1080I60 Capture with OMX failure
I have copied and modified the OMX capture_encode example to only capture and display continuously (no encode).
If I configure the capture with -f 60  after a short and random period of time the capture/display stops.
The DM8148 locks up and a system reset is necessary.
If I configure the capture for with -f 30 the lock up will take much longer but will still occur.
Has anyone seen this problem?
John
OMX Version: omx_05_02_00_48
Video Input: 16bit YUV422 -> VIN0 port
Display      : 480x272 LCD
root@DVM8148:~/tools/tests# ./dvm_capture_display_a8host_debug.xv5T  -m 1080i -f 60  -d 1
frame_rate: 60
mode: 1080i
display_id: 1
 Capture-Display example
 OMX_Init completed
 UIAClient is ready to send a UIA configuration command
UIAClient received UIA_CONFIGURE_ACK
UIAClient is done sending requests
 capture component is created
Buffer Size computed: 2073600
set input port params (width = 1920, height = 1080)enable capture output port
got eventEnable/Disable Event
 dei component is created
set output port params (width = 1920, height = 1080)set output port params (width = 1920, height = 1080)set number of channelsset input resolutionset output resolutionenable dei input port
enable dei output port 0
enable dei output port 1
found handle 0x12c850 for component OMX.TI.VPSSM3.VFDC
 got display handle
found handle 0x130858 for component OMX.TI.VPSSM3.CTRL.DC
Buffer Size computed: 1036800
set input port params (width = 1920, height = 1080)setting input and output memory type to defaultenable input port
 connect call for capture-Dei
  connect call for dei-display
  Capture outport buffers allocated
 got eventState changed to: OMX_StateIdle
 Capture is in IDLE state
 Dei input port use buffer done
  DEI outport buffers allocated
 DEI is in IDLE state
 ctrl-dc state IDLE
  display buffers allocated
 waiting for IDLEgot eventState changed to: OMX_StateIdle
 display state IDLE
 got eventState changed to: OMX_StateExecuting
 display control state execute
 display state execute
 dei state execute
 capture state execute
  Clent exit thread created
  dei connect thread created
  capture connect thread created
  display connect thread created
  executing the application now!!
got event*** unrecoverable error: OMX_ErrorBadParameter (0x80001005)
Press a key to proceed
N:VPSS  P:2 #:45558 T:000000ba63e0aabb M:xdc.runtime.Main S:VIP-0 PORT-A Dropped Frame Count :43240 Total Capture Frame Count 67218
N:VPSS  P:2 #:45559 T:000000ba70dae21d M:xdc.runtime.Main S:VIP-0 PORT-A Dropped Frame Count :43241 Total Capture Frame Count 67250
N:VPSS  P:2 #:45560 T:000000bbb7cc7d33 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<_OMX_BASE_DIO_GroupGetMemberHandles> @line<898>
N:VPSS  P:2 #:45561 T:000000bbb7cd4a41 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<_OMX_BASE_DIO_GroupGetMemberHandles> @line<918> with error<0:ErrorNone>
N:VPSS  P:2 #:45562 T:000000bbb7cdd85d M:xdc.runtime.Main S: OMX Error in OMX_BASE_DIO_GroupGetCount :: line 1027
N:VPSS  P:2 #:45563 T:000000bbb7ce4413 M:xdc.runtime.Main S: OMX Error in _omx_get_iobuf_cnt :: line 2051
N:VPSS  P:2 #:45564 T:000000bbb7cea729 M:xdc.runtime.Main S: OMX Error in _omx_get_ready_process_channel_list :: line 3042
N:VPSS  P:2 #:45565 T:000000bbb7cf1595 M:xdc.runtime.Main S: OMX Error in OMX_TI_VFPC_DataNotify :: line 1509
N:VPSS  P:2 #:45566 T:000000bbeeb459c7 M:xdc.runtime.Main S:VIP-0 PORT-A Dropped Frame Count :43242 Total Capture Frame Count 68209
N:VPSS  P:2 #:45567 T:000000bd8d2ce055 M:xdc.runtime.Main S:VIP-0 PORT-A Dropped Frame Count :43243 Total Capture Frame Count 69250
