PROGRESSIVE] [NON-TILED  ], bitrate = 500 Kbps ...
     [m3video]  20317: ENCODE: Creating CH18 of 352 x 288, pitch = (352, 352) [PROGRESSIVE] [NON-TILED  ], bitrate = 500 Kbps ...
     [m3video]  20321: ENCODE: Creating CH19 of 352 x 288, pitch = (352, 352) [PROGRESSIVE] [NON-TILED  ], bitrate = 500 Kbps ...
     [m3video]  20325: ENCODE: Creating CH20 of 352 x 288, pitch = (352, 352) [PROGRESSIVE] [NON-TILED  ], bitrate = 500 Kbps ...
     [m3video]  20330: ENCODE: Creating CH21 of 352 x 288, pitch = (352, 352) [PROGRESSIVE] [NON-TILED  ], bitrate = 500 Kbps ...
     [m3video]  20334: ENCODE: Creating CH22 of 352 x 288, pitch = (352, 352) [PROGRESSIVE] [NON-TILED  ], bitrate = 500 Kbps ...
     [m3video]  20338: ENCODE: Creating CH23 of 352 x 288, pitch = (352, 352) [PROGRESSIVE] [NON-TILED  ], bitrate = 500 Kbps ...
     [m3video]  20342: ENCODE: Creating CH24 of 352 x 288, pitch = (352, 352) [PROGRESSIVE] [NON-TILED  ], bitrate = 500 Kbps ...
     [m3video]  20347: ENCODE: Creating CH25 of 352 x 288, pitch = (352, 352) [PROGRESSIVE] [NON-TILED  ], bitrate = 500 Kbps ...
     [m3video]  20351: ENCODE: Creating CH26 of 352 x 288, pitch = (352, 352) [PROGRESSIVE] [NON-TILED  ], bitrate = 500 Kbps ...
     [m3video]  20355: ENCODE: Creating CH27 of 352 x 288, pitch = (352, 352) [PROGRESSIVE] [NON-TILED  ], bitrate = 500 Kbps ...
     [m3video]  20359: ENCODE: Creating CH28 of 352 x 288, pitch = (352, 352) [PROGRESSIVE] [NON-TILED  ], bitrate = 500 Kbps ...
     [m3vpss ]  20845: IPC_IN_M3   : Create in progress !!!
     [m3vpss ]  20845: SYSTEM: Opening ListMP [VIDEO-M3_IPC_OUT_0] ...
     [m3vpss ]  20846: SYSTEM: Opening ListMP [VIDEO-M3_IPC_IN_0] ...
     [m3vpss ]  20846: SYSTEM: Opening MsgQ [VIDEO-M3_MSGQ] ...
     [m3vpss ]  20848: IPC_IN_M3   : Create Done !!!
     [m3video]  20364: ENCODE: Creating CH29 of 352 x 288, pitch = (352, 352) [PROGRESSIVE] [NON-TILED  ], bitrate = 500 Kbps ...
     [m3vpss ]  20849: MERGE   : Create Done !!!
     [m3vpss ]  20853: DUP   : Create Done !!!
     [m3vpss ]  20853: SWMS: Create in progress !!!
     [m3video]  20368: ENCODE: Creating CH30 of 352 x 288, pitch = (352, 352) [PROGRESSIVE] [NON-TILED  ], bitrate = 500 Kbps ...
     [m3video]  20372: ENCODE: Creating CH31 of 352 x 288, pitch = (352, 352) [PROGRESSIVE] [NON-TILED  ], bitrate = 500 Kbps ...
     [m3video]  20377: ENCODE: All CH Create ... DONE !!!
     [m3video] ENCLINK:HEAPID:0	USED:383200
     [m3video] ENCLINK:HEAPID:2	USED:26929152
     [m3video] ENCLINK:HEAPID:3	USED:10027008
     [m3video]  20378: ENCODE: Create ... DONE !!!
     [m3video]  20379: IPC_BITS_OUT   : Create in progress !!!
     [m3video]  20380: IPC_BITS_OUT   : Create Done !!!
     [m3video]  20392: IPC_BITS_IN   : Create in progress !!!
     [m3video]  20392: SYSTEM: Opening ListMP [HOST_IPC_OUT_24] ...
     [m3video]  20392: SYSTEM: Opening ListMP [HOST_IPC_IN_24] ...
     [m3video]  20393: SYSTEM: Opening MsgQ [HOST_MSGQ] ...
     [m3video]  20395: IPC_BITS_IN   : Create Done !!!
     [m3video]  20396: DECODE: Create in progress ... !!!
     [m3video] DECLINK_H264:HEAPID:0	USED:2368
     [m3video] DECLINK_H264:HEAPID:3	USED:4501504
     [m3video]  20423: DECODE: Creating CH0 of 720 x 576 [PROGRESSIVE] [TILED      ],target bitrate = 2000 Kbps ...
     [m3video]  20450: DECODE: Creating CH1 of 720 x 576 [PROGRESSIVE] [TILED      ],target bitrate = 2000 Kbps ...
     [m3vpss ]  UTILS: DMA: Allocated CH (TCC) = 59 (59)
     [m3video]  20476: DECODE: Creating CH2 of 720 x 576 [PROGRESSIVE] [TILED      ],target bitrate = 2000 Kbps ...
     [m3vpss ] SWMS: instance 0, sc id 5, start win 0 end win 17
     [m3video]  20503: DECODE: Creating CH3 of 720 x 576 [PROGRESSIVE] [TILED      ],target bitrate = 2000 Kbps ...
     [m3vpss ]  20970: SWMS0    : Loading Vertical Co-effs (UPSCALE)x ...
     [m3vpss ]  20970: SWMS0    : Loading Horizontal Co-effs (UPSCALE)x ...
     [m3vpss ]  20970: SWMS    : Co-effs Loading ... DONE !!!
     [m3video]  20529: DECODE: Creating CH4 of 720 x 576 [PROGRESSIVE] [TILED      ],target bitrate = 2000 Kbps ...
     [m3vpss ]  20971: SWMS    : ******* Configuring clock 37 secs...
     [m3vpss ]  20971: SWMS0    : Loading Vertical Co-effs (UPSCALE)x ...
     [m3vpss ]  20971: SWMS0    : Loading Horizontal Co-effs (UPSCALE)x ...
     [m3vpss ]  20971: SWMS    : Co-effs Loading ... DONE !!!
