android2.3.4 can't run on Am3352
Other Parts Discussed in Thread: AM3352, AM3359
Hello everyone!
        My platform is am3352, system:android2.3.4  kernel: 3.1.0
I compile the android2.3.4 can run on am3359,but can't run on am3352
the log is :
[ 4.042336] VFS: Mounted root (ubifs filesystem) on device 0:12.
[ 4.049334] Freeing init memory: 216K
[ 4.309689] init: cannot find '/system/etc/install-recovery.sh', disabling 'flash_recovery'
# [ 4.504145] Compat-wireless backport release: compat-wireless-2011-07-27
[ 4.511472] Backport based on wl12xx.git v2.6.39-1152-g0c08ddf
[ 4.627517] warning: `dhcpcd' uses 32-bit capabilities (legacy support in use)
[ 4.681456] g_zero: disagrees about version of symbol module_layout
[ 4.781745] android_usb: already disabled
[ 4.786614] adb_bind_config
[ 4.790430] init: sys_prop: mis-match msg size recieved: -1 expected: 128
[ 4.854157] adb_open
[ 4.913264]
[ 4.913275] CPSW phy found : id is : 0x0
[ 4.920143]
[ 4.920147] CPSW phy found : id is : 0x0
[ 5.133183] cm: Module associated with clock sgx_ck didn't enable in 100000 tries
[ 5.196026] cfg80211: Calling CRDA to update world regulatory domain
[ 5.262273] cfg80211: World regulatory domain updated:
[ 5.267970] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 5.277096] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 5.285741] cfg80211: (2457000 KHz - 2482000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
[ 5.294385] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
[ 5.303014] cfg80211: (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 5.311657] cfg80211: (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 6.484128] Unhandled fault: external abort on non-linefetch (0x1028) at 0xe3000014
[ 6.492495] Internal error: : 1028 [#1]
[ 6.496672] Modules linked in: wl12xx mac80211 cfg80211 omaplfb pvrsrvkm compat
[ 6.504678] CPU: 0 Not tainted (3.1.0 #4)
[ 6.509495] PC is at OSReadHWReg+0xc/0x18 [pvrsrvkm]
[ 6.514935] LR is at SysFinalise+0x9c/0x118 [pvrsrvkm]
[ 6.520535] pc : [<bf004220>] lr : [<bf017910>] psr: a0000013
[ 6.520544] sp : df317e30 ip : df317e40 fp : df317e3c
[ 6.533050] r10: 00000000 r9 : df316000 r8 : e3000000
[ 6.538743] r7 : bf023db4 r6 : 00000000 r5 : 00000000 r4 : bf023cf0
[ 6.545855] r3 : 00000000 r2 : e4000000 r1 : 00000014 r0 : e3000000
[ 6.552972] Flags: NzCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
[ 6.560748] Control: 10c5387d Table: 9f31c019 DAC: 00000015
[ 6.567008]
[ 6.567012] SP: 0xdf317db0:
[ 6.571659] 7db0 01000000 df191000 df316000 00000000 df317dec df317dd0 bf004220 a0000013
[ 6.580605] 7dd0 ffffffff df317e1c df317e3c df317de8 c03f0618 c0008374 e3000000 00000014
[ 6.589548] 7df0 e4000000 00000000 bf023cf0 00000000 00000000 bf023db4 e3000000 df316000
[ 6.598491] 7e10 00000000 df317e3c df317e40 df317e30 bf017910 bf004220 a0000013 ffffffff
[ 6.607435] 7e30 df317e6c df317e40 bf017910 bf004220 df317e64 00000012 df190048 bf023db4
