Other Parts Discussed in Thread: AM3505
Dear Forum,
are there any code examples for the NEON coprocessor?
Werner
NEON is a standard component of most ARM Cortex-A processors. So you should find that on the web.
E.g. ffmpeg is largely done in NEON assembly as far as I know.
Regards.
Some TI Neon docs here you can see the Cortex-A8, Neon (and even VFP) share the same program counter:
http://processors.wiki.ti.com/index.php/Cortex-A8_Architecture#Cortex-A8_Pipeline_Diagram
How to run code here (in Linux):
Some people are even running on AM335x Starterware (similar enoug to AM3505 you should be able to port the code):
http://e2e.ti.com/support/embedded/starterware/f/790/p/223377/787742.aspx#787742
