help, mosaic and encode on DVRRDK-3.5 ? (DM8168 evm+daughter card)
hi,
the link struct:
the result:
d
Vsys_printDetailedStatistics()=======================================
[m3vpss ]
[m3vpss ] *** Capture Driver Advanced Statistics ***
[m3vpss ]
[m3vpss ] *** [NSF0] NSF Statistics ***
[m3vpss ]
[m3vpss ] Elasped Time : 195 secs
[m3vpss ] Total Fields Processed : 0
[m3vpss ] Total Fields FPS : 0 FPS
[m3vpss ]
[m3vpss ]
[m3vpss ] CH | In Recv In Reject In Process Out User Out Out
[m3vpss ] Num | FPS FPS FPS FPS Skip FPS Skip FPS
[m3vpss ] ------------------------------------------------
[m3vpss ] 0 | 0 0 0 0 0 0
[m3vpss ]
[m3vpss ]
[m3vpss ] *** [NSF1] NSF Statistics ***
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ] VIP Parser Reset Count : 0
[m3vpss ]
[m3vpss ] | Total Even Odd Total Even Odd Min / Max Min / Max Dropped Fid Repeat Frame Error Y/C
[m3vpss ] CH | Fields Fields Fields FPS FPS FPS Width Height Fields Count (Desc Error Y/C)
[m3vpss ] ------------------------------------------------------------------------------------------------------------
[m3vpss ] 000 | 12821 12821 0 60 60 0 1920 / 1920 1080 / 1080 12810 0 0/0 (0/0)
[m3vpss ]
[m3vpss ] VIP Capture Port 0 | DescMissMatch1 = 0, DescMissMatch2 = 0 , DescMissMatch3 = 0
[m3vpss ]
[m3vpss ] *** Capture List Manager Advanced Statistics ***
[m3vpss ]
[m3vpss ] List Post Count : 26712
[m3vpss ] List Stall Count : 0
[m3vpss ] List Post Time (ms) : Max = 0, Min = 0, Avg = 0, Total = 0
[m3vpss ] INTC Timeout Count : (0, 0) (Min timeout value = 989, 1000)
[m3vpss ] Descriptor miss found count : 0
[m3vpss ]
[m3vpss ]
[m3vpss ] VIP and VPDMA registers,
[m3vpss ] VIP0 : FIQ_STATUS : 0x4810551c = 0x00000000
[m3vpss ] VIP1 : FIQ_STATUS : 0x48105a1c = 0x00000000
[m3vpss ] VPDMA: LIST_BUSY : 0x4810d00c = 0x000c0000
[m3vpss ]
[m3vpss ]
[m3vpss ] 246720: CAPTURE: Fields = 11 (fps = 0, CPU Load = 0)
[m3vpss ] 246720: CAPTURE: Num Resets = 0 (Avg 0 ms per reset)
[m3vpss ] 246721: SYSTEM : FREE SPACE : System Heap = 66584 B, Mbx = 10238 msgs)
[m3vpss ] 246721: SYSTEM : FREE SPACE : SR0 Heap = 9367296 B (8 MB)
[m3vpss ] 246721: SYSTEM : FREE SPACE : Frame Buffer = 22241664 B (21 MB)
[m3vpss ] 246721: SYSTEM : FREE SPACE : Bitstream Buffer = 174487424 B (166 MB)
[m3vpss ] 246721: SYSTEM : FREE SPACE : Tiler 8-bit = 134217728 B (128 MB) - TILER ON
[m3vpss ] 246722: SYSTEM : FREE SPACE : Tiler 16-bit = 134217728 B (128 MB) - TILER ON
[m3vpss ]
[m3vpss ] *** [SWMS0] Mosaic Statistics ***
[m3vpss ]
[m3vpss ] Elasped Time: 195 secs
[m3vpss ]
[m3vpss ] Output Request FPS : 60 fps (11747 frames)
[m3vpss ] Output Actual FPS : 60 fps (11747 frames)
[m3vpss ] Output Drop FPS : 0 fps (0 frames)
[m3vpss ] Output Reject FPS : 0 fps (0 frames)
[m3vpss ] Scaling Internal : 16 ms
[m3vpss ] Scaling Internal min : 14 ms
[m3vpss ] Scaling Internal max : 17 ms
