Other Parts Discussed in Thread: TMS320VC5505
Hello Everyone,
I am using the TMS320VC5505 EzDSP board and am having an issue using the uart port on the expansion header. I set up the project to use the CSL 2.5 library and have based the uart setup off of the polled uart example provided in the CSL folder. Currently i can successfully write over the uart port but when I attempt to read data the function fails and returns
#include <stdio.h>
#include "csl_uart.h"
#include "csl_uartAux.h"
#include "csl_general.h"
#include "usbstk5505_uart.h"
/* This file contains all functions required to initalize and communicate with the uart module
CSL_Status init_uart(CSL_UartHandle *uartH)
//uart initalization stuct
CSL_UartSetup Params = {
100000000, /* input clock freq */
115200, /* baud rate */
CSL_UART_WORD8, /* word length */
1, /* stop bits */
CSL_UART_DISABLE_PARITY, /* parity */
CSL_UART_FIFO_DISABLE,
/* Loop Back enable */
CSL_UART_NO_LOOPBACK,
/* No auto flow control*/
CSL_UART_NO_AFE ,
/* No RTS */
CSL_UART_NO_RTS ,
CSL_Status status; //status
CSL_UartObj uartObj; //uart object
//call uart init function
status = UART_init(&uartObj,CSL_UART_INST_0,UART_POLLED);
if(CSL_SOK != status)
printf("UART_init failed error code %d\n",status);
return(status);
else
printf("UART_init Successful\n");
*uartH = (CSL_UartHandle)(&uartObj);
//call setup function
status = UART_setup(*uartH,&Params);
printf("UART_setup failed error code %d\n",status);
return(status);
else
printf("UART_setup Successful\n");
return CSL_SOK;
/* FILENAME */
/* main.c */
/* DESCRIPTION */
/* TMS320C5505 USB Stick. Application 1. Getting started. */
/* Take microphone input and send to headphones. */
/* REVISION */
/* Revision: 1.00 */
/* Author : Richard Sikora */
/* HISTORY */
/* 5th March 2010. Created by Richard Sikora from TMS320C5510 DSK code. */
* Copyright (C) 2010 Texas Instruments Incorporated - http://www.ti.com/
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the
* distribution.
* Neither the name of Texas Instruments Incorporated nor the names of
* its contributors may be used to endorse or promote products derived
* from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
* "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
* LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
* A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
* OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
* SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
* DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
* THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
* OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
#include "stdio.h"
#include "usbstk5505.h"
#include "aic3204.h"
#include "PLL.h"
#include "stereo.h"
Int16 left_input;
Int16 right_input;
Int16 left_output;
Int16 right_output;
Int16 mono_input;
#define SAMPLES_PER_SECOND 48000
unsigned long int i = 0;
CSL_Status uartStatus;
CSL_UartHandle uartHandle;
char inputUartBuffer[30];
char outputUartBuffer[30];
* main( ) *
void main( void )
/* Initialize BSL */
USBSTK5505_init( );
/* Initialize PLL */
pll_frequency_setup(100);
/* Initialise hardware interface and I2C for code */
aic3204_hardware_init();
/* Initialise the AIC3204 codec */
aic3204_init();
/* Setup sampling frequency and 30dB gain for microphone */
set_sampling_frequency_and_gain(SAMPLES_PER_SECOND, 1);
// initilize UART
init_uart(&uartHandle);
//main loop
while(1)
printf("please enter message\n");
scanf("%s",inputUartBuffer);
printf("sending %s",inputUartBuffer);
uartStatus = UART_fputs(uartHandle,inputUartBuffer,0);
if(CSL_SOK != uartStatus)
printf("UART_fputs failed error code %d\n",uartStatus);
/* this is failing!!!, once it fails the write function stops working*/
uartStatus = UART_read(uartHandle,outputUartBuffer,2,0);
printf("UART_read failed error code %d\n",uartStatus);
* End of main.c *
John
