Hi dears:
I am try to export frame data from m3 to a8 in DM8148 package is DVRRDK_03.00.00.00,
i modify my usecase " multich_progressive_4d1_vcap_venc_vdec_vdis.c " ,
i reference the file multich_vcap_venc_vdis.c , copy some code to my usecase for modification
like follow code:
if (enableVideoFramesExport)
/* Set ipcFramesOutVpss link info */
ipcFramesOutVpssToHostPrm.baseCreateParams.noNotifyMode = TRUE;
ipcFramesOutVpssToHostPrm.baseCreateParams.notifyNextLink = FALSE;
ipcFramesOutVpssToHostPrm.baseCreateParams.notifyPrevLink = TRUE;
ipcFramesOutVpssToHostPrm.baseCreateParams.inQueParams.prevLinkId = gMultiCh_VcapVencVdisObj.mergeId[DEI_SC_D1_MERG E_LINK_IDX];
ipcFramesOutVpssToHostPrm.baseCreateParams.inQueParams.prevLinkQueId = 0;
ipcFramesOutVpssToHostPrm.baseCreateParams.outQueParams[0].nextLink = gVcapModuleContext.ipcFramesInHostId;
ipcFramesInHostPrm.baseCreateParams.noNotifyMode = TRUE;
ipcFramesInHostPrm.baseCreateParams.notifyNextLink = FALSE;
ipcFramesInHostPrm.baseCreateParams.notifyPrevLink = FALSE;
ipcFramesInHostPrm.baseCreateParams.inQueParams.prevLinkId = gVcapModuleContext.ipcFramesOutVpssToHostId;
ipcFramesInHostPrm.baseCreateParams.inQueParams.prevLinkQueId = 0;
ipcFramesInHostPrm.baseCreateParams.outQueParams[0].nextLink = SYSTEM_LINK_ID_INVALID;
ipcFramesInHostPrm.exportOnlyPhyAddr = TRUE;
ipcFramesInHostPrm.cbCtx = &gVcapModuleContext;
ipcFramesInHostPrm.cbFxn = Vcap_ipcFramesInCbFxn;
ipcFramesOutHostPrm.baseCreateParams.noNotifyMode = TRUE;
ipcFramesOutHostPrm.baseCreateParams.notifyNextLink = FALSE;
ipcFramesOutHostPrm.baseCreateParams.notifyPrevLink = FALSE;
ipcFramesOutHostPrm.baseCreateParams.inQueParams.prevLinkId = SYSTEM_LINK_ID_INVALID;
ipcFramesOutHostPrm.baseCreateParams.inQueParams.prevLinkQueId = 0;
ipcFramesOutHostPrm.baseCreateParams.outQueParams[0].nextLink = gVdisModuleContext.ipcFramesInVpssFromHostId;
ipcFramesInVpssFromHostPrm.baseCreateParams.noNotifyMode = TRUE;
ipcFramesInVpssFromHostPrm.baseCreateParams.notifyNextLink = TRUE;
ipcFramesInVpssFromHostPrm.baseCreateParams.notifyPrevLink = FALSE;
ipcFramesInVpssFromHostPrm.baseCreateParams.inQueParams.prevLinkId = gVdisModuleContext.ipcFramesOutHostId;
ipcFramesInVpssFromHostPrm.baseCreateParams.inQueParams.prevLinkQueId = 0;
ipcFramesInVpssFromHostPrm.baseCreateParams.outQueParams[0].nextLink = gVdisModuleContext.swMsId[0];
swMsPrm.inQueParams.prevLinkId = gVdisModuleContext.ipcFramesInVpssFromHostId;
now i can use function Vcap_getFullVideoFrames(&bufList,0); to get frame data in A8
but i loss my live stream in display, i have no idea what happened ??!!
in my modification, data flow is like : frameOutM3->frameInA8->frameOutA8->frameInM3
it should put date back to M3 and display in live ~~
is any one can help me ?? thanks
this is my usecase file :
* Copyright (c) 2009 Texas Instruments Incorporated - http://www.ti.com/ *
* ALL RIGHTS RESERVED *
/* This usecase assumes that all 3 outputs - D1 <h.264> + CIF <h.264> + D1 <MJPEG> are enabled */
/*------------------------------ D1 <h.264> + CIF <h.264> + D1 <MJPEG> -------------------------------------
Capture (YUV422I) 4CH D1 60fps
DEI
(DEI-SC YUV422I) (VIP-SC YUV420 ) (VIP-SC1 YUV420 )
D1 D1 | CIF|
D1_DUP_LINK_IDX | |
| NSF | |
| (YUV420) | |
| <D1-MJPEG> 2| |0 | 1
| | |<D1-H.264>| <CIF-H.264>
| D1_CIF_MERGE_LINK_IDX
| FRAMESOUT(VPSS)---------------<<<processLink>>>----FramesInDSP--------ALG_LINK <OSD, SCD Algs>
| IPCM3OUT(VPSS)------IPCM3IN(VID)----ENC-----IPCBITS_RTOSOUT(VID)-----IPCBITS_HLOSIN(HOST)-----FILEOUT
|+--------------------------IPCM3IN(VPSS)---------IPCM3OUT(VID)---------DEC---------------IPCBITS_RTOSIN(VID)-----------IPCBITS_HLOSOUT(HOST)
LIVE_DECODE_MERGE_LINK_IDX
LIVE_DECODE_DUP_LINK_IDX
SW Mosaic 1 SW Mosaic 0
(SC2 YUV422I) (SC5 YUV422I)
DISPLAY 1 DISPLAY 0
------------- ------------- <tied>
<SDTV> <On-Chip HDMI> --------- <Off-Chip HDMI>
PAL/NTSC 1080p60 1080p60
#include "mcfw/src_linux/mcfw_api/usecases/multich_common.h"
#include "mcfw/src_linux/mcfw_api/usecases/multich_ipcbits.h"
// Keeping TILER disabled for 4D1 usecase
#define TILER_ENABLE FALSE
* Externs
static UInt8 SCDChannelMonitor[4] = {4, 5, 6, 7};
* Use case code
static SystemVideo_Ivahd2ChMap_Tbl systemVid_encDecIvaChMapTbl =
.isPopulated = 1,
.ivaMap[0] =
.EncNumCh = 16,
.EncChList = {0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13 , 14, 15},
.DecNumCh = 16,
.DecChList = {0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13 , 14, 15},
// #define ADD_NSF_AFTER_CAPTURE
#define NUM_MERGE_LINK 2
#define D1_CIF_MERGE_LINK_IDX 0
#define LIVE_DECODE_MERGE_LINK_IDX 1
#define NUM_DUP_LINK 2
#define D1_DUP_LINK_IDX 0
#define LIVE_DECODE_DUP_LINK_IDX 1
#if(defined(TI_814X_BUILD) || defined(DDR_MEM_256M))
#define NUM_CAPTURE_BUFFERS 8
#define NUM_NSF_BUFFERS 4
#define NUM_ENCODE_D1_BUFFERS 4
#define NUM_ENCODE_CIF_BUFFERS 4
#define NUM_DECODE_BUFFERS 4
#define NUM_IPC_OUT_BUFFERS 4
#define NUM_SWMS_MAX_BUFFERS 8
#else
#define NUM_NSF_BUFFERS 6
#define NUM_ENCODE_D1_BUFFERS 6
#define NUM_ENCODE_CIF_BUFFERS 6
#define NUM_DECODE_BUFFERS 6
#define NUM_IPC_OUT_BUFFERS 6
#endif
#define NUM_CAPTURE_DEVICES 1
/* This usecase assumes CIF <secondary out>, MJPEG are enabled */
Void MultiCh_createProgressive4D1VcapVencVdecVdis()
CaptureLink_CreateParams capturePrm;
NsfLink_CreateParams nsfPrm;
DeiLink_CreateParams deiPrm;
MergeLink_CreateParams mergePrm[NUM_MERGE_LINK];
DupLink_CreateParams dupPrm[NUM_DUP_LINK];
static SwMsLink_CreateParams swMsPrm[VDIS_DEV_MAX];
