DM365: ARM Load 100%!!! / Nand flash (jffs / jffs2 / yaffs...)
Other Parts Discussed in Thread: PCA9543A, TSC2004, THS7303, TVP5146, TVP7002, THS7353, DM3730
Hi all,
I flashed the nand flash (MTD3) with jffs2 file system.
Now the system is very slowly.
and when I tried to recording video:
root@dm365-evm:/usr/share/ti/dvsdk-demos# ./encode -I1 -y2 -vtest.264
I get 100% ARM load!
ARM Load: 62% Video fps: 25 fps Video bit rate: 1263 kbps Sound bit rate: 0 kbps Time: 00:00:04 Demo: Encode Display: D1 PAL Video Codec: H.264 HP Resolution: 736x576 Sound Codec: N/A Sampling Freq: N/A
ARM Load: 90% Video fps: 25 fps Video bit rate: 1175 kbps Sound bit rate: 0 kbps Time: 00:00:06 Demo: Encode Display: D1 PAL Video Codec: H.264 HP Resolution: 736x576 Sound Codec: N/A Sampling Freq: N/A
ARM Load: 100% Video fps: 6 fps Video bit rate: 59 kbps Sound bit rate: 0 kbps Time: 00:00:07 Demo: Encode Display: D1 PAL Video Codec: H.264 HP Resolution: 736x576 Sound Codec: N/A Sampling Freq: N/A
What's wrong?
Please see the boot log:
Jumping to entry point at 0x81080000.
LSP 2.10 BETA RELEASE
VERSION: 2.10.008.02
U-Boot 1.3.4 (Mar 2 2009 - 11:50:39)
I2C: ready
DRAM: 128 MB
NAND: NAND device: Manufacturer ID: 0x2c, Chip ID: 0xd3 (Micron NAND 1GiB 3,3V 8-bit)
Bad block table not found for chip 0
Bad block table written to 0x3ffe0000, version 0x01
Bad block table written to 0x3ffc0000, version 0x01
2048 MiB
In: serial
Out: serial
Err: serial
Ethernet PHY: GENERIC @ 0x00
Hit any key to stop autoboot: 4 0
DM365 EVM :>setenv bootcmd 'nboot 0x80700000 0 0x400000;bootm'
DM365 EVM :>setenv bootargs console=ttyS0,115200n8 ip=dhcp root=/dev/mtdblock3 rw rootfstype=jffs2 mem=54M video=davincifb:vid0=OFF:vid1=OFF:osd0=720x576x16,4050K dm365_imp.oper_mode=0 davinci_capture.device_type=1 vpfe_capture.cont_bufsize=6291456 davinci_enc_mngr.ch0_output=COMPOSITE davinci_enc_mngr.ch0_mode=PAL
DM365 EVM :>boot
Loading from NAND 1GiB 3,3V 8-bit, offset 0x400000
Image Name: Arago/2.6.32.17-psp03.01.01.39/d
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 2148060 Bytes = 2 MB
Load Address: 80008000
Entry Point: 80008000
## Booting kernel from Legacy Image at 80700000 ...
Verifying Checksum ... OK
Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux............................................................................................................................................ done, booting the kernel.
Linux version 2.6.32.17-davinci1 (sdk@nemo) (gcc version 4.3.3 (Sourcery G++ Lite 2009q1-203) ) #1 PREEMPT Thu Mar 24 19:30:24 CDT 2011
CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=00053177
CPU: VIVT data cache, VIVT instruction cache
Machine: DaVinci DM36x EVM
Memory policy: ECC disabled, Data cache writeback
DaVinci dm36x_rev1.2 variant 0x8
Built 1 zonelists in Zone order, mobility grouping off. Total pages: 13716
Kernel command line: console=ttyS0,115200n8 ip=dhcp root=/dev/mtdblock3 rw rootfstype=jffs2 mem=54M video=davincifb:vid0=OFF:vid1=OFF:osd0=720x576x16,4050K dm365_imp.oper_mode=0 davinci_capture.device_type=1 vpfe_capture.cont_bufsize=6291456 davinci_enc_mngr.ch0_output=COMPOSITE davinci_enc_mngr.ch0_mode=PAL
PID hash table entries: 256 (order: -2, 1024 bytes)
Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
Memory: 54MB = 54MB total
Memory: 50076KB available (4024K code, 393K data, 144K init, 0K highmem)
SLUB: Genslabs=11, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Hierarchical RCU implementation.
