Compiling Qt5 in Linux AM335x
I need some help in getting Qt5 up and running in my AM335x Development System. My hardware is AM335x Starter kit. I have the sdk + graphics sdk installed. I am able to modify and compile kernel. Qt 4.8 packed within sdk also works fine.
I am now trying to compilet Qt5 and having some trouble with it. These are the steps I followed. (Ref: http://tigraphics.blogspot.de/2013/01/qt-500-final-dec-2012-available-on-ti.html
1. git clone qtmaster repository and download everything.
2. clear QMAKESPEC environment variable
3. copy linux-arm-gnueabi-ti-g++ folder into qtbase/mkspecs as specified in https://github.com/prabindh/qt-configs/blob/master/qt5_1.0_Dec12/README
4. Apply qttestbrowser patch from the same link
5. set the rootfs and toolchain path as follows in the qmake.conf file
ROOTFS_PATH=/home/rammy/ti-sdk-am335x-evm-05.07.00.00/targetNFS
TOOLCHAIN_PREFIX=/home/rammy/ti-sdk-am335x-evm-05.07.00.00/linux-devkit/bin/arm-arago-linux-gnueabi
(my sdk is installed in /home/rammy/ti-sdk-am335x-evm-05.07.00.00/ and I have a working NFS root partition at the ROOTFS_PATH. I am able to boot with tftp and nfs with this system)
6. ./configure -prefix /home/rammy/qt5_install -release -make libs -xplatform linux-arm-gnueabi-ti-g++ -opengl es2 -confirm-license -opensource -icu -no-xcb -make examples -verbose
Output:
ICU auto-detection... ()
/home/rammy/ti-sdk-am335x-evm-05.07.00.00/linux-devkit/bin/arm-arago-linux-gnueabi-g++ -c -pipe -O3 -march=armv7-a -mfpu=neon -mfloat-abi=softfp -Wall -W -fPIE -I../../../mkspecs/linux-arm-gnueabi-ti-g++ -I. -I/home/rammy/ti-sdk-am335x-evm-05.07.00.00/targetNFS/usr/include -I/home/rammy/ti-sdk-am335x-evm-05.07.00.00/targetNFS/usr/include/glib-2.0 -I/home/rammy/ti-sdk-am335x-evm-05.07.00.00/targetNFS/usr/lib/glib-2.0/include/ -I/home/rammy/ti-sdk-am335x-evm-05.07.00.00/targetNFS/usr/include/libxml2/ -I/home/rammy/ti-sdk-am335x-evm-05.07.00.00/targetNFS/usr/include/freetype2 -I/home/rammy/ti-sdk-am335x-evm-05.07.00.00/targetNFS/usr/include/dbus-1.0 -I/home/rammy/ti-sdk-am335x-evm-05.07.00.00/targetNFS/usr/include/dbus-1.0/dbus -o icu.o icu.cpp
icu.cpp:42:28: fatal error: unicode/utypes.h: No such file or directory
compilation terminated.
make: *** [icu.o] Error 1
ICU disabled.
The ICU library support cannot be enabled.
Turn on verbose messaging (-v) to /home/rammy/qt5/qtbase/configure to see the final report.
If you believe this message is in error you may use the continue
switch (-continue) to /home/rammy/qt5/qtbase/configure to continue.
*** qtbase/configure exited with non-zero status.
I am also attaching the full output as a text file below this message.
Now if i configure without -icu flag, I get a successful output as follows:
Configure summary
Building on: linux-g++ (i386, CPU features:)
Building for: linux-arm-gnueabi-ti-g++ (arm, CPU features:)
Platform notes:
- Also available for Linux: linux-kcc linux-icc linux-cxx
qmake vars .......... styles += mac fusion windows DEFINES += QT_NO_XCB PRECOMPILED_DIR = .pch/release-shared OBJECTS_DIR = .obj/release-shared MOC_DIR = .moc/release-shared RCC_DIR = .rcc/release-shared UI_DIR = .uic/release-shared sql-drivers = sql-plugins = sqlite qmake switches .........
Build options:
Configuration .......... accessibility alsa audio-backend c++11 clock-gettime clock-monotonic concurrent cross_compile egl eglfs evdev eventfd freetype full-config getaddrinfo getifaddrs iconv inotify ipv6ifname large-config largefile libudev linuxfb medium-config minimal-config mremap neon nis no-pkg-config opengl opengles2 openssl pcre png qpa qpa release rpath shared small-config system-jpeg system-png system-zlib v8 v8snapshot
Build parts ............ libs examples
Mode ................... release
Using C++11 ............ yes
Using PCH .............. no
Target compiler supports:
iWMMXt/Neon .......... no/yes
Qt modules and options:
Qt D-Bus ............... no
Qt Concurrent .......... yes
Qt GUI ................. yes
Qt Widgets ............. yes
JavaScriptCore JIT ..... To be decided by JavaScriptCore
QML debugging .......... yes
Use system proxies ..... no
Support enabled for:
Accessibility .......... yes
ALSA ................... yes
CUPS ................... no
FontConfig ............. no
Iconv .................. yes
ICU .................... no
Image formats:
GIF .................. plugin
JPEG ................. plugin (system)
PNG .................. yes (system)
Glib ................... no
GStreamer
 .............. no
GTK theme .............. no
Large Files ............ yes
Networking:
getaddrinfo .......... yes
getifaddrs ........... yes
IPv6 ifname .......... yes
OpenSSL .............. yes (loading libraries at run-time)
NIS .................... yes
OpenGL ................. yes (OpenGL ES 2.x)
OpenVG ................. no
PCRE ................... yes (qt)
pkg-config ............. no
PulseAudio ............. no
QPA backends:
DirectFB ............. no
EGLFS ................ yes
KMS .................. no
LinuxFB .............. yes
XCB .................. no
Session management ..... auto
SQL drivers:
DB2 .................. no
InterBase ............ no
MySQL ................ no
OCI .................. no
ODBC ................. no
PostgreSQL ........... no
SQLite 2 ............. no
SQLite ............... plugin (qt)
TDS .................. no
udev ................... yes
xkbcommon .............. no
zlib ................... yes (system)
This output is not identical to the one in README. In first look I dont have glib and dbus support.
Now my questions:
1. Are glib and dbus important ?
2. How do i get icu library support ?
It would be great if someone could point me in the right direction.
Thanks very much.
Ram
5707.qt5_configure_icuenabled_output.txt
1423.qt5_configure_icuDISbled_output.txt
  • icu is required for webkit build.
    Did you do a make and get the binaries built without webkit ?
  • Hi Prabindh,
    Thanks for the fast reply.
    As you mentioned in the duplicate thread, I was building with a master clone. I downloaded 5.0.1 branch and the configure + build is successfull WITHOUT icu (webkit). (with icu option I am still getting "ICU support cannot be enabled" message).
    But when I try to run any qt example application, I get the error
    QIconvCodec::convertFromUnicode: using Latin-1 for conversion, iconv_open failed
    QIconvCodec::convertToUnicode: using Latin-1 for conversion, iconv_open failed
    Failed to load platform plugin "xcb". Available platforms are:
    sh: line 1: 1649 Aborted
    According to the README file in qt-configs/qt5_1.0_Dec12/ we configure with --no-xcb option.
    What am I missing here ?
    Thanks a lot again.
    Ram
  • Hi Prabindh,
    An update regarding the example applications.
    I copied the qt5 install dir files to nfs file system and then set the proper path for env variable QT_QPA_PLATFORM_PLUGIN_PATH. Now with the command line option -platform eglfs, I am able to execute the example applications.
    Can you help me in enabling icu support for webkit ? Where do I get icu and how to compile it for AM335x.
    Thanks a lot.
    Ram
  • You can add icu and reconfigure qt5 using the prebuilt binary for Arago (for 5.07 SDK) from
    https://gforge.ti.com/gf/download/docmanfileversion/318/6549/libicu.tar.gz
    But this alone may not be sufficient and additional components may be needed for webkit.
    fyi - A list of steps to follow for building qtbase directly on Arago in-tree is available now at, http://gpupowered.org/node/22
  • Hi Prabindh,
    Thanks for the info. I will definitely try this out.
    We have just switched to the new TI AM335x platform and would prefer to develop with Qt5.
    Does TI plan to release Qt5 with the SDK instead of Qt 4.8 ?
    Thanks a lot for your support.
    Ram
  • Hi Prabhind ,after following your instructions when I run configure the output is below:-
    /opt/3_july_qt_arm/qt-everywhere-opensource-src-5.0.0-beta1/qtbase/configure: 5550: /opt/3_july_qt_arm/qt-everywhere-opensource-src-5.0.0-beta1/qtbas
    root@tejbir:/opt/3_july_qt_arm/qt-everywhere-opensource-src-5.0.0-beta1# ./configure -prefix /opt/3_july_installation -release -platform /opt/3_july_qt_arm/qt-everywhere-opensource-src-5.0.0-beta1/qtbase/mkspecs/linux-g++ -xplatform /opt/3_july_qt_arm/qt-everywhere-opensource-src-5.0.0-beta1/qtbase/mkspecs/linux-arm-gnueabi-ti-g++ -confirm-license -opensource  -qt-libpng -qt-libjpeg -no-gtkstyle
    + /opt/3_july_qt_arm/qt-everywhere-opensource-src-5.0.0-beta1/qtbase/configure -prefix /opt/3_july_installation -release -platform /opt/3_july_qt_arm/qt-everywhere-opensource-src-5.0.0-beta1/qtbase/mkspecs/linux-g++ -xplatform /opt/3_july_qt_arm/qt-everywhere-opensource-src-5.0.0-beta1/qtbase/mkspecs/linux-arm-gnueabi-ti-g++ -confirm-license -opensource -qt-libpng -qt-libjpeg -no-gtkstyle
    /opt/3_july_qt_arm/qt-everywhere-opensource-src-5.0.0-beta1/qtbase/configure: 2608: /opt/3_july_qt_arm/qt-everywhere-opensource-src-5.0.0-beta1/qtbase/configure: -g++: not found
    This is the Qt Open Source Edition.
    You are licensed to use this software under the terms of
    the Lesser GNU General Public License (LGPL) versions 2.1.
    You have already accepted the terms of the  license.
    Creating qmake. Please wait...
    make: Nothing to be done for `first'.
    Could not determine the target architecture!
    Turn on verbose messaging (-v) to see the final report.
    Could not determine the host architecture!
    Project ERROR: Package libdrm not found
    /opt/3_july_qt_arm/qt-everywhere-opensource-src-5.0.0-beta1/qtbase/configure: 5550: /opt/3_july_qt_arm/qt-everywhere-opensource-src-5.0.0-beta1/qtbase/configure: -g++: not found
    Building on:   /opt/3_july_qt_arm/qt-everywhere-opensource-src-5.0.0-beta1/qtbase/mkspecs/linux-g++
    Building for:  /opt/3_july_qt_arm/qt-everywhere-opensource-src-5.0.0-beta1/qtbase/mkspecs/linux-arm-gnueabi-ti-g++
    Architecture:  unknown, features:
    Host architecture: unknown, features:
    Build .................. libs examples
    Configuration ..........  cross_compile qpa largefile pcre  minimal-config small-config medium-config large-config full-config libudev evdev linuxfb c++11 accessibility egl eglfs opengl opengles2 shared qpa clock-gettime clock-monotonic mremap getaddrinfo ipv6ifname getifaddrs inotify png freetype system-zlib nis iconv openssl rpath alsa concurrent audio-backend v8 v8snapshot release
    Debug .................. no
    C++11 support .......... yes
    pkg-config ............. yes
    QtDBus module .......... no
    QtConcurrent code ...... yes
    QtGui module ........... yes
    QtWidgets module ....... yes
    PCH support ............ no
    IPv6 ifname support .... yes
    getaddrinfo support .... yes
    getifaddrs support ..... yes
    NIS support ............ yes
    CUPS support ........... no
    Iconv support .......... yes
    Glib support ........... no
    GStreamer support ...... no
    PulseAudio support ..... no
    Large File support ..... yes
    GIF support ............ plugin
    JPEG support ........... plugin (qt)
    PNG support ............ yes (qt)
    zlib support ........... system
    libudev support ........ yes
    OpenGL support ......... yes (OpenGL ES 2.x)
    OpenVG support ......... no
    XShape support ......... auto
    XVideo support ......... auto
    XSync support .......... auto
    Xinerama support ....... runtime
    Xcursor support ........ runtime
    Xfixes support ......... runtime
    Xrandr support ......... runtime
    Xi support ............. runtime
    Xi2 support ............ auto
    MIT-SHM support ........ auto
    FontConfig support ..... no
    XKB Support ............ auto
    immodule support ....... yes
    GTK theme support ...... no
    SQLite support ......... plugin (qt)
    OpenSSL support ........ yes (run-time)
    Alsa support ........... yes
    libICU support ......... no
    PCRE support ........... qt
    Xcb support ............ no
    Xrender support ........ no
    EGLFS support .......... yes
    DirectFB support ....... no
    LinuxFB support ........ yes
    KMS support ............ no
    Project MESSAGE: /opt/3_july_qt_arm/qt-everywhere-opensource-src-5.0.0-beta1/qtbase/bin/syncqt -qtdir /opt/3_july_qt_arm/qt-everywhere-opensource-src-5.0.0-beta1/qtbase -outdir /opt/3_july_qt_arm/qt-everywhere-opensource-src-5.0.0-beta1/qtbase /opt/3_july_qt_arm/qt-everywhere-opensource-src-5.0.0-beta1/qtbase
    <srcbase> = /opt/3_july_qt_arm/qt-everywhere-opensource-src-5.0.0-beta1/qtbase
    <outbase> = /opt/3_july_qt_arm/qt-everywhere-opensource-src-5.0.0-beta1/qtbase
            NOTICE: configure was unable to determine the architecture
            for the /opt/3_july_qt_arm/qt-everywhere-opensource-src-5.0.0-beta1/qtbase/mkspecs/linux-arm-gnueabi-ti-g++ target.
            Qt will not use a specialized implementation for any atomic
            operations. Instead a generic implemention based on either GCC
            intrinsics or C++11 std::atomic<T> will be used (when
            available). The generic implementations are generally as fast
            as and always as safe as a specialized implementation.
            If no generic implementation is available, Qt will use a
            fallback UNIX implementation which uses a single
            pthread_mutex_t to protect all atomic operations. This
            implementation is the slow (but safe) fallback implementation
            for architectures Qt does not yet support.
    Qt is now configured for building. Just run 'make'.
    Once everything is built, you must run 'make install'.
    Qt will be installed into /opt/3_july_installation
    To reconfigure, run 'make confclean' and 'configure
    THEN WHEN I build it by ./build -j 4 then comes the error.
    plz help me out wat to do something is going wrong in the configure bcoz itz not recongnizing the host and target ...And the packages I am using are :-
    1)qt-everywhere-opensource-src-5.0.0-beta1
    2)ti-sdk toolchain and rfs as you described earlier.
    Tej
  • Please repost with all details:
    - SDK version
    - Graphics SDK version
    - Host platform
    - env settings on host machine
    - Output of configure with -verbose added to options
  • Hi Prabindh ,thanks for the reply .The packages I am using are--
    Hi Prabindh ,Thanks a lot for ur reply.Here the packages I am using:-
    1)ti-sdk-am-3335x-evm-05.07.00.00-linux-x86-install
    2) Graphics_SDK_4_08_00_02
    3) uname -m --> it gives i686
    4)I give the toolchain path in PATH env variable and other things are according to qmake.conf file
    5)qt-everywhere-opensource-src-5.0.1
    And configure output is --
    root@tejbir:/opt/qt-everywhere-opensource-src-5.0.1# ./configure -release -prefix /opt/3_jul_install/ -platform linux-g++ -xplatform linux-arm-gnueabi-ti-g++ -confirm-license -opensource -qt-libpng -qt-libjpeg -no-sse2 -no-sse3 -no-ssse3 -no-sse4.1 -no-sse4.2 -v
    + /opt/qt-everywhere-opensource-src-5.0.1/qtbase/configure -release -prefix /opt/3_jul_install/ -platform linux-g++ -xplatform linux-arm-gnueabi-ti-g++ -confirm-license -opensource -qt-libpng -qt-libjpeg -no-sse2 -no-sse3 -no-ssse3 -no-sse4.1 -no-sse4.2 -v
    /opt/qt-everywhere-opensource-src-5.0.1/qtbase/configure: 2638: /opt/qt-everywhere-opensource-src-5.0.1/qtbase/configure: -g++: not found
    Precompiled-headers support disabled.