DisplayLink_CreateParams displayPrm[VDIS_DEV_MAX];
IpcLink_CreateParams ipcOutVpssPrm;
IpcLink_CreateParams ipcInVpssPrm;
IpcLink_CreateParams ipcOutVideoPrm;
IpcLink_CreateParams ipcInVideoPrm;
EncLink_CreateParams encPrm;
DecLink_CreateParams decPrm;
IpcBitsOutLinkHLOS_CreateParams ipcBitsOutHostPrm;
IpcBitsOutLinkRTOS_CreateParams ipcBitsOutVideoPrm;
IpcBitsInLinkHLOS_CreateParams ipcBitsInHostPrm[2];
IpcBitsInLinkRTOS_CreateParams ipcBitsInVideoPrm;
CaptureLink_VipInstParams *pCaptureInstPrm;
CaptureLink_OutParams *pCaptureOutPrm;
IpcFramesInLinkRTOS_CreateParams ipcFramesInDspPrm;
IpcFramesOutLinkRTOS_CreateParams ipcFramesOutVpssPrm;
AlgLink_CreateParams dspAlgPrm;
//hlc add for alg1
IpcFramesInLinkRTOS_CreateParams ipcFramesInDspPrm1;
IpcFramesOutLinkRTOS_CreateParams ipcFramesOutVpssPrm1;
AlgLink_CreateParams dspAlgPrm1;
//hlc add for frame export to A8
Bool enableVideoFramesExport = TRUE;//FALSE;
IpcFramesOutLinkRTOS_CreateParams ipcFramesOutVpssToHostPrm;
IpcFramesInLinkHLOS_CreateParams ipcFramesInHostPrm;
IpcFramesOutLinkHLOS_CreateParams ipcFramesOutHostPrm;
IpcFramesInLinkRTOS_CreateParams ipcFramesInVpssFromHostPrm;
System_LinkInfo framesProducerLinkInfo;
System_LinkInfo bitsProducerLinkInfo;
UInt32 mergeId[NUM_MERGE_LINK];
UInt32 dupId[NUM_DUP_LINK];
UInt32 ipcOutVpssId, ipcInVpssId;
UInt32 ipcOutVideoId, ipcInVideoId;
IpcBitsOutLinkRTOS_CreateParams ipcBitsOutDspPrm;
UInt32 ipcBitsOutDSPId;
VCAP_VIDDEC_PARAMS_S vidDecVideoModeArgs[NUM_CAPTURE_DEVICES];
UInt32 vipInstId;
UInt32 i, j;
Bool enableOsdAlgLink = gVsysModuleContext.vsysConfig.enableOsd;
Bool enableScdAlgLink = gVsysModuleContext.vsysConfig.enableScd;
Bool enableMuxAlgLink = gVsysModuleContext.vsysConfig.enableMux;
#ifdef ADD_NSF_AFTER_CAPTURE
NsfLink_CreateParams nsfPrm2;
#endif
MULTICH_INIT_STRUCT(IpcLink_CreateParams,ipcOutVpssPrm);
MULTICH_INIT_STRUCT(IpcLink_CreateParams,ipcInVpssPrm);
MULTICH_INIT_STRUCT(IpcLink_CreateParams,ipcOutVideoPrm);
MULTICH_INIT_STRUCT(IpcLink_CreateParams,ipcInVideoPrm);
MULTICH_INIT_STRUCT(IpcBitsOutLinkHLOS_CreateParams,ipcBitsOutHostPrm);
MULTICH_INIT_STRUCT(IpcBitsOutLinkRTOS_CreateParams,ipcBitsOutVideoPrm);
MULTICH_INIT_STRUCT(IpcBitsOutLinkRTOS_CreateParams,ipcBitsOutDspPrm);
MULTICH_INIT_STRUCT(IpcBitsInLinkHLOS_CreateParams,ipcBitsInHostPrm[0]);
MULTICH_INIT_STRUCT(IpcBitsInLinkHLOS_CreateParams,ipcBitsInHostPrm[1]);
MULTICH_INIT_STRUCT(IpcBitsInLinkRTOS_CreateParams,ipcBitsInVideoPrm);
MULTICH_INIT_STRUCT(DecLink_CreateParams, decPrm);
MULTICH_INIT_STRUCT(IpcFramesInLinkRTOS_CreateParams,ipcFramesInDspPrm);
MULTICH_INIT_STRUCT(IpcFramesOutLinkRTOS_CreateParams,ipcFramesOutVpssPrm);
MULTICH_INIT_STRUCT(EncLink_CreateParams, encPrm);
MULTICH_INIT_STRUCT(AlgLink_CreateParams, dspAlgPrm);
//hlc add for alg1
MULTICH_INIT_STRUCT(IpcFramesInLinkRTOS_CreateParams,ipcFramesInDspPrm1);
MULTICH_INIT_STRUCT(IpcFramesOutLinkRTOS_CreateParams,ipcFramesOutVpssPrm1);
MULTICH_INIT_STRUCT(AlgLink_CreateParams, dspAlgPrm1);
MULTICH_INIT_STRUCT(IpcFramesOutLinkRTOS_CreateParams ,ipcFramesOutVpssToHostPrm);
MULTICH_INIT_STRUCT(IpcFramesInLinkHLOS_CreateParams ,ipcFramesInHostPrm);
MULTICH_INIT_STRUCT(IpcFramesOutLinkHLOS_CreateParams ,ipcFramesOutHostPrm);
MULTICH_INIT_STRUCT(IpcFramesInLinkRTOS_CreateParams ,ipcFramesInVpssFromHostPrm);
//AlgLink_CreateParams_Init
for (i = 0; i < VDIS_DEV_MAX;i++)
MULTICH_INIT_STRUCT(DisplayLink_CreateParams,
displayPrm[i]);
MULTICH_INIT_STRUCT(SwMsLink_CreateParams ,swMsPrm[i]);
MULTICH_INIT_STRUCT(NsfLink_CreateParams, nsfPrm);
MULTICH_INIT_STRUCT(DeiLink_CreateParams, deiPrm);
printf("\n********* Entered usecase 4CH <814x> Enc/Dec OSD %s SCD %s MUX %s\n\n",
enableOsdAlgLink == TRUE ? "Enabled" : "Disabled",
enableScdAlgLink == TRUE ? "Enabled" : "Disabled",
enableMuxAlgLink == TRUE ? "Enabled" : "Disabled"
MultiCh_detectBoard();
System_linkControl(
SYSTEM_LINK_ID_M3VPSS,
SYSTEM_M3VPSS_CMD_RESET_VIDEO_DEVICES,
NULL,
0,
TRUE
System_linkControl(
SYSTEM_LINK_ID_M3VIDEO,
SYSTEM_COMMON_CMD_SET_CH2IVAHD_MAP_TBL,
&systemVid_encDecIvaChMapTbl,
sizeof(SystemVideo_Ivahd2ChMap_Tbl),
TRUE
vipInstId = 0;
gVcapModuleContext.captureId = SYSTEM_LINK_ID_CAPTURE;
if(enableOsdAlgLink || enableScdAlgLink)
gVcapModuleContext.dspAlgId[0] = SYSTEM_LINK_ID_ALG_0 ;
gVcapModuleContext.ipcFramesOutVpssId[0] = SYSTEM_VPSS_LINK_ID_IPC_FRAMES_OUT_0;
gVcapModuleContext.ipcFramesInDspId[0] = SYSTEM_DSP_LINK_ID_IPC_FRAMES_IN_0;
if(enableScdAlgLink)
ipcBitsOutDSPId = SYSTEM_DSP_LINK_ID_IPC_BITS_OUT_0;
gVcapModuleContext.ipcBitsInHLOSId = SYSTEM_HOST_LINK_ID_IPC_BITS_IN_0;
#if MUX_SUPPORT
if(enableMuxAlgLink)
//if(enableMuxAlgLink||enableOsdAlgLink)
gVcapModuleContext.dspAlgId[1] = SYSTEM_LINK_ID_ALG_1 ;
gVcapModuleContext.ipcFramesOutVpssId[1] = SYSTEM_VPSS_LINK_ID_IPC_FRAMES_OUT_1;
gVcapModuleContext.ipcFramesInDspId[1] = SYSTEM_DSP_LINK_ID_IPC_FRAMES_IN_1;
#endif
if (enableVideoFramesExport){
gVcapModuleContext.ipcFramesOutVpssToHostId = SYSTEM_VPSS_LINK_ID_IPC_FRAMES_OUT_2;
gVcapModuleContext.ipcFramesInHostId = SYSTEM_HOST_LINK_ID_IPC_FRAMES_IN_0;
gVdisModuleContext.ipcFramesOutHostId = SYSTEM_HOST_LINK_ID_IPC_FRAMES_OUT_0;
gVdisModuleContext.ipcFramesInVpssFromHostId = SYSTEM_VPSS_LINK_ID_IPC_FRAMES_IN_0;
gVcapModuleContext.nsfId[0] = SYSTEM_LINK_ID_NSF_0;
gVcapModuleContext.nsfId[1] =SYSTEM_LINK_ID_NSF_1;
#endif
gVcapModuleContext.deiId[0] = SYSTEM_LINK_ID_DEI_0;
gVencModuleContext.encId = SYSTEM_LINK_ID_VENC_0;
