Other Parts Discussed in Thread: OMAP-L138, OMAPL138
Hello, dear TI!
I have an issue with example of ARM and DSP interconnection.
I downloaded quickStartOMAPL1x_rCSL-2.0-Setup.zip - the register Chip Support Library
There are two projects in rCSL examples:
- ARM2DSP_integration_dspL138 - I can run it on my OMAP-L138 Experimenter KiT (I added OMAPL138_DSP.gel from support files to the target configuration)
- ARM2DSP_integration_armL138 - I have problem with running this project.
First, I added OMAPL138_ARM.gel to the target configuration.
Problems start when I click Debug.
ARM9_0: Output: Target Connected.
ARM9_0: Output: ---------------------------------------------
ARM9_0: Output: Memory Map Cleared.
ARM9_0: Output: Memory Map Setup Complete.
ARM9_0: Output: KICK Unlocked.
ARM9_0: Output: PSC Enable Complete.
ARM9_0: GEL: Error while executing OnTargetConnect(): Target failed to write memory at 0x01C11138.
ARM9_0: Trouble Reading Register REG_END: (Error -1060 @ 0x2E18) Device is not responding to the request. Reset the device, and retry the operation. If error persists, confirm configuration, power-cycle the board, and/or try more reliable JTAG settings (e.g. lower TCLK). (Release 5.0.429.0)
ARM9_0: Trouble getting target property: (Error -1060 @ 0x2E18) Device is not responding to the request. Reset the device, and retry the operation. If error persists, confirm configuration, power-cycle the board, and/or try more reliable JTAG settings (e.g. lower TCLK). (Release 5.0.429.0)
ARM9_0: Warning: (Error -1060 @ 0x2E18) Device is not responding to the request. Reset the device, and retry the operation. If error persists, confirm configuration, power-cycle the board, and/or try more reliable JTAG settings (e.g. lower TCLK). (Release 5.0.429.0)
ARM9_0: Trouble Writing Memory Block at 0x80000000 on Page 0 of Length 0x4d68: (Error -1060 @ 0x2E18) Device is not responding to the request. Reset the device, and retry the operation. If error persists, confirm configuration, power-cycle the board, and/or try more reliable JTAG settings (e.g. lower TCLK). (Release 5.0.429.0)
I will be grateful for any advices.