[m3vpss ]
[m3vpss ] Win | Window Repeat Drop Recv Que FID Invlid Acc Event Invalid Que Reject Reject Latency OutBufCopy InBufCopy
[m3vpss ] Num | FPS FPS FPS FPS FPS FPS Count (Max/Min) CH Frames Frames Frames Min / Max FPS FPS
[m3vpss ] ---------------------------------------------------------------------------------------------------------------------------
[m3vpss ] 0 | 60 60 0 0 0 0 0 ( 0/255) 0 0 0 19724 / 215487 60 0
[m3vpss ] 1 | 60 60 0 0 0 0 0 ( 0/255) 0 0 0 19724 / 215487 60 0
[m3vpss ] 2 | 60 60 0 0 0 0 0 ( 0/255) 0 0 0 19724 / 215487 60 0
[m3vpss ] 3 | 60 60 0 0 0 0 0 ( 0/255) 0 0 0 19724 / 215487 60 0
[m3vpss ]
[m3vpss ]
[m3vpss ] *** [SWMS0] Mosaic Parameters ***
[m3vpss ]
[m3vpss ] Output FPS: 60
[m3vpss ]
[m3vpss ] Win | Ch | Input | Input | Input | Input | Output | Output | Output | Output | Low Cost | SWMS | Data | Blank |
[m3vpss ] Num | Num | Start X, Y | Width x Height | Pitch Y / C | Memory Type | Start X, Y | Width x Height | Pitch Y / C | Memory Type | ON / OFF | Inst | Format| Frame |
[m3vpss ] ----------------------------------------------------------------------------------------------------------------------------------------------------------------------
[m3vpss ] 0 | 0 | 0, 0 | 1920 x 1080 | 1920 / 1920 | NON-TILED | 0, 0 | 960 x 540 | 3840 / 0 | NON-TILED | OFF | 0 | 420SP | OFF |
[m3vpss ] 1 | 1 | 0, 0 | 1920 x 1080 | 1920 / 1920 | NON-TILED | 960, 0 | 960 x 540 | 3840 / 0 | NON-TILED | OFF | 0 | 420SP | OFF |
[m3vpss ] 2 | 2 | 0, 0 | 1920 x 1080 | 1920 / 1920 | NON-TILED | 0, 540 | 960 x 540 | 3840 / 0 | NON-TILED | OFF | 0 | 420SP | OFF |
[m3vpss ] 3 | 3 | 0, 0 | 1920 x 1080 | 1920 / 1920 | NON-TILED | 960, 540 | 960 x 540 | 3840 / 0 | NON-TILED | OFF | 0 | 420SP | OFF |
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ] *** [SWMS1] Mosaic Statistics ***
[m3vpss ]
[m3vpss ]
[m3vpss ] Scaling Internal min : 12 ms
[m3vpss ] Scaling Internal max : 19 ms
[m3vpss ]
[m3vpss ] 0 | 60 60 0 0 0 0 0 ( 0/255) 0 0 0 19739 / 215504 60 0
[m3vpss ] 1 | 60 60 0 0 0 0 0 ( 0/255) 0 0 0 19739 / 215504 60 0
[m3vpss ] 2 | 60 60 0 0 0 0 0 ( 0/255) 0 0 0 19739 / 215504 60 0
[m3vpss ] 3 | 60 60 0 0 0 0 0 ( 0/255) 0 0 0 19739 / 215504 60 0
[m3vpss ]
[m3vpss ]
[m3vpss ] *** [SWMS1] Mosaic Parameters ***
[m3vpss ]
[m3vpss ]
[m3vpss ] 0 | 0 | 0, 0 | 1920 x 1080 | 1920 / 1920 | NON-TILED | 0, 0 | 1440 x 1080 | 3840 / 0 | NON-TILED | OFF | 0 | 420SP | OFF |
[m3vpss ] 1 | 1 | 0, 0 | 1920 x 1080 | 1920 / 1920 | NON-TILED | 1440, 0 | 480 x 360 | 3840 / 0 | NON-TILED | OFF | 0 | 420SP | OFF |
[m3vpss ] 2 | 2 | 0, 0 | 1920 x 1080 | 1920 / 1920 | NON-TILED | 1440, 360 | 480 x 360 | 3840 / 0 | NON-TILED | OFF | 0 | 420SP | OFF |
[m3vpss ] 3 | 3 | 0, 0 | 1920 x 1080 | 1920 / 1920 | NON-TILED | 1440, 720 | 480 x 360 | 3840 / 0 | NON-TILED | OFF | 0 | 420SP | OFF |
