HID Gadget module problem, BeagleBoard-xM Rev C
Hello everyone,
I want to use Beagleboard as HID gadget but I have some problems. Well, I'm using Beagle board-xM Rev C, Linux kernel 2.6.38, arm-angstrom-linux-gnueabi- toolchain and u-boot loads kernel from NFS (Network File System).
For network setup I followed guide from this link: http://veter-project.blogspot.com/2012/03/comfortable-kernel-workflow-on.html
I have built uImage and modules with this instruction: cross make -j5 uImage modules; cross is alias for: ARCH=arm CROSS_COMPILE=arm-angstrom-linux-gnueabi- CFLAGS=" -march=armv7-a -fno-tree-vectorize -mthumb-interwork -mfloat-abi=softfp -mfpu=neon -mtune=cortex-a8 " LOCALVERSION="".
I checked in menuconfig following fields:
Device Drivers --->
HID Devices --->
-*- Generic HID support
<*> USB Human Interface Device (full HID) support
Device Drivers --->
HID Devices --->
USB Gadget Support --->
<M> USB Gadget Drivers
<M> HID Gadget
My Linux .config file is in attachment.
# Automatically generated make config: don't edit
# Linux/arm 2.6.38.8 Kernel Configuration
# Mon Apr 29 16:54:19 2013
CONFIG_ARM=y
CONFIG_HAVE_PWM=y
CONFIG_SYS_SUPPORTS_APM_EMULATION=y
CONFIG_HAVE_SCHED_CLOCK=y
CONFIG_GENERIC_GPIO=y
CONFIG_GENERIC_TIME_VSYSCALL=y
# CONFIG_ARCH_USES_GETTIMEOFFSET is not set
CONFIG_GENERIC_CLOCKEVENTS=y
CONFIG_HAVE_PROC_CPU=y
CONFIG_STACKTRACE_SUPPORT=y
CONFIG_HAVE_LATENCYTOP_SUPPORT=y
CONFIG_LOCKDEP_SUPPORT=y
CONFIG_TRACE_IRQFLAGS_SUPPORT=y
CONFIG_HARDIRQS_SW_RESEND=y
CONFIG_GENERIC_IRQ_PROBE=y
CONFIG_RWSEM_GENERIC_SPINLOCK=y
CONFIG_ARCH_HAS_CPUFREQ=y
CONFIG_ARCH_HAS_CPU_IDLE_WAIT=y
CONFIG_GENERIC_HWEIGHT=y
CONFIG_GENERIC_CALIBRATE_DELAY=y
CONFIG_NEED_DMA_MAP_STATE=y
CONFIG_ARM_L1_CACHE_SHIFT_6=y
CONFIG_VECTORS_BASE=0xffff0000
CONFIG_DEFCONFIG_LIST="/lib/modules/$UNAME_RELEASE/.config"
CONFIG_CONSTRUCTORS=y
CONFIG_HAVE_IRQ_WORK=y
# General setup
CONFIG_EXPERIMENTAL=y
CONFIG_BROKEN_ON_SMP=y
CONFIG_LOCK_KERNEL=y
CONFIG_INIT_ENV_ARG_LIMIT=32
CONFIG_CROSS_COMPILE=""
CONFIG_LOCALVERSION=""
# CONFIG_LOCALVERSION_AUTO is not set
CONFIG_HAVE_KERNEL_GZIP=y
CONFIG_HAVE_KERNEL_LZMA=y
CONFIG_HAVE_KERNEL_LZO=y
# CONFIG_KERNEL_GZIP is not set
CONFIG_KERNEL_LZMA=y
# CONFIG_KERNEL_LZO is not set
CONFIG_SWAP=y
CONFIG_SYSVIPC=y
CONFIG_SYSVIPC_SYSCTL=y
CONFIG_POSIX_MQUEUE=y
CONFIG_POSIX_MQUEUE_SYSCTL=y
CONFIG_BSD_PROCESS_ACCT=y
# CONFIG_BSD_PROCESS_ACCT_V3 is not set
CONFIG_TASKSTATS=y
CONFIG_TASK_DELAY_ACCT=y
CONFIG_TASK_XACCT=y
CONFIG_TASK_IO_ACCOUNTING=y
# CONFIG_AUDIT is not set
CONFIG_HAVE_GENERIC_HARDIRQS=y
# IRQ subsystem
CONFIG_GENERIC_HARDIRQS=y
# CONFIG_GENERIC_HARDIRQS_NO_DEPRECATED is not set
CONFIG_HAVE_SPARSE_IRQ=y
# CONFIG_GENERIC_PENDING_IRQ is not set
# CONFIG_AUTO_IRQ_AFFINITY is not set
# CONFIG_IRQ_PER_CPU is not set
# CONFIG_SPARSE_IRQ is not set
# RCU Subsystem
# CONFIG_TREE_PREEMPT_RCU is not set
CONFIG_TINY_RCU=y
# CONFIG_TINY_PREEMPT_RCU is not set
# CONFIG_PREEMPT_RCU is not set
# CONFIG_RCU_TRACE is not set
# CONFIG_TREE_RCU_TRACE is not set
CONFIG_IKCONFIG=y
CONFIG_IKCONFIG_PROC=y
CONFIG_LOG_BUF_SHIFT=16
CONFIG_CGROUPS=y
# CONFIG_CGROUP_DEBUG is not set
# CONFIG_CGROUP_NS is not set
# CONFIG_CGROUP_FREEZER is not set
# CONFIG_CGROUP_DEVICE is not set
# CONFIG_CPUSETS is not set
# CONFIG_CGROUP_CPUACCT is not set
# CONFIG_RESOURCE_COUNTERS is not set
CONFIG_CGROUP_SCHED=y
CONFIG_FAIR_GROUP_SCHED=y
CONFIG_RT_GROUP_SCHED=y
# CONFIG_BLK_CGROUP is not set
CONFIG_NAMESPACES=y
CONFIG_UTS_NS=y
CONFIG_IPC_NS=y
CONFIG_USER_NS=y
CONFIG_PID_NS=y
CONFIG_NET_NS=y
CONFIG_SCHED_AUTOGROUP=y
# CONFIG_SYSFS_DEPRECATED is not set
# CONFIG_RELAY is not set
CONFIG_BLK_DEV_INITRD=y
CONFIG_INITRAMFS_SOURCE=""
CONFIG_RD_GZIP=y
CONFIG_RD_BZIP2=y
CONFIG_RD_LZMA=y
CONFIG_RD_XZ=y
CONFIG_RD_LZO=y
CONFIG_CC_OPTIMIZE_FOR_SIZE=y
CONFIG_SYSCTL=y
CONFIG_ANON_INODES=y
CONFIG_EXPERT=y
CONFIG_EMBEDDED=y
CONFIG_UID16=y
# CONFIG_SYSCTL_SYSCALL is not set
CONFIG_KALLSYMS=y
# CONFIG_KALLSYMS_ALL is not set
# CONFIG_KALLSYMS_EXTRA_PASS is not set
CONFIG_HOTPLUG=y
CONFIG_PRINTK=y
CONFIG_BUG=y
CONFIG_ELF_CORE=y
CONFIG_BASE_FULL=y
CONFIG_FUTEX=y
CONFIG_EPOLL=y
CONFIG_SIGNALFD=y
CONFIG_TIMERFD=y
CONFIG_EVENTFD=y
CONFIG_SHMEM=y
CONFIG_AIO=y
CONFIG_HAVE_PERF_EVENTS=y
CONFIG_PERF_USE_VMALLOC=y
# Kernel Performance Events And Counters
# CONFIG_PERF_EVENTS is not set
# CONFIG_PERF_COUNTERS is not set
CONFIG_VM_EVENT_COUNTERS=y
# CONFIG_COMPAT_BRK is not set
CONFIG_SLAB=y
# CONFIG_SLUB is not set
# CONFIG_SLOB is not set
CONFIG_PROFILING=y
CONFIG_OPROFILE=y
CONFIG_HAVE_OPROFILE=y
# CONFIG_KPROBES is not set
CONFIG_HAVE_KPROBES=y
CONFIG_HAVE_KRETPROBES=y
CONFIG_HAVE_REGS_AND_STACK_ACCESS_API=y
CONFIG_HAVE_CLK=y
CONFIG_HAVE_DMA_API_DEBUG=y
# GCOV-based kernel profiling
# CONFIG_GCOV_KERNEL is not set
CONFIG_HAVE_GENERIC_DMA_COHERENT=y
CONFIG_SLABINFO=y
CONFIG_RT_MUTEXES=y
CONFIG_BASE_SMALL=0
CONFIG_MODULES=y
CONFIG_MODULE_FORCE_LOAD=y
CONFIG_MODULE_UNLOAD=y
CONFIG_MODULE_FORCE_UNLOAD=y
CONFIG_MODVERSIONS=y
# CONFIG_MODULE_SRCVERSION_ALL is not set
CONFIG_BLOCK=y
CONFIG_LBDAF=y
CONFIG_BLK_DEV_BSG=y
CONFIG_BLK_DEV_INTEGRITY=y
# IO Schedulers
CONFIG_IOSCHED_NOOP=y
CONFIG_IOSCHED_DEADLINE=y
CONFIG_IOSCHED_CFQ=y
# CONFIG_DEFAULT_DEADLINE is not set
# CONFIG_DEFAULT_CFQ is not set
CONFIG_DEFAULT_NOOP=y
CONFIG_DEFAULT_IOSCHED="noop"
# CONFIG_INLINE_SPIN_TRYLOCK is not set
# CONFIG_INLINE_SPIN_TRYLOCK_BH is not set
# CONFIG_INLINE_SPIN_LOCK is not set
# CONFIG_INLINE_SPIN_LOCK_BH is not set
# CONFIG_INLINE_SPIN_LOCK_IRQ is not set
# CONFIG_INLINE_SPIN_LOCK_IRQSAVE is not set
# CONFIG_INLINE_SPIN_UNLOCK is not set
# CONFIG_INLINE_SPIN_UNLOCK_BH is not set
# CONFIG_INLINE_SPIN_UNLOCK_IRQ is not set
# CONFIG_INLINE_SPIN_UNLOCK_IRQRESTORE is not set
# CONFIG_INLINE_READ_TRYLOCK is not set
# CONFIG_INLINE_READ_LOCK is not set
# CONFIG_INLINE_READ_LOCK_BH is not set
# CONFIG_INLINE_READ_LOCK_IRQ is not set
# CONFIG_INLINE_READ_LOCK_IRQSAVE is not set
# CONFIG_INLINE_READ_UNLOCK is not set
# CONFIG_INLINE_READ_UNLOCK_BH is not set
# CONFIG_INLINE_READ_UNLOCK_IRQ is not set
# CONFIG_INLINE_READ_UNLOCK_IRQRESTORE is not set
# CONFIG_INLINE_WRITE_TRYLOCK is not set
# CONFIG_INLINE_WRITE_LOCK is not set
# CONFIG_INLINE_WRITE_LOCK_BH is not set
# CONFIG_INLINE_WRITE_LOCK_IRQ is not set
# CONFIG_INLINE_WRITE_LOCK_IRQSAVE is not set
# CONFIG_INLINE_WRITE_UNLOCK is not set
# CONFIG_INLINE_WRITE_UNLOCK_BH is not set
# CONFIG_INLINE_WRITE_UNLOCK_IRQ is not set
# CONFIG_INLINE_WRITE_UNLOCK_IRQRESTORE is not set
# CONFIG_MUTEX_SPIN_ON_OWNER is not set
# Real-time sub-system
CONFIG_XENOMAI=y
CONFIG_XENO_GENERIC_STACKPOOL=y
CONFIG_XENO_FASTSYNCH_DEP=y
CONFIG_XENO_FASTSYNCH=y
CONFIG_XENO_OPT_NUCLEUS=y
CONFIG_XENO_OPT_PERVASIVE=y
CONFIG_XENO_OPT_PRIOCPL=y
CONFIG_XENO_OPT_PIPELINE_HEAD=y
# CONFIG_XENO_OPT_SCHED_CLASSES is not set
CONFIG_XENO_OPT_PIPE=y
CONFIG_XENO_OPT_VFILE=y
CONFIG_XENO_OPT_PIPE_NRDEV=32
CONFIG_XENO_OPT_REGISTRY_NRSLOTS=512
CONFIG_XENO_OPT_SYS_HEAPSZ=256
CONFIG_XENO_OPT_SYS_STACKPOOLSZ=128
CONFIG_XENO_OPT_SEM_HEAPSZ=12
CONFIG_XENO_OPT_GLOBAL_SEM_HEAPSZ=12
CONFIG_XENO_OPT_STATS=y
# CONFIG_XENO_OPT_DEBUG is not set
# CONFIG_XENO_OPT_SHIRQ is not set
CONFIG_XENO_OPT_SELECT=y
CONFIG_XENO_OPT_HOSTRT=y
# Timing
# CONFIG_XENO_OPT_TIMING_PERIODIC is not set
CONFIG_XENO_OPT_TIMING_VIRTICK=1000
CONFIG_XENO_OPT_TIMING_SCHEDLAT=0
# Scalability
# CONFIG_XENO_OPT_SCALABLE_SCHED is not set
CONFIG_XENO_OPT_TIMER_LIST=y
# CONFIG_XENO_OPT_TIMER_HEAP is not set
# CONFIG_XENO_OPT_TIMER_WHEEL is not set
# Machine
CONFIG_IPIPE_WANT_PREEMPTIBLE_SWITCH=y
CONFIG_XENO_HW_FPU=y
CONFIG_XENO_HW_UNLOCKED_SWITCH=y
# Interfaces
CONFIG_XENO_SKIN_NATIVE=y
CONFIG_XENO_OPT_NATIVE_PERIOD=0
CONFIG_XENO_OPT_NATIVE_PIPE=y
CONFIG_XENO_OPT_NATIVE_PIPE_BUFSZ=1024
CONFIG_XENO_OPT_NATIVE_SEM=y
CONFIG_XENO_OPT_NATIVE_EVENT=y
CONFIG_XENO_OPT_NATIVE_MUTEX=y
CONFIG_XENO_OPT_NATIVE_COND=y
CONFIG_XENO_OPT_NATIVE_QUEUE=y
CONFIG_XENO_OPT_NATIVE_BUFFER=y
CONFIG_XENO_OPT_NATIVE_HEAP=y
CONFIG_XENO_OPT_NATIVE_ALARM=y
CONFIG_XENO_OPT_NATIVE_MPS=y
# CONFIG_XENO_OPT_NATIVE_INTR is not set
CONFIG_XENO_SKIN_POSIX=y
CONFIG_XENO_OPT_POSIX_PERIOD=0
# CONFIG_XENO_OPT_POSIX_SHM is not set
# CONFIG_XENO_OPT_POSIX_INTR is not set
CONFIG_XENO_OPT_POSIX_SELECT=y
CONFIG_XENO_OPT_DEBUG_POSIX=y
# CONFIG_XENO_SKIN_PSOS is not set
# CONFIG_XENO_SKIN_UITRON is not set
# CONFIG_XENO_SKIN_VRTX is not set
# CONFIG_XENO_SKIN_VXWORKS is not set
# CONFIG_XENO_OPT_NOWARN_DEPRECATED is not set
CONFIG_XENO_SKIN_RTDM=y
CONFIG_XENO_OPT_RTDM_PERIOD=0
CONFIG_XENO_OPT_RTDM_FILDES=128
CONFIG_XENO_OPT_RTDM_SELECT=y
# Drivers
# Serial drivers
# CONFIG_XENO_DRIVERS_16550A is not set
# Testing drivers
CONFIG_XENO_DRIVERS_TIMERBENCH=m
CONFIG_XENO_DRIVERS_KLATENCY=m