NR_IRQS:245
Console: colour dummy device 80x30
Calibrating delay loop... 147.86 BogoMIPS (lpj=739328)
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
DaVinci: 8 gpio irqs
NET: Registered protocol family 16
davinci_serial_init:97: failed to get UART2 clock
EVM: HD imager video input
bio: create slab <bio-0> at 0
DM365 IPIPE initialized in Continuous mode
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
pca9543a_probe
vpss vpss: dm365_vpss vpss probed
vpss vpss: dm365_vpss vpss probe success
dm365_afew_hw_init
ch0 default output "COMPOSITE", mode "PAL"
VPBE Encoder Initialized
cfg80211: Using static regulatory domain info
cfg80211: Regulatory domain: US
(start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
(2402000 KHz - 2472000 KHz @ 40000 KHz), (600 mBi, 2700 mBm)
(5170000 KHz - 5190000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
(5190000 KHz - 5210000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
(5210000 KHz - 5230000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
(5230000 KHz - 5330000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
(5735000 KHz - 5835000 KHz @ 40000 KHz), (600 mBi, 3000 mBm)
cfg80211: Calling CRDA for country: US
LogicPD encoder initialized
Switching to clocksource timer0_1
musb_hdrc: version 6.0, cppi-dma, host, debug=0
musb_hdrc: USB Host mode controller at fec64000 using DMA, IRQ 12
musb_hdrc musb_hdrc: MUSB HDRC host driver
musb_hdrc musb_hdrc: new USB bus registered, assigned bus number 1
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 2048 (order: 2, 16384 bytes)
TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
TCP: Hash tables configured (established 2048 bind 2048)
TCP reno registered
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
msgmni has been set to 97
alg: No test for stdrng (krng)
io scheduler noop registered
io scheduler anticipatory registered (default)
Console: switching to colour frame buffer device 90x36
davincifb davincifb.0: dm_osd0_fb: 720x576x16@0,0 with framebuffer size 4050KB
davincifb davincifb.0: dm_vid0_fb: 0x0x16@0,0 with framebuffer size 1224KB
davincifb davincifb.0: dm_osd1_fb: 720x576x4@0,0 with framebuffer size 810KB
davincifb davincifb.0: dm_vid1_fb: 0x0x16@0,0 with framebuffer size 1224KB
DM365 IPIPEIF probed
imp serializer initialized
davinci_previewer initialized
davinci_resizer initialized
Serial: 8250/16550 driver, 2 ports, IRQ sharing disabled
serial8250.0: ttyS0 at MMIO 0x1c20000 (irq = 40) is a 16550A
console [ttyS0] enabled
brd: module loaded
at24 1-0050: 32768 byte 24c256 EEPROM (writable)
Read MAC addr from EEPROM: 00:0e:99:02:cf:54
2 NAND chips detected
Bad block table not found for chip 1
Scanning device for bad blocks
Bad eraseblock 27 at 0x000000360000
Bad eraseblock 28 at 0x000000380000
Bad eraseblock 32 at 0x000000400000
Bad eraseblock 33 at 0x000000420000
Bad eraseblock 34 at 0x000000440000
Bad eraseblock 35 at 0x000000460000
Bad eraseblock 36 at 0x000000480000
Bad eraseblock 37 at 0x0000004a0000
Bad eraseblock 38 at 0x0000004c0000
Bad eraseblock 39 at 0x0000004e0000
Bad eraseblock 40 at 0x000000500000
Bad eraseblock 41 at 0x000000520000
Bad eraseblock 42 at 0x000000540000
Bad eraseblock 43 at 0x000000560000
Bad eraseblock 44 at 0x000000580000
Bad eraseblock 45 at 0x0000005a0000
Bad eraseblock 46 at 0x0000005c0000
Bad eraseblock 47 at 0x0000005e0000
Bad eraseblock 48 at 0x000000600000
Bad eraseblock 62 at 0x0000007c0000
Bad eraseblock 64 at 0x000000800000
Bad eraseblock 65 at 0x000000820000
Bad eraseblock 66 at 0x000000840000
Bad eraseblock 67 at 0x000000860000
Bad eraseblock 68 at 0x000000880000
Bad eraseblock 69 at 0x0000008a0000
Bad eraseblock 70 at 0x0000008c0000
Bad eraseblock 71 at 0x0000008e0000
Bad eraseblock 72 at 0x000000900000
Bad eraseblock 73 at 0x000000920000
Bad eraseblock 74 at 0x000000940000
Bad eraseblock 75 at 0x000000960000
Bad eraseblock 76 at 0x000000980000
Bad eraseblock 77 at 0x0000009a0000
Bad eraseblock 78 at 0x0000009c0000
Bad eraseblock 79 at 0x0000009e0000
Bad eraseblock 80 at 0x000000a00000
Bad eraseblock 81 at 0x000000a20000
Bad eraseblock 82 at 0x000000a40000
Bad eraseblock 83 at 0x000000a60000
Bad eraseblock 84 at 0x000000a80000
Bad eraseblock 85 at 0x000000aa0000