    -g++ -c -fvisibility=hidden fvisibility.c
    /opt/qt-everywhere-opensource-src-5.0.1/qtbase/config.tests/unix/fvisibility.test: 29: /opt/qt-everywhere-opensource-src-5.0.1/qtbase/config.tests/unix/fvisibility.test: -g++: not found
    Symbol visibility control disabled.
    -g++ -o libtest.so -shared -Wl,-Bsymbolic-functions -fPIC bsymbolic_functions.c
    /opt/qt-everywhere-opensource-src-5.0.1/qtbase/config.tests/unix/bsymbolic_functions.test: 14: /opt/qt-everywhere-opensource-src-5.0.1/qtbase/config.tests/unix/bsymbolic_functions.test: -g++: not found
    Symbolic function binding disabled.
    <srcbase> = /opt/qt-everywhere-opensource-src-5.0.1/qtbase
    <outbase> = /opt/qt-everywhere-opensource-src-5.0.1/qtbase
    Determining architecture... ()
    /usr/local/ti-sdk-am335x-evm/linux-devkit/bin/arm-arago-linux-gnueabi-g++ -c -pipe -g -Wall -W -fPIE  -I../../mkspecs/linux-arm-gnueabi-ti-g++ -I. -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/glib-2.0 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib/glib-2.0/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/libxml2 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/freetype2 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/dbus-1.0 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/dbus-1.0/dbus -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib/dbus-1.0/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/gstreamer-0.10 -I/usr/local/Graphics_SDK_4_08_00_02/targetfs/XSGX/include -o arch.o arch.cpp
    /usr/local/ti-sdk-am335x-evm/linux-devkit/bin/arm-arago-linux-gnueabi-g++  -o arch arch.o   -L/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/lib -L/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib -L/usr/local/ti-sdk-am335x-evm/filesystem/opt/qt/lib -lxml2 -lz -lts -lasound -lfreetype -lexpat -lgstreamer-0.10 -ldbus-1 -lglib-2.0 -lgthread-2.0 -lfontconfig -lpng -lpthread -Wl,-rpath-link=/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/lib -Wl,-rpath-link=/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib -Wl,-rpath-link=/usr/local/ti-sdk-am335x-evm/filesystem/opt/qt/lib
    /usr/local/ti-sdk-am335x-evm/linux-devkit/bin/../lib/gcc/arm-arago-linux-gnueabi/4.5.3/../../../../arm-arago-linux-gnueabi/bin/ld: skipping incompatible /usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/lib/../../lib/libpthread.so.0 when searching for ../../lib/libpthread.so.0
    /usr/local/ti-sdk-am335x-evm/linux-devkit/bin/../lib/gcc/arm-arago-linux-gnueabi/4.5.3/../../../../arm-arago-linux-gnueabi/bin/ld: skipping incompatible /usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/lib/../../lib/libc.so.6 when searching for ../../lib/libc.so.6
    { test -n "" && DESTDIR="" || DESTDIR=.; } && test $(gdb --version | sed -e 's,[^0-9]\+\([0-9]\)\.\([0-9]\).*,\1\2,;q') -gt 72 && gdb --nx --batch --quiet -ex 'set confirm off' -ex "save gdb-index $DESTDIR" -ex quit 'arch' && test -f arch.gdb-index && /usr/local/ti-sdk-am335x-evm/linux-devkit/bin/arm-arago-linux-gnueabi-objcopy --add-section '.gdb_index=arch.gdb-index' --set-section-flags '.gdb_index=readonly' 'arch' 'arch' && rm -f arch.gdb-index || true
        Found architecture in binary
    CFG_ARCH="arm"
    CFG_CPUFEATURES=""
    g++ -c -pipe -g -Wall -W -fPIE  -I../../mkspecs/linux-g++ -I. -o arch.o arch.cpp
    g++  -o arch arch.o
    { test -n "" && DESTDIR="" || DESTDIR=.; } && test $(gdb --version | sed -e 's,[^0-9]\+\([0-9]\)\.\([0-9]\).*,\1\2,;q') -gt 72 && gdb --nx --batch --quiet -ex 'set confirm off' -ex "save gdb-index $DESTDIR" -ex quit 'arch' && test -f arch.gdb-index && objcopy --add-section '.gdb_index=arch.gdb-index' --set-section-flags '.gdb_index=readonly' 'arch' 'arch' && rm -f arch.gdb-index || true
    CFG_HOST_ARCH="i386"
    CFG_HOST_CPUFEATURES=""
    System architecture: 'arm'
    Host architecture: 'i386'
    C++11 auto-detection... ()
    /usr/local/ti-sdk-am335x-evm/linux-devkit/bin/arm-arago-linux-gnueabi-g++ -c -pipe -Os -march=armv7-a -mfpu=neon -mfloat-abi=softfp -std=c++0x -Wall -W -fPIE  -I../../../mkspecs/linux-arm-gnueabi-ti-g++ -I. -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/glib-2.0 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib/glib-2.0/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/libxml2 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/freetype2 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/dbus-1.0 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/dbus-1.0/dbus -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib/dbus-1.0/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/gstreamer-0.10 -I/usr/local/Graphics_SDK_4_08_00_02/targetfs/XSGX/include -o c++11.o c++11.cpp
    /usr/local/ti-sdk-am335x-evm/linux-devkit/bin/arm-arago-linux-gnueabi-g++ -Wl,-O1 -o c++11 c++11.o   -L/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/lib -L/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib -L/usr/local/ti-sdk-am335x-evm/filesystem/opt/qt/lib -lxml2 -lz -lts -lasound -lfreetype -lexpat -lgstreamer-0.10 -ldbus-1 -lglib-2.0 -lgthread-2.0 -lfontconfig -lpng -lpthread -Wl,-rpath-link=/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/lib -Wl,-rpath-link=/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib -Wl,-rpath-link=/usr/local/ti-sdk-am335x-evm/filesystem/opt/qt/lib
    C++11 enabled.
    floatmath auto-detection... ()
    /usr/local/ti-sdk-am335x-evm/linux-devkit/bin/arm-arago-linux-gnueabi-g++ -c -pipe -Os -march=armv7-a -mfpu=neon -mfloat-abi=softfp -Wall -W -fPIE  -I../../../mkspecs/linux-arm-gnueabi-ti-g++ -I. -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/glib-2.0 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib/glib-2.0/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/libxml2 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/freetype2 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/dbus-1.0 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/dbus-1.0/dbus -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib/dbus-1.0/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/gstreamer-0.10 -I/usr/local/Graphics_SDK_4_08_00_02/targetfs/XSGX/include -o floatmath.o floatmath.cpp
    floatmath.cpp:44:5: warning: unused parameter 'argc'
    floatmath.cpp:44:5: warning: unused parameter 'argv'
    /usr/local/ti-sdk-am335x-evm/linux-devkit/bin/arm-arago-linux-gnueabi-g++ -Wl,-O1 -o floatmath floatmath.o   -L/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/lib -L/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib -L/usr/local/ti-sdk-am335x-evm/filesystem/opt/qt/lib -lxml2 -lz -lts -lasound -lfreetype -lexpat -lgstreamer-0.10 -ldbus-1 -lglib-2.0 -lgthread-2.0 -lfontconfig -lpng -lpthread -Wl,-rpath-link=/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/lib -Wl,-rpath-link=/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib -Wl,-rpath-link=/usr/local/ti-sdk-am335x-evm/filesystem/opt/qt/lib
    floatmath enabled.
    avx auto-detection... ()
    /usr/local/ti-sdk-am335x-evm/linux-devkit/bin/arm-arago-linux-gnueabi-g++ -c -pipe -mavx -g -Wall -W -fPIE  -I../../../mkspecs/linux-arm-gnueabi-ti-g++ -I. -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/glib-2.0 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib/glib-2.0/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/libxml2 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/freetype2 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/dbus-1.0 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/dbus-1.0/dbus -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib/dbus-1.0/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/gstreamer-0.10 -I/usr/local/Graphics_SDK_4_08_00_02/targetfs/XSGX/include -o avx.o avx.cpp
    cc1plus: error: unrecognized command line option "-mavx"
    make: *** [avx.o] Error 1
    avx disabled.
    neon auto-detection... ()
    /usr/local/ti-sdk-am335x-evm/linux-devkit/bin/arm-arago-linux-gnueabi-g++ -c -pipe -mfpu=neon -Os -march=armv7-a -mfpu=neon -mfloat-abi=softfp -Wall -W -fPIE  -I../../../mkspecs/linux-arm-gnueabi-ti-g++ -I. -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/glib-2.0 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib/glib-2.0/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/libxml2 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/freetype2 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/dbus-1.0 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/dbus-1.0/dbus -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib/dbus-1.0/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/gstreamer-0.10 -I/usr/local/Graphics_SDK_4_08_00_02/targetfs/XSGX/include -o neon.o neon.cpp
    /usr/local/ti-sdk-am335x-evm/linux-devkit/bin/arm-arago-linux-gnueabi-g++ -Wl,-O1 -o neon neon.o   -L/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/lib -L/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib -L/usr/local/ti-sdk-am335x-evm/filesystem/opt/qt/lib -lxml2 -lz -lts -lasound -lfreetype -lexpat -lgstreamer-0.10 -ldbus-1 -lglib-2.0 -lgthread-2.0 -lfontconfig -lpng -lpthread -Wl,-rpath-link=/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/lib -Wl,-rpath-link=/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib -Wl,-rpath-link=/usr/local/ti-sdk-am335x-evm/filesystem/opt/qt/lib
    neon enabled.
    zlib auto-detection... ()
    /usr/local/ti-sdk-am335x-evm/linux-devkit/bin/arm-arago-linux-gnueabi-g++ -c -pipe -Os -march=armv7-a -mfpu=neon -mfloat-abi=softfp -Wall -W -fPIE  -I../../../mkspecs/linux-arm-gnueabi-ti-g++ -I. -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/glib-2.0 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib/glib-2.0/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/libxml2 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/freetype2 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/dbus-1.0 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/dbus-1.0/dbus -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib/dbus-1.0/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/gstreamer-0.10 -I/usr/local/Graphics_SDK_4_08_00_02/targetfs/XSGX/include -o zlib.o zlib.cpp
    /usr/local/ti-sdk-am335x-evm/linux-devkit/bin/arm-arago-linux-gnueabi-g++ -Wl,-O1 -o zlib zlib.o   -L/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/lib -L/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib -L/usr/local/ti-sdk-am335x-evm/filesystem/opt/qt/lib -lxml2 -lts -lasound -lfreetype -lexpat -lgstreamer-0.10 -ldbus-1 -lglib-2.0 -lgthread-2.0 -lfontconfig -lpng -lpthread -Wl,-rpath-link=/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/lib -Wl,-rpath-link=/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib -Wl,-rpath-link=/usr/local/ti-sdk-am335x-evm/filesystem/opt/qt/lib -lz
    zlib enabled.
    DB2 auto-detection... ()
    /usr/local/ti-sdk-am335x-evm/linux-devkit/bin/arm-arago-linux-gnueabi-g++ -c -pipe -Os -march=armv7-a -mfpu=neon -mfloat-abi=softfp -Wall -W -fPIE  -I../../../mkspecs/linux-arm-gnueabi-ti-g++ -I. -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/glib-2.0 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib/glib-2.0/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/libxml2 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/freetype2 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/dbus-1.0 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/dbus-1.0/dbus -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib/dbus-1.0/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/gstreamer-0.10 -I/usr/local/Graphics_SDK_4_08_00_02/targetfs/XSGX/include -o db2.o db2.cpp
    db2.cpp:42:20: fatal error: sqlcli.h: No such file or directory
    make: *** [db2.o] Error 1
    DB2 disabled.
    InterBase auto-detection... ()
    /usr/local/ti-sdk-am335x-evm/linux-devkit/bin/arm-arago-linux-gnueabi-g++ -c -pipe -Os -march=armv7-a -mfpu=neon -mfloat-abi=softfp -Wall -W -fPIE  -I../../../mkspecs/linux-arm-gnueabi-ti-g++ -I. -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/glib-2.0 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib/glib-2.0/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/libxml2 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/freetype2 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/dbus-1.0 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/dbus-1.0/dbus -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib/dbus-1.0/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/gstreamer-0.10 -I/usr/local/Graphics_SDK_4_08_00_02/targetfs/XSGX/include -o ibase.o ibase.cpp
    ibase.cpp:42:19: fatal error: ibase.h: No such file or directory
    make: *** [ibase.o] Error 1
    InterBase disabled.
    MySQL (thread-safe) auto-detection... ()
    /usr/local/ti-sdk-am335x-evm/linux-devkit/bin/arm-arago-linux-gnueabi-g++ -c -pipe -Os -march=armv7-a -mfpu=neon -mfloat-abi=softfp -Wall -W -fPIE  -I../../../mkspecs/linux-arm-gnueabi-ti-g++ -I. -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/glib-2.0 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib/glib-2.0/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/libxml2 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/freetype2 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/dbus-1.0 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/dbus-1.0/dbus -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib/dbus-1.0/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/gstreamer-0.10 -I/usr/local/Graphics_SDK_4_08_00_02/targetfs/XSGX/include -o mysql.o ../mysql/mysql.cpp
    ../mysql/mysql.cpp:42:19: fatal error: mysql.h: No such file or directory
    make: *** [mysql.o] Error 1
    MySQL (thread-safe) disabled.
    MySQL (thread-unsafe) auto-detection... ()
    /usr/local/ti-sdk-am335x-evm/linux-devkit/bin/arm-arago-linux-gnueabi-g++ -c -pipe -Os -march=armv7-a -mfpu=neon -mfloat-abi=softfp -Wall -W -fPIE  -I../../../mkspecs/linux-arm-gnueabi-ti-g++ -I. -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/glib-2.0 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib/glib-2.0/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/libxml2 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/freetype2 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/dbus-1.0 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/dbus-1.0/dbus -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib/dbus-1.0/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/gstreamer-0.10 -I/usr/local/Graphics_SDK_4_08_00_02/targetfs/XSGX/include -o mysql.o mysql.cpp
    MySQL (thread-unsafe) disabled.
    OCI auto-detection... ()
    /usr/local/ti-sdk-am335x-evm/linux-devkit/bin/arm-arago-linux-gnueabi-g++ -c -pipe -Os -march=armv7-a -mfpu=neon -mfloat-abi=softfp -Wall -W -fPIE  -I../../../mkspecs/linux-arm-gnueabi-ti-g++ -I. -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/glib-2.0 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib/glib-2.0/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/libxml2 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/freetype2 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/dbus-1.0 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/dbus-1.0/dbus -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib/dbus-1.0/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/gstreamer-0.10 -I/usr/local/Graphics_SDK_4_08_00_02/targetfs/XSGX/include -o oci.o oci.cpp
    oci.cpp:42:17: fatal error: oci.h: No such file or directory
    make: *** [oci.o] Error 1
    OCI disabled.