     [m3video] DECLINK_H264:HEAPID:2	USED:4083712
     [m3vpss ]
     [m3vpss ]  *** [SWMS0] Mosaic Parameters ***
     [m3vpss ]
     [m3vpss ]  Output FPS: 25
     [m3vpss ]
     [m3vpss ]  Win | Ch  | Input      | Input          | Input         | Input       | Output     |  Output         | Output        | Output      | Low Cost | SWMS | Data  | Blank |
     [m3vpss ]  Num | Num | Start X, Y | Width x Height | Pitch Y / C   | Memory Type | Start X, Y |  Width x Height | Pitch Y / C   | Memory Type | ON / OFF | Inst | Format| Frame |
     [m3vpss ]  ----------------------------------------------------------------------------------------------------------------------------------------------------------------------
     [m3video] DECLINK_H264:HEAPID:3	USED:417792
     [m3vpss ]    0 |  32 |    0,    0 |   352 x    288 |   352 /   352 | NON-TILED   |    0,    0 |   480 x    270 |  3840 /      0 | NON-TILED   |      OFF |    0 |  420SP |   OFF |
     [m3video]  20556: DECODE: Creating CH5 of 720 x 576 [PROGRESSIVE] [TILED      ],target bitrate = 2000 Kbps ...
     [m3vpss ]    1 |  33 |    0,    0 |   352 x    288 |   352 /   352 | NON-TILED   |  480,    0 |   480 x    270 |  3840 /      0 | NON-TILED   |      OFF |    0 |  420SP |   OFF |
     [m3vpss ]    2 |  34 |    0,    0 |   352 x    288 |   352 /   352 | NON-TILED   |  960,    0 |   480 x    270 |  3840 /      0 | NON-TILED   |      OFF |    0 |  420SP |   OFF |
     [m3vpss ]    3 |  35 |    0,    0 |   352 x    288 |   352 /   352 | NON-TILED   | 1440,    0 |   480 x    270 |  3840 /      0 | NON-TILED   |      OFF |    0 |  420SP |   OFF |
     [m3vpss ]    4 |  36 |    0,    0 |   352 x    288 |   352 /   352 | NON-TILED   |    0,  270 |   480 x    270 |  3840 /      0 | NON-TILED   |      OFF |    0 |  420SP |   OFF |
     [m3vpss ]    5 |  37 |    0,    0 |   352 x    288 |   352 /   352 | NON-TILED   |  480,  270 |   480 x    270 |  3840 /      0 | NON-TILED   |      OFF |    0 |  420SP |   OFF |
     [m3vpss ]    6 |  38 |    0,    0 |   352 x    288 |   352 /   352 | NON-TILED   |  960,  270 |   480 x    270 |  3840 /      0 | NON-TILED   |      OFF |    0 |  420SP |   OFF |
     [m3video]  20583: DECODE: Creating CH6 of 720 x 576 [PROGRESSIVE] [TILED      ],target bitrate = 2000 Kbps ...
     [m3vpss ]    7 |  39 |    0,    0 |   352 x    288 |   352 /   352 | NON-TILED   | 1440,  270 |   480 x    270 |  3840 /      0 | NON-TILED   |      OFF |    0 |  420SP |   OFF |
     [m3vpss ]    8 |  40 |    0,    0 |   352 x    288 |   352 /   352 | NON-TILED   |    0,  540 |   480 x    270 |  3840 /      0 | NON-TILED   |      OFF |    0 |  420SP |   OFF |
     [m3vpss ]    9 |  41 |    0,    0 |   352 x    288 |   352 /   352 | NON-TILED   |  480,  540 |   480 x    270 |  3840 /      0 | NON-TILED   |      OFF |    0 |  420SP |   OFF |
     [m3vpss ]   10 |  42 |    0,    0 |   352 x    288 |   352 /   352 | NON-TILED   |  960,  540 |   480 x    270 |  3840 /      0 | NON-TILED   |      OFF |    0 |  420SP |   OFF |
     [m3vpss ]   11 |  43 |    0,    0 |   352 x    288 |   352 /   352 | NON-TILED   | 1440,  540 |   480 x    270 |  3840 /      0 | NON-TILED   |      OFF |    0 |  420SP |   OFF |
     [m3vpss ]   12 |  44 |    0,    0 |   352 x    288 |   352 /   352 | NON-TILED   |    0,  810 |   480 x    270 |  3840 /      0 | NON-TILED   |      OFF |    0 |  420SP |   OFF |
     [m3video]  20610: DECODE: Creating CH7 of 720 x 576 [PROGRESSIVE] [TILED      ],target bitrate = 2000 Kbps ...
     [m3vpss ]   13 |  45 |    0,    0 |   352 x    288 |   352 /   352 | NON-TILED   |  480,  810 |   480 x    270 |  3840 /      0 | NON-TILED   |      OFF |    0 |  420SP |   OFF |
     [m3vpss ]   14 |  46 |    0,    0 |   352 x    288 |   352 /   352 | NON-TILED   |  960,  810 |   480 x    270 |  3840 /      0 | NON-TILED   |      OFF |    0 |  420SP |   OFF |
     [m3vpss ]   15 |  47 |    0,    0 |   352 x    288 |   352 /   352 | NON-TILED   | 1440,  810 |   480 x    270 |  3840 /      0 | NON-TILED   |      OFF |    0 |  420SP |   OFF |
     [m3vpss ]
     [m3video]  20637: DECODE: Creating CH8 of 720 x 576 [PROGRESSIVE] [TILED      ],target bitrate = 2000 Kbps ...
     [m3vpss ] SWMS:HEAPID:0	USED:360
     [m3vpss ] SWMS:HEAPID:1	USED:47296
     [m3vpss ] SWMS:HEAPID:3	USED:20736000
     [m3vpss ]  20978: SWMS: Create Done !!!
     [m3vpss ]  20979: SWMS: Create in progress !!!
     [m3vpss ]  UTILS: DMA: Allocated CH (TCC) = 60 (60)
     [m3video]  20664: DECODE: Creating CH9 of 720 x 576 [PROGRESSIVE] [TILED      ],target bitrate = 2000 Kbps ...
     [m3vpss ]  21009: SWMS1    : Loading Vertical Co-effs (UPSCALE)x ...
     [m3vpss ]  21009: SWMS1    : Loading Horizontal Co-effs (UPSCALE)x ...
     [m3vpss ]  21010: SWMS    : Co-effs Loading ... DONE !!!
     [m3vpss ]  21010: SWMS    : ******* Configuring clock 37 secs...
