Other Parts Discussed in Thread: AM3354
Dear Sir,
I am trying to interface SD card to AM3354 using starterware example file. with these example file I am able to find the sd card and its contents.
Now I am trying to data in to this SD card using MMCSDWriteCmdSend function( mmcsd_proto.c ). While debuging using XDS100 V2 the cursor is jumping some where else. where it is going exactly i am not able to find and the remaining code is also not working.
give ur best suggestion to clear this issue.
* \file hs_mmcsd_rw.c
* \brief Sample application for HS MMCSD
* Copyright (C) 2010 Texas Instruments Incorporated - http://www.ti.com/
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the
* distribution.
* Neither the name of Texas Instruments Incorporated nor the names of
* its contributors may be used to endorse or promote products derived
* from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
* "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
* LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
* A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
* OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
* SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
* DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
* THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
* OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
#include "mmcsd_proto.h"
#include "hs_mmcsdlib.h"
#include "evmskAM335x.h"
#include "edma_event.h"
#include "soc_AM335x.h"
#include "interrupt.h"
#include "uartStdio.h"
#include "hs_mmcsd.h"
#include "string.h"
#include "delay.h"
#include "cache.h"
#include "edma.h"
#include "mmu.h"
#ifdef MMCSD_PERF
#include "perf.h"
#endif
** INTERNAL MACRO DEFINITIONS
/* Frequency */
#define HSMMCSD_IN_FREQ 96000000 /* 96MHz */
#define HSMMCSD_INIT_FREQ 400000 /* 400kHz */
#define HSMMCSD_CARD_DETECT_PINNUM 6
/* EDMA3 Event queue number. */
#define EVT_QUEUE_NUM 0
/* EDMA3 Region Number. */
#define REGION_NUMBER 0
/* Block size config */
#define HSMMCSD_BLK_SIZE 512
#define HSMMCSD_RW_BLK 1
/* Global data pointers */
#define HSMMCSD_DATA_SIZE 512
/* GPIO instance related macros. */
#define GPIO_INST_BASE (SOC_GPIO_0_REGS)
/* MMCSD instance related macros. */
#define MMCSD_INST_BASE (SOC_MMCHS_0_REGS)
#define MMCSD_INT_NUM (SYS_INT_MMCSD0INT)
/* EDMA instance related macros. */
#define EDMA_INST_BASE (SOC_EDMA30CC_0_REGS)
#define EDMA_COMPLTN_INT_NUM (SYS_INT_EDMACOMPINT)
#define EDMA_ERROR_INT_NUM (SYS_INT_EDMAERRINT)
/* EDMA Events */
#define MMCSD_TX_EDMA_CHAN (EDMA3_CHA_MMCSD0_TX)
#define MMCSD_RX_EDMA_CHAN (EDMA3_CHA_MMCSD0_RX)
/* MMU related macros. */
#define START_ADDR_OCMC 0x40300000
#define START_ADDR_DDR 0x80000000
#define START_ADDR_DEV 0x44000000
#define NUM_SECTIONS_DDR 512
#define NUM_SECTIONS_DEV 960
#define NUM_SECTIONS_OCMC 1
/* SD card info structure */
mmcsdCardInfo sdCard;
/* SD Controller info structure */
mmcsdCtrlInfo ctrlInfo;
** FUNCTION PROTOTYPES
extern void HSMMCSDFsMount(unsigned int driveNum, void *ptr);
extern void HSMMCSDFsProcessCmdLine(void);
extern int Cmd_help(int argc, char *argv[]);
//extern unsigned int MMCSDWriteCmdSend(mmcsdCtrlInfo *ctrl, void *ptr, unsigned int block,
// unsigned int nblks);
/* EDMA callback function array */
static void (*cb_Fxn[EDMA3_NUM_TCC]) (unsigned int tcc, unsigned int status);
** VARIABLE DEFINITIONS
/* Global flags for interrupt handling */
volatile unsigned int sdBlkSize = HSMMCSD_BLK_SIZE;
volatile unsigned int callbackOccured = 0;
volatile unsigned int xferCompFlag = 0;
volatile unsigned int dataTimeout = 0;
volatile unsigned int cmdCompFlag = 0;
volatile unsigned int cmdTimeout = 0;
volatile unsigned int errFlag = 0;
unsigned char vru[10] = {'v','e','e','r','a','s','w','a','m','y'};
#ifdef __IAR_SYSTEMS_ICC__
#pragma data_alignment=SOC_CACHELINE_SIZE
unsigned char data[HSMMCSD_DATA_SIZE];
#elif defined(__TMS470__)
#pragma DATA_ALIGN(data, SOC_CACHELINE_SIZE);
#elif defined(gcc)
__attribute__ ((aligned (SOC_CACHELINE_SIZE)))= {0};
#else
#error "Unsupported Compiler. \r\n"
#endif
/* page tables start must be aligned in 16K boundary */ //
#ifdef __TMS470__
#pragma DATA_ALIGN(pageTable, MMU_PAGETABLE_ALIGN_SIZE);
static volatile unsigned int pageTable[MMU_PAGETABLE_NUM_ENTRY];
#elif defined(__IAR_SYSTEMS_ICC__)
#pragma data_alignment=MMU_PAGETABLE_ALIGN_SIZE
#elif defined(gcc)
__attribute__((aligned(MMU_PAGETABLE_ALIGN_SIZE)));
#else
#endif
** FUNCTION DEFINITIONS
** This function will setup the MMU. The function maps three regions -
** 1. DDR
** 2. OCMC RAM
** 3. Device memory
** The function also enables the MMU.
void MMUConfigAndEnable(void)
