Other Parts Discussed in Thread: TCA6416
when I start up EC7 with a normal SD card (non-SDHC), I've no problems. When I use a SDHC card, the kernel stops at:
17010 PID:0 TID:2 NKStartup done, starting up kernel. nCpus = 1
17010 PID:0 TID:2 Windows CE KernelInit
17010 PID:0 TID:2 Error Reporting Memory Reserved, dump size = 0004b000
17010 PID:0 TID:2 Booting Windows CE version 7.00 for (ARM)
17010 PID:0 TID:2 Memory Configuring: Total pages: 21557, Filesystem pages = 10778
17010 PID:0 TID:2 Booting kernel with clean memory configuration:
17010 PID:0 TID:2 Total Memory Sections:1
17010 PID:0 TID:2 [0] (static): start: 87b7c000, extension/attributes: 00016000, length: 05435000
17010 PID:400002 TID:410002 Scheduling the first thread.
17034 PID:400002 TID:410002 PGPOOL: Reserved 768 pages for Loader pool
17035 PID:400002 TID:410002 PGPOOL: Reserved 256 pages for File pool
17043 PID:400002 TID:410002 OSAXST0: Platform Name = BSP_AM33X
17048 PID:400002 TID:410002 OSAXST1: >>> Loading Module 'kd.dll' (0x9E40209C) at address 0xEFFE0000-0xEFFFE000 in Process 'NK.EXE' (0x87B5EAD0)
17049 PID:400002 TID:410002 KD: Starting kernel debugger software probe (KdStub) - KD API version 27
PB Debugger Kernel debugger connected.
17072 PID:400002 TID:410002 OSAXST1: >>> Loading Module 'NK.EXE' (0x87B5EAD0) at address 0x80002000-0x8003E000 in Process 'NK.EXE' (0x87B5EAD0)
PB Debugger The Kernel Debugger connection has been established (Target CPU is ARM).
PB Debugger Target name: AM335x
PB Debugger Probe name: KdStub
PB Debugger Binary Image should be loaded at 0x80002000 / Data relocated at 0x87b16000
PB Debugger Loaded symbols for 'C:\MYPROJECTS\AM335X_OS\AM335X_OS\RELDIR\AM33X_BSP_ARMV7_DEBUG\NK.EXE'
PB Debugger Loaded symbols for 'C:\MYPROJECTS\AM335X_OS\AM335X_OS\RELDIR\AM33X_BSP_ARMV7_DEBUG\KERNEL.DLL'
PB Debugger Loaded symbols for 'C:\MYPROJECTS\AM335X_OS\AM335X_OS\RELDIR\AM33X_BSP_ARMV7_DEBUG\KITL.DLL'
PB Debugger Loaded symbols for 'C:\MYPROJECTS\AM335X_OS\AM335X_OS\RELDIR\AM33X_BSP_ARMV7_DEBUG\HD.DLL'
PB Debugger Loaded symbols for 'C:\MYPROJECTS\AM335X_OS\AM335X_OS\RELDIR\AM33X_BSP_ARMV7_DEBUG\OSAXST0.DLL'
PB Debugger Loaded symbols for 'C:\MYPROJECTS\AM335X_OS\AM335X_OS\RELDIR\AM33X_BSP_ARMV7_DEBUG\K.COREDLL.DLL'
PB Debugger Loaded symbols for 'C:\MYPROJECTS\AM335X_OS\AM335X_OS\RELDIR\AM33X_BSP_ARMV7_DEBUG\OSAXST1.DLL'
PB Debugger Loaded symbols for 'C:\MYPROJECTS\AM335X_OS\AM335X_OS\RELDIR\AM33X_BSP_ARMV7_DEBUG\KD.DLL'