gVdecModuleContext.decId = SYSTEM_LINK_ID_VDEC_0;
gVdisModuleContext.swMsId[0] = SYSTEM_LINK_ID_SW_MS_MULTI_INST_0;
gVdisModuleContext.swMsId[1] = SYSTEM_LINK_ID_SW_MS_MULTI_INST_1;
swMsPrm[0].numSwMsInst = 1;
swMsPrm[1].numSwMsInst = 1;
/* use AUX scaler (SC2), since SC1 is used for DEI */
swMsPrm[0].swMsInstId[0] = SYSTEM_SW_MS_SC_INST_DEI_SC_NO_DEI;
swMsPrm[1].swMsInstId[0] = SYSTEM_SW_MS_SC_INST_SC5;
gVdisModuleContext.displayId[0] = SYSTEM_LINK_ID_DISPLAY_0; /* ON AND OFF CHIP HDMI */
gVdisModuleContext.displayId[1] = SYSTEM_LINK_ID_DISPLAY_2; /* SDTV */
mergeId[LIVE_DECODE_MERGE_LINK_IDX] = SYSTEM_VPSS_LINK_ID_MERGE_0;
mergeId[D1_CIF_MERGE_LINK_IDX] = SYSTEM_VPSS_LINK_ID_MERGE_1;
dupId[D1_DUP_LINK_IDX] = SYSTEM_VPSS_LINK_ID_DUP_0;
dupId[LIVE_DECODE_DUP_LINK_IDX] = SYSTEM_VPSS_LINK_ID_DUP_1;
ipcOutVpssId = SYSTEM_VPSS_LINK_ID_IPC_OUT_M3_0;
ipcInVideoId = SYSTEM_VIDEO_LINK_ID_IPC_IN_M3_0;
ipcOutVideoId= SYSTEM_VIDEO_LINK_ID_IPC_OUT_M3_0;
ipcInVpssId = SYSTEM_VPSS_LINK_ID_IPC_IN_M3_0;
gVencModuleContext.ipcBitsOutRTOSId = SYSTEM_VIDEO_LINK_ID_IPC_BITS_OUT_0;
gVencModuleContext.ipcBitsInHLOSId = SYSTEM_HOST_LINK_ID_IPC_BITS_IN_1;
else
gVencModuleContext.ipcBitsInHLOSId = SYSTEM_HOST_LINK_ID_IPC_BITS_IN_0;
gVdecModuleContext.ipcBitsOutHLOSId = SYSTEM_HOST_LINK_ID_IPC_BITS_OUT_0;
gVdecModuleContext.ipcBitsInRTOSId = SYSTEM_VIDEO_LINK_ID_IPC_BITS_IN_0;
CaptureLink_CreateParams_Init(&capturePrm);
capturePrm.outQueParams[0].nextLink = gVcapModuleContext.nsfId[1];
#else
capturePrm.outQueParams[0].nextLink = gVcapModuleContext.deiId[0];
#endif
capturePrm.numVipInst = 1;
capturePrm.tilerEnable = FALSE;
capturePrm.numBufsPerCh = NUM_CAPTURE_BUFFERS;
capturePrm.maxBlindAreasPerCh = 4;
pCaptureInstPrm = &capturePrm.vipInst[0];
pCaptureInstPrm->vipInstId = (SYSTEM_CAPTURE_INST_VIP0_PORTA+
vipInstId)%SYSTEM_CAPTURE_INST_MAX;
pCaptureInstPrm->videoDecoderId = SYSTEM_DEVICE_VID_DEC_TVP5158_DRV;
pCaptureInstPrm->inDataFormat = SYSTEM_DF_YUV422P;
pCaptureInstPrm->standard = SYSTEM_STD_MUX_4CH_D1;
pCaptureInstPrm->numOutput = 1;
pCaptureOutPrm = &pCaptureInstPrm->outParams[0];
pCaptureOutPrm->dataFormat = SYSTEM_DF_YUV422I_YUYV;
pCaptureOutPrm->scEnable = FALSE;
pCaptureOutPrm->scOutWidth = 0;
pCaptureOutPrm->scOutHeight = 0;
pCaptureOutPrm->outQueId = 0;
for(i = 0; i < NUM_CAPTURE_DEVICES; i++)
vidDecVideoModeArgs[i].videoIfMode = DEVICE_CAPT_VIDEO_IF_MODE_8BIT;
vidDecVideoModeArgs[i].videoDataFormat = SYSTEM_DF_YUV422P;
vidDecVideoModeArgs[i].standard = SYSTEM_STD_MUX_4CH_D1;
vidDecVideoModeArgs[i].videoCaptureMode =
DEVICE_CAPT_VIDEO_CAPTURE_MODE_MULTI_CH_PIXEL_MUX_EMBEDDED_SYNC;
vidDecVideoModeArgs[i].videoSystem =
DEVICE_VIDEO_DECODER_VIDEO_SYSTEM_AUTO_DETECT;
vidDecVideoModeArgs[i].videoCropEnable = FALSE;
vidDecVideoModeArgs[i].videoAutoDetectTimeout = -1;
Vcap_configVideoDecoder(vidDecVideoModeArgs, NUM_CAPTURE_DEVICES);
nsfPrm2.bypassNsf = TRUE;
nsfPrm2.tilerEnable = FALSE;
nsfPrm2.inQueParams.prevLinkId = gVcapModuleContext.captureId;
nsfPrm2.inQueParams.prevLinkQueId = 0;
nsfPrm2.numOutQue = 1;
nsfPrm2.outQueParams[0].nextLink = gVcapModuleContext.deiId[0];
nsfPrm2.numBufsPerCh = NUM_NSF_BUFFERS;
nsfPrm2.inputFrameRate = 30;
nsfPrm2.outputFrameRate = 30;
deiPrm.inQueParams.prevLinkId = gVcapModuleContext.nsfId[1];
#else
deiPrm.inQueParams.prevLinkId = gVcapModuleContext.captureId;
#endif
deiPrm.inQueParams.prevLinkQueId = 0;
/* Set Output Scaling at DEI based on ratio */
deiPrm.outScaleFactor[DEI_LINK_OUT_QUE_DEI_SC][0].scaleMode = DEI_SCALE_MODE_RATIO;
deiPrm.outScaleFactor[DEI_LINK_OUT_QUE_DEI_SC][0].ratio.widthRatio.numerator = 1;
deiPrm.outScaleFactor[DEI_LINK_OUT_QUE_DEI_SC][0].ratio.widthRatio.denominator = 1;
deiPrm.outScaleFactor[DEI_LINK_OUT_QUE_DEI_SC][0].ratio.heightRatio.numerator = 1;
deiPrm.outScaleFactor[DEI_LINK_OUT_QUE_DEI_SC][0].ratio.heightRatio.denominator = 1;
for (i=1; i < DEI_LINK_MAX_CH; i++)
deiPrm.outScaleFactor[DEI_LINK_OUT_QUE_DEI_SC][i] = deiPrm.outScaleFactor[DEI_LINK_OUT_QUE_DEI_SC][0];
deiPrm.outScaleFactor[DEI_LINK_OUT_QUE_VIP_SC][0].scaleMode = DEI_SCALE_MODE_RATIO;
deiPrm.outScaleFactor[DEI_LINK_OUT_QUE_VIP_SC][0].ratio.heightRatio.numerator = 1;
deiPrm.outScaleFactor[DEI_LINK_OUT_QUE_VIP_SC][0].ratio.heightRatio.denominator = 1;
deiPrm.outScaleFactor[DEI_LINK_OUT_QUE_VIP_SC][0].ratio.widthRatio.numerator = 1;
deiPrm.outScaleFactor[DEI_LINK_OUT_QUE_VIP_SC][0].ratio.widthRatio.denominator = 1;
deiPrm.outScaleFactor[DEI_LINK_OUT_QUE_VIP_SC][i] = deiPrm.outScaleFactor[DEI_LINK_OUT_QUE_VIP_SC][0];
deiPrm.outScaleFactor[DEI_LINK_OUT_QUE_VIP_SC_SECONDARY_OUT][0].scaleMode = DEI_SCALE_MODE_RATIO;
deiPrm.outScaleFactor[DEI_LINK_OUT_QUE_VIP_SC_SECONDARY_OUT][0].ratio.heightRatio.numerator = 1;
deiPrm.outScaleFactor[DEI_LINK_OUT_QUE_VIP_SC_SECONDARY_OUT][0].ratio.heightRatio.denominator = 2;
deiPrm.outScaleFactor[DEI_LINK_OUT_QUE_VIP_SC_SECONDARY_OUT][0].ratio.widthRatio.numerator = 1;
deiPrm.outScaleFactor[DEI_LINK_OUT_QUE_VIP_SC_SECONDARY_OUT][0].ratio.widthRatio.denominator = 2;
deiPrm.outScaleFactor[DEI_LINK_OUT_QUE_VIP_SC_SECONDARY_OUT][i] = deiPrm.outScaleFactor[DEI_LINK_OUT_QUE_VIP_SC_SECONDARY_OUT][0];
deiPrm.enableOut[DEI_LINK_OUT_QUE_DEI_SC] = TRUE;
deiPrm.enableOut[DEI_LINK_OUT_QUE_VIP_SC] = TRUE;
deiPrm.enableOut[DEI_LINK_OUT_QUE_VIP_SC_SECONDARY_OUT] = TRUE;
deiPrm.outQueParams[DEI_LINK_OUT_QUE_DEI_SC].nextLink = dupId[D1_DUP_LINK_IDX];
deiPrm.outQueParams[DEI_LINK_OUT_QUE_VIP_SC].nextLink = mergeId[D1_CIF_MERGE_LINK_IDX];