     [m3vpss ]  21010: SWMS1    : Loading Vertical Co-effs (UPSCALE)x ...
     [m3video]  20691: DECODE: Creating CH10 of 720 x 576 [PROGRESSIVE] [TILED      ],target bitrate = 2000 Kbps ...
     [m3vpss ]  21010: SWMS1    : Loading Horizontal Co-effs (UPSCALE)x ...
     [m3vpss ]  21011: SWMS    : Co-effs Loading ... DONE !!!
     [m3vpss ]
     [m3vpss ]  *** [SWMS1] Mosaic Parameters ***
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]    0 |  32 |    0,    0 |   352 x    288 |   352 /   352 | NON-TILED   |    0,    0 |   176 x    144 |  1472 /      0 | NON-TILED   |      OFF |    0 |  420SP |   OFF |
     [m3vpss ]    1 |  33 |    0,    0 |   352 x    288 |   352 /   352 | NON-TILED   |  176,    0 |   176 x    144 |  1472 /      0 | NON-TILED   |      OFF |    0 |  420SP |   OFF |
     [m3vpss ]    2 |  34 |    0,    0 |   352 x    288 |   352 /   352 | NON-TILED   |  352,    0 |   176 x    144 |  1472 /      0 | NON-TILED   |      OFF |    0 |  420SP |   OFF |
     [m3video]  20718: DECODE: Creating CH11 of 720 x 576 [PROGRESSIVE] [TILED      ],target bitrate = 2000 Kbps ...
     [m3vpss ]    3 |  35 |    0,    0 |   352 x    288 |   352 /   352 | NON-TILED   |  528,    0 |   192 x    144 |  1472 /      0 | NON-TILED   |      OFF |    0 |  420SP |   OFF |
     [m3vpss ]    4 |  36 |    0,    0 |   352 x    288 |   352 /   352 | NON-TILED   |    0,  144 |   176 x    144 |  1472 /      0 | NON-TILED   |      OFF |    0 |  420SP |   OFF |
     [m3vpss ]    5 |  37 |    0,    0 |   352 x    288 |   352 /   352 | NON-TILED   |  176,  144 |   176 x    144 |  1472 /      0 | NON-TILED   |      OFF |    0 |  420SP |   OFF |
     [m3vpss ]    6 |  38 |    0,    0 |   352 x    288 |   352 /   352 | NON-TILED   |  352,  144 |   176 x    144 |  1472 /      0 | NON-TILED   |      OFF |    0 |  420SP |   OFF |
     [m3video] DECLINK_H264:HEAPID:2	USED:4263936
     [m3vpss ]    7 |  39 |    0,    0 |   352 x    288 |   352 /   352 | NON-TILED   |  528,  144 |   192 x    144 |  1472 /      0 | NON-TILED   |      OFF |    0 |  420SP |   OFF |
     [m3video] DECLINK_H264:HEAPID:3	USED:237568
     [m3vpss ]    8 |  40 |    0,    0 |   352 x    288 |   352 /   352 | NON-TILED   |    0,  288 |   176 x    144 |  1472 /      0 | NON-TILED   |      OFF |    0 |  420SP |   OFF |
     [m3video]  20746: DECODE: Creating CH12 of 720 x 576 [PROGRESSIVE] [TILED      ],target bitrate = 2000 Kbps ...
     [m3vpss ]    9 |  41 |    0,    0 |   352 x    288 |   352 /   352 | NON-TILED   |  176,  288 |   176 x    144 |  1472 /      0 | NON-TILED   |      OFF |    0 |  420SP |   OFF |
     [m3vpss ]   10 |  42 |    0,    0 |   352 x    288 |   352 /   352 | NON-TILED   |  352,  288 |   176 x    144 |  1472 /      0 | NON-TILED   |      OFF |    0 |  420SP |   OFF |
     [m3vpss ]   11 |  43 |    0,    0 |   352 x    288 |   352 /   352 | NON-TILED   |  528,  288 |   192 x    144 |  1472 /      0 | NON-TILED   |      OFF |    0 |  420SP |   OFF |
     [m3vpss ]   12 |  44 |    0,    0 |   352 x    288 |   352 /   352 | NON-TILED   |    0,  432 |   176 x    144 |  1472 /      0 | NON-TILED   |      OFF |    0 |  420SP |   OFF |
     [m3video] DECLINK_H264:HEAPID:2	USED:4497408
     [m3vpss ]   13 |  45 |    0,    0 |   352 x    288 |   352 /   352 | NON-TILED   |  176,  432 |   176 x    144 |  1472 /      0 | NON-TILED   |      OFF |    0 |  420SP |   OFF |
     [m3video] DECLINK_H264:HEAPID:3	USED:4096
     [m3vpss ]   14 |  46 |    0,    0 |   352 x    288 |   352 /   352 | NON-TILED   |  352,  432 |   176 x    144 |  1472 /      0 | NON-TILED   |      OFF |    0 |  420SP |   OFF |
     [m3video]  20777: DECODE: Creating CH13 of 720 x 576 [PROGRESSIVE] [TILED      ],target bitrate = 2000 Kbps ...
     [m3vpss ]   15 |  47 |    0,    0 |   352 x    288 |   352 /   352 | NON-TILED   |  528,  432 |   192 x    144 |  1472 /      0 | NON-TILED   |      OFF |    0 |  420SP |   OFF |
     [m3vpss ]
     [m3video] DECLINK_H264:HEAPID:2	USED:4501504
     [m3video]  20808: DECODE: Creating CH14 of 720 x 576 [PROGRESSIVE] [TILED      ],target bitrate = 2000 Kbps ...
     [m3vpss ] SWMS:HEAPID:1	USED:43776
     [m3vpss ] SWMS:HEAPID:3	USED:4239360
     [m3vpss ]  21017: SWMS: Create Done !!!
     [m3vpss ]  21017: DISPLAY: Create in progress !!!
     [m3vpss ] ==============FVID2_SETFMT STARTING===================
     [m3video]  20839: DECODE: Creating CH15 of 720 x 576 [PROGRESSIVE] [TILED      ],target bitrate = 2000 Kbps ...
     [m3vpss ] ==============FVID2_SETFMT STARTED===================
     [m3video]  20840: DECODE: All CH Create ... DONE !!!
     [m3vpss ]  21019: DISPLAY: Create Done !!!
     [m3vpss ]  21019: DISPLAY: Create in progress !!!