17085 PID:400002 TID:410002 HD: Immediate debugger module load notifications ACTIVE (slower boot - non real-time).
17102 PID:400002 TID:410002 SetOpp to 3
17103 PID:400002 TID:410002 Message Queue support initialized, g_hMsgQHeap = a24d0010
17113 PID:400002 TID:580002 OSAXST1: >>> Loading Module 'filesys.dll' (0x9E403530) at address 0xEFC70000-0xEFD3B000 in Process 'NK.EXE' (0x87B5EAD0)
PB Debugger Loaded symbols for 'C:\MYPROJECTS\AM335X_OS\AM335X_OS\RELDIR\AM33X_BSP_ARMV7_DEBUG\FILESYS.DLL'
17124 PID:400002 TID:580002 OSAXST1: >>> Loading Module 'fsdmgr.dll' (0x9E403668) at address 0xEF7A0000-0xEF7E8000 in Process 'NK.EXE' (0x87B5EAD0)
PB Debugger Loaded symbols for 'C:\MYPROJECTS\AM335X_OS\AM335X_OS\RELDIR\AM33X_BSP_ARMV7_DEBUG\FSDMGR.DLL'
17137 PID:400002 TID:5a0002 FileSystem Starting - starting with clean file system
17142 PID:400002 TID:5a0002 OSAXST1: >>> Loading Module 'romfsd.dll' (0x9E403CD8) at address 0xEFC60000-0xEFC67000 in Process 'NK.EXE' (0x87B5EAD0)
PB Debugger Loaded symbols for 'C:\MYPROJECTS\AM335X_OS\AM335X_OS\RELDIR\AM33X_BSP_ARMV7_DEBUG\ROMFSD.DLL'
17170 PID:400002 TID:5a0002 OSAXST1: >>> Loading Module 'k.locale.dll' (0x9E404F44) at address 0xEFDB0000-0xEFDF1000 in Process 'NK.EXE' (0x87B5EAD0)
PB Debugger Loaded symbols for 'C:\MYPROJECTS\AM335X_OS\AM335X_OS\RELDIR\AM33X_BSP_ARMV7_DEBUG\K.LOCALE.DLL'
17233 PID:400002 TID:5a0002 Warning! Kernel DLL 'k.locale.dll' is registered for thread creation/deletion notification. To improve performance if you dont need thread notifications call DisableThreadLibraryCalls from inside D
17236 PID:400002 TID:5a0002 OSAXST1: >>> Loading Module 'k.normalize.dll' (0x9E40697C) at address 0xEFD60000-0xEFD80000 in Process 'NK.EXE' (0x87B5EAD0)
PB Debugger Loaded symbols for 'C:\MYPROJECTS\AM335X_OS\AM335X_OS\RELDIR\AM33X_BSP_ARMV7_DEBUG\K.NORMALIZE.DLL'
17238 PID:400002 TID:5a0002 Warning! Kernel DLL 'k.normalize.dll' is registered for thread creation/deletion notification. To improve performance if you dont need thread notifications call DisableThreadLibraryCalls from insid
17245 PID:400002 TID:5a0002 OSAXST1: >>> Loading Module 'relfsd.dll' (0x9E406B2C) at address 0xEF880000-0xEF892000 in Process 'NK.EXE' (0x87B5EAD0)
PB Debugger Loaded symbols for 'C:\MYPROJECTS\AM335X_OS\AM335X_OS\RELDIR\AM33X_BSP_ARMV7_DEBUG\RELFSD.DLL'
