Another USB issue
Other Parts Discussed in Thread: OMAP3530
See below issues with usb head timed out.. causing my GSM/GPS module to stop working.
Once this happens it can only be reset by a hard reset. A reboot will not bring it back.
I am using a board heavily based on the BeagleBoard - omap3530
I am using 3.2 kernel from Robert Nelson repo.
Any ideas? Again - really stuck on this one and would love any help regarding where I might look to solve it.
Many thanks!
[ 240.087799] usb 1-1.1: head timed out on ep0out len=0/0
[ 240.087860] tty_port_close_start: tty->count = 1 port count = 0.
[ 245.087799] usb 1-1.1: head timed out on ep0out len=0/0
[ 251.808715] hub 1-1:1.0: state 7 ports 4 chg 0000 evt 0002
[ 251.809356] hub 1-1:1.0: port 1, status 0101, change 0001, 12 Mb/s
[ 251.809692] usb 1-1.1: USB disconnect, device number 3
[ 251.815155] usb 1-1.1: unregistering device
[ 251.815155] usb 1-1.1: unregistering interface 1-1.1:1.0
[ 251.820343] usb 1-1.1: unregistering interface 1-1.1:1.1
[ 251.820587] usb 1-1.1: unregistering interface 1-1.1:1.2
[ 251.826538] usb 1-1.1: unregistering interface 1-1.1:1.3
[ 251.826782] usb 1-1.1: unregistering interface 1-1.1:1.4
[ 251.830505] usb 1-1.1: unregistering interface 1-1.1:1.5
[ 251.830749] usb 1-1.1: unregistering interface 1-1.1:1.6
[ 251.838012] usb 1-1.1: unregistering interface 1-1.1:1.7
[ 251.838256] usb 1-1.1: unregistering interface 1-1.1:1.8
[ 251.841308] usb 1-1.1: unregistering interface 1-1.1:1.9
[ 251.841552] usb 1-1.1: unregistering interface 1-1.1:1.10
[ 251.843902] usb 1-1.1: unregistering interface 1-1.1:1.11
[ 251.844146] usb 1-1.1: unregistering interface 1-1.1:1.12
[ 251.853637] usb 1-1.1: unregistering interface 1-1.1:1.13
[ 251.853881] usb 1-1.1: usb_disable_device nuking all URBs
[ 252.010009] hub 1-1:1.0: debounce: port 1: total 100ms stable 100ms status 0x101
[ 252.095886] usb 1-1.1: new high-speed USB device number 6 using musb-hdrc
[ 257.095642] usb 1-1.1: khubd timed out on ep0in len=0/64
[ 262.095611] usb 1-1.1: khubd timed out on ep0in len=0/64
[ 267.095611] usb 1-1.1: khubd timed out on ep0in len=0/64
[ 267.181823] usb 1-1.1: device descriptor read/64, error -110
[ 272.290954] usb 1-1.1: khubd timed out on ep0in len=0/64
[ 277.290924] usb 1-1.1: khubd timed out on ep0in len=0/64
[ 282.290924] usb 1-1.1: khubd timed out on ep0in len=0/64
[ 282.377136] usb 1-1.1: device descriptor read/64, error -110
[ 282.572540] usb 1-1.1: new high-speed USB device number 7 using musb-hdrc
[ 287.572204] usb 1-1.1: khubd timed out on ep0in len=0/64
[ 292.572174] usb 1-1.1: khubd timed out on ep0in len=0/64
[ 297.572174] usb 1-1.1: khubd timed out on ep0in len=0/64
[ 297.658447] usb 1-1.1: device descriptor read/64, error -110
[ 301.815246] hub 1-1:1.0: unable to enumerate USB device on port 1
[ 301.826293] hub 1-1:1.0: state 7 ports 4 chg 0000 evt 0002
[ 301.826965] hub 1-1:1.0: port 1, status 0101, change 0001, 12 Mb/s
[ 301.978729] hub 1-1:1.0: debounce: port 1: total 100ms stable 100ms status 0x101
