Hi all:
we get APPRO DM8127 IPNC camera kit with RDK version 3.5.0.
There are two ipnc config below:
IPNC_CONFIG: = full_feature
low_power
It can boot success with low_power mode and see the video on IE website, but fail with full_feature mode.
This is the DM8127 bootlog:
U-Boot 2010.06-00023-g6d4b40c (Dec 21 2012 - 19:58:49) DM8127_IPNC_3.50.00
TI8148-GP rev 2.1
ARM clk: 600MHz
DDR clk: 400MHz
L3 clk: 200MHz
IVA clk: 450MHz
ISS clk: 400MHz
DSP Default OFF
DSS Default OFF
DRAM: 512 MiB
NAND: HW ECC BCH8 Selected
256 MiB
Using default environment
The 2nd stage U-Boot will now be auto-loaded
Please do not interrupt the countdown till TI8148_EVM prompt if 2nd stage is already flashed
Hit any key to stop autoboot: 0
NAND read: device 0 offset 0x20000, size 0x40000
262144 bytes read: OK
## Starting application at 0x81000000 ...
U-Boot 2010.06 (Feb 25 2013 - 18:25:17) DM8127_IPNC_3.50.00
TI8148-GP rev 2.1
ARM clk: 600MHz
DDR clk: 400MHz
L3 clk: 200MHz
IVA clk: 450MHz
ISS clk: 400MHz
DSP Default OFF
DSS Default OFF
I2C: ready
DRAM: 512 MiB
256 MiB
MMC: OMAP SD/MMC: 0, ON-BOARD SDIO: 1
.:;rrr;;.
,5#@@@@#####@@@@@@#2,
,A@@@hi;;;r5;;;;r;rrSG@@@A,
r@@#i;:;s222hG;rrsrrrrrr;ri#@@r
:@@hr:r;SG3ssrr2r;rrsrsrsrsrr;rh@@:
B@H;;rr;3Hs;rrr;sr;;rrsrsrsrsrsr;;H@B
@@s:rrs;5#;;rrrr;r#@H:;;rrsrsrsrsrr:s@@
@@;;srs&X#9;r;r;;,2@@@rrr:;;rrsrsrsrr;;@@
@@;;rrsrrs@MB#@@@@@###@@@@@@#rsrsrsrsrr;;@@
G@r;rrsrsr;#X;SX25Ss#@@#M@#9H9rrsrsrsrsrs;r@G
@9:srsrsrs;2@;:;;:.X@@@@@H::;rrsrsrsrsrsrr:3@
X@;rrsrsrsrr;XAi;;:&@@#@Bs:rrsrsrsrsrsrsrsrr;@X
@#;rsrsrsrsrr;r2ir@@@###::rrsrsrsrsrsrsrsrsr:@@
@A:rrsrsrsrr;:2@29@@M@@@;:;rrrrsrsrsrsrsrsrs;H@
@&;rsrsrsrr;A@@@@@@###@@@s::;:;;rrsrsrsrsrsr;G@
@#:rrsrsrsr;G@5Hr25@@@#@@@#9XG9s:rrrrsrsrsrs:#@
M@;rsrsrsrs;r@&#;::S@@@@@@@M@@@@Grr:;rsrsrsr;@#
:@s;rsrsrsrr:M#Msrr;;&#@@@@@@@@@@H@@5;rsrsr;s@,
@@:rrsrsrsr;S@rrrsr;:;r3MH@@#@M5,S@@irrsrr:@@
@A:rrsrsrsrrrrrsrsrrr;::;@##@r:;rH@h;srr:H@
;@9:rrsrsrsrrrsrsrsrsr;,S@Hi@i:;s;MX;rr:h@;
r@B:rrrrsrsrsrsrsrr;;sA@#i,i@h;r;S5;r:H@r
,@@r;rrrsrsrsrsrr;2BM3r:;r:G@:rrr;;r@@,
B@Mr;rrrrsrsrsr@@S;;;rrr:5M;rr;rM@H
.@@@i;;rrrrsrs2i;rrrrr;r@M:;i@@@.
.A@@#5r;;;r;;;rrr;r:r#AsM@@H.
;&@@@@MhXS5i5SX9B@@@@G;
:ihM#@@@@@##hs,
Date: 2013-01-21 (Monday) Time: 7:23:48
Net: Detected MACID:40:5f:c2:6:9b:d4
cpsw
Hit any key to stop autoboot: 3 2 1 0
Loading from nand0, offset 0x280000
Image Name: Linux-2.6.37_DM8127_IPNC_3.50.00
Created: 2013-02-26 2:47:04 UTC
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 2492848 Bytes = 2.4 MiB
Load Address: 80008000
Entry Point: 80008000
## Booting kernel from Legacy Image at 81000000 ...
Verifying Checksum ... OK
Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
Linux version 2.6.37_DM8127_IPNC_3.50.00 (root@ubuntu) (gcc version 4.5.3 20110311 (prerelease) (GCC) ) #1 Mon Feb 25 18:46:31 PST 2013
CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c53c7f
CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine: ti8148ipnc
vram size = 4194304 at 0x0
bootconsole [earlycon0] enabled
ti81xx_reserve: ### Reserved DDR region @84f00000
reserved size = 4194304 at 0x0
FB: Reserving 4194304 bytes SDRAM for VRAM
Memory policy: ECC disabled, Data cache writeback
OMAP chip is TI8148 2.1
SRAM: Mapped pa 0x402f1000 to va 0xfe400000 size: 0xf000
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 19040
Kernel command line: console=ttyO0,115200n8 rootwait=1 rw ubi.mtd=4,2048 rootfstype=ubifs root=ubi0:rootfs init=/init mem=80M vram=4M notifyk.vpssm3_sva=0xBFD00000 ip=dhcp eth=$(ethaddr) cmemk.phys_start=0x85000000 cmemk.phys_end=0x89000000 cmemk.allowOverlap=1 earlyprintk
cpsw: kernel boot params Ethernet address: $(ethaddr)
PID hash table entries: 512 (order: -1, 2048 bytes)
Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Memory: 74MB 1MB = 75MB total
Memory: 70652k/70652k available, 11268k reserved, 0K highmem
Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
DMA : 0xffc00000 - 0xffe00000 ( 2 MB)
vmalloc : 0xc5800000 - 0xf8000000 ( 808 MB)
lowmem : 0xc0000000 - 0xc5000000 ( 80 MB)
pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
.init : 0xc0008000 - 0xc003e000 ( 216 kB)
.text : 0xc003e000 - 0xc04bf000 (4612 kB)
.data : 0xc04c0000 - 0xc05004c0 ( 258 kB)
SLUB: Genslabs=11, HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
NR_IRQS:375
IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts
Total of 128 interrupts on 1 active controller
GPMC revision 6.0
Trying to install interrupt handler for IRQ368
Trying to install interrupt handler for IRQ369
Trying to install interrupt handler for IRQ370
Trying to install interrupt handler for IRQ371
Trying to install interrupt handler for IRQ372
Trying to install interrupt handler for IRQ373
Trying to install interrupt handler for IRQ374
Trying to install type control for IRQ375
Trying to set irq flags for IRQ375
OMAP clockevent source: GPTIMER1 at 20000000 Hz
Console: colour dummy device 80x30
Calibrating delay loop... 599.65 BogoMIPS (lpj=2998272)
pid_max: default: 32768 minimum: 301
Security Framework initialized
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
devtmpfs: initialized
TI81XX: Map 0x84f00000 to 0xfe500000 for dram barrier
TI81XX: Map 0x40300000 to 0xfe600000 for sram barrier
omap_voltage_early_init: voltage driver support not added
regulator: core version 0.5
regulator: dummy:
NET: Registered protocol family 16
omap_voltage_domain_lookup: Voltage driver init not yet happened.Faulting!
omap_voltage_add_dev: VDD specified does not exist!
OMAP GPIO hardware version 0.1
omap_mux_init: Add partition: #1: core, flags: 4
_omap_mux_init_gpio: Could not set gpio79
_omap_mux_init_gpio: Could not set gpio80
Cannot clk_get ck_32
Debugfs: Only enabling/disabling deep sleep and wakeup timer is supported now
registered ti81xx_vpss device
registered ti81xx_vidout device
registered ti81xx on-chip HDMI device
registered ti81xx_fb device
PWM0 init success.
