Arago build failed due to unavilability of git://arago-project.org/git/projects/test-automation/ltp-ddt.git
Other Parts Discussed in Thread: OMAPL138
I am using ti arago build for OMAPL138. When I tried to compile in Ubuntu environment, if internet is not working or "git://arago-project.org/git/projects/test-automation/ltp-ddt.git" is not available, then I am not able to compile.
How to avoid connecting to the server ? I want to compile in a PC standalone without using Internet.
Please go through the traces of errors.
NOTE: <class 'bb.fetch.FetchError'>:Fetch command export HOME=/home/ewl; export SSH_AUTH_SOCK=/tmp/keyring-34O5Yx/ssh; export ftp_proxy=192.168.7.113:8088; export http_proxy=192.168.7.113:8088; export PATH=/home/ewl/svn/mpers/branches/pendant-rev0/arago/bin:/home/ewl/svn/mpers/branches/pendant-rev0/arago-oe-dev/bin:/home/ewl/svn/mpers/branches/pendant-rev0/arago-tmp/sysroots/x86_64-linux/usr/armv5te/bin:/home/ewl/svn/mpers/branches/pendant-rev0/arago-tmp/sysroots/x86_64-linux/usr/sbin:/home/ewl/svn/mpers/branches/pendant-rev0/arago-tmp/sysroots/x86_64-linux/usr/bin:/home/ewl/svn/mpers/branches/pendant-rev0/arago-tmp/sysroots/x86_64-linux/sbin:/home/ewl/svn/mpers/branches/pendant-rev0/arago-tmp/sysroots/x86_64-linux//bin:/home/ewl/svn/mpers/branches/pendant-rev0/arago-bitbake/bin/:/home/ewl/svn/mpers/branches/pendant-rev0/arago-utils/:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/home/ewl/CodeSourcery/Sourcery_G++_Lite/bin; git ls-remote git://arago-project.org/git/projects/test-automation/ltp-ddt.git master failed with signal 128, output:
fatal: The remote end hung up unexpectedly
 while evaluating:
${PN}-${EXTENDPE}${PV}-${PR}
 while evaluating:
${PF}:${P}:${PN}:${BP}:${BPN}:files:.
ERROR: Fetch command export HOME=/home/ewl; export SSH_AUTH_SOCK=/tmp/keyring-34O5Yx/ssh; export ftp_proxy=192.168.7.113:8088; export http_proxy=192.168.7.113:8088; export PATH=/home/ewl/svn/mpers/branches/pendant-rev0/arago/bin:/home/ewl/svn/mpers/branches/pendant-rev0/arago-oe-dev/bin:/home/ewl/svn/mpers/branches/pendant-rev0/arago-tmp/sysroots/x86_64-linux/usr/armv5te/bin:/home/ewl/svn/mpers/branches/pendant-rev0/arago-tmp/sysroots/x86_64-linux/usr/sbin:/home/ewl/svn/mpers/branches/pendant-rev0/arago-tmp/sysroots/x86_64-linux/usr/bin:/home/ewl/svn/mpers/branches/pendant-rev0/arago-tmp/sysroots/x86_64-linux/sbin:/home/ewl/svn/mpers/branches/pendant-rev0/arago-tmp/sysroots/x86_64-linux//bin:/home/ewl/svn/mpers/branches/pendant-rev0/arago-bitbake/bin/:/home/ewl/svn/mpers/branches/pendant-rev0/arago-utils/:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/home/ewl/CodeSourcery/Sourcery_G++_Lite/bin; git ls-remote git://arago-project.org/git/projects/test-automation/ltp-ddt.git master failed with signal 128, output:
 while parsing /home/ewl/svn/mpers/branches/pendant-rev0/arago/recipes/ti/ltp-ddt_git.bb
NOTE: Handling BitBake files: / (7721/7722) [99 %]Command execution failed: Traceback (most recent call last):
  File "/home/ewl/svn/mpers/branches/pendant-rev0/arago-bitbake/lib/bb/command.py", line 85, in runAsyncCommand
    self.cooker.updateCache()
  File "/home/ewl/svn/mpers/branches/pendant-rev0/arago-bitbake/lib/bb/cooker.py", line 829, in updateCache
    if not self.parser.parse_next():
  File "/home/ewl/svn/mpers/branches/pendant-rev0/arago-bitbake/lib/bb/cooker.py", line 1022, in parse_next
    raise ParsingErrorsFound
ParsingErrorsFound
NOTE: Handling BitBake files: - (1658/7722) [21 %]ERROR: Fetch command export HOME=/home/ewl; export SSH_AUTH_SOCK=/tmp/keyring-34O5Yx/ssh; export ftp_proxy=192.168.7.113:8088; export http_proxy=192.168.7.113:8088; export PATH=/home/ewl/svn/mpers/branches/pendant-rev0/arago/bin:/home/ewl/svn/mpers/branches/pendant-rev0/arago-oe-dev/bin:/home/ewl/svn/mpers/branches/pendant-rev0/arago-tmp/sysroots/x86_64-linux/usr/armv5te/bin:/home/ewl/svn/mpers/branches/pendant-rev0/arago-tmp/sysroots/x86_64-linux/usr/sbin:/home/ewl/svn/mpers/branches/pendant-rev0/arago-tmp/sysroots/x86_64-linux/usr/bin:/home/ewl/svn/mpers/branches/pendant-rev0/arago-tmp/sysroots/x86_64-linux/sbin:/home/ewl/svn/mpers/branches/pendant-rev0/arago-tmp/sysroots/x86_64-linux//bin:/home/ewl/svn/mpers/branches/pendant-rev0/arago-bitbake/bin/:/home/ewl/svn/mpers/branches/pendant-rev0/arago-utils/:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/home/ewl/CodeSourcery/Sourcery_G++_Lite/bin; git ls-remote git://arago-project.org/git/projects/test-automation/ltp-ddt.git master failed with signal 128, output:
 while evaluating:
${@bb.fetch.get_srcrev(d)}
 while evaluating:
r2+gitr${SRCPV}
 while evaluating:
 while evaluating:
ParsingErrorsFound
  • Is this the only step of the build process that fails? When using bitbake and the provided recipes, many of the packages are pulled from remote git repositories or their source is downloaded in an archive. Unless all of the packages are already downloaded and stored locally an internet connection will be required.
    Dave
  • Thank you for your quick response. Other packages dependency I have taken out. I am getting only the problem with this only [ltp-ddt.git]. I do not want to include this git for every compilation. Can you please suggest a method to avoid it?
    Murali Krishna S.V.
    Within the file task-arago-test.bb (Found at both arago-amsdk/recipes/tasks or arago/recipes/tasks depending on which copies of the arago repos you have checked out) you should be able to remove the reference to ltp-ddt and prevent this from being built. Note that you will need to bump the PR number found towards the start of the file in order to make sure the recipe gets reparsed and built.
    Dave