CONFIG_XENO_DRIVERS_IRQBENCH=m
CONFIG_XENO_DRIVERS_SWITCHTEST=m
CONFIG_XENO_DRIVERS_RTDMTEST=m
# CAN drivers
# CONFIG_XENO_DRIVERS_CAN is not set
# ANALOGY drivers
# CONFIG_XENO_DRIVERS_ANALOGY is not set
# Real-time IPC drivers
# CONFIG_XENO_DRIVERS_RTIPC is not set
CONFIG_FREEZER=y
# System Type
CONFIG_MMU=y
# CONFIG_ARCH_AAEC2000 is not set
# CONFIG_ARCH_INTEGRATOR is not set
# CONFIG_ARCH_REALVIEW is not set
# CONFIG_ARCH_VERSATILE is not set
# CONFIG_ARCH_VEXPRESS is not set
# CONFIG_ARCH_AT91 is not set
# CONFIG_ARCH_BCMRING is not set
# CONFIG_ARCH_CLPS711X is not set
# CONFIG_ARCH_CNS3XXX is not set
# CONFIG_ARCH_GEMINI is not set
# CONFIG_ARCH_EBSA110 is not set
# CONFIG_ARCH_EP93XX is not set
# CONFIG_ARCH_FOOTBRIDGE is not set
# CONFIG_ARCH_MXC is not set
# CONFIG_ARCH_MXS is not set
# CONFIG_ARCH_STMP3XXX is not set
# CONFIG_ARCH_NETX is not set
# CONFIG_ARCH_H720X is not set
# CONFIG_ARCH_IOP13XX is not set
# CONFIG_ARCH_IOP32X is not set
# CONFIG_ARCH_IOP33X is not set
# CONFIG_ARCH_IXP23XX is not set
# CONFIG_ARCH_IXP2000 is not set
# CONFIG_ARCH_IXP4XX is not set
# CONFIG_ARCH_DOVE is not set
# CONFIG_ARCH_KIRKWOOD is not set
# CONFIG_ARCH_LOKI is not set
# CONFIG_ARCH_LPC32XX is not set
# CONFIG_ARCH_MV78XX0 is not set
# CONFIG_ARCH_ORION5X is not set
# CONFIG_ARCH_MMP is not set
# CONFIG_ARCH_KS8695 is not set
# CONFIG_ARCH_NS9XXX is not set
# CONFIG_ARCH_W90X900 is not set
# CONFIG_ARCH_NUC93X is not set
# CONFIG_ARCH_TEGRA is not set
# CONFIG_ARCH_PNX4008 is not set
# CONFIG_ARCH_PXA is not set
# CONFIG_ARCH_MSM is not set
# CONFIG_ARCH_SHMOBILE is not set
# CONFIG_ARCH_RPC is not set
# CONFIG_ARCH_SA1100 is not set
# CONFIG_ARCH_S3C2410 is not set
# CONFIG_ARCH_S3C64XX is not set
# CONFIG_ARCH_S5P64X0 is not set
# CONFIG_ARCH_S5P6442 is not set
# CONFIG_ARCH_S5PC100 is not set
# CONFIG_ARCH_S5PV210 is not set
# CONFIG_ARCH_S5PV310 is not set
# CONFIG_ARCH_SHARK is not set
# CONFIG_ARCH_TCC_926 is not set
# CONFIG_ARCH_LH7A40X is not set
# CONFIG_ARCH_U300 is not set
# CONFIG_ARCH_U8500 is not set
# CONFIG_ARCH_NOMADIK is not set
# CONFIG_ARCH_DAVINCI is not set
CONFIG_ARCH_OMAP=y
# CONFIG_PLAT_SPEAR is not set
# CONFIG_GPIO_PCA953X is not set
# CONFIG_KEYBOARD_GPIO_POLLED is not set
# TI OMAP Common Features
CONFIG_ARCH_OMAP_OTG=y
# CONFIG_ARCH_OMAP1 is not set
CONFIG_ARCH_OMAP2PLUS=y
# OMAP Feature Selections
# CONFIG_OMAP_SMARTREFLEX is not set
# CONFIG_OMAP_RESET_CLOCKS is not set
# CONFIG_OMAP_MUX is not set
CONFIG_OMAP_MCBSP=y
CONFIG_OMAP_MBOX_FWK=y
CONFIG_OMAP_MBOX_KFIFO_SIZE=256
# CONFIG_OMAP3_L2_AUX_SECURE_SAVE_RESTORE is not set
CONFIG_OMAP_DM_TIMER=y
# CONFIG_OMAP_PM_NONE is not set
CONFIG_OMAP_PM_NOOP=y
# TI OMAP2/3/4 Specific Features
CONFIG_ARCH_OMAP2PLUS_TYPICAL=y
# CONFIG_ARCH_OMAP2 is not set
CONFIG_ARCH_OMAP3=y
# CONFIG_ARCH_OMAP4 is not set
CONFIG_ARCH_OMAP3430=y
CONFIG_OMAP_PACKAGE_CBB=y
# OMAP Board Type
CONFIG_MACH_OMAP3_BEAGLE=y
# CONFIG_MACH_DEVKIT8000 is not set
# CONFIG_MACH_OMAP_LDP is not set
# CONFIG_MACH_OMAP3530_LV_SOM is not set
# CONFIG_MACH_OMAP3_TORPEDO is not set
# CONFIG_MACH_OVERO is not set
# CONFIG_MACH_OMAP3EVM is not set
# CONFIG_MACH_OMAP3517EVM is not set
# CONFIG_MACH_CRANEBOARD is not set
# CONFIG_MACH_OMAP3_PANDORA is not set
# CONFIG_MACH_OMAP3_TOUCHBOOK is not set
# CONFIG_MACH_OMAP_3430SDP is not set
# CONFIG_MACH_NOKIA_RM680 is not set
# CONFIG_MACH_NOKIA_RX51 is not set
# CONFIG_MACH_OMAP_ZOOM2 is not set
# CONFIG_MACH_OMAP_ZOOM3 is not set
# CONFIG_MACH_CM_T35 is not set
# CONFIG_MACH_CM_T3517 is not set
# CONFIG_MACH_IGEP0020 is not set
# CONFIG_MACH_IGEP0030 is not set
# CONFIG_MACH_SBC3530 is not set
# CONFIG_MACH_OMAP_3630SDP is not set
# CONFIG_OMAP3_EMU is not set
# CONFIG_OMAP3_SDRC_AC_TIMING is not set
# System MMU
CONFIG_IPIPE_ARM_KUSER_TSC=y
# Processor Type
CONFIG_CPU_32v6K=y
CONFIG_CPU_V7=y
CONFIG_CPU_32v7=y
CONFIG_CPU_ABRT_EV7=y
CONFIG_CPU_PABRT_V7=y
CONFIG_CPU_CACHE_V7=y
CONFIG_CPU_CACHE_VIPT=y
CONFIG_CPU_COPY_V6=y
CONFIG_CPU_TLB_V7=y
CONFIG_CPU_HAS_ASID=y
CONFIG_CPU_CP15=y
CONFIG_CPU_CP15_MMU=y
CONFIG_CPU_USE_DOMAINS=y
# Processor Features
CONFIG_ARM_THUMB=y
CONFIG_ARM_THUMBEE=y
# CONFIG_CPU_ICACHE_DISABLE is not set
# CONFIG_CPU_DCACHE_DISABLE is not set
# CONFIG_CPU_BPREDICT_DISABLE is not set
CONFIG_ARM_L1_CACHE_SHIFT=6
CONFIG_ARM_DMA_MEM_BUFFERABLE=y
CONFIG_ARM_ERRATA_430973=y
# CONFIG_ARM_ERRATA_458693 is not set
# CONFIG_ARM_ERRATA_460075 is not set
# CONFIG_ARM_ERRATA_743622 is not set
# Bus support
# CONFIG_PCI_SYSCALL is not set
# CONFIG_ARCH_SUPPORTS_MSI is not set
# CONFIG_PCCARD is not set
# Kernel Features
CONFIG_TICK_ONESHOT=y
# CONFIG_NO_HZ is not set
CONFIG_HIGH_RES_TIMERS=y
CONFIG_GENERIC_CLOCKEVENTS_BUILD=y
CONFIG_VMSPLIT_3G=y
# CONFIG_VMSPLIT_2G is not set
# CONFIG_VMSPLIT_1G is not set
CONFIG_PAGE_OFFSET=0xC0000000
CONFIG_IPIPE=y
CONFIG_IPIPE_DOMAINS=4
CONFIG_IPIPE_DELAYED_ATOMICSW=y
# CONFIG_IPIPE_UNMASKED_CONTEXT_SWITCH is not set
CONFIG_HAVE_IPIPE_HOSTRT=y
# CONFIG_PREEMPT_NONE is not set
# CONFIG_PREEMPT_VOLUNTARY is not set
CONFIG_PREEMPT=y
CONFIG_HZ=100
# CONFIG_THUMB2_KERNEL is not set
CONFIG_AEABI=y
# CONFIG_OABI_COMPAT is not set
CONFIG_ARCH_HAS_HOLES_MEMORYMODEL=y
# CONFIG_ARCH_SPARSEMEM_DEFAULT is not set
# CONFIG_ARCH_SELECT_MEMORY_MODEL is not set
# CONFIG_HIGHMEM is not set
CONFIG_SELECT_MEMORY_MODEL=y
CONFIG_FLATMEM_MANUAL=y
CONFIG_FLATMEM=y
CONFIG_FLAT_NODE_MEM_MAP=y
CONFIG_HAVE_MEMBLOCK=y
CONFIG_PAGEFLAGS_EXTENDED=y
CONFIG_SPLIT_PTLOCK_CPUS=4
CONFIG_COMPACTION=y
CONFIG_MIGRATION=y
# CONFIG_PHYS_ADDR_T_64BIT is not set
CONFIG_ZONE_DMA_FLAG=0
CONFIG_VIRT_TO_BUS=y
# CONFIG_KSM is not set
CONFIG_DEFAULT_MMAP_MIN_ADDR=4096
CONFIG_NEED_PER_CPU_KM=y
CONFIG_FORCE_MAX_ZONEORDER=11
CONFIG_LEDS=y
CONFIG_ALIGNMENT_TRAP=y
# CONFIG_UACCESS_WITH_MEMCPY is not set
# CONFIG_SECCOMP is not set
# CONFIG_CC_STACKPROTECTOR is not set
# CONFIG_DEPRECATED_PARAM_STRUCT is not set
# Boot options
CONFIG_ZBOOT_ROM_TEXT=0x0
CONFIG_ZBOOT_ROM_BSS=0x0
CONFIG_CMDLINE=" loglevel=3"
# CONFIG_CMDLINE_FORCE is not set
# CONFIG_XIP_KERNEL is not set
CONFIG_KEXEC=y
CONFIG_ATAGS_PROC=y
# CONFIG_CRASH_DUMP is not set
CONFIG_AUTO_ZRELADDR=y
# CPU Power Management
# CONFIG_CPU_FREQ is not set
# CONFIG_CPU_IDLE is not set
# Floating point emulation
# At least one emulation must be selected
CONFIG_VFP=y
CONFIG_VFPv3=y
CONFIG_NEON=y
# Userspace binary formats
CONFIG_BINFMT_ELF=y
# CONFIG_CORE_DUMP_DEFAULT_ELF_HEADERS is not set
CONFIG_HAVE_AOUT=y
# CONFIG_BINFMT_AOUT is not set
CONFIG_BINFMT_MISC=y
# Power management options
CONFIG_PM=y
# CONFIG_PM_DEBUG is not set
CONFIG_PM_SLEEP=y
CONFIG_SUSPEND=y
CONFIG_SUSPEND_FREEZER=y
# CONFIG_APM_EMULATION is not set
CONFIG_PM_RUNTIME=y
CONFIG_PM_OPS=y
CONFIG_ARCH_HAS_OPP=y
CONFIG_PM_OPP=y
CONFIG_ARCH_SUSPEND_POSSIBLE=y
CONFIG_NET=y
# Networking options
CONFIG_PACKET=y
CONFIG_UNIX=y
CONFIG_XFRM=y
# CONFIG_XFRM_USER is not set
# CONFIG_XFRM_SUB_POLICY is not set
# CONFIG_XFRM_MIGRATE is not set
# CONFIG_XFRM_STATISTICS is not set
CONFIG_NET_KEY=y
# CONFIG_NET_KEY_MIGRATE is not set
CONFIG_INET=y
# CONFIG_IP_MULTICAST is not set
# CONFIG_IP_ADVANCED_ROUTER is not set
CONFIG_IP_FIB_HASH=y
CONFIG_IP_PNP=y
CONFIG_IP_PNP_DHCP=y
CONFIG_IP_PNP_BOOTP=y
CONFIG_IP_PNP_RARP=y
# CONFIG_NET_IPIP is not set
# CONFIG_NET_IPGRE_DEMUX is not set
# CONFIG_ARPD is not set
# CONFIG_SYN_COOKIES is not set
# CONFIG_INET_AH is not set
# CONFIG_INET_ESP is not set
# CONFIG_INET_IPCOMP is not set
# CONFIG_INET_XFRM_TUNNEL is not set
# CONFIG_INET_TUNNEL is not set
# CONFIG_INET_XFRM_MODE_TRANSPORT is not set
# CONFIG_INET_XFRM_MODE_TUNNEL is not set
# CONFIG_INET_XFRM_MODE_BEET is not set
# CONFIG_INET_LRO is not set
# CONFIG_INET_DIAG is not set
# CONFIG_TCP_CONG_ADVANCED is not set
CONFIG_TCP_CONG_CUBIC=y
CONFIG_DEFAULT_TCP_CONG="cubic"
# CONFIG_TCP_MD5SIG is not set
# CONFIG_IPV6 is not set
# CONFIG_NETWORK_SECMARK is not set
CONFIG_NETWORK_PHY_TIMESTAMPING=y
# CONFIG_NETFILTER is not set
# CONFIG_IP_DCCP is not set
# CONFIG_IP_SCTP is not set
# CONFIG_RDS is not set
# CONFIG_TIPC is not set
# CONFIG_ATM is not set
# CONFIG_L2TP is not set
# CONFIG_BRIDGE is not set
# CONFIG_NET_DSA is not set
# CONFIG_VLAN_8021Q is not set
# CONFIG_DECNET is not set
# CONFIG_LLC2 is not set
# CONFIG_IPX is not set
# CONFIG_ATALK is not set
# CONFIG_X25 is not set
# CONFIG_LAPB is not set
# CONFIG_ECONET is not set
# CONFIG_WAN_ROUTER is not set
# CONFIG_PHONET is not set
# CONFIG_IEEE802154 is not set
# CONFIG_NET_SCHED is not set
# CONFIG_DCB is not set
CONFIG_DNS_RESOLVER=y
# CONFIG_BATMAN_ADV is not set
# Network testing
# CONFIG_NET_PKTGEN is not set
# CONFIG_HAMRADIO is not set
# CONFIG_CAN is not set
# CONFIG_IRDA is not set
# CONFIG_BT is not set
# CONFIG_AF_RXRPC is not set
CONFIG_WIRELESS=y