     [m3video] DECLINK:HEAPID:0	USED:38008
     [m3video] DECLINK:HEAPID:2	USED:46350336
     [m3vpss ]  21020: DISPLAY: Create Done !!!
     [m3video] DECLINK:HEAPID:3	USED:25673728
     [m3vpss ]  21042: DISPLAY: Start in progress !!!
     [m3video]  20844: DECODE: Create ... DONE !!!
     [m3vpss ]  21105: DISPLAY: Start Done !!!
     [m3video]  20844: IPC_OUT_M3   : Create in progress !!!
     [m3vpss ]  21106: DISPLAY: HDDAC(BP0) : 31 fps, Latency (Min / Max) = ( 255 / 0 ), Callback Interval (Min / Max) = ( 255 / 0 ) !!!
     [m3video]  20845: IPC_OUT_M3   : Create Done !!!
     [m3vpss ]  21106: DISPLAY: UNDERFLOW COUNT: HDMI(BP0) 1, HDDAC(BP0) 1, DVO2(BP1) 1, SDDAC(SEC1) 0
     [m3vpss ]  21106: SYSTEM  : FREE SPACE : System Heap      = 4688 B, Mbx = 10238 msgs)
     [m3vpss ]  21106: SYSTEM  : FREE SPACE : SR0 Heap         = 10512128 B (10 MB)
     [m3vpss ]  21106: SYSTEM  : FREE SPACE : Frame Buffer     = 896 B (0 MB)
     [m3vpss ]  21106: SYSTEM  : FREE SPACE : Bitstream Buffer = 200982400 B (191 MB)
     [m3vpss ]  21107: SYSTEM  : FREE SPACE : Tiler 8-bit      = 19243008 B (18 MB)  - TILER ON
    Feb 11 07:39:02 192 user.debug LAUNCHER : Wait 1 seconds for DMP_ADAPTOR initialization
    Feb 11 07:39:02 192 user.info LAUNCHER : startup: starting DVR
     [m3vpss ]  21107: SYSTEM  : FREE SPACE : Tiler 16-bit     = 76816384 B (73 MB)  - TILER ON
     [m3vpss ]  21107: DISPLAY: Start in progress !!!
     [m3vpss ]  21178: DISPLAY: Start Done !!!
     [m3vpss ]  21178: DISPLAY: SDDAC(SEC1): 14 fps, Latency (Min / Max) = ( 255 / 0 ), Callback Interval (Min / Max) = ( 255 / 0 ) !!!
     [m3vpss ]  21178: SWMS: Start in Progress !!!
     [m3vpss ]  21179: SWMS: Start Done !!!
     [m3vpss ]  21179: SWMS: Start in Progress !!!
     [m3vpss ]  21183: CAPTURE: Start in progress !!!
     [m3vpss ]  21183: CAPTURE: Start Done !!!
  • Pls set captureLink create params "enableSDCrop" to FALSE to capture 720 width instead of 704
  • Ok, enableSdCrop changes the encoded resolution to 720x576.
    But now we have a narrow stripe at the left side of the video picture.
    This black stripe is visible in mosaic and also in the recorded pictures.
    I attached a recorded file, this explains the effect.
    The white OSD background starts at 0,0 but video starts some pixels later
  • Can you check if capture link create params  . doCropInCapture is set to FALSE ? Also do you have SYSTEM_USE_VIDEO_DECODER define enabled in system_debug.h ?
  • I set doCropInCapture FALSE and enabled SYSTEM_USE_VIDEO_DECODER but the narrow stripe still occurs.
  • Dont enable SYSTEM_USE_VIDEO_DECODER. Set doCropInCapture to FALSE, enableSdCrop to FALSE and share the log of Vsys_printDetailedStatistics.Are you using TVP 5158 or some other external video decoder ?
  • I disabled SYSTEM_USE_VIDEO_DECODER,  pPrm->enableSdCrop = FALSE;    pPrm->doCropInCapture = FALSE;
    We use TVP5158.
     [m3vpss ]
     [m3vpss ]  *** Capture Driver Advanced Statistics ***
     [m3vpss ]
     [m3vpss ]  VIP Parser Reset Count : 0
     [m3vpss ]
     [m3vpss ]      |   Total    Even     Odd  Total  Even   Odd  Min /  Max  Min /  Max Dropped Fid Repeat Frame Error Y/C
     [m3vpss ]  CH  |  Fields  Fields  Fields    FPS   FPS   FPS       Width      Height  Fields      Count (Desc Error Y/C)
     [m3vpss ]  000 |  111800   55901   55899     50    25    24  720 /  720  288 /  288       1          1 0/0 (0/0)
     [m3vpss ]  001 |  111806   55903   55903     50    25    25  720 /  720  288 /  288       5          0 0/0 (0/0)
     [m3vpss ]  002 |  111766   55884   55882     49    24    24  720 /  720  283 /  289       5         18 0/0 (3/0)
     [m3vpss ]  003 |  111782   55889   55893     49    24    24  720 /  720  283 /  289       5         16 0/0 (13/0)
     [m3vpss ]  100 |  111766   55884   55882     49    24    24  720 /  720  259 /  289       5         40 0/0 (3/0)
     [m3vpss ]  101 |  111771   55886   55885     49    24    24  720 /  720  167 /  289       5         21 0/0 (7/0)
     [m3vpss ]  102 |  111795   55899   55896     49    24    24  720 /  720  286 /  289       5         11 0/0 (1/0)
     [m3vpss ]  103 |  111799   55899   55900     49    24    25  720 /  720  285 /  289       5         15 0/0 (3/0)
     [m3vpss ]  200 |  111798   55901   55897     49    25    24  720 /  720  288 /  288       4          4 0/0 (16/0)
     [m3vpss ]  201 |  111798   55901   55897     49    25    24  720 /  720  288 /  288       4          4 0/0 (17/0)
     [m3vpss ]  202 |  111798   55899   55899     49    24    24  720 /  720  288 /  288       4          4 0/0 (15/0)
     [m3vpss ]  203 |  111798   55895   55903     49    24    25  720 /  720  288 /  288       4          8 0/0 (29/0)
     [m3vpss ]  300 |  111798   55899   55899     49    24    24  720 /  720  288 /  288       4          0 0/0 (0/0)
     [m3vpss ]  301 |  111798   55899   55899     49    24    24  720 /  720  288 /  288       4          0 0/0 (1/0)
     [m3vpss ]  302 |  111798   55899   55899     49    24    24  720 /  720  288 /  288       4          0 0/0 (0/0)
     [m3vpss ]  303 |  111798   55899   55899     49    24    24  720 /  720  288 /  288       4          4 0/0 (9/0)
     [m3vpss ]
     [m3vpss ]  VIP Capture Port 0 | DescMissMatch1 = 0, DescMissMatch2 = 0 , DescMissMatch3 = 0
     [m3vpss ]  VIP Capture Port 1 | DescMissMatch1 = 0, DescMissMatch2 = 0 , DescMissMatch3 = 0
     [m3vpss ]  VIP Capture Port 2 | DescMissMatch1 = 0, DescMissMatch2 = 0 , DescMissMatch3 = 0
     [m3vpss ]  VIP Capture Port 3 | DescMissMatch1 = 0, DescMissMatch2 = 0 , DescMissMatch3 = 0
     [m3vpss ]
     [m3vpss ]  *** Capture List Manager Advanced Statistics ***
     [m3vpss ]
     [m3vpss ]  List Post Count        : 1118030
     [m3vpss ]  List Stall Count       : 0
