PWM Pulse Generation using interrupt
Other Parts Discussed in Thread: OMAP3530
I am using OMAP3530 Processor.I want to generate PWM Pulse as 20ns on time.I studied your datasheet using PWM Concept it can not be generate 20 ns On time.SO i preferred to PWM Pulse generation using Interrupt.
I am using timer 8 to generate PWM.I want to generate PWM for 20ms so Accordingly i am loading timer value.Once it reaches 20ms overflow will occur that time interrupt will be generated.I am going to use GPIO58 as output so when the interrupt is generated I will make on and OFF the particular GPIO pins.Kindly suggest me IS this Concept is OK?if it so How to achieve 20 ns ON time in 20ms Period time...?
Rajvel M
