hi, Judah
it is link error, unresolved symbol "HWI_eventMap", which lib shall I link?
thanks!
on omapl138 since the watch dog is on timer1 and dspbios default clock is also timer1, how to change dspbois clock from timer1 to timer2 ? my dspbois is 5_41_03_17. thanks!
bios_L138.tci
 * Copyright 2010 by Texas Instruments Incorporated.
 * @(#) DSP/BIOS_Kernel 5,2,5,28 02-10-2010 (cuda-u28)
 * ======== bios_L138.tci ========
 * This file contains BIOS settings for OMAPL138.
utils.importFile("ti/bios/config/bios_6748.tci");
 * ======== bios.initL138 ========
 * BIOS initialization for the L138 is same as for 6748 except that
 * we do not reset the timer by default (timer is shared with Arm).
bios.initL138 = function (prog, baseseed)
 bios.init6748(prog, baseseed);
prog.module("CLK").RESETTIMER = false;
bios_6748.tci
 * ======== bios_6748.tci ========
 * This file contains BIOS settings for 6748.
 * ======== bios.internal.setupMemory6748 ========
 * This function is the top-level function that will remove all MEM segments
 * from the cdb file. It will take your physical memory map from calling
 * getMemoryMap() and create MEM instances in cdb.
 * It will then set sections to the default segment specified and fix up
 * the length and/or base of MEM segments if needed.
bios.internal.setupMemory6748 = function (prog)
 * Enable the MAR bits for the entire DDR memory range.
 * (0xC000 0000 - 0xDFFF FFFF)
 prog.module("GBL").C64PLUSCONFIGURE = 1;
 prog.module("GBL").C64PLUSMAR192to223 = 0xffffffff;
 * BIOS MEM segments will be created from object model memory definitions.
 * Place default code and data sections into specified memory segments.
 bios.initializeMemory(prog, "IRAM", "IRAM");
 var iram = prog.module("MEM").instance("IRAM");
 var l1dsram = prog.module("MEM").instance("L1DSRAM");
bios.internal.setupCache6748(prog, iram);
 * ======== bios.internal.setupCache6748 ========
bios.internal.setupCache6748 = function (prog, iram)
 var cpu = prog.cpu;
 var cache_l1p = prog.module("MEM").instance("CACHE_L1P");
 var l1psram = prog.module("MEM").instance("L1PSRAM");
cache_l1p.len = 0x0;
 cache_l1p.base = l1psram.base + l1psram.len;
 if (cpu.registers.l1PMode == undefined || cpu.registers.l1PMode == null ||
 cpu.registers.l1PMode == "32k") {
 if (l1psram != undefined) {
 l1psram.destroy();
 cache_l1p.base -= 0x8000;
 cache_l1p.len = 0x8000;
 else {
 if (cpu.registers.l1PMode == "0k") {
 l1psram.len -= 0x0;
 else if (cpu.registers.l1PMode == "4k") {
 l1psram.len -= 0x1000;
 else if (cpu.registers.l1PMode == "8k") {
 l1psram.len -= 0x2000;
 else if (cpu.registers.l1PMode == "16k") {
 l1psram.len -= 0x4000;
 else {
 throw new Error("Can't set L1P cache to size: " +
 cpu.registers.l1PMode);
 var cache_l1d = prog.module("MEM").instance("CACHE_L1D");
 cache_l1d.len = 0x0;
 cache_l1d.base = l1dsram.base + l1dsram.len;
if (cpu.registers.l1DMode == undefined || cpu.registers.l1DMode == null ||
 cpu.registers.l1DMode == "32k") {
 if (l1dsram != undefined) {
 l1dsram.destroy();
 cache_l1d.base -= 0x8000;
 cache_l1d.len = 0x8000;
 else {
 if (cpu.registers.l1DMode == "0k") {
 l1dsram.len -= 0x0;
 else if (cpu.registers.l1DMode == "4k") {
 l1dsram.len -= 0x1000;
 else if (cpu.registers.l1DMode == "8k") {
 l1dsram.len -= 0x2000;
 else if (cpu.registers.l1DMode == "16k") {
 l1dsram.len -= 0x4000;
 else throw new Error("Can't set L1D cache to size: " +
 cpu.registers.l1DMode);
var cache = prog.module("MEM").instance("CACHE_L2");
cache.len = 0x0;
 cache.base = iram.base + iram.len;
if (cpu.registers.l2Mode != null) {
 if (cpu.registers.l2Mode == "0k") {
 iram.len -= 0x0;
 else if (cpu.registers.l2Mode == "32k") {
 iram.len -= 0x8000;
 else if (cpu.registers.l2Mode == "64k") {
 iram.len -= 0x10000;
 else if (cpu.registers.l2Mode == "128k") {
 iram.len -= 0x20000;
 else if (cpu.registers.l2Mode == "256k") {
 iram.len -= 0x40000;
 * All references to IRAM need to be changed to point to some other
 * available MEM instance.
