Question on DVRRDK Decoder timestamp
Other Parts Discussed in Thread: TVP5158
I am using DVRRDK 3.0 and is trying the effect of different paramters in the Decode link.
I tried changing the time stamp parameter of the dec_disp demo and see that the video become slower as I increase the timestamp,
which is the same as what I expect.
And it still looks ok when I change the timestamp from 33ms to 500ms.
But when I further change it to 1000ms, for trying 1 fps video.
Either no video is seen, or it just keep showing one frame as if it is paused.
Why is this happening? is there other parameters (e.g. frame rate) that need to be change in dec, swms or display?
  • Are you getting any refClk adjust msgs ? Can you share the console logs (Running remote_debug_client). Also pls share the console logs with "a" command output.
    If timestamp difference is greater than a threshold avsync will treat it as a change in timebase and adjust the reference clock. You can check if this is the issue by modifying
    /dvr_rdk/mcfw/src_linux/mcfw_api/usecases/multich_vdec_vdis.c
    static
    Void mulich_vdec_vdis_set_avsync_vidque_prm(Avsync_SynchConfigParams *queCfg,
                                                Int chnum,
                                                UInt32 avsStartChNum,
                                                UInt32 avsEndChNum,
                                                VDIS_DEV vdDevId)
     Change
        queCfg->clkAdjustPolicy.clkAdjustLead = AVSYNC_VIDEO_TIMEBASESHIFT_MAX_LEAD_MS;
        queCfg->clkAdjustPolicy.clkAdjustLag  = AVSYNC_VIDEO_TIMEBASESHIFT_MAX_LAG_MS;
    to
        queCfg->clkAdjustPolicy.clkAdjustLead = 10000;
        queCfg->clkAdjustPolicy.clkAdjustLag  = 10000;
    Rebuild dvr rdk with this change and check if you still see the issue with 1 fps input
  • The changes I had made was demo_vdec_vdis_bits_rd.c
    static Void VdecVdis_setFrameTimeStamp(VCODEC_BITSBUF_S *pEmptyBuf)
        UInt64 curTimeStamp;
        if (pEmptyBuf->chnId == 0 || pEmptyBuf->chnId == 1)
            curTimeStamp = gVdecVdis_config.frameCnt[pEmptyBuf->chnId] * 1000;
        else
            curTimeStamp = gVdecVdis_config.frameCnt[pEmptyBuf->chnId] * VDEC_VDIS_FRAME_DURATION_MS;
        pEmptyBuf->lowerTimeStamp = (UInt32)(curTimeStamp & 0xFFFFFFFF);
        pEmptyBuf->upperTimeStamp = (UInt32)((curTimeStamp >> 32)& 0xFFFFFFFF);
        if (0 == gVdecVdis_config.frameCnt[pEmptyBuf->chnId])
            UInt32 displayChId;
            Vdec_mapDec2DisplayChId(VDIS_DEV_HDMI,pEmptyBuf->chnId,&displayChId);
            Vdis_setFirstVidPTS(VDIS_DEV_HDMI,displayChId,curTimeStamp);
            Vdec_mapDec2DisplayChId(VDIS_DEV_HDCOMP,pEmptyBuf->chnId,&displayChId);
            Vdis_setFirstVidPTS(VDIS_DEV_HDCOMP,displayChId,curTimeStamp);
            Vdec_mapDec2DisplayChId(VDIS_DEV_SD,pEmptyBuf->chnId,&displayChId);
            Vdis_setFirstVidPTS(VDIS_DEV_SD,displayChId,curTimeStamp);
        gVdecVdis_config.frameCnt[pEmptyBuf->chnId] += 1;
    I am decoding 4 h264 files, with ch 0 and ch 2 1920x1080, and ch1 and ch3 720x576. And now I tried your suggestion and change the following in multich_vdec_vdis.c
    static Void mulich_vdec_vdis_set_avsync_vidque_prm(Avsync_SynchConfigParams *queCfg,  Int chnum,  UInt32 avsStartChNum,   UInt32 avsEndChNum,  VDIS_DEV vdDevId)
         queCfg->chNum = chnum;
         queCfg->audioPresent = FALSE;
         if ((queCfg->chNum >= avsStartChNum)         &&         (queCfg->chNum <= avsEndChNum)         &&         (gVsysModuleContext.vsysConfig.enableAVsync))
            queCfg->avsyncEnable = TRUE;
        else
            queCfg->avsyncEnable = FALSE;
        queCfg->clkAdjustPolicy.refClkType = AVSYNC_REFCLKADJUST_NONE;
        queCfg->clkAdjustPolicy.clkAdjustLead = 10000;    //AVSYNC_VIDEO_TIMEBASESHIFT_MAX_LEAD_MS;
        queCfg->clkAdjustPolicy.clkAdjustLag  = 10000;     //AVSYNC_VIDEO_TIMEBASESHIFT_MAX_LAG_MS;
        queCfg->vidSynchPolicy.maxReplayLead  = AVSYNC_VIDEO_FUTURE_FRAME_DROP_THRESHOLD_MS;
        queCfg->vidSynchPolicy.playMaxLag  = 180;
        queCfg->vidSynchPolicy.playMaxLead = 0;
        queCfg->vidSynchPolicy.doMarginScaling = FALSE;
        queCfg->playTimerStartTimeout = 0;
        queCfg->playStartMode = AVSYNC_PLAYBACK_START_MODE_WAITSYNCH;
        queCfg->ptsInitMode   = AVSYNC_PTS_INIT_MODE_APP;
    but it still looks the same.
    VPSS_GRPX : (1)- venc 4 not running.  [m3video]  7801248: IPC_BITS_IN   : Create in progress !!!  [m3video]  7801248: SYSTEM: Opening ListMP [HOST_IPC_OUT_24] ...  [m3video]  7801248: SYSTEM: Opening ListMP [HOST_IPC_IN_24] ...  [m3video]  7801251: IPC_BITS_IN   : Create Done !!!  [m3video]  7801251: DECODE: Create in progress ... !!!  [m3video] DECLINK_H264:HEAPID:0        USED:2368  [m3video] DECLINK_H264:HEAPID:3        USED:8933376  [m3video]  7801375: DECODE: Creating CH0 of 1920 x 1080 [PROGRESSIVE] [NON-TILED  ],target bitrate = 2000 Kbps ...  [m3video] DECLINK_H264:HEAPID:0        USED:2368  [m3video] DECLINK_H264:HEAPID:3        USED:4501504  [m3video]  7801417: DECODE: Creating CH1 of 720 x 576 [PROGRESSIVE] [NON-TILED  ],target bitrate = 2000 Kbps ...  [m3video] DECLINK_H264:HEAPID:0        USED:2368  [m3video] DECLINK_H264:HEAPID:3        USED:8933376  [m3video]  7801541: DECODE: Creating CH2 of 1920 x 1080 [PROGRESSIVE] [NON-TILED  ],target bitrate = 2000 Kbps ...  [m3video] DECLINK_H264:HEAPID:0        USED:2368  [m3vpss ]  7801589: IPC_IN_M3   : Create in progress !!!  [m3video] DECLINK_H264:HEAPID:3        USED:4501504  [m3vpss ]  7801589: SYSTEM: Opening ListMP [VIDEO-M3_IPC_OUT_0] ...  [m3video]  7801583: DECODE: Creating CH3 of 720 x 576 [PROGRESSIVE] [NON-TILED  ],target bitrate = 2000 Kbps ...  [m3vpss ]  7801589: SYSTEM: Opening ListMP [VIDEO-M3_IPC_IN_0] ...  [m3video]  7801585: DECODE: All CH Create ... DONE !!!  [m3vpss ]  7801591: IPC_IN_M3   : Create Done !!!  [m3vpss ]  7801592: MP_SCLR: Create in progress !!!  [m3video] DECLINK:HEAPID:0     USED:9592  [m3vpss ]  UTILS: DMA: Allocated CH (TCC) = 58 (58)  [m3video] DECLINK:HEAPID:3     USED:72028160  [m3vpss ]  7801593: MP_SCLR: Create Done !!!  [m3video]  7801587: DECODE: Create ... DONE !!!  [m3vpss ]  7801598: DUP   : Create Done !!!  [m3video]  7801588: IPC_OUT_M3   : Create in progress !!!  [m3vpss ]  7801598: SWMS: Create in progress !!!  [m3video]  7801588: IPC_OUT_M3   : Create Done !!!  [m3vpss ]  UTILS: DMA: Allocated CH (TCC) = 59 (59)  [m3vpss ] SWMS: instance 0, sc id 4, start win 0 end win 15  [m3vpss ]  7801740: SWMS0    : Loading Vertical Co-effs (UPSCALE)x ...  [m3vpss ]  7801740: SWMS0    : Loading Horizontal Co-effs (UPSCALE)x ...  [m3vpss ]  7801740: SWMS    : Co-effs Loading ... DONE !!!  [m3vpss ] SWMS: instance 1, sc id 7, start win 16 end win 33  [m3vpss ]  7801740: SWMS    : VipScReq is FALSE!!!  [m3vpss ]  7801743: SWMS0    : Loading Vertical Co-effs (UPSCALE)x ...  [m3vpss ]  7801743: SWMS0    : Loading Horizontal Co-effs (UPSCALE)x ...  [m3vpss ]  7801743: SWMS    : Co-effs Loading ... DONE !!!  [m3vpss ]  7801744: SWMS    : ******* Configuring clock 32 secs...  [m3vpss ]  7801744: SWMS0    : Loading Vertical Co-effs (7/16)x ...  [m3vpss ]  7801744: SWMS0    : Loading Horizontal Co-effs (7/16)x ...  [m3vpss ]  7801744: SWMS    : Co-effs Loading ... DONE !!!  [m3vpss ]  [m3vpss ]  *** [SWMS0] Mosaic Parameters ***  [m3vpss ]  [m3vpss ]  Output FPS: 29  [m3vpss ]  [m3vpss ]  Win | Ch  | Input      | Input          | Input         | Input       | Output     |  Output         | Output        | Output      | Low Cost | SWMS | Data  | Blank |  [m3vpss ]  Num | Num | Start X, Y | Width x Height | Pitch Y / C   | Memory Type | Start X, Y |  Width x Height | Pitch Y / C   | Memory Type | ON / OFF | Inst | Format| Frame |  [m3vpss ]  ----------------------------------------------------------------------------------------------------------------------------------------------------------------------  [m3vpss ]    0 |   0 |    0,    0 |  1920 x   1080 |  2048 /  2048 | NON-TILED   |    0,    0 |   736 x    500 |  3840 /      0 | NON-TILED   |      OFF |    0 |  420SP |   OFF |  [m3vpss ]    1 |   1 |    0,    0 |   720 x    576 |   896 /   896 | NON-TILED   |  736,    0 |   736 x    500 |  3840 /      0 | NON-TILED   |      OFF |    0 |  420SP |   OFF |  [m3vpss ]    2 |   2 |    0,    0 |  1920 x   1080 |  2048 /  2048 | NON-TILED   |    0,  500 |   736 x    500 |  3840 /      0 | NON-TILED   |      OFF |    0 |  420SP |   OFF |  [m3vpss ]    3 |   3 |    0,    0 |   720 x    576 |   896 /   896 | NON-TILED   |  736,  500 |   736 x    500 |  3840 /      0 | NON-TILED   |      OFF |    0 |  420SP |   OFF |  [m3vpss ]    4 | 255 |    0,    0 |   352 x    132 |  1408 /  1408 | NON-TILED   | 1472,    0 |   368 x    250 |  3840 /      0 | NON-TILED   |      ON  |    0 |  422I  |   OFF |  [m3vpss ]    5 | 255 |    0,    0 |   352 x    132 |  1408 /  1408 | NON-TILED   | 1472,  250 |   368 x    250 |  3840 /      0 | NON-TILED   |      ON  |    0 |  422I  |   OFF |  [m3vpss ]    6 | 255 |    0,    0 |   352 x    132 |  1408 /  1408 | NON-TILED   | 1472,  500 |   368 x    250 |  3840 /      0 | NON-TILED   |      ON  |    0 |  422I  |   OFF |  [m3vpss ]    7 | 255 |    0,    0 |   352 x    132 |  1408 /  1408 | NON-TILED   | 1472,  750 |   368 x    250 |  3840 /      0 | NON-TILED   |      ON  |    0 |  422I  |   OFF |  [m3vpss ]  [m3vpss ] SWMS:HEAPID:0        USED:424  [m3vpss ] SWMS:HEAPID:1        USED:64352  [m3vpss ] SWMS:HEAPID:4        USED:29030400  [m3vpss ]  7801748: SWMS: Create Done !!!  [m3vpss ]  7801748: SWMS: Create in progress !!!  [m3vpss ]  UTILS: DMA: Allocated CH (TCC) = 60 (60)  [m3vpss ] SWMS: instance 0, sc id 6, start win 0 end win 15  [m3vpss ]  7801886: SWMS    : VipScReq is FALSE!!!  [m3vpss ]  7801889: SWMS1    : Loading Vertical Co-effs (UPSCALE)x ...  [m3vpss ]  7801889: SWMS1    : Loading Horizontal Co-effs (UPSCALE)x ...  [m3vpss ]  7801889: SWMS    : Co-effs Loading ... DONE !!!  [m3vpss ] SWMS: instance 1, sc id 5, start win 16 end win 33  [m3vpss ]  7801892: SWMS1    : Loading Vertical Co-effs (UPSCALE)x ...  [m3vpss ]  7801892: SWMS1    : Loading Horizontal Co-effs (UPSCALE)x ...  [m3vpss ]  7801893: SWMS    : Co-effs Loading ... DONE !!!  [m3vpss ]  7801893: SWMS    : ******* Configuring clock 30 secs...  [m3vpss ]  7801893: SWMS1    : Loading Vertical Co-effs (UPSCALE)x ...  [m3vpss ]  7801893: SWMS1    : Loading Horizontal Co-effs (UPSCALE)x ...  [m3vpss ]  7801893: SWMS    : Co-effs Loading ... DONE !!!  [m3vpss ]  [m3vpss ]  *** [SWMS1] Mosaic Parameters ***  [m3vpss ]  [m3vpss ]  Output FPS: 30  [m3vpss ]  [m3vpss ]  Win | Ch  | Input      | Input          | Input         | Input       | Output     |  Output         | Output        | Output      | Low Cost | SWMS | Data  | Blank |  [m3vpss ]  Num | Num | Start X, Y | Width x Height | Pitch Y / C   | Memory Type | Start X, Y |  Width x Height | Pitch Y / C   | Memory Type | ON / OFF | Inst | Format| Frame |  [m3vpss ]  ----------------------------------------------------------------------------------------------------------------------------------------------------------------------  [m3vpss ]    0 |   0 |    0,    0 |  1920 x   1080 |  2048 /  2048 | NON-TILED   |    0,    0 |  1920 x   1080 |  3840 /      0 | NON-TILED   |      OFF |    0 |  420SP |   OFF |  [m3vpss ]  [m3vpss ] SWMS:HEAPID:0        USED:424  [m3vpss ] SWMS:HEAPID:1        USED:61376  [m3vpss ] SWMS:HEAPID:4        USED:29030400  [m3vpss ]  7801895: SWMS: Create Done !!!  [m3vpss ]  7801895: DISPLAY: Create in progress !!!  [m3vpss ]  7801896: DISPLAY: Create Done !!!  [m3vpss ]  7801896: DISPLAY: Create in progress !!!  [m3vpss ]  7801897: DISPLAY: Create Done !!!  [m3vpss ]  7801898: SWMS    : ******* Configuring clock 30 secs...  [m3vpss ]  7801898: SWMS1    : Loading Vertical Co-effs (UPSCALE)x ...  [m3vpss ]  7801898: SWMS1    : Loading Horizontal Co-effs (UPSCALE)x ...  [m3vpss ]  7801899: SWMS    : Co-effs Loading ... DONE !!!  [m3vpss ]  [m3vpss ]  *** [SWMS1] Mosaic Parameters ***  [m3vpss ]  [m3vpss ]  Output FPS: 30  [m3vpss ]  [m3vpss ]  Win | Ch  | Input      | Input          | Input         | Input       | Output     |  Output         | Output        | Output      | Low Cost | SWMS | Data  | Blank |  [m3vpss ]  Num | Num | Start X, Y | Width x Height | Pitch Y / C   | Memory Type | Start X, Y |  Width x Height | Pitch Y / C   | Memory Type | ON / OFF | Inst | Format| Frame |  [m3vpss ]  ----------------------------------------------------------------------------------------------------------------------------------------------------------------------  [m3vpss ]    0 |   0 |    0,    0 |  1920 x   1080 |  2048 /  2048 | NON-TILED   |    0,    0 |  1920 x   1080 |  3840 /      0 | NON-TILED   |      OFF |    0 |  420SP |   OFF |  [m3vpss ]  [m3vpss ]  7801900: DISPLAY: Start in progress !!!  [m3vpss ]  7801941: DISPLAY: Start Done !!!  [m3vpss ]  7801941: DISPLAY: HDDAC(BP0) : 50 fps, Latency (Min / Max) = ( 255 / 0 ), Callback Interval (Min / Max) = ( 255 / 0 ) !!!  [m3vpss ]  7801941: DISPLAY: UNDERFLOW COUNT: HDMI(BP0) 0, HDDAC(BP0) 0, DVO2(BP1) 0, SDDAC(SEC1) 0  [m3vpss ]  7801941: SYSTEM  : FREE SPACE : System Heap      = 5792 B, Mbx = 10238 msgs)  [m3vpss ]  7801941: SYSTEM  : FREE SPACE : SR0 Heap         = 10998016 B (10 MB)  [m3vpss ]  7801941: SYSTEM  : FREE SPACE : Frame Buffer     = 110705536 B (105 MB)  [m3vpss ]  7801941: SYSTEM  : FREE SPACE : Bitstream Buffer = 188243840 B (179 MB)  [m3vpss ]  7801942: DISPLAY: Start in progress !!!  [m3vpss ]  7801942: SYSTEM  : FREE SPACE : Tiler Buffer     = 256 B (0 MB)  - TILER OFF  [m3vpss ]  7802007: DISPLAY: Start Done !!!  [m3vpss ]  7802008: DISPLAY: DVO2(BP1)  : 30 fps, Latency (Min / Max) = ( 255 / 0 ), Callback Interval (Min / Max) = ( 255 / 0 ) !!!  [m3vpss ]  7802008: SWMS: Start in Progress !!!  [m3vpss ]  7802008: SWMS: Start Done !!!  [m3vpss ]  7802008: SWMS: Start in Progress !!!  [m3vpss ]  7802008: SWMS: Start Done !!!  [m3vpss ] AVSYNC:AVSYNC_LINK_CMD_SET_FIRST_VIDPTS successConfig:DisplayID[0],ChID[0],FirstPTS[0]  [m3vpss ] AVSYNC:AVSYNC_LINK_CMD_SET_FIRST_VIDPTS successConfig:DisplayID[1],ChID[0],FirstPTS[0]  [m3vpss ] AVSYNC:AVSYNC_LINK_CMD_SET_FIRST_VIDPTS successConfig:DisplayID[0],ChID[2],FirstPTS[0]  [m3vpss ] AVSYNC:AVSYNC_LINK_CMD_SET_FIRST_VIDPTS successConfig:DisplayID[1],ChID[2],FirstPTS[0]  [m3vpss ] AVSYNC:AVSYNC_LINK_CMD_SET_FIRST_VIDPTS successConfig:DisplayID[0],ChID[1],FirstPTS[0]  [m3vpss ] AVSYNC:AVSYNC_LINK_CMD_SET_FIRST_VIDPTS successConfig:DisplayID[1],ChID[1],FirstPTS[0]  [m3vpss ] AVSYNC:AVSYNC_LINK_CMD_SET_FIRST_VIDPTS successConfig:DisplayID[0],ChID[3],FirstPTS[0]  [m3vpss ] AVSYNC:AVSYNC_LINK_CMD_SET_FIRST_VIDPTS successConfig:DisplayID[1],ChID[3],FirstPTS[0]  [m3vpss ] AVSYNC:Media Time Base:0,FirstVidPTS:0,FirstAudPTS:-1  [m3vpss ] AVSYNC:Media Time Base:0,FirstVidPTS:0,FirstAudPTS:-1  [m3vpss ]  SWMS: *** UPDATING RT Params ***  [m3vpss ]  7802126: SWMS    : ******* Configuring clock 32 secs...  [m3vpss ]  7802126: SWMS0    : Loading Vertical Co-effs (7/16)x ...  [m3vpss ]  7802126: SWMS0    : Loading Horizontal Co-effs (7/16)x ...  [m3vpss ]  7802127: SWMS    : Co-effs Loading ... DONE !!!  [m3vpss ]  [m3vpss ]  *** [SWMS0] Mosaic Parameters ***  [m3vpss ]  [m3vpss ]  Output FPS: 29  [m3vpss ]  [m3vpss ]  Win | Ch  | Input      | Input          | Input         | Input       | Output     |  Output         | Output        | Output      | Low Cost | SWMS | Data  | Blank |  [m3vpss ]  Num | Num | Start X, Y | Width x Height | Pitch Y / C   | Memory Type | Start X, Y |  Width x Height | Pitch Y / C   | Memory Type | ON / OFF | Inst | Format| Frame |  [m3vpss ]  ----------------------------------------------------------------------------------------------------------------------------------------------------------------------  [m3vpss ]    0 |   0 |    0,    0 |  1920 x   1080 |  2048 /  2048 | NON-TILED   |    0,    0 |   736 x    500 |  3840 /      0 | NON-TILED   |      OFF |    0 |  420SP |   OFF |  [m3vpss ]    1 |   1 |    0,    0 |   720 x    576 |   896 /   896 | NON-TILED   |  736,    0 |   736 x    500 |  3840 /      0 | NON-TILED   |      OFF |    0 |  420SP |   OFF |  [m3vpss ]    2 |   2 |    0,    0 |  1920 x   1080 |  2048 /  2048 | NON-TILED   |    0,  500 |   736 x    500 |  3840 /      0 | NON-TILED   |      OFF |    0 |  420SP |   OFF |  [m3vpss ]    3 |   3 |    0,    0 |   704 x    576 |   896 /   896 | NON-TILED   |  736,  500 |   736 x    500 |  3840 /      0 | NON-TILED   |      OFF |    0 |  420SP |   OFF |  [m3vpss ]    4 | 255 |    0,    0 |   352 x    132 |  1408 /  1408 | NON-TILED   | 1472,    0 |   368 x    250 |  3840 /      0 | NON-TILED   |      ON  |    0 |  422I  |   OFF |  [m3vpss ]    5 | 255 |    0,    0 |   352 x    132 |  1408 /  1408 | NON-TILED   | 1472,  250 |   368 x    250 |  3840 /      0 | NON-TILED   |      ON  |    0 |  422I  |   OFF |  [m3vpss ]    6 | 255 |    0,    0 |   352 x    132 |  1408 /  1408 | NON-TILED   | 1472,  500 |   368 x    250 |  3840 /      0 | NON-TILED   |      ON  |    0 |  422I  |   OFF |  [m3vpss ]    7 | 255 |    0,    0 |   352 x    132 |  1408 /  1408 | NON-TILED   | 1472,  750 |   368 x    250 |  3840 /      0 | NON-TILED   |      ON  |    0 |  422I  |   OFF |  [m3vpss ]
    root@dm816x:/opt/dvr_rdk/ti816x# root@dm816x:/opt/dvr_rdk/ti816x# root@dm816x:/opt/dvr_rdk/ti816x#  [m3vpss ]  7884734: SWMS    : ******* Configuring clock 32 secs...  [m3vpss ]  7884734: SWMS0    : Loading Vertical Co-effs (8/16)x ...  [m3vpss ]  7884734: SWMS0    : Loading Horizontal Co-effs (9/16)x ...  [m3vpss ]  7884734: SWMS    : Co-effs Loading ... DONE !!!  [m3vpss ]  [m3vpss ]  *** [SWMS0] Mosaic Parameters ***  [m3vpss ]  [m3vpss ]  Output FPS: 29  [m3vpss ]  [m3vpss ]  Win | Ch  | Input      | Input          | Input         | Input       | Output     |  Output         | Output        | Output      | Low Cost | SWMS | Data  | Blank |  [m3vpss ]  Num | Num | Start X, Y | Width x Height | Pitch Y / C   | Memory Type | Start X, Y |  Width x Height | Pitch Y / C   | Memory Type | ON / OFF | Inst | Format| Frame |  [m3vpss ]  ----------------------------------------------------------------------------------------------------------------------------------------------------------------------  [m3vpss ]    0 |   0 |    0,    0 |  1920 x   1080 |  2048 /  2048 | NON-TILED   |    0,    0 |   960 x    540 |  3840 /      0 | NON-TILED   |      OFF |    0 |  420SP |   OFF |  [m3vpss ]    1 |   1 |    0,    0 |   720 x    576 |   896 /   896 | NON-TILED   |  960,    0 |   960 x    540 |  3840 /      0 | NON-TILED   |      OFF |    0 |  420SP |   OFF |  [m3vpss ]    2 |   2 |    0,    0 |  1920 x   1080 |  2048 /  2048 | NON-TILED   |    0,  540 |   960 x    540 |  3840 /      0 | NON-TILED   |      OFF |    0 |  420SP |   OFF |  [m3vpss ]    3 |   3 |    0,    0 |   704 x    576 |   896 /   896 | NON-TILED   |  960,  540 |   960 x    540 |  3840 /      0 | NON-TILED   |      OFF |    0 |  420SP |   OFF |  [m3vpss ]  [m3vpss ]  7884737: SWMS    : ******* Configuring clock 32 secs...  [m3vpss ]  7884737: SWMS1    : Loading Vertical Co-effs (8/16)x ...  [m3vpss ]  7884737: SWMS1    : Loading Horizontal Co-effs (9/16)x ...  [m3vpss ]  7884738: SWMS    : Co-effs Loading ... DONE !!!  [m3vpss ]  [m3vpss ]  *** [SWMS1] Mosaic Parameters ***  [m3vpss ]  [m3vpss ]  Output FPS: 29  [m3vpss ]  [m3vpss ]  Win | Ch  | Input      | Input          | Input         | Input       | Output     |  Output         | Output        | Output      | Low Cost | SWMS | Data  | Blank |  [m3vpss ]  Num | Num | Start X, Y | Width x Height | Pitch Y / C   | Memory Type | Start X, Y |  Width x Height | Pitch Y / C   | Memory Type | ON / OFF | Inst | Format| Frame |  [m3vpss ]  ----------------------------------------------------------------------------------------------------------------------------------------------------------------------  [m3vpss ]    0 |   0 |    0,    0 |  1920 x   1080 |  2048 /  2048 | NON-TILED   |    0,    0 |   960 x    540 |  3840 /      0 | NON-TILED   |      OFF |    0 |  420SP |   OFF |  [m3vpss ]    1 |   1 |    0,    0 |   720 x    576 |   896 /   896 | NON-TILED   |  960,    0 |   960 x    540 |  3840 /      0 | NON-TILED   |      OFF |    0 |  420SP |   OFF |  [m3vpss ]    2 |   2 |    0,    0 |  1920 x   1080 |  2048 /  2048 | NON-TILED   |    0,  540 |   960 x    540 |  3840 /      0 | NON-TILED   |      OFF |    0 |  420SP |   OFF |  [m3vpss ]    3 |   3 |    0,    0 |   720 x    576 |   896 /   896 | NON-TILED   |  960,  540 |   960 x    540 |  3840 /      0 | NON-TILED   |      OFF |    0 |  420SP |   OFF |  [m3vpss ]  [m3vpss ] AVSYNC:Media Time Base:82532,FirstVidPTS:82533,FirstAudPTS:-1  [m3vpss ] AVSYNC:Media Time Base:82532,FirstVidPTS:82533,FirstAudPTS:-1  [m3vpss ]  SWMS: *** UPDATING RT Params ***  [m3vpss ]  7884843: SWMS    : ******* Configuring clock 32 secs...  [m3vpss ]  7884843: SWMS1    : Loading Vertical Co-effs (8/16)x ...  [m3vpss ]  7884843: SWMS1    : Loading Horizontal Co-effs (9/16)x ...  [m3vpss ]  7884843: SWMS    : Co-effs Loading ... DONE !!!  [m3vpss ]  [m3vpss ]  *** [SWMS1] Mosaic Parameters ***  [m3vpss ]  [m3vpss ]  Output FPS: 29  [m3vpss ]  [m3vpss ]  Win | Ch  | Input      | Input          | Input         | Input       | Output     |  Output         | Output        | Output      | Low Cost | SWMS | Data  | Blank |  [m3vpss ]  Num | Num | Start X, Y | Width x Height | Pitch Y / C   | Memory Type | Start X, Y |  Width x Height | Pitch Y / C   | Memory Type | ON / OFF | Inst | Format| Frame |  [m3vpss ]  ----------------------------------------------------------------------------------------------------------------------------------------------------------------------  [m3vpss ]    0 |   0 |    0,    0 |  1920 x   1080 |  2048 /  2048 | NON-TILED   |    0,    0 |   960 x    540 |  3840 /      0 | NON-TILED   |      OFF |    0 |  420SP |   OFF |  [m3vpss ]    1 |   1 |    0,    0 |   704 x    576 |   896 /   896 | NON-TILED   |  960,    0 |   960 x    540 |  3840 /      0 | NON-TILED   |      OFF |    0 |  420SP |   OFF |  [m3vpss ]    2 |   2 |    0,    0 |  1920 x   1080 |  2048 /  2048 | NON-TILED   |    0,  540 |   960 x    540 |  3840 /      0 | NON-TILED   |      OFF |    0 |  420SP |   OFF |  [m3vpss ]    3 |   3 |    0,    0 |   704 x    576 |   896 /   896 | NON-TILED   |  960,  540 |   960 x    540 |  3840 /      0 | NON-TILED   |      OFF |    0 |  420SP |   OFF |
    and this is what I get when pressing the 'a', the print avsync command. It seems ch0 and ch1 is not functioning?