    ODBC auto-detection... ()
    /usr/local/ti-sdk-am335x-evm/linux-devkit/bin/arm-arago-linux-gnueabi-g++ -c -pipe -Os -march=armv7-a -mfpu=neon -mfloat-abi=softfp -Wall -W -fPIE  -I../../../mkspecs/linux-arm-gnueabi-ti-g++ -I. -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/glib-2.0 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib/glib-2.0/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/libxml2 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/freetype2 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/dbus-1.0 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/dbus-1.0/dbus -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib/dbus-1.0/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/gstreamer-0.10 -I/usr/local/Graphics_SDK_4_08_00_02/targetfs/XSGX/include -o odbc.o odbc.cpp
    odbc.cpp:45:17: fatal error: sql.h: No such file or directory
    make: *** [odbc.o] Error 1
    ODBC disabled.
    iODBC auto-detection... ()
    /usr/local/ti-sdk-am335x-evm/linux-devkit/bin/arm-arago-linux-gnueabi-g++ -c -pipe -Os -march=armv7-a -mfpu=neon -mfloat-abi=softfp -Wall -W -fPIE  -I../../../mkspecs/linux-arm-gnueabi-ti-g++ -I. -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/glib-2.0 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib/glib-2.0/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/libxml2 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/freetype2 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/dbus-1.0 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/dbus-1.0/dbus -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib/dbus-1.0/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/gstreamer-0.10 -I/usr/local/Graphics_SDK_4_08_00_02/targetfs/XSGX/include -o iodbc.o iodbc.cpp
    iodbc.cpp:42:17: fatal error: sql.h: No such file or directory
    make: *** [iodbc.o] Error 1
    iODBC disabled.
    PostgreSQL auto-detection... ()
    /usr/local/ti-sdk-am335x-evm/linux-devkit/bin/arm-arago-linux-gnueabi-g++ -c -pipe -Os -march=armv7-a -mfpu=neon -mfloat-abi=softfp -Wall -W -fPIE  -I../../../mkspecs/linux-arm-gnueabi-ti-g++ -I. -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/glib-2.0 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib/glib-2.0/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/libxml2 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/freetype2 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/dbus-1.0 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/dbus-1.0/dbus -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib/dbus-1.0/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/gstreamer-0.10 -I/usr/local/Graphics_SDK_4_08_00_02/targetfs/XSGX/include -o psql.o psql.cpp
    psql.cpp:42:22: fatal error: libpq-fe.h: No such file or directory
    make: *** [psql.o] Error 1
    PostgreSQL disabled.
    SQLite2 auto-detection... ()
    /usr/local/ti-sdk-am335x-evm/linux-devkit/bin/arm-arago-linux-gnueabi-g++ -c -pipe -Os -march=armv7-a -mfpu=neon -mfloat-abi=softfp -Wall -W -fPIE  -I../../../mkspecs/linux-arm-gnueabi-ti-g++ -I. -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/glib-2.0 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib/glib-2.0/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/libxml2 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/freetype2 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/dbus-1.0 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/dbus-1.0/dbus -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib/dbus-1.0/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/gstreamer-0.10 -I/usr/local/Graphics_SDK_4_08_00_02/targetfs/XSGX/include -o sqlite2.o sqlite2.cpp
    sqlite2.cpp:42:20: fatal error: sqlite.h: No such file or directory
    make: *** [sqlite2.o] Error 1
    SQLite2 disabled.
    TDS auto-detection... ()
    /usr/local/ti-sdk-am335x-evm/linux-devkit/bin/arm-arago-linux-gnueabi-g++ -c -pipe -Os -march=armv7-a -mfpu=neon -mfloat-abi=softfp -Wall -W -fPIE  -I../../../mkspecs/linux-arm-gnueabi-ti-g++ -I. -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/glib-2.0 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib/glib-2.0/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/libxml2 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/freetype2 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/dbus-1.0 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/dbus-1.0/dbus -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib/dbus-1.0/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/gstreamer-0.10 -I/usr/local/Graphics_SDK_4_08_00_02/targetfs/XSGX/include -o tds.o tds.cpp
    tds.cpp:42:22: fatal error: sybfront.h: No such file or directory
    make: *** [tds.o] Error 1
    TDS disabled.
    NIS auto-detection... ()
    /usr/local/ti-sdk-am335x-evm/linux-devkit/bin/arm-arago-linux-gnueabi-g++ -c -pipe -Os -march=armv7-a -mfpu=neon -mfloat-abi=softfp -Wall -W -fPIE  -I../../../mkspecs/linux-arm-gnueabi-ti-g++ -I. -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/glib-2.0 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib/glib-2.0/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/libxml2 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/freetype2 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/dbus-1.0 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/dbus-1.0/dbus -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib/dbus-1.0/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/gstreamer-0.10 -I/usr/local/Graphics_SDK_4_08_00_02/targetfs/XSGX/include -o nis.o nis.cpp
    /usr/local/ti-sdk-am335x-evm/linux-devkit/bin/arm-arago-linux-gnueabi-g++ -Wl,-O1 -o nis nis.o   -L/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/lib -L/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib -L/usr/local/ti-sdk-am335x-evm/filesystem/opt/qt/lib -lxml2 -lz -lts -lasound -lfreetype -lexpat -lgstreamer-0.10 -ldbus-1 -lglib-2.0 -lgthread-2.0 -lfontconfig -lpng -lpthread -Wl,-rpath-link=/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/lib -Wl,-rpath-link=/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib -Wl,-rpath-link=/usr/local/ti-sdk-am335x-evm/filesystem/opt/qt/lib -lnsl
    NIS enabled.
    Cups auto-detection... ()
    /usr/local/ti-sdk-am335x-evm/linux-devkit/bin/arm-arago-linux-gnueabi-g++ -c -pipe -Os -march=armv7-a -mfpu=neon -mfloat-abi=softfp -Wall -W -fPIE  -I../../../mkspecs/linux-arm-gnueabi-ti-g++ -I. -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/glib-2.0 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib/glib-2.0/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/libxml2 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/freetype2 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/dbus-1.0 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/dbus-1.0/dbus -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib/dbus-1.0/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/gstreamer-0.10 -I/usr/local/Graphics_SDK_4_08_00_02/targetfs/XSGX/include -o cups.o cups.cpp
    cups.cpp:42:23: fatal error: cups/cups.h: No such file or directory
    make: *** [cups.o] Error 1
    Cups disabled.
    POSIX iconv auto-detection... ()
    /usr/local/ti-sdk-am335x-evm/linux-devkit/bin/arm-arago-linux-gnueabi-g++ -c -pipe -Os -march=armv7-a -mfpu=neon -mfloat-abi=softfp -Wall -W -fPIE  -I../../../mkspecs/linux-arm-gnueabi-ti-g++ -I. -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/glib-2.0 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib/glib-2.0/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/libxml2 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/freetype2 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/dbus-1.0 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/dbus-1.0/dbus -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib/dbus-1.0/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/gstreamer-0.10 -I/usr/local/Graphics_SDK_4_08_00_02/targetfs/XSGX/include -o iconv.o iconv.cpp
    /usr/local/ti-sdk-am335x-evm/linux-devkit/bin/arm-arago-linux-gnueabi-g++ -Wl,-O1 -o iconv iconv.o   -L/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/lib -L/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib -L/usr/local/ti-sdk-am335x-evm/filesystem/opt/qt/lib -lxml2 -lz -lts -lasound -lfreetype -lexpat -lgstreamer-0.10 -ldbus-1 -lglib-2.0 -lgthread-2.0 -lfontconfig -lpng -lpthread -Wl,-rpath-link=/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/lib -Wl,-rpath-link=/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib -Wl,-rpath-link=/usr/local/ti-sdk-am335x-evm/filesystem/opt/qt/lib
    POSIX iconv enabled.
    D-Bus auto-detection... ()
    /usr/local/ti-sdk-am335x-evm/linux-devkit/bin/arm-arago-linux-gnueabi-g++ -c -pipe -Os -march=armv7-a -mfpu=neon -mfloat-abi=softfp -Wall -W -fPIE  -I../../../mkspecs/linux-arm-gnueabi-ti-g++ -I. -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/glib-2.0 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib/glib-2.0/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/libxml2 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/freetype2 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/dbus-1.0 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/dbus-1.0/dbus -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib/dbus-1.0/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/gstreamer-0.10 -I/usr/local/Graphics_SDK_4_08_00_02/targetfs/XSGX/include -o dbus.o dbus.cpp
    /usr/local/ti-sdk-am335x-evm/linux-devkit/bin/arm-arago-linux-gnueabi-g++ -Wl,-O1 -o dbus dbus.o   -L/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/lib -L/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib -L/usr/local/ti-sdk-am335x-evm/filesystem/opt/qt/lib -lxml2 -lz -lts -lasound -lfreetype -lexpat -lgstreamer-0.10 -ldbus-1 -lglib-2.0 -lgthread-2.0 -lfontconfig -lpng -lpthread -Wl,-rpath-link=/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/lib -Wl,-rpath-link=/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib -Wl,-rpath-link=/usr/local/ti-sdk-am335x-evm/filesystem/opt/qt/lib
    D-Bus enabled.
    Glib auto-detection... ()
    /usr/local/ti-sdk-am335x-evm/linux-devkit/bin/arm-arago-linux-gnueabi-g++ -c -pipe -Os -march=armv7-a -mfpu=neon -mfloat-abi=softfp -Wall -W -fPIE  -I../../../mkspecs/linux-arm-gnueabi-ti-g++ -I. -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/glib-2.0 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib/glib-2.0/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/libxml2 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/freetype2 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/dbus-1.0 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/dbus-1.0/dbus -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib/dbus-1.0/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/gstreamer-0.10 -I/usr/local/Graphics_SDK_4_08_00_02/targetfs/XSGX/include -o glib.o glib.cpp
    glib.cpp: In function 'int main(int, char**)':
    glib.cpp:55:38: warning: 'pollfd' is used uninitialized in this function
    /usr/local/ti-sdk-am335x-evm/linux-devkit/bin/arm-arago-linux-gnueabi-g++ -Wl,-O1 -o glib glib.o   -L/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/lib -L/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib -L/usr/local/ti-sdk-am335x-evm/filesystem/opt/qt/lib -lxml2 -lz -lts -lasound -lfreetype -lexpat -lgstreamer-0.10 -ldbus-1 -lglib-2.0 -lgthread-2.0 -lfontconfig -lpng -lpthread -Wl,-rpath-link=/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/lib -Wl,-rpath-link=/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib -Wl,-rpath-link=/usr/local/ti-sdk-am335x-evm/filesystem/opt/qt/lib
    Glib enabled.
    GStreamer auto-detection... ()
    /usr/local/ti-sdk-am335x-evm/linux-devkit/bin/arm-arago-linux-gnueabi-g++ -c -pipe -Os -march=armv7-a -mfpu=neon -mfloat-abi=softfp -Wall -W -fPIE  -I../../../mkspecs/linux-arm-gnueabi-ti-g++ -I. -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/glib-2.0 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib/glib-2.0/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/libxml2 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/freetype2 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/dbus-1.0 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/dbus-1.0/dbus -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib/dbus-1.0/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/gstreamer-0.10 -I/usr/local/Graphics_SDK_4_08_00_02/targetfs/XSGX/include -o gstreamer.o gstreamer.cpp
    gstreamer.cpp:53:5: warning: unused parameter 'argc'
    gstreamer.cpp:53:5: warning: unused parameter 'argv'
    /usr/local/ti-sdk-am335x-evm/linux-devkit/bin/arm-arago-linux-gnueabi-g++ -Wl,-O1 -o gstreamer gstreamer.o   -L/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/lib -L/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib -L/usr/local/ti-sdk-am335x-evm/filesystem/opt/qt/lib -lxml2 -lz -lts -lasound -lfreetype -lexpat -lgstreamer-0.10 -ldbus-1 -lglib-2.0 -lgthread-2.0 -lfontconfig -lpng -lpthread -Wl,-rpath-link=/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/lib -Wl,-rpath-link=/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib -Wl,-rpath-link=/usr/local/ti-sdk-am335x-evm/filesystem/opt/qt/lib -lgstinterfaces-0.10 -lgstvideo-0.10 -lgstbase-0.10
    GStreamer enabled.
    /usr/local/ti-sdk-am335x-evm/linux-devkit/bin/arm-arago-linux-gnueabi-g++ -c -pipe -Os -march=armv7-a -mfpu=neon -mfloat-abi=softfp -Wall -W -fPIE  -I../../../mkspecs/linux-arm-gnueabi-ti-g++ -I. -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/glib-2.0 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib/glib-2.0/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/libxml2 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/freetype2 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/dbus-1.0 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/dbus-1.0/dbus -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib/dbus-1.0/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/gstreamer-0.10 -I/usr/local/Graphics_SDK_4_08_00_02/targetfs/XSGX/include -o icu.o icu.cpp
    ICU disabled.
    PulseAudio auto-detection... ()
    /usr/local/ti-sdk-am335x-evm/linux-devkit/bin/arm-arago-linux-gnueabi-g++ -c -pipe -Os -march=armv7-a -mfpu=neon -mfloat-abi=softfp -Wall -W -fPIE  -I../../../mkspecs/linux-arm-gnueabi-ti-g++ -I. -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/glib-2.0 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib/glib-2.0/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/libxml2 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/freetype2 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/dbus-1.0 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/dbus-1.0/dbus -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib/dbus-1.0/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/gstreamer-0.10 -I/usr/local/Graphics_SDK_4_08_00_02/targetfs/XSGX/include -o pulseaudio.o pulseaudio.cpp
    /usr/local/ti-sdk-am335x-evm/linux-devkit/bin/arm-arago-linux-gnueabi-g++ -Wl,-O1 -o pulseaudio pulseaudio.o   -L/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/lib -L/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib -L/usr/local/ti-sdk-am335x-evm/filesystem/opt/qt/lib -lxml2 -lz -lts -lasound -lfreetype -lexpat -lgstreamer-0.10 -ldbus-1 -lglib-2.0 -lgthread-2.0 -lfontconfig -lpng -lpthread -Wl,-rpath-link=/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/lib -Wl,-rpath-link=/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib -Wl,-rpath-link=/usr/local/ti-sdk-am335x-evm/filesystem/opt/qt/lib
    pulseaudio.o: In function `main':
    pulseaudio.cpp:(.text+0x4): undefined reference to `pa_get_library_version'
    pulseaudio.cpp:(.text+0xc): undefined reference to `pa_glib_mainloop_new'
    collect2: ld returned 1 exit status
    make: *** [pulseaudio] Error 1
    PulseAudio disabled.
    OpenGL auto-detection... ()
    /usr/local/ti-sdk-am335x-evm/linux-devkit/bin/arm-arago-linux-gnueabi-g++ -c -pipe -Os -march=armv7-a -mfpu=neon -mfloat-abi=softfp -Wall -W -fPIE  -I../../../mkspecs/linux-arm-gnueabi-ti-g++ -I. -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/glib-2.0 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib/glib-2.0/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/libxml2 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/freetype2 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/dbus-1.0 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/dbus-1.0/dbus -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib/dbus-1.0/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/gstreamer-0.10 -I/usr/local/Graphics_SDK_4_08_00_02/targetfs/XSGX/include -o opengldesktop.o opengldesktop.cpp
    /usr/local/ti-sdk-am335x-evm/linux-devkit/bin/arm-arago-linux-gnueabi-g++ -Wl,-O1 -o opengldesktop opengldesktop.o   -L/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/lib -L/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib -L/usr/local/ti-sdk-am335x-evm/filesystem/opt/qt/lib -lxml2 -lz -lts -lasound -lfreetype -lexpat -lgstreamer-0.10 -ldbus-1 -lglib-2.0 -lgthread-2.0 -lfontconfig -lpng -lpthread -Wl,-rpath-link=/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/lib -Wl,-rpath-link=/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib -Wl,-rpath-link=/usr/local/ti-sdk-am335x-evm/filesystem/opt/qt/lib -lGL
    /usr/local/ti-sdk-am335x-evm/linux-devkit/bin/../lib/gcc/arm-arago-linux-gnueabi/4.5.3/../../../../arm-arago-linux-gnueabi/bin/ld: cannot find -lGL
    make: *** [opengldesktop] Error 1
    OpenGL disabled.