PWM1 init success.
bio: create slab <bio-0> at 0
SCSI subsystem initialized
USBSS revision 4ea2080b
registerd cppi-dma Intr @ IRQ 17
Cppi41 Init Done
omap_i2c omap_i2c.1: bus 1 rev4.0 at 100 kHz
regulator: VRTC: 1800 mV
regulator: VIO: 1500 mV
regulator: VDD1: 600 <--> 1500 mV at 1100 mV
regulator: VDD2: 600 <--> 1500 mV at 1350 mV
regulator: VDDCTRL: 600 <--> 1400 mV at 1200 mV
regulator: LDO1: 1100 <--> 3300 mV at 1800 mV
regulator: LDO2: 1100 <--> 3300 mV at 1800 mV
regulator: LDO3: 1100 <--> 3300 mV at 3300 mV
regulator: LDO4: 1100 <--> 3300 mV at 1800 mV
regulator: LDO5: 1100 <--> 3300 mV at 3300 mV
regulator: LDO6: 1100 <--> 3300 mV at 3300 mV
regulator: LDO7: 1100 <--> 3300 mV at 3300 mV
regulator: LDO8: 1100 <--> 3300 mV at 1800 mV
tps65911-rtc tps65911-rtc: rtc core: registered tps65911-rtc as rtc0
tps65910 1-002d: No interrupt support, no core IRQ
Advanced Linux Sound Architecture Driver Version 1.0.23.
Switching to clocksource gp timer
musb-hdrc: version 6.0, peripheral, debug=0
musb-hdrc musb-hdrc.0: dma type: dma-cppi41
MUSB controller-0 revision 4ea20800
usb2phy: computed values rxcalib(15)DACs(34 13 16)
usb2phy: override computed values rxcalib(15)DACs(34 13 16)
usb2phy_config: musb(0) rxcalib done, rxcalib read value 6f715b86
musb-hdrc musb-hdrc.0: USB Peripheral mode controller at c581e000 using DMA, IRQ 18
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 4096 (order: 3, 32768 bytes)
TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
TCP reno registered
UDP hash table entries: 256 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
NetWinder Floating Point Emulator V0.97 (double precision)
PMU: registered new PMU device of type 0
omap-iommu omap-iommu.0: ducati registered
omap-iommu omap-iommu.1: sys registered
JFFS2 version 2.2. (NAND) ? 2001-2006 Red Hat, Inc.
msgmni has been set to 137
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
CMEMK module: built on Feb 25 2013 at 18:29:06
Reference Linux version 2.6.37
File /home/justin/DM385/IPNC_RDK_DM385_Release_3.5.0/Source/ti_tools/linuxutils_3_23_00_01/packages/ti/sdo/linuxutils/cmem/src/module/cmemk.c
allocated heap buffer 0xc7000000 of size 0x4000000
cmemk initialized
Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
omap_uart.0: ttyO0 at MMIO 0x48020000 (irq = 72) is a OMAP UART0
console [ttyO0] enabled, bootconsole disabled
omap_uart.1: ttyO1 at MMIO 0x48022000 (irq = 73) is a OMAP UART1
omap_uart.2: ttyO2 at MMIO 0x48024000 (irq = 74) is a OMAP UART2
omap_uart.3: ttyO3 at MMIO 0x481a6000 (irq = 44) is a OMAP UART3
omap_uart.4: ttyO4 at MMIO 0x481a8000 (irq = 45) is a OMAP UART4
omap_uart.5: ttyO5 at MMIO 0x481aa000 (irq = 46) is a OMAP UART5
brd: module loaded
loop: module loaded
omap2-nand driver initializing
NAND device: Manufacturer ID: 0x2c, Chip ID: 0xca (Micron )
Creating 8 MTD partitions on "omap2-nand.0":
0x000000000000-0x000000020000 : "U-Boot-min"
0x000000020000-0x000000260000 : "U-Boot"
0x000000260000-0x000000280000 : "U-Boot Env"
0x000000280000-0x0000006c0000 : "Kernel"
0x0000006c0000-0x000006fc0000 : "File System"
0x000006fc0000-0x000007bc0000 : "Data"
0x000007bc0000-0x00000b0c0000 : "File System2"
0x00000b0c0000-0x000010000000 : "Reserved"
UBI: attaching mtd4 to ubi0
UBI: physical eraseblock size: 131072 bytes (128 KiB)
UBI: logical eraseblock size: 126976 bytes
UBI: smallest flash I/O unit: 2048
UBI: sub-page size: 512
UBI: VID header offset: 2048 (aligned 2048)
UBI: data offset: 4096
UBI: max. sequence number: 84
UBI: attached mtd4 to ubi0
UBI: MTD device name: "File System"
UBI: MTD device size: 105 MiB
UBI: number of good PEBs: 840
UBI: number of bad PEBs: 0
UBI: number of corrupted PEBs: 0
UBI: max. allowed volumes: 128
UBI: wear-leveling threshold: 4096
UBI: number of internal volumes: 1
UBI: number of user volumes: 1
UBI: available PEBs: 0
UBI: total number of reserved PEBs: 840
UBI: number of PEBs reserved for bad PEB handling: 8
UBI: max/mean erase counter: 2/0
UBI: image sequence number: 155695375
UBI: background thread "ubi_bgt0d" started, PID 44
davinci_mdio davinci_mdio.0: davinci mdio revision 1.6
davinci_mdio davinci_mdio.0: detected phy mask fffffffe
davinci_mdio.0: probed
davinci_mdio davinci_mdio.0: phy[0]: device 0:00, driver unknown
mice: PS/2 mouse device common for all mice
i2c /dev entries driver
Linux video capture interface: v2.00
OMAP Watchdog Timer Rev 0x00: initial timeout 60 sec
notify_init : notify drivercreated for remote proc id 2 at physical Address 0xbfd00000
cm: Module associated with clock hdmi_i2s_fck didn't enable in 100000 tries
asoc: tlv320aic3x-hifi <-> davinci-mcasp.2 mapping ok
asoc: HDMI-DAI-CODEC <-> hdmi-dai mapping ok
ALSA device list:
#0: TI8148 IPNC
nf_conntrack version 0.5.0 (1103 buckets, 4412 max)
ip_tables: (C) 2000-2006 Netfilter Core Team
TCP cubic registered
NET: Registered protocol family 17
Bridge firewalling registered
lib80211: common routines for IEEE802.11 drivers
Registering the dns_resolver key type
VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
omap_voltage_late_init: Voltage driver support not added
Power Management for TI81XX.
Detected MACID=0:e0:a:dd:0:0
tps65911-rtc tps65911-rtc: setting system clock to 2013-01-21 07:23:57 UTC (1358753037)
CPSW phy found : id is : 0x4dd074
PHY 0:01 not found
Sending DHCP requests .
PHY: 0:00 - Link is Up - 100/Full
., OK
IP-Config: Got DHCP answer from 0.0.0.0, my address is 192.168.2.100
IP-Config: Complete:
device=eth0, addr=192.168.2.100, mask=255.255.255.0, gw=192.168.2.1,
host=192.168.2.100, domain=, nis-domain=(none),
bootserver=0.0.0.0, rootserver=0.0.0.0, rootpath=
UBIFS: recovery needed
UBIFS: recovery completed
UBIFS: mounted UBI device 0, volume 0, name "rootfs"
UBIFS: file system size: 103612416 bytes (101184 KiB, 98 MiB, 816 LEBs)
UBIFS: journal size: 9023488 bytes (8812 KiB, 8 MiB, 72 LEBs)
UBIFS: media format: w4/r0 (latest is w4/r0)
UBIFS: default compressor: lzo
UBIFS: reserved for root: 0 bytes (0 KiB)
VFS: Mounted root (ubifs filesystem) on device 0:13.
devtmpfs: mounted
Freeing init memory: 216K
Failed to execute /init. Attempting defaults...
INIT: version 2.86 booting
Please wait: booting...
Starting udev
Root filesystem already rw, not remounting
Caching udev devnodes
root: mount: mounting /dev/root on / failed: No such file or directory
Configuring network interfaces... udhcpc (v1.13.2) started
Sending discover...