     AVSYNC:PlayerTimer Stats  AVSYNC:PlayerTimer Stats DisplayID:0  AVSYNC:PlayerTimer Stats NumCh:4  Chn | Positive Negative  LastVid LastAud  Num | ClkAdj   ClkAdj    PTS     PTS      | Count    Count  ----------------------------------------    2|        0        0  974853      -1    3|        0        0  974853      -1  AVSYNC:Video Stats  AVSYNC:Video Stats DisplayID:0  AVSYNC:Video Stats NumCh:4  Chn | Play  Replay Skip  Skip  Underrun Overflow      | Count Count  Early Late  -------------------------------------------------    2|  2716      1    23 26803     25442        0    3|  2720      1    23 26799     26532        0  AVSYNC:PlayerTimer Stats  AVSYNC:PlayerTimer Stats DisplayID:1  AVSYNC:PlayerTimer Stats NumCh:4  Chn | Positive Negative  LastVid LastAud  Num | ClkAdj   ClkAdj    PTS     PTS      | Count    Count  ----------------------------------------    2|        0        0  974754      -1    3|        0        0  974754      -1  AVSYNC:Video Stats  AVSYNC:Video Stats DisplayID:1  AVSYNC:Video Stats NumCh:4  Chn | Play  Replay Skip  Skip  Underrun Overflow      | Count Count  Early Late  -------------------------------------------------    2| 26771      2   266    0         0        0    3| 26771      2   266    0         0        0  AVSYNC:Capture TS Avg Delta  Chn | Avg      | Delta  ----------------------------    0|     0    1|     0    2|     0    3|     0    4|     0    5|     0    6|     0    7|     0    8|     0    9|     0   10|     0   11|     0   12|     0   13|     0   14|     0   15|     0  AVSYNC:IPCBITSOUT TS Avg Delta  Chn | Avg      | Delta  ----------------------------    0|   998    1|   998    2|    32    3|    32    4|     0    5|     0    6|     0    7|     0    8|     0    9|     0   10|     0   11|     0   12|     0   13|     0   14|     0   15|     0  AVGPTSDELTA NUMPLAY NUMSKIP NUMREPLAY NUMCLKADJ            0       0       0         0         0  ChNum | AVGPTSDELTA NUMPLAY NUMSKIP NUMREPLAY NUMUNDERUN      0 |           0       0       0         0          0      1 |           0       0       0         0          0      2 |           0     827      44         0        827      3 |           0     862       9         0        862      4 |           0       0       0         0          0      5 |           0       0       0         0          0      6 |           0       0       0         0          0      7 |           0       0       0         0          0      8 |           0       0       0         0          0      9 |           0       0       0         0          0     10 |           0       0       0         0          0     11 |           0       0       0         0          0     12 |           0       0       0         0          0     13 |           0       0       0         0          0     14 |           0       0       0         0          0     15 |           0       0       0         0          0     16 |           0       0       0         0          0     17 |           0       0       0         0          0     18 |           0       0       0         0          0     19 |           0       0       0         0          0     20 |           0       0       0         0          0     21 |           0       0       0         0          0     22 |           0       0       0         0          0     23 |           0       0       0         0          0     24 |           0       0       0         0          0     25 |           0       0       0         0          0     26 |           0       0       0         0          0     27 |           0       0       0         0          0     28 |           0       0       0         0          0     29 |           0       0       0         0          0     30 |           0       0       0         0          0     31 |           0       0       0         0          0  AVGPTSDELTA NUMPLAY NUMSKIP NUMREPLAY NUMCLKADJ            0       0       0         0         0  ChNum | AVGPTSDELTA NUMPLAY NUMSKIP NUMREPLAY NUMUNDERUN      0 |           0       0       0         0          0      1 |           0       0       0         0          0      2 |        -162     411       4         0          0      3 |        -162     411       4         0          0      4 |           0       0       0         0          0      5 |           0       0       0         0          0      6 |           0       0       0         0          0      7 |           0       0       0         0          0      8 |           0       0       0         0          0      9 |           0       0       0         0          0     10 |           0       0       0         0          0     11 |           0       0       0         0          0     12 |           0       0       0         0          0     13 |           0       0       0         0          0     14 |           0       0       0         0          0     15 |           0       0       0         0          0     16 |           0       0       0         0          0     17 |           0       0       0         0          0     18 |           0       0       0         0          0     19 |           0       0       0         0          0     20 |           0       0       0         0          0     21 |           0       0       0         0          0     22 |           0       0       0         0          0     23 |           0       0       0         0          0     24 |           0       0       0         0          0     25 |           0       0       0         0          0     26 |           0       0       0         0          0     27 |           0       0       0         0          0     28 |           0       0       0         0          0     29 |           0       0       0         0          0     30 |           0       0       0         0          0     31 |           0       0       0         0          0  AVGPTSDELTA NUMPLAY NUMSKIP NUMREPLAY NUMCLKADJ            0       0       0         0         0  ChNum | AVGPTSDELTA NUMPLAY NUMSKIP NUMREPLAY NUMUNDERUN      0 |           0       0       0         0          0      1 |           0       0       0         0          0      2 |           0       0       0         0          0      3 |           0       0       0         0          0      4 |           0       0       0         0          0      5 |           0       0       0         0          0      6 |           0       0       0         0          0      7 |           0       0       0         0          0      8 |           0       0       0         0          0      9 |           0       0       0         0          0     10 |           0       0       0         0          0     11 |           0       0       0         0          0     12 |           0       0       0         0          0     13 |           0       0       0         0          0     14 |           0       0       0         0          0     15 |           0       0       0         0          0     16 |           0       0       0         0          0     17 |           0       0       0         0          0     18 |           0       0       0         0          0     19 |           0       0       0         0          0     20 |           0       0       0         0          0     21 |           0       0       0         0          0     22 |           0       0       0         0          0     23 |           0       0       0         0          0     24 |           0       0       0         0          0     25 |           0       0       0         0          0     26 |           0       0       0         0          0     27 |           0       0       0         0          0     28 |           0       0       0         0          0     29 |           0       0       0         0          0     30 |           0       0       0         0          0     31 |           0       0       0         0          0
  • and this is what I get if I type 'i' print detailed system information. (not in the same executaion as ablove post, just re-run to get this extra information for your reference)
     [m3vpss ]  *** [SWMS0] Mosaic Statistics ***  [m3vpss ]  [m3vpss ]  Elasped Time: 20 secs  [m3vpss ]  [m3vpss ]  Output Request FPS   : 31 fps (622 frames)  [m3vpss ]  Output Actual  FPS   : 31 fps (622 frames)  [m3vpss ]  Output Drop    FPS   : 0 fps (0 frames)  [m3vpss ]  Output Reject  FPS   : 0 fps (0 frames)  [m3vpss ]  Scaling Internal     : 33 ms  [m3vpss ]  Scaling Internal min : 30 ms  [m3vpss ]  Scaling Internal max : 37 ms  [m3vpss ]  [m3vpss ]  Win | Window Repeat Drop Recv Que  FID Invlid Acc Event          Invalid   Que Reject Reject Latency  [m3vpss ]  Num | FPS    FPS    FPS  FPS  FPS  FPS        Count (Max/Min)    CH Frames Frames     Frames Min / Max  [m3vpss ]  ------------------------------------------------------------------------------------------------------  [m3vpss ]    0 |      0     31   31    0    0          0        0 (  0/255)         0          0      0 255 /   0  [m3vpss ]    1 |      0     31   31    0    0          0        0 (  0/255)         0          0      0 255 /   0  [m3vpss ]    2 |     31      1    1    0   29          0        0 (  0/255)         0          0      0 255 / 11488826  [m3vpss ]    3 |     31      0    0    0   31          0        0 (  0/255)         0          0      0 255 / 11488826  [m3vpss ]  [m3vpss ]  [m3vpss ]  *** [SWMS0] Mosaic Parameters ***  [m3vpss ]  [m3vpss ]  Output FPS: 29  [m3vpss ]  [m3vpss ]  Win | Ch  | Input      | Input          | Input         | Input       | Output     |  Output         | Output        | Output      | Low Cost | SWMS | Data  | Blank |  [m3vpss ]  Num | Num | Start X, Y | Width x Height | Pitch Y / C   | Memory Type | Start X, Y |  Width x Height | Pitch Y / C   | Memory Type | ON / OFF | Inst | Format| Frame |  [m3vpss ]  ----------------------------------------------------------------------------------------------------------------------------------------------------------------------  [m3vpss ]    0 |   0 |    0,    0 |  1920 x   1080 |  2048 /  2048 | NON-TILED   |    0,    0 |   960 x    540 |  3840 /      0 | NON-TILED   |      OFF |    0 |  420SP |   ON  |  [m3vpss ]    1 |   1 |    0,    0 |   720 x    576 |   896 /   896 | NON-TILED   |  960,    0 |   960 x    540 |  3840 /      0 | NON-TILED   |      OFF |    0 |  420SP |   ON  |  [m3vpss ]    2 |   2 |    0,    0 |  1920 x   1080 |  2048 /  2048 | NON-TILED   |    0,  540 |   960 x    540 |  3840 /      0 | NON-TILED   |      OFF |    0 |  420SP |   OFF |  [m3vpss ]    3 |   3 |    0,    0 |   704 x    576 |   896 /   896 | NON-TILED   |  960,  540 |   960 x    540 |  3840 /      0 | NON-TILED   |      OFF |    0 |  420SP |   OFF |  [m3vpss ]  [m3vpss ]  [m3vpss ]  [m3vpss ]  *** [SWMS1] Mosaic Statistics ***  [m3vpss ]  [m3vpss ]  Elasped Time: 20 secs  [m3vpss ]  [m3vpss ]  Output Request FPS   : 31 fps (623 frames)  [m3vpss ]  Output Actual  FPS   : 31 fps (623 frames)  [m3vpss ]  Output Drop    FPS   : 0 fps (0 frames)  [m3vpss ]  Output Reject  FPS   : 0 fps (0 frames)  [m3vpss ]  Scaling Internal     : 33 ms  [m3vpss ]  Scaling Internal min : 31 ms  [m3vpss ]  Scaling Internal max : 37 ms  [m3vpss ]  [m3vpss ]  Win | Window Repeat Drop Recv Que  FID Invlid Acc Event          Invalid   Que Reject Reject Latency  [m3vpss ]  Num | FPS    FPS    FPS  FPS  FPS  FPS        Count (Max/Min)    CH Frames Frames     Frames Min / Max  [m3vpss ]  ------------------------------------------------------------------------------------------------------  [m3vpss ]    0 |      0     31   31    0    0          0        0 (  0/255)         0          0      0 255 /   0  [m3vpss ]    1 |     31     31   31    0    0          0        0 (  0/255)         0          0      0 255 / 11488863  [m3vpss ]    2 |     31      0    0    0   31          0        0 (  0/255)         0          0      0 255 / 11488863  [m3vpss ]    3 |     31      0    0    0   31          0        0 (  0/255)         0          0      0 255 / 11488863  [m3vpss ]  [m3vpss ]  [m3vpss ]  *** [SWMS1] Mosaic Parameters ***  [m3vpss ]  [m3vpss ]  Output FPS: 29  [m3vpss ]  [m3vpss ]  Win | Ch  | Input      | Input          | Input         | Input       | Output     |  Output         | Output        | Output      | Low Cost | SWMS | Data  | Blank |  [m3vpss ]  Num | Num | Start X, Y | Width x Height | Pitch Y / C   | Memory Type | Start X, Y |  Width x Height | Pitch Y / C   | Memory Type | ON / OFF | Inst | Format| Frame |  [m3vpss ]  ----------------------------------------------------------------------------------------------------------------------------------------------------------------------  [m3vpss ]    0 |   0 |    0,    0 |  1920 x   1080 |  2048 /  2048 | NON-TILED   |    0,    0 |   960 x    540 |  3840 /      0 | NON-TILED   |      OFF |    0 |  420SP |   ON  |  [m3vpss ]    1 |   1 |    0,    0 |   704 x    576 |   896 /   896 | NON-TILED   |  960,    0 |   960 x    540 |  3840 /      0 | NON-TILED   |      OFF |    0 |  420SP |   OFF |  [m3vpss ]    2 |   2 |    0,    0 |  1920 x   1080 |  2048 /  2048 | NON-TILED   |    0,  540 |   960 x    540 |  3840 /      0 | NON-TILED   |      OFF |    0 |  420SP |   OFF |  [m3vpss ]    3 |   3 |    0,    0 |   704 x    576 |   896 /   896 | NON-TILED   |  960,  540 |   960 x    540 |  3840 /      0 | NON-TILED   |      OFF |    0 |  420SP |   OFF |  [m3vpss ]  [m3vpss ]  [m3vpss ]  11488878: DISPLAY: HDDAC(BP0) : 59 fps, Latency (Min / Max) = ( 15 / 50 ), Callback Interval (Min / Max) = ( 16 / 17 ) !!!  [m3vpss ]  11488878: DISPLAY: UNDERFLOW COUNT: HDMI(BP0) 13568, HDDAC(BP0) 13568, DVO2(BP1) 13568, SDDAC(SEC1) 13569  [m3vpss ]  11488879: SYSTEM  : FREE SPACE : System Heap      = 5792 B, Mbx = 10239 msgs)  [m3vpss ]  11488879: SYSTEM  : FREE SPACE : SR0 Heap         = 10993792 B (10 MB)  [m3vpss ]  11488879: SYSTEM  : FREE SPACE : Frame Buffer     = 110705536 B (105 MB)  [m3vpss ]  11488879: SYSTEM  : FREE SPACE : Bitstream Buffer = 188243840 B (179 MB)  [m3vpss ]  11488879: SYSTEM  : FREE SPACE : Tiler Buffer     = 256 B (0 MB)  - TILER OFF  [m3vpss ]  11488880: DISPLAY: DVO2(BP1)  : 59 fps, Latency (Min / Max) = ( 15 / 50 ), Callback Interval (Min / Max) = ( 16 / 17 ) !!!  [m3video]      11492880: HDVICP-ID:0  [m3video] All percentage figures are based off totalElapsedTime  [m3video]               totalAcquire2wait :0 %  [m3video]               totalWait2Isr :41 %  [m3video]               totalIsr2Done :0 %  [m3video]               totalWait2Done :41 %  [m3video]               totalDone2Release :0 %  [m3video]               totalAcquire2Release :42 %  [m3video]               totalAcq2acqDelay :57 %  [m3video]               totalElapsedTime in msec :  245974  [m3video]               numAccessCnt:  177888  [m3video]              IVA-FPS :     726  [m3video]              Average time spent per frame in microsec:     566  [m3video]      11492881: HDVICP-ID:1  [m3video] All percentage figures are based off totalElapsedTime  [m3video]               totalAcquire2wait :0 %  [m3video]               totalWait2Isr :9 %  [m3video]               totalIsr2Done :0 %  [m3video]               totalWait2Done :9 %  [m3video]               totalDone2Release :0 %  [m3video]               totalAcquire2Release :9 %  [m3video]               totalAcq2acqDelay :90 %  [m3video]               totalElapsedTime in msec :  245960  [m3video]               numAccessCnt:   88536  [m3video]              IVA-FPS :     361  [m3video]              Average time spent per frame in microsec:     250  [m3video]      11492881: HDVICP-ID:2  [m3video] All percentage figures are based off totalElapsedTime  [m3video]               totalAcquire2wait :0 %  [m3video]               totalWait2Isr :35 %  [m3video]               totalIsr2Done :0 %  [m3video]               totalWait2Done :35 %  [m3video]               totalDone2Release :0 %  [m3video]               totalAcquire2Release :35 %  [m3video]               totalAcq2acqDelay :64 %  [m3video]               totalElapsedTime in msec :  245972  [m3video]               numAccessCnt:   89340  [m3video]              IVA-FPS :     364  [m3video]              Average time spent per frame in microsec:     963  [m3video]  [m3video]  *** DECODE Statistics ***  [m3video]  [m3video]  Elasped Time           : 226 secs  [m3video]  [m3video]  [m3video]  CH  | In Recv In User  Out  [m3video]  Num | FPS     Skip FPS FPS  [m3video]  -----------------------------------  [m3video]    0 |      30        0  30  [m3video]    1 |      29        0  29  [m3video]    2 |      30        0  30  [m3video]    3 |      30        0  30  [m3video]  [m3video] Multi Channel Decode Average Submit Batch Size  [m3video] Max Submit Batch Size : 24  [m3video] IVAHD_0 Average Batch Size : 1  [m3video] IVAHD_0 Max achieved Batch Size : 1  [m3video] IVAHD_1 Average Batch Size : 1  [m3video] IVAHD_1 Max achieved Batch Size : 1  [m3video] IVAHD_2 Average Batch Size : 1  [m3video] IVAHD_2 Max achieved Batch Size : 1  [m3video]  [m3video] Multi Channel Decode Batch break Stats  [m3video] Total Number of Batches created: 13627  [m3video] All numbers are based off total number of Batches created  [m3video]       Batch breaks due to batch sizeexceeding limit: 49 %  [m3video]       Batch breaks due to ReqObj Que being empty: 50 %  [m3video]       Batch breaks due to changed resolution class: 0 %  [m3video]       Batch breaks due to interlace and progressivecontent mix: 0 %  [m3video]       Batch breaks due to channel repeat: 0 %  [m3video]       Batch breaks due to different codec: 0 %  [m3video] Total Number of Batches created: 6779  [m3video] All numbers are based off total number of Batches created  [m3video]       Batch breaks due to batch sizeexceeding limit: 0 %  [m3video]       Batch breaks due to ReqObj Que being empty: 100 %  [m3video]       Batch breaks due to changed resolution class: 0 %  [m3video]       Batch breaks due to interlace and progressivecontent mix: 0 %  [m3video]       Batch breaks due to channel repeat: 0 %  [m3video]       Batch breaks due to different codec: 0 %  [m3video] Total Number of Batches created: 6847  [m3video] All numbers are based off total number of Batches created  [m3video]       Batch breaks due to batch sizeexceeding limit: 100 %  [m3video]       Batch breaks due to ReqObj Que being empty: 0 %  [m3video]       Batch breaks due to changed resolution class: 0 %  [m3video]       Batch breaks due to interlace and progressivecontent mix: 0 %  [m3video]       Batch breaks due to channel repeat: 0 %  [m3video]       Batch breaks due to different codec: 0 %  [m3video]  [m3vpss ]  [m3vpss ]  *** [MP_SCLR0 ] Statistics ***  [m3vpss ]  [m3vpss ]  Total Frames Received  : 29887  [m3vpss ]  Total Frames Forwarded : 29887  [m3vpss ]  [m3vpss ]  [m3vpss ]  CH  | In Recv In Reject Processed  Latency(DRV) Processed  Rejected  [m3vpss ]  Num | FPS     FPS       FPS        Min / Max    Frames     Frames  [m3vpss ]  -------------------------------------------------------------------  [m3vpss ]  [m3vpss ]  11494886: LOAD: CPU: 9.4% HWI: 2.9%, SWI:1.4%  [m3vpss ]  [m3vpss ]  11494886: LOAD: TSK: IPC_IN_M30          : 0.5%  [m3vpss ]  11494886: LOAD: TSK: DISPLAY0            : 0.3%  [m3vpss ]  11494886: LOAD: TSK: DISPLAY1            : 0.2%  [m3vpss ]  11494886: LOAD: TSK: DUP0                : 0.4%  [m3vpss ]  11494886: LOAD: TSK: SWMS0               : 1.5%  [m3vpss ]  11494886: LOAD: TSK: SWMS1               : 1.2%  [m3vpss ]  11494886: LOAD: TSK: MP_SCLR_FWD_Q0      : 0.3%  [m3vpss ]  11494887: LOAD: TSK: MISC                : 0.7%  [m3vpss ]  [m3video]  [m3video]  11495387: LOAD: CPU: 8.5% HWI: 0.9%, SWI:1.0%  [m3video]  [m3video]  11495387: LOAD: TSK: IPC_OUT_M30         : 1.0%  [m3video]  11495387: LOAD: TSK: IPC_BITS_IN0        : 0.3%  [m3video]  11495387: LOAD: TSK: DEC0                : 1.8%  [m3video]  11495388: LOAD: TSK: DEC_PROCESS_TSK_0   : 1.5%  [m3video]  11495388: LOAD: TSK: DEC_PROCESS_TSK_1   : 1.0%  [m3video]  11495388: LOAD: TSK: DEC_PROCESS_TSK_2   : 0.7%  [m3video]  11495388: LOAD: TSK: MISC                : 0.3%  [m3video]  [c6xdsp ]  [c6xdsp ]  11682567: LOAD: CPU: 0.1% HWI: 0.0%, SWI:0.0%  [c6xdsp ]  [c6xdsp ]  11682567: LOAD: TSK: MISC                : 0.1%  [c6xdsp ]
  • The logs formatting is messed up and I cant understand anything from it.Pls save logs to file and attach it.
    ALso is your intention to do slow playback at 1 fps ? Then it is not correct to change the timestamp. To do slow playback don't change the original PTS. Instead use the API:
    Int32 Vdis_setPlaybackSpeed(VDIS_DEV vdDevId,VDIS_CHN vdispChnId, UInt32 timeScaleX1000,                             UInt32 seqId)
    where playback speed can be specified .1000 indicates 1x playback. If you want to playback a 30 fps stream at 1 fps you should use 33 as playback speed param.
    Refer /dvr_rdk/demos/mcfw_api_demos/mcfw_demo/demo_display.c for example code.
  • Ok, I will regenerate the log, thanks.
    I know we can change the playback speed using Int32 Vdis_setPlaybackSpeed(VDIS_DEV vdDevId,VDIS_CHN vdispChnId, UInt32 timeScaleX1000,                             UInt32 seqId)
    But I am trying to change the time stamp because we need to be able to change the encoded frame rate to slowest of 1 fps. And in this case, i think having a time stamp difference of 1 sec during playback should be the right way to do so?
  • The setting is the same as previous post.
    For Ch0 and Ch1, curTimeStamp = gVdecVdis_config.frameCnt[pEmptyBuf->chnId] * 1000;
    For Ch2 and Ch3, curTimeStamp = gVdecVdis_config.frameCnt[pEmptyBuf->chnId] * VDEC_VDIS_FRAME_DURATION_MS;
    Ch1 is a file that only the I-frame is saved, while other Ch are normal files,
    Attached is the log file, and I post it below too.
     [m3video]  1200256: IPC_BITS_IN   : Create in progress !!!
     [m3video]  1200256: SYSTEM: Opening ListMP [HOST_IPC_OUT_24] ...
     [m3video]  1200256: SYSTEM: Opening ListMP [HOST_IPC_IN_24] ...
     [m3video]  1200257: SYSTEM: Opening MsgQ [HOST_MSGQ] ...
     [m3video]  1200259: IPC_BITS_IN   : Create Done !!!
     [m3video]  1200259: DECODE: Create in progress ... !!!
