Other Parts Discussed in Thread: TVP7002
I'm using latest EZSDK 5.05.02.00 on DM816x EVM rev. G.? all by default.
i'm move /usr/share/ti/ti-media-controller-utils/load-hd-v4l2-firmware.sh to /etc/init.d/load-hd-firmware.sh
v4l2 and tvp7002 module load success.
FIRMWARE: 2 start Successful
VPSS_FVID2: M3 firmware version 0x1000145 is newer,driver may not work properly.
tvp7002 2-005d: tvp7002 found @ 0x5d (OMAP I2C adapter)
tvp7002 2-005d: Rev. 02 detected.
ti81xxvin ti81xxvin: registered sub device tvp7002
ti81xxvin ti81xxvin: TI81xx HDVPSS Capture driver initialized
HDMI W1 rev 2.0
HDMI CEC Spec version 1.2
Starting system message bus: dbus.
Starting telnet daemon.
Starting syslogd/klogd: done
Starting thttpd.
Starting PVR
Starting Matrix GUI application.
root@dm816x-evm:~# lsmod
Module Size Used by
ti81xxhdmi 17685 0
ti81xxvin 20388 0
tvp7002 6405 1
ti81xxvo 21210 0
ti81xxfb 21979 0
vpss 75009 4 ti81xxhdmi,ti81xxvin,ti81xxvo,ti81xxfb
syslink 1134279 0
ipv6 209855 12
And I get:
root@dm816x-evm:/usr/share/ti/ti-media-controller-utils# /etc/init.d/pvr-init st
op
Stopping PVR
root@dm816x-evm:/usr/share/ti/ti-media-controller-utils# /etc/init.d/matrix-gui-
e stop
Stopping Matrix GUI application.
root@dm816x-evm:/usr/share/ti/ti-media-controller-utils# gst-launch -e --gst-deb
ug=3 --verbose v4l2src device="/dev/video0" always-copy=false queue-size=12 num-
buffers=-1 ! 'video/x-raw-yuv-strided,format=(fourcc)NV12,width=1920,height=1080,f
ramerate=(fraction)60/1' ! omxbufferalloc silent=false numBuffers=12 ! omx_scale
r ! omx_ctrl display-mode=OMX_DC_MODE_1080P_60 ! omx_videosink sync=false
0:00:00.014394434 1487 0x16050 INFO GST_INIT gstquery.c:108:_gst_query_initialize: init queries
0:00:00.019086211 1487 0x16050 INFO GST_INIT gstmessage.c:73:_gst_message_initialize: init messages
0:00:00.020250104 1487 0x16050 INFO GST_PLUGIN_LOADING gstplugin.c:350:_gst_plugin_initialize: registering 0 static plugins
0:00:00.021045441 1487 0x16050 INFO GST_PLUGIN_LOADING gstplugin.c:255:gst_plugin_register_static: registered static plugin "staticelements"
0:00:00.021126515 1487 0x16050 INFO GST_PLUGIN_LOADING gstplugin.c:257:gst_plugin_register_static: added static plugin "staticelements", result: 1
0:00:00.027035277 1487 0x16050 INFO GST_REGISTRY gstregistry.c:1599:ensure_current_registry: reading registry cache: /home/root/.gstreamer-0.10/registry.arm.bin
0:00:00.126458412 1487 0x16050 INFO GST_REGISTRY gstregistrybinary.c:614:gst_registry_binary_read_cache: loaded /home/root/.gstreamer-0.10/registry.arm.bin in 0.099276 seconds
0:00:00.126867004 1487 0x16050 INFO GST_REGISTRY gstregistry.c:1469:scan_and_update_registry: Validating plugins from registry cache: /home/root/.gstreamer-0.10/registry.arm.bin
0:00:00.134260889 1487 0x16050 INFO GST_REGISTRY gstregistry.c:1219:gst_registry_scan_path_level:<registry0> cached info for /usr/lib/gstreamer-0.10/libgstlibvisual.so is stale
0:00:00.176937552 1487 0x16050 INFO GST_REGISTRY gstregistry.c:1219:gst_registry_scan_path_level:<registry0> cached info for /usr/lib/gstreamer-0.10/libgstfrei0r.so is stale
0:00:00.272820182 1487 0x16050 INFO GST_REGISTRY gstregistry.c:1570:scan_and_update_registry: Registry cache changed. Writing new registry cache
0:00:00.273018405 1487 0x16050 INFO GST_REGISTRY gstregistrybinary.c:364:gst_registry_binary_write_cache: Building binary registry cache image
0:00:00.323220368 1487 0x16050 INFO GST_REGISTRY gstregistrybinary.c:396:gst_registry_binary_write_cache: Writing binary registry cache
0:00:00.463552886 1487 0x16050 INFO GST_REGISTRY gstregistrybinary.c:258:gst_registry_binary_cache_finish: Wrote binary registry cache
0:00:00.463714590 1487 0x16050 INFO GST_REGISTRY gstregistry.c:1578:scan_and_update_registry: Registry cache written successfully
0:00:00.463769145 1487 0x16050 INFO GST_REGISTRY gstregistry.c:1628:ensure_current_registry: registry reading and updating done, result = 1
0:00:00.463815145 1487 0x16050 INFO GST_INIT gst.c:792:init_post: GLib runtime version: 2.24.1
0:00:00.463865368 1487 0x16050 INFO GST_INIT gst.c:794:init_post: GLib headers version: 2.24.1
0:00:00.464107182 1487 0x16050 INFO GST_PIPELINE gstparse.c:299:gst_parse_launch_full: parsing pipeline description 'v4l2src device=/dev/video0 always-copy=false queue-size=12 num-buffers=-1 ! video/x-raw-yuv-strided,format=(fourcc)NV12,width=800,height=480,framerate=(fraction)60/1 ! omxbufferalloc silent=false numBuffers=12 ! omx_scaler ! omx_ctrl display-mode=OMX_DC_MODE_1080P_60 ! omx_videosink sync=false '
0:00:00.476084775 1487 0x16050 INFO GST_PLUGIN_LOADING gstplugin.c:859:gst_plugin_load_file: plugin "/usr/lib/gstreamer-0.10/libgstvideo4linux2.so" loaded
0:00:00.476202775 1487 0x16050 INFO GST_ELEMENT_FACTORY gstelementfactory.c:371:gst_element_factory_create: creating element "v4l2src"
0:00:00.479566294 1487 0x16050 INFO GST_ELEMENT_PADS gstelement.c:716:gst_element_add_pad:<GstBaseSrc@0x1f8010> adding pad 'src'
0:00:00.838869183 1487 0x16050 INFO omx gstomx_videomixer.c:2183:init_interfaces: GstChildProxy interface registered