     [m3vpss ]  List Post Time (ms)    : Max = 2, Min = 0, Avg = 0, Total = 470
     [m3vpss ]  INTC Timeout Count     : (0, 0) (Min timeout value = 884, 969)
     [m3vpss ]  Descriptor miss found count : 0
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]  VIP and VPDMA registers,
     [m3vpss ]  VIP0 : FIQ_STATUS  : 0x4810551c = 0x00003400
     [m3vpss ]  VIP1 : FIQ_STATUS  : 0x48105a1c = 0x00001400
     [m3vpss ]  VPDMA: LIST_BUSY   : 0x4810d00c = 0x000e0000
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]  2255484: CAPTURE: Fields = 1788592 (fps = 799, CPU Load = 0)
     [m3vpss ]  2255484: CAPTURE: Num Resets = 0 (Avg 0 ms per reset)
     [m3vpss ]  2255484: SYSTEM  : FREE SPACE : System Heap      = 4688 B, Mbx = 10237 msgs)
     [m3vpss ]  2255485: SYSTEM  : FREE SPACE : SR0 Heap         = 10512128 B (10 MB)
     [m3vpss ]  2255485: SYSTEM  : FREE SPACE : Frame Buffer     = 896 B (0 MB)
     [m3vpss ]  2255485: SYSTEM  : FREE SPACE : Bitstream Buffer = 198288256 B (189 MB)
     [m3vpss ]  2255487: SYSTEM  : FREE SPACE : Tiler 8-bit      = 17883136 B (17 MB)  - TILER ON
     [m3vpss ]  2255488: SYSTEM  : FREE SPACE : Tiler 16-bit     = 75612160 B (72 MB)  - TILER ON
     [m3vpss ]
     [m3vpss ]  *** [DEI0    ] DEI Statistics ***
     [m3vpss ]
     [m3vpss ]  Elasped Time           : 152 secs
     [m3vpss ]  Total Fields Processed : 894528
     [m3vpss ]  Total Fields FPS       : 546 FPS
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]  CH  | In Recv In Reject In Process Out[0] Out[1] Out[2] Out[3] Out[4] Skip Out[0] Skip Out[1] Skip Out[2] Skip Out[3] Skip Out[4] User Out[0] User Out[1] User Out[2] User Out[3] User Out[4] Latency
     [m3vpss ]  Num | FPS     FPS       FPS        FPS    FPS    FPS    FPS    FPS       FPS         FPS         FPS         FPS         FPS       Skip FPS    Skip FPS    Skip FPS    Skip FPS    Skip FPS   Min / Max
     [m3vpss ]  -------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------
     [m3vpss ]    0 |      50         0         50     25     25     25      0      0           0           0           0           0           0          25           0           0           0           0   2 /  24
     [m3vpss ]    1 |      50         0         50      0     25     25      0      0           0           0           0           0           0          50           0           0           0           0   6 /  24
     [m3vpss ]    2 |      50         0         50      0     25     25      0      0           0           0           0           0           0          50           0           0           0           0   7 /  24
     [m3vpss ]    3 |      50         0         50      0     25     25      0      0           0           0           0           0           0          50           0           0           0           0   8 /  24
     [m3vpss ]    4 |      50         0         50      0     25     25      0      0           0           0           0           0           0          50           0           0           0           0  10 /  24
     [m3vpss ]    5 |      50         0         50      0     25     25      0      0           0           0           0           0           0          50           0           0           0           0  10 /  23
     [m3vpss ]    6 |      50         0         50      0     25     25      0      0           0           0           0           0           0          50           0           0           0           0  10 /  23
     [m3vpss ]    7 |      50         0         50      0     25     25      0      0           0           0           0           0           0          50           0           0           0           0  10 /  23
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]  *** [DEI2    ] DEI Statistics ***
     [m3vpss ]
     [m3vpss ]  Total Fields Processed : 895112
     [m3vpss ]  Total Fields FPS       : 543 FPS
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]    0 |      50         0         50      0     25     25      0      0           0           0           0           0           0          50           0           0           0           0   4 /  30
     [m3vpss ]    1 |      50         0         50      0     25     25      0      0           0           0           0           0           0          50           0           0           0           0   9 /  30
     [m3vpss ]    2 |      50         0         50      0     25     25      0      0           0           0           0           0           0          50           0           0           0           0   9 /  30
     [m3vpss ]    3 |      50         0         50      0     25     25      0      0           0           0           0           0           0          50           0           0           0           0   9 /  29
     [m3vpss ]    4 |      50         0         50      0     25     25      0      0           0           0           0           0           0          50           0           0           0           0   8 /  29
     [m3vpss ]    5 |      50         0         50      0     25     25      0      0           0           0           0           0           0          50           0           0           0           0   8 /  29
     [m3vpss ]    6 |      50         0         50      0     25     25      0      0           0           0           0           0           0          50           0           0           0           0   8 /  29
     [m3vpss ]    7 |      50         0         50      0     25     25      0      0           0           0           0           0           0          50           0           0           0           0   4 /  29
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]  *** [SWMS0] Mosaic Statistics ***
     [m3vpss ]
     [m3vpss ]  Elasped Time: 152 secs