Bad eraseblock 86 at 0x000000ac0000
Bad eraseblock 87 at 0x000000ae0000
Bad eraseblock 88 at 0x000000b00000
Bad eraseblock 89 at 0x000000b20000
Bad eraseblock 90 at 0x000000b40000
Bad eraseblock 91 at 0x000000b60000
Bad eraseblock 92 at 0x000000b80000
Bad eraseblock 93 at 0x000000ba0000
Bad eraseblock 94 at 0x000000bc0000
Bad eraseblock 95 at 0x000000be0000
Bad eraseblock 96 at 0x000000c00000
Bad eraseblock 97 at 0x000000c20000
Bad eraseblock 98 at 0x000000c40000
Bad eraseblock 99 at 0x000000c60000
Bad eraseblock 100 at 0x000000c80000
Bad eraseblock 101 at 0x000000ca0000
Bad eraseblock 102 at 0x000000cc0000
Bad eraseblock 103 at 0x000000ce0000
Bad eraseblock 104 at 0x000000d00000
Bad eraseblock 105 at 0x000000d20000
Bad eraseblock 106 at 0x000000d40000
Bad eraseblock 107 at 0x000000d60000
Bad eraseblock 108 at 0x000000d80000
Bad eraseblock 109 at 0x000000da0000
Bad eraseblock 110 at 0x000000dc0000
Bad eraseblock 111 at 0x000000de0000
Bad eraseblock 112 at 0x000000e00000
Bad eraseblock 113 at 0x000000e20000
Bad eraseblock 114 at 0x000000e40000
Bad eraseblock 115 at 0x000000e60000
Bad eraseblock 116 at 0x000000e80000
Bad eraseblock 117 at 0x000000ea0000
Bad eraseblock 118 at 0x000000ec0000
Bad eraseblock 119 at 0x000000ee0000
Bad eraseblock 120 at 0x000000f00000
Bad eraseblock 121 at 0x000000f20000
Bad eraseblock 122 at 0x000000f40000
Bad eraseblock 123 at 0x000000f60000
Bad eraseblock 124 at 0x000000f80000
Bad eraseblock 125 at 0x000000fa0000
Bad eraseblock 126 at 0x000000fc0000
Bad eraseblock 127 at 0x000000fe0000
Bad eraseblock 128 at 0x000001000000
Bad eraseblock 129 at 0x000001020000
Bad eraseblock 130 at 0x000001040000
Bad eraseblock 131 at 0x000001060000
Bad eraseblock 132 at 0x000001080000
Bad eraseblock 133 at 0x0000010a0000
Bad eraseblock 134 at 0x0000010c0000
Bad eraseblock 135 at 0x0000010e0000
Bad eraseblock 136 at 0x000001100000
Bad eraseblock 137 at 0x000001120000
Bad eraseblock 138 at 0x000001140000
Bad eraseblock 139 at 0x000001160000
Bad eraseblock 140 at 0x000001180000
Bad eraseblock 141 at 0x0000011a0000
Bad eraseblock 142 at 0x0000011c0000
Bad eraseblock 143 at 0x0000011e0000
Bad eraseblock 144 at 0x000001200000
Bad eraseblock 145 at 0x000001220000
Bad eraseblock 146 at 0x000001240000
Bad eraseblock 147 at 0x000001260000
Bad eraseblock 148 at 0x000001280000
Bad eraseblock 149 at 0x0000012a0000
Bad eraseblock 150 at 0x0000012c0000
Bad eraseblock 151 at 0x0000012e0000
Bad eraseblock 152 at 0x000001300000
Bad eraseblock 153 at 0x000001320000
Bad eraseblock 154 at 0x000001340000
Bad eraseblock 155 at 0x000001360000
Bad eraseblock 156 at 0x000001380000
Bad eraseblock 157 at 0x0000013a0000
Bad eraseblock 158 at 0x0000013c0000
Bad eraseblock 159 at 0x0000013e0000
Bad eraseblock 160 at 0x000001400000
Bad eraseblock 161 at 0x000001420000
Bad eraseblock 162 at 0x000001440000
Bad eraseblock 163 at 0x000001460000
Bad eraseblock 164 at 0x000001480000
Bad eraseblock 165 at 0x0000014a0000
Bad eraseblock 166 at 0x0000014c0000
Bad eraseblock 167 at 0x0000014e0000
Bad eraseblock 168 at 0x000001500000
Bad eraseblock 169 at 0x000001520000
Bad eraseblock 170 at 0x000001540000
Bad eraseblock 171 at 0x000001560000
Bad eraseblock 172 at 0x000001580000
Bad eraseblock 173 at 0x0000015a0000
Bad eraseblock 174 at 0x0000015c0000
Bad eraseblock 175 at 0x0000015e0000
Bad eraseblock 176 at 0x000001600000
Bad eraseblock 177 at 0x000001620000
Bad eraseblock 178 at 0x000001640000
Bad eraseblock 179 at 0x000001660000
Bad eraseblock 180 at 0x000001680000
Bad eraseblock 181 at 0x0000016a0000
Bad eraseblock 182 at 0x0000016c0000
Bad eraseblock 183 at 0x0000016e0000
Bad eraseblock 184 at 0x000001700000
Bad eraseblock 185 at 0x000001720000
Bad eraseblock 186 at 0x000001740000
Bad eraseblock 187 at 0x000001760000
Bad eraseblock 188 at 0x000001780000
Bad eraseblock 189 at 0x0000017a0000
Bad eraseblock 190 at 0x0000017c0000
Bad eraseblock 191 at 0x0000017e0000
Bad eraseblock 192 at 0x000001800000
Bad eraseblock 193 at 0x000001820000
Bad eraseblock 194 at 0x000001840000
Bad eraseblock 195 at 0x000001860000
Bad eraseblock 196 at 0x000001880000
Bad eraseblock 197 at 0x0000018a0000
Bad eraseblock 198 at 0x0000018c0000