deiPrm.outQueParams[DEI_LINK_OUT_QUE_VIP_SC_SECONDARY_OUT].nextLink = mergeId[D1_CIF_MERGE_LINK_IDX];
deiPrm.tilerEnable[DEI_LINK_OUT_QUE_VIP_SC] = TILER_ENABLE;
deiPrm.comprEnable = FALSE;
deiPrm.setVipScYuv422Format = FALSE;
dupPrm[D1_DUP_LINK_IDX].inQueParams.prevLinkId = gVcapModuleContext.deiId[0];
dupPrm[D1_DUP_LINK_IDX].inQueParams.prevLinkQueId = DEI_LINK_OUT_QUE_DEI_SC;
dupPrm[D1_DUP_LINK_IDX].numOutQue = 2;
dupPrm[D1_DUP_LINK_IDX].outQueParams[0].nextLink = gVcapModuleContext.ipcFramesOutVpssToHostId;
dupPrm[D1_DUP_LINK_IDX].outQueParams[1].nextLink = gVcapModuleContext.nsfId[0];
dupPrm[D1_DUP_LINK_IDX].notifyNextLink = TRUE;
ipcFramesOutVpssToHostPrm.baseCreateParams.inQueParams.prevLinkId = dupId[D1_DUP_LINK_IDX];
//ipcFramesInHostPrm.baseCreateParams.outQueParams[0].nextLink = gVdisModuleContext.ipcFramesOutHostId;
//ipcFramesOutHostPrm.baseCreateParams.inQueParams.prevLinkId = gVcapModuleContext.ipcFramesInHostId;
ipcFramesInVpssFromHostPrm.baseCreateParams.outQueParams[0].nextLink = mergeId[LIVE_DECODE_MERGE_LINK_IDX];;
//swMsPrm.inQueParams.prevLinkId = gVdisModuleContext.ipcFramesInVpssFromHostId;
else
dupPrm[D1_DUP_LINK_IDX].outQueParams[0].nextLink = mergeId[LIVE_DECODE_MERGE_LINK_IDX];
#if MUX_SUPPORT
dupPrm[D1_DUP_LINK_IDX].outQueParams[0].nextLink = gVcapModuleContext.ipcFramesOutVpssId[1];
printf ("\n\n========Redirect to DSP for MUX============\n");
/* Redirect to DSP for MUX */
ipcFramesOutVpssPrm1.baseCreateParams.inQueParams.prevLinkId = dupId[D1_DUP_LINK_IDX];
ipcFramesOutVpssPrm1.baseCreateParams.inQueParams.prevLinkQueId = 0;
ipcFramesOutVpssPrm1.baseCreateParams.outQueParams[0].nextLink = mergeId[LIVE_DECODE_MERGE_LINK_IDX];
ipcFramesOutVpssPrm1.baseCreateParams.processLink = gVcapModuleContext.ipcFramesInDspId[1];
ipcFramesOutVpssPrm1.baseCreateParams.notifyPrevLink = TRUE;
ipcFramesOutVpssPrm1.baseCreateParams.notifyNextLink = TRUE;
ipcFramesOutVpssPrm1.baseCreateParams.notifyProcessLink = TRUE;
ipcFramesOutVpssPrm1.baseCreateParams.noNotifyMode = FALSE;
ipcFramesOutVpssPrm1.baseCreateParams.numOutQue = 1;
ipcFramesInDspPrm1.baseCreateParams.inQueParams.prevLinkId = gVcapModuleContext.ipcFramesOutVpssId[1];
ipcFramesInDspPrm1.baseCreateParams.inQueParams.prevLinkQueId = 0;
ipcFramesInDspPrm1.baseCreateParams.outQueParams[0].nextLink = gVcapModuleContext.dspAlgId[1];
ipcFramesInDspPrm1.baseCreateParams.notifyPrevLink = TRUE;
ipcFramesInDspPrm1.baseCreateParams.notifyNextLink = TRUE;
ipcFramesInDspPrm1.baseCreateParams.noNotifyMode = FALSE;
ipcFramesInDspPrm1.baseCreateParams.numOutQue = 1;
dspAlgPrm1.inQueParams.prevLinkId = gVcapModuleContext.ipcFramesInDspId[1];
dspAlgPrm1.inQueParams.prevLinkQueId = 0;
dspAlgPrm1.outQueParams[0].nextLink = SYSTEM_LINK_ID_INVALID;
else
#endif
nsfPrm.bypassNsf = TRUE;
nsfPrm.tilerEnable = TILER_ENABLE;
nsfPrm.inQueParams.prevLinkId = dupId[D1_DUP_LINK_IDX];
nsfPrm.inQueParams.prevLinkQueId = 1;
nsfPrm.numOutQue = 1;
nsfPrm.outQueParams[0].nextLink = mergeId[D1_CIF_MERGE_LINK_IDX];
nsfPrm.numBufsPerCh = NUM_NSF_BUFFERS;
nsfPrm.inputFrameRate = 30;
nsfPrm.outputFrameRate = 1;
/* Merge Q0 - D1 <from VIP-SC>, Q1 - CIF <from VIP-SC_SECONDARY>, Q2 -D1 for MJPEG <from DEI-SC> */
mergePrm[D1_CIF_MERGE_LINK_IDX].inQueParams[0].prevLinkId = gVcapModuleContext.deiId[0];
mergePrm[D1_CIF_MERGE_LINK_IDX].inQueParams[0].prevLinkQueId = DEI_LINK_OUT_QUE_VIP_SC;
mergePrm[D1_CIF_MERGE_LINK_IDX].inQueParams[1].prevLinkId = gVcapModuleContext.deiId[0];
mergePrm[D1_CIF_MERGE_LINK_IDX].inQueParams[1].prevLinkQueId = DEI_LINK_OUT_QUE_VIP_SC_SECONDARY_OUT;
mergePrm[D1_CIF_MERGE_LINK_IDX].inQueParams[2].prevLinkId = gVcapModuleContext.nsfId[0];
mergePrm[D1_CIF_MERGE_LINK_IDX].inQueParams[2].prevLinkQueId = 0;
mergePrm[D1_CIF_MERGE_LINK_IDX].notifyNextLink = TRUE;
mergePrm[D1_CIF_MERGE_LINK_IDX].numInQue = 3;
ipcOutVpssPrm.inQueParams.prevLinkQueId = 0;
if (enableOsdAlgLink || enableScdAlgLink)
mergePrm[D1_CIF_MERGE_LINK_IDX].outQueParams.nextLink = gVcapModuleContext.ipcFramesOutVpssId[0];
ipcOutVpssPrm.inQueParams.prevLinkId = gVcapModuleContext.ipcFramesOutVpssId[0];
/* Redirect to DSP for OSD / SCD */
ipcFramesOutVpssPrm .baseCreateParams.inQueParams.prevLinkId = mergeId[D1_CIF_MERGE_LINK_IDX];
ipcFramesOutVpssPrm.baseCreateParams.inQueParams.prevLinkQueId = 0;
ipcFramesOutVpssPrm.baseCreateParams.outQueParams[0].nextLink = ipcOutVpssId;
ipcFramesOutVpssPrm.baseCreateParams.processLink = gVcapModuleContext.ipcFramesInDspId[0];
ipcFramesOutVpssPrm.baseCreateParams.notifyPrevLink = TRUE;
ipcFramesOutVpssPrm.baseCreateParams.notifyNextLink = TRUE;
ipcFramesOutVpssPrm.baseCreateParams.notifyProcessLink = TRUE;
ipcFramesOutVpssPrm.baseCreateParams.noNotifyMode = FALSE;
ipcFramesOutVpssPrm.baseCreateParams.numOutQue = 1;
ipcFramesInDspPrm.baseCreateParams.inQueParams.prevLinkId = gVcapModuleContext.ipcFramesOutVpssId[0];
ipcFramesInDspPrm.baseCreateParams.inQueParams.prevLinkQueId = 0;
ipcFramesInDspPrm.baseCreateParams.outQueParams[0].nextLink = gVcapModuleContext.dspAlgId[0];
ipcFramesInDspPrm.baseCreateParams.notifyPrevLink = TRUE;
ipcFramesInDspPrm.baseCreateParams.notifyNextLink = TRUE;
ipcFramesInDspPrm.baseCreateParams.noNotifyMode = FALSE;
ipcFramesInDspPrm.baseCreateParams.numOutQue = 1;
dspAlgPrm.inQueParams.prevLinkId = gVcapModuleContext.ipcFramesInDspId[0];
dspAlgPrm.inQueParams.prevLinkQueId = 0;
else
mergePrm[D1_CIF_MERGE_LINK_IDX].outQueParams.nextLink = ipcOutVpssId;
ipcOutVpssPrm.inQueParams.prevLinkId = mergeId[D1_CIF_MERGE_LINK_IDX];