17249 PID:400002 TID:5a0002 Mounted ReleaseFSD volume '\Release'
17251 PID:400002 TID:5a0002 size of 'dbglist.txt' = 00000000
17260 PID:400002 TID:5a0002 OSAXST1: >>> Loading Module 'device.dll' (0x9E407000) at address 0xEF9C0000-0xEF9C5000 in Process 'NK.EXE' (0x87B5EAD0)
PB Debugger Loaded symbols for 'C:\MYPROJECTS\AM335X_OS\AM335X_OS\RELDIR\AM33X_BSP_ARMV7_DEBUG\DEVICE.DLL'
17267 PID:400002 TID:5a0002 OSAXST1: >>> Loading Module 'devmgr.dll' (0x9E407138) at address 0xEF980000-0xEF9B4000 in Process 'NK.EXE' (0x87B5EAD0)
PB Debugger Loaded symbols for 'C:\MYPROJECTS\AM335X_OS\AM335X_OS\RELDIR\AM33X_BSP_ARMV7_DEBUG\DEVMGR.DLL'
17272 PID:400002 TID:5a0002 OSAXST1: >>> Loading Module 'k.ceddk.dll' (0x9E407270) at address 0xEF6A0000-0xEF6B5000 in Process 'NK.EXE' (0x87B5EAD0)
PB Debugger Loaded symbols for 'C:\MYPROJECTS\AM335X_OS\AM335X_OS\RELDIR\AM33X_BSP_ARMV7_DEBUG\K.CEDDK.DLL'
17276 PID:400002 TID:5a0002 OSAXST1: >>> Loading Module 'k.edmadrvr.dll' (0x9E4073A8) at address 0xEE1F0000-0xEE211000 in Process 'NK.EXE' (0x87B5EAD0)
PB Debugger Loaded symbols for 'C:\MYPROJECTS\AM335X_OS\AM335X_OS\RELDIR\AM33X_BSP_ARMV7_DEBUG\K.EDMADRVR.DLL'
17296 PID:400002 TID:5a0002 OSAXST1: >>> Loading Module 'pm.dll' (0x9E4074E0) at address 0xEF930000-0xEF95E000 in Process 'NK.EXE' (0x87B5EAD0)
PB Debugger Loaded symbols for 'C:\MYPROJECTS\AM335X_OS\AM335X_OS\RELDIR\AM33X_BSP_ARMV7_DEBUG\PM.DLL'
17355 PID:400002 TID:b30006 OSAXST1: >>> Loading Module 'busenum.dll' (0x9E40AED8) at address 0xEF960000-0xEF96B000 in Process 'NK.EXE' (0x87B5EAD0)
PB Debugger Loaded symbols for 'C:\MYPROJECTS\AM335X_OS\AM335X_OS\RELDIR\AM33X_BSP_ARMV7_DEBUG\BUSENUM.DLL'
17369 PID:400002 TID:b30006 OSAXST1: >>> Loading Module 'am33x_gpio.dll' (0x9E40BD24) at address 0xEE310000-0xEE318000 in Process 'NK.EXE' (0x87B5EAD0)
PB Debugger Loaded symbols for 'C:\MYPROJECTS\AM335X_OS\AM335X_OS\RELDIR\AM33X_BSP_ARMV7_DEBUG\AM33X_GPIO.DLL'
17379 PID:400002 TID:b30006 OSAXST1: >>> Loading Module 'tca6416_gpio.dll' (0x9E40C0E8) at address 0xEE300000-0xEE308000 in Process 'NK.EXE' (0x87B5EAD0)
PB Debugger Loaded symbols for 'C:\MYPROJECTS\AM335X_OS\AM335X_OS\RELDIR\AM33X_BSP_ARMV7_DEBUG\TCA6416_GPIO.DLL'
17392 PID:400002 TID:b30006 OSAXST1: >>> Loading Module 'ccfgsvc.dll' (0x9E40C630) at address 0xEE840000-0xEE86D000 in Process 'NK.EXE' (0x87B5EAD0)