Bad eraseblock 199 at 0x0000018e0000
Bad eraseblock 200 at 0x000001900000
Bad eraseblock 201 at 0x000001920000
Bad eraseblock 202 at 0x000001940000
Bad eraseblock 203 at 0x000001960000
Bad eraseblock 204 at 0x000001980000
Bad eraseblock 205 at 0x0000019a0000
Bad eraseblock 206 at 0x0000019c0000
Bad eraseblock 207 at 0x0000019e0000
Bad eraseblock 208 at 0x000001a00000
Bad eraseblock 209 at 0x000001a20000
Bad eraseblock 210 at 0x000001a40000
Bad eraseblock 211 at 0x000001a60000
Bad eraseblock 212 at 0x000001a80000
Bad eraseblock 213 at 0x000001aa0000
Bad eraseblock 214 at 0x000001ac0000
Bad eraseblock 215 at 0x000001ae0000
Bad eraseblock 216 at 0x000001b00000
Bad eraseblock 217 at 0x000001b20000
Bad eraseblock 218 at 0x000001b40000
Bad eraseblock 219 at 0x000001b60000
Bad eraseblock 220 at 0x000001b80000
Bad eraseblock 221 at 0x000001ba0000
Bad eraseblock 222 at 0x000001bc0000
Bad eraseblock 223 at 0x000001be0000
Bad eraseblock 224 at 0x000001c00000
Bad eraseblock 225 at 0x000001c20000
Bad eraseblock 226 at 0x000001c40000
Bad eraseblock 227 at 0x000001c60000
Bad eraseblock 228 at 0x000001c80000
Bad eraseblock 229 at 0x000001ca0000
Bad eraseblock 230 at 0x000001cc0000
Bad eraseblock 231 at 0x000001ce0000
Bad eraseblock 232 at 0x000001d00000
Bad eraseblock 233 at 0x000001d20000
Bad eraseblock 234 at 0x000001d40000
Bad eraseblock 235 at 0x000001d60000
Bad eraseblock 236 at 0x000001d80000
Bad eraseblock 237 at 0x000001da0000
Bad eraseblock 238 at 0x000001dc0000
Bad eraseblock 239 at 0x000001de0000
Bad eraseblock 240 at 0x000001e00000
Bad eraseblock 241 at 0x000001e20000
Bad eraseblock 242 at 0x000001e40000
Bad eraseblock 243 at 0x000001e60000
Bad eraseblock 244 at 0x000001e80000
Bad eraseblock 245 at 0x000001ea0000
Bad eraseblock 246 at 0x000001ec0000
Bad eraseblock 247 at 0x000001ee0000
Bad eraseblock 248 at 0x000001f00000
Bad eraseblock 249 at 0x000001f20000
Bad eraseblock 250 at 0x000001f40000
Bad eraseblock 251 at 0x000001f60000
Bad eraseblock 252 at 0x000001f80000
Bad eraseblock 253 at 0x000001fa0000
Bad eraseblock 254 at 0x000001fc0000
Bad eraseblock 255 at 0x000001fe0000
Bad eraseblock 256 at 0x000002000000
Bad eraseblock 257 at 0x000002020000
Bad eraseblock 258 at 0x000002040000
Bad eraseblock 259 at 0x000002060000
Bad eraseblock 260 at 0x000002080000
Bad eraseblock 261 at 0x0000020a0000
Bad eraseblock 262 at 0x0000020c0000
Bad eraseblock 263 at 0x0000020e0000
Bad eraseblock 264 at 0x000002100000
Bad eraseblock 265 at 0x000002120000
Bad eraseblock 266 at 0x000002140000
Bad eraseblock 267 at 0x000002160000
Bad eraseblock 268 at 0x000002180000
Bad eraseblock 269 at 0x0000021a0000
Bad eraseblock 270 at 0x0000021c0000
Bad eraseblock 271 at 0x0000021e0000
Bad eraseblock 272 at 0x000002200000
Bad eraseblock 273 at 0x000002220000
Bad eraseblock 274 at 0x000002240000
Bad eraseblock 275 at 0x000002260000
Bad eraseblock 276 at 0x000002280000
Bad eraseblock 277 at 0x0000022a0000
Bad eraseblock 278 at 0x0000022c0000
Bad eraseblock 279 at 0x0000022e0000
Bad eraseblock 280 at 0x000002300000
Bad eraseblock 281 at 0x000002320000
Bad eraseblock 282 at 0x000002340000
Bad eraseblock 283 at 0x000002360000
Bad eraseblock 284 at 0x000002380000
Bad eraseblock 285 at 0x0000023a0000
Bad eraseblock 286 at 0x0000023c0000
Bad eraseblock 287 at 0x0000023e0000
Bad eraseblock 288 at 0x000002400000
Bad eraseblock 289 at 0x000002420000
Bad eraseblock 290 at 0x000002440000
Bad eraseblock 291 at 0x000002460000
Bad eraseblock 292 at 0x000002480000
Bad eraseblock 293 at 0x0000024a0000
Bad eraseblock 294 at 0x0000024c0000
Bad eraseblock 295 at 0x0000024e0000
Bad eraseblock 296 at 0x000002500000
Bad eraseblock 297 at 0x000002520000
Bad eraseblock 298 at 0x000002540000
Bad eraseblock 299 at 0x000002560000
Bad eraseblock 300 at 0x000002580000
Bad eraseblock 301 at 0x0000025a0000
Bad eraseblock 302 at 0x0000025c0000
Bad eraseblock 303 at 0x0000025e0000
Bad eraseblock 304 at 0x000002600000
Bad eraseblock 305 at 0x000002620000
Bad eraseblock 306 at 0x000002640000
Bad eraseblock 307 at 0x000002660000
Bad eraseblock 308 at 0x000002680000
Bad eraseblock 309 at 0x0000026a0000
Bad eraseblock 310 at 0x0000026c0000
Bad eraseblock 311 at 0x0000026e0000
Bad eraseblock 312 at 0x000002700000