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ] *** [SWMS2] Mosaic Statistics ***
[m3vpss ]
[m3vpss ]
[m3vpss ] Output Request FPS : 66 fps (13052 frames)
[m3vpss ] Output Actual FPS : 0 fps (0 frames)
[m3vpss ] Output Drop FPS : 66 fps (13052 frames)
[m3vpss ] Scaling Internal : 14 ms
[m3vpss ] Scaling Internal min : 15 ms
[m3vpss ] Scaling Internal max : 15 ms
[m3vpss ]
[m3vpss ] 0 | 0 0 0 0 0 0 0 ( 0/255) 0 0 0 65535 / 0 0 0
[m3vpss ] 1 | 0 0 0 0 0 0 0 ( 0/255) 0 0 0 65535 / 0 0 0
[m3vpss ] 2 | 0 0 0 0 0 0 0 ( 0/255) 0 0 0 65535 / 0 0 0
[m3vpss ] 3 | 0 0 0 0 0 0 0 ( 0/255) 0 0 0 65535 / 0 0 0
[m3vpss ]
[m3vpss ]
[m3vpss ] *** [SWMS2] Mosaic Parameters ***
[m3vpss ]
[m3vpss ]
[m3vpss ] 0 | 0 | 0, 0 | 1920 x 1080 | 1920 / 1920 | NON-TILED | 0, 0 | 960 x 540 | 3840 / 0 | NON-TILED | OFF | 0 | 420SP | ON |
[m3vpss ] 1 | 1 | 0, 0 | 1920 x 1080 | 1920 / 1920 | NON-TILED | 960, 0 | 960 x 540 | 3840 / 0 | NON-TILED | OFF | 0 | 420SP | ON |
[m3vpss ] 2 | 2 | 0, 0 | 1920 x 1080 | 1920 / 1920 | NON-TILED | 0, 540 | 960 x 540 | 3840 / 0 | NON-TILED | OFF | 0 | 420SP | ON |
[m3vpss ] 3 | 3 | 0, 0 | 1920 x 1080 | 1920 / 1920 | NON-TILED | 960, 540 | 960 x 540 | 3840 / 0 | NON-TILED | OFF | 0 | 420SP | ON |
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ] *** [SWMS3] Mosaic Statistics ***
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ] *** [SWMS3] Mosaic Parameters ***
[m3vpss ]
[m3vpss ]
[m3vpss ] 0 | 0 | 0, 0 | 1920 x 1080 | 1920 / 1920 | NON-TILED | 0, 0 | 1440 x 1080 | 3840 / 0 | NON-TILED | OFF | 0 | 420SP | ON |
[m3vpss ] 1 | 1 | 0, 0 | 1920 x 1080 | 1920 / 1920 | NON-TILED | 1440, 0 | 480 x 360 | 3840 / 0 | NON-TILED | OFF | 0 | 420SP | ON |
[m3vpss ] 2 | 2 | 0, 0 | 1920 x 1080 | 1920 / 1920 | NON-TILED | 1440, 360 | 480 x 360 | 3840 / 0 | NON-TILED | OFF | 0 | 420SP | ON |
[m3vpss ] 3 | 3 | 0, 0 | 1920 x 1080 | 1920 / 1920 | NON-TILED | 1440, 720 | 480 x 360 | 3840 / 0 | NON-TILED | OFF | 0 | 420SP | ON |
[m3vpss ]
[m3vpss ]
[m3vpss ] 248740: DISPLAY: HDDAC(BP0) : 59 fps, Latency (Min / Max) = ( 79 / 85 ), Callback Interval (Min / Max) = ( 16 / 17 ) !!!
[m3vpss ] 248740: DISPLAY: UNDERFLOW COUNT: HDMI(BP0) 11755, HDDAC(BP0) 11804, DVO2(BP1) 11801, SDDAC(SEC1) 23895
[m3vpss ] 248740: SYSTEM : FREE SPACE : System Heap = 66584 B, Mbx = 10239 msgs)
[m3vpss ] 248741: SYSTEM : FREE SPACE : SR0 Heap = 9367296 B (8 MB)
[m3vpss ] 248741: SYSTEM : FREE SPACE : Frame Buffer = 22241664 B (21 MB)
[m3vpss ] 248741: SYSTEM : FREE SPACE : Bitstream Buffer = 174487424 B (166 MB)
[m3vpss ] 248742: SYSTEM : FREE SPACE : Tiler 8-bit = 134217728 B (128 MB) - TILER ON
[m3vpss ] 248742: SYSTEM : FREE SPACE : Tiler 16-bit = 134217728 B (128 MB) - TILER ON
[m3vpss ] 248742: DISPLAY: DVO2(BP1) : 59 fps, Latency (Min / Max) = ( 79 / 86 ), Callback Interval (Min / Max) = ( 16 / 17 ) !!!