    OpenGL ES 2.x auto-detection... ()
    /usr/local/ti-sdk-am335x-evm/linux-devkit/bin/arm-arago-linux-gnueabi-g++ -c -pipe -Os -march=armv7-a -mfpu=neon -mfloat-abi=softfp -Wall -W -fPIE  -I../../../mkspecs/linux-arm-gnueabi-ti-g++ -I. -I/usr/local/Graphics_SDK_4_08_00_02/include/OGLES2 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/glib-2.0 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib/glib-2.0/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/libxml2 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/freetype2 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/dbus-1.0 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/dbus-1.0/dbus -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib/dbus-1.0/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/gstreamer-0.10 -I/usr/local/Graphics_SDK_4_08_00_02/targetfs/XSGX/include -o opengles2.o opengles2.cpp
    /usr/local/ti-sdk-am335x-evm/linux-devkit/bin/arm-arago-linux-gnueabi-g++ -Wl,-O1 -o opengles2 opengles2.o   -L/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/lib -L/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib -L/usr/local/ti-sdk-am335x-evm/filesystem/opt/qt/lib -lxml2 -lz -lts -lasound -lfreetype -lexpat -lgstreamer-0.10 -ldbus-1 -lglib-2.0 -lgthread-2.0 -lfontconfig -lpng -lpthread -Wl,-rpath-link=/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/lib -Wl,-rpath-link=/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib -Wl,-rpath-link=/usr/local/ti-sdk-am335x-evm/filesystem/opt/qt/lib -lEGL -lIMGegl -lsrv_um -lGLESv2 -lGLES_CM -lusc
    OpenGL ES 2.x enabled.
    FontConfig auto-detection... ()
    /usr/local/ti-sdk-am335x-evm/linux-devkit/bin/arm-arago-linux-gnueabi-g++ -c -pipe -Os -march=armv7-a -mfpu=neon -mfloat-abi=softfp -Wall -W -fPIE  -I../../../mkspecs/linux-arm-gnueabi-ti-g++ -I. -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/glib-2.0 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib/glib-2.0/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/libxml2 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/freetype2 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/dbus-1.0 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/dbus-1.0/dbus -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib/dbus-1.0/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/gstreamer-0.10 -I/usr/local/Graphics_SDK_4_08_00_02/targetfs/XSGX/include -o fontconfig.o fontconfig.cpp
    /usr/local/ti-sdk-am335x-evm/linux-devkit/bin/arm-arago-linux-gnueabi-g++ -Wl,-O1 -o fontconfig fontconfig.o   -L/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/lib -L/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib -L/usr/local/ti-sdk-am335x-evm/filesystem/opt/qt/lib -lxml2 -lz -lts -lasound -lexpat -lgstreamer-0.10 -ldbus-1 -lglib-2.0 -lgthread-2.0 -lpng -lpthread -Wl,-rpath-link=/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/lib -Wl,-rpath-link=/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib -Wl,-rpath-link=/usr/local/ti-sdk-am335x-evm/filesystem/opt/qt/lib -lfreetype -lfontconfig
    FontConfig enabled.
    libudev auto-detection... ()
    /usr/local/ti-sdk-am335x-evm/linux-devkit/bin/arm-arago-linux-gnueabi-g++ -c -pipe -Os -march=armv7-a -mfpu=neon -mfloat-abi=softfp -Wall -W -fPIE  -I../../../mkspecs/linux-arm-gnueabi-ti-g++ -I. -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/glib-2.0 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib/glib-2.0/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/libxml2 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/freetype2 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/dbus-1.0 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/dbus-1.0/dbus -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib/dbus-1.0/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/gstreamer-0.10 -I/usr/local/Graphics_SDK_4_08_00_02/targetfs/XSGX/include -o libudev.o libudev.cpp
    /usr/local/ti-sdk-am335x-evm/linux-devkit/bin/arm-arago-linux-gnueabi-g++ -Wl,-O1 -o libudev libudev.o   -L/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/lib -L/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib -L/usr/local/ti-sdk-am335x-evm/filesystem/opt/qt/lib -lxml2 -lz -lts -lasound -lfreetype -lexpat -lgstreamer-0.10 -ldbus-1 -lglib-2.0 -lgthread-2.0 -lfontconfig -lpng -lpthread -Wl,-rpath-link=/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/lib -Wl,-rpath-link=/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib -Wl,-rpath-link=/usr/local/ti-sdk-am335x-evm/filesystem/opt/qt/lib -ludev
    libudev enabled.
    evdev auto-detection... ()
    /usr/local/ti-sdk-am335x-evm/linux-devkit/bin/arm-arago-linux-gnueabi-g++ -c -pipe -Os -march=armv7-a -mfpu=neon -mfloat-abi=softfp -Wall -W -fPIE  -I../../../mkspecs/linux-arm-gnueabi-ti-g++ -I. -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/glib-2.0 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib/glib-2.0/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/libxml2 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/freetype2 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/dbus-1.0 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/dbus-1.0/dbus -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib/dbus-1.0/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/gstreamer-0.10 -I/usr/local/Graphics_SDK_4_08_00_02/targetfs/XSGX/include -o evdev.o evdev.cpp
    /usr/local/ti-sdk-am335x-evm/linux-devkit/bin/arm-arago-linux-gnueabi-g++ -Wl,-O1 -o evdev evdev.o   -L/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/lib -L/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib -L/usr/local/ti-sdk-am335x-evm/filesystem/opt/qt/lib -lxml2 -lz -lts -lasound -lfreetype -lexpat -lgstreamer-0.10 -ldbus-1 -lglib-2.0 -lgthread-2.0 -lfontconfig -lpng -lpthread -Wl,-rpath-link=/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/lib -Wl,-rpath-link=/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib -Wl,-rpath-link=/usr/local/ti-sdk-am335x-evm/filesystem/opt/qt/lib
    evdev enabled.
    XLib auto-detection... ()
    /usr/local/ti-sdk-am335x-evm/linux-devkit/bin/arm-arago-linux-gnueabi-g++ -c -pipe -Os -march=armv7-a -mfpu=neon -mfloat-abi=softfp -Wall -W -fPIE  -I../../../mkspecs/linux-arm-gnueabi-ti-g++ -I. -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/glib-2.0 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib/glib-2.0/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/libxml2 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/freetype2 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/dbus-1.0 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/dbus-1.0/dbus -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib/dbus-1.0/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/gstreamer-0.10 -I/usr/local/Graphics_SDK_4_08_00_02/targetfs/XSGX/include -o xlib.o xlib.cpp
    /usr/local/ti-sdk-am335x-evm/linux-devkit/bin/arm-arago-linux-gnueabi-g++ -Wl,-O1 -o xlib xlib.o   -L/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/lib -L/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib -L/usr/local/ti-sdk-am335x-evm/filesystem/opt/qt/lib -lxml2 -lz -lts -lasound -lfreetype -lexpat -lgstreamer-0.10 -ldbus-1 -lglib-2.0 -lgthread-2.0 -lfontconfig -lpng -lpthread -Wl,-rpath-link=/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/lib -Wl,-rpath-link=/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib -Wl,-rpath-link=/usr/local/ti-sdk-am335x-evm/filesystem/opt/qt/lib -lXext -lX11 -lm
    /usr/local/ti-sdk-am335x-evm/linux-devkit/bin/../lib/gcc/arm-arago-linux-gnueabi/4.5.3/../../../../arm-arago-linux-gnueabi/bin/ld: cannot find -lXext
    make: *** [xlib] Error 1
    XLib disabled.
    Xrender auto-detection... ()
    /usr/local/ti-sdk-am335x-evm/linux-devkit/bin/arm-arago-linux-gnueabi-g++ -c -pipe -Os -march=armv7-a -mfpu=neon -mfloat-abi=softfp -Wall -W -fPIE  -I../../../mkspecs/linux-arm-gnueabi-ti-g++ -I. -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/glib-2.0 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib/glib-2.0/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/libxml2 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/freetype2 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/dbus-1.0 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/dbus-1.0/dbus -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib/dbus-1.0/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/gstreamer-0.10 -I/usr/local/Graphics_SDK_4_08_00_02/targetfs/XSGX/include -o xrender.o xrender.cpp
    /usr/local/ti-sdk-am335x-evm/linux-devkit/bin/arm-arago-linux-gnueabi-g++ -Wl,-O1 -o xrender xrender.o   -L/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/lib -L/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib -L/usr/local/ti-sdk-am335x-evm/filesystem/opt/qt/lib -lxml2 -lz -lts -lasound -lfreetype -lexpat -lgstreamer-0.10 -ldbus-1 -lglib-2.0 -lgthread-2.0 -lfontconfig -lpng -lpthread -Wl,-rpath-link=/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/lib -Wl,-rpath-link=/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib -Wl,-rpath-link=/usr/local/ti-sdk-am335x-evm/filesystem/opt/qt/lib -lXrender -lXext -lX11 -lm
    /usr/local/ti-sdk-am335x-evm/linux-devkit/bin/../lib/gcc/arm-arago-linux-gnueabi/4.5.3/../../../../arm-arago-linux-gnueabi/bin/ld: cannot find -lXrender
    make: *** [xrender] Error 1
    Xrender disabled.
    xcb auto-detection... ()
    /usr/local/ti-sdk-am335x-evm/linux-devkit/bin/arm-arago-linux-gnueabi-g++ -c -pipe -Os -march=armv7-a -mfpu=neon -mfloat-abi=softfp -Wall -W -fPIE  -I../../../mkspecs/linux-arm-gnueabi-ti-g++ -I. -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/glib-2.0 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib/glib-2.0/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/libxml2 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/freetype2 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/dbus-1.0 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/dbus-1.0/dbus -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib/dbus-1.0/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/gstreamer-0.10 -I/usr/local/Graphics_SDK_4_08_00_02/targetfs/XSGX/include -o xcb.o xcb.cpp
    xcb.cpp: In function 'int main(int, char**)':
    xcb.cpp:47:23: warning: unused variable 't'
    /usr/local/ti-sdk-am335x-evm/linux-devkit/bin/arm-arago-linux-gnueabi-g++ -Wl,-O1 -o xcb xcb.o   -L/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/lib -L/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib -L/usr/local/ti-sdk-am335x-evm/filesystem/opt/qt/lib -lxml2 -lz -lts -lasound -lfreetype -lexpat -lgstreamer-0.10 -ldbus-1 -lglib-2.0 -lgthread-2.0 -lfontconfig -lpng -lpthread -Wl,-rpath-link=/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/lib -Wl,-rpath-link=/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib -Wl,-rpath-link=/usr/local/ti-sdk-am335x-evm/filesystem/opt/qt/lib -lxcb
    /usr/local/ti-sdk-am335x-evm/linux-devkit/bin/../lib/gcc/arm-arago-linux-gnueabi/4.5.3/../../../../arm-arago-linux-gnueabi/bin/ld: cannot find -lxcb
    make: *** [xcb] Error 1
    xcb disabled.
    LinuxFB auto-detection... ()
    /usr/local/ti-sdk-am335x-evm/linux-devkit/bin/arm-arago-linux-gnueabi-g++ -c -pipe -Os -march=armv7-a -mfpu=neon -mfloat-abi=softfp -Wall -W -fPIE  -I../../../mkspecs/linux-arm-gnueabi-ti-g++ -I. -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/glib-2.0 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib/glib-2.0/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/libxml2 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/freetype2 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/dbus-1.0 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/dbus-1.0/dbus -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib/dbus-1.0/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/gstreamer-0.10 -I/usr/local/Graphics_SDK_4_08_00_02/targetfs/XSGX/include -o linuxfb.o linuxfb.cpp
    /usr/local/ti-sdk-am335x-evm/linux-devkit/bin/arm-arago-linux-gnueabi-g++ -Wl,-O1 -o linuxfb linuxfb.o   -L/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/lib -L/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib -L/usr/local/ti-sdk-am335x-evm/filesystem/opt/qt/lib -lxml2 -lz -lts -lasound -lfreetype -lexpat -lgstreamer-0.10 -ldbus-1 -lglib-2.0 -lgthread-2.0 -lfontconfig -lpng -lpthread -Wl,-rpath-link=/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/lib -Wl,-rpath-link=/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib -Wl,-rpath-link=/usr/local/ti-sdk-am335x-evm/filesystem/opt/qt/lib
    LinuxFB enabled.
    KMS auto-detection... ()
    sh: 1: /usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi: Permission denied
    Project ERROR: Package libdrm not found
    make: *** No targets specified and no makefile found.  Stop.
    KMS disabled.
    EGL auto-detection... ()
    /usr/local/ti-sdk-am335x-evm/linux-devkit/bin/arm-arago-linux-gnueabi-g++ -c -pipe -Os -march=armv7-a -mfpu=neon -mfloat-abi=softfp -Wall -W -fPIE  -I../../../mkspecs/linux-arm-gnueabi-ti-g++ -I. -I/usr/local/Graphics_SDK_4_08_00_02/include/OGLES2 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/glib-2.0 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib/glib-2.0/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/libxml2 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/freetype2 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/dbus-1.0 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/dbus-1.0/dbus -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib/dbus-1.0/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/gstreamer-0.10 -I/usr/local/Graphics_SDK_4_08_00_02/targetfs/XSGX/include -o egl.o egl.cpp
    egl.cpp: In function 'int main(int, char**)':
    egl.cpp:46:12: warning: unused variable 'x'
    /usr/local/ti-sdk-am335x-evm/linux-devkit/bin/arm-arago-linux-gnueabi-g++ -Wl,-O1 -o egl egl.o   -L/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/lib -L/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib -L/usr/local/ti-sdk-am335x-evm/filesystem/opt/qt/lib -lxml2 -lz -lts -lasound -lfreetype -lexpat -lgstreamer-0.10 -ldbus-1 -lglib-2.0 -lgthread-2.0 -lfontconfig -lpng -lpthread -Wl,-rpath-link=/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/lib -Wl,-rpath-link=/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib -Wl,-rpath-link=/usr/local/ti-sdk-am335x-evm/filesystem/opt/qt/lib -lEGL -lIMGegl -lsrv_um -lGLESv2 -lGLES_CM -lusc
    EGL enabled.
    STL auto-detection... ()
    /usr/local/ti-sdk-am335x-evm/linux-devkit/bin/arm-arago-linux-gnueabi-g++ -c -pipe -Os -march=armv7-a -mfpu=neon -mfloat-abi=softfp -Wall -W -fPIE  -I../../../mkspecs/linux-arm-gnueabi-ti-g++ -I. -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/glib-2.0 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib/glib-2.0/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/libxml2 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/freetype2 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/dbus-1.0 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/dbus-1.0/dbus -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib/dbus-1.0/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/gstreamer-0.10 -I/usr/local/Graphics_SDK_4_08_00_02/targetfs/XSGX/include -o stltest.o stltest.cpp
    stltest.cpp: In function 'int main()':
    stltest.cpp:146:9: warning: unused variable 'n'
    /usr/local/ti-sdk-am335x-evm/linux-devkit/bin/arm-arago-linux-gnueabi-g++ -Wl,-O1 -o stl stltest.o   -L/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/lib -L/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib -L/usr/local/ti-sdk-am335x-evm/filesystem/opt/qt/lib -lxml2 -lz -lts -lasound -lfreetype -lexpat -lgstreamer-0.10 -ldbus-1 -lglib-2.0 -lgthread-2.0 -lfontconfig -lpng -lpthread -Wl,-rpath-link=/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/lib -Wl,-rpath-link=/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib -Wl,-rpath-link=/usr/local/ti-sdk-am335x-evm/filesystem/opt/qt/lib
    STL enabled.
    POSIX clock_gettime() auto-detection... ()
    /usr/local/ti-sdk-am335x-evm/linux-devkit/bin/arm-arago-linux-gnueabi-g++ -c -pipe -Os -march=armv7-a -mfpu=neon -mfloat-abi=softfp -Wall -W -fPIE  -I../../../mkspecs/linux-arm-gnueabi-ti-g++ -I. -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/glib-2.0 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib/glib-2.0/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/libxml2 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/freetype2 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/dbus-1.0 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/dbus-1.0/dbus -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib/dbus-1.0/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/gstreamer-0.10 -I/usr/local/Graphics_SDK_4_08_00_02/targetfs/XSGX/include -o clock-gettime.o clock-gettime.cpp
    /usr/local/ti-sdk-am335x-evm/linux-devkit/bin/arm-arago-linux-gnueabi-g++ -Wl,-O1 -o clock-gettime clock-gettime.o   -L/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/lib -L/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib -L/usr/local/ti-sdk-am335x-evm/filesystem/opt/qt/lib -lxml2 -lz -lts -lasound -lfreetype -lexpat -lgstreamer-0.10 -ldbus-1 -lglib-2.0 -lgthread-2.0 -lfontconfig -lpng -lpthread -Wl,-rpath-link=/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/lib -Wl,-rpath-link=/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib -Wl,-rpath-link=/usr/local/ti-sdk-am335x-evm/filesystem/opt/qt/lib -lrt
    POSIX clock_gettime() enabled.