Bad eraseblock 313 at 0x000002720000
Bad eraseblock 314 at 0x000002740000
Bad eraseblock 315 at 0x000002760000
Bad eraseblock 316 at 0x000002780000
Bad eraseblock 317 at 0x0000027a0000
Bad eraseblock 318 at 0x0000027c0000
Bad eraseblock 319 at 0x0000027e0000
Bad eraseblock 320 at 0x000002800000
Bad eraseblock 321 at 0x000002820000
Bad eraseblock 322 at 0x000002840000
Bad eraseblock 323 at 0x000002860000
Bad eraseblock 324 at 0x000002880000
Bad eraseblock 325 at 0x0000028a0000
Bad eraseblock 326 at 0x0000028c0000
Bad eraseblock 327 at 0x0000028e0000
Bad eraseblock 328 at 0x000002900000
Bad eraseblock 329 at 0x000002920000
Bad eraseblock 330 at 0x000002940000
Bad eraseblock 331 at 0x000002960000
Bad eraseblock 332 at 0x000002980000
Bad eraseblock 333 at 0x0000029a0000
Bad eraseblock 334 at 0x0000029c0000
Bad eraseblock 335 at 0x0000029e0000
Bad eraseblock 336 at 0x000002a00000
Bad eraseblock 337 at 0x000002a20000
Bad eraseblock 338 at 0x000002a40000
Bad eraseblock 339 at 0x000002a60000
Bad eraseblock 340 at 0x000002a80000
Bad eraseblock 341 at 0x000002aa0000
Bad eraseblock 342 at 0x000002ac0000
Bad eraseblock 343 at 0x000002ae0000
Bad eraseblock 344 at 0x000002b00000
Bad eraseblock 345 at 0x000002b20000
Bad eraseblock 346 at 0x000002b40000
Bad eraseblock 347 at 0x000002b60000
Bad eraseblock 348 at 0x000002b80000
Bad eraseblock 349 at 0x000002ba0000
Bad eraseblock 350 at 0x000002bc0000
Bad eraseblock 351 at 0x000002be0000
Bad eraseblock 352 at 0x000002c00000
Bad eraseblock 353 at 0x000002c20000
Bad eraseblock 354 at 0x000002c40000
Bad eraseblock 355 at 0x000002c60000
Bad eraseblock 356 at 0x000002c80000
Bad eraseblock 357 at 0x000002ca0000
Bad eraseblock 358 at 0x000002cc0000
Bad eraseblock 359 at 0x000002ce0000
Bad eraseblock 360 at 0x000002d00000
Bad eraseblock 361 at 0x000002d20000
Bad eraseblock 362 at 0x000002d40000
Bad eraseblock 363 at 0x000002d60000
Bad eraseblock 364 at 0x000002d80000
Bad eraseblock 365 at 0x000002da0000
Bad eraseblock 366 at 0x000002dc0000
Bad eraseblock 367 at 0x000002de0000
Bad eraseblock 368 at 0x000002e00000
Bad eraseblock 369 at 0x000002e20000
Bad eraseblock 370 at 0x000002e40000
Bad eraseblock 371 at 0x000002e60000
Bad eraseblock 372 at 0x000002e80000
Bad eraseblock 373 at 0x000002ea0000
Bad eraseblock 374 at 0x000002ec0000
Bad eraseblock 375 at 0x000002ee0000
Bad eraseblock 376 at 0x000002f00000
Bad eraseblock 377 at 0x000002f20000
Bad eraseblock 378 at 0x000002f40000
Bad eraseblock 379 at 0x000002f60000
Bad eraseblock 380 at 0x000002f80000
Bad eraseblock 381 at 0x000002fa0000
Bad eraseblock 382 at 0x000002fc0000
Bad eraseblock 383 at 0x000002fe0000
Bad eraseblock 384 at 0x000003000000
Bad eraseblock 385 at 0x000003020000
Bad eraseblock 386 at 0x000003040000
Bad eraseblock 387 at 0x000003060000
Bad eraseblock 388 at 0x000003080000
Bad eraseblock 389 at 0x0000030a0000
Bad eraseblock 390 at 0x0000030c0000
Bad eraseblock 391 at 0x0000030e0000
Bad eraseblock 392 at 0x000003100000
Bad eraseblock 393 at 0x000003120000
Bad eraseblock 394 at 0x000003140000
Bad eraseblock 395 at 0x000003160000
Bad eraseblock 396 at 0x000003180000
Bad eraseblock 397 at 0x0000031a0000
Bad eraseblock 398 at 0x0000031c0000
Bad eraseblock 399 at 0x0000031e0000
Bad eraseblock 400 at 0x000003200000
Bad eraseblock 401 at 0x000003220000
Bad eraseblock 402 at 0x000003240000
Bad eraseblock 403 at 0x000003260000
Bad eraseblock 404 at 0x000003280000
Bad eraseblock 405 at 0x0000032a0000
Bad eraseblock 406 at 0x0000032c0000
Bad eraseblock 407 at 0x0000032e0000
Bad eraseblock 408 at 0x000003300000
Bad eraseblock 409 at 0x000003320000
Bad eraseblock 410 at 0x000003340000
Bad eraseblock 411 at 0x000003360000
Bad eraseblock 412 at 0x000003380000
Bad eraseblock 413 at 0x0000033a0000
Bad eraseblock 414 at 0x0000033c0000
Bad eraseblock 415 at 0x0000033e0000
Bad eraseblock 416 at 0x000003400000
Bad eraseblock 417 at 0x000003420000
Bad eraseblock 418 at 0x000003440000
Bad eraseblock 419 at 0x000003460000
Bad eraseblock 420 at 0x000003480000
Bad eraseblock 421 at 0x0000034a0000
Bad eraseblock 422 at 0x0000034c0000
Bad eraseblock 423 at 0x0000034e0000
Bad eraseblock 424 at 0x000003500000
Bad eraseblock 425 at 0x000003520000