     [m3video] DECLINK_H264:HEAPID:0        USED:4264
     [m3video]  1200384: DECODE: Creating CH0 of 1920 x 1080 [PROGRESSIVE] [NON-TILED  ],target bitrate = 2000 Kbps ...
     [m3video]  1200426: DECODE: Creating CH1 of 720 x 576 [PROGRESSIVE] [NON-TILED  ],target bitrate = 2000 Kbps ...
     [m3video]  1200549: DECODE: Creating CH2 of 1920 x 1080 [PROGRESSIVE] [NON-TILED  ],target bitrate = 2000 Kbps ...
     [m3video]  1200592: DECODE: Creating CH3 of 720 x 576 [PROGRESSIVE] [NON-TILED  ],target bitrate = 2000 Kbps ...
     [m3video]  1200593: DECODE: All CH Create ... DONE !!!
     [m3vpss ]  1200598: IPC_IN_M3   : Create in progress !!!
     [m3vpss ]  1200598: SYSTEM: Opening ListMP [VIDEO-M3_IPC_OUT_0] ...
     [m3vpss ]  1200598: SYSTEM: Opening ListMP [VIDEO-M3_IPC_IN_0] ...
     [m3video] DECLINK:HEAPID:0     USED:11488
     [m3vpss ]  1200599: SYSTEM: Opening MsgQ [VIDEO-M3_MSGQ] ...
     [m3vpss ]  1200600: IPC_IN_M3   : Create Done !!!
     [m3video]  1200596: DECODE: Create ... DONE !!!
     [m3vpss ]  1200601: MP_SCLR: Create in progress !!!
     [m3video]  1200597: IPC_OUT_M3   : Create in progress !!!
     [m3video]  1200597: IPC_OUT_M3   : Create Done !!!
     [m3vpss ]  1200602: MP_SCLR: Create Done !!!
     [m3vpss ]  1200607: DUP   : Create Done !!!
     [m3vpss ]  1200608: SWMS: Create in progress !!!
     [m3vpss ]  1200749: SWMS0    : Loading Vertical Co-effs (UPSCALE)x ...
     [m3vpss ]  1200749: SWMS0    : Loading Horizontal Co-effs (UPSCALE)x ...
     [m3vpss ]  1200749: SWMS    : Co-effs Loading ... DONE !!!
     [m3vpss ]  1200749: SWMS    : VipScReq is FALSE!!!
     [m3vpss ]  1200752: SWMS0    : Loading Vertical Co-effs (UPSCALE)x ...
     [m3vpss ]  1200752: SWMS0    : Loading Horizontal Co-effs (UPSCALE)x ...
     [m3vpss ]  1200752: SWMS    : Co-effs Loading ... DONE !!!
     [m3vpss ]  1200753: SWMS    : ******* Configuring clock 32 secs...
     [m3vpss ]  1200753: SWMS0    : Loading Vertical Co-effs (7/16)x ...
     [m3vpss ]  1200753: SWMS0    : Loading Horizontal Co-effs (7/16)x ...
     [m3vpss ]  1200753: SWMS    : Co-effs Loading ... DONE !!!
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]  1200757: SWMS: Create Done !!!
     [m3vpss ]  1200757: SWMS: Create in progress !!!
     [m3vpss ]  1200895: SWMS    : VipScReq is FALSE!!!
     [m3vpss ]  1200898: SWMS1    : Loading Vertical Co-effs (UPSCALE)x ...
     [m3vpss ]  1200898: SWMS1    : Loading Horizontal Co-effs (UPSCALE)x ...
     [m3vpss ]  1200898: SWMS    : Co-effs Loading ... DONE !!!
     [m3vpss ]  1200901: SWMS1    : Loading Vertical Co-effs (UPSCALE)x ...
     [m3vpss ]  1200901: SWMS1    : Loading Horizontal Co-effs (UPSCALE)x ...
     [m3vpss ]  1200901: SWMS    : Co-effs Loading ... DONE !!!
     [m3vpss ]  1200902: SWMS    : ******* Configuring clock 30 secs...
     [m3vpss ]  1200902: SWMS1    : Loading Vertical Co-effs (UPSCALE)x ...
     [m3vpss ]  1200902: SWMS1    : Loading Horizontal Co-effs (UPSCALE)x ...
     [m3vpss ]  1200902: SWMS    : Co-effs Loading ... DONE !!!
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]  1200903: SWMS: Create Done !!!
     [m3vpss ]  1200904: DISPLAY: Create in progress !!!
     [m3vpss ]  1200905: DISPLAY: Create Done !!!
     [m3vpss ]  1200905: DISPLAY: Create in progress !!!
     [m3vpss ]  1200906: DISPLAY: Create Done !!!
     [m3vpss ]  1200907: SWMS    : ******* Configuring clock 30 secs...
     [m3vpss ]  1200908: SWMS1    : Loading Vertical Co-effs (UPSCALE)x ...
     [m3vpss ]  1200908: SWMS1    : Loading Horizontal Co-effs (UPSCALE)x ...
     [m3vpss ]  1200908: SWMS    : Co-effs Loading ... DONE !!!
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]  1200909: DISPLAY: Start in progress !!!
     [m3vpss ]  1200949: DISPLAY: Start Done !!!
     [m3vpss ]  1200949: DISPLAY: HDDAC(BP0) : 51 fps, Latency (Min / Max) = ( 255 / 0 ), Callback Interval (Min / Max) = ( 255 / 0 ) !!!
     [m3vpss ]  1200949: DISPLAY: UNDERFLOW COUNT: HDMI(BP0) 1, HDDAC(BP0) 1, DVO2(BP1) 1, SDDAC(SEC1) 1
     [m3vpss ]  1200949: SYSTEM  : FREE SPACE : System Heap      = 5792 B, Mbx = 10238 msgs)
     [m3vpss ]  1200949: SYSTEM  : FREE SPACE : SR0 Heap         = 11003648 B (10 MB)
     [m3vpss ]  1200949: SYSTEM  : FREE SPACE : Frame Buffer     = 110705536 B (105 MB)
     [m3vpss ]  1200950: SYSTEM  : FREE SPACE : Bitstream Buffer = 188243840 B (179 MB)
     [m3vpss ]  1200950: DISPLAY: Start in progress !!!
     [m3vpss ]  1200950: SYSTEM  : FREE SPACE : Tiler Buffer     = 256 B (0 MB)  - TILER OFF
     [m3vpss ]  1201006: DISPLAY: Start Done !!!
     [m3vpss ]  1201006: DISPLAY: DVO2(BP1)  : 35 fps, Latency (Min / Max) = ( 255 / 0 ), Callback Interval (Min / Max) = ( 255 / 0 ) !!!
     [m3vpss ]  1201006: SWMS: Start in Progress !!!
     [m3vpss ]  1201006: SWMS: Start Done !!!
     [m3vpss ]  1201283: SWMS    : ******* Configuring clock 32 secs...
     [m3vpss ]  1201283: SWMS0    : Loading Vertical Co-effs (7/16)x ...
     [m3vpss ]  1201283: SWMS0    : Loading Horizontal Co-effs (7/16)x ...
     [m3vpss ]  1201283: SWMS    : Co-effs Loading ... DONE !!!
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]  1209230: SWMS    : ******* Configuring clock 32 secs...
     [m3vpss ]  1209230: SWMS0    : Loading Vertical Co-effs (8/16)x ...
     [m3vpss ]  1209230: SWMS0    : Loading Horizontal Co-effs (9/16)x ...
     [m3vpss ]  1209230: SWMS    : Co-effs Loading ... DONE !!!
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]  1209233: SWMS    : ******* Configuring clock 32 secs...
     [m3vpss ]  1209233: SWMS1    : Loading Vertical Co-effs (8/16)x ...
     [m3vpss ]  1209233: SWMS1    : Loading Horizontal Co-effs (9/16)x ...
     [m3vpss ]  1209233: SWMS    : Co-effs Loading ... DONE !!!
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ] AVSYNC:Media Time Base:8117,FirstVidPTS:8118,FirstAudPTS:-1
     [m3vpss ] AVSYNC:Media Time Base:8018,FirstVidPTS:8019,FirstAudPTS:-1
     [m3vpss ]  1209337: SWMS    : ******* Configuring clock 32 secs...
     [m3vpss ]  1209337: SWMS1    : Loading Vertical Co-effs (8/16)x ...
     [m3vpss ]  1209337: SWMS1    : Loading Horizontal Co-effs (9/16)x ...
     [m3vpss ]  1209338: SWMS    : Co-effs Loading ... DONE !!!
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     Run-Time Menu
     1: Capture Settings
     2: Encode  Settings
     3: Decode  Settings
     4: Display Settings
     5: Audio   Capture / Playback Settings
     6: Audio Capture <TVP5158> & Encode <AAC-LC> demo
     7: Audio encode demo <AAC-LC File In/Out>
     8: Audio decode demo <AAC-LC File In/Out>
     i: Print detailed system information
     s: Core Status: Active/In-active
     f: Switch IVA Channel Map
     e: Stop Demo
     Enter Choice: a
         | Count    Count
       2|        0        0  407814      -1
       3|        0        0  407715      -1
     AVSYNC:Video Stats
       2|  4331      0   335 7693      7332        0
       3| 12234      3   121    0         0        0
         | Count    Count
       2|        0        0  407715      -1
       3|        0        0  407616      -1
     AVSYNC:Video Stats
       2| 11992      2   117    0         0        0
       3| 11992      2   117    0         0        0
     Chn | Avg
         | Delta
       0|     0
       1|     0
       2|     0
       3|     0
       4|     0
       5|     0
       6|     0
       7|     0
       8|     0
       9|     0
      10|     0
      11|     0
      12|     0
      13|     0
      14|     0
      15|     0
     Chn | Avg
         | Delta
       0|   999
       1|   999
       2|    32
       3|    32
       4|     0
       5|     0
       6|     0
       7|     0
       8|     0
       9|     0
      10|     0
      11|     0
      12|     0
      13|     0
      14|     0
      15|     0
               0       0       0         0         0
         0 |           0       0       0         0          0
         1 |           0       0       0         0          0
         2 |        -171      65       6         0         43
         3 |        -161      69       1         0          0
         4 |           0       0       0         0          0
         5 |           0       0       0         0          0
         6 |           0       0       0         0          0
         7 |           0       0       0         0          0
         8 |           0       0       0         0          0
         9 |           0       0       0         0          0
        10 |           0       0       0         0          0
        11 |           0       0       0         0          0
        12 |           0       0       0         0          0
        13 |           0       0       0         0          0
        14 |           0       0       0         0          0
        15 |           0       0       0         0          0
        16 |           0       0       0         0          0
        17 |           0       0       0         0          0
        18 |           0       0       0         0          0
        19 |           0       0       0         0          0
        20 |           0       0       0         0          0
        21 |           0       0       0         0          0
        22 |           0       0       0         0          0
        23 |           0       0       0         0          0
        24 |           0       0       0         0          0
        25 |           0       0       0         0          0
        26 |           0       0       0         0          0
        27 |           0       0       0         0          0
        28 |           0       0       0         0          0
        29 |           0       0       0         0          0
        30 |           0       0       0         0          0
        31 |           0       0       0         0          0
               0       0       0         0         0
         0 |           0       0       0         0          0
         1 |           0       0       0         0          0
         2 |        -163     839       9         0          0
         3 |        -163     839       9         0          0
         4 |           0       0       0         0          0
         5 |           0       0       0         0          0
         6 |           0       0       0         0          0
         7 |           0       0       0         0          0
         8 |           0       0       0         0          0
         9 |           0       0       0         0          0
        10 |           0       0       0         0          0
        11 |           0       0       0         0          0
        12 |           0       0       0         0          0
        13 |           0       0       0         0          0
        14 |           0       0       0         0          0
        15 |           0       0       0         0          0
        16 |           0       0       0         0          0
        17 |           0       0       0         0          0
        18 |           0       0       0         0          0
        19 |           0       0       0         0          0
        20 |           0       0       0         0          0
        21 |           0       0       0         0          0
        22 |           0       0       0         0          0
        23 |           0       0       0         0          0
        24 |           0       0       0         0          0
        25 |           0       0       0         0          0
        26 |           0       0       0         0          0
        27 |           0       0       0         0          0
        28 |           0       0       0         0          0
        29 |           0       0       0         0          0
        30 |           0       0       0         0          0
        31 |           0       0       0         0          0
               0       0       0         0         0
         0 |           0       0       0         0          0
         1 |           0       0       0         0          0
         2 |           0       0       0         0          0
         3 |           0       0       0         0          0
         4 |           0       0       0         0          0
         5 |           0       0       0         0          0
         6 |           0       0       0         0          0
         7 |           0       0       0         0          0
         8 |           0       0       0         0          0
         9 |           0       0       0         0          0
        10 |           0       0       0         0          0
        11 |           0       0       0         0          0
        12 |           0       0       0         0          0
        13 |           0       0       0         0          0
        14 |           0       0       0         0          0
        15 |           0       0       0         0          0
        16 |           0       0       0         0          0
        17 |           0       0       0         0          0
        18 |           0       0       0         0          0
        19 |           0       0       0         0          0
        20 |           0       0       0         0          0
        21 |           0       0       0         0          0
        22 |           0       0       0         0          0
        23 |           0       0       0         0          0
        24 |           0       0       0         0          0
        25 |           0       0       0         0          0
        26 |           0       0       0         0          0
        27 |           0       0       0         0          0
        28 |           0       0       0         0          0
        29 |           0       0       0         0          0
        30 |           0       0       0         0          0
        31 |           0       0       0         0          0
     [m3vpss ]
     [m3vpss ]  Elasped Time: 985 secs
     [m3vpss ]
     [m3vpss ]  Output Request FPS   : 30 fps (29554 frames)
     [m3vpss ]  Output Actual  FPS   : 30 fps (29554 frames)
     [m3vpss ]  Scaling Internal min : 33 ms
     [m3vpss ]  Scaling Internal max : 34 ms
     [m3vpss ]
     [m3vpss ]    0 |      0     30   30    0    0          0        0 (  0/255)         0          0      0 255 /   0
     [m3vpss ]    1 |      0     30   30    0    0          0        0 (  0/255)         0          0      0 255 /   0
     [m3vpss ]    2 |     30      1    1    0   28          0        0 (  0/255)         0          0      0 255 / 2194400
     [m3vpss ]    3 |     30      0    0    0   30          0        0 (  0/255)         0          0      0 255 / 2194400
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]  Scaling Internal min : 29 ms
     [m3vpss ]  Scaling Internal max : 38 ms
     [m3vpss ]
     [m3vpss ]    1 |     30     30   30    0    0          0        0 (  0/255)         0          0      0 255 / 2194425
     [m3vpss ]    2 |     30      0    0    0   30          0        0 (  0/255)         0          0      0 255 / 2194425
     [m3vpss ]    3 |     30      0    0    0   30          0        0 (  0/255)         0          0      0 255 / 2194425
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]  2194439: DISPLAY: HDDAC(BP0) : 59 fps, Latency (Min / Max) = ( 16 / 66 ), Callback Interval (Min / Max) = ( 16 / 17 ) !!!