Sending select for 192.168.2.100...
Lease of 192.168.2.100 obtained, lease time 140773632
adding dns 192.168.2.1
done.
Setting up IP spoofing protection: rp_filter.
rm: cannot remove '/tmp': Device or resource busy
inside finish.sh
UBI: attaching mtd5 to ubi1
UBI: max. sequence number: 19
UBI: attached mtd5 to ubi1
UBI: MTD device name: "Data"
UBI: MTD device size: 12 MiB
UBI: number of good PEBs: 96
UBI: total number of reserved PEBs: 96
UBI: number of PEBs reserved for bad PEB handling: 2
UBI: max/mean erase counter: 2/1
UBI: image sequence number: 587448185
UBI: background thread "ubi_bgt1d" started, PID 307
UBI device number 1, total 96 LEBs (12189696 bytes, 11.6 MiB), available 0 LEBs (0 bytes), LEB size 126976 bytes (124.0 KiB)
UBIFS: mounted UBI device 1, volume 0, name "ubifs_volume"
UBIFS: file system size: 10285056 bytes (10044 KiB, 9 MiB, 81 LEBs)
UBIFS: journal size: 1015809 bytes (992 KiB, 0 MiB, 6 LEBs)
UBIFS: reserved for root: 485787 bytes (474 KiB)
UBI: attaching mtd7 to ubi2
UBI: max. sequence number: 10
UBI: attached mtd7 to ubi2
UBI: MTD device name: "Reserved"
UBI: MTD device size: 79 MiB
UBI: number of good PEBs: 634
UBI: total number of reserved PEBs: 634
UBI: number of PEBs reserved for bad PEB handling: 6
UBI: max/mean erase counter: 9/7
UBI: image sequence number: 106273647
UBI: background thread "ubi_bgt2d" started, PID 320
UBI device number 2, total 634 LEBs (80502784 bytes, 76.8 MiB), available 0 LEBs (0 bytes), LEB size 126976 bytes (124.0 KiB)
UBIFS: mounted UBI device 2, volume 0, name "ubifs_volume"
UBIFS: file system size: 78090240 bytes (76260 KiB, 74 MiB, 615 LEBs)
UBIFS: journal size: 3936256 bytes (3844 KiB, 3 MiB, 31 LEBs)
UBIFS: reserved for root: 3688395 bytes (3601 KiB)
./init.sh: line 5: -f: not found
numid=1,iface=MIXER,name='PCM Playback Volume'
; type=INTEGER,access=rw---R--,values=2,min=0,max=127,step=0
: values=127,127
| dBscale-min=-63.50dB,step=0.50dB,mute=0
[c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[m3video] Remote Debug Shared Memory @ 0xbff05020
[m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
SysLink version : 2.20.02.20
SysLink module created on Date:Feb 25 2013 Time:18:49:11
Trace enabled
Trace SetFailureReason enabled
/dev/mem opened.
Phy Addr : 0x48181560 Data : 0x00000002
secss put in low power state
Phy Addr : 0x48180f10 Data : 0x00000000
Phy Addr : 0x48180508 Data : 0x00000302
Phy Addr : 0x48180520 Data : 0x00000002
Phy Addr : 0x48180524 Data : 0x00000002
Phy Addr : 0x48180528 Data : 0x00000002
Phy Addr : 0x4c0000e4 Data : 0x00170208
Phy Addr : 0x4d0000e4 Data : 0x00170208
DDR IOs RX is shutdown
[host] Setting DMM priority for [HDVICP0 ] to [1] ( 0x4e000634 = 0x00000009 )
[host] Setting DMM priority for [ISS ] to [0] ( 0x4e000634 = 0x00800000 )
Creat queue id:0
queue id:0
FileMngThread created
[host] Setting L3 bandwidth regulator for [HDVICP0 ] to [press=[0,0] BW=900, WM Cycles=2500]
Creat queue id:32769
queue id:32769
queue id:32769
AlramThread created
Share memory init success
Creat queue id:65538
queue id:65538
Creat queue id:98307
queue id:98307
[host] Attached to slave procId 2.
[host] Attached to slave procId 1.
[host] Attached to slave procId 0.
[host] Loaded file ./firmware/ipnc_rdk_fw_m3vpss.xem3 on slave procId 2.
[host] Loaded file ./firmware/ipnc_rdk_fw_m3video.xem3 on slave procId 1.
[host] Started slave procId 1.
[host] Started slave procId 2.
[host] After Ipc_loadcallback status [0x00000000]
[m3video] ***** SYSTEM : Frequency <ORG> - 200000000, <NEW> - 200000000
[m3vpss ] ***** SYSTEM : Frequency <ORG> - 200000000, <NEW> - 200000000
[m3video]
[m3vpss ] notify_attach rtnVal 0
[m3video] *** UTILS: CPU KHz = 400000 Khz ***
[m3vpss ] initProxyServer rtnVal 0
[m3video]
[m3video] 50: SYSTEM : System Common Init in progress !!!
[m3video] 50: SYSTEM: IPC init in progress !!!
[m3video] 50: SYSTEM: Attaching to [HOST] ...
[host] Loaded file ./firmware/ipnc_rdk_fw_c6xdsp.xe674 on slave procId 0.
[host] Started slave procId 0.
[c6xdsp ] ***** SYSTEM : Frequency <ORG> - 500000000, <NEW> - 500000000
[m3vpss ]
[c6xdsp ]
[m3vpss ] *** UTILS: CPU KHz = 400000 Khz ***
[c6xdsp ] *** UTILS: CPU KHz = 500000 Khz ***
[m3vpss ]
[c6xdsp ]
[m3vpss ] 92: SYSTEM : System Common Init in progress !!!
[c6xdsp ] 1: SYSTEM : System Common Init in progress !!!
[m3vpss ] 92: SYSTEM: IPC init in progress !!!
[c6xdsp ] 1: SYSTEM: IPC init in progress !!!
[m3vpss ] 92: SYSTEM: Attaching to [HOST] ...
[c6xdsp ] 1: SYSTEM: Attaching to [HOST] ...
[c6xdsp ] 1001: SYSTEM: Attaching to [HOST] ...
[host] After Ipc_startcallback status [0x00000000]
[m3video] 1050: SYSTEM: Attaching to [HOST] ...
[m3vpss ] 1092: SYSTEM: Attaching to [HOST] ...
[c6xdsp ] 1004: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
[m3video] 1116: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
[c6xdsp ] 1004: SYSTEM: Attaching to [VIDEO-M3] ...
[m3video] 1116: SYSTEM: Attaching to [DSP] ...
[m3vpss ] 1178: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
[m3vpss ] 1179: SYSTEM: Attaching to [DSP] ...
[c6xdsp ] 2003: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 2006: SYSTEM: Attaching to [VIDEO-M3] ... SUCCESS !!!
[m3video] 2116: SYSTEM: Attaching to [DSP] ...
[c6xdsp ] 2006: SYSTEM: Attaching to [VPSS-M3] ...
[m3video] 2116: SYSTEM: Attaching to [DSP] ... SUCCESS !!!
[m3video] 2116: SYSTEM: Attaching to [VPSS-M3] ...
[m3vpss ] 2178: SYSTEM: Attaching to [DSP] ...
[c6xdsp ] 3006: SYSTEM: Attaching to [VPSS-M3] ...
[m3video] 3116: SYSTEM: Attaching to [VPSS-M3] ...
[c6xdsp ] 3068: SYSTEM: Attaching to [VPSS-M3] ... SUCCESS !!!
[m3vpss ] 3178: SYSTEM: Attaching to [DSP] ...
[c6xdsp ] 3068: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[m3vpss ] 3178: SYSTEM: Attaching to [DSP] ... SUCCESS !!!
[m3vpss ] 3178: SYSTEM: Attaching to [VIDEO-M3] ...
[m3video] 4116: SYSTEM: Attaching to [VPSS-M3] ...
[c6xdsp ] 4068: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[m3video] 4178: SYSTEM: Attaching to [VPSS-M3] ... SUCCESS !!!
[m3vpss ] 4178: SYSTEM: Attaching to [VIDEO-M3] ...