PB Debugger Loaded symbols for 'C:\MYPROJECTS\AM335X_OS\AM335X_OS\RELDIR\AM33X_BSP_ARMV7_DEBUG\CCFGSVC.DLL'
17422 PID:400002 TID:b30006 OSAXST1: >>> Loading Module 'sdbus.dll' (0x9E414408) at address 0xEED30000-0xEED66000 in Process 'NK.EXE' (0x87B5EAD0)
PB Debugger Loaded symbols for 'C:\MYPROJECTS\AM335X_OS\AM335X_OS\RELDIR\AM33X_BSP_ARMV7_DEBUG\SDBUS.DLL'
17423 PID:400002 TID:b30006 SDBusDriver: PROCESS_ATTACH
17426 PID:400002 TID:b30006 SDBusDriver: +SDC_Init
17427 PID:400002 TID:b30006 SDBusDriver: Bus Driver instance created : 0xA2437200 ! -SDC_Init
17436 PID:400002 TID:b30006 OSAXST1: >>> Loading Module 'am33x_sdhc.dll' (0x9E4148F8) at address 0xEE1C0000-0xEE1E2000 in Process 'NK.EXE' (0x87B5EAD0)
PB Debugger Loaded symbols for 'C:\MYPROJECTS\AM335X_OS\AM335X_OS\RELDIR\AM33X_BSP_ARMV7_DEBUG\AM33X_SDHC.DLL'
17439 PID:400002 TID:b30006 SDHCDGetHCFunctions: +Init
17439 PID:400002 TID:b30006 SDHCDGetHCFunctions: -Init
17440 PID:400002 TID:b30006 SDHC +Init
17440 PID:400002 TID:b30006 SDHC Active RegPath: Drivers\Active\4294967287
17441 PID:400002 TID:b30006 SDHC Active RegPath: Drivers\Active\4294967287
17442 PID:400002 TID:b30006 SDHC: CPU revision 0xffffffff
17444 PID:400002 TID:b30006 SDHC host controller initialize: m_fastPathSDIO:1 m_fastPathSDMEM:0
17446 PID:400002 TID:b30006 SHCSDSlotOptionHandler-SDHCDGetSlotInfo(slot=0)
17447 PID:400002 TID:b30006 SHCSDSlotOptionHandler-SDHCDGetSlotInfo[out](slot=0, Capabilities=2156, VoltageWindowMask=0x00F80000, DesiredVoltageMask=0x00020000, MaxClockRate=0x016E3600, PowerUpDelay=100)
17447 PID:400002 TID:b30006 CSDIOControllerBase::SDHCInitializeImpl++
17449 PID:400002 TID:b30006 SDIO_InitDMA : RX DMA enabled
17450 PID:400002 TID:b30006 SDHC -Init
17451 PID:400002 TID:b30006 SDHC -Init
17453 PID:400002 TID:d30006 SHC: Received IOCTL_POWER_CAPABILITIES
17455 PID:400002 TID:119000a CardInterrupt(1)
17456 PID:400002 TID:112000a HandleInsertion
17558 PID:400002 TID:da000a SHCSDSlotOptionHandler-SDHCDSetSlotInterface(slot=0, interface=0x00000000, clockrate=100000, writeprotect=0)
17561 PID:400002 TID:da000a SetInterface MMCHS_HCTL value = D00
17561 PID:400002 TID:da000a SHCSDSlotOptionHandler-SDHCDSetSlotInterface(out)(slot=0, interface=0x00000000, clockrate=100000, writeprotect=0)