     [m3vpss ]  2194439: DISPLAY: UNDERFLOW COUNT: HDMI(BP0) 59609, HDDAC(BP0) 59611, DVO2(BP1) 59611, SDDAC(SEC1) 59612
     [m3vpss ]  2194439: SYSTEM  : FREE SPACE : System Heap      = 5792 B, Mbx = 10237 msgs)
     [m3vpss ]  2194439: SYSTEM  : FREE SPACE : SR0 Heap         = 11003648 B (10 MB)
     [m3vpss ]  2194439: SYSTEM  : FREE SPACE : Frame Buffer     = 110705536 B (105 MB)
     [m3vpss ]  2194439: SYSTEM  : FREE SPACE : Bitstream Buffer = 188243840 B (179 MB)
     [m3vpss ]  2194440: SYSTEM  : FREE SPACE : Tiler Buffer     = 256 B (0 MB)  - TILER OFF
     [m3vpss ]  2194440: DISPLAY: DVO2(BP1)  : 59 fps, Latency (Min / Max) = ( 11 / 66 ), Callback Interval (Min / Max) = ( 16 / 17 ) !!!
     [m3video]      2198441: HDVICP-ID:0
     [m3video]               totalWait2Isr :36 %
     [m3video]               totalWait2Done :36 %
     [m3video]               totalAcquire2Release :37 %
     [m3video]               totalAcq2acqDelay :62 %
     [m3video]               totalElapsedTime in msec :  997382
     [m3video]               numAccessCnt:  721644
     [m3video]              IVA-FPS :     723
     [m3video]              Average time spent per frame in microsec:     497
     [m3video]      2198441: HDVICP-ID:1
     [m3video]               totalWait2Isr :7 %
     [m3video]               totalWait2Done :7 %
     [m3video]               totalAcquire2Release :8 %
     [m3video]               totalAcq2acqDelay :91 %
     [m3video]               totalElapsedTime in msec :  997376
     [m3video]               numAccessCnt:  359064
     [m3video]              IVA-FPS :     360
     [m3video]              Average time spent per frame in microsec:     194
     [m3video]      2198442: HDVICP-ID:2
     [m3video]               totalWait2Isr :30 %
     [m3video]               totalWait2Done :30 %
     [m3video]               totalAcquire2Release :31 %
     [m3video]               totalAcq2acqDelay :68 %
     [m3video]               totalElapsedTime in msec :  997389
     [m3video]               numAccessCnt:  362616
     [m3video]              IVA-FPS :     363
     [m3video]              Average time spent per frame in microsec:     825
     [m3video]
     [m3video]
     [m3video]  Elasped Time           : 997 secs
     [m3video]
     [m3video]
     [m3video]    1 |      30        0  30
     [m3video]
     [m3video]
     [m3video] Total Number of Batches created: 60129
     [m3video] Total Number of Batches created: 29918
     [m3video] Total Number of Batches created: 30214
     [m3video]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]  Total Frames Received  : 120519
     [m3vpss ]  Total Frames Forwarded : 120519
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]  2200446: LOAD: CPU: 9.2% HWI: 2.7%, SWI:1.2%
     [m3vpss ]
     [m3vpss ]  2200446: LOAD: TSK: IPC_IN_M30          : 0.5%
     [m3vpss ]  2200446: LOAD: TSK: DISPLAY0            : 0.3%
     [m3vpss ]  2200446: LOAD: TSK: DISPLAY1            : 0.3%
     [m3vpss ]  2200447: LOAD: TSK: DUP0                : 0.4%
     [m3vpss ]  2200447: LOAD: TSK: SWMS0               : 1.3%
     [m3vpss ]  2200447: LOAD: TSK: SWMS1               : 1.3%
     [m3vpss ]  2200447: LOAD: TSK: MP_SCLR_FWD_Q0      : 0.3%
     [m3vpss ]  2200447: LOAD: TSK: MISC                : 0.9%
     [m3vpss ]
     [m3video]
     [m3video]  2200948: LOAD: CPU: 8.2% HWI: 0.8%, SWI:0.9%
     [m3video]
     [m3video]  2200948: LOAD: TSK: IPC_OUT_M30         : 1.0%
     [m3video]  2200948: LOAD: TSK: IPC_BITS_IN0        : 0.3%
     [m3video]  2200948: LOAD: TSK: DEC0                : 1.9%
     [m3video]  2200948: LOAD: TSK: DEC_PROCESS_TSK_0   : 1.4%
     [m3video]  2200948: LOAD: TSK: DEC_PROCESS_TSK_1   : 0.7%
     [m3video]  2200948: LOAD: TSK: DEC_PROCESS_TSK_2   : 0.7%
     [m3video]  2200948: LOAD: TSK: MISC                : 0.5%
     [m3video]
     [c6xdsp ]
     [c6xdsp ]  2234460: LOAD: CPU: 0.1% HWI: 0.0%, SWI:0.0%
     [c6xdsp ]
     [c6xdsp ]  2234460: LOAD: TSK: MISC                : 0.1%
     [c6xdsp ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     Run-Time Menu
     1: Capture Settings
     2: Encode  Settings
     3: Decode  Settings
     4: Display Settings
     e: Stop Demo
     Enter Choice: a
         | Count    Count
       2|        0        0  407814      -1
       3|        0        0  407715      -1
     AVSYNC:Video Stats
         | Count    Count
       2|        0        0  407715      -1
       3|        0        0  407616      -1
     AVSYNC:Video Stats
     Chn | Avg
         | Delta
       0|     0
       1|     0
       2|     0
       3|     0
       4|     0
       5|     0
       6|     0
       7|     0
       8|     0
       9|     0
      10|     0
      11|     0
      12|     0
      13|     0
      14|     0
      15|     0
     Chn | Avg
         | Delta
       0|   999
       1|   999
       2|    32
       3|    32
       4|     0
       5|     0
       6|     0
       7|     0
       8|     0
       9|     0
      10|     0
      11|     0
      12|     0
      13|     0
      14|     0
      15|     0
               0       0       0         0         0
         0 |           0       0       0         0          0
         1 |           0       0       0         0          0
         2 |        -171      65       6         0         43
         3 |        -161      69       1         0          0
         4 |           0       0       0         0          0
         5 |           0       0       0         0          0
         6 |           0       0       0         0          0
         7 |           0       0       0         0          0
         8 |           0       0       0         0          0
         9 |           0       0       0         0          0
        10 |           0       0       0         0          0
        11 |           0       0       0         0          0
        12 |           0       0       0         0          0
        13 |           0       0       0         0          0
        14 |           0       0       0         0          0
        15 |           0       0       0         0          0
        16 |           0       0       0         0          0
        17 |           0       0       0         0          0
        18 |           0       0       0         0          0
        19 |           0       0       0         0          0
        20 |           0       0       0         0          0
        21 |           0       0       0         0          0
        22 |           0       0       0         0          0
        23 |           0       0       0         0          0
        24 |           0       0       0         0          0
        25 |           0       0       0         0          0
        26 |           0       0       0         0          0
        27 |           0       0       0         0          0
        28 |           0       0       0         0          0
        29 |           0       0       0         0          0
        30 |           0       0       0         0          0
        31 |           0       0       0         0          0
               0       0       0         0         0
         0 |           0       0       0         0          0
         1 |           0       0       0         0          0
         2 |        -163     839       9         0          0
         3 |        -163     839       9         0          0
         4 |           0       0       0         0          0
         5 |           0       0       0         0          0
         6 |           0       0       0         0          0
         7 |           0       0       0         0          0
         8 |           0       0       0         0          0
         9 |           0       0       0         0          0
        10 |           0       0       0         0          0
        11 |           0       0       0         0          0
        12 |           0       0       0         0          0
        13 |           0       0       0         0          0
        14 |           0       0       0         0          0
        15 |           0       0       0         0          0
        16 |           0       0       0         0          0
        17 |           0       0       0         0          0
        18 |           0       0       0         0          0
        19 |           0       0       0         0          0
        20 |           0       0       0         0          0
        21 |           0       0       0         0          0
        22 |           0       0       0         0          0
        23 |           0       0       0         0          0
        24 |           0       0       0         0          0
        25 |           0       0       0         0          0
        26 |           0       0       0         0          0
        27 |           0       0       0         0          0
        28 |           0       0       0         0          0
        29 |           0       0       0         0          0
        30 |           0       0       0         0          0
        31 |           0       0       0         0          0
               0       0       0         0         0
         0 |           0       0       0         0          0
         1 |           0       0       0         0          0
         2 |           0       0       0         0          0
         3 |           0       0       0         0          0
         4 |           0       0       0         0          0
         5 |           0       0       0         0          0
         6 |           0       0       0         0          0
         7 |           0       0       0         0          0
         8 |           0       0       0         0          0
         9 |           0       0       0         0          0
        10 |           0       0       0         0          0
        11 |           0       0       0         0          0
        12 |           0       0       0         0          0
        13 |           0       0       0         0          0
        14 |           0       0       0         0          0
        15 |           0       0       0         0          0
        16 |           0       0       0         0          0
        17 |           0       0       0         0          0
        18 |           0       0       0         0          0
        19 |           0       0       0         0          0
        20 |           0       0       0         0          0
        21 |           0       0       0         0          0
        22 |           0       0       0         0          0
        23 |           0       0       0         0          0
        24 |           0       0       0         0          0
        25 |           0       0       0         0          0
        26 |           0       0       0         0          0
        27 |           0       0       0         0          0
        28 |           0       0       0         0          0
        29 |           0       0       0         0          0
        30 |           0       0       0         0          0
        31 |           0       0       0         0          0
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3video]
     [m3video]
     [m3video]
     [m3video]
     [m3video]
     [m3video]
     [m3video]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3video]
     [m3video]
     [m3video]
     [c6xdsp ]
     [c6xdsp ]
     [c6xdsp ]
    Thanks, hope to hear from you soon.
  • Channel 0 and Channel 1 are not started playback and is dropping all frames.It looks like the stream you are using has B-frames so the decode order is not display order  OR the stream is not starting with an I-Frame because the mediaTimeBase for 2 channel are set to 0 and two other channels are 8117,8018 which is not expected.Can you try with below configuration:
    static
                                                Int chnum,
                                                UInt32 avsEndChNum,
                                                VDIS_DEV vdDevId)
        else
        queCfg->clkAdjustPolicy.clkAdjustLead = 12000;
        queCfg->clkAdjustPolicy.clkAdjustLag  = 12000;
        queCfg->vidSynchPolicy.maxReplayLead  = 10000;
        queCfg->ptsInitMode   = AVSYNC_PTS_INIT_MODE_AUTO;
    Pls share the log with this configuration
  • But when I was using time stamp of 500ms instead of 1000ms, everything was fine, so it seems strange to me why mediaTimeBase for 2 channel are set to 0 and two other channels are 8117,8018 in the case of 1000ms time stamp?
    Anyway, after doing the changes you mentioned above, I can see the video slowly playbacking now, I don't know if everything is working correctly though.
    what does the paramters you changed means?
    attached please find the new log file
    root@dm816x:/opt/dvr_rdk/ti816x# VPSS_GRPX : (1)- venc 4 not running.
     [m3video]  891201: IPC_BITS_IN   : Create in progress !!!
     [m3video]  891201: SYSTEM: Opening ListMP [HOST_IPC_OUT_24] ...
     [m3video]  891202: SYSTEM: Opening ListMP [HOST_IPC_IN_24] ...
     [m3video]  891204: IPC_BITS_IN   : Create Done !!!
     [m3video]  891204: DECODE: Create in progress ... !!!
     [m3video]  891329: DECODE: Creating CH0 of 1920 x 1080 [PROGRESSIVE] [NON-TILED  ],target bitrate = 2000 Kbps ...