0:00:00.839066479 1487 0x16050 INFO GST_PLUGIN_LOADING gstplugin.c:859:gst_plugin_load_file: plugin "/usr/lib/gstreamer-0.10/libgstomx.so" loaded
0:00:00.839144257 1487 0x16050 INFO GST_ELEMENT_FACTORY gstelementfactory.c:371:gst_element_factory_create: creating element "omxbufferalloc"
0:00:00.839898553 1487 0x16050 INFO GST_ELEMENT_PADS gstelement.c:716:gst_element_add_pad:<GstomxBufferAlloc@0x1fc050> adding pad 'sink'
0:00:00.839984553 1487 0x16050 INFO GST_ELEMENT_PADS gstelement.c:716:gst_element_add_pad:<GstomxBufferAlloc@0x1fc050> adding pad 'src'
0:00:00.840194035 1487 0x16050 INFO GST_ELEMENT_FACTORY gstelementfactory.c:371:gst_element_factory_create: creating element "omx_scaler"
0:00:00.841446220 1487 0x16050 INFO GST_ELEMENT_PADS gstelement.c:716:gst_element_add_pad:<GstOmxBaseFilter@0x1fe060> adding pad 'sink'
0:00:00.841539220 1487 0x16050 INFO GST_ELEMENT_PADS gstelement.c:716:gst_element_add_pad:<GstOmxBaseFilter@0x1fe060> adding pad 'src'
0:00:00.841875331 1487 0x16050 INFO GST_ELEMENT_FACTORY gstelementfactory.c:371:gst_element_factory_create: creating element "omx_ctrl"
0:00:00.842505145 1487 0x16050 INFO GST_ELEMENT_PADS gstelement.c:716:gst_element_add_pad:<GstBaseTransform@0x201030> adding pad 'sink'
0:00:00.842677516 1487 0x16050 INFO GST_ELEMENT_PADS gstelement.c:716:gst_element_add_pad:<GstBaseTransform@0x201030> adding pad 'src'
0:00:00.842962627 1487 0x16050 INFO GST_ELEMENT_FACTORY gstelementfactory.c:371:gst_element_factory_create: creating element "omx_videosink"
0:00:00.843909516 1487 0x16050 INFO GST_ELEMENT_PADS gstelement.c:716:gst_element_add_pad:<GstBaseSink@0x2042a8> adding pad 'sink'
0:00:00.969590109 1487 0x16050 INFO GST_ELEMENT_FACTORY gstelementfactory.c:371:gst_element_factory_create: creating element "pipeline"
0:00:00.970175739 1487 0x16050 INFO GST_PIPELINE ./grammar.y:568:gst_parse_perform_link: linking v4l2src0:(any) to omxbufferalloc0:(any) (0/0) with caps "0x133820"
0:00:00.974090998 1487 0x16050 INFO GST_PLUGIN_LOADING gstplugin.c:859:gst_plugin_load_file: plugin "/usr/lib/gstreamer-0.10/libgstcoreelements.so" loaded
0:00:00.974201294 1487 0x16050 INFO GST_ELEMENT_FACTORY gstelementfactory.c:371:gst_element_factory_create: creating element "capsfilter"
0:00:00.974752849 1487 0x16050 INFO GST_ELEMENT_PADS gstelement.c:716:gst_element_add_pad:<GstBaseTransform@0x208030> adding pad 'sink'
0:00:00.974968775 1487 0x16050 INFO GST_ELEMENT_PADS gstelement.c:716:gst_element_add_pad:<GstBaseTransform@0x208030> adding pad 'src'
0:00:00.975127738 1487 0x16050 INFO GST_STATES gstbin.c:1759:gst_bin_get_state_func:<pipeline0> getting state
0:00:00.975284998 1487 0x16050 INFO GST_STATES gstelement.c:2341:gst_element_continue_state:<capsfilter0> completed state change to NULL
0:00:00.975428331 1487 0x16050 INFO GST_ELEMENT_PADS gstutils.c:1568:gst_element_link_pads_full: trying to link element v4l2src0:(any) to element capsfilter0:sink
0:00:00.975496627 1487 0x16050 INFO GST_ELEMENT_PADS gstelement.c:963:gst_element_get_static_pad: found pad capsfilter0:sink
0:00:00.975558183 1487 0x16050 INFO GST_PADS gstutils.c:1468:prepare_link_maybe_ghosting: v4l2src0 and capsfilter0 in same bin, no need for ghost pads
0:00:00.975710886 1487 0x16050 INFO GST_PADS gstpad.c:1941:gst_pad_link_prepare: trying to link v4l2src0:src and capsfilter0:sink
0:00:00.976609072 1487 0x16050 INFO GST_PADS gstpad.c:2124:gst_pad_link_full: linked v4l2src0:src and capsfilter0:sink, successful
0:00:00.976778072 1487 0x16050 INFO GST_ELEMENT_PADS gstutils.c:1568:gst_element_link_pads_full: trying to link element capsfilter0:src to element omxbufferalloc0:(any)
0:00:00.976843183 1487 0x16050 INFO GST_ELEMENT_PADS gstelement.c:963:gst_element_get_static_pad: found pad capsfilter0:src
0:00:00.976905997 1487 0x16050 INFO GST_PADS gstutils.c:1028:gst_pad_check_link: trying to link capsfilter0:src and omxbufferalloc0:sink
0:00:00.979402591 1487 0x16050 INFO GST_PADS gstutils.c:1468:prepare_link_maybe_ghosting: capsfilter0 and omxbufferalloc0 in same bin, no need for ghost pads
0:00:01.315397331 1487 0x16050 INFO GST_PADS gstpad.c:1941:gst_pad_link_prepare: trying to link capsfilter0:src and omxbufferalloc0:sink
0:00:01.317681072 1487 0x16050 INFO GST_PADS gstpad.c:2124:gst_pad_link_full: linked capsfilter0:src and omxbufferalloc0:sink, successful
0:00:01.317839072 1487 0x16050 INFO GST_PIPELINE ./grammar.y:568:gst_parse_perform_link: linking omxbufferalloc0:(any) to omxscaler0:(any) (0/0) with caps "(nil)"
0:00:01.317907850 1487 0x16050 INFO GST_ELEMENT_PADS gstutils.c:1568:gst_element_link_pads_full: trying to link element omxbufferalloc0:(any) to element omxscaler0:(any)
0:00:01.317974887 1487 0x16050 INFO GST_PADS gstutils.c:1028:gst_pad_check_link: trying to link omxbufferalloc0:src and omxscaler0:sink
0:00:01.320166591 1487 0x16050 INFO GST_PADS gstutils.c:1468:prepare_link_maybe_ghosting: omxbufferalloc0 and omxscaler0 in same bin, no need for ghost pads