ipcOutVpssPrm.numOutQue = 1;
ipcOutVpssPrm.outQueParams[0].nextLink = ipcInVideoId;
ipcOutVpssPrm.notifyNextLink = TRUE;
ipcOutVpssPrm.notifyPrevLink = TRUE;
ipcOutVpssPrm.noNotifyMode = FALSE;
ipcInVideoPrm.inQueParams.prevLinkId = ipcOutVpssId;
ipcInVideoPrm.inQueParams.prevLinkQueId = 0;
ipcInVideoPrm.numOutQue = 1;
ipcInVideoPrm.outQueParams[0].nextLink = gVencModuleContext.encId;
ipcInVideoPrm.notifyNextLink = TRUE;
ipcInVideoPrm.notifyPrevLink = TRUE;
ipcInVideoPrm.noNotifyMode = FALSE;
EncLink_ChCreateParams *pLinkChPrm;
EncLink_ChDynamicParams *pLinkDynPrm;
VENC_CHN_DYNAMIC_PARAM_S *pDynPrm;
VENC_CHN_PARAMS_S *pChPrm;
EncLink_CreateParams_Init(&encPrm);
encPrm.numBufPerCh[0] = NUM_ENCODE_D1_BUFFERS;
encPrm.numBufPerCh[1] = NUM_ENCODE_CIF_BUFFERS;
/* Primary Stream Params - D1 */
for (i=0; i<gVencModuleContext.vencConfig.numPrimaryChn; i++)
pLinkChPrm = &encPrm.chCreateParams[i];
pLinkDynPrm = &pLinkChPrm->defaultDynamicParams;
pChPrm = &gVencModuleContext.vencConfig.encChannelParams[i];
pDynPrm = &pChPrm->dynamicParam;
pLinkChPrm->format = IVIDEO_H264HP;
pLinkChPrm->profile = gVencModuleContext.vencConfig.h264Profile[i];
pLinkChPrm->dataLayout = IVIDEO_FIELD_SEPARATED;
pLinkChPrm->fieldMergeEncodeEnable = FALSE;
pLinkChPrm->enableAnalyticinfo = pChPrm->enableAnalyticinfo;
pLinkChPrm->enableWaterMarking = pChPrm->enableWaterMarking;
pLinkChPrm->maxBitRate = pChPrm->maxBitRate;
pLinkChPrm->encodingPreset = pChPrm->encodingPreset;
pLinkChPrm->rateControlPreset = pChPrm->rcType;
pLinkChPrm->enableSVCExtensionFlag = pChPrm->enableSVCExtensionFlag;
pLinkChPrm->numTemporalLayer = pChPrm->numTemporalLayer;
pLinkDynPrm->intraFrameInterval = pDynPrm->intraFrameInterval;
pLinkDynPrm->targetBitRate = pDynPrm->targetBitRate;
pLinkDynPrm->interFrameInterval = 1;
pLinkDynPrm->mvAccuracy = IVIDENC2_MOTIONVECTOR_QUARTERPEL;
pLinkDynPrm->inputFrameRate = pDynPrm->inputFrameRate;
pLinkDynPrm->rcAlg = pDynPrm->rcAlg;
pLinkDynPrm->qpMin = pDynPrm->qpMin;
pLinkDynPrm->qpMax = pDynPrm->qpMax;
pLinkDynPrm->qpInit = pDynPrm->qpInit;
pLinkDynPrm->vbrDuration = pDynPrm->vbrDuration;
pLinkDynPrm->vbrSensitivity = pDynPrm->vbrSensitivity;
/* Secondary Out <CIF> Params */
for (i=gVencModuleContext.vencConfig.numPrimaryChn, j=VENC_PRIMARY_CHANNELS;
i<(gVencModuleContext.vencConfig.numPrimaryChn
+ gVencModuleContext.vencConfig.numSecondaryChn);
i++, j++)
pChPrm = &gVencModuleContext.vencConfig.encChannelParams[j];
/* MJPEG Params */
for (i=gVencModuleContext.vencConfig.numPrimaryChn + gVencModuleContext.vencConfig.numSecondaryChn;
i<(VENC_CHN_MAX); i++)
pLinkChPrm->format = IVIDEO_MJPEG;
pLinkChPrm->profile = 0;
pLinkChPrm->enableAnalyticinfo = 0;
pLinkChPrm->enableWaterMarking = 0;
pLinkChPrm->maxBitRate = 0;
pLinkChPrm->encodingPreset = 0;
pLinkChPrm->rateControlPreset = 0;
pLinkChPrm->enableSVCExtensionFlag = 0;
pLinkChPrm->numTemporalLayer = 0;
pLinkDynPrm->intraFrameInterval = 0;
pLinkDynPrm->targetBitRate = 100*1000;
pLinkDynPrm->interFrameInterval = 0;
pLinkDynPrm->mvAccuracy = 0;
pLinkDynPrm->qpMin = 0;
pLinkDynPrm->qpMax = 0;
pLinkDynPrm->qpInit = -1;
pLinkDynPrm->vbrDuration = 0;
pLinkDynPrm->vbrSensitivity = 0;
encPrm.inQueParams.prevLinkId = ipcInVideoId;
encPrm.inQueParams.prevLinkQueId = 0;
encPrm.outQueParams.nextLink = gVencModuleContext.ipcBitsOutRTOSId;
ipcBitsOutVideoPrm.baseCreateParams.inQueParams.prevLinkId = gVencModuleContext.encId;
ipcBitsOutVideoPrm.baseCreateParams.inQueParams.prevLinkQueId = 0;
ipcBitsOutVideoPrm.baseCreateParams.numOutQue = 1;
ipcBitsOutVideoPrm.baseCreateParams.outQueParams[0].nextLink = gVencModuleContext.ipcBitsInHLOSId;
MultiCh_ipcBitsInitCreateParams_BitsOutRTOS(&ipcBitsOutVideoPrm,
TRUE);
ipcBitsInHostPrm[0].baseCreateParams.inQueParams.prevLinkId = gVencModuleContext.ipcBitsOutRTOSId;
ipcBitsInHostPrm[0].baseCreateParams.inQueParams.prevLinkQueId = 0;
MultiCh_ipcBitsInitCreateParams_BitsInHLOS(&ipcBitsInHostPrm[0]);
if(enableOsdAlgLink)
int chId;
dspAlgPrm.enableOSDAlg = TRUE;
for(chId = 0; chId < ALG_LINK_OSD_MAX_CH; chId++)
AlgLink_OsdChWinParams * chWinPrm = &dspAlgPrm.osdChCreateParams[chId].chDefaultParams;
/* set osd window max width and height */
dspAlgPrm.osdChCreateParams[chId].maxWidth = EXAMPLE_OSD_WIN_MAX_WIDTH;
dspAlgPrm.osdChCreateParams[chId].maxHeight = EXAMPLE_OSD_WIN_MAX_HEIGHT;
chWinPrm->chId = chId;
chWinPrm->numWindows = 0;
if (enableScdAlgLink)
Int32 numBlksInFrame;
Int32 numHorzBlks, numVertBlks, chIdx;
Uint32 x, y, i;
//AlgLink_ScdblkChngConfig blkConfig[ALG_LINK_SCD_MAX_BLOCKS_IN_FRAME];
dspAlgPrm.enableSCDAlg = TRUE;
dspAlgPrm.outQueParams[ALG_LINK_SCD_OUT_QUE].nextLink = ipcBitsOutDSPId;
dspAlgPrm.scdCreateParams.maxWidth = 352;
if(Vcap_isPalMode())
dspAlgPrm.scdCreateParams.maxHeight = 288;
else
dspAlgPrm.scdCreateParams.maxHeight = 240;
dspAlgPrm.scdCreateParams.maxStride = 352;
dspAlgPrm.scdCreateParams.numValidChForSCD = 4;
dspAlgPrm.scdCreateParams.numSecs2WaitB4Init = 3;
dspAlgPrm.scdCreateParams.numSecs2WaitB4FrmAlert = 1;
dspAlgPrm.scdCreateParams.inputFrameRate = 30;
dspAlgPrm.scdCreateParams.outputFrameRate = 5;
dspAlgPrm.scdCreateParams.numSecs2WaitAfterFrmAlert = 2;
dspAlgPrm.scdCreateParams.enableMotionNotify = FALSE;
dspAlgPrm.scdCreateParams.enableTamperNotify = FALSE;
/* Should be applied on CIF channels whose ch numbers are 4~7 */
//dspAlgPrm.scdCreateParams.startChNoForSCD = 4;
// Configure array to monitor scene changes in all frame blocks, i.e., motion detection.