     [m3video]  891371: DECODE: Creating CH1 of 720 x 576 [PROGRESSIVE] [NON-TILED  ],target bitrate = 2000 Kbps ...
     [m3video]  891494: DECODE: Creating CH2 of 1920 x 1080 [PROGRESSIVE] [NON-TILED  ],target bitrate = 2000 Kbps ...
     [m3video]  891537: DECODE: Creating CH3 of 720 x 576 [PROGRESSIVE] [NON-TILED  ],target bitrate = 2000 Kbps ...
     [m3video]  891538: DECODE: All CH Create ... DONE !!!
     [m3vpss ]  891543: IPC_IN_M3   : Create in progress !!!
     [m3vpss ]  891543: SYSTEM: Opening ListMP [VIDEO-M3_IPC_OUT_0] ...
     [m3vpss ]  891543: SYSTEM: Opening ListMP [VIDEO-M3_IPC_IN_0] ...
     [m3vpss ]  891545: IPC_IN_M3   : Create Done !!!
     [m3video]  891541: DECODE: Create ... DONE !!!
     [m3vpss ]  891545: MP_SCLR: Create in progress !!!
     [m3video]  891541: IPC_OUT_M3   : Create in progress !!!
     [m3video]  891542: IPC_OUT_M3   : Create Done !!!
     [m3vpss ]  891547: MP_SCLR: Create Done !!!
     [m3vpss ]  891552: DUP   : Create Done !!!
     [m3vpss ]  891552: SWMS: Create in progress !!!
     [m3vpss ]  891694: SWMS0    : Loading Vertical Co-effs (UPSCALE)x ...
     [m3vpss ]  891694: SWMS0    : Loading Horizontal Co-effs (UPSCALE)x ...
     [m3vpss ]  891694: SWMS    : Co-effs Loading ... DONE !!!
     [m3vpss ]  891694: SWMS    : VipScReq is FALSE!!!
     [m3vpss ]  891697: SWMS0    : Loading Vertical Co-effs (UPSCALE)x ...
     [m3vpss ]  891697: SWMS0    : Loading Horizontal Co-effs (UPSCALE)x ...
     [m3vpss ]  891697: SWMS    : Co-effs Loading ... DONE !!!
     [m3vpss ]  891698: SWMS    : ******* Configuring clock 32 secs...
     [m3vpss ]  891698: SWMS0    : Loading Vertical Co-effs (7/16)x ...
     [m3vpss ]  891698: SWMS0    : Loading Horizontal Co-effs (7/16)x ...
     [m3vpss ]  891698: SWMS    : Co-effs Loading ... DONE !!!
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]  891702: SWMS: Create Done !!!
     [m3vpss ]  891702: SWMS: Create in progress !!!
     [m3vpss ]  891840: SWMS    : VipScReq is FALSE!!!
     [m3vpss ]  891843: SWMS1    : Loading Vertical Co-effs (UPSCALE)x ...
     [m3vpss ]  891843: SWMS1    : Loading Horizontal Co-effs (UPSCALE)x ...
     [m3vpss ]  891843: SWMS    : Co-effs Loading ... DONE !!!
     [m3vpss ]  891846: SWMS1    : Loading Vertical Co-effs (UPSCALE)x ...
     [m3vpss ]  891846: SWMS1    : Loading Horizontal Co-effs (UPSCALE)x ...
     [m3vpss ]  891846: SWMS    : Co-effs Loading ... DONE !!!
     [m3vpss ]  891847: SWMS    : ******* Configuring clock 30 secs...
     [m3vpss ]  891847: SWMS1    : Loading Vertical Co-effs (UPSCALE)x ...
     [m3vpss ]  891847: SWMS1    : Loading Horizontal Co-effs (UPSCALE)x ...
     [m3vpss ]  891847: SWMS    : Co-effs Loading ... DONE !!!
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]  891849: SWMS: Create Done !!!
     [m3vpss ]  891849: DISPLAY: Create in progress !!!
     [m3vpss ]  891850: DISPLAY: Create Done !!!
     [m3vpss ]  891850: DISPLAY: Create in progress !!!
     [m3vpss ]  891851: DISPLAY: Create Done !!!
     [m3vpss ]  891852: SWMS    : ******* Configuring clock 30 secs...
     [m3vpss ]  891852: SWMS1    : Loading Vertical Co-effs (UPSCALE)x ...
     [m3vpss ]  891852: SWMS1    : Loading Horizontal Co-effs (UPSCALE)x ...
     [m3vpss ]  891853: SWMS    : Co-effs Loading ... DONE !!!
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]  891854: DISPLAY: Start in progress !!!
     [m3vpss ]  891894: DISPLAY: Start Done !!!
     [m3vpss ]  891894: DISPLAY: HDDAC(BP0) : 50 fps, Latency (Min / Max) = ( 255 / 0 ), Callback Interval (Min / Max) = ( 255 / 0 ) !!!
     [m3vpss ]  891895: DISPLAY: UNDERFLOW COUNT: HDMI(BP0) 0, HDDAC(BP0) 0, DVO2(BP1) 0, SDDAC(SEC1) 0
     [m3vpss ]  891895: SYSTEM  : FREE SPACE : System Heap      = 5792 B, Mbx = 10238 msgs)
     [m3vpss ]  891895: SYSTEM  : FREE SPACE : SR0 Heap         = 10998016 B (10 MB)
     [m3vpss ]  891895: SYSTEM  : FREE SPACE : Frame Buffer     = 110705536 B (105 MB)
     [m3vpss ]  891895: SYSTEM  : FREE SPACE : Bitstream Buffer = 188243840 B (179 MB)
     [m3vpss ]  891895: DISPLAY: Start in progress !!!
     [m3vpss ]  891896: SYSTEM  : FREE SPACE : Tiler Buffer     = 256 B (0 MB)  - TILER OFF
     [m3vpss ]  891961: DISPLAY: Start Done !!!
     [m3vpss ]  891961: DISPLAY: DVO2(BP1)  : 30 fps, Latency (Min / Max) = ( 255 / 0 ), Callback Interval (Min / Max) = ( 255 / 0 ) !!!
     [m3vpss ]  891961: SWMS: Start in Progress !!!
     [m3vpss ]  891961: SWMS: Start Done !!!
     [m3vpss ]  891962: SWMS: Start in Progress !!!
     [m3vpss ]  891962: SWMS: Start Done !!!
     [m3vpss ] AVSYNC:AVSYNC_LINK_CMD_SET_FIRST_VIDPTS faileddue to invalid cfg
     [m3vpss ] Config:DisplayID[0],ChID[0]
     [m3vpss ] Config:DisplayID[1],ChID[0]
     [m3vpss ] Config:DisplayID[0],ChID[2]
     [m3vpss ] Config:DisplayID[1],ChID[2]
     [m3vpss ] Config:DisplayID[0],ChID[1]
     [m3vpss ] Config:DisplayID[1],ChID[1]
     [m3vpss ] Config:DisplayID[0],ChID[3]
     [m3vpss ] Config:DisplayID[1],ChID[3]
     [m3vpss ]  892080: SWMS    : ******* Configuring clock 32 secs...
     [m3vpss ]  892080: SWMS0    : Loading Vertical Co-effs (7/16)x ...
     [m3vpss ]  892080: SWMS0    : Loading Horizontal Co-effs (7/16)x ...
     [m3vpss ]  892081: SWMS    : Co-effs Loading ... DONE !!!
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]    1 |   1 |    0,    0 |   704 x    576 |   896 /   896 | NON-TILED   |  736,    0 |   736 x    500 |  3840 /      0 | NON-TILED   |      OFF |    0 |  420SP |   OFF |
     [m3vpss ]
    root@dm816x:/opt/dvr_rdk/ti816x#  [m3vpss ]  908207: SWMS    : ******* Configuring clock 32 secs...
     [m3vpss ]  908207: SWMS0    : Loading Vertical Co-effs (8/16)x ...
     [m3vpss ]  908207: SWMS0    : Loading Horizontal Co-effs (9/16)x ...
     [m3vpss ]  908207: SWMS    : Co-effs Loading ... DONE !!!
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]  908210: SWMS    : ******* Configuring clock 32 secs...
     [m3vpss ]  908210: SWMS1    : Loading Vertical Co-effs (8/16)x ...
     [m3vpss ]  908210: SWMS1    : Loading Horizontal Co-effs (9/16)x ...
     [m3vpss ]  908210: SWMS    : Co-effs Loading ... DONE !!!
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ] AVSYNC:Media Time Base:16037,FirstVidPTS:16038,FirstAudPTS:-1
     [m3vpss ]  908297: SWMS    : ******* Configuring clock 32 secs...
     [m3vpss ]  908297: SWMS1    : Loading Vertical Co-effs (8/16)x ...
     [m3vpss ]  908297: SWMS1    : Loading Horizontal Co-effs (9/16)x ...
     [m3vpss ]  908297: SWMS    : Co-effs Loading ... DONE !!!
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ] AVSYNC:Media Time Base:19999,FirstVidPTS:20000,FirstAudPTS:-1
     Run-Time Menu
     1: Capture Settings
     2: Encode  Settings
     3: Decode  Settings
     4: Display Settings
     e: Stop Demo
     Enter Choice: a
         | Count    Count
       0|        0        0   63000      -1
       1|        0        0   63000      -1
       2|        0        0   62931      -1
       3|        0        0   62931      -1
     AVSYNC:Video Stats
       0|    64   1831     0    0         0        0
       1|    64   1831     0    0         0        0
       2|   736      1     3 1169      1106        0
       3|   740      1     4 1164      1154        0
         | Count    Count
       0|        0        0   63000      -1
       1|        0        0   66000      -1
       2|        0        0   62832      -1
       3|        0        0   62832      -1
     AVSYNC:Video Stats
       0|    64   1831     0    0         0        0
       1|    46   1338     0    0         0        0
       2|  1408      2    10    0         0        0
       3|  1408      2    10    0         0        0
     Chn | Avg
         | Delta
       0|     0
       1|     0
       2|     0
       3|     0
       4|     0
       5|     0
       6|     0
       7|     0
       8|     0
       9|     0
      10|     0
      11|     0
      12|     0
      13|     0
      14|     0
      15|     0
     Chn | Avg
         | Delta
       0|   986
       1|   986
       2|    32
       3|    32
       4|     0
       5|     0
       6|     0
       7|     0
       8|     0
       9|     0
      10|     0
      11|     0
      12|     0
      13|     0
      14|     0
      15|     0
               0       0       0         0         0
         0 |         -32      29       0       843          0
         1 |         -32      29       0       843          0
         2 |           0     841      45         0        841
         3 |           0     877       9         0        877
         4 |           0       0       0         0          0
         5 |           0       0       0         0          0
         6 |           0       0       0         0          0
         7 |           0       0       0         0          0
         8 |           0       0       0         0          0
         9 |           0       0       0         0          0
        10 |           0       0       0         0          0
        11 |           0       0       0         0          0
        12 |           0       0       0         0          0
        13 |           0       0       0         0          0
        14 |           0       0       0         0          0
        15 |           0       0       0         0          0
        16 |           0       0       0         0          0
        17 |           0       0       0         0          0
        18 |           0       0       0         0          0
        19 |           0       0       0         0          0
        20 |           0       0       0         0          0
        21 |           0       0       0         0          0
        22 |           0       0       0         0          0
        23 |           0       0       0         0          0
        24 |           0       0       0         0          0
        25 |           0       0       0         0          0
        26 |           0       0       0         0          0
        27 |           0       0       0         0          0
        28 |           0       0       0         0          0
        29 |           0       0       0         0          0
        30 |           0       0       0         0          0
        31 |           0       0       0         0          0
               0       0       0         0         0
         0 |         -31      29       0       843          0
         1 |         -33      12       0       349          0
         2 |        -163     393       4         0          0
         3 |        -163     393       4         0          0
         4 |           0       0       0         0          0
         5 |           0       0       0         0          0
         6 |           0       0       0         0          0
         7 |           0       0       0         0          0
         8 |           0       0       0         0          0
         9 |           0       0       0         0          0
        10 |           0       0       0         0          0
        11 |           0       0       0         0          0
        12 |           0       0       0         0          0
        13 |           0       0       0         0          0
        14 |           0       0       0         0          0
        15 |           0       0       0         0          0
        16 |           0       0       0         0          0
        17 |           0       0       0         0          0
        18 |           0       0       0         0          0
        19 |           0       0       0         0          0
        20 |           0       0       0         0          0
        21 |           0       0       0         0          0
        22 |           0       0       0         0          0
        23 |           0       0       0         0          0
        24 |           0       0       0         0          0
        25 |           0       0       0         0          0
        26 |           0       0       0         0          0
        27 |           0       0       0         0          0
        28 |           0       0       0         0          0
        29 |           0       0       0         0          0
        30 |           0       0       0         0          0
        31 |           0       0       0         0          0
               0       0       0         0         0
         0 |           0       0       0         0          0
         1 |           0       0       0         0          0
         2 |           0       0       0         0          0
         3 |           0       0       0         0          0
         4 |           0       0       0         0          0
         5 |           0       0       0         0          0
         6 |           0       0       0         0          0
         7 |           0       0       0         0          0
         8 |           0       0       0         0          0
         9 |           0       0       0         0          0
        10 |           0       0       0         0          0
        11 |           0       0       0         0          0
        12 |           0       0       0         0          0
        13 |           0       0       0         0          0
        14 |           0       0       0         0          0
        15 |           0       0       0         0          0
        16 |           0       0       0         0          0
        17 |           0       0       0         0          0
        18 |           0       0       0         0          0
        19 |           0       0       0         0          0
        20 |           0       0       0         0          0
        21 |           0       0       0         0          0
        22 |           0       0       0         0          0
        23 |           0       0       0         0          0
        24 |           0       0       0         0          0
        25 |           0       0       0         0          0
        26 |           0       0       0         0          0
        27 |           0       0       0         0          0
        28 |           0       0       0         0          0
        29 |           0       0       0         0          0
        30 |           0       0       0         0          0
        31 |           0       0       0         0          0
     [m3vpss ]
     [m3vpss ]  Elasped Time: 52 secs
     [m3vpss ]
     [m3vpss ]  Output Request FPS   : 30 fps (1560 frames)
     [m3vpss ]  Output Actual  FPS   : 30 fps (1560 frames)
     [m3vpss ]
     [m3vpss ]    0 |     30     29    0    0    1          0        0 (  0/255)         0          0      0 255 / 960244
     [m3vpss ]    1 |     30     29    0    0    1          0        0 (  0/255)         0          0      0 255 / 960244
     [m3vpss ]    2 |     30      1    1    0   28          0        0 (  0/255)         0          0      0 255 / 960244
     [m3vpss ]    3 |     30      0    0    0   30          0        0 (  0/255)         0          0      0 255 / 960244
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]  Scaling Internal min : 27 ms
     [m3vpss ]  Scaling Internal max : 41 ms
     [m3vpss ]
     [m3vpss ]    0 |     30     29    0    0    1          0        0 (  0/255)         0          0      0 255 / 960245
     [m3vpss ]    1 |     30     29    0    0    0          0        0 (  0/255)         0          0      0 255 / 960245
     [m3vpss ]    2 |     30      0    0    0   29          0        0 (  0/255)         0          0      0 255 / 960245
     [m3vpss ]    3 |     30      0    0    0   29          0        0 (  0/255)         0          0      0 255 / 960245
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]  960263: DISPLAY: HDDAC(BP0) : 59 fps, Latency (Min / Max) = ( 16 / 67 ), Callback Interval (Min / Max) = ( 16 / 17 ) !!!