    POSIX Monotonic Clock auto-detection... ()
    /usr/local/ti-sdk-am335x-evm/linux-devkit/bin/arm-arago-linux-gnueabi-g++ -c -pipe -Os -march=armv7-a -mfpu=neon -mfloat-abi=softfp -Wall -W -fPIE  -I../../../mkspecs/linux-arm-gnueabi-ti-g++ -I. -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/glib-2.0 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib/glib-2.0/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/libxml2 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/freetype2 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/dbus-1.0 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/dbus-1.0/dbus -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib/dbus-1.0/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/gstreamer-0.10 -I/usr/local/Graphics_SDK_4_08_00_02/targetfs/XSGX/include -o clock-monotonic.o clock-monotonic.cpp
    /usr/local/ti-sdk-am335x-evm/linux-devkit/bin/arm-arago-linux-gnueabi-g++ -Wl,-O1 -o clock-monotonic clock-monotonic.o   -L/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/lib -L/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib -L/usr/local/ti-sdk-am335x-evm/filesystem/opt/qt/lib -lxml2 -lz -lts -lasound -lfreetype -lexpat -lgstreamer-0.10 -ldbus-1 -lglib-2.0 -lgthread-2.0 -lfontconfig -lpng -lpthread -Wl,-rpath-link=/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/lib -Wl,-rpath-link=/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib -Wl,-rpath-link=/usr/local/ti-sdk-am335x-evm/filesystem/opt/qt/lib -lrt
    /usr/local/ti-sdk-am335x-evm/linux-devkit/bin/../lib/gcc/arm-arago-linux-gnueabi/4.5.3/../../../../arm-arago-linux-gnueabi/bin/ld: skipping incompatible /usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/lib/../../lib/libpthread.so.0 when searching for ../../lib/libpthread.so.0
    /usr/local/ti-sdk-am335x-evm/linux-devkit/bin/../lib/gcc/arm-arago-linux-gnueabi/4.5.3/../../../../arm-arago-linux-gnueabi/bin/ld: skipping incompatible /usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/lib/../../lib/libc.so.6 when searching for ../../lib/libc.so.6
    POSIX Monotonic Clock enabled.
    mremap auto-detection... ()
    /usr/local/ti-sdk-am335x-evm/linux-devkit/bin/arm-arago-linux-gnueabi-g++ -c -pipe -Os -march=armv7-a -mfpu=neon -mfloat-abi=softfp -Wall -W -fPIE  -I../../../mkspecs/linux-arm-gnueabi-ti-g++ -I. -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/glib-2.0 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib/glib-2.0/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/libxml2 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/freetype2 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/dbus-1.0 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/dbus-1.0/dbus -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib/dbus-1.0/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/gstreamer-0.10 -I/usr/local/Graphics_SDK_4_08_00_02/targetfs/XSGX/include -o mremap.o mremap.cpp
    /usr/local/ti-sdk-am335x-evm/linux-devkit/bin/arm-arago-linux-gnueabi-g++ -Wl,-O1 -o mremap mremap.o   -L/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/lib -L/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib -L/usr/local/ti-sdk-am335x-evm/filesystem/opt/qt/lib -lxml2 -lz -lts -lasound -lfreetype -lexpat -lgstreamer-0.10 -ldbus-1 -lglib-2.0 -lgthread-2.0 -lfontconfig -lpng -lpthread -Wl,-rpath-link=/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/lib -Wl,-rpath-link=/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib -Wl,-rpath-link=/usr/local/ti-sdk-am335x-evm/filesystem/opt/qt/lib
    mremap enabled.
    getaddrinfo auto-detection... ()
    /usr/local/ti-sdk-am335x-evm/linux-devkit/bin/arm-arago-linux-gnueabi-g++ -c -pipe -Os -march=armv7-a -mfpu=neon -mfloat-abi=softfp -Wall -W -fPIE  -I../../../mkspecs/linux-arm-gnueabi-ti-g++ -I. -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/glib-2.0 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib/glib-2.0/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/libxml2 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/freetype2 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/dbus-1.0 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/dbus-1.0/dbus -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib/dbus-1.0/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/gstreamer-0.10 -I/usr/local/Graphics_SDK_4_08_00_02/targetfs/XSGX/include -o getaddrinfotest.o getaddrinfotest.cpp
    /usr/local/ti-sdk-am335x-evm/linux-devkit/bin/arm-arago-linux-gnueabi-g++ -Wl,-O1 -o getaddrinfo getaddrinfotest.o   -L/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/lib -L/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib -L/usr/local/ti-sdk-am335x-evm/filesystem/opt/qt/lib -lxml2 -lz -lts -lasound -lfreetype -lexpat -lgstreamer-0.10 -ldbus-1 -lglib-2.0 -lgthread-2.0 -lfontconfig -lpng -lpthread -Wl,-rpath-link=/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/lib -Wl,-rpath-link=/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib -Wl,-rpath-link=/usr/local/ti-sdk-am335x-evm/filesystem/opt/qt/lib
    getaddrinfo enabled.
    inotify auto-detection... ()
    /usr/local/ti-sdk-am335x-evm/linux-devkit/bin/arm-arago-linux-gnueabi-g++ -c -pipe -Os -march=armv7-a -mfpu=neon -mfloat-abi=softfp -Wall -W -fPIE  -I../../../mkspecs/linux-arm-gnueabi-ti-g++ -I. -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/glib-2.0 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib/glib-2.0/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/libxml2 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/freetype2 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/dbus-1.0 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/dbus-1.0/dbus -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib/dbus-1.0/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/gstreamer-0.10 -I/usr/local/Graphics_SDK_4_08_00_02/targetfs/XSGX/include -o inotifytest.o inotifytest.cpp
    /usr/local/ti-sdk-am335x-evm/linux-devkit/bin/arm-arago-linux-gnueabi-g++ -Wl,-O1 -o inotify inotifytest.o   -L/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/lib -L/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib -L/usr/local/ti-sdk-am335x-evm/filesystem/opt/qt/lib -lxml2 -lz -lts -lasound -lfreetype -lexpat -lgstreamer-0.10 -ldbus-1 -lglib-2.0 -lgthread-2.0 -lfontconfig -lpng -lpthread -Wl,-rpath-link=/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/lib -Wl,-rpath-link=/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib -Wl,-rpath-link=/usr/local/ti-sdk-am335x-evm/filesystem/opt/qt/lib
    inotify enabled.
    IPv6 interface name auto-detection... ()
    /usr/local/ti-sdk-am335x-evm/linux-devkit/bin/arm-arago-linux-gnueabi-g++ -c -pipe -Os -march=armv7-a -mfpu=neon -mfloat-abi=softfp -Wall -W -fPIE  -I../../../mkspecs/linux-arm-gnueabi-ti-g++ -I. -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/glib-2.0 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib/glib-2.0/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/libxml2 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/freetype2 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/dbus-1.0 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/dbus-1.0/dbus -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib/dbus-1.0/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/gstreamer-0.10 -I/usr/local/Graphics_SDK_4_08_00_02/targetfs/XSGX/include -o ipv6ifname.o ipv6ifname.cpp
    /usr/local/ti-sdk-am335x-evm/linux-devkit/bin/arm-arago-linux-gnueabi-g++ -Wl,-O1 -o ipv6ifname ipv6ifname.o   -L/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/lib -L/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib -L/usr/local/ti-sdk-am335x-evm/filesystem/opt/qt/lib -lxml2 -lz -lts -lasound -lfreetype -lexpat -lgstreamer-0.10 -ldbus-1 -lglib-2.0 -lgthread-2.0 -lfontconfig -lpng -lpthread -Wl,-rpath-link=/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/lib -Wl,-rpath-link=/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib -Wl,-rpath-link=/usr/local/ti-sdk-am335x-evm/filesystem/opt/qt/lib
    IPv6 interface name enabled.
    getifaddrs auto-detection... ()
    /usr/local/ti-sdk-am335x-evm/linux-devkit/bin/arm-arago-linux-gnueabi-g++ -c -pipe -Os -march=armv7-a -mfpu=neon -mfloat-abi=softfp -Wall -W -fPIE  -I../../../mkspecs/linux-arm-gnueabi-ti-g++ -I. -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/glib-2.0 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib/glib-2.0/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/libxml2 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/freetype2 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/dbus-1.0 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/dbus-1.0/dbus -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib/dbus-1.0/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/gstreamer-0.10 -I/usr/local/Graphics_SDK_4_08_00_02/targetfs/XSGX/include -o getifaddrs.o getifaddrs.cpp
    /usr/local/ti-sdk-am335x-evm/linux-devkit/bin/arm-arago-linux-gnueabi-g++ -Wl,-O1 -o getifaddrs getifaddrs.o   -L/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/lib -L/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib -L/usr/local/ti-sdk-am335x-evm/filesystem/opt/qt/lib -lxml2 -lz -lts -lasound -lfreetype -lexpat -lgstreamer-0.10 -ldbus-1 -lglib-2.0 -lgthread-2.0 -lfontconfig -lpng -lpthread -Wl,-rpath-link=/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/lib -Wl,-rpath-link=/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib -Wl,-rpath-link=/usr/local/ti-sdk-am335x-evm/filesystem/opt/qt/lib
    getifaddrs enabled.
    OpenSSL auto-detection... ()
    /usr/local/ti-sdk-am335x-evm/linux-devkit/bin/arm-arago-linux-gnueabi-g++ -c -pipe -Os -march=armv7-a -mfpu=neon -mfloat-abi=softfp -Wall -W -fPIE  -I../../../mkspecs/linux-arm-gnueabi-ti-g++ -I. -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/glib-2.0 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib/glib-2.0/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/libxml2 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/freetype2 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/dbus-1.0 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/dbus-1.0/dbus -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib/dbus-1.0/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/gstreamer-0.10 -I/usr/local/Graphics_SDK_4_08_00_02/targetfs/XSGX/include -o openssl.o openssl.cpp
    /usr/local/ti-sdk-am335x-evm/linux-devkit/bin/arm-arago-linux-gnueabi-g++ -Wl,-O1 -o openssl openssl.o   -L/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/lib -L/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib -L/usr/local/ti-sdk-am335x-evm/filesystem/opt/qt/lib -lxml2 -lz -lts -lasound -lfreetype -lexpat -lgstreamer-0.10 -ldbus-1 -lglib-2.0 -lgthread-2.0 -lfontconfig -lpng -lpthread -Wl,-rpath-link=/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/lib -Wl,-rpath-link=/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib -Wl,-rpath-link=/usr/local/ti-sdk-am335x-evm/filesystem/opt/qt/lib
    OpenSSL enabled.
    PCRE auto-detection... ()
    /usr/local/ti-sdk-am335x-evm/linux-devkit/bin/arm-arago-linux-gnueabi-g++ -c -pipe -Os -march=armv7-a -mfpu=neon -mfloat-abi=softfp -Wall -W -fPIE  -I../../../mkspecs/linux-arm-gnueabi-ti-g++ -I. -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/glib-2.0 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib/glib-2.0/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/libxml2 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/freetype2 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/dbus-1.0 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/dbus-1.0/dbus -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib/dbus-1.0/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/gstreamer-0.10 -I/usr/local/Graphics_SDK_4_08_00_02/targetfs/XSGX/include -o pcre.o pcre.cpp
    pcre.cpp:42:18: fatal error: pcre.h: No such file or directory
    compilation terminated.
    make: *** [pcre.o] Error 1
    PCRE disabled.
    OpenVG auto-detection... ()
    /usr/local/ti-sdk-am335x-evm/linux-devkit/bin/arm-arago-linux-gnueabi-g++ -c -pipe -Os -march=armv7-a -mfpu=neon -mfloat-abi=softfp -Wall -W -fPIE  -I../../../mkspecs/linux-arm-gnueabi-ti-g++ -I. -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/glib-2.0 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib/glib-2.0/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/libxml2 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/freetype2 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/dbus-1.0 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/dbus-1.0/dbus -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib/dbus-1.0/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/gstreamer-0.10 -I/usr/local/Graphics_SDK_4_08_00_02/targetfs/XSGX/include -o openvg.o openvg.cpp
    openvg.cpp:48:23: fatal error: VG/openvg.h: No such file or directory
    make: *** [openvg.o] Error 1
    OpenVG disabled.
    OpenVG disabled.
    OpenVG (lc includes) auto-detection... ()
    /usr/local/ti-sdk-am335x-evm/linux-devkit/bin/arm-arago-linux-gnueabi-g++ -c -pipe -Os -march=armv7-a -mfpu=neon -mfloat-abi=softfp -Wall -W -fPIE -DQT_LOWER_CASE_VG_INCLUDES -I../../../mkspecs/linux-arm-gnueabi-ti-g++ -I. -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/glib-2.0 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib/glib-2.0/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/libxml2 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/freetype2 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/dbus-1.0 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/dbus-1.0/dbus -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib/dbus-1.0/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/gstreamer-0.10 -I/usr/local/Graphics_SDK_4_08_00_02/targetfs/XSGX/include -o openvg.o openvg.cpp
    openvg.cpp:46:23: fatal error: vg/openvg.h: No such file or directory
    OpenVG (lc includes) disabled.
    alsa auto-detection... ()
    /usr/local/ti-sdk-am335x-evm/linux-devkit/bin/arm-arago-linux-gnueabi-g++ -c -pipe -Os -march=armv7-a -mfpu=neon -mfloat-abi=softfp -Wall -W -fPIE  -I../../../mkspecs/linux-arm-gnueabi-ti-g++ -I. -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/glib-2.0 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib/glib-2.0/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/libxml2 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/freetype2 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/dbus-1.0 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/dbus-1.0/dbus -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib/dbus-1.0/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/gstreamer-0.10 -I/usr/local/Graphics_SDK_4_08_00_02/targetfs/XSGX/include -o alsatest.o alsatest.cpp
    alsatest.cpp:47:5: warning: unused parameter 'argc'
    alsatest.cpp:47:5: warning: unused parameter 'argv'
    /usr/local/ti-sdk-am335x-evm/linux-devkit/bin/arm-arago-linux-gnueabi-g++ -Wl,-O1 -o alsa alsatest.o   -L/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/lib -L/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib -L/usr/local/ti-sdk-am335x-evm/filesystem/opt/qt/lib -lxml2 -lz -lts -lfreetype -lexpat -lgstreamer-0.10 -ldbus-1 -lglib-2.0 -lgthread-2.0 -lfontconfig -lpng -lpthread -Wl,-rpath-link=/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/lib -Wl,-rpath-link=/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib -Wl,-rpath-link=/usr/local/ti-sdk-am335x-evm/filesystem/opt/qt/lib -lasound
    alsa enabled.
    javascriptcore-jit auto-detection... ()
    /usr/local/ti-sdk-am335x-evm/linux-devkit/bin/arm-arago-linux-gnueabi-g++ -c -pipe -Os -march=armv7-a -mfpu=neon -mfloat-abi=softfp -Wall -W -fPIE  -I../../../mkspecs/linux-arm-gnueabi-ti-g++ -I. -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/glib-2.0 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib/glib-2.0/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/libxml2 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/freetype2 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/dbus-1.0 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/dbus-1.0/dbus -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib/dbus-1.0/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/gstreamer-0.10 -I/usr/local/Graphics_SDK_4_08_00_02/targetfs/XSGX/include -o hwcap_test.o hwcap_test.cpp
    hwcap_test.cpp:43:5: warning: unused parameter 'argc'
    hwcap_test.cpp:43:5: warning: unused parameter 'argv'
    /usr/local/ti-sdk-am335x-evm/linux-devkit/bin/arm-arago-linux-gnueabi-g++ -Wl,-O1 -o javascriptcore-jit hwcap_test.o   -L/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/lib -L/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib -L/usr/local/ti-sdk-am335x-evm/filesystem/opt/qt/lib -lxml2 -lz -lts -lasound -lfreetype -lexpat -lgstreamer-0.10 -ldbus-1 -lglib-2.0 -lgthread-2.0 -lfontconfig -lpng -lpthread -Wl,-rpath-link=/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/lib -Wl,-rpath-link=/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib -Wl,-rpath-link=/usr/local/ti-sdk-am335x-evm/filesystem/opt/qt/lib
    javascriptcore-jit enabled.
