Other Parts Discussed in Thread: AM3874
My customer is using BSP ver. 02.30.00.
Customer tested PowerVR-DEMOS that it is attached in BSP.
And customer had two symptom as the following.
1) Running test for long time:
They run SKYBOX(baloon demo) in own system (AM3874 is used in its system) long time.
After three days, the Power VR demo stopped suddenly! Then, customer closed the PowerVR-Demo once, and tried to run same demo again.
But customer had a below message.
"Cannot execute 'OGLESSkybox'. A critical component is either missing or failing to start due to low memory."
2) Start/Stop test :
Customer repeated to start/stop PowerVR demo. After repetition ten times, customer had the below message.
" PVRShell:Unable to create surface"
The AM3874 system recover from the above both symptom by Power off/on only.
Do you know similar symptoms in WEC7 BSP? If you have any information for these issue, please let me know.
Michi