N:VPSS  P:2 #:45568 T:000000bed6e60071 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<_OMX_BASE_DIO_GroupGetMemberHandles> @line<898>
N:VPSS  P:2 #:45569 T:000000bed6e6c3e9 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<_OMX_BASE_DIO_GroupGetMemberHandles> @line<918> with error<0:ErrorNone>
N:VPSS  P:2 #:45570 T:000000bed6e758ad M:xdc.runtime.Main S: OMX Error in OMX_BASE_DIO_GroupGetCount :: line 1027
N:VPSS  P:2 #:45571 T:000000bed6e7c011 M:xdc.runtime.Main S: OMX Error in _omx_get_iobuf_cnt :: line 2051
N:VPSS  P:2 #:45572 T:000000bed6e823bb M:xdc.runtime.Main S: OMX Error in _omx_get_ready_process_channel_list :: line 3042
N:VPSS  P:2 #:45573 T:000000bed6e89487 M:xdc.runtime.Main S: OMX Error in OMX_TI_VFPC_DataNotify :: line 1509
N:VPSS  P:2 #:45574 T:000000bf18f27947 M:xdc.runtime.Main S:VIP-0 PORT-A Dropped Frame Count :43244 Total Capture Frame Count 70244
N:VPSS  P:2 #:45575 T:000000c23572d3c3 M:xdc.runtime.Main S:VIP-0 PORT-A Dropped Frame Count :43245 Total Capture Frame Count 72245
N:VPSS  P:2 #:45576 T:000000c662d3aefd M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<_OMX_BASE_DIO_GroupGetMemberHandles> @line<898>
N:VPSS  P:2 #:45577 T:000000c662d47553 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<_OMX_BASE_DIO_GroupGetMemberHandles> @line<918> with error<0:ErrorNone>
N:VPSS  P:2 #:45578 T:000000c662d50635 M:xdc.runtime.Main S: OMX Error in OMX_BASE_DIO_GroupGetCount :: line 1027
N:VPSS  P:2 #:45579 T:000000c662d57309 M:xdc.runtime.Main S: OMX Error in _omx_get_iobuf_cnt :: line 2051
N:VPSS  P:2 #:45580 T:000000c662d5d759 M:xdc.runtime.Main S: OMX Error in _omx_get_ready_process_channel_list :: line 3042
N:VPSS  P:2 #:45581 T:000000c662d64939 M:xdc.runtime.Main S: OMX Error in OMX_TI_VFPC_DataNotify :: line 1509
N:VPSS  P:2 #:45582 T:000000c6dd8aa0cf M:xdc.runtime.Main S:VIP-0 PORT-A Dropped Frame Count :43246 Total Capture Frame Count 75241
N:VPSS  P:2 #:45583 T:000000cfca616c15 M:xdc.runtime.Main S:VIP-0 PORT-A Dropped Frame Count :43247 Total Capture Frame Count 80984
N:VPSS  P:2 #:45584 T:000000d15626d91b M:xdc.runtime.Main S:VIP-0 PORT-A Dropped Frame Count :43248 Total Capture Frame Count 81978
N:VPSS  P:2 #:45585 T:000000d78caae2d3 M:xdc.runtime.Main S:VIP-0 PORT-A Dropped Frame Count :43249 Total Capture Frame Count 85976
N:VPSS  P:2 #:45586 T:000000d884a2c61f M:xdc.runtime.Main S:VIP-0 PORT-A Dropped Frame Count :43250 Total Capture Frame Count 86598
N:VPSS  P:2 #:45587 T:000000d919657389 M:xdc.runtime.Main S:VIP-0 PORT-A Dropped Frame Count :43251 Total Capture Frame Count 86971
    What is the EZSDK version, that you are using here?
    What is the GP rev ?
    OMX_ErrorBadParameter means that one or more parameters were not valid.
    I will try to check this. I will let you know, when I have something.
    Margarita
  • Margarita
    I am using ti-ezsdk_dm814x-evm_5_05_02_00 with M3 firmware version 0x1000145
    The GP Rev is 2.1
    John
  • Hello John,
    Could you try capture_encode demo in EZSDK, is it work?
    Let me know the result.
    Margarita
  • Hi Margarita,
    I have tested this with the capture_encode in EZSDK and the failure is the same.
    We have also seen a similar error when running the decode_display demo with h264 elementary streams.
    John
  • Hello John,
    Are you using EVM or  custom board?
    Could you attach the log from decode_display demo? What is the output resolution ?
    Margarita
  • Hi Margarita,
    Our board is a custom board based on the DM8148-EVM. The live video input is from a SDI decoder.