 var memInst = prog.module("MEM").instances();
 var seg = null;
 for (var i=0; i < memInst.length; i++) {
 if (memInst[i].space == "code/data" && memInst[i] != iram) {
 seg = memInst[i];
 if (seg == null) {
 throw new Error("All of IRAM is used for cache " +
 "and there is no external memory in the configuration");
 else {
 bios.setMemCodeSections(prog, seg);
 bios.setMemDataNoHeapSections(prog, seg);
 iram.destroy();
 else {
 throw new Error("Can't set cache to size: " + cpu.registers.l2Mode);
 * ======== bios.init6748 ========
 * BIOS initialization for the 6748
bios.init6748 = function (prog, baseseed)
 * Find configuration seed files to load
 if (baseseed == null) {
 baseseed = "ti/bios/config/cdb/c6748.cdb";
var seed = utils.findSeed(baseseed);
 if (seed != null) {
 try {
 prog.load(seed);
 catch (e) {
 throw new Error ("Can't load configuration seed '" + seed + "' : "
 + e);
 else {
 throw new Error ("Can't find configuration seed: " + baseseed);
prog.module("ISRC").instance("Timer_0").iIntrSelectNum = 4;
 prog.module("ISRC").instance("Timer_1").iIntrSelectNum = 40;
 prog.module("HWI").instance("HWI_INT14").interruptSelectNumber = 4;
 prog.module("CLK").TIMER0BASE = 0x01c20000;
 prog.module("CLK").TIMER1BASE = 0x01c21000;
 prog.module("CLK").TIMERSELECT = "Timer 1";
/* enable specification of Input Clock Rate */
 prog.module("CLK").SPECIFYRATE = true;
 prog.module("CLK").INPUTCLK = 24.0;
 prog.module("CLK").RESETTIMER = true;
/* set CLKOUT to be the value of cpu.clockRate. */
 bios.internal.setClkout(prog);
/* Set endian mode based on build options */
 if (prog.build.target.model.endian != null) {
 if (prog.build.target.model.endian != "little") {
 print("Warning: '" + prog.build.target.model.endian +
 "' endian mode" + " is not supported on '" +
 prog.cpu.deviceName + "' device.")
prog.module("GBL").ENDIANMODE = prog.build.target.model.endian;
 /* initialize the default memory segments for 6748 */
 bios.internal.setupMemory6748(prog);
/* initialize some memory map registers */
 bios.internal.initializeRegisterMap(prog);
hi, Judah
Replace :
With:
prog.module("CLK").TIMERSELECT = "Timer 2";
compile fail, below is error message
make[4]: Entering directory `/omapl138/c6run_0_98_03_03/build/dsp_libs/os/dspbios5'
TCONF: Generating DSP/BIOS files...
(if (self.WHICHTIMER != $1) {if (self.USETIMER == 0) {$e = "ok"} else {if ($1 == "Timer 0") {$a = Timer_0.iHwi} else {if ($1 == "Timer 1") {$a = Timer_1.iHwi} else {$a = Timer_2.iHwi}}, $e = self.seizeHwi($a)}, if ($e == "ok") {self.releaseHwi(self.WHICHHWI), if ($1 == "Timer 0") {self.TIMERNUM = 0, self.WHICHHWI = Timer_0.iHwi} else {if ($1 == "Timer 1") {self.TIMERNUM = 1, self.WHICHHWI = Timer_1.iHwi} else {self.TIMERNUM = 2, self.WHICHHWI = Timer_2.iHwi}}, self.WHICHTIMER = $1, self.HOOKFXN = if self.gNumOf > 0 {@HWI_F_dispatch} else {(if GBL.CALLMODEL == "far" {@CLK_F_frete} else {@CLK_F_rete})}, self.seizeHwi(self.WHICHHWI)} , $e} )
 Timer_2.iHwi
 ==> err
 $a = Timer_2.iHwi
 ==> err
 ==> err
 ==> err
 $a
 ==> err
 $a
 ==> err
 $a
 ==> err
 $a
 ==> err
 $a
 ==> err
 $a
 ==> err
 $a
 ==> err
 $a
 ==> err
 $a
 ==> err
(if ($1.client == "USER" && $1 == HWI_UNUSED) {self.error("Interrupt not mapped for selected timer.")} else {if ($1.client == "USER" && $1.function != @HWI_unused) {self.error("Interrupt mapped to selected timer is already in use.")} else {if ($1.client == "CSL") {self.error("Interrupt mapped to selected timer is already in use by CSL.")} else {$1.function = @CLK_F_isr, $1.client = "CLK", $1.iEventId = $1.iSource.iIntrSelectNum, $1.iUseDispatcher = (if CLK.HOOKFXN == @HWI_F_dispatch {1} else {0}), $1.iArg = (if $1.iUseDispatcher == 1 {@CLK_A_TABBEG} else {0}), HWI.gDirty = 1, "ok"}}})
 $1
 ==> err
 $1.client
 ==> err
 $1.client == "USER"
 ==> err
 $1
 ==> err
 $1 == HWI_UNUSED
 ==> err
 ==> err
 ==> err
 ==> err
 ==> err
 self.seizeHwi($a)
 ==> err
 ==> err
 ==> err
 ==> err
 $e
 ==> err
 $e == "ok"
 ==> err
 ($e == "ok")
 ==> err
 ==> err
 ==> err
 $e
 ==> err
 ==> err
 ==> err
 ==> err
js: "/omapl138/dspbios_5_41_03_17/packages/ti/bios/config/bios_6748.tci", line 191: Can't set field
js: "/omapl138/xdctools_3_16_03_36/include/utils.tci", line 947: Error: Can't load platform definition 'ti.platforms.evmOMAPL138': InternalError: Error
make[4]: *** [C6Runcfg.cmd] Error 1
make[4]: Leaving directory `/omapl138/c6run_0_98_03_03/build/dsp_libs/os/dspbios5'
Huang,
I just realized that there is no support for Timer 2 or 3 in DSPBIOS 5.xx.
