DVR_RDK disable channel
Hi, we use RDK2.8, 8168.
 we use 2 channel for 1080P60 encoding . Now we disable one channel, the resoure is not released just like ivaMap, is it right?
If we don't exit system, the system resource is not released, so we can't change 2 encode - 1ch decode to 1ch encode - 2ch decode, is it right?
  • The IVA HD resource is not locked. The ivaMap is just for balancing the load. There is no problem disabling one encode channel and running 2 decodes. On RDK 2.8 you cannot dynamically change the IVAchMap. On RDK 3.0+  you can also dynamically change the IVAchMap.