[m3video] 4179: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[m3vpss ] 4178: SYSTEM: Attaching to [VIDEO-M3] ... SUCCESS !!!
[m3video] 4179: SYSTEM: Creating MsgQ [VIDEO-M3_MSGQ] ...
[m3vpss ] 4179: SYSTEM: Creating MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[m3video] 4179: SYSTEM: Creating MsgQ [VIDEO-M3_ACK_MSGQ] ...
[m3vpss ] 4179: SYSTEM: Creating MsgQ [VPSS-M3_MSGQ] ...
[m3vpss ] 4179: SYSTEM: Creating MsgQ [VPSS-M3_ACK_MSGQ] ...
[m3video] 4182: SYSTEM: Notify register to [HOST] line 0, event 12 ...
[m3vpss ] 4181: SYSTEM: Notify register to [HOST] line 0, event 12 ...
[m3video] 4182: SYSTEM: Notify register to [DSP] line 0, event 12 ...
[m3vpss ] 4182: SYSTEM: Notify register to [DSP] line 0, event 12 ...
[m3video] 4182: SYSTEM: Notify register to [VPSS-M3] line 0, event 12 ...
[m3vpss ] 4182: SYSTEM: Notify register to [VIDEO-M3] line 0, event 12 ...
[m3video] 4182: SYSTEM: IPC init DONE !!!
[m3vpss ] 4182: SYSTEM: IPC init DONE !!!
[m3vpss ] Received character 's'
[m3video] 4192: MEM: Shared Region 2: Base = 0xb8000000, Length = 0x06900000 (105 MB)
[m3vpss ] 4192: MEM: Shared Region 2: Base = 0xb8000000, Length = 0x06900000 (105 MB)
[m3video] 4192: MEM: Shared Region 1: Base = 0x89000000, Length = 0x03c00000 (60 MB)
[m3vpss ] 4192: MEM: Shared Region 1: Base = 0x89000000, Length = 0x03c00000 (60 MB)
[m3video] 4195: SYSTEM : System Common Init Done !!!
[m3vpss ] 4195: SYSTEM : System Common Init Done !!!
[m3video] Received character 's'
[c6xdsp ] 5068: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[c6xdsp ] 5068: SYSTEM: Creating MsgQ [DSP_MSGQ] ...
[c6xdsp ] 5069: SYSTEM: Creating MsgQ [DSP_ACK_MSGQ] ...
[c6xdsp ] 5069: SYSTEM: Notify register to [HOST] line 0, event 12 ...
[c6xdsp ] 5069: SYSTEM: Notify register to [VIDEO-M3] line 0, event 12 ...
[c6xdsp ] 5069: SYSTEM: Notify register to [VPSS-M3] line 0, event 12 ...
[c6xdsp ] 5070: SYSTEM: IPC init DONE !!!
[c6xdsp ] 5073: MEM: Shared Region 2: Base = 0xb8000000, Length = 0x06900000 (105 MB)
[c6xdsp ] 5073: MEM: Shared Region 1: Base = 0x89000000, Length = 0x03c00000 (60 MB)
[c6xdsp ] 5074: SYSTEM : System Common Init Done !!!
[c6xdsp ] Received character 's'
queue id:65538
CPU is TI812x
Error: SemWait: Invalid Semaphore handler
Error: SemRelease: Invalid Semaphore handler
IPNC BUILD VERSION: DM8127 IPNC RDK VERSION 03.50.00.08
./bin/ipnc_rdk_mcfw.out VNF_QUALITY SINGLESTREAM SINGLE_H264 TI2A AEWB 1080P_D1 H264 HIGH_SPEED1 &
[m3video] 5295: SYSTEM : System Video Init in progress !!!
[m3vpss ] 5295: SYSTEM : System VPSS Init in progress !!!
[m3video] 5295: SYSTEM : System Video Init Done !!!
[m3video] 5295: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_0] in region 0 ...
[m3video] 5296: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_0] in region 0 ...
[m3video] 5296: SYSTEM: ListElem Shared Addr = 0xbe98b680
[m3video] 5298: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_1] in region 0 ...
[m3video] 5299: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_1] in region 0 ...
[m3video] 5299: SYSTEM: ListElem Shared Addr = 0xbe98eb80
[m3video] 5310: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_28] in region 0 ...
[m3video] 5310: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_28] in region 0 ...
[m3video] 5311: SYSTEM: ListElem Shared Addr = 0xbe992080
[m3video] 5313: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_29] in region 0 ...
[m3vpss ] === I2C0/2 Clk is active ===
[m3video] 5314: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_29] in region 0 ...
[m3vpss ] 5313: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_0] in region 0 ...
[m3video] 5314: SYSTEM: ListElem Shared Addr = 0xbe9ac280
[m3vpss ] 5314: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_0] in region 0 ...
[m3video] 5316: HDVICP: Doing PRCM for IVAHD[0] ...
[m3vpss ] 5314: SYSTEM: ListElem Shared Addr = 0xbe9c5980
[m3video] 5316: HDVICP: PRCM for IVAHD[0] ... DONE.
[m3vpss ] 5317: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_1] in region 0 ...
[m3video] 5317: SYSTEM : Initializing Links !!!
[m3vpss ] 5317: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_1] in region 0 ...
[m3vpss ] 5317: SYSTEM: ListElem Shared Addr = 0xbe9c8e80
[m3video] 5317: SYSTEM : FREE SPACE : System Heap = 6282128 B, Mbx = 10240 msgs)
[m3video] 5318: SYSTEM : FREE SPACE : SR0 Heap = 15942272 B (15 MB)
[m3video] 5318: SYSTEM : FREE SPACE : Frame Buffer = 110100352 B (104 MB)
[m3vpss ] 5333: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_23] in region 0 ...
[m3vpss ] 5333: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_23] in region 0 ...
[m3video] 5318: SYSTEM : FREE SPACE : Bitstream Buffer = 62914432 B (59 MB)
[m3vpss ] 5333: SYSTEM: ListElem Shared Addr = 0xbe9cc380
[m3vpss ] 5336: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_24] in region 0 ...
[m3video] 5318: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
[m3vpss ] 5337: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_24] in region 0 ...
[m3video] 5319: SYSTEM : FREE SPACE : Tiler 8-bit = 89128960 B (85 MB) - TILER ON
[m3vpss ] 5337: SYSTEM: ListElem Shared Addr = 0xbe9ebd80
[m3vpss ] 5340: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_25] in region 0 ...
[m3video] 5320: SYSTEM : FREE SPACE : Tiler 16-bit = 44040192 B (42 MB) - TILER ON
[m3vpss ] 5340: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_25] in region 0 ...
[m3vpss ] 5340: SYSTEM: ListElem Shared Addr = 0xbea0b780
[m3vpss ] 5348: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_28] in region 0 ...
[m3vpss ] 5348: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_28] in region 0 ...
[m3vpss ] 5348: SYSTEM: ListElem Shared Addr = 0xbea2b180
[m3vpss ] 5351: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_29] in region 0 ...
[m3vpss ] 5351: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_29] in region 0 ...
[m3vpss ] 5351: SYSTEM: ListElem Shared Addr = 0xbea44e00
[m3vpss ] 5354: SYSTEM : HDVPSS Drivers Version: HDVPSS_01_00_01_37
[m3vpss ] 5354: SYSTEM : FVID2 Init in progress !!!
[m3video] 5376: SYSTEM : Initializing Links ... DONE !!!
[c6xdsp ] 5272: SYSTEM : System DSP Init in progress !!!
[c6xdsp ] 5278: SYSTEM: Creating ListMP [DSP_IPC_OUT_23] in region 0 ...
[c6xdsp ] 5278: SYSTEM: Creating ListMP [DSP_IPC_IN_23] in region 0 ...
[c6xdsp ] 5278: SYSTEM: ListElem Shared Addr = 0xbea5ea80
[c6xdsp ] 5279: SYSTEM: Creating ListMP [DSP_IPC_OUT_24] in region 0 ...
[c6xdsp ] 5279: SYSTEM: Creating ListMP [DSP_IPC_IN_24] in region 0 ...