     [m3vpss ]
     [m3vpss ]  Output Request FPS   : 30 fps (4577 frames)
     [m3vpss ]  Output Actual  FPS   : 30 fps (4577 frames)
     [m3vpss ]  Output Drop    FPS   : 0 fps (0 frames)
     [m3vpss ]  Output Reject  FPS   : 0 fps (0 frames)
     [m3vpss ]  Scaling Internal     : 33 ms
     [m3vpss ]  Scaling Internal min : 20 ms
     [m3vpss ]  Scaling Internal max : 41 ms
     [m3vpss ]
     [m3vpss ]  Win | Window Repeat Drop Recv Que  FID Invlid Acc Event          Invalid   Que Reject Reject Latency
     [m3vpss ]  Num | FPS    FPS    FPS  FPS  FPS  FPS        Count (Max/Min)    CH Frames Frames     Frames Min / Max
     [m3vpss ]    0 |     30      5    0    0   25          0        0 (  0/255)         0          0      0   7 /  63
     [m3vpss ]    1 |     30      5    0    0   25          0        0 (  0/255)         0          0      0  11 /  66
     [m3vpss ]    2 |     30      5    0    0   25          0        0 (  0/255)         0          0      0  11 /  66
     [m3vpss ]    3 |     30      5    0    0   25          0        0 (  0/255)         0          0      0  11 /  66
     [m3vpss ]    4 |     30      5    0    0   25          0        0 (  0/255)         0          0      0  18 /  66
     [m3vpss ]    5 |     30      5    0    0   25          0        0 (  0/255)         0          0      0  18 /  65
     [m3vpss ]    6 |     30      5    0    0   25          0        0 (  0/255)         0          0      0  18 /  65
     [m3vpss ]    7 |     30      5    0    0   25          0        0 (  0/255)         0          0      0  18 /  65
     [m3vpss ]    8 |     30      5    0    0   25          0        0 (  0/255)         0          0      0  10 /  66
     [m3vpss ]    9 |     30      5    0    0   25          0        0 (  0/255)         0          0      0  10 /  66
     [m3vpss ]   10 |     30      5    0    0   25          0        0 (  0/255)         0          0      0  10 /  66
     [m3vpss ]   11 |     30      5    0    0   25          0        0 (  0/255)         0          0      0  10 /  66
     [m3vpss ]   12 |     30      5    0    0   25          0        0 (  0/255)         0          0      0  18 /  66
     [m3vpss ]   13 |     30      5    0    0   25          0        0 (  0/255)         0          0      0  18 /  66
     [m3vpss ]   14 |     30      5    0    0   25          0        0 (  0/255)         0          0      0  18 /  66
     [m3vpss ]   15 |     30      5    0    0   25          0        0 (  0/255)         0          0      0  18 /  67
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]  *** [SWMS1] Mosaic Statistics ***
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]  Output Request FPS   : 25 fps (3814 frames)
     [m3vpss ]  Output Actual  FPS   : 25 fps (3814 frames)
     [m3vpss ]  Scaling Internal     : 39 ms
     [m3vpss ]  Scaling Internal min : 29 ms
     [m3vpss ]  Scaling Internal max : 52 ms
     [m3vpss ]
     [m3vpss ]    0 |     25      0    0    0   25          0        0 (  0/255)         0          0      0  76 /  96
     [m3vpss ]    1 |     25      0    0    0   25          0        0 (  0/255)         0          0      0 148 / 176
     [m3vpss ]    2 |     25      0    0    0   25          0        0 (  0/255)         0          0      0  28 /  48
     [m3vpss ]    3 |     25      0    0    0   25          0        0 (  0/255)         0          0      0  28 /  48
     [m3vpss ]    4 |     25      0    0    0   25          0        0 (  0/255)         0          0      0  28 /  48
     [m3vpss ]    5 |     25      0    0    0   25          0        0 (  0/255)         0          0      0  28 /  48
     [m3vpss ]    6 |     25      0    0    0   25          0        0 (  0/255)         0          0      0  28 /  48
     [m3vpss ]    7 |     25      0    0    0   25          0        0 (  0/255)         0          0      0  28 /  47
     [m3vpss ]    8 |     25      0    0    0   25          0        0 (  0/255)         0          0      0  20 /  79
     [m3vpss ]    9 |     25      0    0    0   25          0        0 (  0/255)         0          0      0  20 /  79
     [m3vpss ]   10 |     25      0    0    0   25          0        0 (  0/255)         0          0      0  20 /  79
     [m3vpss ]   11 |     25      0    0    0   25          0        0 (  0/255)         0          0      0  20 /  79
     [m3vpss ]   12 |     25      0    0    0   25          0        0 (  0/255)         0          0      0  20 /  79
     [m3vpss ]   13 |     25      0    0    0   25          0        0 (  0/255)         0          0      0  20 /  79
     [m3vpss ]   14 |     25      0    0    0   25          0        0 (  0/255)         0          0      0  20 /  79
     [m3vpss ]   15 |     25      0    0    0   25          0        0 (  0/255)         0          0      0  20 /  79
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]  2260533: DISPLAY: HDDAC(BP0) : 59 fps, Latency (Min / Max) = ( 12 / 27 ), Callback Interval (Min / Max) = ( 16 / 17 ) !!!
     [m3vpss ]  2260533: DISPLAY: UNDERFLOW COUNT: HDMI(BP0) 9155, HDDAC(BP0) 9159, DVO2(BP1) 9158, SDDAC(SEC1) 0
     [m3vpss ]  2260534: SYSTEM  : FREE SPACE : System Heap      = 4688 B, Mbx = 10239 msgs)
     [m3vpss ]  2260534: SYSTEM  : FREE SPACE : SR0 Heap         = 10512128 B (10 MB)
     [m3vpss ]  2260534: SYSTEM  : FREE SPACE : Frame Buffer     = 896 B (0 MB)
     [m3vpss ]  2260534: SYSTEM  : FREE SPACE : Bitstream Buffer = 198288256 B (189 MB)
     [m3vpss ]  2260534: SYSTEM  : FREE SPACE : Tiler 8-bit      = 17883136 B (17 MB)  - TILER ON
     [m3vpss ]  2260534: SYSTEM  : FREE SPACE : Tiler 16-bit     = 75612160 B (72 MB)  - TILER ON
     [m3vpss ]  2262539: DISPLAY: SDDAC(SEC1): 24 fps, Latency (Min / Max) = ( 32 / 53 ), Callback Interval (Min / Max) = ( 39 / 41 ) !!!