17561 PID:400002 TID:da000a SDHCBusRequestHandler - CMD::[5] FastPath 1
17563 PID:400002 TID:112000a SDHControllerIstThread() - Got command response timeout!
17564 PID:400002 TID:112000a SDHCBusRequestHandler - CMD::[5] FastPath 0
17566 PID:400002 TID:112000a SDHControllerIstThread() - Got command response timeout!
17566 PID:400002 TID:112000a SDHCBusRequestHandler - CMD::[5] FastPath 0
17568 PID:400002 TID:112000a SDHControllerIstThread() - Got command response timeout!
17568 PID:400002 TID:112000a SDHCBusRequestHandler - CMD::[5] FastPath 0
17570 PID:400002 TID:112000a SDHControllerIstThread() - Got command response timeout!
17571 PID:400002 TID:112000a SDHCBusRequestHandler - CMD::[0] FastPath 0
17572 PID:400002 TID:112000a +CSDIOControllerBase::ProcessCommandTransferStatus: status = 1
17573 PID:400002 TID:112000a SDHCBusRequestHandler - CMD::[1] FastPath 0
17574 PID:400002 TID:112000a SDHControllerIstThread() - Got command response timeout!
17599 PID:400002 TID:112000a SDHCBusRequestHandler - CMD::[1] FastPath 0
17601 PID:400002 TID:112000a SDHControllerIstThread() - Got command response timeout!
17601 PID:400002 TID:112000a SDHCBusRequestHandler - CMD::[1] FastPath 0
17603 PID:400002 TID:112000a SDHControllerIstThread() - Got command response timeout!
17603 PID:400002 TID:112000a SDHCBusRequestHandler - CMD::[1] FastPath 0
17605 PID:400002 TID:112000a SDHControllerIstThread() - Got command response timeout!
17605 PID:400002 TID:112000a SDHCBusRequestHandler - CMD::[0] FastPath 0
17606 PID:400002 TID:112000a +CSDIOControllerBase::ProcessCommandTransferStatus: status = 1
17607 PID:400002 TID:112000a SDHCBusRequestHandler - CMD::[8] FastPath 0
17609 PID:400002 TID:112000a SDHCBusRequestHandler - CMD::[55] FastPath 0
17611 PID:400002 TID:112000a SDHCBusRequestHandler - CMD::[41] FastPath 0
17612 PID:400002 TID:da000a SHCSDSlotOptionHandler-SDHCDSetSlotPower(slot=0, power=0x00020000)
17714 PID:400002 TID:da000a SDHCBusRequestHandler - CMD::[0] FastPath 1
17715 PID:400002 TID:112000a +CSDIOControllerBase::ProcessCommandTransferStatus: status = 1
17715 PID:400002 TID:112000a SDHCBusRequestHandler - CMD::[8] FastPath 0
17768 PID:400002 TID:da000a SDHCBusRequestHandler - CMD::[55] FastPath 1
17769 PID:400002 TID:112000a SDHCBusRequestHandler - CMD::[41] FastPath 0
17822 PID:400002 TID:da000a SDHCBusRequestHandler - CMD::[55] FastPath 1
17823 PID:400002 TID:112000a SDHCBusRequestHandler - CMD::[41] FastPath 0
17876 PID:400002 TID:da000a SDHCBusRequestHandler - CMD::[55] FastPath 1
17877 PID:400002 TID:112000a SDHCBusRequestHandler - CMD::[41] FastPath 0
17879 PID:400002 TID:112000a SDHCBusRequestHandler - CMD::[2] FastPath 0
17882 PID:400002 TID:112000a SDHCBusRequestHandler - CMD::[3] FastPath 0
17884 PID:400002 TID:112000a SDHCBusRequestHandler - CMD::[9] FastPath 0
17887 PID:400002 TID:112000a SDHCBusRequestHandler - CMD::[13] FastPath 0
17889 PID:400002 TID:112000a SDHCBusRequestHandler - CMD::[7] FastPath 0
17891 PID:400002 TID:112000a SDHCBusRequestHandler - CMD::[55] FastPath 0
17892 PID:400002 TID:112000a SDHCBusRequestHandler - CMD::[51] FastPath 0
17895 PID:400002 TID:112000a SDHCBusRequestHandler - CMD::[55] FastPath 0
17897 PID:400002 TID:112000a SDHCBusRequestHandler - CMD::[42] FastPath 0
17899 PID:400002 TID:da000a SHCSDSlotOptionHandler-SDHCDGetWriteProtectStatus(slot=0, protected=0)
17900 PID:400002 TID:da000a SDBusDriver: The SDIO card does not support block mode. Use Soft-Block instead.
17900 PID:400002 TID:da000a SDBusDriver: The host controller needs to use Soft-Block for CMD53 multi-block read operations.