[c6xdsp ] 5279: SYSTEM: ListElem Shared Addr = 0xbea7e480
[c6xdsp ] 5281: SYSTEM: Creating ListMP [DSP_IPC_OUT_25] in region 0 ...
[c6xdsp ] 5281: SYSTEM: Creating ListMP [DSP_IPC_IN_25] in region 0 ...
[c6xdsp ] 5281: SYSTEM: ListElem Shared Addr = 0xbea9de80
[c6xdsp ] 5282: SYSTEM: Creating ListMP [DSP_IPC_OUT_28] in region 0 ...
[c6xdsp ] 5282: SYSTEM: Creating ListMP [DSP_IPC_IN_28] in region 0 ...
[c6xdsp ] 5282: SYSTEM: ListElem Shared Addr = 0xbeabd880
[c6xdsp ] 5283: SYSTEM: Creating ListMP [DSP_IPC_OUT_29] in region 0 ...
[c6xdsp ] 5283: SYSTEM: Creating ListMP [DSP_IPC_IN_29] in region 0 ...
[c6xdsp ] 5283: SYSTEM: ListElem Shared Addr = 0xbead7500
[c6xdsp ] !!WARNING.Resource already registered:2
[c6xdsp ] 5283: SYSTEM : Initializing Links !!!
[c6xdsp ] 5284: SYSTEM : FREE SPACE : System Heap = 6282544 B, Mbx = 10240 msgs)
[c6xdsp ] 5298: SYSTEM : Initializing Links ... DONE !!!
[m3vpss ] 5420: SYSTEM : FVID2 Init in progress DONE !!!
[m3vpss ] 5420: SYSTEM : Device Init in progress !!!
[c6xdsp ] 5298: SYSTEM : System DSP Init Done !!!
[m3vpss ] Iss_init called !!!!!!
[m3vpss ] CPIS_init DONE !!!!!!
[m3vpss ] initPrms.isI2cInitReq = 1
[m3vpss ] Vps_deviceInit Daughter card not detected/connected!
[m3vpss ]
inside autorun
INIT: Entering runlevel: 5
sbulla: unknown partition table
Starting telnet daemon.
Starting syslogd/klogd: done
_____ _ _
|?|___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_
| | _| .'| . | . | | __| _| . | | | -_| _| _|
|__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_|
|___| |___|
Arago Project http://arago-project.org dm814x-evm ttyO0
Arago 2011.09 dm814x-evm ttyO0
dm814x-evm login: root (automatic login)
root@dm814x-evm:~# [m3vpss ] I2C2: Passed for address 0x36 !!!
mkdosfs 3.0.12 (29 Oct 2011)
unable to get drive geometry, using default 255/63
/dev/sbulla has 255 heads and 63 sectors per track,
logical sector size is 512,
using 0xf8 media descriptor, with 1024 sectors;
file system has 2 12-bit FATs and 4 sectors per cluster.
FAT size is 1 sector, and provides 247 clusters.
There is 1 reserved sector.
Root directory contains 512 slots and uses 32 sectors.
Volume ID is ca1af7a0, no volume label.
g_file_storage gadget: No serial-number string provided!
[m3vpss ] I2C2: Passed for addg_file_storage gadget: File-backed Storage Gadget, version: 1 September 2010
ress 0x55 !!!
g_file_storage gadget: Number of LUNs=1
g_file_storage gadget-lun0: ro=0, nofua=0, file: /dev/sbulla
Simple mixer control 'PGA',0
Capabilities: cvolume cswitch penum
Capture channels: Front Left - Front Right
Limits: Capture 0 - 119
Front Left: Capture 80 [67%] [40.00dB] [on]
Front Right: Capture 80 [67%] [40.00dB] [on]
[m3vpss ] 8146: SYSTEM : Device Init in progress DONE !!!
[m3vpss ] 8174: SYSTEM : System VPSS Init Done !!!
[m3vpss ] 8174: UTILS: DMA: HWI Create for INT62 !!!
[m3vpss ] 8174: SYSTEM : Initializing Links !!!
[m3vpss ] 8174: SYSTEM : FREE SPACE : System Heap = 1718872 B, Mbx = 10240 msgs)
[m3vpss ] 8174: SYSTEM : FREE SPACE : SR0 Heap = 14742656 B (14 MB)
[m3vpss ] 8175: SYSTEM : FREE SPACE : Frame Buffer = 105790336 B (100 MB)
[m3vpss ] 8175: SYSTEM : FREE SPACE : Bitstream Buffer = 62914432 B (59 MB)
[m3vpss ] 8175: SYSTEM : FREE SPACE : Tiler 8-bit = 89128960 B (85 MB) - TILER ON
[m3vpss ] 8175: SYSTEM : FREE SPACE : Tiler 16-bit = 44040192 B (42 MB) - TILER ON
[m3vpss ] Received character 't'
[m3vpss ] 8306: SYSTEM : Initializing Links ... DONE !!!
[m3video] Received character 't'
[m3video] Remote Debug Shared Memory @ 0xbfMemory @ 0xbff05020
[m3vpssug Shmote Debug Shared Memory @ 0xbff0a040
eived eo] 5313: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_29] in region 0 ...
[m3vpss ] === I2C0/2 Clkful
ctive ===
[m3video] 5314: SYSTEM: Cr57
[m3vppleted5314: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_0] in region 0 ...
[m3video] 5316: HDVICP: Doing Pgress r IVAHD[0] ...
[m3video] 5316: HDVICP: PRCM fink prHD[0] ... DONE.
[m3vpss ] 5317: SYSTM: CPUeating ListMP [VPSS-M3_IPC_OUT_1] in region 0 ...
[m3video] 5317: SYSTEsyslinnitializing Links !!!
[m3vpss ] 5317: SYSTEM: Cng Msgg ListMP [VPSS-M3_IPC_IN_1] in region 0 ...
[m3vpss ] 5317: SYSTEM: LisT_MSGQShared Addr = 0xbe9c8e80
[m3video] 5317: SYSTEM_ACK_MEE SPACE : System Heap = 6282128 B, Mbx = 10240 msgs)
[m3video] 5318: SYSTEM OpeniE SPACE : SR0 Heap = 15942272 B (15 MB)
[m3video] 5318: SYSTEMlocatREE SPACE : Frame Buffer = 110100352 B (104 MB)
[m3vpss ] 5333: SYSTEM: CreaEM: NListMP [VPSS-M3_IPC_OUT_23] in region 0 ...
[m3video] 5318: SYSTEM : FR regisCE : Bitstream Buffer = 62914432 B (59 MB)
[m3vpss ] 5333: SYSTEM: LisONE !!Shared Addr = 0xbe9cc380
[m3vpss ] 5336: SYSTEM:C_OUT_ing ListMP [VPSS-M3_IPC_OUT_24] in region 0 ...
[m3video] 5318: SYSTEM:28] inng MsgQ [VPSS-M3_MSGQ] ...
[m3vpss ] 5337: SYSTEred Adating ListMP [VPSS-M3_IPC_IN_24] in region 0 ...
[m3video] 5319: SYSTE] in reEE SPACE : Tiler 8-bit = 89128960 B (85 MB) - TILER ON
[m3vpss ] 5340: SYSTEM: Cret] 62ListMP [VPSS-M3_IPC_OUT_25] in region 0 ...
[m3vpss ] 5348: SYSTEM: regiolem Shared Addr = 0xbea2b180
[m3vpss ] 5351: SYSTEM: ListEleaddr =ed Addr = 0xbea44e00
[m3vpss ] 5354: SYSTEM : HDS:App_rivers Version: HDVPSS_01_00_01_37
[m3video] 5376: SYSTEM : py_opalizing Links ... DONE !!!
[c6xdsp ] 5272: SYSTEheMng_ystem DSP Init in progress !!!
[c6xdsp ] 5278: SYSTEM: LFxn:Enm Shared Addr = 0xbea5ea80
[c6xdsp ] 5279: SYSTEM: ListEl+ H264red Addr = 0xbea7e480
[c6xdsp ] 5281: SYSTEM: Crt] 16 ListMP [DSP_IPC_OUT_25] in region 0 ...
[c6xdsp 162: M1: SYSTEM: Creating ListMP [DSP_IPC_IN_25] in region 0 ...