     [m3vpss ]
     [m3vpss ]  *** IpcFramesOutRTOS Statistics ***
     [m3vpss ]
     [m3vpss ]  Total Fields Processed : 122039
     [m3vpss ]  Total Fields FPS       : 802 FPS
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]  CH  | In Recv In Process In Skip
     [m3vpss ]    0 |      50         50       0
     [m3vpss ]    1 |      50         50       0
     [m3vpss ]    2 |      50         50       0
     [m3vpss ]    3 |      50         50       0
     [m3vpss ]    4 |      50         50       0
     [m3vpss ]    5 |      50         50       0
     [m3vpss ]    6 |      50         50       0
     [m3vpss ]    7 |      50         50       0
     [m3vpss ]    8 |      50         50       0
     [m3vpss ]    9 |      50         50       0
     [m3vpss ]   10 |      50         50       0
     [m3vpss ]   11 |      50         50       0
     [m3vpss ]   12 |      50         50       0
     [m3vpss ]   13 |      50         50       0
     [m3vpss ]   14 |      50         50       0
     [m3vpss ]   15 |      50         50       0
     [m3vpss ]
     [c6xdsp ]
     [c6xdsp ]  *** SCD Statistics ***
     [c6xdsp ]
     [c6xdsp ]  Elasped Time           : 190 secs
     [c6xdsp ]  Total Fields Processed : 0
     [c6xdsp ]  Total Fields FPS       : 0 FPS
     [c6xdsp ]
     [c6xdsp ]
     [c6xdsp ]  CH  | In Recv In Process User Skip Process Skip In Process Time
     [c6xdsp ]  Num | FPS     FPS        FPS       FPS          per frame (msec)
     [c6xdsp ]  ----------------------------------------------------------------
     [c6xdsp ]
     [m3video] 	2265546: HDVICP-ID:0
     [m3video] All percentage figures are based off totalElapsedTime
     [m3video] 		 totalAcquire2wait :4 %
     [m3video] 		 totalWait2Isr :46 %
     [m3video] 		 totalIsr2Done :0 %
     [m3video] 		 totalWait2Done :47 %
     [m3video] 		 totalDone2Release :0 %
     [m3video] 		 totalAcquire2Release :55 %
     [m3video] 		 totalAcq2acqDelay :44 %
     [m3video] 		 totalElapsedTime in msec : 2245860
     [m3video] 		 numAccessCnt: 3361812
     [m3video] 		IVA-FPS :    1497
     [m3video] 		Average time spent per frame in microsec:     307
     [m3video] 	2265547: HDVICP-ID:1
     [m3video] 		 totalWait2Isr :43 %
     [m3video] 		 totalWait2Done :44 %
     [m3video] 		 totalAcquire2Release :52 %
     [m3video] 		 totalAcq2acqDelay :47 %
     [m3video] 		 totalElapsedTime in msec : 2245859
     [m3video] 		 numAccessCnt: 3371748
     [m3video] 		IVA-FPS :    1501
     [m3video] 		Average time spent per frame in microsec:     286
     [m3video] 	2265548: HDVICP-ID:2
     [m3video] 		 totalWait2Isr :40 %
     [m3video] 		 totalWait2Done :40 %
     [m3video] 		 totalAcquire2Release :49 %
     [m3video] 		 totalAcq2acqDelay :50 %
     [m3video] 		 numAccessCnt: 3314316
     [m3video] 		IVA-FPS :    1476
     [m3video] 		Average time spent per frame in microsec:     270
     [m3video]
     [m3video]  *** ENCODE Statistics ***
     [m3video]
     [m3video]  Elasped Time           : 152 secs
     [m3video]
     [m3video]
     [m3video]  CH  | In Recv In Skip In User  Out Latency
     [m3video]  Num | FPS     FPS     Skip FPS FPS Min / Max
     [m3video]  --------------------------------------------
     [m3video]    0 |      25       0        0  25  11 /  43
     [m3video]    1 |      25       0        0  25  13 /  43
     [m3video]    2 |      25       0        0  25  26 /  43
     [m3video]    3 |      25       0        0  25  26 /  51
     [m3video]    4 |      25       0        0  25  28 /  51
     [m3video]    5 |      25       0        0  25  27 /  47
     [m3video]    6 |      25       0        0  25  27 /  51
     [m3video]    7 |      25       0        0  25  28 /  51
     [m3video]    8 |      25       0        0  25  26 /  44
     [m3video]    9 |      25       0        0  25  27 /  51
     [m3video]   10 |      25       0        0  25  26 /  44
     [m3video]   11 |      25       0        0  25  30 /  52
     [m3video]   12 |      25       0        0  25  31 /  52
     [m3video]   13 |      25       0        0  25  28 /  51
     [m3video]   14 |      25       0        0  25  30 /  51
     [m3video]   15 |      25       0        0  25  31 /  51
     [m3video]   16 |      25       0        0  25  16 /  52
     [m3video]   17 |      25       0        0  25  23 /  52
     [m3video]   18 |      25       0        0  25  23 /  52
     [m3video]   19 |      25       0        0  25  23 /  52
     [m3video]   20 |      25       0        0  25  23 /  52
     [m3video]   21 |      25       0        0  25  23 /  52
     [m3video]   22 |      25       0        0  25  24 /  51
     [m3video]   23 |      25       0        0  25  25 /  51
     [m3video]   24 |      25       0        0  25  12 /  51
     [m3video]   25 |      25       0        0  25  23 /  51
     [m3video]   26 |      25       0        0  25  23 /  47
     [m3video]   27 |      25       0        0  25  25 /  51
     [m3video]   28 |      25       0        0  25  25 /  51
     [m3video]   29 |      25       0        0  25  25 /  47
     [m3video]   30 |      25       0        0  25  25 /  51
     [m3video]   31 |      25       0        0  25  25 /  51
     [m3video]
     [m3video] Multi Channel Encode Average Submit Batch Size
     [m3video] Max Submit Batch Size : 24
     [m3video] IVAHD_0 Average Batch Size : 2
     [m3video] IVAHD_0 Max achieved Batch Size : 6
     [m3video] IVAHD_1 Average Batch Size : 2
     [m3video] IVAHD_1 Max achieved Batch Size : 6
     [m3video] IVAHD_2 Average Batch Size : 1
