#include <stdio.h>
#include <string.h>
#include <c6x.h>
#include <ti/csl/cslr_device.h>
#include <ti/csl/csl_edma3.h>
#include <ti/csl/csl_intc.h>
#include <ti/csl/csl_intcAux.h>
#include "my.h"
#define TPCC_BASEADDR(n) (0x02700000 + n * 0x20000)
#define IPR(n) *(volatile int*)(TPCC_BASEADDR(n) + 0x1068)
#define INTC_BASEADDR(n) (0x02600000 + n * 0x4000)
#define STATUS_SET_INDEX_REG(n) *(volatile unsigned int*)(INTC_BASEADDR(n) + 0x020)
void Generate_IPC_Interrup(int coreNum, int info);
int IPC_Interrup_Process();
void IPCInterruptHandler();
void main()
int i = 0;
intc_init();
IntcBind(CSL_GEM_IPC_LOCAL,CSL_INTC_VECTID_6, IPCInterruptHandler);
if(DNUM == 1)
for(i = 0; i < 8; i++)
Generate_IPC_Interrup(i,i);
while(1);
* ����˵�����ú���ʵ�ָ�8�����е�����һ���˷���һ��IPC�ж�
* ����˵����int coreNum���˱��
* int info�� �������˷��͵���Ϣ������Ϣ����Ϊ0bit-27bit,����ÿһλ��λ����������ʾһ����Ϣ�������Ϣ�ĸ�ʽ�Զ���
* ��ע�� �ú�����ͬһʱ��ֻ�ܸ�һ���˲���һ��ͬ���¼�
hIpc->IPCGR[coreNum] |= (info << 4);
hIpc->IPCGR[coreNum] |= 0x1;
return;
* ����˵�����ú�������IPC�жϷ�������У�����IPC�жϷ��������ʱ�����øú��������ط��ͷ����ݵ���Ϣ
int info;
info = hIpc->IPCGR[DNUM] & 0xFFFFFFF0;
hIpc->IPCAR[DNUM] = info;
return (info >> 4);
int info;
info = IPC_Interrup_Process();
printf("info = %d\n",info);
I meet a problem with the IPC interrupt, i writed IPCGRx to set up a interrupt to corex.
when i set a specific vector id except for the 4th vector id, the target core will enter twice interrupt ,
i have check the IFR register , the bit Corresponds to the 4th vector id will always be set up regardless of the specific vector id i used after i writed the IPCGRx of the target core , i don't know why ? can anyone help?
the code is pasted:
#include <stdio.h>
#include <string.h>
#include <c6x.h>
#include "my.h"
void main()
int i = 0;
intc_init();
if(DNUM == 1)
while(1);
return;
int info;
return (info >> 4);
int info;
Thanks ,
Jason Gao.
