MsgQ issue
I repeat to close and open the dvr_rdk_demo_mcfw_api.out  and I get this error message. How do I avoid this issue happen ?
/dev/syslinkipc_MultiProc: Too many open files
1: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
ASSERT (system_ipc_msgq.c|System_ipcMsgQHeapCreate|52)
  • After how many iterations of open close do you get this error ? Is it a fixed number ? Can you share full console logs.Also can you share the log of "top" cmd and cat  /proc/[pid]/fd  after every close and open.
  • I am not sure how many times will cause this issue, but it will happen on my system. I see the dvr_rdk_mcfw_api opens many file descriptors.
    0 148 219 290 361 432 503 575 646 717 789 86 930
    1 149 22 291 362 433 504 576 647 718 79 860 931
    10 15 220 292 363 434 505 577 648 719 790 861 932
    100 150 221 293 364 435 506 578 649 72 791 862 933
    1000 151 222 294 365 436 507 579 65 720 792 863 934
    1001 152 223 295 366 437 508 58 650 721 793 864 935
    1002 153 224 296 367 438 509 580 651 722 794 865 936
    1003 154 225 297 368 439 51 581 652 723 795 866 937
    1004 155 226 298 369 44 510 582 653 724 796 867 938
    1005 156 227 299 37 440 511 583 654 725 797 868 939
    1006 157 228 3 370 441 512 584 655 726 798 869 94
    1007 158 229 30 371 442 513 585 656 727 799 87 940
    1008 159 23 300 372 443 514 586 657 728 8 870 941
    1009 16 230 301 373 444 515 587 658 729 80 871 942
    101 160 231 302 374 445 516 588 659 73 800 872 943
    1010 161 232 303 375 446 517 589 66 730 801 873 944
    1011 162 233 304 376 447 518 59 660 731 802 874 945
    1012 163 234 305 377 448 519 590 661 732 803 875 946
    1013 164 235 306 378 449 52 591 662 733 804 876 947
    1014 165 236 307 379 45 520 592 663 734 805 877 948
    1015 166 237 308 38 450 521 593 664 735 806 878 949
    1016 167 238 309 380 451 522 594 665 736 807 879 95
    1017 168 239 31 381 452 523 595 666 737 808 88 950
    1018 169 24 310 382 453 524 596 667 738 809 880 951
    1019 17 240 311 383 454 525 597 668 739 81 881 952
    102 170 241 312 384 455 526 598 669 74 810 882 953
    1020 171 242 313 385 456 527 599 67 740 811 883 954
    1021 172 243 314 386 457 528 6 670 741 812 884 955
    1022 173 244 315 387 458 529 60 671 742 813 885 956
    1023 174 245 316 388 459 53 600 672 743 814 886 957
    103 175 246 317 389 46 530 601 673 744 815 887 958
    104 176 247 318 39 460 531 602 674 745 816 888 959
    105 177 248 319 390 461 532 603 675 746 817 889 96
    106 178 249 32 391 462 533 604 676 747 818 89 960
    107 179 25 320 392 463 534 605 677 748 819 890 961
    108 18 250 321 393 464 535 606 678 749 82 891 962
    109 180 251 322 394 465 536 607 679 75 820 892 963
    11 181 252 323 395 466 537 608 68 750 821 893 964
    110 182 253 324 396 467 538 609 680 751 822 894 965
    111 183 254 325 397 468 539 61 681 752 823 895 966
    112 184 255 326 398 469 54 610 682 753 824 896 967
    113 185 256 327 399 47 540 611 683 754 825 897 968
    114 186 257 328 4 470 541 612 684 755 826 898 969
    115 187 258 329 40 471 542 613 685 756 827 899 97
    116 188 259 33 400 472 543 614 686 757 828 9 970
    117 189 26 330 401 473 544 615 687 758 829 90 971
    118 19 260 331 402 474 545 616 688 759 83 900 972
    119 190 261 332 403 475 546 617 689 76 830 901 973