Bad eraseblock 426 at 0x000003540000
Bad eraseblock 427 at 0x000003560000
Bad eraseblock 428 at 0x000003580000
Bad eraseblock 429 at 0x0000035a0000
Bad eraseblock 430 at 0x0000035c0000
Bad eraseblock 431 at 0x0000035e0000
Bad eraseblock 432 at 0x000003600000
Bad eraseblock 433 at 0x000003620000
Bad eraseblock 434 at 0x000003640000
Bad eraseblock 435 at 0x000003660000
Bad eraseblock 436 at 0x000003680000
Bad eraseblock 437 at 0x0000036a0000
Bad eraseblock 438 at 0x0000036c0000
Bad eraseblock 439 at 0x0000036e0000
Bad eraseblock 440 at 0x000003700000
Bad eraseblock 441 at 0x000003720000
Bad eraseblock 442 at 0x000003740000
Bad eraseblock 443 at 0x000003760000
Bad eraseblock 444 at 0x000003780000
Bad eraseblock 445 at 0x0000037a0000
Bad eraseblock 446 at 0x0000037c0000
Bad eraseblock 447 at 0x0000037e0000
Bad eraseblock 448 at 0x000003800000
Bad eraseblock 449 at 0x000003820000
Bad eraseblock 450 at 0x000003840000
Bad eraseblock 451 at 0x000003860000
Bad eraseblock 452 at 0x000003880000
Bad eraseblock 453 at 0x0000038a0000
Bad eraseblock 454 at 0x0000038c0000
Bad eraseblock 455 at 0x0000038e0000
Bad eraseblock 456 at 0x000003900000
Bad eraseblock 457 at 0x000003920000
Bad eraseblock 458 at 0x000003940000
Bad eraseblock 459 at 0x000003960000
Bad eraseblock 460 at 0x000003980000
Bad eraseblock 461 at 0x0000039a0000
Bad eraseblock 462 at 0x0000039c0000
Bad eraseblock 463 at 0x0000039e0000
Bad eraseblock 464 at 0x000003a00000
Bad eraseblock 465 at 0x000003a20000
Bad eraseblock 466 at 0x000003a40000
Bad eraseblock 467 at 0x000003a60000
Bad eraseblock 468 at 0x000003a80000
Bad eraseblock 469 at 0x000003aa0000
Bad eraseblock 470 at 0x000003ac0000
Bad eraseblock 471 at 0x000003ae0000
Bad eraseblock 472 at 0x000003b00000
Bad eraseblock 473 at 0x000003b20000
Bad eraseblock 474 at 0x000003b40000
Bad eraseblock 475 at 0x000003b60000
Bad eraseblock 476 at 0x000003b80000
Bad eraseblock 477 at 0x000003ba0000
Bad eraseblock 478 at 0x000003bc0000
Bad eraseblock 479 at 0x000003be0000
Bad eraseblock 480 at 0x000003c00000
Bad eraseblock 481 at 0x000003c20000
Bad eraseblock 482 at 0x000003c40000
Bad eraseblock 483 at 0x000003c60000
Bad eraseblock 484 at 0x000003c80000
Bad eraseblock 485 at 0x000003ca0000
Bad eraseblock 486 at 0x000003cc0000
Bad eraseblock 487 at 0x000003ce0000
Bad eraseblock 488 at 0x000003d00000
Bad eraseblock 489 at 0x000003d20000
Bad eraseblock 490 at 0x000003d40000
Bad eraseblock 491 at 0x000003d60000
Bad eraseblock 492 at 0x000003d80000
Bad eraseblock 493 at 0x000003da0000
Bad eraseblock 494 at 0x000003dc0000
Bad eraseblock 495 at 0x000003de0000
Bad eraseblock 496 at 0x000003e00000
Bad eraseblock 497 at 0x000003e20000
Bad eraseblock 498 at 0x000003e40000
Bad eraseblock 499 at 0x000003e60000
Bad eraseblock 500 at 0x000003e80000
Bad eraseblock 501 at 0x000003ea0000
Bad eraseblock 502 at 0x000003ec0000
Bad eraseblock 503 at 0x000003ee0000
Bad eraseblock 504 at 0x000003f00000
Bad eraseblock 505 at 0x000003f20000
Bad eraseblock 506 at 0x000003f40000
Bad eraseblock 507 at 0x000003f60000
Bad eraseblock 508 at 0x000003f80000
Bad eraseblock 509 at 0x000003fa0000
Bad eraseblock 510 at 0x000003fc0000
Bad eraseblock 511 at 0x000003fe0000
Bad eraseblock 512 at 0x000004000000
Bad eraseblock 513 at 0x000004020000
Bad eraseblock 514 at 0x000004040000
Bad eraseblock 515 at 0x000004060000
Bad eraseblock 516 at 0x000004080000
Bad eraseblock 517 at 0x0000040a0000
Bad eraseblock 518 at 0x0000040c0000
Bad eraseblock 519 at 0x0000040e0000
Bad eraseblock 520 at 0x000004100000
Bad eraseblock 521 at 0x000004120000
Bad eraseblock 522 at 0x000004140000
Bad eraseblock 523 at 0x000004160000
Bad eraseblock 524 at 0x000004180000
Bad eraseblock 525 at 0x0000041a0000
Bad eraseblock 526 at 0x0000041c0000
Bad eraseblock 527 at 0x0000041e0000
Bad eraseblock 528 at 0x000004200000
Bad eraseblock 529 at 0x000004220000
Bad eraseblock 530 at 0x000004240000
Bad eraseblock 531 at 0x000004260000
Bad eraseblock 532 at 0x000004280000
Bad eraseblock 533 at 0x0000042a0000
Bad eraseblock 534 at 0x0000042c0000
Bad eraseblock 535 at 0x0000042e0000
Bad eraseblock 536 at 0x000004300000
Bad eraseblock 537 at 0x000004320000
Bad eraseblock 538 at 0x000004340000
Bad eraseblock 539 at 0x000004360000