0:00:01.320276665 1487 0x16050 INFO GST_PADS gstpad.c:1941:gst_pad_link_prepare: trying to link omxbufferalloc0:src and omxscaler0:sink
0:00:01.322445479 1487 0x16050 INFO GST_PADS gstpad.c:2124:gst_pad_link_full: linked omxbufferalloc0:src and omxscaler0:sink, successful
0:00:01.322571072 1487 0x16050 INFO GST_PIPELINE ./grammar.y:568:gst_parse_perform_link: linking omxscaler0:(any) to omxbasectrl0:(any) (0/0) with caps "(nil)"
0:00:01.322635146 1487 0x16050 INFO GST_ELEMENT_PADS gstutils.c:1568:gst_element_link_pads_full: trying to link element omxscaler0:(any) to element omxbasectrl0:(any)
0:00:01.322698887 1487 0x16050 INFO GST_PADS gstutils.c:1028:gst_pad_check_link: trying to link omxscaler0:src and omxbasectrl0:sink
0:00:01.322765701 1487 0x16050 INFO GST_PADS gstutils.c:1468:prepare_link_maybe_ghosting: omxscaler0 and omxbasectrl0 in same bin, no need for ghost pads
0:00:01.322849405 1487 0x16050 INFO GST_PADS gstpad.c:1941:gst_pad_link_prepare: trying to link omxscaler0:src and omxbasectrl0:sink
0:00:01.322918368 1487 0x16050 INFO GST_PADS gstpad.c:2124:gst_pad_link_full: linked omxscaler0:src and omxbasectrl0:sink, successful
0:00:01.323016924 1487 0x16050 INFO GST_PIPELINE ./grammar.y:568:gst_parse_perform_link: linking omxbasectrl0:(any) to omxvideosink0:(any) (0/0) with caps "(nil)"
0:00:01.323074590 1487 0x16050 INFO GST_ELEMENT_PADS gstutils.c:1568:gst_element_link_pads_full: trying to link element omxbasectrl0:(any) to element omxvideosink0:(any)
0:00:01.323132961 1487 0x16050 INFO GST_PADS gstutils.c:1028:gst_pad_check_link: trying to link omxbasectrl0:src and omxvideosink0:sink
0:00:01.323288368 1487 0x16050 INFO GST_PADS gstutils.c:1468:prepare_link_maybe_ghosting: omxbasectrl0 and omxvideosink0 in same bin, no need for ghost pads
0:00:01.323379775 1487 0x16050 INFO GST_PADS gstpad.c:1941:gst_pad_link_prepare: trying to link omxbasectrl0:src and omxvideosink0:sink
0:00:01.658570183 1487 0x16050 INFO omx gstomx_base_sink.c:504:pad_sink_link:<omxvideosink0> link
0:00:02.739552887 1487 0x16050 INFO GST_PADS gstpad.c:2124:gst_pad_link_full: linked omxbasectrl0:src and omxvideosink0:sink, successful
Setting pipeline to PAUSED ...
0:00:02.742412294 1487 0x16050 INFO omx gstomx_base_sink.c:113:change_state:<omxvideosink0> changing state NULL - READY
0:00:02.742527368 1487 0x16050 INFO GST_STATES gstelement.c:2341:gst_element_continue_state:<omxvideosink0> completed state change to READY
0:00:02.742589739 1487 0x16050 INFO GST_STATES gstelement.c:2354:gst_element_continue_state:<omxvideosink0> posting state-changed NULL to READY
0:00:02.742775701 1487 0x16050 INFO GST_STATES gstbin.c:2492:gst_bin_change_state_func:<pipeline0> child 'omxvideosink0' changed state to 2(READY) successfully
0:00:02.742873183 1487 0x16050 INFO GST_STATES gstelement.c:2341:gst_element_continue_state:<omxbasectrl0> completed state change to READY
0:00:02.742928813 1487 0x16050 INFO GST_STATES gstelement.c:2354:gst_element_continue_state:<omxbasectrl0> posting state-changed NULL to READY
0:00:02.743007998 1487 0x16050 INFO GST_STATES gstbin.c:2492:gst_bin_change_state_func:<pipeline0> child 'omxbasectrl0' changed state to 2(READY) successfully
0:00:02.743083627 1487 0x16050 INFO omx gstomx_base_filter.c:153:change_state:<omxscaler0> begin: changing state NULL -> READY
0:00:02.778987443 1487 0x16050 INFO GST_STATES gstelement.c:2341:gst_element_continue_state:<omxscaler0> completed state change to READY
0:00:02.779108480 1487 0x16050 INFO GST_STATES gstelement.c:2354:gst_element_continue_state:<omxscaler0> posting state-changed NULL to READY
0:00:02.779232294 1487 0x16050 INFO GST_STATES gstbin.c:2492:gst_bin_change_state_func:<pipeline0> child 'omxscaler0' changed state to 2(READY) successfully
0:00:02.779341220 1487 0x16050 INFO GST_STATES gstelement.c:2341:gst_element_continue_state:<omxbufferalloc0> completed state change to READY
0:00:02.779399517 1487 0x16050 INFO GST_STATES gstelement.c:2354:gst_element_continue_state:<omxbufferalloc0> posting state-changed NULL to READY
0:00:02.779478294 1487 0x16050 INFO GST_STATES gstbin.c:2492:gst_bin_change_state_func:<pipeline0> child 'omxbufferalloc0' changed state to 2(READY) successfully
0:00:02.779550109 1487 0x16050 INFO GST_STATES gstelement.c:2341:gst_element_continue_state:<capsfilter0> completed state change to READY
0:00:02.779603257 1487 0x16050 INFO GST_STATES gstelement.c:2354:gst_element_continue_state:<capsfilter0> posting state-changed NULL to READY
0:00:02.779676628 1487 0x16050 INFO GST_STATES gstbin.c:2492:gst_bin_change_state_func:<pipeline0> child 'capsfilter0' changed state to 2(READY) successfully
0:00:02.780125887 1487 0x16050 INFO v4l2 v4l2_calls.c:480:gst_v4l2_open:<v4l2src0> Opened device 'TI81xx_catalogue' (/dev/video0) successfully
0:00:02.780295591 1487 0x16050 INFO GST_STATES gstelement.c:2341:gst_element_continue_state:<v4l2src0> completed state change to READY
0:00:02.780359257 1487 0x16050 INFO GST_STATES gstelement.c:2354:gst_element_continue_state:<v4l2src0> posting state-changed NULL to READY