[ 302.064636] usb 1-1.1: new high-speed USB device number 8 using musb-hdrc
[ 307.064361] usb 1-1.1: khubd timed out on ep0in len=0/64
[ 312.064361] usb 1-1.1: khubd timed out on ep0in len=0/64
[ 317.064361] usb 1-1.1: khubd timed out on ep0in len=0/64
[ 317.150604] usb 1-1.1: device descriptor read/64, error -110
[ 322.259704] usb 1-1.1: khubd timed out on ep0in len=0/64
[ 327.259704] usb 1-1.1: khubd timed out on ep0in len=0/64
[ 332.259674] usb 1-1.1: khubd timed out on ep0in len=0/64
[ 332.345886] usb 1-1.1: device descriptor read/64, error -110
[ 332.541259] usb 1-1.1: new high-speed USB device number 9 using musb-hdrc
[ 337.540924] usb 1-1.1: khubd timed out on ep0in len=0/64
[ 342.540985] usb 1-1.1: khubd timed out on ep0in len=0/64
[ 347.540924] usb 1-1.1: khubd timed out on ep0in len=0/64
[ 347.627166] usb 1-1.1: device descriptor read/64, error -110
[ 352.736236] usb 1-1.1: khubd timed out on ep0in len=0/64
[ 357.736236] usb 1-1.1: khubd timed out on ep0in len=0/64
[ 362.736267] usb 1-1.1: khubd timed out on ep0in len=0/64
[ 362.822448] usb 1-1.1: device descriptor read/64, error -110
[ 363.017852] usb 1-1.1: new high-speed USB device number 10 using musb-hdrc
[ 368.017486] usb 1-1.1: khubd timed out on ep0out len=0/0
[ 373.228454] usb 1-1.1: khubd timed out on ep0out len=0/0
[ 373.439331] usb 1-1.1: device not accepting address 10, error -110
[ 373.541442] usb 1-1.1: new high-speed USB device number 11 using musb-hdrc
[ 378.548736] usb 1-1.1: khubd timed out on ep0out len=0/0
[ 383.759704] usb 1-1.1: khubd timed out on ep0out len=0/0
[ 383.970611] usb 1-1.1: device not accepting address 11, error -110
[ 383.986206] hub 1-1:1.0: unable to enumerate USB device on port 1
[ 384.001831] hub 1-1:1.0: state 7 ports 4 chg 0000 evt 0002
  • Hi CJ,
    The problem maybe due to damaged USB device or controller but it maybe a software issue. Could you try to unplug and plug the USB GSM/GPS module and execute the commands:
    dmesg -s
    lsusb
    Then post the output.
    BR
    Tsvetolin Shulev
  • Hi Tsvetolin,
    Thanks for the response. The GPS module is miniPCIe so I can't unplug the USB part. I can unplug the module, and if I do this there is no error.
    This is not an isolated problem with one board, it is on all the boards.
    It looks to me like it might be an issue with the ACM driver in linux 3.2. I have also tested 3.5 and the same problem exists.
    I am currently trying a SIERRA wireless unit which uses a proprietary driver - so far it has been fine. Which makes me think it is likely an ACM issue in the linux kernel.
    Will update if the issue continues.. if it does I guess it means that there is a hardware design fault or a controller issue.
    Many thanks!
    CJ
  • Hi CJ.
    do you have any update about this problem? I am having the same problem on the OTG port of pandaboard using kernel 3.4.0 when I plug in a sequans wimax modem. The error message kept appearing even when I have disconnected the modem from the OTG port.