    12 191 262 333 404 476 547 618 69 760 831 902 974
    120 192 263 334 405 477 548 619 690 761 832 903 975
    121 193 264 335 406 478 549 62 691 762 833 904 976
    122 194 265 336 407 479 55 620 692 763 834 905 977
    123 195 266 337 408 48 550 621 693 764 835 906 978
    124 196 267 338 409 480 551 622 694 765 836 907 979
    125 197 268 339 41 481 552 623 695 766 837 908 98
    126 198 269 34 410 482 553 624 696 767 838 909 980
    127 199 27 340 411 483 554 625 697 768 839 91 981
    128 2 270 341 412 484 555 626 698 769 84 910 982
    129 20 271 342 413 485 556 627 699 77 840 911 983
    13 200 272 343 414 486 557 628 7 770 841 912 984
    130 201 273 344 415 487 558 629 70 771 842 913 985
    131 202 274 345 416 488 559 63 700 772 843 914 986
    132 203 275 346 417 489 56 630 701 773 844 915 987
    133 204 276 347 418 49 560 631 702 774 845 916 988
    134 205 277 348 419 490 561 632 703 775 846 917 989
    135 206 278 349 42 491 562 633 704 776 847 918 99
    136 207 279 35 420 492 563 634 705 777 848 919 990
    137 208 28 350 421 493 564 635 706 778 849 92 991
    138 209 280 351 422 494 565 636 707 779 85 920 992
    139 21 281 352 423 495 566 637 708 78 850 921 993
    14 210 282 353 424 496 567 638 709 780 851 922 994
    140 211 283 354 425 497 568 639 71 781 852 923 995
    141 212 284 355 426 498 569 64 710 782 853 924 996
    142 213 285 356 427 499 57 640 711 783 854 925 997
    143 214 286 357 428 5 570 641 712 784 855 926 998
    144 215 287 358 429 50 571 642 713 785 856 927 999
    145 216 288 359 43 500 572 643 714 786 857 928
    146 217 289 36 430 501 573 644 715 787 858 929
    147 218 29 360 431 502 574 645 716 788 859 93
  • This looks like 1024 fd limit is exceeded. Can you pls use  readlink ( http://linux.die.net/man/2/readlink) on /proc/self/fd/NNN where NNN is the fd number and let me know the file name of the fd that is not getting deleted.Also which RDK release are you using. There was a issue with i2c handle not being closed which was fixed in RDK 3.5.
  • We are using RDK3.0 and it is difficult for us to move to RDK3.5 since we need to change lots of our programs. Could you tell us where we can find the modified for I2C ?
  • Pls confirm the filename using readlink first .Will try to provide patch depending on which file handle is not closed
  • Name: init /proc/1/status
    Name: kthreadd /proc/2/status
    Name: ksoftirqd/0 /proc/3/status
    Name: ksoftirqd/0 /proc/4/status
    Name: kworker/u:0 /proc/5/status
    Name: khelper /proc/6/status
    Name: irq/72-serial /proc/7/status
    Name: irq/73-serial /proc/8/status
    Name: irq/74-serial /proc/9/status
    Name: mboxd /proc/10/status
    Name: sync_supers /proc/11/status
    Name: bdi-default /proc/12/status
    Name: kblockd /proc/13/status
    Name: khubd /proc/14/status
    Name: kseriod /proc/15/status
    Name: musb-hdrc.0 /proc/16/status
    Name: kworker/0:1 /proc/17/status
    Name: musb-hdrc.1 /proc/18/status
    Name: rpciod /proc/19/status
    Name: kswapd0 /proc/20/status
    Name: aio /proc/21/status
    Name: nfsiod /proc/22/status
    Name: kworker/u:1 /proc/23/status
    Name: mtdblock0 /proc/28/status
    Name: mtdblock1 /proc/29/status
    Name: mtdblock2 /proc/30/status