     [m3video] IVAHD_2 Max achieved Batch Size : 5
     [m3video]
     [m3video] Multi Channel Encode Batch break Stats
     [m3video] Total Number of Batches created: 19421
     [m3video] All numbers are based off total number of Batches created
     [m3video] 	 Batch breaks due to batch sizeexceeding limit: 0 %
     [m3video] 	 Batch breaks due to ReqObj Que being empty: 100 %
     [m3video] 	 Batch breaks due to changed resolution class: 0 %
     [m3video] 	 Batch breaks due to interlace and progressivecontent mix: 0 %
     [m3video] 	 Batch breaks due to channel repeat: 0 %
     [m3video] 	 Batch breaks due to different codec: 0 %
     [m3video] Total Number of Batches created: 19542
     [m3video] Total Number of Batches created: 19319
     [m3video]
     [m3video]  *** DECODE Statistics ***
     [m3video]
     [m3video]
     [m3video]
     [m3video]  CH  | In Recv In User  Out
     [m3video]  Num | FPS     Skip FPS FPS
     [m3video]    0 |       0        0   0
     [m3video]    1 |       0        0   0
     [m3video]    2 |       0        0   0
     [m3video]    3 |       0        0   0
     [m3video]    4 |       0        0   0
     [m3video]    5 |       0        0   0
     [m3video]    6 |       0        0   0
     [m3video]    7 |       0        0   0
     [m3video]    8 |       0        0   0
     [m3video]    9 |       0        0   0
     [m3video]   10 |       0        0   0
     [m3video]   11 |       0        0   0
     [m3video]   12 |       0        0   0
     [m3video]   13 |       0        0   0
     [m3video]   14 |       0        0   0
     [m3video]   15 |       0        0   0
     [m3video]
     [m3video] Multi Channel Decode Average Submit Batch Size
     [m3video] IVAHD_0 Average Batch Size : 0
     [m3video] IVAHD_0 Max achieved Batch Size : 0
     [m3video] IVAHD_1 Average Batch Size : 0
     [m3video] IVAHD_1 Max achieved Batch Size : 0
     [m3video] IVAHD_2 Average Batch Size : 0
     [m3video] IVAHD_2 Max achieved Batch Size : 0
     [m3video]
     [m3video] Multi Channel Decode Batch break Stats
     [m3video] Total Number of Batches created: 0
     [m3video] 	 Batch breaks due to ReqObj Que being empty: 0 %
     [m3video]
     [m3vpss ]
     [m3vpss ]  2268561: LOAD: CPU: 37.9% HWI: 4.3%, SWI:3.0%
     [m3vpss ]
     [m3vpss ]  2268561: LOAD: TSK: IPC_OUT_M30         : 2.5%
     [m3vpss ]  2268562: LOAD: TSK: IPC_IN_M30          : 0.2%
     [m3vpss ]  2268562: LOAD: TSK: IPC_FRAMES_OUT0     : 2.8%
     [m3vpss ]  2268562: LOAD: TSK: CAPTURE             : 1.4%
     [m3vpss ]  2268562: LOAD: TSK: DEI0                : 4.0%
     [m3vpss ]  2268562: LOAD: TSK: DEI2                : 4.0%
     [m3vpss ]  2268562: LOAD: TSK: DISPLAY0            : 0.6%
     [m3vpss ]  2268562: LOAD: TSK: DISPLAY2            : 0.2%
     [m3vpss ]  2268562: LOAD: TSK: DUP0                : 0.3%
     [m3vpss ]  2268563: LOAD: TSK: DUP1                : 0.7%
     [m3vpss ]  2268563: LOAD: TSK: DUP2                : 0.6%
     [m3vpss ]  2268563: LOAD: TSK: DUP3                : 0.6%
     [m3vpss ]  2268563: LOAD: TSK: SWMS0               : 2.9%
     [m3vpss ]  2268563: LOAD: TSK: SWMS1               : 2.6%
     [m3vpss ]  2268563: LOAD: TSK: MERGE0              : 0.2%
     [m3vpss ]  2268563: LOAD: TSK: MERGE1              : 0.3%
     [m3vpss ]  2268564: LOAD: TSK: MERGE2              : 0.2%
     [m3vpss ]  2268564: LOAD: TSK: MERGE3              : 0.4%
     [m3vpss ]  2268564: LOAD: TSK: MISC                : 6.1%
     [m3vpss ]
     [m3video]
     [m3video]  2269065: LOAD: CPU: 35.0% HWI: 1.7%, SWI:2.7%
     [m3video]
     [m3video]  2269065: LOAD: TSK: IPC_IN_M30          : 0.7%
     [m3video]  2269065: LOAD: TSK: IPC_BITS_IN0        : 0.2%
     [m3video]  2269065: LOAD: TSK: IPC_BITS_OUT0       : 3.5%
     [m3video]  2269065: LOAD: TSK: ENC0                : 5.6%
     [m3video]  2269065: LOAD: TSK: DEC0                : 0.8%
     [m3video]  2269065: LOAD: TSK: ENC_PROCESS_TSK_0   : 6.7%
     [m3video]  2269066: LOAD: TSK: ENC_PROCESS_TSK_1   : 6.5%
     [m3video]  2269066: LOAD: TSK: ENC_PROCESS_TSK_2   : 6.2%
     [m3video]  2269066: LOAD: TSK: MISC                : 0.4%
     [m3video]
     [c6xdsp ]
     [c6xdsp ]  2833536: LOAD: CPU: 5.3% HWI: 0.1%, SWI:0.0%
     [c6xdsp ]
     [c6xdsp ]  2833536: LOAD: TSK: IPC_FRAMES_IN0      : 0.6%
     [c6xdsp ]  2833536: LOAD: TSK: ALG0                : 4.4%
     [c6xdsp ]  2833536: LOAD: TSK: MISC                : 0.2%
     [c6xdsp ]
  • I see the input width as 352 to SwMs which means DEI is still configured for 704 input. Are you seeing this patch is all layouts including 1x1 ? Anyhow pls share your create logs. It looks like capture is still configured for 704 output.
  • The patch occurs in all mosaic layouts.
    0880.teraterm.log
  • Ok the primary stream resolution is 720. For some reason the secondary stream resolution is 352 instead of 360 which I have to check but since you have seen the issue in all layout including 1x1 it is not the issue.I am unabel to view the video you shared either in quicktime or vlc . It is an mp4 file or did you rename the file to be able to attach it ? Is the strip black or grey ? If it black it could be coming from the video decoder in which case nothing can be done to resolve the issue. Pls see http://en.wikipedia.org/wiki/Nominal_analogue_blanking
  • The stripe is black.
    The video file is mp4, You should be able to open with VLC.
  • Ok, I understand, the reason for the behavior is the difference between 720 and 702.
    Thank You Badri for Your efforts
