In DM814X, while running application causes ioremap() error?
Hi All,
when we try to run an application in dm8148,
we face this error,
Please let us know what cause this error?
BUG: Your driver calls ioremap() on system memory. This leads
to architecturally unpredictable behaviour on ARMv6+, and ioremap()
will fail in the next kernel release. Please fix your driver.
------------[ cut here ]------------
WARNING: at arch/arm/mm/ioremap.c:211 __arm_ioremap_pfn_caller+0x58/0x190()
Modules linked in: pinmux_linux_i2c2 syslink ipv6
Backtrace:
[<c0050bf4>] (dump_backtrace+0x0/0x110) from [<c03e9ddc>] (dump_stack+0x18/0x1c)
r7:00000000 r6:c005478c r5:c04b7fae r4:000000d3
[<c03e9dc4>] (dump_stack+0x0/0x1c) from [<c00779b8>] (warn_slowpath_common+0x54/0x6c)
[<c0077964>] (warn_slowpath_common+0x0/0x6c) from [<c00779f4>] (warn_slowpath_null+0x24/0x2c)
r9:00000002 r8:00000000 r7:bf07efb8 r6:0008a600 r5:00600000
r4:00000000
[<c00779d0>] (warn_slowpath_null+0x0/0x2c) from [<c005478c>] (__arm_ioremap_pfn_caller+0x58/0x190)
[<c0054734>] (__arm_ioremap_pfn_caller+0x0/0x190) from [<c0054948>] (__arm_ioremap_caller+0x64/0x6c)
[<c00548e4>] (__arm_ioremap_caller+0x0/0x6c) from [<c0068110>] (omap_ioremap+0x60/0x64)
r6:00000000 r5:00600000 r4:8a600000
[<c00680b0>] (omap_ioremap+0x0/0x64) from [<bf07efb8>] (MemoryOS_map+0x1f0/0x3a8 [syslink])
r7:d5871cc8 r6:00000000 r5:d5871c60 r4:d72bc000
[<bf07edc8>] (MemoryOS_map+0x0/0x3a8 [syslink]) from [<bf04d594>] (_ProcMgr_map+0x1cc/0x4ac [syslink])
r8:db2ca000 r7:d5871cc8 r6:00000000 r5:06a85000 r4:d5871d48
[<bf04d3c8>] (_ProcMgr_map+0x0/0x4ac [syslink]) from [<bf05b974>] (ElfLoaderTrgWrite_copy+0x10c/0x368 [syslink])
[<bf05b868>] (ElfLoaderTrgWrite_copy+0x0/0x368 [syslink]) from [<bf05ef20>] (DLIF_copy+0x10/0x1c [syslink])
[<bf05ef10>] (DLIF_copy+0x0/0x1c [syslink]) from [<bf05dcd4>] (DLOAD_load+0x734/0xa58 [syslink])
[<bf05d5a0>] (DLOAD_load+0x0/0xa58 [syslink]) from [<bf05aa60>] (ElfLoader_load+0x268/0x36c [syslink])
[<bf05a7f8>] (ElfLoader_load+0x0/0x36c [syslink]) from [<bf04b2d0>] (Loader_load+0xec/0x164 [syslink])
[<bf04b1e4>] (Loader_load+0x0/0x164 [syslink]) from [<bf04f9cc>] (ProcMgr_load+0x220/0x2fc [syslink])
[<bf04f7ac>] (ProcMgr_load+0x0/0x2fc [syslink]) from [<bf0519a4>] (ProcMgrDrv_ioctl+0xb98/0x1c38 [syslink])
[<bf050e0c>] (ProcMgrDrv_ioctl+0x0/0x1c38 [syslink]) from [<c00dee44>] (vfs_ioctl+0x28/0x44)
r8:41c39d30 r7:00000017 r6:00000017 r5:d5f50900 r4:00000000