17901 PID:400002 TID:da000a SDHCBusRequestHandler - CMD::[55] FastPath 1
17903 PID:400002 TID:112000a SDHCBusRequestHandler - CMD::[6] FastPath 0
17905 PID:400002 TID:da000a SHCSDSlotOptionHandler-SDHCDSetSlotInterface(slot=0, interface=0x00000001, clockrate=25000000, writeprotect=0)
17908 PID:400002 TID:da000a SetInterface MMCHS_HCTL value = D02
17908 PID:400002 TID:da000a SHCSDSlotOptionHandler-SDHCDSetSlotInterface(out)(slot=0, interface=0x00000001, clockrate=24000000, writeprotect=0)
17909 PID:400002 TID:da000a SDSetCardInterfaceForSlot - HC ClockRate differs desired setting: desired: 25000000 Hz, Actual : 24000000 Hz
17909 PID:400002 TID:da000a The clock rate is set to 24000000
17909 PID:400002 TID:da000a HandleAddDevice: LoadDevice type = 2, slot 0
17917 PID:400002 TID:da000a OSAXST1: >>> Loading Module 'sdmemory.dll' (0x9E4165C0) at address 0xEED10000-0xEED2A000 in Process 'NK.EXE' (0x87B5EAD0)
PB Debugger Loaded symbols for 'C:\MYPROJECTS\AM335X_OS\AM335X_OS\RELDIR\AM33X_BSP_ARMV7_DEBUG\SDMEMORY.DLL'
18159 PID:400002 TID:da000a SDMemory: +SMC_Init
18160 PID:400002 TID:da000a SDGetDeviceHandle: ActivePath: Drivers\Active\4294967288
18161 PID:400002 TID:da000a SDGetClientFunctions: +Init
18161 PID:400002 TID:da000a SDGetClientFunctions: -Init
18162 PID:400002 TID:da000a SDMemCardConfig: Card is high capacity (2.0+)
18162 PID:400002 TID:da000a SDMemCalcDataAccessClocks: Tpd:f ns, Asynch: f ns, AsyncClocks:0 , SyncClocks: 1078231040, ReadTotal: 0, Write Factor: 1093567616 WriteTotal: 24390
18162 PID:400002 TID:da000a SDMemory: Initialize: Using block transfer size of 64 blocks
18163 PID:400002 TID:da000a SDMemory: Idle Timeout: 2000 Idle Power State: 2
18164 PID:400002 TID:da000a SDMemory: Power Management Setup complete
18164 PID:400002 TID:da000a SDMemory: -SMC_Init
18167 PID:400002 TID:8c0002 SDMemory: GetDeviceInfo - Profile = SDHCMemory, length = 22
18168 PID:400002 TID:8c0002 SDemory: GetDeviceInfo - RegQueryValueEx(Profile) returned 2
18168 PID:400002 TID:8c0002 SDMemory: GetStorageID Insufficient buffer space
SDMemory: -GetStorageID
18175 PID:400002 TID:8c0002 OSAXST1: >>> Loading Module 'mspart.dll' (0x9E417050) at address 0xEF780000-0xEF790000 in Process 'NK.EXE' (0x87B5EAD0)
PB Debugger Loaded symbols for 'C:\MYPROJECTS\AM335X_OS\AM335X_OS\RELDIR\AM33X_BSP_ARMV7_DEBUG\MSPART.DLL'
18178 PID:400002 TID:8c0002 SDHCBusRequestHandler - CMD::[17] FastPath 1
18181 PID:400002 TID:8c0002 SDHCBusRequestHandler - CMD::[17] FastPath 1
18183 PID:400002 TID:8c0002 SDHCBusRequestHandler - CMD::[17] FastPath 1
18184 PID:400002 TID:8c0002 SDHCBusRequestHandler - CMD::[17] FastPath 1
18185 PID:400002 TID:8c0002 Partition Part00 NumSectors=1048576
18186 PID:400002 TID:8c0002 MSPART!PD_OpenPartition: dwStoreId=A243ACE0, PartName=Part00
18188 PID:400002 TID:8c0002 SDHCBusRequestHandler - CMD::[17] FastPath 1
18196 PID:400002 TID:8c0002 OSAXST1: >>> Loading Module 'exfat.dll' (0x9E417270) at address 0xEF8E0000-0xEF91C000 in Process 'NK.EXE' (0x87B5EAD0)
PB Debugger Loaded symbols for 'C:\MYPROJECTS\AM335X_OS\AM335X_OS\RELDIR\AM33X_BSP_ARMV7_DEBUG\EXFAT.DLL'
18202 PID:400002 TID:8c0002 SDHCBusRequestHandler - CMD::[17] FastPath 1
18213 PID:400002 TID:8c0002 OSAXST1: >>> Loading Module 'diskcache.dll' (0x9E417888) at address 0xEF8D0000-0xEF8DA000 in Process 'NK.EXE' (0x87B5EAD0)
PB Debugger Loaded symbols for 'C:\MYPROJECTS\AM335X_OS\AM335X_OS\RELDIR\AM33X_BSP_ARMV7_DEBUG\DISKCACHE.DLL'
