Dear all:
How to output HS clock under LP mode ? I find "REG_FLD_MOD(dsidev, DSI_CLK_CTRL, 1, 13, 13); " can always output HS clock regardless LP or HS mode.
But how to toggle HS clock output immediately ?
Dear all:
omapdss_dsi_vc_enable_hs(dssdev, td->channel, true); //===> will output HS clock and HS Data
REG_FLD_MOD(dsidev, DSI_CLK_CTRL, 1, 13, 13); // ===> always DDR clock output
omapdss_dsi_vc_enable_hs(dssdev, td->channel, false); // ===> Low power mode
I try below:
1. omapdss_dsi_vc_enable_hs(dssdev, td->channel, true);
2. REG_FLD_MOD(dsidev, DSI_CLK_CTRL, 1, 13, 13);
3. omapdss_dsi_vc_enable_hs(dssdev, td->channel, false);
4. taal_sleep_out(td); // ===> exit sleep out
But HS clock stop in step 3.
How to let HS clock always output during step 1~4 ? Anyone knows ?
OK. I solved it.
flow:
1. REG_FLD_MOD(dsidev, DSI_CLK_CTRL, 1, 13, 13);
2. omapdss_dsi_vc_enable_hs(dssdev, td->channel, true);
3. send NOP command to trigger HS clock output
4. switch to LP mode : omapdss_dsi_vc_enable_hs(dssdev, td->channel, false);
Thanks.