    Name: mtdblock3 /proc/31/status
    Name: mtdblock4 /proc/32/status
    Name: mtdblock5 /proc/33/status
    Name: mtdblock6 /proc/34/status
    Name: mtdblock7 /proc/35/status
    Name: usbhid_resumer /proc/36/status
    Name: kworker/0:2 /proc/37/status
    Name: telnetd /proc/55/status
    Name: syslogd /proc/63/status
    Name: syslogd /proc/64/status
    Name: sh /proc/66/status
    Name: sh /proc/75/status
    Name: sh /proc/89/status
    Name: sh /proc/107/status
    Name: sh /proc/109/status
    Name: remote_debug_cl /proc/135/status
    Name: HDMI /proc/204/status
    Name: HDMI /proc/216/status
    Name: exe /proc/217/status
    Name: exe /proc/218/status
    Name: exe /proc/220/status
    Name: exe /proc/227/status
    Name: exe /proc/227/statusInvalid cmd passed, 5401
    Name: exe /dev/ti816x_pcieInvalid cmd passed, 5401
    _ep
    Name: exe /dev/ti816x_edma*** OsalDrvDrv_ioctl: Unsupported ioctl command specified
            Error [0x8010d002] at Line no: 816 in file /home/Jack123/project/DVRRDK_03.00.00.00/ti_tools/syslink/syslink_2_10_02_17_patched/packages/ti/syslink/utils/hlos/knl/Linux/../../../../../../ti/syslink/utils/hlos/knl/osal/Linux/OsalDriver.c
    _ep
    Name: exe /dev/syslinkipc_*** IpcDrv_drvioctl: Unsupported ioctl command specified
            Error [0xfffffffe] at Line no: 364 in file /home/Jack123/project/DVRRDK_03.00.00.00/ti_tools/syslink/syslink_2_10_02_17_patched/packages/ti/syslink/utils/hlos/knl/Linux/../../../../../../ti/syslink/ipc/hlos/knl/Linux/IpcDrv.c
    Osal
    Name: exe /dev/syslinkipc_*** MultiProcDrv_ioctl: Unsupported ioctl command specified
            Error [0xffffffff] at Line no: 320 in file /home/Jack123/project/DVRRDK_03.00.00.00/ti_tools/syslink/syslink_2_10_02_17_patched/packages/ti/syslink/utils/hlos/knl/Linux/MultiProcDrv.c
    Ipc
    Name: exe /dev/syslinkipc_Invalid cmd passed, 5401
    MultiProc
    Name: exe /dev/ti816x_pcie*** NameServerDrv_ioctl: Unsupported ioctl command specified
            Error [0xfffffffe] at Line no: 593 in file /home/Jack123/project/DVRRDK_03.00.00.00/ti_tools/syslink/syslink_2_10_02_17_patched/packages/ti/syslink/utils/hlos/knl/Linux/NameServerDrv.c
    _ep
    NameServer
    Name: exe /dev/ti816x_edma*** ProcMgrDrv_ioctl: Unsupported ioctl command specified
            Error [0xfffffffe] at Line no: 2138 in file /home/Jack123/project/DVRRDK_03.00.00.00/ti_tools/syslink/syslink_2_10_02_17_patched/packages/ti/syslink/utils/hlos/knl/Linux/../../../../../../ti/syslink/procMgr/hlos/knl/Linux/ProcMgrDrv.c
    _ep
    Name: exe /dev/syslinkipc_ProcMgr
    Name: exe /proc/236/status
    Name: exe /proc/269/status
    Name: exe /proc/302/status
    Name: exe /proc/374/status
    Name: exe /proc/399/status
    Name: exe /proc/482/status
    Name: exe /proc/507/status
    Name: exe /proc/596/status
    Name: exe /proc/621/status
  •  I dont see any filenames related to RDK.Also the path is not to /proc/self/fd/. Was this log captured from the RDK app process ? Anyhow I dont see any open i2c handles so the patch will not help. If you are trying deleting and creating the usecase monitor the number of open file handles are not increasing each time you delete and create the usecase.
  • I find where the bugs are. Thanks for your help.