[ 6.616379] 7e50 df191000 00000000 df190000 df191000 df317e84 df317e70 bf0103f4 bf017880
[ 6.625322] 7e70 df190000 df191000 df317ea4 df317e88 bf015038 bf0103e0 df022340 df317ed0
[ 6.634266] 7e90 00000045 df190000 df317ecc df317ea8 bf014218 bf014fec df2ffac0 000000b2
[ 6.643211]
[ 6.643215] IP: 0xdf317dc0:
[ 6.647862] 7dc0 df317dec df317dd0 bf004220 a0000013 ffffffff df317e1c df317e3c df317de8
[ 6.656806] 7de0 c03f0618 c0008374 e3000000 00000014 e4000000 00000000 bf023cf0 00000000
[ 6.665750] 7e00 00000000 bf023db4 e3000000 df316000 00000000 df317e3c df317e40 df317e30
[ 6.674693] 7e20 bf017910 bf004220 a0000013 ffffffff df317e6c df317e40 bf017910 bf004220
[ 6.683637] 7e40 df317e64 00000012 df190048 bf023db4 df191000 00000000 df190000 df191000
[ 6.692580] 7e60 df317e84 df317e70 bf0103f4 bf017880 df190000 df191000 df317ea4 df317e88
[ 6.701524] 7e80 bf015038 bf0103e0 df022340 df317ed0 00000045 df190000 df317ecc df317ea8
[ 6.710468] 7ea0 bf014218 bf014fec df2ffac0 000000b2 df317ed0 c01c6745 00000000 df316000
[ 6.719412]
[ 6.719416] FP: 0xdf317dbc:
[ 6.724064] 7dbc 00000000 df317dec df317dd0 bf004220 a0000013 ffffffff df317e1c df317e3c
[ 6.733007] 7ddc df317de8 c03f0618 c0008374 e3000000 00000014 e4000000 00000000 bf023cf0
[ 6.741950] 7dfc 00000000 00000000 bf023db4 e3000000 df316000 00000000 df317e3c df317e40
[ 6.750893] 7e1c df317e30 bf017910 bf004220 a0000013 ffffffff df317e6c df317e40 bf017910
[ 6.759837] 7e3c bf004220 df317e64 00000012 df190048 bf023db4 df191000 00000000 df190000
[ 6.768781] 7e5c df191000 df317e84 df317e70 bf0103f4 bf017880 df190000 df191000 df317ea4
[ 6.777725] 7e7c df317e88 bf015038 bf0103e0 df022340 df317ed0 00000045 df190000 df317ecc
[ 6.786668] 7e9c df317ea8 bf014218 bf014fec df2ffac0 000000b2 df317ed0 c01c6745 00000000
[ 6.795612]
[ 6.795616] R0: 0xe2ffff80:
[ 6.800264] ff80 ******** ******** ******** ******** ******** ******** ******** ********
[ 6.809217] ffa0 ******** ******** ******** ******** ******** ******** ******** ********
[ 6.818164] ffc0 ******** ******** ******** ******** ******** ******** ******** ********
[ 6.827110] ffe0 ******** ******** ******** ******** ******** ******** ******** ********
[ 6.836056] 0000
[ 6.837961] Unhandled fault: external abort on non-linefetch (0x1028) at 0xe3000000
[ 6.846497] Internal error: : 1028 [#2]
[ 6.850671] Modules linked in: wl12xx mac80211 cfg80211 omaplfb pvrsrvkm compat
[ 6.858663] CPU: 0 Not tainted (3.1.0 #4)
[ 6.863434] PC is at __copy_from_user+0xac/0x3b4
[ 6.868484] LR is at show_data.clone.0+0x84/0xfc
[ 6.873516] pc : [<c0199778>] lr : [<c0014684>] psr: 00000193
[ 6.873525] sp : df317bc4 ip : 0000001c fp : df317c1c
[ 6.886030] r10: 00000008 r9 : 00000000 r8 : 00000000
[ 6.891722] r7 : 00000000 r6 : e3000000 r5 : 00000004 r4 : df316000
[ 6.898835] r3 : 00000000 r2 : ffffffe4 r1 : e3000000 r0 : df317bec
[ 6.905948] Flags: nzcv IRQs off FIQs on Mode SVC_32 ISA ARM Segment kernel
[ 6.914009] Control: 10c5387d Table: 9f31c019 DAC: 00000015
who can help me the question?
 Thanks!