[c6xdsp ] 5281: SYSTEM:REV A]lem Shared Addr = 0xbea9de80
[c6xdsp ] 5282: SYSTEM: Creatin_SET_VMP [DSP_IPC_OUT_28] in region 0 ...
[c6xdsp ] 5282: SYSTEM: ListTEM_DChared Addr = 0xbeabd880
[c6xdsp ] 5283: SYSTEM: CC VPSng ListMP [DSP_IPC_OUT_29] in region 0 ...
[ebebeb ] 5283: SYSTEM : Initializing Links !!!
[c6xdsp ] 5284: SYSTEM : F= 0 VpACE : System Heap = 6282544 B, Mbx = 10240 msgs)
[m3vpss ] 5420: SYSTEMDetectID2 Init in progress DONE !!!
[m3vpss ] 5420: SYSTEM : DeviDone it in progress !!!
[c6xdsp ] 5298: SYSTEM : Systrogres Init Done !!!
ss ] ss ] Iss_init called !!!!!!
[m3vpss H0 of S_init DONE !!!!!!
[m3vpss ] initPrms.isI2cInitRVE] [7
[m3ughter card not detected/connected!
[ [m3vp ]
inone !!utorun
INIT: E97: MEg runlevel: 5
ne !!a: unknown partition table
runni: unknown partition table
Starting telnet daemon. [m3vping syslogd/klogd: done
} edma3Handle->tccVal = 37
[m3pss ] {SWOSD} edma3Handle->chId = 37
[m3vpss ] {SWOSD} edma3Handle->tccVal = 38
[m3vpss ] {SWOSD} edma3Handle->chId = 38
[m3vpss ] 9871: SWOSD : Create Done !!!
[m3vpss ] 9968: DUP : Create Done !!!
[m3vpss ] 9969: SCLR: Create in progress !!!
[m3vpss ] 9974: SCLR : Loading U-scaling Co-effs ...
[m3vpss ] 9974: SCLR : Co-effs Loading ... DONE !!!
[m3video] 9981: IPC_IN_M3 : Create in progress !!!
[m3video] 9982: SYSTEM: Opening ListMP [VPSS-M3_IPC_OUT_0] ...
[m3vpss ] SCLR:HEAPID:0 USED:64
[m3video] 9982: SYSTEM: Opening ListMP [VPSS-M3_IPC_IN_0] ...
[m3vpss ] SCLR:HEAPID:1 USED:5952
[m3video] 9985: IPC_IN_M3 : Create Done !!!
[m3vpss ] 9975: SCLR: Create Done !!!
[m3video] 9986: ENCODE: Create in progress ... !!!
[m3vpss ] 9888: FD : Alg Create Done !!!
[m3vpss ] 9888: FD : Create Done !!!
[m3vpss ] 9980: IPC_OUT_M3 : Create in progress !!!
[m3vpss ] 9981: IPC_OUT_M3 : Create Done !!!
[m3video] 10049: ENCODE: Creating CH0 of 1920 x 1080, pitch = (1952, 1952) [PROGRESSIVE] [NON-TILED ], bitrate = 8000 Kbps ...
[host] IpcBitsInLink_tskMain:Entered
[host] 809: IPC_BITS_IN : Create in progress !!!
[host] 809: IPC_BITS_IN : ListMPOpen start !!!
[host] 809: SYSTEM: Opening ListMP [VIDEO-M3_IPC_OUT_28] ...
[host] 810: SYSTEM: Opening ListMP [VIDEO-M3_IPC_IN_28] ...
[host] 812: IPC_BITS_IN : ListMPOpen done !!!
[host] 813: IPC_BITS_IN : System_linkGetInfo done !!!
[host] 813: IPC_BITS_IN : Create Done !!!
[host] USECASE SETUP DONE
[m3video] ENCLINK_H264:HEAPID:0 USED:13808
[m3vpss ] 10172: DISPLAY: Create in progress !!!
[m3video] 10155: ENCODE: Creating CH1 of 720 x 480, pitch = (16384, 32768) [PROGRESSIVE] [TILED ], bitrate = 8000 Kbps ...
[m3vpss ] DisplayId = 1,DataFormat = 7
[m3vpss ] SC2 displayInstId = 6
[m3vpss ] 10174: DISPLAY: Create Done !!!
[m3video] ENCLINK_H264:HEAPID:0 USED:11912
[m3vpss ] 10174: DISPLAY: Create in progress !!!
[m3video] 10160: ENCODE: Creating CH2 of 1920 x 1080, pitch = (1952, 1952) [PROGRESSIVE] [NON-TILED ], bitrate = 100 Kbps ...
[m3vpss ] DisplayId = 4,DataFormat = 7
[m3vpss ] SD displayInstId = 2
[m3vpss ] 10175: DISPLAY: Create Done !!!
[m3video] ENCLINK_JPEG:HEAPID:0 USED:4432
[m3vpss ] 10177: DISPLAY: Start in progress !!!
[m3video] 10161: ENCODE: All CH Create ... DONE !!!
[m3video] ENCLINK:HEAPID:0 USED:30472
[m3video] 10163: ENCODE: Create ... DONE !!!
[m3video] 10115: VSTAB : Alg Create Done !!!
[m3video] 10115: VSTAB : Create Done !!!
[m3video] 10164: IPC_BITS_OUT : Create in progress !!!
[m3video] 10167: IPC_BITS_OUT : Create Done !!!
[m3vpss ] 10219: DISPLAY: Start Done !!!
[m3vpss ] 10219: DISPLAY: AUX PATH: 47 fps, Latency (Min / Max) = ( 255 / 0 ), Callback Interval (Min / Max) = ( 255 / 0 ) !!!
[m3vpss ] 10219: DISPLAY: Start in progress !!!
[m3vpss ] 10266: DISPLAY: Start Done !!!
[m3vpss ] 10266: DISPLAY: SDDAC(SEC1): 21 fps, Latency (Min / Max) = ( 255 / 0 ), Callback Interval (Min / Max) = ( 255 / 0 ) !!!
[m3vpss ] 10177: CAMERA: Start in progress !!!
[m3vpss ] 10177: CAMERA: Start Done !!!
[host]
Application Run Completed
ApproDrvInit: 3
queue id:131076
queue id:0
queue id:32769
[host] ITT server task running !!!
[host]
ITT ittServer_run
[host] ITT Server Message initialization successful
[host]
ITT capture task created
[host] DCC server Message ques is open succefully
[host] Setting cmd <1> in message <4040b100>
[host] Posting message <4040b100> in QId <20002>
[m3vpss ] Command 1 recived from HOST A8
[host] Response from M3 is : 1
[m3vpss ] Command 2 recived from HOST A8
[m3vpss ] New DCC data of size <33603>
[host] Default parameters were sent sucessfully
[host] Server Socket created with ID <22>
[m3vpss ] Call to VNF_LINK_CMD_UPDATE_DCC 536870977
queue id:0
ApproDrvInit: 7
queue id:131076
TimeOut occure in boot_proc.
Program exit.
Program exit.
[host]
Usecase is Active !!!
ApproDrvExit: 7
Error: WaitStreamReady Fail.
