Hello!
I am a beginner with Keystone Multicore DSP. We purchased eval board TMDXEVM6657LE with CCS 5.1.1.00031. We have some troubles with eval board.
I run the "Example 1 - Building and running a simple single core application" from "BIOS-MCSDK User Guide" with CCS debug session. But LEDs on the eval board play only a few minutes. After that the message appears:
C66xx_0: Power Failure on Target CPU
C66xx_0: Failed to remove the debug state from the target before disconnecting. There may still be breakpoint op-codes embedded in program memory. It is recommended that you reset the emulator before you connect and reload your program before you continue debugging
Simultaneously, the orange led "SYSPG_D1" on eval board switches off.
What is this?