CONFIG_WIRELESS_EXT=y
CONFIG_WEXT_CORE=y
CONFIG_WEXT_PROC=y
CONFIG_WEXT_SPY=y
CONFIG_WEXT_PRIV=y
CONFIG_CFG80211=y
# CONFIG_NL80211_TESTMODE is not set
# CONFIG_CFG80211_DEVELOPER_WARNINGS is not set
# CONFIG_CFG80211_REG_DEBUG is not set
# CONFIG_CFG80211_DEFAULT_PS is not set
# CONFIG_CFG80211_DEBUGFS is not set
# CONFIG_CFG80211_INTERNAL_REGDB is not set
CONFIG_CFG80211_WEXT=y
CONFIG_WIRELESS_EXT_SYSFS=y
CONFIG_LIB80211=y
CONFIG_LIB80211_CRYPT_WEP=m
CONFIG_LIB80211_CRYPT_CCMP=m
CONFIG_LIB80211_CRYPT_TKIP=m
# CONFIG_LIB80211_DEBUG is not set
CONFIG_MAC80211=y
CONFIG_MAC80211_HAS_RC=y
CONFIG_MAC80211_RC_PID=y
# CONFIG_MAC80211_RC_MINSTREL is not set
CONFIG_MAC80211_RC_DEFAULT_PID=y
CONFIG_MAC80211_RC_DEFAULT="pid"
# CONFIG_MAC80211_MESH is not set
CONFIG_MAC80211_LEDS=y
# CONFIG_MAC80211_DEBUGFS is not set
# CONFIG_MAC80211_DEBUG_MENU is not set
# CONFIG_WIMAX is not set
# CONFIG_RFKILL is not set
# CONFIG_NET_9P is not set
# CONFIG_CAIF is not set
# CONFIG_CEPH_LIB is not set
# Device Drivers
# Generic Driver Options
CONFIG_UEVENT_HELPER_PATH=""
CONFIG_DEVTMPFS=y
CONFIG_DEVTMPFS_MOUNT=y
CONFIG_STANDALONE=y
CONFIG_PREVENT_FIRMWARE_BUILD=y
CONFIG_FW_LOADER=y
CONFIG_FIRMWARE_IN_KERNEL=y
CONFIG_EXTRA_FIRMWARE=""
# CONFIG_DEBUG_DRIVER is not set
# CONFIG_DEBUG_DEVRES is not set
# CONFIG_SYS_HYPERVISOR is not set
# CONFIG_CONNECTOR is not set
CONFIG_MTD=y
# CONFIG_MTD_DEBUG is not set
# CONFIG_MTD_TESTS is not set
# CONFIG_MTD_CONCAT is not set
CONFIG_MTD_PARTITIONS=y
# CONFIG_MTD_REDBOOT_PARTS is not set
# CONFIG_MTD_CMDLINE_PARTS is not set
# CONFIG_MTD_AFS_PARTS is not set
# CONFIG_MTD_AR7_PARTS is not set
# User Modules And Translation Layers
CONFIG_MTD_CHAR=y
CONFIG_MTD_BLKDEVS=y
CONFIG_MTD_BLOCK=y
# CONFIG_FTL is not set
# CONFIG_NFTL is not set
# CONFIG_INFTL is not set
# CONFIG_RFD_FTL is not set
# CONFIG_SSFDC is not set
# CONFIG_SM_FTL is not set
# CONFIG_MTD_OOPS is not set
# RAM/ROM/Flash chip drivers
# CONFIG_MTD_CFI is not set
# CONFIG_MTD_JEDECPROBE is not set
CONFIG_MTD_MAP_BANK_WIDTH_1=y
CONFIG_MTD_MAP_BANK_WIDTH_2=y
CONFIG_MTD_MAP_BANK_WIDTH_4=y
# CONFIG_MTD_MAP_BANK_WIDTH_8 is not set
# CONFIG_MTD_MAP_BANK_WIDTH_16 is not set
# CONFIG_MTD_MAP_BANK_WIDTH_32 is not set
CONFIG_MTD_CFI_I1=y
CONFIG_MTD_CFI_I2=y
# CONFIG_MTD_CFI_I4 is not set
# CONFIG_MTD_CFI_I8 is not set
# CONFIG_MTD_RAM is not set
# CONFIG_MTD_ROM is not set
# CONFIG_MTD_ABSENT is not set
# Mapping drivers for chip access
# CONFIG_MTD_COMPLEX_MAPPINGS is not set
# CONFIG_MTD_PLATRAM is not set
# Self-contained MTD device drivers
# CONFIG_MTD_DATAFLASH is not set
# CONFIG_MTD_M25P80 is not set
# CONFIG_MTD_SST25L is not set
# CONFIG_MTD_SLRAM is not set
# CONFIG_MTD_PHRAM is not set
# CONFIG_MTD_MTDRAM is not set
# CONFIG_MTD_BLOCK2MTD is not set
# Disk-On-Chip Device Drivers
# CONFIG_MTD_DOC2000 is not set
# CONFIG_MTD_DOC2001 is not set
# CONFIG_MTD_DOC2001PLUS is not set
CONFIG_MTD_NAND_ECC=y
# CONFIG_MTD_NAND_ECC_SMC is not set
CONFIG_MTD_NAND=y
# CONFIG_MTD_NAND_VERIFY_WRITE is not set
# CONFIG_MTD_SM_COMMON is not set
# CONFIG_MTD_NAND_MUSEUM_IDS is not set
# CONFIG_MTD_NAND_GPIO is not set
CONFIG_MTD_NAND_OMAP2=y
CONFIG_MTD_NAND_OMAP_PREFETCH=y
# CONFIG_MTD_NAND_OMAP_PREFETCH_DMA is not set
CONFIG_MTD_NAND_IDS=y
# CONFIG_MTD_NAND_DISKONCHIP is not set
# CONFIG_MTD_NAND_NANDSIM is not set
CONFIG_MTD_NAND_PLATFORM=y
# CONFIG_MTD_ALAUDA is not set
# CONFIG_MTD_ONENAND is not set
# LPDDR flash memory drivers
# CONFIG_MTD_LPDDR is not set
CONFIG_MTD_UBI=y
CONFIG_MTD_UBI_WL_THRESHOLD=4096
CONFIG_MTD_UBI_BEB_RESERVE=1
# CONFIG_MTD_UBI_GLUEBI is not set
# UBI debugging options
# CONFIG_MTD_UBI_DEBUG is not set
# CONFIG_PARPORT is not set
CONFIG_BLK_DEV=y
# CONFIG_BLK_DEV_COW_COMMON is not set
CONFIG_BLK_DEV_LOOP=y
# CONFIG_BLK_DEV_CRYPTOLOOP is not set
# DRBD disabled because PROC_FS, INET or CONNECTOR not selected
# CONFIG_BLK_DEV_NBD is not set
# CONFIG_BLK_DEV_UB is not set
CONFIG_BLK_DEV_RAM=y
CONFIG_BLK_DEV_RAM_COUNT=16
CONFIG_BLK_DEV_RAM_SIZE=16384
# CONFIG_BLK_DEV_XIP is not set
# CONFIG_CDROM_PKTCDVD is not set
# CONFIG_ATA_OVER_ETH is not set
# CONFIG_MG_DISK is not set
# CONFIG_BLK_DEV_RBD is not set
# CONFIG_MISC_DEVICES is not set
CONFIG_HAVE_IDE=y
# CONFIG_IDE is not set
# SCSI device support
CONFIG_SCSI_MOD=y
# CONFIG_RAID_ATTRS is not set
# CONFIG_SCSI is not set
# CONFIG_SCSI_DMA is not set
# CONFIG_SCSI_NETLINK is not set
# CONFIG_ATA is not set
# CONFIG_MD is not set
CONFIG_NETDEVICES=y
# CONFIG_DUMMY is not set
# CONFIG_BONDING is not set
# CONFIG_MACVLAN is not set
# CONFIG_EQUALIZER is not set
# CONFIG_TUN is not set
# CONFIG_VETH is not set
CONFIG_MII=y
CONFIG_PHYLIB=y
# MII PHY device drivers
# CONFIG_MARVELL_PHY is not set
# CONFIG_DAVICOM_PHY is not set
# CONFIG_QSEMI_PHY is not set
# CONFIG_LXT_PHY is not set
# CONFIG_CICADA_PHY is not set
# CONFIG_VITESSE_PHY is not set
# CONFIG_SMSC_PHY is not set
# CONFIG_BROADCOM_PHY is not set
# CONFIG_BCM63XX_PHY is not set
# CONFIG_ICPLUS_PHY is not set
# CONFIG_REALTEK_PHY is not set
# CONFIG_NATIONAL_PHY is not set
# CONFIG_STE10XP is not set
# CONFIG_LSI_ET1011C_PHY is not set
# CONFIG_MICREL_PHY is not set
# CONFIG_FIXED_PHY is not set
# CONFIG_MDIO_BITBANG is not set
# CONFIG_NET_ETHERNET is not set
# CONFIG_NETDEV_1000 is not set
# CONFIG_NETDEV_10000 is not set
CONFIG_WLAN=y
# CONFIG_LIBERTAS_THINFIRM is not set
# CONFIG_AT76C50X_USB is not set
# CONFIG_USB_ZD1201 is not set
# CONFIG_USB_NET_RNDIS_WLAN is not set
# CONFIG_RTL8187 is not set
# CONFIG_MAC80211_HWSIM is not set
CONFIG_ATH_COMMON=m
# CONFIG_ATH_DEBUG is not set
# CONFIG_ATH9K_HTC is not set
CONFIG_AR9170_USB=m
CONFIG_AR9170_LEDS=y
# CONFIG_CARL9170 is not set
# CONFIG_B43 is not set
# CONFIG_B43LEGACY is not set
CONFIG_HOSTAP=m
# CONFIG_HOSTAP_FIRMWARE is not set
# CONFIG_IWM is not set
# CONFIG_LIBERTAS is not set
# CONFIG_P54_COMMON is not set
# CONFIG_RT2X00 is not set
# CONFIG_RTL8192CE is not set
# CONFIG_WL1251 is not set
# CONFIG_WL12XX_MENU is not set
# CONFIG_ZD1211RW is not set
# Enable WiMAX (Networking options) to see the WiMAX drivers
# USB Network Adapters
# CONFIG_USB_CATC is not set
# CONFIG_USB_KAWETH is not set
# CONFIG_USB_PEGASUS is not set
# CONFIG_USB_RTL8150 is not set
CONFIG_USB_USBNET=y
# CONFIG_USB_NET_AX8817X is not set
# CONFIG_USB_NET_CDCETHER is not set
# CONFIG_USB_NET_CDC_EEM is not set
# CONFIG_USB_NET_CDC_NCM is not set
# CONFIG_USB_NET_DM9601 is not set
# CONFIG_USB_NET_SMSC75XX is not set
CONFIG_USB_NET_SMSC95XX=y
# CONFIG_USB_NET_GL620A is not set
# CONFIG_USB_NET_NET1080 is not set
# CONFIG_USB_NET_PLUSB is not set
# CONFIG_USB_NET_MCS7830 is not set
# CONFIG_USB_NET_RNDIS_HOST is not set
# CONFIG_USB_NET_CDC_SUBSET is not set
# CONFIG_USB_NET_ZAURUS is not set
# CONFIG_USB_NET_CX82310_ETH is not set
# CONFIG_USB_NET_INT51X1 is not set
# CONFIG_USB_IPHETH is not set
# CONFIG_USB_SIERRA_NET is not set
# CONFIG_WAN is not set
# CAIF transport drivers
# CONFIG_PPP is not set
# CONFIG_SLIP is not set
# CONFIG_NETCONSOLE is not set
# CONFIG_NETPOLL is not set
# CONFIG_NET_POLL_CONTROLLER is not set
# CONFIG_ISDN is not set
# CONFIG_PHONE is not set
# Input device support
CONFIG_INPUT=y
CONFIG_INPUT_FF_MEMLESS=y
CONFIG_INPUT_POLLDEV=m
# CONFIG_INPUT_SPARSEKMAP is not set
# Userland interfaces
# CONFIG_INPUT_MOUSEDEV is not set
# CONFIG_INPUT_JOYDEV is not set
CONFIG_INPUT_EVDEV=y
# CONFIG_INPUT_EVBUG is not set
# Input Device Drivers
CONFIG_INPUT_KEYBOARD=y
# CONFIG_KEYBOARD_ADP5588 is not set
# CONFIG_KEYBOARD_ATKBD is not set
# CONFIG_KEYBOARD_QT2160 is not set
# CONFIG_KEYBOARD_LKKBD is not set
CONFIG_KEYBOARD_GPIO=y
# CONFIG_KEYBOARD_TCA6416 is not set
# CONFIG_KEYBOARD_MATRIX is not set
# CONFIG_KEYBOARD_LM8323 is not set
# CONFIG_KEYBOARD_MAX7359 is not set
# CONFIG_KEYBOARD_MCS is not set
# CONFIG_KEYBOARD_NEWTON is not set
# CONFIG_KEYBOARD_OPENCORES is not set
# CONFIG_KEYBOARD_STOWAWAY is not set
# CONFIG_KEYBOARD_SUNKBD is not set
CONFIG_KEYBOARD_TWL4030=m
# CONFIG_KEYBOARD_XTKBD is not set
# CONFIG_INPUT_MOUSE is not set
# CONFIG_INPUT_JOYSTICK is not set
# CONFIG_INPUT_TABLET is not set
# CONFIG_INPUT_TOUCHSCREEN is not set
CONFIG_INPUT_MISC=y
# CONFIG_INPUT_AD714X is not set
# CONFIG_INPUT_ATI_REMOTE is not set
# CONFIG_INPUT_ATI_REMOTE2 is not set
# CONFIG_INPUT_KEYSPAN_REMOTE is not set
# CONFIG_INPUT_POWERMATE is not set
# CONFIG_INPUT_YEALINK is not set
# CONFIG_INPUT_CM109 is not set
CONFIG_INPUT_TWL4030_PWRBUTTON=m
CONFIG_INPUT_TWL4030_VIBRA=m
# CONFIG_INPUT_UINPUT is not set
# CONFIG_INPUT_PCF8574 is not set
# CONFIG_INPUT_PWM_BEEPER is not set
CONFIG_INPUT_GPIO_ROTARY_ENCODER=y