    This decoder provides a 16-bit YCrCb interleaved output with embedded sync and is connected to
    VIN0 of the DM8148. The display is a 480x272 LCD. Functionally this is no different than the DM8148-EVM.
    The video is displayed correctly for both progressive and interlaced modes but for interlaced video the
    capture stops. If the capture starts with few frame drops then the it will run. If the capture starts with
    more frame drops then the logger will not log any more frames and video stops.
    If the demo is exited then the demo locks up the linux kernel. This is due the calls to tear down the M3
    components. We have traced this to the M3 VPSS hanging and locking up the system. There appears
    to be a bug in the M3 code.
    From the logs below you can compare the frame rate drop interval for both captures.
    The questions are:
    Why are there frame drops?
    If frame drops occur quickly why does the M3 VPSS lock-up and not recover?
    John
     --------------- DM8148 M3 Core locks up after short interval of frame drops at startup ---------
    N:VPSS  P:2 #:00991 T:0000000a3f44d61f M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFCC> Leaving<_OMX_BASE_EventNotifyToClient> @line<1172> with error<0:ErrorNone>
    N:VPSS  P:2 #:00994 T:0000000a3f4ab873 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_PROCESS_CmdCompleteEvent> @line<930> with error<0:ErrorNone>
    N:VPSS  P:2 #:00995 T:0000000a3f4b490b M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_CmdCompleteEventHandler> @line<496> with error<0:ErrorNone>
    N:VPSS  P:2 #:00996 T:0000000a3f4e84f5 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_CmdEventHandler> @line<434>
    N:VPSS  P:2 #:00997 T:0000000a3f4f274d M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_CmdEventHandler> @line<466> with error<0:ErrorNone>
    N:VPSS  P:2 #:00998 T:0000000a3f7d57f7 M:xdc.runtime.Main S:VIP-0 PORT-A Dropped Frame Count :1 Total Capture Frame Count 0
    N:VPSS  P:2 #:00999 T:0000000a400fb131 M:xdc.runtime.Main S:VIP-0 PORT-A Dropped Frame Count :2 Total Capture Frame Count 0
    N:VPSS  P:2 #:01000 T:0000000a40717a55 M:xdc.runtime.Main S:VIP-0 PORT-A Dropped Frame Count :3 Total Capture Frame Count 0
    N:VPSS  P:2 #:01001 T:0000000ba93c6df1 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<_OMX_BASE_DIO_GroupGetMemberHandles> @line<898>
    N:VPSS  P:2 #:01002 T:0000000ba93d32a7 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<_OMX_BASE_DIO_GroupGetMemberHandles> @line<918> with error<0:ErrorNone>
    N:VPSS  P:2 #:01003 T:0000000ba93de35f M:xdc.runtime.Main S: OMX Error in OMX_BASE_DIO_GroupSend :: line 970
    N:VPSS  P:2 #:01004 T:0000000ba93e4e9d M:xdc.runtime.Main S: OMX Error in _omx_send_iobufs :: line 671
    N:VPSS  P:2 #:01005 T:0000000ba93eaccb M:xdc.runtime.Main S: OMX Error in _omx_process_fvid_done_framelist :: line 914
    N:VPSS  P:2 #:01006 T:0000000ba93f16ed M:xdc.runtime.Main S: OMX Error in _OMX_VFPCDrvIfProcessDoneFcn :: line 1090
    N:VPSS  P:2 #:01007 T:0000000bb6dcb8b7 M:xdc.runtime.Main S:VIP-0 PORT-A Dropped Frame Count :4 Total Capture Frame Count 940
    N:VPSS  P:2 #:01008 T:0000000bdbaafe2f M:xdc.runtime.Main S:VIP-0 PORT-A Dropped Frame Count :5 Total Capture Frame Count 1032
    N:VPSS  P:2 #:01009 T:0000000bddc50f0b M:xdc.runtime.Main S:VIP-0 PORT-A Dropped Frame Count :6 Total Capture Frame Count 1036
    N:VPSS  P:2 #:01010 T:0000000be102271f M:xdc.runtime.Main S:VIP-0 PORT-A Dropped Frame Count :7 Total Capture Frame Count 1043
    N:VPSS  P:2 #:01011 T:0000000be6289d55 M:xdc.runtime.Main S:VIP-0 PORT-A Dropped Frame Count :8 Total Capture Frame Count 1055
    N:VPSS  P:2 #:01012 T:0000000be8d429ab M:xdc.runtime.Main S:VIP-0 PORT-A Dropped Frame Count :9 Total Capture Frame Count 1061
    N:VPSS  P:2 #:01013 T:0000000beaed49b1 M:xdc.runtime.Main S:VIP-0 PORT-A Dropped Frame Count :10 Total Capture Frame Count 1065
    N:VPSS  P:2 #:01014 T:0000000bf414eb27 M:xdc.runtime.Main S:VIP-0 PORT-A Dropped Frame Count :11 Total Capture Frame Count 1087
    N:VPSS  P:2 #:01015 T:0000000bf78430e7 M:xdc.runtime.Main S:VIP-0 PORT-A Dropped Frame Count :12 Total Capture Frame Count 1095
    N:VPSS  P:2 #:01016 T:0000000bfc48d8b5 M:xdc.runtime.Main S:VIP-0 PORT-A Dropped Frame Count :13 Total Capture Frame Count 1106
    ---------------- DM8148 M3 Core runs does not lockup but drops frames intermittently -----------------------------
    N:VPSS  P:2 #:00964 T:0000001bb3800417 M:xdc.runtime.Main S:Capture Driver Started!!