[m3video] 252743: HDVICP-ID:0
[m3video] All percentage figures are based off totalElapsedTime
[m3video] totalAcquire2wait :0 %
[m3video] totalWait2Isr :97 %
[m3video] totalIsr2Done :0 %
[m3video] totalWait2Done :98 %
[m3video] totalDone2Release :0 %
[m3video] totalAcquire2Release :99 %
[m3video] totalAcq2acqDelay :0 %
[m3video] totalElapsedTime in msec : 580
[m3video] numAccessCnt: 44
[m3video] IVA-FPS : 0
[m3video] Average time spent per frame in microsec: 12785
[m3video] 252743: HDVICP-ID:1
[m3video] totalWait2Isr :0 %
[m3video] totalWait2Done :0 %
[m3video] totalAcquire2Release :0 %
[m3video] totalElapsedTime in msec : 0
[m3video] numAccessCnt: 0
[m3video] Average time spent per frame in microsec: 0
[m3video] 252744: HDVICP-ID:2
[m3video]
[m3video] *** ENCODE Statistics ***
[m3video]
[m3video] Elasped Time : 195 secs
[m3video]
[m3video]
[m3video] CH | In Recv In Skip In User Out Latency
[m3video] Num | FPS FPS Skip FPS FPS Min / Max
[m3video] --------------------------------------------
[m3video] 0 | 0 0 0 0 255 / 0
[m3video] 1 | 0 0 0 0 255 / 0
[m3video] 2 | 0 0 0 0 255 / 0
[m3video] 3 | 0 0 0 0 255 / 0
[m3video] 4 | 0 0 0 0 255 / 0
[m3video] 5 | 0 0 0 0 255 / 0
[m3video]
[m3video] Multi Channel Encode Average Submit Batch Size
[m3video] Max Submit Batch Size : 24
[m3video] IVAHD_0 Average Batch Size : 0
[m3video] IVAHD_0 Max achieved Batch Size : 0
[m3video] IVAHD_1 Average Batch Size : 0
[m3video] IVAHD_1 Max achieved Batch Size : 0
[m3video] IVAHD_2 Average Batch Size : 0
[m3video] IVAHD_2 Max achieved Batch Size : 0
[m3video]
[m3video] Multi Channel Encode Batch break Stats
[m3video] Total Number of Batches created: 0
[m3video] All numbers are based off total number of Batches created
[m3video] Batch breaks due to batch sizeexceeding limit: 0 %
[m3video] Batch breaks due to ReqObj Que being empty: 0 %
[m3video] Batch breaks due to changed resolution class: 0 %
[m3video] Batch breaks due to interlace and progressivecontent mix: 0 %
[m3video] Batch breaks due to channel repeat: 0 %
[m3video] Batch breaks due to different codec: 0 %
[m3vpss ]
[m3vpss ] 254749: LOAD: CPU: 7.9% HWI: 2.1%, SWI:1.2%
[m3vpss ]
[m3vpss ] 254749: LOAD: TSK: IPC_OUT_M30 : 0.1%
[m3vpss ] 254749: LOAD: TSK: CAPTURE : 0.2%
[m3vpss ] 254749: LOAD: TSK: DISPLAY0 : 0.4%
[m3vpss ] 254749: LOAD: TSK: DISPLAY1 : 0.4%
[m3vpss ] 254749: LOAD: TSK: SWMS0 : 0.9%
[m3vpss ] 254749: LOAD: TSK: SWMS1 : 0.9%
[m3vpss ] 254749: LOAD: TSK: SWMS2 : 0.1%
[m3vpss ] 254749: LOAD: TSK: SWMS3 : 0.1%
[m3vpss ] 254750: LOAD: TSK: MISC : 1.5%
[m3vpss ]
[m3video]
[m3video] 255250: LOAD: CPU: 1.9% HWI: 0.4%, SWI:0.6%
[m3video]
[m3video] 255250: LOAD: TSK: IPC_IN_M30 : 0.1%
