McFW VLIB errors
Hi all,
      Recently, I am working on McFW  demos in DVRRDK 3.0 with DM8168EVM. Now I want to use vlib function in my  codes,so I have to addd the vlib library (vlib_elf.le64p) in makefile.
In rules_c674.mk file, I added the following library.
LIB_PATHS += $(dvr_rdk_PATH)/mcfw/src_bios6/links_c6xdsp/alg_link/ivs/lib/vlib_elf.le64p .
However,when I build the codes,I meeting the following errors:
error: symbol "minArea" redefined: first defined in
"/usr/local/yourapp/DVRRDK_03.00.00.00/dvr_rdk/../dvr_rdk/mcfw/src_bios6/lin
ks_c6xdsp/alg_link/ivs/lib/vlib_elf.le64p<AVMIntervalImage.obj>"; redefined
in
"/usr/local/yourapp/DVRRDK_03.00.00.00/dvr_rdk/../dvr_rdk/mcfw/src_bios6/alg
/va/lib/analytics.ae674<DMVAL_ccIntervalImage.obj>"
error: symbol "ucAssign" redefined: first defined in
ks_c6xdsp/alg_link/ivs/lib/vlib_elf.le64p<ncList.obj>"; redefined in
/va/lib/analytics.ae674<DMVAL_List.obj>"
error: symbol "ucEqual" redefined: first defined in
error: symbol "notNULL" redefined: first defined in
error: symbol "ptrEqual" redefined: first defined in
error: symbol "ptrAssign" redefined: first defined in
error: symbol "intEqual" redefined: first defined in
error: symbol "intAssign" redefined: first defined in
"/usr/local/yourapp/DVRRDK_03.00.00.00/dvr_rdk/../dvr_rdk/mcfw/src_bios6/cfg/ti816x/link_algs.cmd", line 12: warning:
no matching section
How can I solve the problem ? Could you give me some help?
Thank you.
         JQ Zhao
    We have already  included VLIB library in RDK code hence you might be getting compilation errors related to multiple definition. Please remove one of them and then check. Could you let us know the version of VLIB that you have added from your end.
    Please check ~/dvr_rdk/makerules/rules_c674.mk file.
                 $(dvr_rdk_PATH)/mcfw/src_bios6/alg/va/lib/vlib.ae674\^M
                 $(dvr_rdk_PATH)/mcfw/src_bios6/alg/va/lib/analytics.ae674\^M
  • Thanks for your reply. I have checked the rules_c674.mk file. The following Is I used
                 $(dvr_rdk_PATH)/mcfw/src_bios6/alg/va/lib/vlib.ae674 \
    However the similar errors is occurred。
    /alg/va/lib/vlib.ae674<AVMIntervalImage.obj>"; redefined
    in
    /alg/va/lib/vlib.ae674<ncList.obj>"; redefined in
    How to solve this??Please give me some suggestions?
    Thanks for confirming.
    I have couple of questions:
    1. Are you seeing this problem for the symbols that are used in your custom code/algorithms? E.g. do you use minArea in your code ?
    2. Did you verify compile options and checked if --scan_libraries and/or -scanlibs are not enabled by default?
  • Any updates?
    We are planning to fix this issue in DVR-RDK 04.0 release.