18217 PID:400002 TID:8c0002 CreateCache: Successful. Cache Size: 256 KB, Start: 32, End: 2079, CreateFlags: 0.
18219 PID:400002 TID:8c0002 CreateCache: Successful. Cache Size: 256 KB, Start: 2080, End: 1048575, CreateFlags: 0.
18220 PID:400002 TID:8c0002 SDHCBusRequestHandler - CMD::[18] FastPath 0
18225 PID:400002 TID:112000a SDHCBusRequestHandler - CMD::[12] FastPath 0
18225 PID:400002 TID:8c0002 SDHCBusRequestHandler - CMD::[18] FastPath 0
18229 PID:400002 TID:112000a SDHCBusRequestHandler - CMD::[12] FastPath 0
18230 PID:400002 TID:8c0002 SDHCBusRequestHandler - CMD::[18] FastPath 0
18234 PID:400002 TID:112000a SDHCBusRequestHandler - CMD::[12] FastPath 0
18234 PID:400002 TID:8c0002 SDHCBusRequestHandler - CMD::[18] FastPath 0
18238 PID:400002 TID:112000a SDHCBusRequestHandler - CMD::[12] FastPath 0
18239 PID:400002 TID:8c0002 SDHCBusRequestHandler - CMD::[18] FastPath 0
18243 PID:400002 TID:112000a SDHCBusRequestHandler - CMD::[12] FastPath 0
18243 PID:400002 TID:8c0002 SDHCBusRequestHandler - CMD::[18] FastPath 0
18247 PID:400002 TID:112000a SDHCBusRequestHandler - CMD::[12] FastPath 0
18248 PID:400002 TID:8c0002 SDHCBusRequestHandler - CMD::[18] FastPath 0
18252 PID:400002 TID:112000a SDHCBusRequestHandler - CMD::[12] FastPath 0
18253 PID:400002 TID:8c0002 SDHCBusRequestHandler - CMD::[18] FastPath 0
18257 PID:400002 TID:112000a SDHCBusRequestHandler - CMD::[12] FastPath 0
18282 PID:400002 TID:8c0002 SDHCBusRequestHandler - CMD::[18] FastPath 0
18287 PID:400002 TID:112000a SDHCBusRequestHandler - CMD::[12] FastPath 0
18288 PID:400002 TID:8c0002 SDHCBusRequestHandler - CMD::[18] FastPath 0
18292 PID:400002 TID:112000a SDHCBusRequestHandler - CMD::[12] FastPath 0
18292 PID:400002 TID:8c0002 SDHCBusRequestHandler - CMD::[18] FastPath 0
18296 PID:400002 TID:112000a SDHCBusRequestHandler - CMD::[12] FastPath 0
18297 PID:400002 TID:8c0002 SDHCBusRequestHandler - CMD::[18] FastPath 0
18301 PID:400002 TID:112000a SDHCBusRequestHandler - CMD::[12] FastPath 0
18302 PID:400002 TID:8c0002 SDHCBusRequestHandler - CMD::[18] FastPath 0
18306 PID:400002 TID:112000a SDHCBusRequestHandler - CMD::[12] FastPath 0
18306 PID:400002 TID:8c0002 SDHCBusRequestHandler - CMD::[18] FastPath 0
18310 PID:400002 TID:112000a SDHCBusRequestHandler - CMD::[12] FastPath 0
18311 PID:400002 TID:8c0002 SDHCBusRequestHandler - CMD::[18] FastPath 0
18315 PID:400002 TID:112000a SDHCBusRequestHandler - CMD::[12] FastPath 0
18315 PID:400002 TID:8c0002 SDHCBusRequestHandler - CMD::[18] FastPath 0
18319 PID:400002 TID:112000a SDHCBusRequestHandler - CMD::[12] FastPath 0
18354 PID:400002 TID:8c0002 SDHCBusRequestHandler - CMD::[17] FastPath 1
18356 PID:400002 TID:8c0002 SDHCBusRequestHandler - CMD::[17] FastPath 1
Any ideas?