0:00:02.780492516 1487 0x16050 INFO GST_STATES gstbin.c:2492:gst_bin_change_state_func:<pipeline0> child 'v4l2src0' changed state to 2(READY) successfully
0:00:02.780594183 1487 0x16050 INFO GST_STATES gstelement.c:2314:gst_element_continue_state:<pipeline0> committing state from NULL to READY, pending PAUSED, next PAUSED
0:00:03.117779850 1487 0x16050 INFO GST_STATES gstelement.c:2323:gst_element_continue_state:<pipeline0> continue state change READY to PAUSED, final PAUSED
0:00:03.118027183 1487 0x16050 INFO omx gstomx_base_sink.c:113:change_state:<omxvideosink0> changing state READY - PAUSED
0:00:03.118198220 1487 0x16050 INFO GST_STATES gstbin.c:2498:gst_bin_change_state_func:<pipeline0> child 'omxvideosink0' is changing state asynchronously to PAUSED
0:00:03.139450998 1487 0x16050 INFO GST_STATES gstelement.c:2341:gst_element_continue_state:<omxbasectrl0> completed state change to PAUSED
0:00:03.139571961 1487 0x16050 INFO GST_STATES gstelement.c:2354:gst_element_continue_state:<omxbasectrl0> posting state-changed READY to PAUSED
0:00:03.139690591 1487 0x16050 INFO GST_STATES gstbin.c:2492:gst_bin_change_state_func:<pipeline0> child 'omxbasectrl0' changed state to 3(PAUSED) successfully
0:00:03.139791517 1487 0x16050 INFO omx gstomx_base_filter.c:153:change_state:<omxscaler0> begin: changing state READY -> PAUSED
0:00:03.139881554 1487 0x16050 INFO GST_STATES gstelement.c:2341:gst_element_continue_state:<omxscaler0> completed state change to PAUSED
0:00:03.139937665 1487 0x16050 INFO GST_STATES gstelement.c:2354:gst_element_continue_state:<omxscaler0> posting state-changed READY to PAUSED
0:00:03.140015331 1487 0x16050 INFO GST_STATES gstbin.c:2492:gst_bin_change_state_func:<pipeline0> child 'omxscaler0' changed state to 3(PAUSED) successfully
0:00:03.140112665 1487 0x16050 INFO GST_STATES gstelement.c:2341:gst_element_continue_state:<omxbufferalloc0> completed state change to PAUSED
0:00:03.140168479 1487 0x16050 INFO GST_STATES gstelement.c:2354:gst_element_continue_state:<omxbufferalloc0> posting state-changed READY to PAUSED
0:00:03.140241405 1487 0x16050 INFO GST_STATES gstbin.c:2492:gst_bin_change_state_func:<pipeline0> child 'omxbufferalloc0' changed state to 3(PAUSED) successfully
0:00:03.140335405 1487 0x16050 INFO GST_STATES gstelement.c:2341:gst_element_continue_state:<capsfilter0> completed state change to PAUSED
0:00:03.140418109 1487 0x16050 INFO GST_STATES gstelement.c:2354:gst_element_continue_state:<capsfilter0> posting state-changed READY to PAUSED
0:00:03.140496554 1487 0x16050 INFO GST_STATES gstbin.c:2492:gst_bin_change_state_func:<pipeline0> child 'capsfilter0' changed state to 3(PAUSED) successfully
0:00:03.140689702 1487 0x16050 INFO v4l2 gstv4l2object.c:1036:gst_v4l2_object_fill_format_list:<v4l2src0> got 4 format(s):
0:00:03.140746665 1487 0x16050 INFO v4l2 gstv4l2object.c:1042:gst_v4l2_object_fill_format_list:<v4l2src0> NV12
0:00:03.140792294 1487 0x16050 INFO v4l2 gstv4l2object.c:1042:gst_v4l2_object_fill_format_list:<v4l2src0> YUYV
0:00:03.140834591 1487 0x16050 INFO v4l2 gstv4l2object.c:1042:gst_v4l2_object_fill_format_list:<v4l2src0> RGB3
0:00:03.140876220 1487 0x16050 INFO v4l2 gstv4l2object.c:1042:gst_v4l2_object_fill_format_list:<v4l2src0> NV16
0:00:03.476907590 1487 0x16050 INFO v4l2src gstv4l2src.c:611:gst_v4l2src_get_caps:<v4l2src0> probed caps: 0x207aa0
Mode set is 0
0:00:03.479407331 1487 0x16050 INFO v4l2 gstv4l2object.c:1525:gst_v4l2_object_get_caps_info:<v4l2src0> rowstride: 800
0:00:03.479491702 1487 0x16050 WARN basesrc gstbasesrc.c:2778:gst_base_src_start:<v4l2src0> error: Could not negotiate format
0:00:03.479541517 1487 0x16050 WARN basesrc gstbasesrc.c:2778:gst_base_src_start:<v4l2src0> error: Check your filtered caps, if any
0:00:03.479673220 1487 0x16050 INFO GST_ERROR_SYSTEM gstelement.c:1865:gst_element_message_full:<v4l2src0> posting message: Could not negotiate format
0:00:03.479797813 1487 0x16050 INFO GST_ERROR_SYSTEM gstelement.c:1888:gst_element_message_full:<v4l2src0> posted error message: Could not negotiate format
0:00:03.479873998 1487 0x16050 WARN basesrc gstbasesrc.c:2974:gst_base_src_activate_push:<v4l2src0> Failed to start in push mode
0:00:03.479922628 1487 0x16050 INFO GST_PADS gstpad.c:983:gst_pad_activate_push:<v4l2src0:src> failed to activate in push mode
0:00:03.479978368 1487 0x16050 WARN GST_PADS gstpad.c:734:gst_pad_set_active:<v4l2src0:src> Failed to activate pad
0:00:03.480037591 1487 0x16050 INFO GST_STATES gstelement.c:2658:gst_element_change_state:<v4l2src0> have FAILURE change_state return
0:00:03.480090628 1487 0x16050 INFO GST_STATES gstelement.c:2235:gst_element_abort_state:<v4l2src0> aborting state from READY to PAUSED
0:00:03.480144183 1487 0x16050 INFO GST_STATES gstbin.c:2508:gst_bin_change_state_func:<pipeline0> child 'v4l2src0' failed to go to state 3(PAUSED)
0:00:03.480232331 1487 0x16050 INFO GST_STATES gstelement.c:2658:gst_element_change_state:<pipeline0> have FAILURE change_state return
ERROR: Pipeline doesn't want to pause.
ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Could not negotiate format
Additional debug info:
gstbasesrc.c(2778): gst_base_src_start (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
Setting pipeline to NULL ...
0:00:03.482074183 1487 0x16050 INFO omx gstomx_base_sink.c:113:change_state:<omxvideosink0> changing state PAUSED - READY
0:00:03.482285442 1487 0x16050 INFO GST_STATES gstelement.c:2314:gst_element_continue_state:<omxvideosink0> committing state from READY to READY, pending NULL, next NULL
0:00:03.482374183 1487 0x16050 INFO GST_STATES gstelement.c:2323:gst_element_continue_state:<omxvideosink0> continue state change READY to NULL, final NULL
0:00:03.482431072 1487 0x16050 INFO omx gstomx_base_sink.c:113:change_state:<omxvideosink0> changing state READY - NULL
0:00:03.482503664 1487 0x16050 INFO GST_STATES gstelement.c:2341:gst_element_continue_state:<omxvideosink0> completed state change to NULL
0:00:03.818268665 1487 0x16050 INFO GST_STATES gstelement.c:2354:gst_element_continue_state:<omxvideosink0> posting state-changed READY to NULL
0:00:03.818405850 1487 0x16050 INFO Assertion at Line no: 380 in /swcoe/sdk/cm/netra/arago-tmp/work/dm816x-evm-none-linux-gnueabi/ti-syslink-2_20_02_20-r4j/syslink_2_20_02_20/packages/ti/syslink/utils/hlos/knl/Linux/../../../../../../ti/syslink/utils/hlos/knl/ResTrack.c: (elem == NULL) : failed
GST_STATEAssertion at Line no: 380 in /swcoe/sdk/cm/netra/arago-tmp/work/dm816x-evm-none-linux-gnueabi/ti-syslink-2_20_02_20-r4j/syslink_2_20_02_20/packages/ti/syslink/utils/hlos/knl/Linux/../../../../../../ti/syslink/utils/hlos/knl/ResTrack.c: (elem == NULL) : failed
S gstbin.c:2492:Assertion at Line no: 380 in /swcoe/sdk/cm/netra/arago-tmp/work/dm816x-evm-none-linux-gnueabi/ti-syslink-2_20_02_20-r4j/syslink_2_20_02_20/packages/ti/syslink/utils/hlos/knl/Linux/../../../../../../ti/syslink/utils/hlos/knl/ResTrack.c: (elem == NULL) : failed
gst_bin_change_sAssertion at Line no: 380 in /swcoe/sdk/cm/netra/arago-tmp/work/dm816x-evm-none-linux-gnueabi/ti-syslink-2_20_02_20-r4j/syslink_2_20_02_20/packages/ti/syslink/utils/hlos/knl/Linux/../../../../../../ti/syslink/utils/hlos/knl/ResTrack.c: (elem == NULL) : failed
tate_func:<pipelAssertion at Line no: 380 in /swcoe/sdk/cm/netra/arago-tmp/work/dm816x-evm-none-linux-gnueabi/ti-syslink-2_20_02_20-r4j/syslink_2_20_02_20/packages/ti/syslink/utils/hlos/knl/Linux/../../../../../../ti/syslink/utils/hlos/knl/ResTrack.c: (elem == NULL) : failed
ine0> childAssertion at Line no: 380 in /swcoe/sdk/cm/netra/arago-tmp/work/dm816x-evm-none-linux-gnueabi/ti-syslink-2_20_02_20-r4j/syslink_2_20_02_20/packages/ti/syslink/utils/hlos/knl/Linux/../../../../../../ti/syslink/utils/hlos/knl/ResTrack.c: (elem == NULL) : failed
'omxvideosink0'Assertion at Line no: 380 in /swcoe/sdk/cm/netra/arago-tmp/work/dm816x-evm-none-linux-gnueabi/ti-syslink-2_20_02_20-r4j/syslink_2_20_02_20/packages/ti/syslink/utils/hlos/knl/Linux/../../../../../../ti/syslink/utils/hlos/knl/ResTrack.c: (elem == NULL) : failed
changed state tAssertion at Line no: 380 in /swcoe/sdk/cm/netra/arago-tmp/work/dm816x-evm-none-linux-gnueabi/ti-syslink-2_20_02_20-r4j/syslink_2_20_02_20/packages/ti/syslink/utils/hlos/knl/Linux/../../../../../../ti/syslink/utils/hlos/knl/ResTrack.c: (elem == NULL) : failed
o 1(NULL) succesAssertion at Line no: 380 in /swcoe/sdk/cm/netra/arago-tmp/work/dm816x-evm-none-linux-gnueabi/ti-syslink-2_20_02_20-r4j/syslink_2_20_02_20/packages/ti/syslink/utils/hlos/knl/Linux/../../../../../../ti/syslink/utils/hlos/knl/ResTrack.c: (elem == NULL) : failed
sfully
0:00:03.838082702 1487 0x16050 INFO GST_STATES gstelement.c:2314:gst_element_continue_state:<omxbasectrl0> committing state from PAUSED to READY, pending NULL, next NULL
0:00:03.838241554 1487 0x16050 INFO GST_STATES gstelement.c:2323:gst_element_continue_state:<omxbasectrl0> continue state change READY to NULL, final NULL
0:00:03.838332183 1487 0x16050 INFO GST_STATES gstelement.c:2341:gst_element_continue_state:<omxbasectrl0> completed state change to NULL
0:00:03.838390146 1487 0x16050 INFO GST_STATES gstelement.c:2354:gst_element_continue_state:<omxbasectrl0> posting state-changed READY to NULL
0:00:03.838471146 1487 0x16050 INFO GST_STATES gstbin.c:2492:gst_bin_change_state_func:<pipeline0> child 'omxbasectrl0' changed state to 1(NULL) successfully
0:00:03.838559850 1487 0x16050 INFO omx gstomx_base_filter.c:153:change_state:<omxscaler0> begin: changing state PAUSED -> READY
0:00:03.838686035 1487 0x16050 INFO GST_STATES gstelement.c:2314:gst_element_continue_state:<omxscaler0> committing state from PAUSED to READY, pending NULL, next NULL
0:00:03.838773406 1487 0x16050 INFO GST_STATES gstelement.c:2323:gst_element_continue_state:<omxscaler0> continue state change READY to NULL, final NULL
0:00:03.838828035 1487 0x16050 INFO omx gstomx_base_filter.c:153:change_state:<omxscaler0> begin: changing state READY -> NULL
0:00:03.859434517 1487 0x16050 INFO GST_STATES gstelement.c:2341:gst_element_continue_state:<omxscaler0> completed state change to NULL