[m3video] 255250: LOAD: TSK: IPC_BITS_OUT0 : 0.1%
[m3video] 255251: LOAD: TSK: ENC0 : 0.4%
[m3video] 255251: LOAD: TSK: MISC : 0.3%
[m3video]
[c6xdsp ]
[c6xdsp ] 253173: LOAD: CPU: 0.1% HWI: 0.0%, SWI:0.0%
[c6xdsp ]
[c6xdsp ] 253173: LOAD: TSK: MISC : 0.1%
[c6xdsp ]
Vsys_printBufferStatistics()=========================================
[m3vpss ]
[m3vpss ] *** CAPTURE Statistics ***
[m3vpss ] 256252: CAPTURE: Queued to driver = 11, Dequeued from driver = 11
[m3vpss ]
[m3vpss ] 256252: NSF: Rcvd from prev = 0, Returned to prev = 0
[m3vpss ] NSF Out [0] Buf Q Status
[m3vpss ] Empty Q -> count 0, wrPtr 0, rdPtr 0
[m3vpss ] Full Q -> count 0, wrPtr 0, rdPtr 0
[m3vpss ] CAPTURE [0] Buf Q Status
[m3vpss ]
[m3vpss ] Full Q -> count 0, wrPtr 11, rdPtr 11
[m3vpss ]
[m3vpss ] 256253: SWMS: Rcvd from prev = 0, Returned to prev = 40
[m3vpss ] SWMS Out Buf Q Status
[m3vpss ] Empty Q -> count 1, wrPtr 344, rdPtr 343
[m3vpss ] Full Q -> count 1, wrPtr 343, rdPtr 342
[m3vpss ]
[m3vpss ] Empty Q -> count 1, wrPtr 343, rdPtr 342
[m3vpss ] Full Q -> count 1, wrPtr 342, rdPtr 341
[m3vpss ]
[m3vpss ] 256254: SWMS: Rcvd from prev = 0, Returned to prev = 0
[m3vpss ] Empty Q -> count 0, wrPtr 6, rdPtr 6
[m3vpss ] Full Q -> count 6, wrPtr 6, rdPtr 0
[m3vpss ]
[m3vpss ] 256255: SWMS: Rcvd from prev = 0, Returned to prev = 0
[m3vpss ]
[m3vpss ] *** Display Statistics ***
[m3vpss ] 256255: DISPLAY: Rcvd from prev = 13398, Returned to prev = 13394, BufsInDriver = 6
[m3vpss ]
[m3vpss ] 256256: DISPLAY: Rcvd from prev = 13398, Returned to prev = 13394, BufsInDriver = 6
[m3video]
[m3video] *** Encode Statistics ***
[m3video] 256756: ENC: Rcvd from prev = 44, Returned to prev = 44
[m3video] ENC Out BitBuf Q Status
[m3video] Empty Q 0 -> count 36, wrPtr 80, rdPtr 44
[m3video] Full Q -> count 0, wrPtr 44, rdPtr 44
current, the program works well, but display[0], [1] stop there and no encode stream.
at program:
gVdisModuleContext.swMsId[0] = gUsecaseContext.swMsId[0];
gVdisModuleContext.swMsId[1] = gUsecaseContext.swMsId[1];
gVdisModuleContext.swMsId[2] = gUsecaseContext.swMsId[2];
gVdisModuleContext.swMsId[3] = gUsecaseContext.swMsId[3];
gVcapModuleContext.nsfId[0] = gUsecaseContext.nsfId[0];
gVcapModuleContext.nsfId[1] = gUsecaseContext.nsfId[1];
gVcapModuleContext.captureId = gUsecaseContext.captureId;
gVdisModuleContext.displayId[0] = gUsecaseContext.displayId[0]; // ON CHIP HDMI
gVdisModuleContext.displayId[1] = gUsecaseContext.displayId[1]; // ON CHIP YCbCr
gVencModuleContext.encId = gUsecaseContext.encId;
gVencModuleContext.ipcBitsInHLOSId = gUsecaseContext.ipcBitsInHLOSId;
gVencModuleContext.ipcBitsOutRTOSId = gUsecaseContext.ipcBitsOutRTOSId;
does need some step? thanks