# CONFIG_INPUT_ADXL34X is not set
# CONFIG_INPUT_CMA3000 is not set
# Hardware I/O ports
CONFIG_SERIO=y
CONFIG_SERIO_SERPORT=y
CONFIG_SERIO_LIBPS2=y
CONFIG_SERIO_RAW=y
# CONFIG_SERIO_ALTERA_PS2 is not set
# CONFIG_SERIO_PS2MULT is not set
# CONFIG_GAMEPORT is not set
# Character devices
CONFIG_VT=y
CONFIG_CONSOLE_TRANSLATIONS=y
CONFIG_VT_CONSOLE=y
CONFIG_HW_CONSOLE=y
CONFIG_VT_HW_CONSOLE_BINDING=y
CONFIG_DEVKMEM=y
# CONFIG_SERIAL_NONSTANDARD is not set
# CONFIG_N_GSM is not set
# Serial drivers
# CONFIG_SERIAL_8250 is not set
# Non-8250 serial port support
# CONFIG_SERIAL_MAX3100 is not set
# CONFIG_SERIAL_MAX3107 is not set
CONFIG_SERIAL_CORE=y
CONFIG_SERIAL_CORE_CONSOLE=y
CONFIG_SERIAL_OMAP=y
CONFIG_SERIAL_OMAP_CONSOLE=y
# CONFIG_SERIAL_TIMBERDALE is not set
# CONFIG_SERIAL_ALTERA_JTAGUART is not set
# CONFIG_SERIAL_ALTERA_UART is not set
# CONFIG_SERIAL_IFX6X60 is not set
CONFIG_UNIX98_PTYS=y
# CONFIG_DEVPTS_MULTIPLE_INSTANCES is not set
# CONFIG_LEGACY_PTYS is not set
CONFIG_TTY_PRINTK=y
# CONFIG_HVC_DCC is not set
# CONFIG_IPMI_HANDLER is not set
CONFIG_HW_RANDOM=y
# CONFIG_HW_RANDOM_TIMERIOMEM is not set
# CONFIG_R3964 is not set
# CONFIG_RAW_DRIVER is not set
# CONFIG_TCG_TPM is not set
# CONFIG_RAMOOPS is not set
CONFIG_I2C=y
CONFIG_I2C_BOARDINFO=y
CONFIG_I2C_COMPAT=y
CONFIG_I2C_CHARDEV=y
# CONFIG_I2C_MUX is not set
CONFIG_I2C_HELPER_AUTO=y
# I2C Hardware Bus support
# I2C system bus drivers (mostly embedded / system-on-chip)
# CONFIG_I2C_DESIGNWARE is not set
# CONFIG_I2C_GPIO is not set
# CONFIG_I2C_OCORES is not set
CONFIG_I2C_OMAP=y
# CONFIG_I2C_PCA_PLATFORM is not set
# CONFIG_I2C_SIMTEC is not set
# CONFIG_I2C_XILINX is not set
# External I2C/SMBus adapter drivers
# CONFIG_I2C_PARPORT_LIGHT is not set
# CONFIG_I2C_TAOS_EVM is not set
# CONFIG_I2C_TINY_USB is not set
# Other I2C/SMBus bus drivers
# CONFIG_I2C_STUB is not set
# CONFIG_I2C_DEBUG_CORE is not set
# CONFIG_I2C_DEBUG_ALGO is not set
# CONFIG_I2C_DEBUG_BUS is not set
CONFIG_SPI=y
CONFIG_SPI_DEBUG=y
CONFIG_SPI_MASTER=y
# SPI Master Controller Drivers
# CONFIG_SPI_BITBANG is not set
# CONFIG_SPI_GPIO is not set
CONFIG_SPI_OMAP24XX=y
# CONFIG_SPI_PXA2XX_PCI is not set
# CONFIG_SPI_XILINX is not set
# CONFIG_SPI_DESIGNWARE is not set
# SPI Protocol Masters
CONFIG_SPI_SPIDEV=y
# CONFIG_SPI_TLE62X0 is not set
# PPS support
# CONFIG_PPS is not set
# PPS generators support
CONFIG_ARCH_REQUIRE_GPIOLIB=y
CONFIG_GPIOLIB=y
# CONFIG_DEBUG_GPIO is not set
CONFIG_GPIO_SYSFS=y
# Memory mapped GPIO expanders:
# CONFIG_GPIO_BASIC_MMIO is not set
# CONFIG_GPIO_IT8761E is not set
# I2C GPIO expanders:
# CONFIG_GPIO_MAX7300 is not set
# CONFIG_GPIO_MAX732X is not set
# CONFIG_GPIO_PCF857X is not set
# CONFIG_GPIO_SX150X is not set
CONFIG_GPIO_TWL4030=y
# CONFIG_GPIO_ADP5588 is not set
# PCI GPIO expanders:
# SPI GPIO expanders:
# CONFIG_GPIO_MAX7301 is not set
# CONFIG_GPIO_MCP23S08 is not set
# CONFIG_GPIO_MC33880 is not set
# CONFIG_GPIO_74X164 is not set
# AC97 GPIO expanders:
# MODULbus GPIO expanders:
# CONFIG_W1 is not set
# CONFIG_POWER_SUPPLY is not set
# CONFIG_HWMON is not set
# CONFIG_THERMAL is not set
# CONFIG_WATCHDOG is not set
CONFIG_SSB_POSSIBLE=y
# Sonics Silicon Backplane
CONFIG_SSB=y
CONFIG_SSB_SDIOHOST_POSSIBLE=y
# CONFIG_SSB_SDIOHOST is not set
# CONFIG_SSB_SILENT is not set
# CONFIG_SSB_DEBUG is not set
CONFIG_MFD_SUPPORT=y
CONFIG_MFD_CORE=y
# CONFIG_MFD_88PM860X is not set
# CONFIG_MFD_SM501 is not set
# CONFIG_MFD_ASIC3 is not set
# CONFIG_HTC_EGPIO is not set
# CONFIG_HTC_PASIC3 is not set
# CONFIG_HTC_I2CPLD is not set
# CONFIG_TPS65010 is not set
# CONFIG_TPS6507X is not set
CONFIG_TWL4030_CORE=y
CONFIG_TWL4030_POWER=y
CONFIG_TWL4030_CODEC=y
CONFIG_TWL6030_PWM=y
# CONFIG_MFD_STMPE is not set
# CONFIG_MFD_TC3589X is not set
# CONFIG_MFD_TMIO is not set
# CONFIG_MFD_T7L66XB is not set
# CONFIG_MFD_TC6387XB is not set
# CONFIG_MFD_TC6393XB is not set
# CONFIG_PMIC_DA903X is not set
# CONFIG_PMIC_ADP5520 is not set
# CONFIG_MFD_MAX8925 is not set
# CONFIG_MFD_MAX8998 is not set
# CONFIG_MFD_WM8400 is not set
# CONFIG_MFD_WM831X_I2C is not set
# CONFIG_MFD_WM831X_SPI is not set
# CONFIG_MFD_WM8350_I2C is not set
# CONFIG_MFD_WM8994 is not set
# CONFIG_MFD_PCF50633 is not set
# CONFIG_MFD_MC13XXX is not set
# CONFIG_ABX500_CORE is not set
# CONFIG_EZX_PCAP is not set
CONFIG_MFD_TPS6586X=y
# CONFIG_MFD_WL1273_CORE is not set
CONFIG_REGULATOR=y
# CONFIG_REGULATOR_DEBUG is not set
# CONFIG_REGULATOR_DUMMY is not set
# CONFIG_REGULATOR_FIXED_VOLTAGE is not set
# CONFIG_REGULATOR_VIRTUAL_CONSUMER is not set
# CONFIG_REGULATOR_USERSPACE_CONSUMER is not set
# CONFIG_REGULATOR_BQ24022 is not set
# CONFIG_REGULATOR_MAX1586 is not set
# CONFIG_REGULATOR_MAX8649 is not set
# CONFIG_REGULATOR_MAX8660 is not set
# CONFIG_REGULATOR_MAX8952 is not set
CONFIG_REGULATOR_TWL4030=y
# CONFIG_REGULATOR_LP3971 is not set
# CONFIG_REGULATOR_LP3972 is not set
# CONFIG_REGULATOR_TPS65023 is not set
# CONFIG_REGULATOR_TPS6507X is not set
# CONFIG_REGULATOR_ISL6271A is not set
# CONFIG_REGULATOR_AD5398 is not set
# CONFIG_REGULATOR_TPS6586X is not set
# CONFIG_REGULATOR_TPS6524X is not set
CONFIG_MEDIA_SUPPORT=y
# Multimedia core support
CONFIG_VIDEO_DEV=y
CONFIG_VIDEO_V4L2_COMMON=y
# CONFIG_DVB_CORE is not set
CONFIG_VIDEO_MEDIA=y
# Multimedia drivers
# CONFIG_RC_CORE is not set
# CONFIG_MEDIA_ATTACH is not set
CONFIG_MEDIA_TUNER=y
# CONFIG_MEDIA_TUNER_CUSTOMISE is not set
CONFIG_MEDIA_TUNER_SIMPLE=y
CONFIG_MEDIA_TUNER_TDA8290=y
CONFIG_MEDIA_TUNER_TDA827X=y
CONFIG_MEDIA_TUNER_TDA18271=y
CONFIG_MEDIA_TUNER_TDA9887=y
CONFIG_MEDIA_TUNER_TEA5761=y
CONFIG_MEDIA_TUNER_TEA5767=y
CONFIG_MEDIA_TUNER_MT20XX=y
CONFIG_MEDIA_TUNER_XC2028=y
CONFIG_MEDIA_TUNER_XC5000=y
CONFIG_MEDIA_TUNER_MC44S803=y
CONFIG_VIDEO_V4L2=y
CONFIG_VIDEO_CAPTURE_DRIVERS=y
# CONFIG_VIDEO_ADV_DEBUG is not set
# CONFIG_VIDEO_FIXED_MINOR_RANGES is not set
# CONFIG_VIDEO_HELPER_CHIPS_AUTO is not set
# Encoders/decoders and other helper chips
# Audio decoders
# CONFIG_VIDEO_TVAUDIO is not set
# CONFIG_VIDEO_TDA7432 is not set
# CONFIG_VIDEO_TDA9840 is not set
# CONFIG_VIDEO_TEA6415C is not set
# CONFIG_VIDEO_TEA6420 is not set
# CONFIG_VIDEO_MSP3400 is not set
# CONFIG_VIDEO_CS5345 is not set
# CONFIG_VIDEO_CS53L32A is not set
# CONFIG_VIDEO_M52790 is not set
# CONFIG_VIDEO_TLV320AIC23B is not set
# CONFIG_VIDEO_WM8775 is not set
# CONFIG_VIDEO_WM8739 is not set
# CONFIG_VIDEO_VP27SMPX is not set
# RDS decoders
# CONFIG_VIDEO_SAA6588 is not set
# Video decoders
# CONFIG_VIDEO_ADV7180 is not set
# CONFIG_VIDEO_BT819 is not set
# CONFIG_VIDEO_BT856 is not set
# CONFIG_VIDEO_BT866 is not set
# CONFIG_VIDEO_KS0127 is not set
# CONFIG_VIDEO_OV7670 is not set
# CONFIG_VIDEO_MT9V011 is not set
# CONFIG_VIDEO_TCM825X is not set
# CONFIG_VIDEO_SAA7110 is not set
# CONFIG_VIDEO_SAA711X is not set
# CONFIG_VIDEO_SAA717X is not set
# CONFIG_VIDEO_SAA7191 is not set
# CONFIG_VIDEO_TVP514X is not set
# CONFIG_VIDEO_TVP5150 is not set
# CONFIG_VIDEO_TVP7002 is not set
# CONFIG_VIDEO_VPX3220 is not set
# Video and audio decoders
# CONFIG_VIDEO_CX25840 is not set
# MPEG video encoders
# CONFIG_VIDEO_CX2341X is not set
# Video encoders
# CONFIG_VIDEO_SAA7127 is not set
# CONFIG_VIDEO_SAA7185 is not set
# CONFIG_VIDEO_ADV7170 is not set
# CONFIG_VIDEO_ADV7175 is not set
# CONFIG_VIDEO_THS7303 is not set
# CONFIG_VIDEO_ADV7343 is not set
# CONFIG_VIDEO_AK881X is not set
# Video improvement chips
# CONFIG_VIDEO_UPD64031A is not set
# CONFIG_VIDEO_UPD64083 is not set
# CONFIG_VIDEO_VPFE_CAPTURE is not set
# CONFIG_VIDEO_OMAP2_VOUT is not set
# CONFIG_VIDEO_CPIA2 is not set
# CONFIG_VIDEO_TIMBERDALE is not set
# CONFIG_VIDEO_SR030PC30 is not set
# CONFIG_SOC_CAMERA is not set
CONFIG_V4L_USB_DRIVERS=y
CONFIG_USB_VIDEO_CLASS=m
CONFIG_USB_VIDEO_CLASS_INPUT_EVDEV=y
# CONFIG_USB_GSPCA is not set
# CONFIG_VIDEO_PVRUSB2 is not set
# CONFIG_VIDEO_HDPVR is not set
# CONFIG_VIDEO_USBVISION is not set
# CONFIG_USB_ET61X251 is not set
# CONFIG_USB_SN9C102 is not set
# CONFIG_USB_PWC is not set
# CONFIG_USB_ZR364XX is not set
# CONFIG_USB_STKWEBCAM is not set
# CONFIG_USB_S2255 is not set
# CONFIG_V4L_MEM2MEM_DRIVERS is not set
# CONFIG_RADIO_ADAPTERS is not set
# Graphics support
# CONFIG_DRM is not set
# CONFIG_VGASTATE is not set
# CONFIG_VIDEO_OUTPUT_CONTROL is not set
# CONFIG_FB is not set
# CONFIG_OMAP2_DSS is not set
# CONFIG_BACKLIGHT_LCD_SUPPORT is not set
# Display device support
# CONFIG_DISPLAY_SUPPORT is not set
# Console display driver support
CONFIG_DUMMY_CONSOLE=y
# CONFIG_SOUND is not set
CONFIG_HID_SUPPORT=y
CONFIG_HID=y
# CONFIG_HIDRAW is not set
# USB Input Devices
CONFIG_USB_HID=y