0:00:03.859539368 1487 0x16050 INFO GST_STATES gstelement.c:2354:gst_element_continue_state:<omxscaler0> posting state-changed READY to NULL
0:00:03.859650331 1487 0x16050 INFO GST_STATES gstbin.c:2492:gst_bin_change_state_func:<pipeline0> child 'omxscaler0' changed state to 1(NULL) successfully
0:00:03.859799924 1487 0x16050 INFO GST_STATES gstelement.c:2314:gst_element_continue_state:<omxbufferalloc0> committing state from PAUSED to READY, pending NULL, next NULL
0:00:03.859889554 1487 0x16050 INFO GST_STATES gstelement.c:2323:gst_element_continue_state:<omxbufferalloc0> continue state change READY to NULL, final NULL
0:00:04.109003886 1487 0x16050 INFO GST_STATES gstelement.c:2341:gst_element_continue_state:<omxbufferalloc0> completed state change to NULL
0:00:04.109125664 1487 0x16050 INFO GST_STATES gstelement.c:2354:gst_element_continue_state:<omxbufferalloc0> posting state-changed READY to NULL
0:00:04.109247442 1487 0x16050 INFO GST_STATES gstbin.c:2492:gst_bin_change_state_func:<pipeline0> child 'omxbufferalloc0' changed state to 1(NULL) successfully
0:00:04.109412220 1487 0x16050 INFO GST_STATES gstelement.c:2314:gst_element_continue_state:<capsfilter0> committing state from PAUSED to READY, pending NULL, next NULL
0:00:04.109505442 1487 0x16050 INFO GST_STATES gstelement.c:2323:gst_element_continue_state:<capsfilter0> continue state change READY to NULL, final NULL
0:00:04.109586146 1487 0x16050 INFO GST_STATES gstelement.c:2341:gst_element_continue_state:<capsfilter0> completed state change to NULL
0:00:04.109638146 1487 0x16050 INFO GST_STATES gstelement.c:2354:gst_element_continue_state:<capsfilter0> posting state-changed READY to NULL
0:00:04.444758516 1487 0x16050 INFO GST_STATES gstbin.c:2492:gst_bin_change_state_func:<pipeline0> child 'capsfilter0' changed state to 1(NULL) successfully
0:00:04.445011590 1487 0x16050 INFO GST_STATES gstelement.c:2341:gst_element_continue_state:<v4l2src0> completed state change to NULL
0:00:04.445081516 1487 0x16050 INFO GST_STATES gstelement.c:2354:gst_element_continue_state:<v4l2src0> posting state-changed READY to NULL
0:00:04.445167293 1487 0x16050 INFO GST_STATES gstbin.c:2492:gst_bin_change_state_func:<pipeline0> child 'v4l2src0' changed state to 1(NULL) successfully
0:00:04.445362404 1487 0x16050 INFO GST_STATES gstelement.c:2341:gst_element_continue_state:<pipeline0> completed state change to NULL
0:00:04.445420701 1487 0x16050 INFO GST_STATES gstelement.c:2354:gst_element_continue_state:<pipeline0> posting state-changed READY to NULL
0:00:04.445518034 1487 0x16050 INFO GST_STATES gstbin.c:1759:gst_bin_get_state_func:<pipeline0> getting state
Freeing pipeline ...
0:00:04.445746997 1487 0x16050 INFO GST_ELEMENT_PADS gstpad.c:1713:gst_pad_unlink: unlinking capsfilter0:src(0x1f7710) and omxbufferalloc0:sink(0x1f70d0)
0:00:04.445871182 1487 0x16050 INFO GST_ELEMENT_PADS gstpad.c:1758:gst_pad_unlink: unlinked capsfilter0:src and omxbufferalloc0:sink
0:00:04.445975108 1487 0x16050 INFO GST_ELEMENT_PADS gstpad.c:1713:gst_pad_unlink: unlinking v4l2src0:src(0x1f7008) and capsfilter0:sink(0x1f7648)
0:00:04.446105479 1487 0x16050 INFO GST_ELEMENT_PADS gstpad.c:1758:gst_pad_unlink: unlinked v4l2src0:src and capsfilter0:sink
0:00:04.446225812 1487 0x16050 INFO GST_PARENTAGE gstbin.c:1440:gst_bin_remove_func:<pipeline0> removed child "capsfilter0"
0:00:04.446329886 1487 0x16050 INFO GST_REFCOUNTING gstelement.c:2955:gst_element_dispose:<capsfilter0> dispose
0:00:04.446386701 1487 0x16050 INFO GST_ELEMENT_PADS gstelement.c:835:gst_element_remove_pad:<capsfilter0> removing pad 'src'
0:00:04.446492849 1487 0x16050 INFO GST_ELEMENT_PADS gstelement.c:835:gst_element_remove_pad:<capsfilter0> removing pad 'sink'
0:00:04.446572738 1487 0x16050 INFO GST_REFCOUNTING gstelement.c:2979:gst_element_dispose:<capsfilter0> parent class dispose
0:00:04.446633849 1487 0x16050 INFO GST_REFCOUNTING gstelement.c:3010:gst_element_finalize:<capsfilter0> finalize
0:00:04.446689108 1487 0x16050 INFO GST_REFCOUNTING gstelement.c:3021:gst_element_finalize:<capsfilter0> finalize parent
0:00:04.446753404 1487 0x16050 INFO GST_ELEMENT_PADS gstpad.c:1713:gst_pad_unlink: unlinking omxbasectrl0:src(0x1f74b8) and omxvideosink0:sink(0x1f7580)
0:00:04.446844960 1487 0x16050 INFO GST_ELEMENT_PADS gstpad.c:1758:gst_pad_unlink: unlinked omxbasectrl0:src and omxvideosink0:sink
0:00:04.782315553 1487 0x16050 INFO GST_PARENTAGE gstbin.c:1440:gst_bin_remove_func:<pipeline0> removed child "omxvideosink0"
0:00:04.782413256 1487 0x16050 INFO GST_REFCOUNTING gstelement.c:2955:gst_element_dispose:<omxvideosink0> dispose
0:00:04.782471368 1487 0x16050 INFO GST_ELEMENT_PADS gstelement.c:835:gst_element_remove_pad:<omxvideosink0> removing pad 'sink'
0:00:04.782551331 1487 0x16050 INFO GST_REFCOUNTING gstelement.c:2979:gst_element_dispose:<omxvideosink0> parent class dispose
gst-launch-0.10: OmxRpcStub.c:1432: OmxRpc_stubGetState: Assertion `(1 == OmxRpc_module->localCoreRcmServer.initDone)' failed.
