Other Parts Discussed in Thread: LINUXEZSDK-SITARA
HI,
Does the AM389x uses DTS file to map the memory and interrupt?
If not how its mapped for AM389x?
Thanks in advance
Salih
HI,
Thanks in advance
Salih
Hi Salih,
No, AM389x device does not use/support DTS (Device Tree Source) file. The latest EZSDK for AM389X device is 5.04.00.11 (http://www.ti.com/tool/linuxezsdk-sitara -> http://software-dl.ti.com/dsps/dsps_public_sw/ezsdk/5_04_00_11/index_FDS.html). And this EZSDK is using 2.6.37 linux kernel version. While DTS is supported from 3.x version.
For example, AM335x device with kernel version 3.6 supports DTS: http://processors.wiki.ti.com/index.php/Sitara_Linux_Upstream_Status#AM335x_Linux_Status
Check also this wiki page for info regarding DTS: http://processors.wiki.ti.com/index.php/MCSDK_UG_Chapter_Developing_System_Mgmt
As this is the AM389x hardware forum, I would recommend you to double check this question in our Linux/Software forum: http://e2e.ti.com/support/embedded/linux/default.aspx
Pavel