// Each block is fixed to be 32x10 in size,
numHorzBlks = dspAlgPrm.scdCreateParams.maxWidth / 32;
if(dspAlgPrm.scdCreateParams.maxHeight == 240)
numVertBlks = dspAlgPrm.scdCreateParams.maxHeight / 10;
else /* For 288 Block height becomes 12 */
numVertBlks = dspAlgPrm.scdCreateParams.maxHeight / 12;
numBlksInFrame = numHorzBlks * numVertBlks;
for(chIdx = 0; chIdx < dspAlgPrm.scdCreateParams.numValidChForSCD; chIdx++)
AlgLink_ScdChParams * chPrm = &dspAlgPrm.scdCreateParams.chDefaultParams[chIdx];
chPrm->blkNumBlksInFrame = numBlksInFrame;
chPrm->chId = SCDChannelMonitor[chIdx];
chPrm->mode = ALG_LINK_SCD_DETECTMODE_MONITOR_BLOCKS_AND_FRAME;
chPrm->frmIgnoreLightsON = FALSE;
chPrm->frmIgnoreLightsOFF = FALSE;
chPrm->frmSensitivity = ALG_LINK_SCD_SENSITIVITY_MID;
chPrm->frmEdgeThreshold = 100;
i = 0;
for(y = 0; y < numVertBlks; y++)
for(x = 0; x < numHorzBlks; x++)
chPrm->blkConfig[i].sensitivity = ALG_LINK_SCD_SENSITIVITY_MID;
chPrm->blkConfig[i].monitored = 0;
i++;
ipcBitsOutDspPrm.baseCreateParams.inQueParams.prevLinkId = gVcapModuleContext.dspAlgId[0];
ipcBitsOutDspPrm.baseCreateParams.inQueParams.prevLinkQueId = 0;
ipcBitsOutDspPrm.baseCreateParams.numOutQue = 1;
ipcBitsOutDspPrm.baseCreateParams.outQueParams[0].nextLink = gVcapModuleContext.ipcBitsInHLOSId;
MultiCh_ipcBitsInitCreateParams_BitsOutRTOS(&ipcBitsOutDspPrm,
TRUE);
ipcBitsOutDspPrm.baseCreateParams.notifyNextLink = TRUE;
ipcBitsOutDspPrm.baseCreateParams.noNotifyMode = FALSE;
ipcBitsInHostPrm[1].baseCreateParams.inQueParams.prevLinkId = ipcBitsOutDSPId;
ipcBitsInHostPrm[1].baseCreateParams.inQueParams.prevLinkQueId = 0;
MultiCh_ipcBitsInitCreateParams_BitsInHLOSVcap(&ipcBitsInHostPrm[1]);
ipcBitsInHostPrm[1].baseCreateParams.notifyPrevLink = TRUE;
ipcBitsInHostPrm[1].baseCreateParams.noNotifyMode = FALSE;
else
dspAlgPrm.outQueParams[ALG_LINK_SCD_OUT_QUE].nextLink = SYSTEM_LINK_ID_INVALID;
#ifndef SYSTEM_USE_VIDEO_DECODER
capturePrm.isPalMode = Vcap_isPalMode();
#endif
System_linkCreate (gVcapModuleContext.captureId, &capturePrm, sizeof(capturePrm));
System_linkCreate(gVcapModuleContext.nsfId[1], &nsfPrm2, sizeof(nsfPrm2));
#endif
System_linkCreate(gVcapModuleContext.deiId[0], &deiPrm, sizeof(deiPrm));
System_linkCreate(dupId[D1_DUP_LINK_IDX], &dupPrm[D1_DUP_LINK_IDX], sizeof(dupPrm[D1_DUP_LINK_IDX]));
System_linkCreate(gVcapModuleContext.nsfId[0] , &nsfPrm, sizeof(nsfPrm));
System_linkCreate(mergeId[D1_CIF_MERGE_LINK_IDX], &mergePrm[D1_CIF_MERGE_LINK_IDX], sizeof(mergePrm[D1_CIF_MERGE_LINK_IDX]));
printf ("\n\n========System_linkCreate ALG0============\n");
System_linkCreate(gVcapModuleContext.ipcFramesOutVpssId[0], &ipcFramesOutVpssPrm, sizeof(ipcFramesOutVpssPrm));
System_linkCreate(gVcapModuleContext.ipcFramesInDspId[0], &ipcFramesInDspPrm, sizeof(ipcFramesInDspPrm));
System_linkCreate(gVcapModuleContext.dspAlgId[0] , &dspAlgPrm, sizeof(dspAlgPrm));
System_linkCreate(ipcBitsOutDSPId, &ipcBitsOutDspPrm, sizeof(ipcBitsOutDspPrm));
System_linkCreate(gVcapModuleContext.ipcBitsInHLOSId, &ipcBitsInHostPrm[1], sizeof(ipcBitsInHostPrm[1]));
System_linkCreate(ipcOutVpssId , &ipcOutVpssPrm , sizeof(ipcOutVpssPrm) );
System_linkCreate(ipcInVideoId , &ipcInVideoPrm , sizeof(ipcInVideoPrm) );
System_linkCreate(gVencModuleContext.encId, &encPrm, sizeof(encPrm));
System_linkCreate(gVencModuleContext.ipcBitsOutRTOSId, &ipcBitsOutVideoPrm, sizeof(ipcBitsOutVideoPrm));
System_linkCreate(gVencModuleContext.ipcBitsInHLOSId, &ipcBitsInHostPrm[0], sizeof(ipcBitsInHostPrm[0]));
System_linkGetInfo(gVencModuleContext.ipcBitsInHLOSId,&bitsProducerLinkInfo);
OSA_assert(bitsProducerLinkInfo.numQue == 1);
ipcBitsOutHostPrm.baseCreateParams.outQueParams[0].nextLink = gVdecModuleContext.ipcBitsInRTOSId;
printf ("\n\n========bitsProducerLinkInfo============\n");
printf ("numQ %d, numCh %d\n",
bitsProducerLinkInfo.numQue,
bitsProducerLinkInfo.queInfo[0].numCh);
int i;
for (i=0; i<bitsProducerLinkInfo.queInfo[0].numCh; i++)
printf ("Ch [%d] Width %d, Height %d\n",
i,
bitsProducerLinkInfo.queInfo[0].chInfo[i].width,
bitsProducerLinkInfo.queInfo[0].chInfo[i].height
printf ("\n====================\n\n");
if (bitsProducerLinkInfo.queInfo[0].numCh > gVencModuleContext.vencConfig.numPrimaryChn)
bitsProducerLinkInfo.queInfo[0].numCh = gVencModuleContext.vencConfig.numPrimaryChn;
printf ("Reducing bitsProducerLinkInfo.numCh to %d\n", bitsProducerLinkInfo.queInfo[0].numCh);
MultiCh_ipcBitsInitCreateParams_BitsOutHLOS(&ipcBitsOutHostPrm,
&bitsProducerLinkInfo.queInfo[0]);
ipcBitsOutHostPrm.numBufPerCh[0] = NUM_IPC_OUT_BUFFERS;
if(gVdecModuleContext.vdecConfig.forceUseDecChannelParams)
/* use channel info provided by user instead of from encoder */
UInt32 chId;
System_LinkChInfo *pChInfo;
ipcBitsOutHostPrm.inQueInfo.numCh = gVdecModuleContext.vdecConfig.numChn;
for(chId=0; chId<ipcBitsOutHostPrm.inQueInfo.numCh; chId++)
pChInfo = &ipcBitsOutHostPrm.inQueInfo.chInfo[chId];
/* Not Used - Start */
pChInfo->bufType = 0;
pChInfo->codingformat = 0;
pChInfo->dataFormat = 0;
pChInfo->memType = 0;