** Define DDR memory region of AM335x. DDR can be configured as Normal
** memory with R/W access in user/privileged modes. The cache attributes
** specified here are,
** Inner - Write through, No Write Allocate
** Outer - Write Back, Write Allocate
REGION regionDdr = {
MMU_PGTYPE_SECTION, START_ADDR_DDR, NUM_SECTIONS_DDR,
MMU_MEMTYPE_NORMAL_NON_SHAREABLE(MMU_CACHE_WT_NOWA,
MMU_CACHE_WB_WA),
MMU_REGION_NON_SECURE, MMU_AP_PRV_RW_USR_RW,
(unsigned int*)pageTable
** Define OCMC RAM region of AM335x. Same Attributes of DDR region given.
REGION regionOcmc = {
MMU_PGTYPE_SECTION, START_ADDR_OCMC, NUM_SECTIONS_OCMC,
MMU_CACHE_WB_WA),
** Define Device Memory Region. The region between OCMC and DDR is
** configured as device memory, with R/W access in user/privileged modes.
** Also, the region is marked 'Execute Never'.
REGION regionDev = {
MMU_PGTYPE_SECTION, START_ADDR_DEV, NUM_SECTIONS_DEV,
MMU_MEMTYPE_DEVICE_SHAREABLE,
MMU_AP_PRV_RW_USR_RW | MMU_SECTION_EXEC_NEVER,
/* Initialize the page table and MMU */
MMUInit((unsigned int*)pageTable);
/* Map the defined regions */
MMUMemRegionMap(®ionDdr);
MMUMemRegionMap(®ionOcmc);
MMUMemRegionMap(®ionDev);
/* Now Safe to enable MMU */
MMUEnable((unsigned int*)pageTable);
* Check command status
static unsigned int HSMMCSDCmdStatusGet(mmcsdCtrlInfo *ctrl)
unsigned int status = 0;
while ((cmdCompFlag == 0) && (cmdTimeout == 0));
if (cmdCompFlag)
status = 1;
cmdCompFlag = 0;
if (cmdTimeout)
status = 0;
cmdTimeout = 0;
return status;
static unsigned int HSMMCSDXferStatusGet(mmcsdCtrlInfo *ctrl)
volatile unsigned int timeOut = 0xFFFF;
while ((xferCompFlag == 0) && (dataTimeout == 0));
if (xferCompFlag)
status = 1;
xferCompFlag = 0;
if (dataTimeout)
status = 0;
dataTimeout = 0;
/* Also, poll for the callback */
if (HWREG(ctrl->memBase + MMCHS_CMD) & MMCHS_CMD_DP)
while(callbackOccured == 0 && ((timeOut--) != 0));
if(timeOut == 0)
status = 0;
ctrlInfo.dmaEnable = 0;
return status;