    /opt/qt-everywhere-opensource-src-5.0.1/qtbase/configure: 5572: /opt/qt-everywhere-opensource-src-5.0.1/qtbase/configure: -g++: not found
    Testing size of pointers ... (/opt/qt-everywhere-opensource-src-5.0.1/qtbase/mkspecs/linux-arm-gnueabi-ti-g++ yes /opt/qt-everywhere-opensource-src-5.0.1/qtbase /opt/qt-everywhere-opensource-src-5.0.1/qtbase)
    rm -f ptrsizetest.o
    rm -f *~ core *.core
    /usr/local/ti-sdk-am335x-evm/linux-devkit/bin/arm-arago-linux-gnueabi-g++ -c -pipe -Os -march=armv7-a -mfpu=neon -mfloat-abi=softfp -Wall -W -fPIE  -I../../../mkspecs/linux-arm-gnueabi-ti-g++ -I. -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/glib-2.0 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib/glib-2.0/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/libxml2 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/freetype2 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/dbus-1.0 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/dbus-1.0/dbus -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib/dbus-1.0/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/gstreamer-0.10 -I/usr/local/Graphics_SDK_4_08_00_02/targetfs/XSGX/include -o ptrsizetest.o ptrsizetest.cpp
    ptrsizetest.cpp: In function 'int main(int, char**)':
    ptrsizetest.cpp:59:12: error: 'PointerSize' is not a member of 'QPointerSizeTest<4>'
    make: *** [ptrsizetest.o] Error 1
    Pointer size: 4
    Building on:   linux-g++
    Building for:  linux-arm-gnueabi-ti-g++
    Architecture:  arm, features:
    Host architecture: i386, features:
    qmake vars .......... styles += mac fusion windows QT_CFLAGS_DBUS =  QT_LIBS_DBUS =  QT_CFLAGS_GLIB =  QT_LIBS_GLIB =  QT_CFLAGS_GSTREAMER =  QT_LIBS_GSTREAMER =  QMAKE_CFLAGS_FONTCONFIG =  QMAKE_LIBS_FONTCONFIG = -lfreetype -lfontconfig DEFINES += QT_NO_XCB PRECOMPILED_DIR = .pch/release-shared OBJECTS_DIR = .obj/release-shared MOC_DIR = .moc/release-shared RCC_DIR = .rcc/release-shared UI_DIR = .uic/release-shared sql-drivers =  sql-plugins =  sqlite qmake switches .........
    Build .................. libs examples
    Configuration ..........  cross_compile qpa largefile neon pcre  minimal-config small-config medium-config large-config full-config fontconfig libudev evdev linuxfb c++11 accessibility egl eglfs opengl opengles2 shared qpa clock-gettime clock-monotonic mremap getaddrinfo ipv6ifname getifaddrs inotify png system-freetype system-zlib nis iconv glib gstreamer dbus openssl rpath alsa concurrent audio-backend v8 v8snapshot release
    Debug .................. no
    C++11 support .......... yes
    pkg-config ............. yes
    QtDBus module .......... yes (run-time)
    QtConcurrent code ...... yes
    QtGui module ........... yes
    QtWidgets module ....... yes
    JavaScriptCore JIT ..... To be decided by JavaScriptCore
    QML debugging .......... yes
    PCH support ............ no
    iWMMXt support ......... no
    NEON support ........... yes
    IPv6 ifname support .... yes
    getaddrinfo support .... yes
    getifaddrs support ..... yes
    Accessibility .......... yes
    NIS support ............ yes
    CUPS support ........... no
    Iconv support .......... yes
    Glib support ........... yes
    GStreamer support ...... yes
    PulseAudio support ..... no
    Large File support ..... yes
    GIF support ............ plugin
    JPEG support ........... plugin (qt)
    PNG support ............ yes (qt)
    zlib support ........... system
    Session management ..... auto
    libudev support ........ yes
    Use system proxies ..... no
    OpenGL support ......... yes (OpenGL ES 2.x)
    OpenVG support ......... no
    XShape support ......... auto
    XVideo support ......... auto
    XSync support .......... auto
    Xinerama support ....... runtime
    Xcursor support ........ runtime
    Xfixes support ......... runtime
    Xrandr support ......... runtime
    Xi support ............. runtime
    Xi2 support ............ auto
    MIT-SHM support ........ auto
    FontConfig support ..... yes
    XKB Support ............ auto
    GTK theme support ...... no
    SQLite support ......... plugin (qt)
    OpenSSL support ........ yes (run-time)
    Alsa support ........... yes
    libICU support ......... no
    PCRE support ........... qt
    Xcb support ............ no
    Xrender support ........ no
    EGLFS support .......... yes
    DirectFB support ....... no
    LinuxFB support ........ yes
    KMS support ............ no
    Qt is now configured for building. Just run 'make'.
    Once everything is built, you must run 'make install'.
    Qt will be installed into /opt/3_jul_install/
    To reconfigure, run 'make confclean' and 'configure'.
    + /opt/qt-everywhere-opensource-src-5.0.1/qtbase/bin/qmake /opt/qt-everywhere-opensource-src-5.0.1/qtsdk.pro
    Project WARNING: qmake spec does not announce the compiler family. Guessed gcc.
    Project MESSAGE: WebKit: Qt was built without ICU support, WebKit disabled.
    /opt/qt-everywhere-opensource-src-5.0.1/qtbase/mkspecs/features/qt_docs_targets.prf:31: 'prepareRecursiveTarget' is not a recognized test function.
    root@tejbir:/opt/qt-everywhere-opensource-src-5.0.1#
    Here host architecture shown is i386
    but when i do
    uname -m -- i686
    uname -a -- Linux tejbir 3.2.0-39-generic-pae #62-Ubuntu SMP Wed Feb 27 22:25:11 UTC 2013 i686 i686 i386 GNU/Linux
    After this when ido make then output is 7776.make_output.pdf
    So,I dont know what I am doing wrong and help me out what to do next.
    Tej
  • Qt needs host toolchain also (in addition to cross toolchain) - Please install gcc on the host machine, ensure "g++ not found" goes away.
  • But Sir gcc-4.7 already installed
    root@tejbir:/opt/qt-everywhere-opensource-src-5.0.1# gcc -v
    Using built-in specs.
    COLLECT_GCC=gcc
    COLLECT_LTO_WRAPPER=/usr/lib/gcc/i686-linux-gnu/4.7/lto-wrapper
    Target: i686-linux-gnu
    Configured with: ../src/configure -v --with-pkgversion='Ubuntu/Linaro 4.7.3-2ubuntu1~12.04' --with-bugurl=file:///usr/share/doc/gcc-4.7/README.Bugs --enable-languages=c,c++,go,fortran,objc,obj-c++ --prefix=/usr --program-suffix=-4.7 --enable-shared --enable-linker-build-id --libexecdir=/usr/lib --without-included-gettext --enable-threads=posix --with-gxx-include-dir=/usr/include/c++/4.7 --libdir=/usr/lib --enable-nls --with-sysroot=/ --enable-clocale=gnu --enable-libstdcxx-debug --enable-libstdcxx-time=yes --enable-gnu-unique-object --enable-plugin --with-system-zlib --enable-objc-gc --enable-targets=all --enable-multiarch --disable-werror --with-arch-32=i686 --with-multilib-list=m32,m64 --with-tune=generic --enable-checking=release --build=i686-linux-gnu --host=i686-linux-gnu --target=i686-linux-gnu
    Thread model: posix
    gcc version 4.7.3 (Ubuntu/Linaro 4.7.3-2ubuntu1~12.04)
  • hi  Prabindh
    this is the log for qt5.1-alpha
    root@tejbir:/opt/qt5.1_alpha/qt-everywhere-opensource-src-5.1.0-alpha# make -j 4
    cd qtbase/ && ( test -e Makefile || /opt/qt5.1_alpha/qt-everywhere-opensource-src-5.1.0-alpha/qtbase/bin/qmake /opt/qt5.1_alpha/qt-everywhere-opensource-src-5.1.0-alpha/qtbase/qtbase.pro -o Makefile ) && make -f Makefile
    make[1]: Entering directory `/opt/qt5.1_alpha/qt-everywhere-opensource-src-5.1.0-alpha/qtbase'
    cd src/ && ( test -e Makefile || /opt/qt5.1_alpha/qt-everywhere-opensource-src-5.1.0-alpha/qtbase/bin/qmake /opt/qt5.1_alpha/qt-everywhere-opensource-src-5.1.0-alpha/qtbase/src/src.pro -o Makefile ) && make -f Makefile
    make[2]: Entering directory `/opt/qt5.1_alpha/qt-everywhere-opensource-src-5.1.0-alpha/qtbase/src'
    cd tools/bootstrap/ && ( test -e Makefile || /opt/qt5.1_alpha/qt-everywhere-opensource-src-5.1.0-alpha/qtbase/bin/qmake /opt/qt5.1_alpha/qt-everywhere-opensource-src-5.1.0-alpha/qtbase/src/tools/bootstrap/bootstrap.pro -o Makefile ) && make -f Makefile
    make[3]: Entering directory `/opt/qt5.1_alpha/qt-everywhere-opensource-src-5.1.0-alpha/qtbase/src/tools/bootstrap'
    make[3]: Nothing to be done for `first'.
    make[3]: Leaving directory `/opt/qt5.1_alpha/qt-everywhere-opensource-src-5.1.0-alpha/qtbase/src/tools/bootstrap'
    cd tools/moc/ && ( test -e Makefile || /opt/qt5.1_alpha/qt-everywhere-opensource-src-5.1.0-alpha/qtbase/bin/qmake /opt/qt5.1_alpha/qt-everywhere-opensource-src-5.1.0-alpha/qtbase/src/tools/moc/moc.pro -o Makefile ) && make -f Makefile
    cd tools/rcc/ && ( test -e Makefile || /opt/qt5.1_alpha/qt-everywhere-opensource-src-5.1.0-alpha/qtbase/bin/qmake /opt/qt5.1_alpha/qt-everywhere-opensource-src-5.1.0-alpha/qtbase/src/tools/rcc/rcc.pro -o Makefile ) && make -f Makefile
    cd tools/uic/ && ( test -e Makefile || /opt/qt5.1_alpha/qt-everywhere-opensource-src-5.1.0-alpha/qtbase/bin/qmake /opt/qt5.1_alpha/qt-everywhere-opensource-src-5.1.0-alpha/qtbase/src/tools/uic/uic.pro -o Makefile ) && make -f Makefile
    cd tools/qdoc/ && ( test -e Makefile || /opt/qt5.1_alpha/qt-everywhere-opensource-src-5.1.0-alpha/qtbase/bin/qmake /opt/qt5.1_alpha/qt-everywhere-opensource-src-5.1.0-alpha/qtbase/src/tools/qdoc/qdoc.pro -o Makefile ) && make -f Makefile
    make[3]: Entering directory `/opt/qt5.1_alpha/qt-everywhere-opensource-src-5.1.0-alpha/qtbase/src/tools/moc'
    make[3]: Leaving directory `/opt/qt5.1_alpha/qt-everywhere-opensource-src-5.1.0-alpha/qtbase/src/tools/moc'
    make[3]: Entering directory `/opt/qt5.1_alpha/qt-everywhere-opensource-src-5.1.0-alpha/qtbase/src/tools/rcc'
    make[3]: Leaving directory `/opt/qt5.1_alpha/qt-everywhere-opensource-src-5.1.0-alpha/qtbase/src/tools/rcc'
    make[3]: Entering directory `/opt/qt5.1_alpha/qt-everywhere-opensource-src-5.1.0-alpha/qtbase/src/tools/uic'
    make[3]: Leaving directory `/opt/qt5.1_alpha/qt-everywhere-opensource-src-5.1.0-alpha/qtbase/src/tools/uic'
    cd corelib/ && ( test -e Makefile || /opt/qt5.1_alpha/qt-everywhere-opensource-src-5.1.0-alpha/qtbase/bin/qmake /opt/qt5.1_alpha/qt-everywhere-opensource-src-5.1.0-alpha/qtbase/src/corelib/corelib.pro -o Makefile ) && make -f Makefile
    make[3]: Entering directory `/opt/qt5.1_alpha/qt-everywhere-opensource-src-5.1.0-alpha/qtbase/src/tools/qdoc'
    make[3]: Leaving directory `/opt/qt5.1_alpha/qt-everywhere-opensource-src-5.1.0-alpha/qtbase/src/tools/qdoc'
    make[3]: Entering directory `/opt/qt5.1_alpha/qt-everywhere-opensource-src-5.1.0-alpha/qtbase/src/corelib'
    make[3]: Leaving directory `/opt/qt5.1_alpha/qt-everywhere-opensource-src-5.1.0-alpha/qtbase/src/corelib'
    cd network/ && ( test -e Makefile || /opt/qt5.1_alpha/qt-everywhere-opensource-src-5.1.0-alpha/qtbase/bin/qmake /opt/qt5.1_alpha/qt-everywhere-opensource-src-5.1.0-alpha/qtbase/src/network/network.pro -o Makefile ) && make -f Makefile
    cd sql/ && ( test -e Makefile || /opt/qt5.1_alpha/qt-everywhere-opensource-src-5.1.0-alpha/qtbase/bin/qmake /opt/qt5.1_alpha/qt-everywhere-opensource-src-5.1.0-alpha/qtbase/src/sql/sql.pro -o Makefile ) && make -f Makefile
    cd xml/ && ( test -e Makefile || /opt/qt5.1_alpha/qt-everywhere-opensource-src-5.1.0-alpha/qtbase/bin/qmake /opt/qt5.1_alpha/qt-everywhere-opensource-src-5.1.0-alpha/qtbase/src/xml/xml.pro -o Makefile ) && make -f Makefile
    cd testlib/ && ( test -e Makefile || /opt/qt5.1_alpha/qt-everywhere-opensource-src-5.1.0-alpha/qtbase/bin/qmake /opt/qt5.1_alpha/qt-everywhere-opensource-src-5.1.0-alpha/qtbase/src/testlib/testlib.pro -o Makefile ) && make -f Makefile
    make[3]: Entering directory `/opt/qt5.1_alpha/qt-everywhere-opensource-src-5.1.0-alpha/qtbase/src/sql'
    rm -f libQt5Sql.so.5.1.0 libQt5Sql.so libQt5Sql.so.5 libQt5Sql.so.5.1
    make[3]: Entering directory `/opt/qt5.1_alpha/qt-everywhere-opensource-src-5.1.0-alpha/qtbase/src/xml'
    make[3]: Leaving directory `/opt/qt5.1_alpha/qt-everywhere-opensource-src-5.1.0-alpha/qtbase/src/xml'
    cd concurrent/ && ( test -e Makefile || /opt/qt5.1_alpha/qt-everywhere-opensource-src-5.1.0-alpha/qtbase/bin/qmake /opt/qt5.1_alpha/qt-everywhere-opensource-src-5.1.0-alpha/qtbase/src/concurrent/concurrent.pro -o Makefile ) && make -f Makefile
    /usr/local/ti-sdk-am335x-evm/linux-devkit/bin/arm-arago-linux-gnueabi-g++ --sysroot=/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi -Wl,--no-undefined -Wl,-O1 -Wl,-rpath,/opt/3_jul_install/lib -shared -Wl,-soname,libQt5Sql.so.5 -o libQt5Sql.so.5.1.0 .obj/release-shared/qsqlquery.o .obj/release-shared/qsqldatabase.o .obj/release-shared/qsqlfield.o .obj/release-shared/qsqlrecord.o .obj/release-shared/qsqldriver.o .obj/release-shared/qsqldriverplugin.o .obj/release-shared/qsqlerror.o .obj/release-shared/qsqlresult.o .obj/release-shared/qsqlindex.o .obj/release-shared/qsqlcachedresult.o .obj/release-shared/qsqlquerymodel.o .obj/release-shared/qsqltablemodel.o .obj/release-shared/qsqlrelationaldelegate.o .obj/release-shared/qsqlrelationaltablemodel.o .obj/release-shared/moc_qsqldriver.o .obj/release-shared/moc_qsqldriverplugin.o .obj/release-shared/moc_qsqlquerymodel.o .obj/release-shared/moc_qsqltablemodel.o .obj/release-shared/moc_qsqlrelationaltablemodel.o  -L/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/lib -L/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib -L/opt/3_july_qt_arm/qt-everywhere-opensource-src-5.0.1/qtbase/lib -Wl,-rpath-link=/opt/3_july_qt_arm/htouch_rfs_devel/usr/lib/arm-linux-gnueabi -Wl,-rpath-link=/opt/3_july_qt_arm/htouch_rfs_devel/usr/lib -L/opt/qt5.1_alpha/qt-everywhere-opensource-src-5.1.0-alpha/qtbase/lib -lQt5Core -lxml2 -lts -lasound -lfreetype -lexpat -lfontconfig -lpng -Wl,-rpath-link=/opt/3_july_qt_arm/htouch_rfs_devel/usr/lib/arm-linux-gnueabi -Wl,-rpath-link=/opt/3_july_qt_arm/htouch_rfs_devel/usr/lib -lz -lpthread
