Andriod ICS Booting issue on Pandaboard ES1.1 4460
setenv bootargs 'console=ttyO2,115200n8 androidboot.console=ttyO2 mem=4
Panda # setenv bootcmd 'mmcinit 0;fatload mmc 0 0x80000000 uImage; bootm 0x8000'
Panda # boot
Unknown command 'mmcinit' - try 'help'
reading uImage
4434784 bytes read
## Booting kernel from Legacy Image at 80000000 ...
   Image Name:   Ubuntu kernel
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    4434720 Bytes = 4.2 MiB
   Load Address: 80008000
   Entry Point:  80008000
   Verifying Checksum ... OK
   Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
[    0.000000] Booting Linux on physical CPU 0
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Linux version 3.2.0-1412-omap4 (buildd@shedir) (gcc version 4.6.)
[    0.000000] CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=10c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instructie
[    0.000000] Machine: OMAP4 Panda board
[    0.000000] Reserving 33554432 bytes SDRAM for VRAM
[    0.000000] Memory policy: ECC disabled, Data cache writealloc
[    0.000000] OMAP4460 ES1.1
[    0.000000] PERCPU: Embedded 8 pages/cpu @c1240000 s10080 r8192 d14496 u32768
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pa2
[    0.000000] Kernel command line: console=ttyO2,115200n8 androidboot.console=0
[    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] allocated 4194304 bytes of page_cgroup
[    0.000000] please try 'cgroup_disable=memory' option if you don't want memos
[    0.000000] Memory: 456MB 479MB = 935MB total
[    0.000000] Memory: 934188k/934188k available, 57044k reserved, 228352K highm
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
[    0.000000]     vmalloc : 0xf0800000 - 0xf8000000   ( 120 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xf0000000   ( 768 MB)
[    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
[    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
[    0.000000]       .text : 0xc0008000 - 0xc08b334c   (8877 kB)
[    0.000000]       .init : 0xc08b4000 - 0xc0918760   ( 402 kB)
[    0.000000]       .data : 0xc091a000 - 0xc09710a8   ( 349 kB)
[    0.000000]        .bss : 0xc09710cc - 0xc0a37a0c   ( 795 kB)
[    0.000000] SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=2, 1
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000] NR_IRQS:410 nr_irqs:410 410
[    0.000000] ------------[ cut here ]------------
[    0.000000] WARNING: at /build/buildd/linux-ti-omap4-3.2.0/arch/arm/common/g)
[    0.000000] Cannot allocate irq_descs @ IRQ16, assuming pre-allocated
[    0.000000] Modules linked in:
[    0.000000] [<c0015cd0>] (unwind_backtrace+0x0/0xec) from [<c05b9fd4>] (dump)
[    0.000000] [<c05b9fd4>] (dump_stack+0x20/0x24) from [<c0052a64>] (warn_slow)
[    0.000000] [<c0052a64>] (warn_slowpath_common+0x5c/0x74) from [<c0052b38>] )
[    0.000000] [<c0052b38>] (warn_slowpath_fmt+0x40/0x48) from [<c08bbc50>] (gi)
[    0.000000] [<c08bbc50>] (gic_init+0xb0/0x11c) from [<c08bf360>] (gic_init_i)
[    0.000000] [<c08bf360>] (gic_init_irq+0x6c/0x80) from [<c08b74bc>] (init_IR)
[    0.000000] [<c08b74bc>] (init_IRQ+0x1c/0x24) from [<c08b4774>] (start_kerne)
[    0.000000] [<c08b4774>] (start_kernel+0x184/0x318) from [<80008044>] (0x800)
[    0.000000] ---[ end trace da227214a82491b7 ]---
[    0.000000] OMAP clockevent source: GPTIMER1 at 32768 Hz
[    0.000000] sched_clock: 32 bits at 32kHz, resolution 30517ns, wraps every 1s
[    0.000000] Console: colour dummy device 80x30
[    0.000152] Calibrating delay loop... 1392.74 BogoMIPS (lpj=5439488)
[    0.070404] pid_max: default: 32768 minimum: 301
[    0.070648] Security Framework initialized
[    0.070739] AppArmor: AppArmor initialized
[    0.070739] Yama: becoming mindful.