[host]
This is my Rules.make:
# Copyright (c) Texas Instruments Inc 2012
# Use of this software is controlled by the terms and conditions found in the
# license agreement under which this software has been supplied or provided.
# Default build environment, windows or linux
ifeq ($(OS), )
OS := Linux
endif
#CONFIGURATION
SYSTEM_PLATFORM := IPNC
#SYSTEM_PLATFORM := EVM
# Build configuration
#APP_BUILD_CFG := debug
APP_BUILD_CFG := release
# Binary to boot from NAND or SDCARD
BINARY_MODE := nand
#BINARY_MODE := sd
# Values are "DM385" and "DM812x"
#IPNC_DEVICE := DM385
IPNC_DEVICE := DM812x
# Values are "LOW_POWER" and "FULL_FEATURE"
IPNC_CONFIG := FULL_FEATURE
#IPNC_CONFIG := LOW_POWER
# Memory foot print
#MEMORY_CONFIG := 256MB
MEMORY_CONFIG := 512MB
# UBIFS mtd-utils mode
#MTD_UTILS_MODE := 64bit
MTD_UTILS_MODE := 32bit
ifeq ($(IPNC_DEVICE), DM812x)
IMGS_ID := IMGS_MICRON_MT9J003
#IMGS_ID := IMGS_MICRON_AR0330
#IMGS_ID := IMGS_MICRON_AR0331
#IMGS_ID := IMGS_PANASONIC_MN34041
#IMGS_ID := IMGS_OMNIVISION_OV10630
else
#IMGS_ID := IMGS_MICRON_MT9J003
#IMGS_ID := IMGS_SONY_IMX136
#IMGS_ID := IMGS_SONY_IMX104
#IMGS_ID := IMGS_MICRON_MT9M034
endif
# TILER Memory enable
#IPNC_TILER_ENABLE := NO
IPNC_TILER_ENABLE := YES
BTE_ENABLE := NO
# Codec Setting Parameters
# Mjpeg Rate Control Mode ( VBR, CBR, QPMODE)
MJPEG_RC_MODE := MJPEG_QPMODE
#MJPEG_RC_MODE := MJPEG_VBR_MODE
#MJPEG_RC_MODE := MJPEG_CBR_MODE
#Power optimization mode for 30fps usecases
#This flag if TRUE will lower clocks in UBOOT
#Application code is not affected by this change
LOW_POWER_30FPS_MODE = NO
#LOW_POWER_30FPS_MODE = YES
#Build warnings will be treated as errors for ipnc_mcfw folder
TREAT_WARNINGS_AS_ERROR=yes
# Special usecase flags are given here, will override the normal IPNC setting
# User need to ensure that IPNC_CONFIG is in FULL_FEATURE mode for this usecase
# This usecase enables capture + encode + decode + display dataflow
# this is normally useful for video-conf usecase who use IPNCRDK as codebase
ENC_A8_DEC_USE_CASE := NO
# This is Quad stream usecase of H264 1080p@30fps+H264 D1@30fps+H264 CIF@30fps+MJPEG 1080p@5fps
# In this mode noisefilter is applied only once on 1080p stream and all other resolution are derived from it
QUAD_STREAM_NF_USE_CASE := NO
# This usecase enables Capture + Display mode, normally used for sensor bringup and during IPIPE tunnning
# Set this flag FRAMES_TO_A8 to "YUV" will send secondary stream only with a round trip M3-A8-M3 to reach the SD display
# Set this flag FRAMES_TO_A8 to "RAW" will send RAW frames to A8 and then back to M3
# This flag FRAMES_TO_A8 can be set only if CAPTURE_DISPLAY_MODE_ON is set to YES
CAPTURE_DISPLAY_MODE_ON := NO
FRAMES_TO_A8 := NO
ifeq ($(ENC_A8_DEC_USE_CASE), YES)
endif
ifeq ($(QUAD_STREAM_NF_USE_CASE), YES)
endif
ifeq ($(CAPTURE_DISPLAY_MODE_ON), YES)
endif
# All build tools paths are set in this section
BASE_INSTALL_DIR := $(shell pwd)/..
# Defining the install base directory for IPNC RDK
IPNC_INSTALL_DIR := $(BASE_INSTALL_DIR)/ipnc_rdk
#IPNC_INSTALL_DIR := /home/justin/DM385/IPNC_RDK_DM385_Release_3.5.0/Source/ipnc_rdk
TOOLS_INSTALL_DIR := $(BASE_INSTALL_DIR)/ti_tools
#TOOLS_INSTALL_DIR := /home/justin/DM385/IPNC_RDK_DM385_Release_3.5.0/Source/ti_tools
# Defining the build tools directory for IPNC RDK
BUILD_TOOL_DIR := $(TOOLS_INSTALL_DIR)/linux_devkit
BUILD_TOOL_PREFIX := $(BUILD_TOOL_DIR)/bin/arm-arago-linux-gnueabi-
CODEGEN_PATH_A8 := $(BUILD_TOOL_DIR)
#BUILD_TOOL_DIR := /home/justin/DM385/IPNC_RDK_DM385_Release_3.5.0/Source/ti_tools/linux_devkit
#BUILD_TOOL_PREFIX := /home/justin/CodeSourcery/Sourcery_G++_Lite/bin/arm-none-linux-gnueabi-
#CODEGEN_PATH_A8 := /home/justin/CodeSourcery/Sourcery_G++_Lite
# Defining all the tools that are required for IPNC RDK
bios_PATH := $(TOOLS_INSTALL_DIR)/bios_6_33_05_46
CODEGEN_PATH_DSP := $(TOOLS_INSTALL_DIR)/cgt6x_7_4_2
CODEGEN_PATH_M3 := $(TOOLS_INSTALL_DIR)/cgt470_4_9_7
edma3lld_PATH := $(TOOLS_INSTALL_DIR)/edma3_lld_02_11_06_01
fc_PATH := $(TOOLS_INSTALL_DIR)/framework_components_3_22_03_09
ipc_PATH := $(TOOLS_INSTALL_DIR)/ipc_1_24_03_32
hdvicplib_PATH := $(TOOLS_INSTALL_DIR)/ivahd-hdvicp20api_01_00_00_19
linuxdevkit_PATH := $(TOOLS_INSTALL_DIR)/linux_devkit/arm-arago-linux-gnueabi
xdais_PATH := $(TOOLS_INSTALL_DIR)/xdais_7_23_00_06
xdc_PATH := $(TOOLS_INSTALL_DIR)/xdctools_3_24_03_33
hdvpss_PATH := $(TOOLS_INSTALL_DIR)/hdvpss_01_00_01_37
iss_PATH := $(TOOLS_INSTALL_DIR)/iss_03_50_00_00
syslink_PATH := $(TOOLS_INSTALL_DIR)/syslink_2_20_02_20
linuxutils_PATH := $(TOOLS_INSTALL_DIR)/linuxutils_3_23_00_01
# Defining all the codec components that are required for IPNC RDK
codecs_DIR := $(TOOLS_INSTALL_DIR)/codecs-dm814x
h264enc_DIR := $(codecs_DIR)/REL.500.V.H264AVC.E.IVAHD.02.00.04.01
h264dec_DIR := $(codecs_DIR)/REL.500.V.H264AVC.D.HP.IVAHD.02.00.08.00
mpeg4enc_DIR := $(codecs_DIR)/REL.500.V.MPEG4.E.SP.IVAHD.01.00.00.05
mpeg4dec_DIR := $(codecs_DIR)/REL.500.V.MPEG4.D.IVAHD.01.00.11.00
jpegenc_DIR := $(codecs_DIR)/REL.500.V.MJPEG.E.IVAHD.01.00.09.00
jpegdec_DIR := $(codecs_DIR)/REL.500.V.MJPEG.D.IVAHD.01.00.07.00
h264enc_PATH := $(h264enc_DIR)/500.V.H264AVC.E.IVAHD.02.00/IVAHD_001
h264dec_PATH := $(h264dec_DIR)/500.V.H264AVC.D.HP.IVAHD.02.00/IVAHD_001
jpegenc_PATH := $(jpegenc_DIR)/500.V.MJPEG.E.IVAHD.01.00/IVAHD_001
jpegdec_PATH := $(jpegdec_DIR)/500.V.MJPEG.D.IVAHD.01.00/IVAHD_001
mpeg4enc_PATH := $(mpeg4enc_DIR)/500.V.MPEG4.E.SP.IVAHD.01.00/IVAHD_001
mpeg4dec_PATH := $(mpeg4dec_DIR)/500.V.MPEG4.D.ASP.IVAHD.01.00/IVAHD_001
# The directory that points to the Linux Support Package
lsp_PATH := $(TOOLS_INSTALL_DIR)/ipnc_psp_arago
KERNELDIR := $(lsp_PATH)/kernel
UBOOTDIR := $(lsp_PATH)/u-boot
# The directory that points to where filesystem is mounted
FILESYS_INSTALL_DIR := $(IPNC_INSTALL_DIR)/target
TARGET_FS := $(FILESYS_INSTALL_DIR)/filesys
TARGET_FS_DIR := $(TARGET_FS)
MTD_UTILS := $(FILESYS_INSTALL_DIR)/mtd-utils/$(MTD_UTILS_MODE)
# The directory that points IPNC RDK source code
MCFW_ROOT_PATH := $(IPNC_INSTALL_DIR)/ipnc_mcfw
IPNC_DIR := $(IPNC_INSTALL_DIR)/ipnc_app
TFTP_HOME := $(IPNC_INSTALL_DIR)/tftp/$(IPNC_DEVICE)/$(BINARY_MODE)
# SYSLINK related options/paths are set here
syslink_DEVICE := TI814X
else
syslink_DEVICE := TI813X
endif
syslink_INCLUDE := $(syslink_PATH)/packages
syslink_LIB_DIR := $(syslink_INCLUDE)/ti/syslink/lib
syslink_OUT_DIR := $(syslink_PATH)/packages/ti/syslink/bin/$(syslink_DEVICE)
# The directory to MCFW binaries
TARGET_MCFW_DIR := $(MCFW_ROOT_PATH)/bin/ti814x
PLATFORM_CFG := ti8148
else
TARGET_MCFW_DIR := $(MCFW_ROOT_PATH)/bin/ti810x
PLATFORM_CFG := dm385
endif
# The directory to application interface
IPNC_INTERFACE_DIR := $(IPNC_DIR)/interface
# The directory to application interface include files
PUBLIC_INCLUDE_DIR := $(IPNC_INTERFACE_DIR)/inc
# The directory to application interface library files
APP_LIB_DIR := $(IPNC_INTERFACE_DIR)/lib
# The directory to CMEM library
CMEM_LIB_DIR := $(linuxutils_PATH)/packages/ti/sdo/linuxutils/cmem/lib
CMEM_INC_DIR := $(linuxutils_PATH)/packages/ti/sdo/linuxutils/cmem/include
# The directory to root file system
ROOT_FILE_SYS:= $(TARGET_FS)