    N:VPSS  P:2 #:00965 T:0000001bb3809d34 M:xdc.runtime.Main S:Priming the buffers to the Capture Driver
    N:VPSS  P:2 #:00966 T:0000001bb3810091 M:xdc.runtime.Main S:Priming the buffers to the Capture Driver
    N:VPSS  P:2 #:00967 T:0000001bb3816203 M:xdc.runtime.Main S:Priming the buffers to the Capture Driver
    N:VPSS  P:2 #:00968 T:0000001bb381c19d M:xdc.runtime.Main S:Priming the buffers to the Capture Driver
    N:VPSS  P:2 #:00969 T:0000001bb38228df M:xdc.runtime.Main S:Priming the buffers to the Capture Driver
    N:VPSS  P:2 #:00970 T:0000001bb38289e5 M:xdc.runtime.Main S:Priming the buffers to the Capture Driver
    N:VPSS  P:2 #:00971 T:0000001bb382eab3 M:xdc.runtime.Main S:Priming the buffers to the Capture Driver
    N:VPSS  P:2 #:00972 T:0000001bb3834611 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_CB_ReturnEventNotify> @line<100>
    N:VPSS  P:2 #:00973 T:0000001bb383c3cd M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFCC> @<OMX_BASE_CB_ReturnEventNotify> @line<115> msg<Notify client for state transition>
    N:VPSS  P:2 #:00974 T:0000001bb384f7ad M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_CB_ReturnEventNotify> @line<224> with error<0:ErrorNone>
    N:VPSS  P:2 #:00975 T:0000001bb3858747 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFCC> Leaving<_OMX_BASE_HandleStateTransition> @line<483> with error<0:ErrorNone>
    N:VPSS  P:2 #:00976 T:0000001bb386138f M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_PROCESS_CmdEvent> @line<784> with error<0:ErrorNone>
    N:VPSS  P:2 #:00977 T:0000001bb3869975 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_CmdEventHandler> @line<466> with error<0:ErrorNone>
    N:VPSS  P:2 #:00978 T:0000001bb3872d91 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_CmdCompleteEventHandler> @line<483>
    N:VPSS  P:2 #:00979 T:0000001bb387a6b1 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_PROCESS_CmdCompleteEvent> @line<809>
    N:VPSS  P:2 #:00980 T:0000001bb3882587 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFCC> @<OMX_BASE_PROCESS_CmdCompleteEvent> @line<821> msg<Processing OMX_CommandStateSet>
    N:VPSS  P:2 #:00981 T:0000001bb388b4df M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFCC> Entering<_OMX_BASE_HandleStateTransitionComplete> @line<506>
    N:VPSS  P:2 #:00982 T:0000001bb389357a M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFCC> @<_OMX_BASE_HandleStateTransitionComplete> @line<614> msg<Idle to Executing Transition>
    N:VPSS  P:2 #:00983 T:0000001bb389c43d M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFCC> Leaving<_OMX_BASE_HandleStateTransitionComplete> @line<704> with error<0:ErrorNone>
    N:VPSS  P:2 #:00984 T:0000001bb38a5109 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFCC> Entering<_OMX_BASE_EventNotifyToClient> @line<881>
    N:VPSS  P:2 #:00986 T:0000001bb391ee39 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_GetParameter> @line<695>
    N:VPSS  P:2 #:00987 T:0000001bb3929c45 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_GetParameter> @line<858> with error<0:ErrorNone>