[    0.071044] Mount-cache hash table entries: 512
[    0.072174] Initializing cgroup subsys cpuacct
[    0.072235] Initializing cgroup subsys memory
[    0.072296] Initializing cgroup subsys devices
[    0.072326] Initializing cgroup subsys freezer
[    0.072326] Initializing cgroup subsys net_cls
[    0.072357] Initializing cgroup subsys blkio
[    0.072387] Initializing cgroup subsys perf_event
[    0.072540] CPU: Testing write buffer coherency: ok
[    0.072601] ftrace: allocating 25675 entries in 76 pages
[    0.117462] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.117523] Calibrating local timer... 341.64MHz.
[    0.164306] hw perfevents: enabled with ARMv7 Cortex-A9 PMU driver, 7 countee
[    0.164428] Setting up static identity map for 0x805d4dd0 - 0x805d4e18
[    0.164459] L310 cache controller enabled
[    0.164459] l2x0: 16 ways, CACHE_ID 0x410000c7, AUX_CTRL 0x5e470000, Cache sB
[    0.240905] CPU1: Booted secondary processor
[    0.271087] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.271118] CPU1: Unknown IPI message 0x1
[    0.271148] Brought up 2 CPUs
[    0.271148] SMP: Total of 2 processors activated (2755.07 BogoMIPS).
[    0.272155] devtmpfs: initialized
[    0.276947] omap_hwmod: l4_div_ck: missing clockdomain for l4_div_ck.
[    0.332153] omap_hwmod: mcpdm: _wait_target_ready: -16
[    0.332183] ------------[ cut here ]------------
[    0.332214] WARNING: at /build/buildd/linux-ti-omap4-3.2.0/arch/arm/mach-oma)
[    0.332214] Modules linked in:
[    0.332275] [<c0015cd0>] (unwind_backtrace+0x0/0xec) from [<c05b9fd4>] (dump)
[    0.332305] [<c05b9fd4>] (dump_stack+0x20/0x24) from [<c0052a64>] (warn_slow)
[    0.332336] [<c0052a64>] (warn_slowpath_common+0x5c/0x74) from [<c0052aa8>] )
[    0.332366] [<c0052aa8>] (warn_slowpath_null+0x2c/0x34) from [<c0022a34>] (_)
[    0.332397] [<c0022a34>] (_enable+0x1ec/0x220) from [<c0022e64>] (_setup.par)
[    0.332427] [<c0022e64>] (_setup.part.13+0x20/0xf0) from [<c0022fc8>] (_setu)
[    0.332458] [<c0022fc8>] (_setup+0x94/0x9c) from [<c0023174>] (omap_hwmod_fo)
[    0.332489] [<c0023174>] (omap_hwmod_for_each+0x38/0x68) from [<c08be724>] ()
[    0.332519] [<c08be724>] (omap_hwmod_setup_all+0x74/0xa0) from [<c000876c>] )
[    0.332550] [<c000876c>] (do_one_initcall+0xa0/0x170) from [<c08b49d0>] (ker)
[    0.332580] [<c08b49d0>] (kernel_init+0xc8/0x170) from [<c000ee84>] (kernel_)
[    0.332580] ---[ end trace da227214a82491b8 ]---
[    0.332611] omap_hwmod: mcpdm: cannot be enabled (3)
[    0.339355] Enabling ERRATA 751472
[    0.339385] OMAP4: Map 0xafe00000 to 0xfe600000 for dram barrier
[    0.340332] print_constraints: dummy:
[    0.340637] NET: Registered protocol family 16
[    0.341369] GPMC revision 6.0
[    0.341461]  mpu.0: alias fck already exists
[    0.341766]  iva.0: alias fck already exists
[    0.343200] OMAP GPIO hardware version 0.1
[    0.344848] omap_mux_init: Add partition: #1: core, flags: 2
[    0.345855] omap_mux_init: Add partition: #2: wkup, flags: 2
[    0.348602] SRAM: Mapped pa 0x40300000 to va 0xf0840000 size: 0xd000
[    0.352050] _omap_mux_init_gpio: Could not set gpio7
[    0.352111] hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint.
