What is function of hdvpss_examples_utility.aem3
After install dvr_rdk SDK, there is a directory named hdvpss under ti_tools folder.
I think this folder contains M3-vpss codes  , I compiled it and get a file hdvpss_examples_utility.aem3.
What is function fo hdvpss_examples_utility.aem3, and how I use it for dvr_rdk demos?
Is there some relatively with xem3?
In the HDVPSS_userguide.pdf , it indicates install the REL_HDVPSS.exe on computer, where is it?
  • What is function fo hdvpss_examples_utility.aem3, and how I use it for dvr_rdk demos?
    - you could check README.txt under /ti_tools/hdvpss/hdvpss_01_00_01_37_patched/
      The generated files are placed in the below folders,
      Executables   - $(ROOTDIR)/<APP_NAME>/bin/$(PLATFORM)/<APP_NAME>_m3vpss_$(PROFILE).xem3
      Libraries     - $(ROOTDIR)/<MODULE_RELPATH>/lib/$(PLATFORM)/m3/$(PROFILE)/*.aem3
      pls refer to example under /ti_tools/hdvpss/hdvpss_01_00_01_37_patched/packages/ti/psp/examples/  for usage
    - I can't find the description, could you point out where's the description in which rdk version?
  • Hi Liu,
    What command did you use to compile vpss code?
    Brijehs Jadav
  • Hi:
    I use dvr_rdk  _3.5 paltform
    The TI81xx- HDVPSS- UserGuide.pdf is under directory (INSTALL_PATH)\ti_tools\hdvpss\dvr_rdk_hdvpss\docs
    After compiled, I get  files for example ;hdvpss_examples_sdDisplay_m3vpss_debug.xem3 ,But how to use it to debug?
    Replace the xem3 on mcfw demo named dvr_rdk_fw_m3vpss_1024M_256M.xem3?
  • Hi  Jadav:
    make -s hdvpss
    make -s all
  • After compiled, I get  files for example ;hdvpss_examples_sdDisplay_m3vpss_debug.xem3 ,But how to use it to debug?
    - you should run the DVR demo first to be familiar to the steps about enable M3-VPSS running.
    In /target/rfs_816x/opt/dvr_rdk/ti816x/scripts/load_vpss.sh, you could find the .xem3 was loaded and run.
    To debug with more info, you could use Vps_printf which is like printf in your code.
    - it's unnecessary
  • The hdvpss example utility is meant to be loaded and run using CCS + JTAG. You cannot use any DVR RDK utility like load_vpss to run this executable.
  • hi badri,
    let me double confirm your speaking.
    - Does "hdvpss example utility" mean the folder "./ti_tools/hdvpss/dvr_rdk_hdvpss/packages/ti/psp/examples/utility" instead of "/ti_tools/hdvpss/dvr_rdk_hdvpss/packages/ti/psp/examples"? Right? If not, pls point out the location clearly. Thanks.