    N:VPSS  P:2 #:00988 T:0000001bb3940025 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_GetParameter> @line<695>
    N:VPSS  P:2 #:00989 T:0000001bb3949cbf M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_GetParameter> @line<858> with error<0:ErrorNone>
    N:VPSS  P:2 #:00985 T:0000001bb3905d47 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_DIO_Control> @line<455>
    N:VPSS  P:2 #:00990 T:0000001bb3a19991 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_DIO_Control> @line<463> with error<0:ErrorNone>
    N:VPSS  P:2 #:00991 T:0000001bb3abc15f M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFCC> Leaving<_OMX_BASE_EventNotifyToClient> @line<1172> with error<0:ErrorNone>
    N:VPSS  P:2 #:00992 T:0000001bb3ac6b9f M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_PROCESS_CmdCompleteEvent> @line<930> with error<0:ErrorNone>
    N:VPSS  P:2 #:00993 T:0000001bb3acfc31 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_CmdCompleteEventHandler> @line<496> with error<0:ErrorNone>
    N:VPSS  P:2 #:00994 T:0000001bb3b89307 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_GetParameter> @line<695>
    N:VPSS  P:2 #:00995 T:0000001bb3b94c07 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_GetParameter> @line<858> with error<0:ErrorNone>
    N:VPSS  P:2 #:00996 T:0000001bb3bc2285 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_CmdEventHandler> @line<434>
    N:VPSS  P:2 #:00997 T:0000001bb3bcbbcd M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_CmdEventHandler> @line<466> with error<0:ErrorNone>
    N:VPSS  P:2 #:00998 T:0000001bb3e6ae41 M:xdc.runtime.Main S:VIP-0 PORT-A Dropped Frame Count :1 Total Capture Frame Count 0
    N:VPSS  P:2 #:00999 T:0000001bb4795407 M:xdc.runtime.Main S:VIP-0 PORT-A Dropped Frame Count :2 Total Capture Frame Count 0
    N:VPSS  P:2 #:01000 T:0000001bb4dad7bf M:xdc.runtime.Main S:VIP-0 PORT-A Dropped Frame Count :3 Total Capture Frame Count 0
    N:VPSS  P:2 #:01001 T:000000241ed2e725 M:xdc.runtime.Main S:VIP-0 PORT-A Dropped Frame Count :4 Total Capture Frame Count 5414
    N:VPSS  P:2 #:01002 T:00000028c68dccfd M:xdc.runtime.Main S:VIP-0 PORT-A Dropped Frame Count :5 Total Capture Frame Count 8409
    N:VPSS  P:2 #:01003 T:0000002adc056117 M:xdc.runtime.Main S:VIP-0 PORT-A Dropped Frame Count :6 Total Capture Frame Count 9749
    N:VPSS  P:2 #:01004 T:0000003094dd4399 M:xdc.runtime.Main S:VIP-0 PORT-A Dropped Frame Count :7 Total Capture Frame Count 13431
    N:VPSS  P:2 #:01005 T:000000366498ae9f M:xdc.runtime.Main S:VIP-0 PORT-A Dropped Frame Count :8 Total Capture Frame Count 17170
    N:VPSS  P:2 #:01006 T:0000003b12ffc099 M:xdc.runtime.Main S:VIP-0 PORT-A Dropped Frame Count :9 Total Capture Frame Count 20182
    N:VPSS  P:2 #:01007 T:0000003b6c3f5b03 M:xdc.runtime.Main S:VIP-0 PORT-A Dropped Frame Count :10 Total Capture Frame Count 20405
    N:VPSS  P:2 #:01008 T:0000003c9ec43a7d M:xdc.runtime.Main S:VIP-0 PORT-A Dropped Frame Count :11 Total Capture Frame Count 21175
    N:VPSS  P:2 #:01009 T:0000004014571947 M:xdc.runtime.Main S:VIP-0 PORT-A Dropped Frame Count :12 Total Capture Frame Count 23400
