[dm8107] how to sd boot for dm8107 udworks board. use DVRRDK-3.5.0.5
Other Parts Discussed in Thread: DM8107
hi all.
I used to DVRRDK-3.5.0.5.
The only option is to build and uart, nand images for dm8107's RDK makerule For sd boot DVRRDK-3.0.0.0 build options have been added.
view makeruls/build_uboot.mk
ifeq ($(DVR_RDK_BOARD_TYPE),DM810X_UD_DVR)
$(MAKE) -fbuild_uboot.mk uboot_clean
$(MAKE) -fbuild_uboot.mk uboot_build UBOOT_TARGET=ti8107_dvr_min_uart
$(MAKE) -fbuild_uboot.mk uboot_build UBOOT_TARGET=u-boot.ti
cp $(UBOOTDIR)/u-boot.min.uart $(TFTP_HOME)/u-boot_$(DVR_RDK_BOARD_TYPE).min.uart
$(MAKE) -fbuild_uboot.mk uboot_build UBOOT_TARGET=ti8107_dvr_min_nand
cp $(UBOOTDIR)/u-boot.min.nand $(TFTP_HOME)/u-boot_$(DVR_RDK_BOARD_TYPE).min.nand
$(MAKE) -fbuild_uboot.mk uboot_build UBOOT_TARGET=ti8107_dvr_min_sd
cp $(UBOOTDIR)/u-boot.min.sd $(TFTP_HOME)/MLO
$(MAKE) -fbuild_uboot.mk uboot_build UBOOT_TARGET=ti8107_dvr_config_nand
cp $(UBOOTDIR)/u-boot.bin $(TFTP_HOME)/u-boot_$(DVR_RDK_BOARD_TYPE).bin
$(MAKE) -fbuild_uboot.mk uboot_build UBOOT_TARGET=ti8107_dvr_config_sd
cp $(UBOOTDIR)/u-boot.bin $(TFTP_HOME)/u-boot_$(DVR_RDK_BOARD_TYPE).sd.bin
endif
==> Add the red code. Reference makerules DVRRDK-3.0.0.0.
look at the file
u_boot_DM810X_UD_DVR.bin
u_boot_DM810X_UD_DVR.min.nand
u_boot_DM810X_UD_DVR.min.uart
u_boot_DM810X_UD_DVR.sd.bin
u_boot_DM810X_UD_DVR.min.sd  ==> file is generated by modifying makerules / build_uboot.mk.
Make MLO file. (MLO file is rename u_boot_DM810X_UD_DVR.min.sd file)
and copy MLO, u_boot_DM810X_UD_DVR.sd.bin, u_boot_DM810X_UD_DVR.bin, u_boot_DM810X_UD_DVR.min.nand to SD card.
so, board booting.
but, Serial consol display charctor 'C'. board is do not anything.
Thanks.
    Please make sure that you have board in SD boot mode. For this you need to put SW1[10:1] in the following order 0001010111
    Also make sure that you format the SD Card using HP Disk format utility v2.6 to FAT32 format.
    Arun