[    0.352142] hw-breakpoint: maximum watchpoint size is 4 bytes.
[    0.357849] omap_ipussdev_init: could not look up fdif
[    0.358795] OMAP DMA hardware revision 0.0
[    0.366760] bio: create slab <bio-0> at 0
[    0.367584] print_constraints: vwl1271: 1800 mV
[    0.368865] i2c-core: driver [twl] using legacy suspend method
[    0.368865] i2c-core: driver [twl] using legacy resume method
[    0.369659] SCSI subsystem initialized
[    0.371124] usbcore: registered new interface driver usbfs
[    0.371185] usbcore: registered new interface driver hub
[    0.371368] usbcore: registered new device driver usb
[    0.385528] omap_i2c omap_i2c.1: bus 1 rev2.4.0 at 400 kHz
[    0.386230] Skipping twl internal clock init and using bootloader value (unk)
[    0.386749] twl6030: PIH (irq 39) chaining IRQs 368..387
[    0.387390] print_constraints: VUSB: 3300 mV normal standby
[    0.585357] twl6030_usb twl6030_usb: Initialized TWL6030 USB module
[    0.586334] print_constraints: VMMC: 1200 <--> 3000 mV at 3000 mV normal stay
[    0.586853] print_constraints: VPP: 1800 <--> 2500 mV at 1900 mV normal stany
[    0.587341] print_constraints: VUSIM: 1200 <--> 2900 mV at 1800 mV normal sty
[    0.587921] print_constraints: VCXIO: 1800 mV normal standby
[    0.588256] print_constraints: VDAC: 1800 mV normal standby
[    0.588745] print_constraints: VAUX1_6030: 1000 <--> 3000 mV at 2800 mV normy
[    0.588806] twl_reg twl_reg.37: Failed to set supply vmmc
[    0.588897] twl_reg twl_reg.37: can't register VAUX1_6030, -16
[    0.588928] twl_reg: probe of twl_reg.37 failed with error -16
[    0.589355] print_constraints: VAUX2_6030: 1200 <--> 2800 mV at 1800 mV normy
[    0.589843] print_constraints: VAUX3_6030: 1000 <--> 3000 mV at 1200 mV normy
[    0.590209] print_constraints: CLK32KG:
[    0.590545] print_constraints: VANA: 2100 mV normal standby
[    0.599060] omap_i2c omap_i2c.2: bus 2 rev2.4.0 at 400 kHz
[    0.614318] omap_i2c omap_i2c.3: bus 3 rev2.4.0 at 100 kHz
[    0.629577] omap_i2c omap_i2c.4: bus 4 rev2.4.0 at 400 kHz
[    0.630279] iommu_enable: NULL arch_iommu
[    0.630310] omap-iommu omap-iommu.0: can't get omap iommu: -19
[    0.630310] omap-iommu omap-iommu.0: can't attach iommu device: -19
[    0.630401] omap-iommu omap-iommu.1: tesla registered
[    0.630554] Advanced Linux Sound Architecture Driver Version 1.0.24.
