AM3359 Powerlink support
Other Parts Discussed in Thread: TLK110, AM3359
Hi all,
         I see schematic for AM3359 IDK daughter board is using PRUSS for industrial ethernet PHY being used is TLK110.
I see that Pin 42 MII_COL is pulled low. I just wanted to know if this configuration is ok for Powerlink to work over this phy.
Also is there any software support available in Linux for AM3359 for powerlink?
Thanks in Advance.
  • Hello Prateek,
    I assume you are asking for Powerlink slave. We've a version of Powelink slave in the Industrial SDK but that's based on Sys/BIOS RTOS, no on Linux. Pl check the release notes for the features supported currently and the limitations. Here is the SDK link.
    http://www.ti.com/tool/sysbiossdk-ind-sitara
    We are also working with a 3P on the stack side for Powerlink. Pl contact your local TI rep or myself (gurrapu@ti.com) so we can put you in touch with this 3P that can provide you the complete SW solution on AM335x.
    -Srik
  • Hello Srik,
    Do we have any updates on the Powerlink support for Linux OS on the AM3359 ?