[<c00dee1c>] (vfs_ioctl+0x0/0x44) from [<c00df554>] (do_vfs_ioctl+0x500/0x540)
[<c00df054>] (do_vfs_ioctl+0x0/0x540) from [<c00df5ec>] (sys_ioctl+0x58/0x7c)
[<c00df594>] (sys_ioctl+0x0/0x7c) from [<c004ce00>] (ret_fast_syscall+0x0/0x30)
r8:c004cfa8 r7:00000036 r6:00000000 r5:00000000 r4:41c39d30
---[ end trace ac7311448df33465 ]---
Backtrace:
r9:00000002 r8:00000000 r7:bf07efb8 r6:0008b000 r5:011698dc
r4:00000000
r6:00000000 r5:011698dc r4:8b000000
---[ end trace ac7311448df33466 ]---
Backtrace:
r9:00000002 r8:00000000 r7:bf07efb8 r6:0008c169 r5:00000004
r4:00000000
r6:00000000 r5:00000004 r4:8c1698dc
---[ end trace ac7311448df33467 ]---
Backtrace:
r9:00000002 r8:00000000 r7:bf07efb8 r6:0008c169 r5:00000010
r4:00000000
r6:00000000 r5:00000010 r4:8c1698e0
---[ end trace ac7311448df33468 ]---
Backtrace:
r9:00000002 r8:00000000 r7:bf07efb8 r6:0008c169 r5:003247a6
r4:00000000
r6:00000000 r5:003247a6 r4:8c1698f0
---[ end trace ac7311448df33469 ]---
Backtrace:
r9:00000002 r8:00000000 r7:bf07efb8 r6:0008c48e r5:00000008
r4:00000000
r6:00000000 r5:00000008 r4:8c48e098
---[ end trace ac7311448df3346a ]---
Backtrace:
r9:00000002 r8:00000000 r7:bf07efb8 r6:0008c48e r5:00000060
r4:00000000
r6:00000000 r5:00000060 r4:8c48e0a0
---[ end trace ac7311448df3346b ]---
Backtrace:
r9:00000002 r8:00000000 r7:bf07efb8 r6:0008c48e r5:00152444
r4:00000000
r6:00000000 r5:00152444 r4:8c48e100
---[ end trace ac7311448df3346c ]---
Backtrace:
r9:00000002 r8:00000000 r7:bf07efb8 r6:0008c5e0 r5:00000018
r4:00000000
r6:00000000 r5:00000018 r4:8c5e0548
---[ end trace ac7311448df3346d ]---
Backtrace:
r9:00000002 r8:00000000 r7:bf07efb8 r6:0008c5e0 r5:000bbd80
r4:00000000
r6:00000000 r5:000bbd80 r4:8c5e0560
---[ end trace ac7311448df3346e ]---
Backtrace:
r9:00000002 r8:00000000 r7:bf07efb8 r6:0008c69c r5:00080000
r4:00000000
r6:00000000 r5:00080000 r4:8c69c2e0
---[ end trace ac7311448df3346f ]---
Backtrace:
r9:00000002 r8:00000000 r7:bf07efb8 r6:0008c71c r5:00044dfa
r4:00000000
r6:00000000 r5:00044dfa r4:8c71c2e0
---[ end trace ac7311448df33470 ]---
Backtrace:
r9:00000002 r8:00000000 r7:bf07efb8 r6:0008c779 r5:00000020
r4:00000000
r6:00000000 r5:00000020 r4:8c7790e0
---[ end trace ac7311448df33471 ]---
Backtrace:
r9:00000002 r8:00000000 r7:bf07efb8 r6:0008c779 r5:00020000
r4:00000000
r6:00000000 r5:00020000 r4:8c779100
---[ end trace ac7311448df33472 ]---
Backtrace:
r9:00000002 r8:00000000 r7:bf07efb8 r6:0008c799 r5:0000057c
r4:00000000