    make[3]: Entering directory `/opt/qt5.1_alpha/qt-everywhere-opensource-src-5.1.0-alpha/qtbase/src/testlib'
    /usr/local/ti-sdk-am335x-evm/linux-devkit/bin/arm-arago-linux-gnueabi-g++ -c -pipe --sysroot=/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi -O3 -march=armv7-a -mfpu=neon -mfloat-abi=softfp -std=c++0x -Wall -W -D_REENTRANT -fPIC -DQT_NO_XCB -DQT_NO_CAST_TO_ASCII -DQT_NO_CAST_FROM_ASCII -DQT_NO_DATASTREAM -DQT_BUILD_TESTLIB_LIB -DQT_BUILDING_QT -DQT_ASCII_CAST_WARNINGS -DQT_MOC_COMPAT -DQT_USE_QSTRINGBUILDER -DQT_DEPRECATED_WARNINGS -DQT_DISABLE_DEPRECATED_BEFORE=0x050000 -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE -DQT_NO_DEBUG -DQT_CORE_LIB -I../../mkspecs/linux-arm-gnueabi-ti-g++ -I. -I../../include -I../../include/QtTest -I../../include/QtTest/5.1.0 -I../../include/QtTest/5.1.0/QtTest -I../../include/QtCore -I../../include/QtCore/5.1.0 -I../../include/QtCore/5.1.0/QtCore -I.moc/release-shared -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/glib-2.0 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib/glib-2.0/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/libxml2 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/freetype2 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/dbus-1.0 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/dbus-1.0/dbus -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib/dbus-1.0/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/gstreamer-0.10 -I/usr/local/Graphics_SDK_4_08_00_02/targetfs/XSGX/include -o .obj/release-shared/qbenchmarkperfevents.o qbenchmarkperfevents.cpp
    make[3]: Entering directory `/opt/qt5.1_alpha/qt-everywhere-opensource-src-5.1.0-alpha/qtbase/src/network'
    rm -f libQt5Network.so.5.1.0 libQt5Network.so libQt5Network.so.5 libQt5Network.so.5.1
    /usr/local/ti-sdk-am335x-evm/linux-devkit/bin/arm-arago-linux-gnueabi-g++ --sysroot=/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi -Wl,--no-undefined -Wl,-O1 -Wl,-rpath,/opt/3_jul_install/lib -shared -Wl,-soname,libQt5Network.so.5 -o libQt5Network.so.5.1.0 .obj/release-shared/qftp.o .obj/release-shared/qhttpnetworkheader.o .obj/release-shared/qhttpnetworkrequest.o .obj/release-shared/qhttpnetworkreply.o .obj/release-shared/qhttpnetworkconnection.o .obj/release-shared/qhttpnetworkconnectionchannel.o .obj/release-shared/qnetworkaccessauthenticationmanager.o .obj/release-shared/qnetworkaccessmanager.o .obj/release-shared/qnetworkaccesscache.o .obj/release-shared/qnetworkaccessbackend.o .obj/release-shared/qnetworkaccessdebugpipebackend.o .obj/release-shared/qnetworkaccessfilebackend.o .obj/release-shared/qnetworkaccesscachebackend.o .obj/release-shared/qnetworkaccessftpbackend.o .obj/release-shared/qnetworkcookie.o .obj/release-shared/qnetworkcookiejar.o .obj/release-shared/qnetworkrequest.o .obj/release-shared/qnetworkreply.o .obj/release-shared/qnetworkreplyimpl.o .obj/release-shared/qnetworkreplydataimpl.o .obj/release-shared/qnetworkreplyhttpimpl.o .obj/release-shared/qnetworkreplyfileimpl.o .obj/release-shared/qabstractnetworkcache.o .obj/release-shared/qnetworkdiskcache.o .obj/release-shared/qhttpthreaddelegate.o .obj/release-shared/qhttpmultipart.o .obj/release-shared/qnetworksession.o .obj/release-shared/qnetworkconfigmanager.o .obj/release-shared/qnetworkconfiguration.o .obj/release-shared/qnetworkconfigmanager_p.o .obj/release-shared/qbearerengine.o .obj/release-shared/qbearerplugin.o .obj/release-shared/qsharednetworksession.o .obj/release-shared/qauthenticator.o .obj/release-shared/qdnslookup.o .obj/release-shared/qhostaddress.o .obj/release-shared/qhostinfo.o .obj/release-shared/qurlinfo.o .obj/release-shared/qnetworkproxy.o .obj/release-shared/qnetworkinterface.o .obj/release-shared/qdnslookup_unix.o .obj/release-shared/qhostinfo_unix.o .obj/release-shared/qnetworkinterface_unix.o .obj/release-shared/qnetworkproxy_generic.o .obj/release-shared/qabstractsocketengine.o .obj/release-shared/qhttpsocketengine.o .obj/release-shared/qsocks5socketengine.o .obj/release-shared/qabstractsocket.o .obj/release-shared/qtcpsocket.o .obj/release-shared/qudpsocket.o .obj/release-shared/qtcpserver.o .obj/release-shared/qlocalsocket.o .obj/release-shared/qlocalserver.o .obj/release-shared/qnativesocketengine.o .obj/release-shared/qnativesocketengine_unix.o .obj/release-shared/qlocalsocket_unix.o .obj/release-shared/qlocalserver_unix.o .obj/release-shared/qssl.o .obj/release-shared/qsslcertificate.o .obj/release-shared/qsslconfiguration.o .obj/release-shared/qsslcipher.o .obj/release-shared/qsslerror.o .obj/release-shared/qsslkey.o .obj/release-shared/qsslsocket.o .obj/release-shared/qsslsocket_openssl.o .obj/release-shared/qsslsocket_openssl_symbols.o .obj/release-shared/qsslcertificateextension.o .obj/release-shared/qsslcontext.o .obj/release-shared/moc_qhttpnetworkreply_p.o .obj/release-shared/moc_qnetworkaccesscache_p.o .obj/release-shared/moc_qnetworkaccessbackend_p.o .obj/release-shared/moc_qnetworkaccessdebugpipebackend_p.o .obj/release-shared/moc_qnetworkaccessfilebackend_p.o .obj/release-shared/moc_qnetworkaccessftpbackend_p.o .obj/release-shared/moc_qnetworkcookiejar.o .obj/release-shared/moc_qnetworkreply.o .obj/release-shared/moc_qnetworkreplyhttpimpl_p.o .obj/release-shared/moc_qabstractnetworkcache.o .obj/release-shared/moc_qnetworkdiskcache.o .obj/release-shared/moc_qhttpthreaddelegate_p.o .obj/release-shared/moc_qhttpmultipart.o .obj/release-shared/moc_qnetworkconfigmanager_p.o .obj/release-shared/moc_qnetworksession_p.o .obj/release-shared/moc_qbearerplugin_p.o .obj/release-shared/moc_qdnslookup_p.o .obj/release-shared/moc_qhostinfo_p.o .obj/release-shared/moc_qabstractsocketengine_p.o .obj/release-shared/moc_qhttpsocketengine_p.o .obj/release-shared/moc_qsocks5socketengine_p.o .obj/release-shared/moc_qtcpsocket.o .obj/release-shared/moc_qudpsocket.o .obj/release-shared/moc_qnativesocketengine_p.o .obj/release-shared/moc_qsslsocket_openssl_p.o  -L/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/lib -L/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib -L/opt/3_july_qt_arm/qt-everywhere-opensource-src-5.0.1/qtbase/lib -Wl,-rpath-link=/opt/3_july_qt_arm/htouch_rfs_devel/usr/lib/arm-linux-gnueabi -Wl,-rpath-link=/opt/3_july_qt_arm/htouch_rfs_devel/usr/lib -L/opt/qt5.1_alpha/qt-everywhere-opensource-src-5.1.0-alpha/qtbase/lib -lQt5Core -lxml2 -lts -lasound -lfreetype -lexpat -lfontconfig -lpng -Wl,-rpath-link=/opt/3_july_qt_arm/htouch_rfs_devel/usr/lib/arm-linux-gnueabi -Wl,-rpath-link=/opt/3_july_qt_arm/htouch_rfs_devel/usr/lib -lz -lpthread -lz
    make[3]: Entering directory `/opt/qt5.1_alpha/qt-everywhere-opensource-src-5.1.0-alpha/qtbase/src/concurrent'
    make[3]: Leaving directory `/opt/qt5.1_alpha/qt-everywhere-opensource-src-5.1.0-alpha/qtbase/src/concurrent'
    cd gui/ && ( test -e Makefile || /opt/qt5.1_alpha/qt-everywhere-opensource-src-5.1.0-alpha/qtbase/bin/qmake /opt/qt5.1_alpha/qt-everywhere-opensource-src-5.1.0-alpha/qtbase/src/gui/gui.pro -o Makefile ) && make -f Makefile
    .obj/release-shared/qsqltablemodel.o: In function `QSqlTableModel::flags(QModelIndex const&) const':
    qsqltablemodel.cpp:(.text+0x3a50): undefined reference to `QAbstractTableModel::flags(QModelIndex const&) const'
    qsqltablemodel.cpp:(.text+0x3bc4): undefined reference to `QAbstractTableModel::flags(QModelIndex const&) const'
    .obj/release-shared/moc_qsqlquerymodel.o:(.data.rel.ro+0xb8): undefined reference to `QAbstractTableModel::flags(QModelIndex const&) const'
    collect2: ld returned 1 exit status
    make[3]: *** [../../lib/libQt5Sql.so.5.1.0] Error 1
    make[3]: Leaving directory `/opt/qt5.1_alpha/qt-everywhere-opensource-src-5.1.0-alpha/qtbase/src/sql'
    make[2]: *** [sub-sql-make_first] Error 2
    make[2]: *** Waiting for unfinished jobs....
    /usr/local/ti-sdk-am335x-evm/linux-devkit/bin/arm-arago-linux-gnueabi-g++ -c -pipe --sysroot=/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi -O3 -march=armv7-a -mfpu=neon -mfloat-abi=softfp -std=c++0x -Wall -W -D_REENTRANT -fPIC -DQT_NO_XCB -DQT_NO_CAST_TO_ASCII -DQT_NO_CAST_FROM_ASCII -DQT_NO_DATASTREAM -DQT_BUILD_TESTLIB_LIB -DQT_BUILDING_QT -DQT_ASCII_CAST_WARNINGS -DQT_MOC_COMPAT -DQT_USE_QSTRINGBUILDER -DQT_DEPRECATED_WARNINGS -DQT_DISABLE_DEPRECATED_BEFORE=0x050000 -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE -DQT_NO_DEBUG -DQT_CORE_LIB -I../../mkspecs/linux-arm-gnueabi-ti-g++ -I. -I../../include -I../../include/QtTest -I../../include/QtTest/5.1.0 -I../../include/QtTest/5.1.0/QtTest -I../../include/QtCore -I../../include/QtCore/5.1.0 -I../../include/QtCore/5.1.0/QtCore -I.moc/release-shared -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/glib-2.0 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib/glib-2.0/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/libxml2 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/freetype2 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/dbus-1.0 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/dbus-1.0/dbus -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib/dbus-1.0/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/gstreamer-0.10 -I/usr/local/Graphics_SDK_4_08_00_02/targetfs/XSGX/include -o .obj/release-shared/qtestelement.o qtestelement.cpp
    make[3]: Entering directory `/opt/qt5.1_alpha/qt-everywhere-opensource-src-5.1.0-alpha/qtbase/src/gui'
    rm -f libQt5Gui.so.5.1.0 libQt5Gui.so libQt5Gui.so.5 libQt5Gui.so.5.1
    /usr/local/ti-sdk-am335x-evm/linux-devkit/bin/arm-arago-linux-gnueabi-g++ --sysroot=/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi -Wl,--no-undefined -Wl,-O1 -Wl,-rpath,/opt/3_jul_install/lib -shared -Wl,-soname,libQt5Gui.so.5 -o libQt5Gui.so.5.1.0 .obj/release-shared/qimage_neon.o .obj/release-shared/qdrawhelper_neon.o .obj/release-shared/qaccessible.o .obj/release-shared/qaccessible2.o .obj/release-shared/qaccessibleobject.o .obj/release-shared/qaccessibleplugin.o .obj/release-shared/qplatformaccessibility.o .obj/release-shared/qaccessiblebridge.o .obj/release-shared/qclipboard_qpa.o .obj/release-shared/qcursor_qpa.o .obj/release-shared/qgenericpluginfactory.o .obj/release-shared/qgenericplugin.o .obj/release-shared/qwindowsysteminterface.o .obj/release-shared/qplatforminputcontextfactory.o .obj/release-shared/qplatforminputcontextplugin.o .obj/release-shared/qplatforminputcontext.o .obj/release-shared/qplatformintegration.o .obj/release-shared/qplatformdrag.o .obj/release-shared/qplatformscreen.o .obj/release-shared/qplatformintegrationfactory.o .obj/release-shared/qplatformintegrationplugin.o .obj/release-shared/qplatformtheme.o .obj/release-shared/qplatformthemefactory.o .obj/release-shared/qplatformthemeplugin.o .obj/release-shared/qplatformwindow.o .obj/release-shared/qplatformoffscreensurface.o .obj/release-shared/qplatformcursor.o .obj/release-shared/qplatformclipboard.o .obj/release-shared/qplatformnativeinterface.o .obj/release-shared/qsessionmanager.o .obj/release-shared/qsurfaceformat.o .obj/release-shared/qguiapplication.o .obj/release-shared/qwindow.o .obj/release-shared/qoffscreensurface.o .obj/release-shared/qplatformsurface.o .obj/release-shared/qsurface.o .obj/release-shared/qclipboard.o .obj/release-shared/qcursor.o .obj/release-shared/qdrag.o .obj/release-shared/qdnd.o .obj/release-shared/qevent.o .obj/release-shared/qinputmethod.o .obj/release-shared/qkeysequence.o .obj/release-shared/qkeymapper.o .obj/release-shared/qkeymapper_qpa.o .obj/release-shared/qpalette.o .obj/release-shared/qguivariant.o .obj/release-shared/qscreen.o .obj/release-shared/qshortcutmap.o .obj/release-shared/qstylehints.o .obj/release-shared/qtouchdevice.o .obj/release-shared/qplatformsharedgraphicscache.o .obj/release-shared/qplatformdialoghelper.o .obj/release-shared/qplatformservices.o .obj/release-shared/qplatformscreenpageflipper.o .obj/release-shared/qplatformsystemtrayicon_qpa.o .obj/release-shared/qplatformopenglcontext.o .obj/release-shared/qopenglcontext.o .obj/release-shared/qbitmap.o .obj/release-shared/qimage.o .obj/release-shared/qimageiohandler.o .obj/release-shared/qimagereader.o .obj/release-shared/qimagewriter.o .obj/release-shared/qpaintengine_pic.o .obj/release-shared/qpicture.o .obj/release-shared/qpictureformatplugin.o .obj/release-shared/qpixmap.o .obj/release-shared/qpixmapcache.o .obj/release-shared/qplatformpixmap.o .obj/release-shared/qmovie.o .obj/release-shared/qpixmap_raster.o .obj/release-shared/qpixmap_blitter.o .obj/release-shared/qnativeimage.o .obj/release-shared/qimagepixmapcleanuphooks.o .obj/release-shared/qicon.o .obj/release-shared/qiconloader.o .obj/release-shared/qiconengine.o .obj/release-shared/qiconengineplugin.o .obj/release-shared/qbmphandler.o .obj/release-shared/qppmhandler.o .obj/release-shared/qxbmhandler.o .obj/release-shared/qxpmhandler.o .obj/release-shared/qpnghandler.o .obj/release-shared/png.o .obj/release-shared/pngerror.o .obj/release-shared/pngget.o .obj/release-shared/pngmem.o .obj/release-shared/pngpread.o .obj/release-shared/pngread.o .obj/release-shared/pngrio.o .obj/release-shared/pngrtran.o .obj/release-shared/pngrutil.o .obj/release-shared/pngset.o .obj/release-shared/pngtrans.o .obj/release-shared/pngwio.o .obj/release-shared/pngwrite.o .obj/release-shared/pngwtran.o .obj/release-shared/pngwutil.o .obj/release-shared/qfont.o .obj/release-shared/qfontengine.o .obj/release-shared/qfontsubset.o .obj/release-shared/qfontmetrics.o .obj/release-shared/qfontdatabase.o .obj/release-shared/qtextengine.o .obj/release-shared/qtextlayout.o .obj/release-shared/qtextformat.o .obj/release-shared/qtextobject.o .obj/release-shared/qtextoption.o .obj/release-shared/qfragmentmap.o .obj/release-shared/qtextdocument.o .obj/release-shared/qtextdocument_p.o .obj/release-shared/qtexthtmlparser.o .obj/release-shared/qabstracttextdocumentlayout.o .obj/release-shared/qtextdocumentlayout.o .obj/release-shared/qtextcursor.o .obj/release-shared/qtextdocumentfragment.o .obj/release-shared/qtextimagehandler.o .obj/release-shared/qtexttable.o .obj/release-shared/qtextlist.o .obj/release-shared/qtextdocumentwriter.o .obj/release-shared/qsyntaxhighlighter.o .obj/release-shared/qcssparser.o .obj/release-shared/qzip.o .obj/release-shared/qtextodfwriter.o .obj/release-shared/qstatictext.o .obj/release-shared/qrawfont.o .obj/release-shared/qglyphrun.o .obj/release-shared/qdistancefield.o .obj/release-shared/qfont_qpa.o .obj/release-shared/qfontengine_qpa.o .obj/release-shared/qplatformfontdatabase.o .obj/release-shared/qrawfont_qpa.o .obj/release-shared/qbackingstore.o .obj/release-shared/qbezier.o .obj/release-shared/qblendfunctions.o .obj/release-shared/qblittable.o .obj/release-shared/qbrush.o .obj/release-shared/qcolor.o .obj/release-shared/qcolor_p.o .obj/release-shared/qcosmeticstroker.o .obj/release-shared/qcssutil.o .obj/release-shared/qdrawhelper.o .obj/release-shared/qemulationpaintengine.o .obj/release-shared/qgammatables.o .obj/release-shared/qgrayraster.o .obj/release-shared/qimagescale.o .obj/release-shared/qmatrix.o .obj/release-shared/qmemrotate.o .obj/release-shared/qoutlinemapper.o .obj/release-shared/qpagedpaintdevice.o .obj/release-shared/qpaintdevice.o .obj/release-shared/qpaintengine.o .obj/release-shared/qpaintengineex.o .obj/release-shared/qpaintengine_blitter.o .obj/release-shared/qpaintengine_raster.o .obj/release-shared/qpainter.o .obj/release-shared/qpainterpath.o .obj/release-shared/qpathclipper.o .obj/release-shared/qpdf.o .obj/release-shared/qpdfwriter.o .obj/release-shared/qpen.o .obj/release-shared/qpolygon.o .obj/release-shared/qrasterizer.o .obj/release-shared/qregion.o .obj/release-shared/qstroker.o .obj/release-shared/qtextureglyphcache.o .obj/release-shared/qtransform.o .obj/release-shared/qplatformbackingstore.o .obj/release-shared/qpaintbuffer.o .obj/release-shared/qpathsimplifier.o .obj/release-shared/qdesktopservices.o .obj/release-shared/qvalidator.o .obj/release-shared/qgenericmatrix.o .obj/release-shared/qmatrix4x4.o .obj/release-shared/qquaternion.o .obj/release-shared/qvector2d.o .obj/release-shared/qvector3d.o .obj/release-shared/qvector4d.o .obj/release-shared/qopengl.o .obj/release-shared/qopenglfunctions.o .obj/release-shared/qopenglframebufferobject.o .obj/release-shared/qopenglpaintdevice.o .obj/release-shared/qopenglbuffer.o .obj/release-shared/qopenglshaderprogram.o .obj/release-shared/qopenglgradientcache.o .obj/release-shared/qopengltexturecache.o .obj/release-shared/qopenglengineshadermanager.o .obj/release-shared/qopengl2pexvertexarray.o .obj/release-shared/qopenglpaintengine.o .obj/release-shared/qopenglcustomshaderstage.o .obj/release-shared/qtriangulatingstroker.o .obj/release-shared/qopengltextureglyphcache.o .obj/release-shared/qtriangulator.o .obj/release-shared/qopenglversionfunctions.o .obj/release-shared/qopenglversionfunctionsfactory.o .obj/release-shared/qopenglvertexarrayobject.o .obj/release-shared/qopengldebug.o .obj/release-shared/qopenglfunctions_es2.o .obj/release-shared/qguivariantanimation.o .obj/release-shared/qstandarditemmodel.o .obj/release-shared/pixman-arm-neon-asm.o .obj/release-shared/qdrawhelper_neon_asm.o .obj/release-shared/moc_qaccessible.o .obj/release-shared/moc_qaccessibleplugin.o .obj/release-shared/moc_qaccessiblebridge.o .obj/release-shared/moc_qgenericplugin.o .obj/release-shared/moc_qplatforminputcontext.o .obj/release-shared/moc_qplatforminputcontextplugin_p.o .obj/release-shared/moc_qplatformintegrationplugin.o .obj/release-shared/moc_qplatformthemeplugin.o .obj/release-shared/moc_qplatformnativeinterface.o .obj/release-shared/moc_qplatformmenu.o .obj/release-shared/moc_qwindow.o .obj/release-shared/moc_qoffscreensurface.o .obj/release-shared/moc_qclipboard.o .obj/release-shared/moc_qdrag.o .obj/release-shared/moc_qdnd_p.o .obj/release-shared/moc_qkeymapper_p.o .obj/release-shared/moc_qpalette.o .obj/release-shared/moc_qsessionmanager.o .obj/release-shared/moc_qscreen.o .obj/release-shared/moc_qstylehints.o .obj/release-shared/moc_qplatformsharedgraphicscache.o .obj/release-shared/moc_qplatformdialoghelper.o .obj/release-shared/moc_qplatformscreenpageflipper.o .obj/release-shared/moc_qopenglcontext.o .obj/release-shared/moc_qimageiohandler.o .obj/release-shared/moc_qpictureformatplugin.o .obj/release-shared/moc_qiconengineplugin.o .obj/release-shared/moc_qfont.o .obj/release-shared/moc_qfontdatabase.o .obj/release-shared/moc_qfontengine_p.o .obj/release-shared/moc_qtextformat.o .obj/release-shared/moc_qtextobject.o .obj/release-shared/moc_qtextdocument.o .obj/release-shared/moc_qtextimagehandler_p.o .obj/release-shared/moc_qtexttable.o .obj/release-shared/moc_qtextlist.o .obj/release-shared/moc_qbrush.o .obj/release-shared/moc_qpainter.o .obj/release-shared/moc_qpdfwriter.o .obj/release-shared/moc_qvalidator.o .obj/release-shared/moc_qopenglshaderprogram.o .obj/release-shared/moc_qopenglengineshadermanager_p.o .obj/release-shared/moc_qopenglvertexarrayobject.o  -L/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/lib -L/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib -L/opt/3_july_qt_arm/qt-everywhere-opensource-src-5.0.1/qtbase/lib -L/usr/local/Graphics_SDK_4_08_00_02/gfx_rel_es8.x -Wl,-rpath-link=/opt/3_july_qt_arm/htouch_rfs_devel/usr/lib/arm-linux-gnueabi -Wl,-rpath-link=/opt/3_july_qt_arm/htouch_rfs_devel/usr/lib -L/opt/qt5.1_alpha/qt-everywhere-opensource-src-5.1.0-alpha/qtbase/lib -lQt5Core -lxml2 -lts -lasound -lfreetype -lexpat -lfontconfig -lpng -Wl,-rpath-link=/opt/3_july_qt_arm/htouch_rfs_devel/usr/lib/arm-linux-gnueabi -Wl,-rpath-link=/opt/3_july_qt_arm/htouch_rfs_devel/usr/lib -lz -lpthread -lz -lEGL -lIMGegl -lsrv_um -lGLESv2 -lGLES_CM -lusc
    qbenchmarkperfevents.cpp: In function 'int perf_event_open(perf_event_attr*, pid_t, int, int, long unsigned int)':
    qbenchmarkperfevents.cpp:133:20: error: 'SYS_perf_event_open' was not declared in this scope
    .obj/release-shared/qnativesocketengine_unix.o: In function `QNativeSocketEnginePrivate::nativeSelect(int, bool) const':
    qnativesocketengine_unix.cpp:(.text+0x27e4): undefined reference to `qt_safe_select(int, fd_set*, fd_set*, fd_set*, timespec const*)'
    qnativesocketengine_unix.cpp:(.text+0x280c): undefined reference to `qt_safe_select(int, fd_set*, fd_set*, fd_set*, timespec const*)'
    .obj/release-shared/qnativesocketengine_unix.o: In function `QNativeSocketEnginePrivate::nativeSelect(int, bool, bool, bool*, bool*) const':
    qnativesocketengine_unix.cpp:(.text+0x2994): undefined reference to `qt_safe_select(int, fd_set*, fd_set*, fd_set*, timespec const*)'
    .obj/release-shared/qlocalserver_unix.o: In function `QLocalServerPrivate::waitForNewConnection(int, bool*)':
    qlocalserver_unix.cpp:(.text+0xa04): undefined reference to `qt_safe_select(int, fd_set*, fd_set*, fd_set*, timespec const*)'
    make[3]: *** [../../lib/libQt5Network.so.5.1.0] Error 1
    make[3]: Leaving directory `/opt/qt5.1_alpha/qt-everywhere-opensource-src-5.1.0-alpha/qtbase/src/network'
    make[2]: *** [sub-network-make_first] Error 2
    /usr/local/ti-sdk-am335x-evm/linux-devkit/bin/arm-arago-linux-gnueabi-g++ -c -pipe --sysroot=/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi -O3 -march=armv7-a -mfpu=neon -mfloat-abi=softfp -std=c++0x -Wall -W -D_REENTRANT -fPIC -DQT_NO_XCB -DQT_NO_CAST_TO_ASCII -DQT_NO_CAST_FROM_ASCII -DQT_NO_DATASTREAM -DQT_BUILD_TESTLIB_LIB -DQT_BUILDING_QT -DQT_ASCII_CAST_WARNINGS -DQT_MOC_COMPAT -DQT_USE_QSTRINGBUILDER -DQT_DEPRECATED_WARNINGS -DQT_DISABLE_DEPRECATED_BEFORE=0x050000 -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE -DQT_NO_DEBUG -DQT_CORE_LIB -I../../mkspecs/linux-arm-gnueabi-ti-g++ -I. -I../../include -I../../include/QtTest -I../../include/QtTest/5.1.0 -I../../include/QtTest/5.1.0/QtTest -I../../include/QtCore -I../../include/QtCore/5.1.0 -I../../include/QtCore/5.1.0/QtCore -I.moc/release-shared -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/glib-2.0 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib/glib-2.0/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/libxml2 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/freetype2 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/dbus-1.0 -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/dbus-1.0/dbus -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/lib/dbus-1.0/include -I/usr/local/ti-sdk-am335x-evm/linux-devkit/arm-arago-linux-gnueabi/usr/include/gstreamer-0.10 -I/usr/local/Graphics_SDK_4_08_00_02/targetfs/XSGX/include -o .obj/release-shared/qtestelementattribute.o qtestelementattribute.cpp
    qbenchmarkperfevents.cpp:134:1: warning: control reaches end of non-void function
    make[3]: *** [.obj/release-shared/qbenchmarkperfevents.o] Error 1
    make[3]: *** Waiting for unfinished jobs....
    make[3]: Leaving directory `/opt/qt5.1_alpha/qt-everywhere-opensource-src-5.1.0-alpha/qtbase/src/testlib'
    make[2]: *** [sub-testlib-make_first] Error 2
    .obj/release-shared/qfontmetrics.o: In function `QFontMetrics::inFont(QChar) const':
    qfontmetrics.cpp:(.text+0x634): undefined reference to `QChar::script(unsigned int)'
    .obj/release-shared/qfontmetrics.o: In function `QFontMetrics::inFontUcs4(unsigned int) const':
    qfontmetrics.cpp:(.text+0x694): undefined reference to `QChar::script(unsigned int)'
    .obj/release-shared/qfontmetrics.o: In function `QFontMetrics::leftBearing(QChar) const':
    qfontmetrics.cpp:(.text+0x730): undefined reference to `QChar::script(unsigned int)'
    .obj/release-shared/qfontmetrics.o: In function `QFontMetrics::rightBearing(QChar) const':
    qfontmetrics.cpp:(.text+0x900): undefined reference to `QChar::script(unsigned int)'
    .obj/release-shared/qfontmetrics.o: In function `QFontMetrics::width(QChar) const':
    qfontmetrics.cpp:(.text+0xf54): undefined reference to `QChar::script(unsigned int)'
    .obj/release-shared/qfontmetrics.o:qfontmetrics.cpp:(.text+0x10b4): more undefined references to `QChar::script(unsigned int)' follow
    .obj/release-shared/qtextengine.o: In function `QTextEngine::itemize() const':
    qtextengine.cpp:(.text+0x7754): undefined reference to `QUnicodeTools::initScripts(unsigned short const*, int, unsigned char*)'
    qtextengine.cpp:(.text+0x89d8): undefined reference to `QUnicodeTools::initScripts(unsigned short const*, int, unsigned char*)'
    make[3]: *** [../../lib/libQt5Gui.so.5.1.0] Error 1
    make[3]: Leaving directory `/opt/qt5.1_alpha/qt-everywhere-opensource-src-5.1.0-alpha/qtbase/src/gui'
    make[2]: *** [sub-gui-make_first] Error 2
    make[2]: Leaving directory `/opt/qt5.1_alpha/qt-everywhere-opensource-src-5.1.0-alpha/qtbase/src'
    make[1]: *** [sub-src-make_first] Error 2
    make[1]: Leaving directory `/opt/qt5.1_alpha/qt-everywhere-opensource-src-5.1.0-alpha/qtbase'
    make: *** [module-qtbase-make_first] Error 2
  • I too can confirm this issue too...
    following is the output log: http://pastebin.com/abFdYd4u
    Using this post as reference: http://tigraphics.blogspot.com/2013/01/qt-500-final-dec-2012-available-on-ti.html
    The configure command is:
    ./configure -prefix /home/devkit/qt5.1/opt/qt5.1 -release -make libs -device beaglebone -opengl es2 -confirm-license -opensource -icu -no-xcb -make examples -verbose
    Created a directory under mkspec/devices/linux-beaglebone-g++
    my qmake.conf is as follows: http://pastebin.com/1RjCS0ZD
    -Thanks