void HSMMCSDRxDmaConfig(void *ptr, unsigned int blkSize, unsigned int nblks)
EDMA3CCPaRAMEntry paramSet;
paramSet.srcAddr = ctrlInfo.memBase + MMCHS_DATA;
paramSet.destAddr = (unsigned int)ptr;
paramSet.srcBIdx = 0;
paramSet.srcCIdx = 0;
paramSet.destBIdx = 4;
paramSet.destCIdx = (unsigned short)blkSize;
paramSet.aCnt = 0x4;
paramSet.bCnt = (unsigned short)blkSize/4;
paramSet.cCnt = (unsigned short)nblks;
paramSet.bCntReload = 0x0;
paramSet.linkAddr = 0xffff;
paramSet.opt = 0;
/* Set OPT */
paramSet.opt |= ((MMCSD_RX_EDMA_CHAN << EDMA3CC_OPT_TCC_SHIFT) & EDMA3CC_OPT_TCC);
/* 1. Transmission complition interrupt enable */
paramSet.opt |= (1 << EDMA3CC_OPT_TCINTEN_SHIFT);
/* 2. Read FIFO : SRC Constant addr mode */
paramSet.opt |= (1 << 0);
/* 3. SRC FIFO width is 32 bit */
paramSet.opt |= (2 << 8);
/* 4. AB-Sync mode */
paramSet.opt |= (1 << 2);
/* configure PaRAM Set */
EDMA3SetPaRAM(EDMA_INST_BASE, MMCSD_RX_EDMA_CHAN, ¶mSet);
/* Enable the transfer */
EDMA3EnableTransfer(EDMA_INST_BASE, MMCSD_RX_EDMA_CHAN, EDMA3_TRIG_MODE_EVENT);
void HSMMCSDTxDmaConfig(void *ptr, unsigned int blkSize, unsigned int blks)
paramSet.srcAddr = (unsigned int)ptr;
paramSet.destAddr = ctrlInfo.memBase + MMCHS_DATA;
paramSet.srcBIdx = 4;
paramSet.srcCIdx = blkSize;
paramSet.destBIdx = 0;
paramSet.destCIdx = 0;
paramSet.cCnt = (unsigned short)blks;
paramSet.opt = 0;
/* Set OPT */
paramSet.opt |= ((MMCSD_TX_EDMA_CHAN << EDMA3CC_OPT_TCC_SHIFT) & EDMA3CC_OPT_TCC);
/* 2. Read FIFO : DST Constant addr mode */
paramSet.opt |= (1 << 1);
/* 3. DST FIFO width is 32 bit */
EDMA3SetPaRAM(EDMA_INST_BASE, MMCSD_TX_EDMA_CHAN, ¶mSet);
EDMA3EnableTransfer(EDMA_INST_BASE, MMCSD_TX_EDMA_CHAN, EDMA3_TRIG_MODE_EVENT);
static void HSMMCSDXferSetup(mmcsdCtrlInfo *ctrl, unsigned char rwFlag, void *ptr,
unsigned int blkSize, unsigned int nBlks)
xferCompFlag = 0;
if (rwFlag == 1)
HSMMCSDRxDmaConfig(ptr, blkSize, nBlks);
else
HSMMCSDTxDmaConfig(ptr, blkSize, nBlks);
ctrl->dmaEnable = 1;
HSMMCSDBlkLenSet(ctrl->memBase, blkSize);