[    0.631164] NetLabel: Initializing
[    0.631195] NetLabel:  domain hash size = 128
[    0.631195] NetLabel:  protocols = UNLABELED CIPSOv4
[    0.631256] NetLabel:  unlabeled traffic allowed by default
[    0.631683] Switching to clocksource 32k_counter
[    0.651550] FS-Cache: Loaded
[    0.651855] AppArmor: AppArmor Filesystem Enabled
[    0.666290] musb-hdrc: version 6.0, ?dma?, otg (peripheral+host)
[    0.666931] musb-hdrc musb-hdrc: USB OTG mode controller at fc0ab000 using D4
[    0.667236] NET: Registered protocol family 2
[    0.667663] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.668975] TCP established hash table entries: 131072 (order: 8, 1048576 by)
[    0.671173] TCP bind hash table entries: 65536 (order: 7, 786432 bytes)
[    0.672424] TCP: Hash tables configured (established 131072 bind 65536)
[    0.672424] TCP reno registered
[    0.672454] UDP hash table entries: 512 (order: 2, 16384 bytes)
[    0.672515] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[    0.672973] NET: Registered protocol family 1
[    1.367248] ipu-power ipu0: Test of writing to the device message log,done ft
[    1.367279] ipu-power initialized ipu, major: 253, minor: 0
[    1.367828] iovmm-omap initialized ducati, major: 252, base-minor: 0
[    1.368072] iovmm-omap initialized tesla, major: 252, base-minor: 1
[    1.369049] omap-remoteproc omap-remoteproc.0: omap_rproc_probe: adding rproa
[    1.369262] omap-remoteproc omap-remoteproc.0: omap-rproc initialized tesla,0
[    1.369323] omap-remoteproc omap-remoteproc.1: omap_rproc_probe: adding rpro0
[    1.369506] omap-remoteproc omap-remoteproc.1: omap-rproc initialized ducati1
[    1.369567] omap-remoteproc omap-remoteproc.2: omap_rproc_probe: adding rpro1
[    1.369781] omap-remoteproc omap-remoteproc.2: omap-rproc initialized ducati2
[    1.370483] audit: initializing netlink socket (disabled)
[    1.370513] type=2000 audit(1.343:1): initialized
[    1.489624] highmem bounce pool size: 64 pages
[    1.498809] VFS: Disk quotas dquot_6.5.2
[    1.499328] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    1.502929] fuse init (API version 7.17)
[    1.503540] msgmni has been set to 1378
[    1.505249] Block layer SCSI generic (bsg) driver version 0.4 loaded (major )
[    1.505401] io scheduler noop registered
[    1.505401] io scheduler deadline registered
[    1.505462] io scheduler cfq registered (default)
[    1.506195] OMAP DSS rev 4.0
[    1.535186] omap_uart.0: ttyO0 at MMIO 0x4806a000 (irq = 104) is a OMAP UART0
[    1.553680] omap_uart.1: ttyO1 at MMIO 0x4806c000 (irq = 105) is a OMAP UART1
[    1.584899] omap_uart.2: ttyO2 at MMIO 0x48020000 (irq = 106) is a OMAP UART2
[    2.784759] console [ttyO2] enabled
[    2.873992] omap_uart.3: ttyO3 at MMIO 0x4806e000 (irq = 102) is a OMAP UART3
[    2.999420] [drm] Initialized drm 1.1.0 20060810
[    3.005035] brd: module loaded
[    3.013549] loop: module loaded
[    3.016998] (stk) :sysfs entries created
[    3.021209] (stk) : debugfs entries created
[    3.026458] Non-trimmed BGAP, Temp not accurate
[    3.031494] thermal_sensor_dev_register:Need to init the cpu domain
[    3.044830] Fixed MDIO Bus: probed
[    3.048492] tun: Universal TUN/TAP device driver, 1.6
[    3.053863] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    3.060821] PPP generic driver version 2.4.2
[    3.065795] usbcore: registered new interface driver smsc95xx
[    3.072235] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    3.079345] _regulator_get: ehci-omap.0 supply hsusb0 not found, using dummyr
[    3.087921] ehci-omap ehci-omap.0: OMAP-EHCI Host Controller
[    3.094268] ehci-omap ehci-omap.0: new USB bus registered, assigned bus numb1
[    3.102294] ehci-omap ehci-omap.0: irq 109, io mem 0x4a064c00
[    3.123931] ehci-omap ehci-omap.0: USB 2.0 started, EHCI 1.00
[    3.130218] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    3.137420] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber1
[    3.145111] usb usb1: Product: OMAP-EHCI Host Controller
[    3.150756] usb usb1: Manufacturer: Linux 3.2.0-1412-omap4 ehci_hcd
[    3.157409] usb usb1: SerialNumber: ehci-omap.0
[    3.162902] hub 1-0:1.0: USB hub found
[    3.166931] hub 1-0:1.0: 3 ports detected
[    3.202117] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    3.208862] ohci-omap3 ohci-omap3.0: OMAP3 OHCI Host Controller
[    3.215423] ohci-omap3 ohci-omap3.0: new USB bus registered, assigned bus nu2
[    3.223632] ohci-omap3 ohci-omap3.0: irq 108, io mem 0x4a064800
[    3.307891] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[    3.315124] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber1
[    3.322784] usb usb2: Product: OMAP3 OHCI Host Controller
[    3.328521] usb usb2: Manufacturer: Linux 3.2.0-1412-omap4 ohci_hcd
[    3.335174] usb usb2: SerialNumber: ohci-omap3.0
[    3.340759] hub 2-0:1.0: USB hub found
[    3.344787] hub 2-0:1.0: 3 ports detected
[    3.349700] Initializing USB Mass Storage driver...