# Where to copy the resulting executables and data to (when executing 'make
# install') in a proper file structure. This EXEC_DIR should either be visible
# from the target, or you will have to copy this (whole) directory onto the
# target filesystem.
EXEC_DIR:=$(TARGET_FS)/opt/ipnc
# Combinations checks for the options set above are done here
# Board type can be one of the following
# 1. DM814X_IPNC
# 2. DM8107_IPNC
DVR_RDK_BOARD_TYPE := DM814X_IPNC
else
DVR_RDK_BOARD_TYPE := DM8107_IPNC
endif
# Values are "NULL", "FPGA" or "LVDS324"
SENSOR_DATA_OP := SENSOR_DATA_OP_NULL
ifeq ($(IMGS_ID), IMGS_PANASONIC_MN34041)
SENSOR_DATA_OP:= MN34041_DATA_OP_FPGA
endif
else
ifeq ($(IMGS_ID), IMGS_SONY_IMX136)
SENSOR_DATA_OP:= IMX136_DATA_OP_LVDS324
endif
SENSOR_DATA_OP:= MN34041_DATA_OP_LVDS324
endif
ifeq ($(IMGS_ID), IMGS_SONY_IMX104)
SENSOR_DATA_OP:= IMX104_LVDS324
endif
endif
ifeq ($(IMGS_ID), IMGS_MICRON_AR0330)
CAPTURE_MODE:= MIPI_CSI2
endif
ifeq ($(IPNC_CONFIG), FULL_FEATURE)
# Values are "NO" and "YES"
POWER_OPT_DSP_OFF := NO
POWER_OPT_DSS_OFF := NO
else
POWER_OPT_DSP_OFF := YES
endif
else
POWER_OPT_DSS_OFF := YES
endif
endif
ifeq ($(MEMORY_CONFIG), 256MB)
BTE_ENABLE := NO
MEMORY_256MB := YES
else
MEMORY_256MB := NO
endif
# Default platform
PLATFORM := ti814x-evm
else
PLATFORM := ti810x-evm
endif
# Default profile
ifeq ($(PROFILE_m3video), )
PROFILE_m3video := $(APP_BUILD_CFG)
endif
ifeq ($(PROFILE_m3vpss), )
PROFILE_m3vpss := $(APP_BUILD_CFG)
endif
ifeq ($(PROFILE_c6xdsp), )
PROFILE_c6xdsp := $(APP_BUILD_CFG)
ifeq ($(APP_BUILD_CFG), whole_program_debug)
PROFILE_c6xdsp := release
endif
endif
# Default klockwork build flag
ifeq ($(KW_BUILD), )
KW_BUILD := no
endif
#Teardown method for reloading usecases
TEARDOWN_LOAD_UNLOAD := NO
# Option to speed up GLBCE/SALDRE by offloading tonalcurve calculation on A8
USE_A8_FOR_TC_CALC := YES
# Option where from the BoxCar comes from ISS or calculated by iMX
ifeq ($(USE_A8_FOR_TC_CALC), YES)
USE_ISS_BOXCAR := YES
else
USE_ISS_BOXCAR := NO
endif
ifeq ($(SYSTEM_PLATFORM), IPNC)
export SYSTEM_CFG := ipnc
else
export SYSTEM_CFG := evm
endif
ifeq (, $(findstring $(UBOOTDIR)/tools, $(PATH)))
export PATH:=$(UBOOTDIR)/tools:$(PATH)
endif
FS_CFG := ubifs
ROOTDIR := $(MCFW_ROOT_PATH)
SC_SCRIPTS_BASE_DIR := $(TOOLS_BASE_DIR)/coding_guidelines/scripts
XDCPATH = $(bios_PATH)/packages;$(xdc_PATH)/packages;$(ipc_PATH)/packages;$(hdvpss_PATH)/packages;$(fc_PATH)/packages;$(MCFW_ROOT_PATH);$(syslink_PATH)/packages;$(xdais_PATH)/packages;$(edma3lld_PATH)/packages
# All EXPORT symbols are defined here
export OS
export PLATFORM
export CORE
export PROFILE_m3vpss
export PROFILE_m3video
export PROFILE_c6xdsp
export CODEGEN_PATH_M3
export CODEGEN_PATH_A8
export CODEGEN_PATH_DSP
export ROOTDIR
export bios_PATH
export xdc_PATH
export iss_PATH
export hdvpss_PATH
export ipc_PATH
export fc_PATH
export xdais_PATH
export h264dec_PATH
export h264enc_PATH
export jpegenc_PATH
export jpegdec_PATH
export hdvicplib_PATH
export linuxdevkit_PATH
export edma3lld_PATH
export XDCPATH
export KW_BUILD
export syslink_PATH
export KERNELDIR
export TARGET_FS
export TARGET_MCFW_DIR
export ROOT_FILE_SYS
export MCFW_ROOT_PATH
export UBOOTDIR
export DVR_RDK_BOARD_TYPE
export DEST_ROOT
export IPNC_INSTALL_DIR
export TFTP_HOME
export LINUX_MEM
export BUILD_TOOL_DIR
export BUILD_TOOL_PREFIX
export IPNC_DIR
export PUBLIC_INCLUDE_DIR
export APP_LIB_DIR
export EXEC_DIR
export syslink_INCLUDE
export syslink_LIB_DIR
export ipc_INCLUDE
export linuxutils_PATH
export IPNC_CONFIG
export POWER_OPT_DSP_OFF
export POWER_OPT_DSS_OFF
export IMGS_ID
export OSD_MODE
export TREAT_WARNINGS_AS_ERROR
export SC_SCRIPTS_BASE_DIR
export CMEM_LIB_DIR
export CMEM_INC_DIR
export mpeg4enc_PATH
export mpeg4dec_PATH
export CAPTURE_DISPLAY_MODE_ON
export FRAMES_TO_A8
export MEMORY_256MB
export IPNC_TILER_ENABLE
export BTE_ENABLE
export IPNC_DEVICE
export TARGET_FS_DIR
export USE_A8_FOR_TC_CALC
export USE_ISS_BOXCAR
export TEARDOWN_LOAD_UNLOAD
export SENSOR_DATA_OP
export ENC_A8_DEC_USE_CASE
export LOW_POWER_30FPS_MODE
export QUAD_STREAM_NF_USE_CASE
export CAPTURE_MODE
export MJPEG_RC_MODE
Can anyone help?
Thank you.
Justin