    N:VPSS  P:2 #:01010 T:00000045f1ce1c65 M:xdc.runtime.Main S:VIP-0 PORT-A Dropped Frame Count :13 Total Capture Frame Count 27174
    N:VPSS  P:2 #:01011 T:00000045f22fca84 M:xdc.runtime.Main S:VIP-0 PORT-A Dropped Frame Count :14 Total Capture Frame Count 27174
    N:VPSS  P:2 #:01012 T:00000046430f1bb5 M:xdc.runtime.Main S:VIP-0 PORT-A Dropped Frame Count :15 Total Capture Frame Count 27376
    N:VPSS  P:2 #:01013 T:00000046e15e3a21 M:xdc.runtime.Main S:VIP-0 PORT-A Dropped Frame Count :16 Total Capture Frame Count 27773
    N:VPSS  P:2 #:01014 T:00000048ba332a7b M:xdc.runtime.Main S:VIP-0 PORT-A Dropped Frame Count :17 Total Capture Frame Count 28961
    N:VPSS  P:2 #:01015 T:0000004b03c183eb M:xdc.runtime.Main S:VIP-0 PORT-A Dropped Frame Count :18 Total Capture Frame Count 30432
    N:VPSS  P:2 #:01016 T:0000004b05da7d27 M:xdc.runtime.Main S:VIP-0 PORT-A Dropped Frame Count :19 Total Capture Frame Count 30436
    N:VPSS  P:2 #:01017 T:0000004b5563fe69 M:xdc.runtime.Main S:VIP-0 PORT-A Dropped Frame Count :20 Total Capture Frame Count 30635
    N:VPSS  P:2 #:01018 T:0000004ba42a5205 M:xdc.runtime.Main S:VIP-0 PORT-A Dropped Frame Count :21 Total Capture Frame Count 30832
    N:VPSS  P:2 #:01019 T:0000004cdf1128e1 M:xdc.runtime.Main S:VIP-0 PORT-A Dropped Frame Count :22 Total Capture Frame Count 31623
    N:VPSS  P:2 #:01020 T:0000004d712b6c59 M:xdc.runtime.Main S:VIP-0 PORT-A Dropped Frame Count :23 Total Capture Frame Count 31989
    N:VPSS  P:2 #:01021 T:0000004e07d9be3b M:xdc.runtime.Main S:VIP-0 PORT-A Dropped Frame Count :24 Total Capture Frame Count 32367
    N:VPSS  P:2 #:01022 T:0000004e4fc1eed5 M:xdc.runtime.Main S:VIP-0 PORT-A Dropped Frame Count :25 Total Capture Frame Count 32547
    N:VPSS  P:2 #:01023 T:00000050300705bd M:xdc.runtime.Main S:VIP-0 PORT-A Dropped Frame Count :26 Total Capture Frame Count 33753
    N:VPSS  P:2 #:01024 T:000000507cb42485 M:xdc.runtime.Main S:VIP-0 PORT-A Dropped Frame Count :27 Total Capture Frame Count 33945
    N:VPSS  P:2 #:01025 T:000000516c48eeeb M:xdc.runtime.Main S:VIP-0 PORT-A Dropped Frame Count :28 Total Capture Frame Count 34546
    N:VPSS  P:2 #:01026 T:000000520a9370b7 M:xdc.runtime.Main S:VIP-0 PORT-A Dropped Frame Count :29 Total Capture Frame Count 34943
    N:VPSS  P:2 #:01027 T:000000538cd6ddb7 M:xdc.runtime.Main S:VIP-0 PORT-A Dropped Frame Count :30 Total Capture Frame Count 35913
    N:VPSS  P:2 #:01028 T:0000005399058557 M:xdc.runtime.Main S:VIP-0 PORT-A Dropped Frame Count :31 Total Capture Frame Count 35943
    N:VPSS  P:2 #:01029 T:00000053ea46bedd M:xdc.runtime.Main S:VIP-0 PORT-A Dropped Frame Count :32 Total Capture Frame Count 36146
    N:VPSS  P:2 #:01030 T:00000053eaa7cd58 M:xdc.runtime.Main S:VIP-0 PORT-A Dropped Frame Count :33 Total Capture Frame Count 36146
    N:VPSS  P:2 #:01031 T:000000552ba986e7 M:xdc.runtime.Main S:VIP-0 PORT-A Dropped Frame Count :34 Total Capture Frame Count 36952
    N:VPSS  P:2 #:01032 T:0000005576116d09 M:xdc.runtime.Main S:VIP-0 PORT-A Dropped Frame Count :35 Total Capture Frame Count 37138