You only have Timer 0 and Timer 1 available. I don't know why Timer 2 and Timer 3 support was not added...could be that these only support 64-bit mode?
I will file a bug but I don't know if or when this will be fix as development is mainly on SYSBIOS 6.xx and I know Timer 2 and 3 are supported there.
bug id: SDOCM00100381
Judah
hi, Judah
http://e2e.ti.com/support/embedded/bios/f/355/p/74121/284126.aspx#284126
seems to be the same problem i'm facing, but i fail to link "timer.c" because of unresolved "HWI_eventMap", and i don't know how to modify bios configuration file,
can you give me some advice ?
thanks!
Huang,
Yes, the same workaround should work for you. HWI_eventMap is an API that is part of the HWI module in BIOS. It should be included in one of the BIOS libraries.
What's the exact error you are getting? Is it a compile or a link error?
Judah
hi, Judah
thanks!
Sounds like you are manually linking in the BIOS libraries? Which version of BIOS are you using?
It should be part of the library called something like "ti/bios/lib/bios.a64P". Are you on a c64+ device? I believe OMAPL138 uses a c64+ DSP part.
Judah
hi, Karl
i think i make a mistake, i compile and link "timer.c" on the ARM side. according to the lib "bios.a674", i think "timer.c" shall compile and link on DSP side, is it right?
i'm using C6Run to compile code on DSP side, and when i compile "timer.c", got following error, which macro shall i define ?
thanks!
/omapl138/c6run_0_98_03_03/bin/c6runlib-cc -c -O3 -I/omapl138/c6run_0_98_03_03/include -I/omapl138/c6run_0_98_03_03/../ti_libs/volib_C64P_2_0_0_3/packages -I./src -I./ -Dti_targets_C64P -D__TI_DSP__ -I./mp4v2 -I/omapl138/dspbios_5_41_03_17/packages/ti/bios/include -o dsp_lib/timer.o timer.c
In file included from /omapl138/dspbios_5_41_03_17/packages/ti/bios/include/std.h:12,
 from timer.c:29:
/omapl138/dspbios_5_41_03_17/packages/ti/bios/include/tistdtypes.h:80:6: error: #error <tistdtypes.h> is not supported for this target
In file included from timer.c:29:
/omapl138/dspbios_5_41_03_17/packages/ti/bios/include/std.h:168:2: error: #error <std.h> types not supported for this target
 from timer.c:29:
In file included from /omapl138/dspbios_5_41_03_17/packages/ti/bios/include/prd.h:13,
 from timer.c:32:
/omapl138/dspbios_5_41_03_17/packages/ti/bios/include/fxn.h:24: error: expected specifier-qualifier-list before 'Arg'
In file included from timer.c:34:
/omapl138/dspbios_5_41_03_17/packages/ti/bios/include/gbl.h:20: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'GBL_procId'
/omapl138/dspbios_5_41_03_17/packages/ti/bios/include/gbl.h:21: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'GBL_clkIn'
/omapl138/dspbios_5_41_03_17/packages/ti/bios/include/gbl.h:22: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'GBL_freq'
/omapl138/dspbios_5_41_03_17/packages/ti/bios/include/gbl.h:31: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'GBL_getProcId'
/omapl138/dspbios_5_41_03_17/packages/ti/bios/include/gbl.h:43: error: expected ')' before 'newProcId'
/omapl138/dspbios_5_41_03_17/packages/ti/bios/include/gbl.h:54: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'GBL_getClkIn'
/omapl138/dspbios_5_41_03_17/packages/ti/bios/include/gbl.h:65: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'GBL_getFrequency'
/omapl138/dspbios_5_41_03_17/packages/ti/bios/include/gbl.h:78: error: expected ')' before 'frequency'
/omapl138/dspbios_5_41_03_17/packages/ti/bios/include/gbl.h:90: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'GBL_getVersion'
timer.c: In function 'Timer_init':