# CONFIG_HID_PID is not set
# CONFIG_USB_HIDDEV is not set
# Special HID drivers
# CONFIG_HID_3M_PCT is not set
# CONFIG_HID_A4TECH is not set
# CONFIG_HID_ACRUX is not set
# CONFIG_HID_APPLE is not set
# CONFIG_HID_BELKIN is not set
# CONFIG_HID_CANDO is not set
# CONFIG_HID_CHERRY is not set
# CONFIG_HID_CHICONY is not set
# CONFIG_HID_CYPRESS is not set
# CONFIG_HID_DRAGONRISE is not set
# CONFIG_HID_EMS_FF is not set
# CONFIG_HID_EGALAX is not set
# CONFIG_HID_EZKEY is not set
# CONFIG_HID_KYE is not set
# CONFIG_HID_UCLOGIC is not set
# CONFIG_HID_WALTOP is not set
# CONFIG_HID_GYRATION is not set
# CONFIG_HID_TWINHAN is not set
# CONFIG_HID_KENSINGTON is not set
# CONFIG_HID_LOGITECH is not set
# CONFIG_HID_MICROSOFT is not set
# CONFIG_HID_MOSART is not set
# CONFIG_HID_MONTEREY is not set
# CONFIG_HID_MULTITOUCH is not set
# CONFIG_HID_NTRIG is not set
# CONFIG_HID_ORTEK is not set
# CONFIG_HID_PANTHERLORD is not set
# CONFIG_HID_PETALYNX is not set
# CONFIG_HID_PICOLCD is not set
# CONFIG_HID_QUANTA is not set
# CONFIG_HID_ROCCAT is not set
# CONFIG_HID_ROCCAT_KONE is not set
# CONFIG_HID_ROCCAT_KONEPLUS is not set
# CONFIG_HID_ROCCAT_PYRA is not set
# CONFIG_HID_SAMSUNG is not set
# CONFIG_HID_SONY is not set
# CONFIG_HID_STANTUM is not set
# CONFIG_HID_SUNPLUS is not set
# CONFIG_HID_GREENASIA is not set
# CONFIG_HID_SMARTJOYPLUS is not set
# CONFIG_HID_TOPSEED is not set
# CONFIG_HID_THRUSTMASTER is not set
# CONFIG_HID_ZEROPLUS is not set
# CONFIG_HID_ZYDACRON is not set
CONFIG_USB_SUPPORT=y
CONFIG_USB_ARCH_HAS_HCD=y
CONFIG_USB_ARCH_HAS_OHCI=y
CONFIG_USB_ARCH_HAS_EHCI=y
CONFIG_USB=y
# CONFIG_USB_DEBUG is not set
CONFIG_USB_ANNOUNCE_NEW_DEVICES=y
# Miscellaneous USB options
CONFIG_USB_DEVICEFS=y
CONFIG_USB_DEVICE_CLASS=y
CONFIG_USB_DYNAMIC_MINORS=y
# CONFIG_USB_SUSPEND is not set
CONFIG_USB_OTG=y
# CONFIG_USB_OTG_WHITELIST is not set
# CONFIG_USB_OTG_BLACKLIST_HUB is not set
# CONFIG_USB_MON is not set
# CONFIG_USB_WUSB is not set
# CONFIG_USB_WUSB_CBAF is not set
# USB Host Controller Drivers
# CONFIG_USB_C67X00_HCD is not set
CONFIG_USB_EHCI_HCD=y
# CONFIG_USB_EHCI_ROOT_HUB_TT is not set
CONFIG_USB_EHCI_TT_NEWSCHED=y
CONFIG_USB_EHCI_HCD_OMAP=y
# CONFIG_USB_OXU210HP_HCD is not set
# CONFIG_USB_ISP116X_HCD is not set
# CONFIG_USB_ISP1760_HCD is not set
# CONFIG_USB_ISP1362_HCD is not set
CONFIG_USB_OHCI_HCD=y
CONFIG_USB_OHCI_HCD_OMAP3=y
# CONFIG_USB_OHCI_HCD_SSB is not set
# CONFIG_USB_OHCI_BIG_ENDIAN_DESC is not set
# CONFIG_USB_OHCI_BIG_ENDIAN_MMIO is not set
CONFIG_USB_OHCI_LITTLE_ENDIAN=y
# CONFIG_USB_SL811_HCD is not set
# CONFIG_USB_R8A66597_HCD is not set
# CONFIG_USB_HWA_HCD is not set
CONFIG_USB_MUSB_HDRC=y
# CONFIG_USB_MUSB_TUSB6010 is not set
CONFIG_USB_MUSB_OMAP2PLUS=y
# CONFIG_USB_MUSB_AM35X is not set
# CONFIG_USB_MUSB_HOST is not set
# CONFIG_USB_MUSB_PERIPHERAL is not set
CONFIG_USB_MUSB_OTG=y
CONFIG_USB_GADGET_MUSB_HDRC=y
CONFIG_USB_MUSB_HDRC_HCD=y
# CONFIG_MUSB_PIO_ONLY is not set
CONFIG_USB_INVENTRA_DMA=y
# CONFIG_USB_TI_CPPI_DMA is not set
CONFIG_USB_MUSB_DEBUG=y
# USB Device Class drivers
CONFIG_USB_ACM=m
# CONFIG_USB_PRINTER is not set
CONFIG_USB_WDM=y
# CONFIG_USB_TMC is not set
# NOTE: USB_STORAGE depends on SCSI but BLK_DEV_SD may
# also be needed; see USB_STORAGE Help for more info
# CONFIG_USB_LIBUSUAL is not set
# USB Imaging devices
# CONFIG_USB_MDC800 is not set
# USB port drivers
CONFIG_USB_SERIAL=m
CONFIG_USB_EZUSB=y
CONFIG_USB_SERIAL_GENERIC=y
# CONFIG_USB_SERIAL_AIRCABLE is not set
# CONFIG_USB_SERIAL_ARK3116 is not set
# CONFIG_USB_SERIAL_BELKIN is not set
# CONFIG_USB_SERIAL_CH341 is not set
# CONFIG_USB_SERIAL_WHITEHEAT is not set
# CONFIG_USB_SERIAL_DIGI_ACCELEPORT is not set
# CONFIG_USB_SERIAL_CP210X is not set
# CONFIG_USB_SERIAL_CYPRESS_M8 is not set
# CONFIG_USB_SERIAL_EMPEG is not set
CONFIG_USB_SERIAL_FTDI_SIO=m
# CONFIG_USB_SERIAL_FUNSOFT is not set
# CONFIG_USB_SERIAL_VISOR is not set
# CONFIG_USB_SERIAL_IPAQ is not set
# CONFIG_USB_SERIAL_IR is not set
# CONFIG_USB_SERIAL_EDGEPORT is not set
# CONFIG_USB_SERIAL_EDGEPORT_TI is not set
# CONFIG_USB_SERIAL_GARMIN is not set
# CONFIG_USB_SERIAL_IPW is not set
# CONFIG_USB_SERIAL_IUU is not set
# CONFIG_USB_SERIAL_KEYSPAN_PDA is not set
# CONFIG_USB_SERIAL_KEYSPAN is not set
# CONFIG_USB_SERIAL_KLSI is not set
# CONFIG_USB_SERIAL_KOBIL_SCT is not set
# CONFIG_USB_SERIAL_MCT_U232 is not set
# CONFIG_USB_SERIAL_MOS7720 is not set
# CONFIG_USB_SERIAL_MOS7840 is not set
# CONFIG_USB_SERIAL_MOTOROLA is not set
# CONFIG_USB_SERIAL_NAVMAN is not set
CONFIG_USB_SERIAL_PL2303=m
# CONFIG_USB_SERIAL_OTI6858 is not set
# CONFIG_USB_SERIAL_QCAUX is not set
# CONFIG_USB_SERIAL_QUALCOMM is not set
# CONFIG_USB_SERIAL_SPCP8X5 is not set
# CONFIG_USB_SERIAL_HP4X is not set
# CONFIG_USB_SERIAL_SAFE is not set
# CONFIG_USB_SERIAL_SAMBA is not set
# CONFIG_USB_SERIAL_SIEMENS_MPI is not set
# CONFIG_USB_SERIAL_SIERRAWIRELESS is not set
# CONFIG_USB_SERIAL_SYMBOL is not set
# CONFIG_USB_SERIAL_TI is not set
# CONFIG_USB_SERIAL_CYBERJACK is not set
# CONFIG_USB_SERIAL_XIRCOM is not set
# CONFIG_USB_SERIAL_OPTION is not set
# CONFIG_USB_SERIAL_OMNINET is not set
# CONFIG_USB_SERIAL_OPTICON is not set
# CONFIG_USB_SERIAL_VIVOPAY_SERIAL is not set
# CONFIG_USB_SERIAL_ZIO is not set
# CONFIG_USB_SERIAL_SSU100 is not set
# CONFIG_USB_SERIAL_DEBUG is not set
# USB Miscellaneous drivers
# CONFIG_USB_EMI62 is not set
# CONFIG_USB_EMI26 is not set
# CONFIG_USB_ADUTUX is not set
# CONFIG_USB_SEVSEG is not set
# CONFIG_USB_RIO500 is not set
# CONFIG_USB_LEGOTOWER is not set
# CONFIG_USB_LCD is not set
# CONFIG_USB_LED is not set
# CONFIG_USB_CYPRESS_CY7C63 is not set
# CONFIG_USB_CYTHERM is not set
# CONFIG_USB_IDMOUSE is not set
# CONFIG_USB_FTDI_ELAN is not set
# CONFIG_USB_APPLEDISPLAY is not set
# CONFIG_USB_SISUSBVGA is not set
# CONFIG_USB_LD is not set
# CONFIG_USB_TRANCEVIBRATOR is not set
# CONFIG_USB_IOWARRIOR is not set
# CONFIG_USB_TEST is not set
# CONFIG_USB_ISIGHTFW is not set
# CONFIG_USB_YUREX is not set
CONFIG_USB_GADGET=y
CONFIG_USB_GADGET_DEBUG=y
CONFIG_USB_GADGET_DEBUG_FILES=y
CONFIG_USB_GADGET_DEBUG_FS=y
CONFIG_USB_GADGET_VBUS_DRAW=2
CONFIG_USB_GADGET_SELECTED=y
# CONFIG_USB_GADGET_OMAP is not set
# CONFIG_USB_GADGET_R8A66597 is not set
# CONFIG_USB_GADGET_PXA_U2O is not set
# CONFIG_USB_GADGET_M66592 is not set
# CONFIG_USB_GADGET_DUMMY_HCD is not set
CONFIG_USB_GADGET_DUALSPEED=y
# CONFIG_USB_ZERO is not set
# CONFIG_USB_ETH is not set
# CONFIG_USB_G_NCM is not set
# CONFIG_USB_GADGETFS is not set
# CONFIG_USB_FUNCTIONFS is not set
# CONFIG_USB_FILE_STORAGE is not set
# CONFIG_USB_MASS_STORAGE is not set
# CONFIG_USB_G_SERIAL is not set
# CONFIG_USB_G_PRINTER is not set
# CONFIG_USB_CDC_COMPOSITE is not set
# CONFIG_USB_G_MULTI is not set
CONFIG_USB_G_HID=m
# CONFIG_USB_G_DBGP is not set
# CONFIG_USB_G_WEBCAM is not set
# OTG and related infrastructure
CONFIG_USB_OTG_UTILS=y
CONFIG_USB_GPIO_VBUS=y
# CONFIG_ISP1301_OMAP is not set
# CONFIG_USB_ULPI is not set
CONFIG_TWL4030_USB=y
# CONFIG_TWL6030_USB is not set
# CONFIG_NOP_USB_XCEIV is not set
CONFIG_MMC=y
# CONFIG_MMC_DEBUG is not set
CONFIG_MMC_UNSAFE_RESUME=y
# CONFIG_MMC_CLKGATE is not set
# MMC/SD/SDIO Card Drivers
CONFIG_MMC_BLOCK=y
CONFIG_MMC_BLOCK_MINORS=8
CONFIG_MMC_BLOCK_BOUNCE=y
CONFIG_SDIO_UART=y
# CONFIG_MMC_TEST is not set
# MMC/SD/SDIO Host Controller Drivers
# CONFIG_MMC_SDHCI is not set
# CONFIG_MMC_OMAP is not set
CONFIG_MMC_OMAP_HS=y
CONFIG_MMC_SPI=m
# CONFIG_MMC_DW is not set
CONFIG_MMC_USHC=m
# CONFIG_MEMSTICK is not set
CONFIG_NEW_LEDS=y
CONFIG_LEDS_CLASS=y
# LED drivers
# CONFIG_LEDS_PCA9532 is not set
CONFIG_LEDS_GPIO=y
CONFIG_LEDS_GPIO_PLATFORM=y
# CONFIG_LEDS_LP3944 is not set
# CONFIG_LEDS_LP5521 is not set
# CONFIG_LEDS_LP5523 is not set
# CONFIG_LEDS_PCA955X is not set
# CONFIG_LEDS_DAC124S085 is not set
CONFIG_LEDS_PWM=y
CONFIG_LEDS_REGULATOR=y
# CONFIG_LEDS_BD2802 is not set
# CONFIG_LEDS_LT3593 is not set
CONFIG_LEDS_TRIGGERS=y
# LED Triggers
CONFIG_LEDS_TRIGGER_TIMER=y
CONFIG_LEDS_TRIGGER_HEARTBEAT=y
CONFIG_LEDS_TRIGGER_BACKLIGHT=y
CONFIG_LEDS_TRIGGER_GPIO=y
CONFIG_LEDS_TRIGGER_DEFAULT_ON=y
# iptables trigger is under Netfilter config (LED target)
# CONFIG_NFC_DEVICES is not set
# CONFIG_ACCESSIBILITY is not set
CONFIG_RTC_LIB=y
CONFIG_RTC_CLASS=y
CONFIG_RTC_HCTOSYS=y
CONFIG_RTC_HCTOSYS_DEVICE="rtc0"
# CONFIG_RTC_DEBUG is not set
# RTC interfaces
CONFIG_RTC_INTF_SYSFS=y
CONFIG_RTC_INTF_PROC=y
CONFIG_RTC_INTF_DEV=y
# CONFIG_RTC_INTF_DEV_UIE_EMUL is not set
# CONFIG_RTC_DRV_TEST is not set
# I2C RTC drivers
CONFIG_RTC_DRV_DS1307=y
# CONFIG_RTC_DRV_DS1374 is not set
# CONFIG_RTC_DRV_DS1672 is not set
# CONFIG_RTC_DRV_DS3232 is not set
# CONFIG_RTC_DRV_MAX6900 is not set
# CONFIG_RTC_DRV_RS5C372 is not set
# CONFIG_RTC_DRV_ISL1208 is not set
# CONFIG_RTC_DRV_ISL12022 is not set
# CONFIG_RTC_DRV_X1205 is not set
# CONFIG_RTC_DRV_PCF8563 is not set
# CONFIG_RTC_DRV_PCF8583 is not set
# CONFIG_RTC_DRV_M41T80 is not set
# CONFIG_RTC_DRV_BQ32K is not set
CONFIG_RTC_DRV_TWL4030=y