     [m3vpss ]  960263: DISPLAY: UNDERFLOW COUNT: HDMI(BP0) 4102, HDDAC(BP0) 4104, DVO2(BP1) 4104, SDDAC(SEC1) 4104
     [m3vpss ]  960263: SYSTEM  : FREE SPACE : System Heap      = 5792 B, Mbx = 10237 msgs)
     [m3vpss ]  960263: SYSTEM  : FREE SPACE : SR0 Heap         = 10998016 B (10 MB)
     [m3vpss ]  960263: SYSTEM  : FREE SPACE : Frame Buffer     = 110705536 B (105 MB)
     [m3vpss ]  960263: SYSTEM  : FREE SPACE : Bitstream Buffer = 188243840 B (179 MB)
     [m3vpss ]  960263: SYSTEM  : FREE SPACE : Tiler Buffer     = 256 B (0 MB)  - TILER OFF
     [m3vpss ]  960264: DISPLAY: DVO2(BP1)  : 59 fps, Latency (Min / Max) = ( 16 / 50 ), Callback Interval (Min / Max) = ( 16 / 17 ) !!!
     [m3video]      964264: HDVICP-ID:0
     [m3video]               totalElapsedTime in msec :   72260
     [m3video]               numAccessCnt:   27096
     [m3video]              IVA-FPS :     376
     [m3video]              Average time spent per frame in microsec:     239
     [m3video]      964265: HDVICP-ID:1
     [m3video]               totalWait2Isr :0 %
     [m3video]               totalWait2Done :0 %
     [m3video]               totalAcquire2Release :0 %
     [m3video]               totalAcq2acqDelay :99 %
     [m3video]               totalElapsedTime in msec :   72126
     [m3video]               numAccessCnt:     924
     [m3video]              IVA-FPS :      12
     [m3video]              Average time spent per frame in microsec:       0
     [m3video]      964266: HDVICP-ID:2
     [m3video]               totalElapsedTime in msec :   72268
     [m3video]               numAccessCnt:   26172
     [m3video]              Average time spent per frame in microsec:     828
     [m3video]
     [m3video]
     [m3video]  Elasped Time           : 72 secs
     [m3video]
     [m3video]
     [m3video]    0 |       1        0   1
     [m3video]    1 |       1        0   1
     [m3video]
     [m3video]
     [m3video] Total Number of Batches created: 2250
     [m3video]       Batch breaks due to batch sizeexceeding limit: 3 %
     [m3video]       Batch breaks due to ReqObj Que being empty: 96 %
     [m3video] Total Number of Batches created: 73
     [m3video] Total Number of Batches created: 2177
     [m3video]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]  Total Frames Received  : 4642
     [m3vpss ]  Total Frames Forwarded : 4642
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]  966270: LOAD: CPU: 7.6% HWI: 2.2%, SWI:1.0%
     [m3vpss ]
     [m3vpss ]  966270: LOAD: TSK: IPC_IN_M30          : 0.3%
     [m3vpss ]  966270: LOAD: TSK: DISPLAY0            : 0.3%
     [m3vpss ]  966270: LOAD: TSK: DISPLAY1            : 0.2%
     [m3vpss ]  966270: LOAD: TSK: DUP0                : 0.2%
     [m3vpss ]  966270: LOAD: TSK: SWMS0               : 1.1%
     [m3vpss ]  966270: LOAD: TSK: SWMS1               : 1.4%
     [m3vpss ]  966270: LOAD: TSK: MP_SCLR_FWD_Q0      : 0.2%
     [m3vpss ]  966271: LOAD: TSK: MISC                : 0.7%
     [m3vpss ]
     [m3video]
     [m3video]  966771: LOAD: CPU: 4.9% HWI: 0.6%, SWI:0.6%
     [m3video]
     [m3video]  966771: LOAD: TSK: IPC_OUT_M30         : 0.5%
     [m3video]  966771: LOAD: TSK: IPC_BITS_IN0        : 0.2%
     [m3video]  966771: LOAD: TSK: DEC0                : 1.2%
     [m3video]  966772: LOAD: TSK: DEC_PROCESS_TSK_0   : 0.8%
     [m3video]  966772: LOAD: TSK: DEC_PROCESS_TSK_2   : 0.8%
     [m3video]  966772: LOAD: TSK: MISC                : 0.2%
     [m3video]
     [c6xdsp ]
     [c6xdsp ]  980591: LOAD: CPU: 0.1% HWI: 0.0%, SWI:0.0%
     [c6xdsp ]
     [c6xdsp ]  980591: LOAD: TSK: MISC                : 0.1%
     [c6xdsp ]
     Thanks.
  • Dear Badri Narayanan,
    any idea why is it happening?
    and I have another question, what does Vdis_setWallTimeBase(wallTimeBase); do?
    in vdec_vdis demo, it is set to 0, while in vcap_venc_vdec_vdis demo, it is set to current time
  • The explanation for changes mentioned are below:
    1. queCfg->clkAdjustPolicy.clkAdjustLead = 12000;
       This parameters indicate that if a Timestamp of the received video frame is greater than 12000 msec in the future or 12000 msec in the past the system time should be adjusted instead of the usual operation of dropping or replaying a frame. This is because it may be a change in timebase of the stream if the stream timestamp is too different compared to current system time. Since you are feeding frames at 1 fps timestamp will be significantly different from the system time so we don't want the system clock to get adjusted.
     2.  queCfg->vidSynchPolicy.maxReplayLead  = 10000;
      This  is the main change. If a frame is too ahead in the future it will be dropped instead of waiting for the system time to reach the frames timestamp. As you are feeding frames at 1 fps, the difference between system time and frame's timestamp will be about 1 sec so it will get dropped. By setting it to a large alue we ensure future frames are not dropped and instead replay happens until system time reached frame timestamp.
    3..queCfg->ptsInitMode   = AVSYNC_PTS_INIT_MODE_AUTO;
     Two modes of intialization of system time are supported. If application wants to perform SEEK operation it should use PTS_INIT_MODE_APP. This means application is informing AVSYNC that the first frame for display in this sequence will have the timestamp specified in Vdis_setFirstPTS API call. If application makes any mistake in setting this value playback will not start as Avsync will be dropping frames expecting to receive a frame matching the application set PTS.
    If PTS_INIT_MODE_AUTO the system time will get initialized with the first frame's timestamp that is received in AVSYNC. This ensures palyback starts even if application sets the wrong first PTS value.
    Vdis_setWallTimeBase sets the starting value of the WallTime that is used in AVSYNC. If set to 0 wallTime will start with zero. Application may choose to set to the gettimeofday value so that Avsync WallTime and the Linux gettimeofday are in synch. For this you have to additionally ensure Avsync uses the same dmtimer used by Linux for the free running time else you will see some drift between Linux time and Avsync_getWallTime values.
  • Thanks, I understand a lot more now.
    But why is the demo not functioning properly when .queCfg->ptsInitMode   = AVSYNC_PTS_INIT_MODE_APP ?
    With timestamp of 1000ms, these log can be seen, so I think Vdis_setFirstPTS API have been called,
    and things were still fine when time stamp is less than 500ms (2+ fps)
    So what's wrong with the timestamp in the demo_vdec_vdis?
  • When PTS_INIT_MODE is AVSYNC_PTS_INIT_MODE_APP AVSYNC will check if the frame PTS received is within AVSYNC_FIRST_PTS_MAX_DELTA_MS range of the application configured INIT_PTS value. This define is set in /dvr_rdk/mcfw/interfaces/link_api/avsync_internal.h and its default value is 500ms. It looks like the initial frames are in error or the sequence has B-Frames. As long as your timestamp modification is < 500ms playback still starts as it is within the range to start playback. Pls check the following:
    1.Modify AVSYNC_FIRST_PTS_MAX_DELTA_MS  to some larger values like 3000.
    2.Check if decoder reports any error initially
    3. If sequence has B-frames then setting the PTS like how it is done in the demo currently is wrong as timestamp is set in decode order and not display order. You should set the correct frame timestamp from the upper level container format in a real application and not just multiply frame number by frame duration to get the timestamp.
  • Thanks, I am just tracking there too.
    queObj->playerTime->firstFrmInSeqReceived in avsync_m3vpss.c was never set to TRUE due to value of AVSYNC_FIRST_PTS_MAX_DELTA_MS.
    1. I follow what you suggest, changing AVSYNC_FIRST_PTS_MAX_DELTA_MS from 500 to 3000, and it can perform playback in AVSYNC_PTS_INIT_MODE_APP mode now.
    2. I don't recognize any error message on decoder initially
    3. I have checked there should be no B-Frames in the videos
    Would changing the value of AVSYNC_FIRST_PTS_MAX_DELTA_MS causing other side effects? If not, thanks for helping to solve the problem.
  • And I have a few more questions,
    1. why is Vdis_setWallTimeBase(wallTimeBase); called before Vsys_create() only? Shouln't it be called earlier before Vsys_init()? as AvsyncLink_init is already called at that time and thus pObj->srObj->wallTimer.curWallTime was already inited with 0 initWallTimeTS, and capturelink_drv use this for calculating the time stamp
    2. what do the seek and scan function of avsync do?
    3. is there an API to perform backwork playback? I mean just decoding and playbacking the I-frame only. Or is it already done if I feed the frames with the right time-stamp?
    4. can I manually change the player reference clock time after the playback start?
    Thank
    Yes that is correct.This is fixed in later RDK release.Refer /dvr_rdk/demos/mcfw_api_demos/mcfw_demo/demo_spl_usecases.c in RDK 4.0 release
       -- Seek is used to resume playback at the specified timestamp. Application configure the SEEK PTS and starts feeding frames starting from the first I-frame before the SEEK point. Display will start at the specified SEEK point.
      -- Scan is used for I-frame only playback. In scan mode it is expected application send only I-frame for decoding. In scan mode the timestamp in the frame is ignored and each frame is displayed for application specified duration.For example application will typically configure to display each frame for 300 ms.
      - Yes Scan mode should be used for backward playback (I-frame only playback).
     - No this is not supported. What is the functionality you want to realize ? Maybe there is someother way to achieve the same without reseting the player reference clock.
    Thanks. I am using RDK 3.0 and may not migrate to RDK 4.0, so it is fine if I just call Vdis_setWallTimeBase(wallTimeBase) before Vsys_init()? or it there anything else I need to take care?
    I guess I don't really need that actually. The reference clock would be automatically updated when the timestamp of a frame exceeds clkAdjustPolicy.clkAdjustLead and queCfg->clkAdjustPolicy.clkAdjustLag, right?
    Thanks for all the help.
    - Yes that is correct.Note that several bug fixes since RDK 3.0 (not related to avsync though) so it is recommended to be on RDK 4.0 release
    - Yes correct.
    [- Yes that is correct.Note that several bug fixes since RDK 3.0 (not related to avsync though) so it is recommended to be on RDK 4.0 release
    Are those complicate and important bug fix? or are they minor one that you could help pointing out I just make the related changes?
  • Bug fixes are numerous and across many files.It is not possible to back port to earlier release.If you face issues only option is to migrate to RDK 4.0 release,
  • Thanks for the advice.