Aborted
If launch second, get other error:
root@dm816x-evm:~# gst-launch -e --gst-debug=3 --verbose v4l2src device="/dev/vi
deo0" always-copy=false queue-size=12 num-buffers=-1 ! 'video/x-raw-yuv-strided,
format=(fourcc)NV12,width=1920,height=1080,framerate=(fraction)60/1' ! omxbuffer
0:00:00.014467905 1496 0x16050 INFO GST_INIT gstquery.c:108:_gst_query_initialize: init queries
0:00:00.019066974 1496 0x16050 INFO GST_INIT gstmessage.c:73:_gst_message_initialize: init messages
0:00:00.020178556 1496 0x16050 INFO GST_PLUGIN_LOADING gstplugin.c:350:_gst_plugin_initialize: registering 0 static plugins
0:00:00.021223361 1496 0x16050 INFO GST_PLUGIN_LOADING gstplugin.c:255:gst_plugin_register_static: registered static plugin "staticelements"
0:00:00.021310694 1496 0x16050 INFO GST_PLUGIN_LOADING gstplugin.c:257:gst_plugin_register_static: added static plugin "staticelements", result: 1
0:00:00.028972372 1496 0x16050 INFO GST_REGISTRY gstregistry.c:1599:ensure_current_registry: reading registry cache: /home/root/.gstreamer-0.10/registry.arm.bin
0:00:00.129807035 1496 0x16050 INFO GST_REGISTRY gstregistrybinary.c:614:gst_registry_binary_read_cache: loaded /home/root/.gstreamer-0.10/registry.arm.bin in 0.100691 seconds
0:00:00.130214999 1496 0x16050 INFO GST_REGISTRY gstregistry.c:1469:scan_and_update_registry: Validating plugins from registry cache: /home/root/.gstreamer-0.10/registry.arm.bin
0:00:00.196191242 1496 0x16050 INFO GST_REGISTRY gstregistry.c:1561:scan_and_update_registry: Registry cache has not changed
0:00:00.196348464 1496 0x16050 INFO GST_REGISTRY gstregistry.c:1628:ensure_current_registry: registry reading and updating done, result = 1
0:00:00.196405650 1496 0x16050 INFO GST_INIT gst.c:792:init_post: GLib runtime version: 2.24.1
0:00:00.196455538 1496 0x16050 INFO GST_INIT gst.c:794:init_post: GLib headers version: 2.24.1
0:00:00.196670205 1496 0x16050 INFO GST_PIPELINE gstparse.c:299:gst_parse_launch_full: parsing pipeline description 'v4l2src device=/dev/video0 always-copy=false queue-size=12 num-buffers=-1 ! video/x-raw-yuv-strided,format=(fourcc)NV12,width=1920,height=1080,framerate=(fraction)60/1 ! omxbufferalloc silent=false numBuffers=12 ! omx_scaler ! omx_ctrl display-mode=OMX_DC_MODE_1080P_60 ! omx_videosink sync=false '
0:00:00.206594941 1496 0x16050 INFO GST_PLUGIN_LOADING gstplugin.c:859:gst_plugin_load_file: plugin "/usr/lib/gstreamer-0.10/libgstvideo4linux2.so" loaded
0:00:00.206709978 1496 0x16050 INFO GST_ELEMENT_FACTORY gstelementfactory.c:371:gst_element_factory_create: creating element "v4l2src"
0:00:00.209979495 1496 0x16050 INFO GST_ELEMENT_PADS gstelement.c:716:gst_element_add_pad:<GstBaseSrc@0x154060> adding pad 'src'
0:00:00.225110607 1496 0x16050 INFO omx gstomx_videomixer.c:2183:init_interfaces: GstChildProxy interface registered
0:00:00.225251273 1496 0x16050 INFO GST_PLUGIN_LOADING gstplugin.c:859:gst_plugin_load_file: plugin "/usr/lib/gstreamer-0.10/libgstomx.so" loaded
0:00:00.225321496 1496 0x16050 INFO GST_ELEMENT_FACTORY gstelementfactory.c:371:gst_element_factory_create: creating element "omxbufferalloc"
0:00:00.226105903 1496 0x16050 INFO GST_ELEMENT_PADS gstelement.c:716:gst_element_add_pad:<GstomxBufferAlloc@0x159858> adding pad 'sink'
0:00:00.226195348 1496 0x16050 INFO GST_ELEMENT_PADS gstelement.c:716:gst_element_add_pad:<GstomxBufferAlloc@0x159858> adding pad 'src'
0:00:00.226404570 1496 0x16050 INFO GST_ELEMENT_FACTORY gstelementfactory.c:371:gst_element_factory_create: creating element "omx_scaler"
0:00:00.227737311 1496 0x16050 INFO GST_ELEMENT_PADS gstelement.c:716:gst_element_add_pad:<GstOmxBaseFilter@0x15c048> adding pad 'sink'
0:00:00.227830163 1496 0x16050 INFO GST_ELEMENT_PADS gstelement.c:716:gst_element_add_pad:<GstOmxBaseFilter@0x15c048> adding pad 'src'
0:00:00.228127496 1496 0x16050 INFO GST_ELEMENT_FACTORY gstelementfactory.c:371:gst_element_factory_create: creating element "omx_ctrl"
0:00:00.228744608 1496 0x16050 INFO GST_ELEMENT_PADS gstelement.c:716:gst_element_add_pad:<GstBaseTransform@0x15e038> adding pad 'sink'
0:00:00.228915978 1496 0x16050 INFO GST_ELEMENT_PADS gstelement.c:716:gst_element_add_pad:<GstBaseTransform@0x15e038> adding pad 'src'
0:00:00.229201237 1496 0x16050 INFO GST_ELEMENT_FACTORY gstelementfactory.c:371:gst_element_factory_create: creating element "omx_videosink"
0:00:00.230156534 1496 0x16050 INFO GST_ELEMENT_PADS gstelement.c:716:gst_element_add_pad:<GstBaseSink@0x1622c0> adding pad 'sink'
0:00:00.358806315 1496 0x16050 INFO GST_ELEMENT_FACTORY gstelementfactory.c:371:gst_element_factory_create: creating element "pipeline"
0:00:00.359451129 1496 0x16050 INFO GST_PIPELINE ./grammar.y:568:gst_parse_perform_link: linking v4l2src0:(any) to omxbufferalloc0:(any) (0/0) with caps "0x133220"
0:00:00.363208574 1496 0x16050 INFO GST_PLUGIN_LOADING gstplugin.c:859:gst_plugin_load_file: plugin "/usr/lib/gstreamer-0.10/libgstcoreelements.so" loaded