** This function is used as a callback from EDMA3 Completion Handler.
static void callback(unsigned int tccNum, unsigned int status)
callbackOccured = 1;
EDMA3DisableTransfer(EDMA_INST_BASE, tccNum, EDMA3_TRIG_MODE_EVENT);
static void Edma3CompletionIsr(void)
volatile unsigned int pendingIrqs;
volatile unsigned int isIPR = 0;
unsigned int indexl;
unsigned int Cnt = 0;
indexl = 1;
isIPR = EDMA3GetIntrStatus(EDMA_INST_BASE);
if(isIPR)
while ((Cnt < EDMA3CC_COMPL_HANDLER_RETRY_COUNT)&& (indexl != 0u))
indexl = 0u;
pendingIrqs = EDMA3GetIntrStatus(EDMA_INST_BASE);
while (pendingIrqs)
if((pendingIrqs & 1u) == TRUE)
* If the user has not given any callback function
* while requesting the TCC, its TCC specific bit
* in the IPR register will NOT be cleared.
/* here write to ICR to clear the corresponding IPR bits */
EDMA3ClrIntr(EDMA_INST_BASE, indexl);
if (cb_Fxn[indexl] != NULL)
(*cb_Fxn[indexl])(indexl, EDMA3_XFER_COMPLETE);
++indexl;
pendingIrqs >>= 1u;
Cnt++;
static void Edma3CCErrorIsr(void)
volatile unsigned int evtqueNum = 0; /* Event Queue Num */
volatile unsigned int isIPRH = 0;
volatile unsigned int Cnt = 0u;
volatile unsigned int index;
pendingIrqs = 0u;
index = 1u;
isIPRH = EDMA3IntrStatusHighGet(EDMA_INST_BASE);
if((isIPR | isIPRH ) || (EDMA3QdmaGetErrIntrStatus(EDMA_INST_BASE) != 0)
|| (EDMA3GetCCErrStatus(EDMA_INST_BASE) != 0))
/* Loop for EDMA3CC_ERR_HANDLER_RETRY_COUNT number of time,
* breaks when no pending interrupt is found
while ((Cnt < EDMA3CC_ERR_HANDLER_RETRY_COUNT)
&& (index != 0u))
index = 0u;
if(isIPR)
pendingIrqs = EDMA3GetErrIntrStatus(EDMA_INST_BASE);
else
pendingIrqs = EDMA3ErrIntrHighStatusGet(EDMA_INST_BASE);
while (pendingIrqs)
/*Process all the pending interrupts*/
if(TRUE == (pendingIrqs & 1u))
/* Write to EMCR to clear the corresponding EMR bits.