pChInfo->startX = 0;
pChInfo->startY = 0;
pChInfo->pitch[0] = 0;
pChInfo->pitch[1] = 0;
pChInfo->pitch[2] = 0;
/* Not Used - End */
pChInfo->width = gVdecModuleContext.vdecConfig.decChannelParams[chId].maxVideoWidth;
pChInfo->height = gVdecModuleContext.vdecConfig.decChannelParams[chId].maxVideoHeight;
pChInfo->scanFormat = SYSTEM_SF_PROGRESSIVE;
ipcBitsInVideoPrm.baseCreateParams.inQueParams.prevLinkId = gVdecModuleContext.ipcBitsOutHLOSId;
ipcBitsInVideoPrm.baseCreateParams.inQueParams.prevLinkQueId = 0;
ipcBitsInVideoPrm.baseCreateParams.numOutQue = 1;
ipcBitsInVideoPrm.baseCreateParams.outQueParams[0].nextLink = gVdecModuleContext.decId;
MultiCh_ipcBitsInitCreateParams_BitsInRTOS(&ipcBitsInVideoPrm, TRUE);
for (i=0; i<gVdecModuleContext.vdecConfig.numChn; i++) {
decPrm.chCreateParams[i].format = IVIDEO_H264HP;
decPrm.chCreateParams[i].profile = IH264VDEC_PROFILE_ANY;
decPrm.chCreateParams[i].fieldMergeDecodeEnable = FALSE;
decPrm.chCreateParams[i].targetMaxWidth = ipcBitsOutHostPrm.inQueInfo.chInfo[i].width;
decPrm.chCreateParams[i].targetMaxHeight = ipcBitsOutHostPrm.inQueInfo.chInfo[i].height;
decPrm.chCreateParams[i].defaultDynamicParams.targetFrameRate = gVdecModuleContext.vdecConfig.decChannelParams[i].dynamicParam.frameRate;
decPrm.chCreateParams[i].defaultDynamicParams.targetBitRate = gVdecModuleContext.vdecConfig.decChannelParams[i].dynamicParam.targetBitRate;
/* Max ref frames is only 2 as this is closed loop decoder */
decPrm.chCreateParams[i].dpbBufSizeInFrames = 2;
decPrm.chCreateParams[i].numBufPerCh = NUM_DECODE_BUFFERS;
decPrm.inQueParams.prevLinkId = gVdecModuleContext.ipcBitsInRTOSId;
decPrm.inQueParams.prevLinkQueId = 0;
decPrm.outQueParams.nextLink = ipcOutVideoId;
decPrm.tilerEnable = TILER_ENABLE;
ipcOutVideoPrm.inQueParams.prevLinkId = gVdecModuleContext.decId;
ipcOutVideoPrm.inQueParams.prevLinkQueId = 0;
ipcOutVideoPrm.numOutQue = 1;
ipcOutVideoPrm.outQueParams[0].nextLink = ipcInVpssId;
ipcOutVideoPrm.notifyNextLink = TRUE;
ipcOutVideoPrm.notifyPrevLink = TRUE;
ipcOutVideoPrm.noNotifyMode = FALSE;
ipcInVpssPrm.inQueParams.prevLinkId = ipcOutVideoId;
ipcInVpssPrm.inQueParams.prevLinkQueId = 0;
ipcInVpssPrm.numOutQue = 1;
ipcInVpssPrm.outQueParams[0].nextLink = mergeId[LIVE_DECODE_MERGE_LINK_IDX];
ipcInVpssPrm.notifyNextLink = TRUE;
ipcInVpssPrm.notifyPrevLink = TRUE;
ipcInVpssPrm.noNotifyMode = FALSE;
if(enableVideoFramesExport)
printf ("\n\n========Redirect Frame to A8!!!!!!!!============\n");
mergePrm[LIVE_DECODE_MERGE_LINK_IDX].numInQue = 2;
mergePrm[LIVE_DECODE_MERGE_LINK_IDX].inQueParams[0].prevLinkId = gVdisModuleContext.ipcFramesInVpssFromHostId;
mergePrm[LIVE_DECODE_MERGE_LINK_IDX].inQueParams[0].prevLinkQueId = 0;
mergePrm[LIVE_DECODE_MERGE_LINK_IDX].inQueParams[1].prevLinkId = ipcInVpssId;
mergePrm[LIVE_DECODE_MERGE_LINK_IDX].inQueParams[1].prevLinkQueId = 0;
mergePrm[LIVE_DECODE_MERGE_LINK_IDX].outQueParams.nextLink = dupId[LIVE_DECODE_DUP_LINK_IDX];
mergePrm[LIVE_DECODE_MERGE_LINK_IDX].notifyNextLink = TRUE;
else
mergePrm[LIVE_DECODE_MERGE_LINK_IDX].inQueParams[0].prevLinkId = dupId[D1_DUP_LINK_IDX];
#if MUX_SUPPORT
printf ("\n\n========Redirect to DSP for MUX!!!!!!!!============\n");
mergePrm[LIVE_DECODE_MERGE_LINK_IDX].inQueParams[0].prevLinkId = gVcapModuleContext.ipcFramesOutVpssId[1];
else
#endif
dupPrm[LIVE_DECODE_DUP_LINK_IDX].inQueParams.prevLinkId = mergeId[LIVE_DECODE_MERGE_LINK_IDX];
dupPrm[LIVE_DECODE_DUP_LINK_IDX].inQueParams.prevLinkQueId = 0;
dupPrm[LIVE_DECODE_DUP_LINK_IDX].numOutQue = 2;
dupPrm[LIVE_DECODE_DUP_LINK_IDX].outQueParams[0].nextLink = gVdisModuleContext.swMsId[0];
dupPrm[LIVE_DECODE_DUP_LINK_IDX].outQueParams[1].nextLink = gVdisModuleContext.swMsId[1];
dupPrm[LIVE_DECODE_DUP_LINK_IDX].notifyNextLink = TRUE;
for(i=0; i<2; i++)
swMsPrm[i].inQueParams.prevLinkId = dupId[LIVE_DECODE_DUP_LINK_IDX];
swMsPrm[i].inQueParams.prevLinkQueId = i;
swMsPrm[i].outQueParams.nextLink = gVdisModuleContext.displayId[i];
swMsPrm[i].maxInputQueLen = 4; // KC: changed to 4 to make the display smooth
swMsPrm[i].maxOutRes = VSYS_STD_1080P_60;
swMsPrm[i].initOutRes = gVdisModuleContext.vdisConfig.deviceParams[i].resolution;
swMsPrm[i].numOutBuf = 8;
//swMsPrm[i].numOutBuf = 4;
if (i == 1)
swMsPrm[i].maxOutRes = VSYS_STD_PAL;
swMsPrm[i].initOutRes = gVdisModuleContext.vdisConfig.deviceParams[VDIS_DEV_SD].resolution;
#ifdef SYSTEM_USE_TILER
swMsPrm[i].lineSkipMode = FALSE; // Double pitch not possible in tiler mode; so Line skip not possible
#else
swMsPrm[i].lineSkipMode = TRUE; // Set to TRUE for Enable low cost scaling
#endif
swMsPrm[i].enableLayoutGridDraw = gVdisModuleContext.vdisConfig.enableLayoutGridDraw;
MultiCh_swMsGetDefaultLayoutPrm(VDIS_DEV_HDMI, &swMsPrm[0], TRUE);
MultiCh_swMsGetDefaultLayoutPrm(VDIS_DEV_SD, &swMsPrm[1], TRUE);
displayPrm[i].inQueParams[0].prevLinkId = gVdisModuleContext.swMsId[i];
displayPrm[i].inQueParams[0].prevLinkQueId = 0;
displayPrm[i].displayRes = swMsPrm[i].initOutRes;
if (i == 1)
displayPrm[i].displayRes = gVdisModuleContext.vdisConfig.deviceParams[VDIS_DEV_SD].resolution;