    Jan  1 00:33:08 U-11-04-8G kernel: [ 1990.487335] usb 3-1: device descriptor read/64, error -110
    Jan  1 00:33:08 U-11-04-8G kernel: [ 1990.721710] usb 3-1: new high-speed USB device number 6 using musb-hdrc
    Jan  1 00:33:13 U-11-04-8G kernel: [ 1995.721740] usb 3-1: khubd timed out on ep0in len=0/64
    Jan  1 00:33:18 U-11-04-8G kernel: [ 2000.721740] usb 3-1: khubd timed out on ep0in len=0/64
    Jan  1 00:33:23 U-11-04-8G kernel: [ 2005.721771] usb 3-1: khubd timed out on ep0in len=0/64
    Jan  1 00:33:23 U-11-04-8G kernel: [ 2005.846710] usb 3-1: device descriptor read/64, error -110
    Jan  1 00:33:28 U-11-04-8G kernel: [ 2010.956146] usb 3-1: khubd timed out on ep0in len=0/64
    Jan  1 00:33:33 U-11-04-8G kernel: [ 2015.956115] usb 3-1: khubd timed out on ep0in len=0/64
    Jan  1 00:33:38 U-11-04-8G kernel: [ 2020.956115] usb 3-1: khubd timed out on ep0in len=0/64
    Jan  1 00:33:38 U-11-04-8G kernel: [ 2021.081085] usb 3-1: device descriptor read/64, error -110
    Jan  1 00:33:39 U-11-04-8G kernel: [ 2021.315490] usb 3-1: new high-speed USB device number 7 using musb-hdrc
    Jan  1 00:33:44 U-11-04-8G kernel: [ 2026.315521] usb 3-1: khubd timed out on ep0out len=0/0
    Jan  1 00:33:49 U-11-04-8G kernel: [ 2031.526428] usb 3-1: khubd timed out on ep0out len=0/0
    Jan  1 00:33:49 U-11-04-8G kernel: [ 2031.737335] usb 3-1: device not accepting address 7, error -110
    Jan  1 00:33:49 U-11-04-8G kernel: [ 2031.862426] usb 3-1: new high-speed USB device number 8 using musb-hdrc
    Jan  1 00:33:54 U-11-04-8G kernel: [ 2036.862335] usb 3-1: khubd timed out on ep0out len=0/0
    Jan  1 00:33:59 U-11-04-8G kernel: [ 2042.073303] usb 3-1: khubd timed out on ep0out len=0/0
    Jan  1 00:34:00 U-11-04-8G kernel: [ 2042.284240] usb 3-1: device not accepting address 8, error -110
    Jan  1 00:34:00 U-11-04-8G kernel: [ 2042.291076] hub 3-0:1.0: unable to enumerate USB device on port 1
    Jan  1 00:34:00 U-11-04-8G kernel: [ 2042.299652] hub 3-0:1.0: state 7 ports 1 chg 0000 evt 0002
    Jan  1 00:34:00 U-11-04-8G kernel: [ 2042.301177] hub 3-0:1.0: port 1 enable change, status 00000501
    Jan  1 00:34:02 U-11-04-8G kernel: [ 2045.026428] hub 3-0:1.0: hub_suspend
    Jan  1 00:34:02 U-11-04-8G kernel: [ 2045.026489] usb usb3: bus auto-suspend, wakeup 1
    Jan  1 00:34:02 U-11-04-8G kernel: [ 2045.026550] musb_bus_suspend 2294: trying to suspend as a_host while active
    Jan  1 00:34:02 U-11-04-8G kernel: [ 2045.026580] usb usb3: bus suspend fail, err -16
    Jan  1 00:34:02 U-11-04-8G kernel: [ 2045.026611] hub 3-0:1.0: hub_resume
    Jan  1 00:34:02 U-11-04-8G kernel: [ 2045.026672] hub 3-0:1.0: port 1: status 0501 change 0000
    Jan  1 00:34:02 U-11-04-8G kernel: [ 2045.026794] hub 3-0:1.0: state 7 ports 1 chg 0002 evt 0000
    Jan  1 00:34:02 U-11-04-8G kernel: [ 2045.026855] hub 3-0:1.0: port 1, status 0501, change 0000, 480 Mb/s
    Jan  1 00:34:03 U-11-04-8G kernel: [ 2045.151641] usb 3-1: new high-speed USB device number 9 using musb-hdrc