Bad eraseblock 540 at 0x000004380000
Bad eraseblock 541 at 0x0000043a0000
Bad eraseblock 542 at 0x0000043c0000
Bad eraseblock 543 at 0x0000043e0000
Bad eraseblock 544 at 0x000004400000
Bad eraseblock 545 at 0x000004420000
Bad eraseblock 546 at 0x000004440000
Bad eraseblock 547 at 0x000004460000
Bad eraseblock 548 at 0x000004480000
Bad eraseblock 549 at 0x0000044a0000
Bad eraseblock 550 at 0x0000044c0000
Bad eraseblock 551 at 0x0000044e0000
Bad eraseblock 552 at 0x000004500000
Bad eraseblock 553 at 0x000004520000
Bad eraseblock 554 at 0x000004540000
Bad eraseblock 555 at 0x000004560000
Bad eraseblock 556 at 0x000004580000
Bad eraseblock 557 at 0x0000045a0000
Bad eraseblock 558 at 0x0000045c0000
Bad eraseblock 559 at 0x0000045e0000
Bad eraseblock 560 at 0x000004600000
Bad eraseblock 561 at 0x000004620000
Bad eraseblock 562 at 0x000004640000
Bad eraseblock 563 at 0x000004660000
Bad eraseblock 564 at 0x000004680000
Bad eraseblock 565 at 0x0000046a0000
Bad eraseblock 566 at 0x0000046c0000
Bad eraseblock 567 at 0x0000046e0000
Bad eraseblock 568 at 0x000004700000
Bad eraseblock 569 at 0x000004720000
Bad eraseblock 570 at 0x000004740000
Bad eraseblock 571 at 0x000004760000
Bad eraseblock 572 at 0x000004780000
Bad eraseblock 573 at 0x0000047a0000
Bad eraseblock 574 at 0x0000047c0000
Bad eraseblock 575 at 0x0000047e0000
Bad eraseblock 576 at 0x000004800000
Bad eraseblock 577 at 0x000004820000
Bad eraseblock 578 at 0x000004840000
Bad eraseblock 579 at 0x000004860000
Bad eraseblock 580 at 0x000004880000
Bad eraseblock 581 at 0x0000048a0000
Bad eraseblock 582 at 0x0000048c0000
Bad eraseblock 583 at 0x0000048e0000
Bad eraseblock 584 at 0x000004900000
Bad eraseblock 585 at 0x000004920000
Bad eraseblock 586 at 0x000004940000
Bad eraseblock 587 at 0x000004960000
Bad eraseblock 588 at 0x000004980000
Bad eraseblock 589 at 0x0000049a0000
Bad eraseblock 590 at 0x0000049c0000
Bad eraseblock 591 at 0x0000049e0000
Bad eraseblock 592 at 0x000004a00000
Bad eraseblock 593 at 0x000004a20000
Bad eraseblock 594 at 0x000004a40000
Bad eraseblock 595 at 0x000004a60000
Bad eraseblock 596 at 0x000004a80000
Bad eraseblock 597 at 0x000004aa0000
Bad eraseblock 598 at 0x000004ac0000
Bad eraseblock 599 at 0x000004ae0000
Bad eraseblock 600 at 0x000004b00000
Bad eraseblock 601 at 0x000004b20000
Bad eraseblock 602 at 0x000004b40000
Bad eraseblock 603 at 0x000004b60000
Bad eraseblock 604 at 0x000004b80000
Bad eraseblock 605 at 0x000004ba0000
Bad eraseblock 606 at 0x000004bc0000
Bad eraseblock 1072 at 0x000008600000
Bad eraseblock 2596 at 0x000014480000
Bad eraseblock 2777 at 0x000015b20000
Bad eraseblock 4340 at 0x000021e80000
Bad eraseblock 4911 at 0x0000265e0000
Bad eraseblock 5368 at 0x000029f00000
Bad eraseblock 6068 at 0x00002f680000
Bad eraseblock 7649 at 0x00003bc20000
Bad eraseblock 7718 at 0x00003c4c0000
Bad eraseblock 11350 at 0x000058ac0000
Bad eraseblock 12814 at 0x0000641c0000
Bad eraseblock 14945 at 0x000074c20000
Creating 5 MTD partitions on "davinci_nand.0":
0x000000000000-0x000000f00000 : "bootloader"
0x000000f00000-0x000001000000 : "params"
0x000001000000-0x000001400000 : "kernel"
0x000001400000-0x000021400000 : "filesystem1"
0x000021400000-0x000080000000 : "filesystem2"
davinci_nand davinci_nand.0: controller rev. 2.3
spi_davinci spi_davinci.0: DaVinci SPI driver in EDMA mode
Using RX channel = 17 , TX channel = 16 and event queue = 3
at25 spi0.0: 8 KByte at25640 eeprom, pagesize 32
spi_davinci spi_davinci.0: Controller at 0xfec66000
console [netcon0] enabled
netconsole: network logging started
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
usbcore: registered new interface driver usbtest
mice: PS/2 mouse device common for all mice
tsc2004: probe of 1-0049 failed with error -121
input: DM365 EVM Controls as /devices/platform/i2c_davinci.1/i2c-1/1-0025/input/input0
i2c /dev entries driver
Linux video capture interface: v2.00
ths7303 1-002c: chip found @ 0x58 (DaVinci I2C adapter)
vpfe_init
vpfe-capture: vpss clock vpss_master enabled
vpfe-capture vpfe-capture: v4l2 device registered
vpfe-capture vpfe-capture: video device registered
EVM: switch to tvp5146 SD video input
tvp514x 1-005d: tvp514x 1-005d decoder driver registered !!