# CONFIG_RTC_DRV_S35390A is not set
# CONFIG_RTC_DRV_FM3130 is not set
# CONFIG_RTC_DRV_RX8581 is not set
# CONFIG_RTC_DRV_RX8025 is not set
# SPI RTC drivers
# CONFIG_RTC_DRV_M41T94 is not set
# CONFIG_RTC_DRV_DS1305 is not set
# CONFIG_RTC_DRV_DS1390 is not set
# CONFIG_RTC_DRV_MAX6902 is not set
# CONFIG_RTC_DRV_R9701 is not set
# CONFIG_RTC_DRV_RS5C348 is not set
# CONFIG_RTC_DRV_DS3234 is not set
# CONFIG_RTC_DRV_PCF2123 is not set
# Platform RTC drivers
# CONFIG_RTC_DRV_CMOS is not set
# CONFIG_RTC_DRV_DS1286 is not set
# CONFIG_RTC_DRV_DS1511 is not set
# CONFIG_RTC_DRV_DS1553 is not set
# CONFIG_RTC_DRV_DS1742 is not set
# CONFIG_RTC_DRV_STK17TA8 is not set
# CONFIG_RTC_DRV_M48T86 is not set
# CONFIG_RTC_DRV_M48T35 is not set
# CONFIG_RTC_DRV_M48T59 is not set
# CONFIG_RTC_DRV_MSM6242 is not set
# CONFIG_RTC_DRV_BQ4802 is not set
# CONFIG_RTC_DRV_RP5C01 is not set
# CONFIG_RTC_DRV_V3020 is not set
# on-CPU RTC drivers
# CONFIG_DMADEVICES is not set
# CONFIG_AUXDISPLAY is not set
# CONFIG_UIO is not set
CONFIG_STAGING=y
# CONFIG_STAGING_EXCLUDE_BUILD is not set
# CONFIG_USB_DABUSB is not set
# CONFIG_USB_SE401 is not set
# CONFIG_USB_VICAM is not set
# CONFIG_USB_IP_COMMON is not set
# CONFIG_W35UND is not set
# CONFIG_PRISM2_USB is not set
# CONFIG_ECHO is not set
# CONFIG_BRCM80211 is not set
# CONFIG_RT2870 is not set
# CONFIG_COMEDI is not set
# CONFIG_ASUS_OLED is not set
# CONFIG_R8712U is not set
# CONFIG_TRANZPORT is not set
# CONFIG_POHMELFS is not set
# CONFIG_AUTOFS_FS is not set
# CONFIG_USB_SERIAL_QUATECH2 is not set
# CONFIG_USB_SERIAL_QUATECH_USB2 is not set
# CONFIG_VT6656 is not set
# CONFIG_IIO is not set
# CONFIG_ZRAM is not set
# Texas Instruments shared transport line discipline
# CONFIG_SMB_FS is not set
CONFIG_EASYCAP=m
# CONFIG_TIDSPBRIDGE is not set
# CONFIG_MACH_OMAP3_WESTBRIDGE_AST_PNAND_HAL is not set
CONFIG_MACH_NO_WESTBRIDGE=y
# CONFIG_ATH6K_LEGACY is not set
# CONFIG_BCM_WIMAX is not set
# CONFIG_FT1000 is not set
# Speakup console speech
# CONFIG_SPEAKUP is not set
# CONFIG_TOUCHSCREEN_CLEARPAD_TM1217 is not set
# CONFIG_TOUCHSCREEN_SYNAPTICS_I2C_RMI4 is not set
CONFIG_CLKDEV_LOOKUP=y
# File systems
CONFIG_EXT2_FS=y
# CONFIG_EXT2_FS_XATTR is not set
# CONFIG_EXT2_FS_XIP is not set
CONFIG_EXT3_FS=y
# CONFIG_EXT3_DEFAULTS_TO_ORDERED is not set
# CONFIG_EXT3_FS_XATTR is not set
CONFIG_EXT4_FS=y
# CONFIG_EXT4_FS_XATTR is not set
# CONFIG_EXT4_DEBUG is not set
CONFIG_JBD=y
# CONFIG_JBD_DEBUG is not set
CONFIG_JBD2=y
# CONFIG_JBD2_DEBUG is not set
# CONFIG_REISERFS_FS is not set
# CONFIG_JFS_FS is not set
# CONFIG_XFS_FS is not set
# CONFIG_GFS2_FS is not set
# CONFIG_OCFS2_FS is not set
# CONFIG_BTRFS_FS is not set
# CONFIG_NILFS2_FS is not set
CONFIG_FS_POSIX_ACL=y
CONFIG_FILE_LOCKING=y
CONFIG_FSNOTIFY=y
CONFIG_DNOTIFY=y
CONFIG_INOTIFY_USER=y
CONFIG_FANOTIFY=y
# CONFIG_QUOTA is not set
# CONFIG_QUOTACTL is not set
CONFIG_AUTOFS4_FS=y
CONFIG_FUSE_FS=y
# CONFIG_CUSE is not set
CONFIG_GENERIC_ACL=y
# Caches
# CONFIG_FSCACHE is not set
# CD-ROM/DVD Filesystems
# CONFIG_ISO9660_FS is not set
# CONFIG_UDF_FS is not set
# DOS/FAT/NT Filesystems
CONFIG_FAT_FS=y
CONFIG_MSDOS_FS=y
CONFIG_VFAT_FS=y
CONFIG_FAT_DEFAULT_CODEPAGE=437
CONFIG_FAT_DEFAULT_IOCHARSET="iso8859-1"
# CONFIG_NTFS_FS is not set
# Pseudo filesystems
CONFIG_PROC_FS=y
CONFIG_PROC_SYSCTL=y
CONFIG_PROC_PAGE_MONITOR=y
CONFIG_SYSFS=y
CONFIG_TMPFS=y
CONFIG_TMPFS_POSIX_ACL=y
# CONFIG_HUGETLB_PAGE is not set
CONFIG_CONFIGFS_FS=y
CONFIG_MISC_FILESYSTEMS=y
# CONFIG_ADFS_FS is not set
# CONFIG_AFFS_FS is not set
# CONFIG_ECRYPT_FS is not set
# CONFIG_HFS_FS is not set
# CONFIG_HFSPLUS_FS is not set
# CONFIG_BEFS_FS is not set
# CONFIG_BFS_FS is not set
# CONFIG_EFS_FS is not set
# CONFIG_JFFS2_FS is not set
CONFIG_UBIFS_FS=y
CONFIG_UBIFS_FS_XATTR=y
CONFIG_UBIFS_FS_ADVANCED_COMPR=y
CONFIG_UBIFS_FS_LZO=y
CONFIG_UBIFS_FS_ZLIB=y
# CONFIG_UBIFS_FS_DEBUG is not set
# CONFIG_LOGFS is not set
# CONFIG_CRAMFS is not set
# CONFIG_SQUASHFS is not set
# CONFIG_VXFS_FS is not set
# CONFIG_MINIX_FS is not set
# CONFIG_OMFS_FS is not set
# CONFIG_HPFS_FS is not set
# CONFIG_QNX4FS_FS is not set
# CONFIG_ROMFS_FS is not set
# CONFIG_SYSV_FS is not set
# CONFIG_UFS_FS is not set
CONFIG_NETWORK_FILESYSTEMS=y
CONFIG_NFS_FS=y
CONFIG_NFS_V3=y
CONFIG_NFS_V3_ACL=y
CONFIG_NFS_V4=y
CONFIG_NFS_V4_1=y
CONFIG_PNFS_FILE_LAYOUT=y
CONFIG_ROOT_NFS=y
# CONFIG_NFS_USE_LEGACY_DNS is not set
CONFIG_NFS_USE_KERNEL_DNS=y
# CONFIG_NFS_USE_NEW_IDMAPPER is not set
# CONFIG_NFSD is not set
CONFIG_LOCKD=y
CONFIG_LOCKD_V4=y
CONFIG_NFS_ACL_SUPPORT=y
CONFIG_NFS_COMMON=y
CONFIG_SUNRPC=y
CONFIG_SUNRPC_GSS=y
CONFIG_RPCSEC_GSS_KRB5=y
# CONFIG_CEPH_FS is not set
# CONFIG_CIFS is not set
# CONFIG_NCP_FS is not set
# CONFIG_CODA_FS is not set
# CONFIG_AFS_FS is not set
# Partition Types
CONFIG_PARTITION_ADVANCED=y
# CONFIG_ACORN_PARTITION is not set
# CONFIG_OSF_PARTITION is not set
# CONFIG_AMIGA_PARTITION is not set
# CONFIG_ATARI_PARTITION is not set
# CONFIG_MAC_PARTITION is not set
CONFIG_MSDOS_PARTITION=y
CONFIG_BSD_DISKLABEL=y
CONFIG_MINIX_SUBPARTITION=y
CONFIG_SOLARIS_X86_PARTITION=y
# CONFIG_UNIXWARE_DISKLABEL is not set
CONFIG_LDM_PARTITION=y
CONFIG_LDM_DEBUG=y
# CONFIG_SGI_PARTITION is not set
# CONFIG_ULTRIX_PARTITION is not set
# CONFIG_SUN_PARTITION is not set
# CONFIG_KARMA_PARTITION is not set
CONFIG_EFI_PARTITION=y
# CONFIG_SYSV68_PARTITION is not set
CONFIG_NLS=y
CONFIG_NLS_DEFAULT="utf8"
CONFIG_NLS_CODEPAGE_437=y
# CONFIG_NLS_CODEPAGE_737 is not set
# CONFIG_NLS_CODEPAGE_775 is not set
# CONFIG_NLS_CODEPAGE_850 is not set
# CONFIG_NLS_CODEPAGE_852 is not set
# CONFIG_NLS_CODEPAGE_855 is not set
# CONFIG_NLS_CODEPAGE_857 is not set
# CONFIG_NLS_CODEPAGE_860 is not set
# CONFIG_NLS_CODEPAGE_861 is not set
# CONFIG_NLS_CODEPAGE_862 is not set
# CONFIG_NLS_CODEPAGE_863 is not set
# CONFIG_NLS_CODEPAGE_864 is not set
# CONFIG_NLS_CODEPAGE_865 is not set
# CONFIG_NLS_CODEPAGE_866 is not set
# CONFIG_NLS_CODEPAGE_869 is not set
# CONFIG_NLS_CODEPAGE_936 is not set
# CONFIG_NLS_CODEPAGE_950 is not set
# CONFIG_NLS_CODEPAGE_932 is not set
# CONFIG_NLS_CODEPAGE_949 is not set
# CONFIG_NLS_CODEPAGE_874 is not set
# CONFIG_NLS_ISO8859_8 is not set
# CONFIG_NLS_CODEPAGE_1250 is not set
# CONFIG_NLS_CODEPAGE_1251 is not set
CONFIG_NLS_ASCII=y
# CONFIG_NLS_ISO8859_1 is not set
# CONFIG_NLS_ISO8859_2 is not set
# CONFIG_NLS_ISO8859_3 is not set
# CONFIG_NLS_ISO8859_4 is not set
# CONFIG_NLS_ISO8859_5 is not set
# CONFIG_NLS_ISO8859_6 is not set
# CONFIG_NLS_ISO8859_7 is not set
# CONFIG_NLS_ISO8859_9 is not set
# CONFIG_NLS_ISO8859_13 is not set
# CONFIG_NLS_ISO8859_14 is not set
# CONFIG_NLS_ISO8859_15 is not set
# CONFIG_NLS_KOI8_R is not set
# CONFIG_NLS_KOI8_U is not set
CONFIG_NLS_UTF8=y
# CONFIG_DLM is not set
# Kernel hacking
CONFIG_PRINTK_TIME=y
CONFIG_ENABLE_WARN_DEPRECATED=y
CONFIG_ENABLE_MUST_CHECK=y
CONFIG_FRAME_WARN=1024
CONFIG_MAGIC_SYSRQ=y
# CONFIG_STRIP_ASM_SYMS is not set
# CONFIG_UNUSED_SYMBOLS is not set
CONFIG_DEBUG_FS=y
# CONFIG_HEADERS_CHECK is not set
CONFIG_IPIPE_DEBUG=y
CONFIG_IPIPE_DEBUG_CONTEXT=y
CONFIG_IPIPE_DEBUG_INTERNAL=y
# CONFIG_IPIPE_TRACE is not set
CONFIG_DEBUG_KERNEL=y
# CONFIG_DEBUG_SHIRQ is not set
# CONFIG_LOCKUP_DETECTOR is not set
# CONFIG_HARDLOCKUP_DETECTOR is not set
CONFIG_DETECT_HUNG_TASK=y
# CONFIG_BOOTPARAM_HUNG_TASK_PANIC is not set
CONFIG_BOOTPARAM_HUNG_TASK_PANIC_VALUE=0
CONFIG_SCHED_DEBUG=y
CONFIG_SCHEDSTATS=y
CONFIG_TIMER_STATS=y
# CONFIG_DEBUG_OBJECTS is not set
# CONFIG_DEBUG_SLAB is not set
# CONFIG_DEBUG_KMEMLEAK is not set
CONFIG_DEBUG_PREEMPT=y
CONFIG_DEBUG_RT_MUTEXES=y
CONFIG_DEBUG_PI_LIST=y
# CONFIG_RT_MUTEX_TESTER is not set
# CONFIG_DEBUG_SPINLOCK is not set
CONFIG_DEBUG_MUTEXES=y
CONFIG_BKL=y
# CONFIG_DEBUG_LOCK_ALLOC is not set
# CONFIG_PROVE_LOCKING is not set
# CONFIG_SPARSE_RCU_POINTER is not set
# CONFIG_LOCK_STAT is not set
# CONFIG_DEBUG_SPINLOCK_SLEEP is not set
# CONFIG_DEBUG_LOCKING_API_SELFTESTS is not set
# CONFIG_DEBUG_KOBJECT is not set
CONFIG_DEBUG_BUGVERBOSE=y
# CONFIG_DEBUG_INFO is not set
# CONFIG_DEBUG_VM is not set
# CONFIG_DEBUG_WRITECOUNT is not set
# CONFIG_DEBUG_MEMORY_INIT is not set
# CONFIG_DEBUG_LIST is not set
# CONFIG_TEST_LIST_SORT is not set
# CONFIG_DEBUG_SG is not set
# CONFIG_DEBUG_NOTIFIERS is not set
# CONFIG_DEBUG_CREDENTIALS is not set
# CONFIG_BOOT_PRINTK_DELAY is not set
# CONFIG_RCU_TORTURE_TEST is not set
# CONFIG_BACKTRACE_SELF_TEST is not set
# CONFIG_DEBUG_BLOCK_EXT_DEVT is not set
# CONFIG_DEBUG_FORCE_WEAK_PER_CPU is not set
# CONFIG_LKDTM is not set
# CONFIG_FAULT_INJECTION is not set
# CONFIG_LATENCYTOP is not set
# CONFIG_SYSCTL_SYSCALL_CHECK is not set
# CONFIG_PAGE_POISONING is not set
CONFIG_HAVE_FUNCTION_TRACER=y