/*Clear any SER*/
if(isIPR)
EDMA3ClrMissEvt(EDMA_INST_BASE, index);
else
EDMA3ClrMissEvt(EDMA_INST_BASE, index + 32);
++index;
pendingIrqs >>= 1u;
index = 0u;
pendingIrqs = EDMA3QdmaGetErrIntrStatus(EDMA_INST_BASE);
while (pendingIrqs)
/* Here write to QEMCR to clear the corresponding QEMR bits*/
/*Clear any QSER*/
EDMA3QdmaClrMissEvt(EDMA_INST_BASE, index);
++index;
pendingIrqs >>= 1u;
index = 0u;
pendingIrqs = EDMA3GetCCErrStatus(EDMA_INST_BASE);
if (pendingIrqs != 0u)
/* Process all the pending CC error interrupts. */
/* Queue threshold error for different event queues.*/
for (evtqueNum = 0u; evtqueNum < SOC_EDMA3_NUM_EVQUE; evtqueNum++)
if((pendingIrqs & (1u << evtqueNum)) != 0u)
/* Clear the error interrupt. */
EDMA3ClrCCErr(EDMA_INST_BASE, (1u << evtqueNum));
/* Transfer completion code error. */
if ((pendingIrqs & (1 << EDMA3CC_CCERR_TCCERR_SHIFT)) != 0u)
(0x01u << EDMA3CC_CCERR_TCCERR_SHIFT));
++index;
Cnt++;
static void HSMMCSDIsr(void)
volatile unsigned int status = 0;
status = HSMMCSDIntrStatusGet(ctrlInfo.memBase, 0xFFFFFFFF);
HSMMCSDIntrStatusClear(ctrlInfo.memBase, status);
if (status & HS_MMCSD_STAT_CMDCOMP)
cmdCompFlag = 1;
if (status & HS_MMCSD_STAT_ERR)
errFlag = status & 0xFFFF0000;
if (status & HS_MMCSD_STAT_CMDTIMEOUT)
cmdTimeout = 1;
if (status & HS_MMCSD_STAT_DATATIMEOUT)
dataTimeout = 1;
if (status & HS_MMCSD_STAT_TRNFCOMP)
xferCompFlag = 1;
** This function configures the AINTC to receive EDMA3 interrupts.
static void EDMA3AINTCConfigure(void)
/* Initializing the ARM Interrupt Controller. */
IntAINTCInit();
/* Registering EDMA3 Channel Controller transfer completion interrupt. */
IntRegister(EDMA_COMPLTN_INT_NUM, Edma3CompletionIsr);
/* Setting the priority for EDMA3CC completion interrupt in AINTC. */
IntPrioritySet(EDMA_COMPLTN_INT_NUM, 0, AINTC_HOSTINT_ROUTE_IRQ);
/* Registering EDMA3 Channel Controller Error Interrupt. */
IntRegister(EDMA_ERROR_INT_NUM, Edma3CCErrorIsr);
/* Setting the priority for EDMA3CC Error interrupt in AINTC. */
IntPrioritySet(EDMA_ERROR_INT_NUM, 0, AINTC_HOSTINT_ROUTE_IRQ);
/* Enabling the EDMA3CC completion interrupt in AINTC. */
IntSystemEnable(EDMA_COMPLTN_INT_NUM);
/* Enabling the EDMA3CC Error interrupt in AINTC. */
IntSystemEnable(EDMA_ERROR_INT_NUM);
/* Registering HSMMC Interrupt handler */
IntRegister(MMCSD_INT_NUM, HSMMCSDIsr);
IntPrioritySet(MMCSD_INT_NUM, 0, AINTC_HOSTINT_ROUTE_IRQ);
/* Enabling the HSMMC interrupt in AINTC. */
IntSystemEnable(MMCSD_INT_NUM);
/* Enabling IRQ in CPSR of ARM processor. */
IntMasterIRQEnable();
** Powering up, initializing and registering interrupts for EDMA.
static void EDMA3Initialize(void)
/* Initialization of EDMA3 */
EDMA3Init(EDMA_INST_BASE, EVT_QUEUE_NUM);
/* Configuring the AINTC to receive EDMA3 interrupts. */
EDMA3AINTCConfigure();
static void HSMMCSDEdmaInit(void)
/* Initializing the EDMA. */
EDMA3Initialize();
/* Request DMA Channel and TCC for MMCSD Transmit*/
EDMA3RequestChannel(EDMA_INST_BASE, EDMA3_CHANNEL_TYPE_DMA,
MMCSD_TX_EDMA_CHAN, MMCSD_TX_EDMA_CHAN,
EVT_QUEUE_NUM);
/* Registering Callback Function for TX*/
cb_Fxn[MMCSD_TX_EDMA_CHAN] = &callback;
/* Request DMA Channel and TCC for UART Receive */
MMCSD_RX_EDMA_CHAN, MMCSD_RX_EDMA_CHAN,
EVT_QUEUE_NUM);
/* Registering Callback Function for RX*/
cb_Fxn[MMCSD_RX_EDMA_CHAN] = &callback;
** Initialize the MMCSD controller structure for use
static void HSMMCSDControllerSetup(void)
ctrlInfo.memBase = MMCSD_INST_BASE;
ctrlInfo.ctrlInit = HSMMCSDControllerInit;
ctrlInfo.xferSetup = HSMMCSDXferSetup;
ctrlInfo.cmdStatusGet = HSMMCSDCmdStatusGet;
ctrlInfo.xferStatusGet = HSMMCSDXferStatusGet;
/* Use the funciton HSMMCSDCDPinStatusGet() to use the card presence
using the controller.