0:00:00.363319055 1496 0x16050 INFO GST_ELEMENT_FACTORY gstelementfactory.c:371:gst_element_factory_create: creating element "capsfilter"
0:00:00.363901278 1496 0x16050 INFO GST_ELEMENT_PADS gstelement.c:716:gst_element_add_pad:<GstBaseTransform@0x1660c0> adding pad 'sink'
0:00:00.364090982 1496 0x16050 INFO GST_ELEMENT_PADS gstelement.c:716:gst_element_add_pad:<GstBaseTransform@0x1660c0> adding pad 'src'
0:00:00.364232834 1496 0x16050 INFO GST_STATES gstbin.c:1759:gst_bin_get_state_func:<pipeline0> getting state
0:00:00.364391352 1496 0x16050 INFO GST_STATES gstelement.c:2341:gst_element_continue_state:<capsfilter0> completed state change to NULL
0:00:00.364532685 1496 0x16050 INFO GST_ELEMENT_PADS gstutils.c:1568:gst_element_link_pads_full: trying to link element v4l2src0:(any) to element capsfilter0:sink
0:00:00.364636278 1496 0x16050 INFO GST_ELEMENT_PADS gstelement.c:963:gst_element_get_static_pad: found pad capsfilter0:sink
0:00:00.700735833 1496 0x16050 INFO GST_PADS gstutils.c:1468:prepare_link_maybe_ghosting: v4l2src0 and capsfilter0 in same bin, no need for ghost pads
0:00:00.700922981 1496 0x16050 INFO GST_PADS gstpad.c:1941:gst_pad_link_prepare: trying to link v4l2src0:src and capsfilter0:sink
0:00:00.701687611 1496 0x16050 INFO GST_PADS gstpad.c:2124:gst_pad_link_full: linked v4l2src0:src and capsfilter0:sink, successful
0:00:00.701839462 1496 0x16050 INFO GST_ELEMENT_PADS gstutils.c:1568:gst_element_link_pads_full: trying to link element capsfilter0:src to element omxbufferalloc0:(any)
0:00:00.701903499 1496 0x16050 INFO GST_ELEMENT_PADS gstelement.c:963:gst_element_get_static_pad: found pad capsfilter0:src
0:00:00.701967314 1496 0x16050 INFO GST_PADS gstutils.c:1028:gst_pad_check_link: trying to link capsfilter0:src and omxbufferalloc0:sink
0:00:00.704388536 1496 0x16050 INFO GST_PADS gstutils.c:1468:prepare_link_maybe_ghosting: capsfilter0 and omxbufferalloc0 in same bin, no need for ghost pads
0:00:00.704506092 1496 0x16050 INFO GST_PADS gstpad.c:1941:gst_pad_link_prepare: trying to link capsfilter0:src and omxbufferalloc0:sink
0:00:00.706722758 1496 0x16050 INFO GST_PADS gstpad.c:2124:gst_pad_link_full: linked capsfilter0:src and omxbufferalloc0:sink, successful
0:00:00.706857870 1496 0x16050 INFO GST_PIPELINE ./grammar.y:568:gst_parse_perform_link: linking omxbufferalloc0:(any) to omxscaler0:(any) (0/0) with caps "(nil)"
0:00:00.706923610 1496 0x16050 INFO GST_ELEMENT_PADS gstutils.c:1568:gst_element_link_pads_full: trying to link element omxbufferalloc0:(any) to element omxscaler0:(any)
0:00:00.706985499 1496 0x16050 INFO GST_PADS gstutils.c:1028:gst_pad_check_link: trying to link omxbufferalloc0:src and omxscaler0:sink
0:00:00.709209684 1496 0x16050 INFO GST_PADS gstutils.c:1468:prepare_link_maybe_ghosting: omxbufferalloc0 and omxscaler0 in same bin, no need for ghost pads
0:00:00.709313795 1496 0x16050 INFO GST_PADS gstpad.c:1941:gst_pad_link_prepare: trying to link omxbufferalloc0:src and omxscaler0:sink
0:00:00.711501314 1496 0x16050 INFO GST_PADS gstpad.c:2124:gst_pad_link_full: linked omxbufferalloc0:src and omxscaler0:sink, successful
0:00:00.711624240 1496 0x16050 INFO GST_PIPELINE ./grammar.y:568:gst_parse_perform_link: linking omxscaler0:(any) to omxbasectrl0:(any) (0/0) with caps "(nil)"
0:00:00.711685128 1496 0x16050 INFO GST_ELEMENT_PADS gstutils.c:1568:gst_element_link_pads_full: trying to link element omxscaler0:(any) to element omxbasectrl0:(any)
0:00:00.711746869 1496 0x16050 INFO GST_PADS gstutils.c:1028:gst_pad_check_link: trying to link omxscaler0:src and omxbasectrl0:sink
0:00:00.711813351 1496 0x16050 INFO GST_PADS gstutils.c:1468:prepare_link_maybe_ghosting: omxscaler0 and omxbasectrl0 in same bin, no need for ghost pads
0:00:01.046729204 1496 0x16050 INFO GST_PADS gstpad.c:1941:gst_pad_link_prepare: trying to link omxscaler0:src and omxbasectrl0:sink
0:00:01.046820870 1496 0x16050 INFO GST_PADS gstpad.c:2124:gst_pad_link_full: linked omxscaler0:src and omxbasectrl0:sink, successful
0:00:01.046928389 1496 0x16050 INFO GST_PIPELINE ./grammar.y:568:gst_parse_perform_link: linking omxbasectrl0:(any) to omxvideosink0:(any) (0/0) with caps "(nil)"
0:00:01.046988611 1496 0x16050 INFO GST_ELEMENT_PADS gstutils.c:1568:gst_element_link_pads_full: trying to link element omxbasectrl0:(any) to element omxvideosink0:(any)
0:00:01.047050796 1496 0x16050 INFO GST_PADS gstutils.c:1028:gst_pad_check_link: trying to link omxbasectrl0:src and omxvideosink0:sink
0:00:01.047214389 1496 0x16050 INFO GST_PADS gstutils.c:1468:prepare_link_maybe_ghosting: omxbasectrl0 and omxvideosink0 in same bin, no need for ghost pads
0:00:01.047306722 1496 0x16050 INFO GST_PADS gstpad.c:1941:gst_pad_link_prepare: trying to link omxbasectrl0:src and omxvideosink0:sink
0:00:01.047435611 1496 0x16050 INFO omx gstomx_base_sink.c:504:pad_sink_link:<omxvideosink0> link
gst-launch-0.10: OmxRpc.c:624: OmxRpc_Instance_init: Assertion `(OmxRpc_errorNone == retVal)' failed.
Aborted
root@dm816x-evm:~#