CONFIG_HAVE_FUNCTION_GRAPH_TRACER=y
CONFIG_HAVE_DYNAMIC_FTRACE=y
CONFIG_HAVE_FTRACE_MCOUNT_RECORD=y
CONFIG_HAVE_C_RECORDMCOUNT=y
CONFIG_RING_BUFFER=y
CONFIG_RING_BUFFER_ALLOW_SWAP=y
CONFIG_TRACING_SUPPORT=y
CONFIG_FTRACE=y
# CONFIG_FUNCTION_TRACER is not set
# CONFIG_IRQSOFF_TRACER is not set
# CONFIG_PREEMPT_TRACER is not set
# CONFIG_SCHED_TRACER is not set
# CONFIG_ENABLE_DEFAULT_TRACERS is not set
CONFIG_BRANCH_PROFILE_NONE=y
# CONFIG_PROFILE_ANNOTATED_BRANCHES is not set
# CONFIG_PROFILE_ALL_BRANCHES is not set
# CONFIG_STACK_TRACER is not set
# CONFIG_BLK_DEV_IO_TRACE is not set
# CONFIG_RING_BUFFER_BENCHMARK is not set
# CONFIG_DYNAMIC_DEBUG is not set
# CONFIG_DMA_API_DEBUG is not set
# CONFIG_ATOMIC64_SELFTEST is not set
# CONFIG_SAMPLES is not set
CONFIG_HAVE_ARCH_KGDB=y
# CONFIG_KGDB is not set
# CONFIG_TEST_KSTRTOX is not set
# CONFIG_STRICT_DEVMEM is not set
CONFIG_ARM_UNWIND=y
# CONFIG_DEBUG_USER is not set
# CONFIG_DEBUG_ERRORS is not set
# CONFIG_DEBUG_STACK_USAGE is not set
# CONFIG_DEBUG_LL is not set
# CONFIG_OC_ETM is not set
# Security options
CONFIG_KEYS=y
# CONFIG_KEYS_DEBUG_PROC_KEYS is not set
# CONFIG_SECURITY_DMESG_RESTRICT is not set
# CONFIG_SECURITY is not set
CONFIG_SECURITYFS=y
CONFIG_DEFAULT_SECURITY_DAC=y
CONFIG_DEFAULT_SECURITY=""
CONFIG_CRYPTO=y
# Crypto core or helper
CONFIG_CRYPTO_ALGAPI=y
CONFIG_CRYPTO_ALGAPI2=y
CONFIG_CRYPTO_AEAD=y
CONFIG_CRYPTO_AEAD2=y
CONFIG_CRYPTO_BLKCIPHER=y
CONFIG_CRYPTO_BLKCIPHER2=y
CONFIG_CRYPTO_HASH=y
CONFIG_CRYPTO_HASH2=y
CONFIG_CRYPTO_RNG=y
CONFIG_CRYPTO_RNG2=y
CONFIG_CRYPTO_PCOMP2=y
CONFIG_CRYPTO_MANAGER=y
CONFIG_CRYPTO_MANAGER2=y
CONFIG_CRYPTO_MANAGER_DISABLE_TESTS=y
# CONFIG_CRYPTO_GF128MUL is not set
# CONFIG_CRYPTO_NULL is not set
CONFIG_CRYPTO_WORKQUEUE=y
# CONFIG_CRYPTO_CRYPTD is not set
CONFIG_CRYPTO_AUTHENC=y
# CONFIG_CRYPTO_TEST is not set
# Authenticated Encryption with Associated Data
# CONFIG_CRYPTO_CCM is not set
# CONFIG_CRYPTO_GCM is not set
# CONFIG_CRYPTO_SEQIV is not set
# Block modes
CONFIG_CRYPTO_CBC=y
# CONFIG_CRYPTO_CTR is not set
# CONFIG_CRYPTO_CTS is not set
CONFIG_CRYPTO_ECB=y
# CONFIG_CRYPTO_LRW is not set
# CONFIG_CRYPTO_PCBC is not set
# CONFIG_CRYPTO_XTS is not set
# Hash modes
CONFIG_CRYPTO_HMAC=y
# CONFIG_CRYPTO_XCBC is not set
# CONFIG_CRYPTO_VMAC is not set
# Digest
CONFIG_CRYPTO_CRC32C=y
# CONFIG_CRYPTO_GHASH is not set
# CONFIG_CRYPTO_MD4 is not set
CONFIG_CRYPTO_MD5=y
CONFIG_CRYPTO_MICHAEL_MIC=y
# CONFIG_CRYPTO_RMD128 is not set
# CONFIG_CRYPTO_RMD160 is not set
# CONFIG_CRYPTO_RMD256 is not set
# CONFIG_CRYPTO_RMD320 is not set
CONFIG_CRYPTO_SHA1=y
CONFIG_CRYPTO_SHA256=y
CONFIG_CRYPTO_SHA512=y
CONFIG_CRYPTO_TGR192=y
# CONFIG_CRYPTO_WP512 is not set
# Ciphers
CONFIG_CRYPTO_AES=y
# CONFIG_CRYPTO_ANUBIS is not set
CONFIG_CRYPTO_ARC4=y
# CONFIG_CRYPTO_BLOWFISH is not set
# CONFIG_CRYPTO_CAMELLIA is not set
# CONFIG_CRYPTO_CAST5 is not set
# CONFIG_CRYPTO_CAST6 is not set
CONFIG_CRYPTO_DES=y
# CONFIG_CRYPTO_FCRYPT is not set
# CONFIG_CRYPTO_KHAZAD is not set
# CONFIG_CRYPTO_SALSA20 is not set
# CONFIG_CRYPTO_SEED is not set
# CONFIG_CRYPTO_SERPENT is not set
# CONFIG_CRYPTO_TEA is not set
# CONFIG_CRYPTO_TWOFISH is not set
# Compression
CONFIG_CRYPTO_DEFLATE=y
# CONFIG_CRYPTO_ZLIB is not set
CONFIG_CRYPTO_LZO=y
# Random Number Generation
CONFIG_CRYPTO_ANSI_CPRNG=y
# CONFIG_CRYPTO_USER_API_HASH is not set
# CONFIG_CRYPTO_USER_API_SKCIPHER is not set
# CONFIG_CRYPTO_HW is not set
# CONFIG_BINARY_PRINTF is not set
# Library routines
CONFIG_BITREVERSE=y
CONFIG_GENERIC_FIND_LAST_BIT=y
CONFIG_CRC_CCITT=y
CONFIG_CRC16=y
CONFIG_CRC_T10DIF=y
CONFIG_CRC_ITU_T=y
CONFIG_CRC32=y
CONFIG_CRC7=y
CONFIG_LIBCRC32C=y
CONFIG_ZLIB_INFLATE=y
CONFIG_ZLIB_DEFLATE=y
CONFIG_LZO_COMPRESS=y
CONFIG_LZO_DECOMPRESS=y
CONFIG_XZ_DEC=y
CONFIG_XZ_DEC_X86=y
CONFIG_XZ_DEC_POWERPC=y
CONFIG_XZ_DEC_IA64=y
CONFIG_XZ_DEC_ARM=y
CONFIG_XZ_DEC_ARMTHUMB=y
CONFIG_XZ_DEC_SPARC=y
CONFIG_XZ_DEC_BCJ=y
# CONFIG_XZ_DEC_TEST is not set
CONFIG_DECOMPRESS_GZIP=y
CONFIG_DECOMPRESS_BZIP2=y
CONFIG_DECOMPRESS_LZMA=y
CONFIG_DECOMPRESS_XZ=y
CONFIG_DECOMPRESS_LZO=y
CONFIG_HAS_IOMEM=y
CONFIG_HAS_IOPORT=y
CONFIG_HAS_DMA=y
CONFIG_NLATTR=y
CONFIG_AVERAGE=y
 I got g_hid.ko module in /drivers/usb/gadget/ folder. I have problem with module enumeration. Modified HID files are in the attachemnt.
* hid.c -- HID Composite driver
* Based on multi.c
* Copyright (C) 2010 Fabien Chouteau <fabien.chouteau@barco.com>
* This program is free software; you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation; either version 2 of the License, or
* (at your option) any later version.
* This program is distributed in the hope that it will be useful,
* but WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
* GNU General Public License for more details.
* You should have received a copy of the GNU General Public License
* along with this program; if not, write to the Free Software
* Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307  USA
#include <linux/kernel.h>
#include <linux/platform_device.h>
#include <linux/list.h>
#define DRIVER_DESC             "HID Gadget"
#define DRIVER_VERSION          "2010/03/16"
#define HIDG_VENDOR_NUM         0x0525  /* XXX NetChip */
#define HIDG_PRODUCT_NUM        0xa4ac  /* Linux-USB HID gadget */
* kbuild is not very cooperative with respect to linking separately
* compiled library objects into one module.  So for now we won't use
* separate compilation ... ensuring init/exit sections work to shrink
* the runtime footprint, and giving us at least some parts of what
* a "gcc --combine ... part1.c part2.c part3.c ... " build would.
#include "composite.c"
#include "usbstring.c"
#include "config.c"
#include "epautoconf.c"
#include "g_zero.c"
struct hidg_func_node
	struct list_head node;
	struct hidg_func_descriptor *func;
static LIST_HEAD(hidg_func_list);
static struct usb_device_descriptor device_desc =
	.bLength =              sizeof device_desc,
	.bDescriptorType =      USB_DT_DEVICE,
	.bcdUSB =               0x0200,
	/* .bDeviceClass =              USB_CLASS_COMM, */
	/* .bDeviceSubClass =   0, */
	/* .bDeviceProtocol =   0, */
	.bDeviceClass =         0x00,
	.bMaxPacketSize0 = 	0x40,
	/* Vendor and product id can be overridden by module parameters.  */
	.idVendor =             cpu_to_le16(HIDG_VENDOR_NUM),
    .idProduct =            cpu_to_le16(HIDG_PRODUCT_NUM),
	.bcdDevice = 		0x6400,
	.iManufacturer = 	0x01,
	.iProduct =  		0x02,
	.iSerialNumber =        0x00,
	.bNumConfigurations =   0x01,
static struct platform_device my_hid =
	.name			= "hidg",
	.id			= 0,
	.num_resources		= 0,
	.resource		= 0,
	.dev.platform_data	= &my_hid_data,
/* string IDs are assigned dynamically */
#define STRING_MANUFACTURER_IDX         0
#define STRING_PRODUCT_IDX              1
static char manufacturer[50];
static struct usb_string strings_dev[] =
	[STRING_MANUFACTURER_IDX].s = manufacturer,
	[STRING_PRODUCT_IDX].s = DRIVER_DESC,
	{  } /* end of list */
static struct usb_gadget_strings stringtab_dev =
	.language       = 0x0409,       /* en-us */
	.strings        = strings_dev,
static struct usb_gadget_strings *dev_strings[] =
	&stringtab_dev,
	NULL,
/****************************** Configurations ******************************/
static int __init do_config(struct usb_configuration *c)
	struct hidg_func_node *e;
	int func = 0, status = 0;
	c->bmAttributes |= USB_CONFIG_ATT_SELFPOWER;
    list_for_each_entry(e, &hidg_func_list, node)
		status = hidg_bind_config(c, e->func, func++);
		if (status)
			break;
	 return status;
static struct usb_configuration config_driver =
	.bConfigurationValue   = 0x01,
	.label                  = "Keyboard",
	.bind                   = do_config,
	.bConfigurationValue    = 1,
	.iConfiguration 	 = 0x03,
	//.bmAttributes           = USB_CONFIG_ATT_WAKEUP,
/****************************** Gadget Bind ******************************/
static int __init hid_bind(struct usb_composite_dev *cdev)
	struct usb_gadget *gadget = cdev->gadget;
        struct list_head *tmp;
        int status, gcnum, funcs = 0;
        list_for_each(tmp, &hidg_func_list)
                 funcs++;
        if (!funcs)
		return -ENODEV;
         /* set up HID */
	status = ghid_setup(cdev->gadget, funcs);
        if (status < 0)
                return status;
        gcnum = usb_gadget_controller_number(gadget);
         /* Allocate string descriptor numbers ... note that string
          * contents can be overridden by the composite_dev glue.