displayPrm[i].forceFieldSeparatedInputMode = TRUE;
#if MUX_SUPPORT
int chId;
dspAlgPrm1.enableMUXAlg = TRUE;
//for(chId = 0; chId < ALG_LINK_MUX_MAX_CH; chId++)
//AlgLink_MuxCreateParams
/* set mux window max width and height */
dspAlgPrm1.muxCreateParams.maxWidth = 704;
dspAlgPrm1.muxCreateParams.maxHeight = 480;
//dspAlgPrm1.muxCreateParams.params_addr = EXAMPLE_OSD_WIN_MAX_HEIGHT;
dspAlgPrm1.muxCreateParams.videoByPass = 0;
dspAlgPrm1.muxCreateParams.RightSideChannelShow = 0;
//dspAlgPrm1.muxCreateParams.AdjustParams[0][0] = EXAMPLE_OSD_WIN_MAX_HEIGHT;
//memcpy(&dspAlgPrm1.muxCreateParams,&gVcapModuleContext.muxCreateParams,sizeof(dspAlgPrm1.muxCreateParams));
printf ("\n\n========Set muxCreateParams============\n");
#if 0
int chId;
//dspAlgPrm1.enableOSDAlg = TRUE;
dspAlgPrm1.enableOSDAlg = FALSE;
AlgLink_OsdChWinParams * chWinPrm = &dspAlgPrm1.osdChCreateParams[chId].chDefaultParams;
dspAlgPrm1.osdChCreateParams[chId].maxWidth = EXAMPLE_OSD_WIN_MAX_WIDTH;
dspAlgPrm1.osdChCreateParams[chId].maxHeight = EXAMPLE_OSD_WIN_MAX_HEIGHT;
#endif
printf ("\n\n========System_linkCreate ALG1============\n");
System_linkCreate(gVcapModuleContext.ipcFramesOutVpssId[1], &ipcFramesOutVpssPrm1, sizeof(ipcFramesOutVpssPrm1));
System_linkCreate(gVcapModuleContext.ipcFramesInDspId[1], &ipcFramesInDspPrm1, sizeof(ipcFramesInDspPrm1));
System_linkCreate(gVcapModuleContext.dspAlgId[1] , &dspAlgPrm1, sizeof(dspAlgPrm1));
#endif
System_linkCreate(gVcapModuleContext.ipcFramesOutVpssToHostId , &ipcFramesOutVpssToHostPrm , sizeof(ipcFramesOutVpssToHostPrm));
System_linkCreate(gVcapModuleContext.ipcFramesInHostId , &ipcFramesInHostPrm , sizeof(ipcFramesInHostPrm));
System_linkGetInfo(gVcapModuleContext.ipcFramesInHostId,&framesProducerLinkInfo);
OSA_assert(framesProducerLinkInfo.numQue == 1);
ipcFramesOutHostPrm.inQueInfo = framesProducerLinkInfo.queInfo[0];
System_linkCreate(gVdisModuleContext.ipcFramesOutHostId , &ipcFramesOutHostPrm , sizeof(ipcFramesOutHostPrm) );
System_linkCreate(gVdisModuleContext.ipcFramesInVpssFromHostId , &ipcFramesInVpssFromHostPrm , sizeof(ipcFramesInVpssFromHostPrm));
System_linkCreate(gVdecModuleContext.ipcBitsOutHLOSId,&ipcBitsOutHostPrm,sizeof(ipcBitsOutHostPrm));
System_linkCreate(gVdecModuleContext.ipcBitsInRTOSId,&ipcBitsInVideoPrm,sizeof(ipcBitsInVideoPrm));
System_linkCreate(gVdecModuleContext.decId, &decPrm, sizeof(decPrm));
System_linkCreate(ipcOutVideoId, &ipcOutVideoPrm, sizeof(ipcOutVideoPrm));
System_linkCreate(ipcInVpssId , &ipcInVpssPrm , sizeof(ipcInVpssPrm) );
System_linkCreate(mergeId[LIVE_DECODE_MERGE_LINK_IDX], &mergePrm[LIVE_DECODE_MERGE_LINK_IDX], sizeof(mergePrm[LIVE_DECODE_MERGE_LINK_IDX]));
System_linkCreate(dupId[LIVE_DECODE_DUP_LINK_IDX], &dupPrm[LIVE_DECODE_DUP_LINK_IDX], sizeof(dupPrm[LIVE_DECODE_DUP_LINK_IDX]));
for(i=0; i<2; i++)
System_linkCreate(gVdisModuleContext.swMsId[i] , &swMsPrm[i], sizeof(swMsPrm[i]));
for(i=0; i<2; i++) /* Both tied VENCs HDMI and DVO2 are handled by single link instance */
System_linkCreate(gVdisModuleContext.displayId[i], &displayPrm[i], sizeof(displayPrm[i]));
MergeLink_InLinkChInfo inChInfo;
MergeLink_InLinkChInfo_Init(&inChInfo);
inChInfo.inLinkID = ipcInVpssId;
System_linkControl(mergeId[LIVE_DECODE_MERGE_LINK_IDX],
MERGE_LINK_CMD_GET_INPUT_LINK_CHINFO,
&inChInfo,
sizeof(inChInfo),
TRUE);
OSA_assert(inChInfo.numCh == gVdecModuleContext.vdecConfig.numChn);
MultiCh_setDec2DispMap(VDIS_DEV_HDMI,gVdecModuleContext.vdecConfig.numChn,0,inChInfo.startChNum);
MultiCh_setDec2DispMap(VDIS_DEV_SD,gVdecModuleContext.vdecConfig.numChn,0,inChInfo.startChNum);
Void MultiCh_deleteProgressive4D1VcapVencVdecVdis()
UInt32 i;
System_linkDelete(gVcapModuleContext.captureId);
System_linkDelete(gVcapModuleContext.nsfId[1]);
#endif
System_linkDelete(gVcapModuleContext.deiId[0]);
System_linkDelete(gVcapModuleContext.nsfId[0]);
System_linkDelete(gVcapModuleContext.ipcFramesOutVpssId[0]);
System_linkDelete(gVcapModuleContext.ipcFramesInDspId[0]);
System_linkDelete(gVcapModuleContext.dspAlgId[0]);
System_linkDelete(ipcBitsOutDSPId);
System_linkDelete(gVcapModuleContext.ipcBitsInHLOSId);
System_linkDelete(ipcOutVpssId );
System_linkDelete(ipcInVideoId );
System_linkDelete(gVencModuleContext.encId);
System_linkDelete(gVencModuleContext.ipcBitsOutRTOSId);
System_linkDelete(gVencModuleContext.ipcBitsInHLOSId);
System_linkDelete(gVdecModuleContext.ipcBitsOutHLOSId);
System_linkDelete(gVdecModuleContext.ipcBitsInRTOSId);
System_linkDelete(gVdecModuleContext.decId);
System_linkDelete(ipcOutVideoId);
System_linkDelete(ipcInVpssId );
for(i=0; i<2; i++)
System_linkDelete(gVdisModuleContext.swMsId[i] );
for(i=0; i<2; i++)
System_linkDelete(gVdisModuleContext.displayId[i]);
for(i=0; i<NUM_DUP_LINK; i++)
System_linkDelete(dupId[i]);
for(i=0; i<NUM_MERGE_LINK; i++)
if (mergeId[i] != SYSTEM_LINK_ID_INVALID )
System_linkDelete(mergeId[i]);
/* Print the HWI, SWI and all tasks load */
/* Reset the accumulated timer ticks */
MultiCh_prfLoadCalcEnable(FALSE, TRUE, FALSE);