[    3.355010] usbcore: registered new interface driver usb-storage
[    3.361419] USB Mass Storage support registered.
[    3.366729] mousedev: PS/2 mouse device common for all mice
[    3.373077] i2c-core: driver [tm12xx_ts] using legacy suspend method
[    3.379882] i2c-core: driver [tm12xx_ts] using legacy resume method
[    3.387298] twl_rtc twl_rtc: Power up reset detected.
[    3.393798] twl_rtc twl_rtc: Enabling TWL-RTC.
[    3.400390] twl_rtc twl_rtc: rtc core: registered twl_rtc as rtc0
[    3.407135] Linux media interface: v0.10
[    3.411346] Linux video capture interface: v2.00
[    3.420074] OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[    3.427124] device-mapper: uevent: version 1.0.3
[    3.432495] device-mapper: ioctl: 4.22.0-ioctl (2011-10-19) initialised: dm-m
[    3.443725] _regulator_get: omap_hsmmc.0 supply vmmc_aux not found, using dur
[    3.455657] _regulator_get: omap_hsmmc.4 supply vmmc_aux not found, using dur
[    3.498962] usb 1-1: new high-speed USB device number 2 using ehci-omap
[    3.541381] thermal_governor_dev_register:Adding omap_ondie_governor governor
[    3.548980] thermal_init_thermal_state:Not all components registered for cpu)
[    3.562591] proc4430_drv_initializeModule
[    3.567413] omap-devicehandler omap-devicehandler.0: omap_devh_probe: addinga
[    3.576141] omap-devh initialized Tesla, major: 242, base-minor: 0
[    3.582916] omap-devicehandler omap-devicehandler.1: omap_devh_probe: adding3
[    3.591644] omap-devh initialized SysM3, major: 242, base-minor: 1
[    3.598449] omap-devicehandler omap-devicehandler.2: omap_devh_probe: adding3
[    3.607177] omap-devh initialized AppM3, major: 242, base-minor: 2
[    3.616363] SDP4430 SoC init
[    3.651824] asoc: null-codec-dai <-> MultiMedia1 mapping ok
[    3.658660] asoc: null-codec-dai <-> MultiMedia2 mapping ok
[    3.666076] asoc: null-codec-dai <-> Voice mapping ok
[    3.671936] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[    3.679840] asoc: null-codec-dai <-> Tones mapping ok
[    3.685211] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    3.693847] asoc: null-codec-dai <-> Vibra mapping ok
[    3.700103] hub 1-1:1.0: USB hub found
[    3.704406] asoc: null-codec-dai <-> MODEM mapping ok
[    3.709899] hub 1-1:1.0: 5 ports detected
[    3.714813] asoc: null-codec-dai <-> MultiMedia1 LP mapping ok
[    3.721069] mmc0: host does not support reading read-only switch. assuming w.