ctrlInfo.cardPresent = HSMMCSDCardPresent;
ctrlInfo.cmdSend = HSMMCSDCmdSend;
ctrlInfo.busWidthConfig = HSMMCSDBusWidthConfig;
ctrlInfo.busFreqConfig = HSMMCSDBusFreqConfig;
ctrlInfo.intrMask = (HS_MMCSD_INTR_CMDCOMP | HS_MMCSD_INTR_CMDTIMEOUT |
HS_MMCSD_INTR_DATATIMEOUT | HS_MMCSD_INTR_TRNFCOMP);
ctrlInfo.intrEnable = HSMMCSDIntEnable;
ctrlInfo.busWidth = (SD_BUS_WIDTH_1BIT | SD_BUS_WIDTH_4BIT);
ctrlInfo.highspeed = 1;
ctrlInfo.ocr = (SD_OCR_VDD_3P0_3P1 | SD_OCR_VDD_3P1_3P2);
ctrlInfo.card = &sdCard;
ctrlInfo.ipClk = HSMMCSD_IN_FREQ;
ctrlInfo.opClk = HSMMCSD_INIT_FREQ;
ctrlInfo.cdPinNum = HSMMCSD_CARD_DETECT_PINNUM;
sdCard.ctrl = &ctrlInfo;
xferCompFlag = 0;
dataTimeout = 0;
cmdCompFlag = 0;
cmdTimeout = 0;
int main(void)
volatile unsigned int i = 0;
volatile unsigned int initFlg = 1;
/* Setup the MMU and do necessary MMU configurations. */
MMUConfigAndEnable();
/* Enable all levels of CACHE. */
CacheEnable(CACHE_ALL);
/* Initialize UART. */
UARTStdioInit();
/* Configure the EDMA clocks. */
EDMAModuleClkConfig();
/* Configure EDMA to service the HSMMCSD events. */
HSMMCSDEdmaInit();
/* Perform pin-mux for HSMMCSD pins. */
HSMMCSDPinMuxSetup();
/* Enable module clock for HSMMCSD. */
HSMMCSDModuleClkConfig();
/* Basic controller initializations */
HSMMCSDControllerSetup();
DelayTimerSetup();
#ifdef MMCSD_PERF
PerfTimerSetup();
#endif
/* Initialize the MMCSD controller */
MMCSDCtrlInit(&ctrlInfo);
MMCSDIntEnable(&ctrlInfo);
while(1)
UARTPuts("Write command to SD Card \n\r", -1);
MMCSDWriteCmdSend(0,vru,1,10);
UARTPuts("Write Completed\n\r", -1);
if((HSMMCSDCardPresent(&ctrlInfo)) == 1)
if(initFlg)
HSMMCSDFsMount(0, &sdCard);
initFlg = 0;
Cmd_help(0, NULL);
HSMMCSDFsProcessCmdLine();
else
delay(1);
i = (i + 1) & 0xFFF;
if(i == 1)
UARTPuts("Please insert the card \n\r", -1);
if(initFlg != 1)
/* Reinitialize all the state variables */
xferCompFlag = 0;
dataTimeout = 0;
cmdCompFlag = 0;
cmdTimeout = 0;
initFlg = 1;
Thanks & Regards,
Veeraswamy