r6:00000000 r5:0000057c r4:8c799100
---[ end trace ac7311448df33473 ]---
Backtrace:
r9:00000002 r8:00000000 r7:bf07efb8 r6:0008c799 r5:00000120
r4:00000000
r6:00000000 r5:00000120 r4:8c79967c
---[ end trace ac7311448df33474 ]---
Backtrace:
r9:00000002 r8:00000000 r7:bf07efb8 r6:0008c799 r5:0000000c
r4:00000000
r6:00000000 r5:0000000c r4:8c79979c
---[ end trace ac7311448df33475 ]---
Backtrace:
r9:00000002 r8:00000000 r7:bf07efb8 r6:0008c799 r5:00000200
r4:00000000
r6:00000000 r5:00000200 r4:8c799800
---[ end trace ac7311448df33476 ]---
Backtrace:
r9:00000002 r8:00000000 r7:bf07efb8 r6:0008c799 r5:000003a5
r4:00000000
r6:00000000 r5:000003a5 r4:8c799a00
---[ end trace ac7311448df33477 ]---
Backtrace:
r9:00000002 r8:00000000 r7:bf07efb8 r6:0008c799 r5:00000008
r4:00000000
r6:00000000 r5:00000008 r4:8c799da8
---[ end trace ac7311448df33478 ]---
Backtrace:
r9:00000002 r8:00000000 r7:bf07efb8 r6:0008c799 r5:00000300
r4:00000000
r6:00000000 r5:00000300 r4:8c799dc0
---[ end trace ac7311448df33479 ]---
Backtrace:
r9:00000002 r8:00000000 r7:bf07efb8 r6:0008c79a r5:000003dc
r4:00000000
r6:00000000 r5:000003dc r4:8c79a0c0
---[ end trace ac7311448df3347a ]---
Backtrace:
r9:00000002 r8:00000000 r7:bf07efb8 r6:0008c79a r5:00000080
r4:00000000
r6:00000000 r5:00000080 r4:8c79a4a0
---[ end trace ac7311448df3347b ]---
Backtrace:
r9:00000002 r8:00000000 r7:bf07efb8 r6:0008c79a r5:00000034
r4:00000000
r6:00000000 r5:00000034 r4:8c79a800
---[ end trace ac7311448df3347c ]---
Backtrace:
r9:00000002 r8:00000000 r7:bf07efb8 r6:0008f900 r5:00200000
r4:00000000
r6:00000000 r5:00200000 r4:8f900000
r7:d5871e28 r6:00000000 r5:d5871d48 r4:d72bc000
r8:d5871e28 r7:d5871e28 r6:00000000 r5:db232000 r4:d730a000
[<bf04d3c8>] (_ProcMgr_map+0x0/0x4ac [syslink]) from [<bf04d990>] (ProcMgr_map+0x11c/0x1b4 [syslink])
[<bf04d874>] (ProcMgr_map+0x0/0x1b4 [syslink]) from [<bf062984>] (Platform_loadCallback+0x4a0/0x7a0 [syslink])
[<bf0624e4>] (Platform_loadCallback+0x0/0x7a0 [syslink]) from [<bf096344>] (Ipc_control+0x68/0x14c [syslink])
[<bf0962dc>] (Ipc_control+0x0/0x14c [syslink]) from [<bf0cf81c>] (IpcDrv_drvioctl+0x68/0x298 [syslink])
r7:00000014 r6:bf143288 r5:c014f497 r4:41c39d4c
[<bf0cf7b4>] (IpcDrv_drvioctl+0x0/0x298 [syslink]) from [<c00dee44>] (vfs_ioctl+0x28/0x44)
r6:00000014 r5:d5f50100 r4:00000000
r8:c004cfa8 r7:00000036 r6:000cae80 r5:c014f497 r4:41c39d4c
---[ end trace ac7311448df3347d ]---
Thanks & Regards,
K.Amirtha Raj