[    3.731567] asoc: FM Digital <-> omap-mcbsp-dai.1 mapping ok
[    3.737701] mmc0: new high speed SDHC card at address aaaa
[    3.744171] mmcblk0: mmc0:aaaa SU04G 3.69 GiB
[    3.749755] asoc: twl6040-legacy <-> mcpdm-dl mapping ok
[    3.756866] asoc: dmic-hifi <-> omap-dmic-dai-0 mapping ok
[    3.763732] asoc: twl6040-dl1 <-> mcpdm-dl1 mapping ok
[    3.769348]  mmcblk0: p1 p2
[    3.780609] asoc: twl6040-ul <-> mcpdm-ul1 mapping ok
[    3.796051] asoc: twl6040-dl2 <-> mcpdm-dl2 mapping ok
[    3.811676] asoc: twl6040-vib <-> mcpdm-vib mapping ok
[    3.827484] asoc: Bluetooth <-> omap-mcbsp-dai.0 mapping ok
[    3.835357] asoc: Bluetooth <-> omap-mcbsp-dai.0 mapping ok
[    3.850769] asoc: FM Digital <-> omap-mcbsp-dai.1 mapping ok
[    3.866394] asoc: MODEM <-> omap-mcbsp-dai.1 mapping ok
[    3.874206] asoc: dmic-hifi <-> omap-dmic-abe-dai-0 mapping ok
[    3.889770] asoc: dmic-hifi <-> omap-dmic-abe-dai-1 mapping ok
[    3.897430] asoc: dmic-hifi <-> omap-dmic-abe-dai-2 mapping ok
[    3.907440] input: PandaES Headset Jack as /devices/platform/soc-audio.0/sou0
[    3.920623] Error: Driver 'hdmi-audio-dai' is already registered, aborting...
[    3.928222] OMAP4 HDMI audio SoC init
[    3.933258] asoc: omap4-hdmi-audio-codec <-> hdmi-audio-dai mapping ok
[    3.941528] ALSA device list:
[    3.945770]   #0: TI OMAP4 Board
[    3.951171]   #1: TI OMAP4 HDMI Board
[    3.955230] u32 classifier
[    3.958129] mmc1: card claims to support voltages below the defined range. T.
[    3.967620]     Actions configured
[    3.972808] TCP cubic registered
[    3.977081] NET: Registered protocol family 10
[    3.985351] NET: Registered protocol family 17
[    3.990325] lib80211: common routines for IEEE802.11 drivers
[    3.996429] Registering the dns_resolver key type
[    4.001525] VFP support v0.3: implementor 41 architecture 3 part 30 variant 4
[    4.009735] ThumbEE CPU extension supported.
[    4.014312] Registering SWP/SWPB emulation handler
[    4.023925] thermal_cooling_dev_register:Found cpu cpu
[    4.029418] thermal_cooling_dev_register: doing deferred tdev
[    4.035675] thermal_sensor_dev_register:Found cpu cpu
[    4.041107] usb 1-1.1: new high-speed USB device number 3 using ehci-omap
[    4.048370] thermal_sensor_dev_register:Adding omap_ondie_sensor sensor
[    4.055480] thermal_init_thermal_state: Getting initial temp for cpu domain
[    4.062957] thermal_request_temp
[    4.066436] omap_safe_zone:hot spot temp 59031
[    4.071197] cpufreq_apply_cooling: Unthrottle cool level 0 curr cool 125000
[    4.078643] omap_thermal_step_freq_up: temperature reduced, stepping up to 0
[    4.086578]    thermal_request_temp got 48600
[    4.091979] omap_sr_disable: omap_sr struct for sr_mpu not found
[    4.098510] omap_sr_disable: omap_sr struct for sr_mpu not found
[    4.105194] Power Management for TI OMAP4.
[    4.109649] mmc1: queuing unknown CIS tuple 0x91 (3 bytes)
[    4.115692] sr_init: No PMIC hook to init smartreflex
[    4.115722] smartreflex smartreflex.0: omap_sr_probe: SmartReflex driver inid
[    4.129669] smartreflex smartreflex.1: omap_sr_probe: SmartReflex driver inid
[    4.139343] smartreflex smartreflex.2: omap_sr_probe: SmartReflex driver inid
[    4.147766] mmc1: new SDIO card at address 0001
[    4.154296] SmartReflex Class3 initialized
[    4.168182] registered taskstats version 1
[    4.175781] regulator_init_complete: VANA: incomplete constraints, leaving on
[    4.183654] regulator_init_complete: CLK32KG: incomplete constraints, leavinn
[    4.192291] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[    4.199645] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumbe0
[    4.208068] regulator_init_complete: VDAC: incomplete constraints, leaving on
[    4.217224] regulator_init_complete: VUSB: incomplete constraints, leaving on
[    4.225158] smsc95xx v1.0.4
[    4.229644] twl_rtc twl_rtc: setting system clock to 2000-01-01 00:00:00 UTC)
[    4.246856] omapdrm omapdrm.0: dvi has no driver.. skipping it
[    4.253265] No connectors reported connected with modes
[    4.258819] [drm] Cannot find any crtc or sizes - going 1024x768
[    4.303619] Console: switching to colour frame buffer device 128x48
[    4.333435] fb0: omapdrm frame buffer device
[    4.338073] drm: registered panic notifier
[    4.342529] [drm] Supports vblank timestamp caching Rev 1 (10.10.2010).