vpfe-capture vpfe-capture: v4l2 sub device tvp5146 registered
EVM: switch to tvp7002 HD video input
tvp7002 1-005c: tvp7002 1-005c decoder driver registered !!
vpfe-capture vpfe-capture: v4l2 sub device tvp7002 registered
ths7353 1-002e: chip found @ 0x5c (DaVinci I2C adapter)
ths7353 1-002e: No platform data!!
vpfe-capture vpfe-capture: v4l2 sub device ths7353 registered
vpfe_register_ccdc_device: DM365 ISIF
DM365 ISIF is registered with vpfe.
af major#: 252, minor# 0
AF Driver initialized
aew major#: 251, minor# 0
AEW Driver initialized
Trying to register davinci display video device.
layer=c20d9400,layer->video_dev=c20d9570
layer=c20d9800,layer->video_dev=c20d9970
davinci_init:DaVinci V4L2 Display Driver V1.0 loaded
watchdog watchdog: heartbeat 60 sec
davinci_mmc davinci_mmc.0: Using DMA, 4-bit mode
usbcore: registered new interface driver usbhid
usbhid: v2.6:USB HID core driver
Advanced Linux Sound Architecture Driver Version 1.0.21.
No device for DAI tlv320aic3x
No device for DAI davinci-i2s
asoc: tlv320aic3x <-> davinci-i2s mapping ok
ALSA device list:
#0: DaVinci EVM (tlv320aic3x)
TCP cubic registered
NET: Registered protocol family 17
lib80211: common routines for IEEE802.11 drivers
Clocks: disable unused mmcsd1
Clocks: disable unused spi1
Clocks: disable unused spi2
Clocks: disable unused spi3
Clocks: disable unused spi4
Clocks: disable unused pwm0
Clocks: disable unused pwm1
Clocks: disable unused pwm2
Clocks: disable unused pwm3
Clocks: disable unused timer1
Clocks: disable unused timer3
Clocks: disable unused emac
Clocks: disable unused voice_codec
Clocks: disable unused rto
Clocks: disable unused mjcp
emac-mii: probed
eth0: attached PHY driver [Generic PHY] (mii_bus:phy_addr=1:01, id=221613)
Sending DHCP requests .
PHY: 1:01 - Link is Up - 100/Full
., OK
IP-Config: Got DHCP answer from 0.0.0.0, my address is 172.20.161.51
IP-Config: Complete:
device=eth0, addr=172.20.161.51, mask=255.255.254.0, gw=172.20.161.254,
host=172.20.161.51, domain=star-ds.local, nis-domain=(none),
bootserver=0.0.0.0, rootserver=0.0.0.0, rootpath=
VFS: Mounted root (jffs2 filesystem) on device 31:3.
Freeing init memory: 144K
INIT: version 2.86 booting
Please wait: booting...
Starting udev
udev: starting version 141
udevd-event[1060]: error changing netif name eth0 to eth1: Device or resource busy
Remounting root file system...
Caching udev devnodes
Populating dev cacheJFFS2 notice: (1259) check_node_data: wrong data CRC in data node at 0x17e7dde4: read 0xc994466f, calculated 0xfd3117d4.
mv: cannot rename '/tmp/devices': No such file or directory
NET: Registered protocol family 10
ALSA: Restoring mixer settings...
Configuring network interfaces... udhcpc (v1.13.2) started
Sending discover...
Sending select for 172.20.161.51...
Lease of 172.20.161.51 obtained, lease time 604800
adding dns 172.20.160.8
adding dns 172.20.160.21
done.
Setting up IP spoofing protection: rp_filter.
hwclock: can't open '/dev/misc/rtc': No such file or directory
Fri Mar 25 00:48:00 UTC 2011
INIT: Entering runlevel: 5
Starting system message bus: dbus.
Starting telnet daemon.
Starting syslogd/klogd: done
Starting thttpd.
CMEMK module: built on Mar 24 2011 at 19:34:57
Reference Linux version 2.6.32
File /sdk/build/DVSDK_4_02/4_02_00_06/arago-install/arago-tmp/work/dm365-evm-none-linux-gnueabi/ti-linuxutils-1_2_26_01_02-r52d/linuxutils_2_26_01_02/packages/ti/sdo/linuxutils/cmem/src/module/cmemk.c
allocated heap buffer 0xc7000000 of size 0x4400000
heap fallback enabled - will try heap if pool buffer is not available
CMEM Range Overlaps Kernel Physical - allowing overlap
CMEM phys_start (0x1000) overlaps kernel (0x80000000 -> 0x83600000)
cmemk initialized
IRQK module: built on Mar 24 2011 at 19:35:11
File /sdk/build/DVSDK_4_02/4_02_00_06/arago-install/arago-tmp/work/dm365-evm-none-linux-gnueabi/ti-linuxutils-1_2_26_01_02-r52d/linuxutils_2_26_01_02/packages/ti/sdo/linuxutils/irq/src/module/irqk.c
irqk initialized
EDMAK module: built on Mar 24 2011 at 19:35:06
File /sdk/build/DVSDK_4_02/4_02_00_06/arago-install/arago-tmp/work/dm365-evm-none-linux-gnueabi/ti-linuxutils-1_2_26_01_02-r52d/linuxutils_2_26_01_02/packages/ti/sdo/linuxutils/edma/src/module/edmak.c
_____ _____ _ _
| _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_
| | _| .'| . | . | | __| _| . | | | -_| _| _|
|__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_|
|___| |___|
Arago Project http://arago-project.org dm365-evm ttyS0
Arago 2011.02 dm365-evm ttyS0
dm365-evm login:
Thanks!