[    4.349639] [drm] No driver support for vblank timestamp query.
[    4.355987] [drm] Initialized omapdrm 1.0.0 20110403 on minor 0
[    4.363464] smsc95xx 1-1.1:1.0: eth0: register 'smsc95xx' at usb-ehci-omap.0a
[    4.363464] Waiting 2sec before mounting root device...
[    6.698608] EXT3-fs (mmcblk0p2): warning: maximal mount count reached, runnid
[    6.708404] kjournald starting.  Commit interval 5 seconds
[    7.343536] EXT3-fs (mmcblk0p2): using internal journal
[    7.343597] EXT3-fs (mmcblk0p2): mounted filesystem with writeback data mode
[    7.356658] VFS: Mounted root (ext3 filesystem) on device 179:2.
[    7.363983] devtmpfs: error mounting -2
[    7.368072] Freeing init memory: 400K
[    7.368072] Failed to execute /init.  Attempting defaults...
[    7.372436] Kernel panic - not syncing: No init found.  Try passing init= op.
[    7.372436] [<c0015cd0>] (unwind_backtrace+0x0/0xec) from [<c05b9fd4>] (dump)
[    7.400817] [<c05b9fd4>] (dump_stack+0x20/0x24) from [<c05bb2f4>] (panic+0x6)
[    7.409057] [<c05bb2f4>] (panic+0x6c/0x1a4) from [<c05b9da0>] (init_post+0xb)
[    7.417205] [<c05b9da0>] (init_post+0xb0/0xd4) from [<c08b4a48>] (kernel_ini)
[    7.425994] CPU0: stopping
[    7.425994] [<c0015cd0>] (unwind_backtrace+0x0/0xec) from [<c05b9fd4>] (dump)
[    7.436828] [<c05b9fd4>] (dump_stack+0x20/0x24) from [<c0013628>] (handle_IP)
[    7.436828] [<c0013628>] (handle_IPI+0xfc/0x178) from [<c0008654>] (do_IPI+0)
[    7.451385] [<c0008654>] (do_IPI+0x18/0x1c) from [<c05cf3f4>] (__irq_svc+0x3)
[    7.459869] Exception stack(0xc091bf40 to 0xc091bf88)
[    7.459869] bf40: f084d000 20000113 00000000 c0972164 c091a000 c09711a8 c05dc
[    7.475860] bf60: 8000406a 412fc09a 00000000 c091bf94 c091bf80 c091bf88 c0020
[    7.477081] bf80: 60000113 ffffffff
[    7.485748] [<c05cf3f4>] (__irq_svc+0x34/0xac) from [<c00250c0>] (omap_defau)
[    7.498596] [<c00250c0>] (omap_default_idle+0x28/0x2c) from [<c000f1a8>] (cp)
[    7.506744] [<c000f1a8>] (cpu_idle+0x8c/0xe0) from [<c05a9bac>] (rest_init+0)
[    7.514556] [<c05a9bac>] (rest_init+0x8c/0xa4) from [<c08b48a8>] (start_kern)
[    7.524810] panic occurred, switching back to text console
i am downloded prebuilt binaries from below site.
wget -O MLO        http://ports.ubuntu.com/ubuntu-ports/dists/precise/main/installer-armhf/current/images/omap4/netboot/MLO
 wget -O u-boot.bin http://ports.ubuntu.com/ubuntu-ports/dists/precise/main/installer-armhf/current/images/omap4/netboot/u-boot.bin
 wget -O uImage     http://ports.ubuntu.com/ubuntu-ports/dists/precise/main/installer-armhf/current/images/omap4/netboot/uImage
regards,
sreedhar