        /* device descriptor strings: manufacturer, product */
        snprintf(manufacturer, sizeof manufacturer, "%s %s with %s", init_utsname()->sysname, init_utsname()->release, gadget->name);
        status = usb_string_id(cdev);
        if (status < 0)
                return status;
        strings_dev[STRING_MANUFACTURER_IDX].id = status;
        if (status < 0)
	        return status;
        strings_dev[STRING_PRODUCT_IDX].id = status;
        /* register our configuration */
        status = usb_add_config(cdev, &config_driver);
        if (status < 0)
                return status;
        dev_info(&gadget->dev, DRIVER_DESC ", version: " DRIVER_VERSION "\n");
        return 0;
static int __exit hid_unbind(struct usb_composite_dev *cdev)
         ghid_cleanup();
         return 0;
static int __init hidg_plat_driver_probe(struct platform_device *pdev)
	struct hidg_func_descriptor *func = pdev->dev.platform_data;
        struct hidg_func_node *entry;
        if(!func)
		dev_err(&pdev->dev, "Platform data missing\n");
                return -ENODEV;
        entry = kzalloc(sizeof(*entry), GFP_KERNEL);
        if (!entry)
        	return -ENOMEM;
        entry->func = func;
        list_add_tail(&entry->node, &hidg_func_list);
        return 0;
static int __devexit hidg_plat_driver_remove(struct platform_device *pdev)
	struct hidg_func_node *e, *n;
	list_for_each_entry_safe(e, n, &hidg_func_list, node)
		list_del(&e->node);
		kfree(e);
	return 0;
/****************************** Some noise ******************************/
static struct usb_composite_driver hidg_driver =
        .name           = "g_hid",
        .dev            = &device_desc,
        .strings        = dev_strings,
        .bind           = hid_bind,
        .unbind         = __exit_p(hid_unbind),
static struct platform_driver hidg_plat_driver =
        .remove         = __devexit_p(hidg_plat_driver_remove),
        .driver         = {
                .owner  = THIS_MODULE,
                .name   = "hidg",
MODULE_DESCRIPTION(DRIVER_DESC);
MODULE_AUTHOR("Fabien Chouteau, Peter Korsgaard");
MODULE_LICENSE("GPL");
static int __init hidg_init(void)
	int status;
	status = platform_device_register(&my_hid);
	if (status < 0)
		platform_device_unregister(&my_hid);
		return status;
        status = platform_driver_probe(&hidg_plat_driver, hidg_plat_driver_probe);
        if (status < 0)
			return status;
        status = usb_composite_register(&hidg_driver);
        if (status < 0)
			platform_driver_unregister(&hidg_plat_driver);
        return status;
module_init(hidg_init);
static void __exit hidg_cleanup(void)
	usb_composite_unregister(&hidg_driver);
module_exit(hidg_cleanup);
7801.g_hid.h
* f_hid.c -- USB HID function driver
#include <linux/utsname.h>
#include <linux/module.h>
#include <linux/hid.h>
#include <linux/cdev.h>
#include <linux/mutex.h>
#include <linux/poll.h>
#include <linux/smp_lock.h>
#include <linux/uaccess.h>
#include <linux/wait.h>
#include <linux/usb/g_hid.h>
#include <linux/delay.h>
static int major, minors;
static struct class *hidg_class;
/*                            HID gadget struct                            */
struct f_hidg
	/* configuration */
	unsigned char                   bInterfaceSubClass;
	unsigned char                   bInterfaceProtocol;
	unsigned short                  report_desc_length;
	char                            *report_desc;
	unsigned short                  report_length;
	/* recv report */
	char                            *set_report_buff;
	unsigned short                  set_report_length;
	spinlock_t                      spinlock;
	wait_queue_head_t               read_queue;
	/* send report */
	struct mutex                    lock;
	bool                            write_pending;
	wait_queue_head_t               write_queue;
	struct usb_request              *req;
	int                             minor;
	struct cdev                     cdev;
	struct usb_function             func;
	struct usb_ep                   *in_ep;
	struct usb_endpoint_descriptor  *fs_in_ep_desc;
	struct usb_endpoint_descriptor  *hs_in_ep_desc;
static inline struct f_hidg *func_to_hidg(struct usb_function *f)
	return container_of(f, struct f_hidg, func);
/*                           Static descriptors                            */
static struct usb_interface_descriptor hidg_interface_desc =
	.bLength                = sizeof hidg_interface_desc,
	.bDescriptorType        = USB_DT_INTERFACE,
	.bInterfaceNumber       = 0x00,
	.bAlternateSetting      = 0x00,
	.bNumEndpoints          = 0x01,
	.bInterfaceClass        = USB_CLASS_HID,	// Defines the device as a HID class device
	.bInterfaceSubClass     = 0x01,
	.bInterfaceProtocol     = 0x01,
	.iInterface             = 0x02,
static struct hid_descriptor hidg_desc =
	.bLength                        = sizeof hidg_desc,
	.bDescriptorType                = HID_DT_HID,
	.bcdHID                         = 0x0200,
	.bCountryCode                   = 0x00,
	.bNumDescriptors                = 0x01,
	.desc[0].bDescriptorType        = 0x22,
	.desc[0].wDescriptorLength      = 0x0018,
static struct hidg_func_descriptor my_hid_data =
	.subclass		= 0,
	.protocol		= 1,
	.report_length	 	= 0x40,
	.report_desc_length 	= 0x18,
	.report_desc =
		0x05, 0x01,		/* USAGE_PAGE (Generic Desktop)	          */
		0x09, 0x06,		/* USAGE (Keyboard)                       */
		0xa1, 0x01,		/* COLLECTION (Application)               */
		0x05, 0x07,		/* 	USAGE_PAGE (Keyboard)                */
		0x19, 0x01,		/*      USAGE_MINIMUM (Keyboard LeftControl) */ // Promena -> Button1
		0x29, 0x01,		/*   	USAGE_MAXIMUM (Keyboard Right GUI)   */ // Promena -> Button1
		0x15, 0x00,		/*   	LOGICAL_MINIMUM (0)                  */
		0x25, 0x01,		/*   	LOGICAL_MAXIMUM (1)                  */
		0x76, 0x00, 0x02,	/*   	REPORT_SIZE (512)                    */
		0x95, 0x08,		/*      REPORT_COUNT (1)                     */
		0x81, 0x02,		/*   	INPUT (Data,Var,Abs)                 */
		0xc0			/* END_COLLECTION                         */
/* High-Speed Support */
static struct usb_endpoint_descriptor hidg_hs_in_ep_desc1 =	// Input endpoint
    .bLength                = USB_DT_ENDPOINT_SIZE,
    .bDescriptorType        = USB_DT_ENDPOINT,
	.bEndpointAddress       = USB_DIR_IN,
    .bmAttributes           = USB_ENDPOINT_XFER_INT,
    .wMaxPacketSize         = 0x0040,
    .bInterval              = 0x04, /* FIXME: Add this field in the
                                     * HID gadget configuration?
                                     * (struct hidg_func_descriptor)
static struct usb_descriptor_header *hidg_hs_descriptors[] =
	(struct usb_descriptor_header *) &hidg_interface_desc,
	(struct usb_descriptor_header *) &hidg_desc,
	(struct usb_descriptor_header *) &hidg_hs_in_ep_desc1,
	NULL,
/* Full-Speed Support */
static struct usb_endpoint_descriptor hidg_fs_in_ep_desc1 =
	.bInterval              = 0x0A, /* FIXME: Add this field in the
static struct usb_descriptor_header *hidg_fs_descriptors[] =
	(struct usb_descriptor_header *)&hidg_interface_desc,
	(struct usb_descriptor_header *)&hidg_desc,
	(struct usb_descriptor_header *)&hidg_fs_in_ep_desc1,
	NULL,
/*                              Char Device                                */
static ssize_t f_hidg_read(struct file *file, char __user *buffer, size_t count, loff_t *ptr)	// 'count' is the size of the requested data transfer;
{												// 'buffer' points to the empty buffer where the newly read data should be placed;
	struct f_hidg   *hidg     = (struct f_hidg *)file->private_data;			// 'ptr' is a pointer to a "long offset type" object that indicates the file position the user is accessing;
	char            *tmp_buff = NULL;
	unsigned long   flags;
	printk("\nread() method \t %s, line: %i\n", __FILE__, __LINE__);
	if (!count)		// No data to be transfered
		return 0;
	if (!access_ok(VERIFY_WRITE, buffer, count))		// Checks if a user space pointer is not valid; 'count' is size of block to check
		return -EFAULT;					// 'VERIFY_WRITE' is a superset of 'VERIFY_READ' - if it is safe to write to a block, it is always safe to read from it
	spin_lock_irqsave(&hidg->spinlock, flags);		// 'spin_lock_irqsave()' will disable interrupts locally and provide the spinlock on SMP (Symmetric Multi Processing); 'spinlock' is something similar to 'mutex'
	#define READ_COND (hidg->set_report_buff != NULL)
	while(!READ_COND)
		spin_unlock_irqrestore(&hidg->spinlock, flags);		// `spin_unlock_irqrestore()' function are used to unlock spinlocks locked with `spin_lock_irqsave()'
		if(file->f_flags & O_NONBLOCK)	// Logical 'and' operation between 'unsigned int f_flags' and '0_NONBLOCK'; The 'O_NONBLOCK' flag means that all input/output operations with this data stream should be nonblocking
			return -EAGAIN;	// Try again
		if(wait_event_interruptible(hidg->read_queue, READ_COND))
			return -ERESTARTSYS;	// -ERESTARTSYS is connected to the concept of a restartable system call.
		}				// A restartable system call is one that can be transparently re-executed by the kernel when there is some interruption.
	count = min_t(unsigned, count, hidg->set_report_length);
	printk("\nread() method count = %i \t %s, line: %i\n", count, __FILE__, __LINE__);
	tmp_buff = hidg->set_report_buff;
	hidg->set_report_buff = NULL;
	if(tmp_buff != NULL)
		/* copy to user outside spinlock */
		count -= copy_to_user(buffer, tmp_buff, count);	// copy_to_user() method copies data from the buffer in the kernel (tmp_buff) to the buffer allocated by the user (buffer)
		kfree(tmp_buff);
	else
		count = -ENOMEM;
	printk("\nread() method count = %i before return.\t %s, line: %i\n", count, __FILE__, __LINE__);
	return count;	// A return value greater than or equal to 0 (count <= 0) tells the calling program how many bytes have been successfully transferred
static void f_hidg_req_complete(struct usb_ep *ep, struct usb_request *req)
	struct f_hidg *hidg;
        hidg = (struct f_hidg *)ep->driver_data;
        if (req->status != 0)
                ERROR(hidg->func.config->cdev, "End Point Request ERROR: %d\n", req->status);
        hidg->write_pending = 0;
        wake_up(&hidg->write_queue);
static ssize_t f_hidg_write(struct file *file, const char __user *buffer, size_t count, loff_t *offp)	// 'count' is the size of the requested data transfer;
{													// 'buffer' points to the user buffer holding the data to be written;
	struct f_hidg *hidg  = (struct f_hidg *)file->private_data;					// 'offp' is a pointer to a "long offset type" object that indicates the file position the user is accessing;
	ssize_t status = -ENOMEM;
        if (!access_ok(VERIFY_READ, buffer, count))
                return -EFAULT;
        mutex_lock(&hidg->lock);
	#define WRITE_COND (!hidg->write_pending)
	/* write queue */
	while (!WRITE_COND)
		mutex_unlock(&hidg->lock);
		if (file->f_flags & O_NONBLOCK)
			return -EAGAIN;
		if (wait_event_interruptible_exclusive(hidg->write_queue, WRITE_COND))
	count  = min_t(unsigned, count, hidg->report_length);
	status = copy_from_user(hidg->req->buf, buffer, count);
	if (status != 0)
		ERROR(hidg->func.config->cdev, "copy_from_user error\n");
		return -EINVAL;
	hidg->req->status = 0;
	hidg->req->zero = 0;
	hidg->req->length = count;
	hidg->req->complete = f_hidg_req_complete;
	hidg->req->context = hidg;
	hidg->write_pending = 1;
	if(hidg->in_ep != NULL)
         	status = usb_ep_queue(hidg->in_ep, hidg->req, GFP_ATOMIC);
	if (status < 0)
		ERROR(hidg->func.config->cdev, "usb_ep_queue error on int endpoint %zd\n", status);
	else
		status = count;
	return status;
static unsigned int f_hidg_poll(struct file *file, poll_table *wait)
	unsigned int    ret = 0;
	poll_wait(file, &hidg->read_queue, wait);
	poll_wait(file, &hidg->write_queue, wait);
	if (WRITE_COND)
		ret |= POLLOUT | POLLWRNORM;
	if (READ_COND)
		ret |= POLLIN | POLLRDNORM;
	return ret;
#undef WRITE_COND
#undef READ_COND
static int f_hidg_release(struct inode *inode, struct file *fd)
	fd->private_data = NULL;
	return 0;
static int f_hidg_open(struct inode *inode, struct file *fd)
	struct f_hidg *hidg = container_of(inode->i_cdev, struct f_hidg, cdev);
	fd->private_data = hidg;
	return 0;
/*                                usb_function                             */
static void hidg_set_report_complete(struct usb_ep *ep, struct usb_request *req)
	struct f_hidg *hidg = (struct f_hidg *)req->context;
	if (req->status != 0 || req->buf == NULL || req->actual == 0)
		ERROR(hidg->func.config->cdev, "%s FAILED\n", __func__);
		return;
	spin_lock(&hidg->spinlock);
	hidg->set_report_buff = krealloc(hidg->set_report_buff, req->actual, GFP_ATOMIC);
	if (hidg->set_report_buff == NULL)
		spin_unlock(&hidg->spinlock);
		return;
	hidg->set_report_length = req->actual;
	memcpy(hidg->set_report_buff, req->buf, req->actual);
	//printk("\nreq->buf = %s \t %s, line: %i\n", (char *)req->buf, __FILE__, __LINE__);
	wake_up(&hidg->read_queue);
	return;
static int hidg_setup(struct usb_function *f, const struct usb_ctrlrequest *ctrl)
	struct f_hidg                   *hidg = func_to_hidg(f);
	struct usb_composite_dev        *cdev = f->config->cdev;
	struct usb_request              *req  = cdev->req;
	int status = 0;
	__u16 value, length;
	value   = __le16_to_cpu(ctrl->wValue);
	length  = __le16_to_cpu(ctrl->wLength);
	VDBG(cdev, "hid_setup crtl_request : bRequestType:0x%x bRequest:0x%x "
		   "Value:0x%x\n", ctrl->bRequestType, ctrl->bRequest, value);
	switch ((ctrl->bRequestType << 8) | ctrl->bRequest)
		case ((USB_DIR_IN | USB_TYPE_CLASS | USB_RECIP_INTERFACE) << 8 | HID_REQ_GET_REPORT):
			VDBG(cdev, "get_report\n");
			/* send an empty report */
			length = min_t(unsigned, length, hidg->report_length);
			memset(req->buf, 0x0, length);
			goto respond;
			break;
		case ((USB_DIR_IN | USB_TYPE_CLASS | USB_RECIP_INTERFACE) << 8 | HID_REQ_GET_PROTOCOL):
			VDBG(cdev, "get_protocol\n");
			goto stall;
			break;
		case ((USB_DIR_OUT | USB_TYPE_CLASS | USB_RECIP_INTERFACE) << 8 | HID_REQ_SET_REPORT):	// 0x2109
			VDBG(cdev, "set_report | wLenght=%d\n", ctrl->wLength);
			req->complete = hidg_set_report_complete;
			goto respond;
			break;
		case ((USB_DIR_OUT | USB_TYPE_CLASS | USB_RECIP_INTERFACE) << 8 | USB_REQ_SET_INTERFACE):
			VDBG(cdev, "set_protocol\n");
			goto stall;
			break;
		case (0x2110):
			VDBG(cdev, "set_custom_report\n");
			goto respond;
			break;
		case ((USB_DIR_IN | USB_TYPE_STANDARD | USB_RECIP_INTERFACE) << 8 | USB_REQ_GET_DESCRIPTOR):	// 0x8106
			switch (value >> 8)
				case HID_DT_REPORT:	// 0x22
					VDBG(cdev, "USB_REQ_GET_DESCRIPTOR: REPORT\n");
					length = min_t(unsigned short, length, hidg->report_desc_length);
					memcpy(req->buf, hidg->report_desc, length);
					goto respond;
					break;
				default:
					VDBG(cdev, "Unknown decriptor request 0x%x\n", value >> 8);
					goto stall;
					break;
			break;
		default:
			VDBG(cdev, "Unknown request 0x%x\n", ctrl->bRequest);
			goto stall;
			break;
stall:
	return -EOPNOTSUPP;
respond:
	req->zero = 0;
	req->length = length;
	status = usb_ep_queue(cdev->gadget->ep0, req, GFP_ATOMIC);
	if (status < 0)
		ERROR(cdev, "usb_ep_queue error on ep0 %d\n", value);
	printk("\nreq->buf (setup) = %s \t %s, line: %i\n", (char *)req->buf, __FILE__, __LINE__);
	return status;
static void hidg_disable(struct usb_function *f)
	usb_ep_disable(hidg->in_ep);
	hidg->in_ep->driver_data = NULL;
	return;
static int hidg_set_alt(struct usb_function *f, unsigned intf, unsigned alt)
	const struct usb_endpoint_descriptor    *ep_desc;
	int status = 0;
	VDBG(cdev, "hidg_set_alt intf:%d alt:%d\n", intf, alt);
	if (hidg->in_ep != NULL)
		/* restart endpoint */
		if (hidg->in_ep->driver_data != NULL)
		ep_desc = ep_choose(f->config->cdev->gadget, hidg->hs_in_ep_desc, hidg->fs_in_ep_desc);
		status = usb_ep_enable(hidg->in_ep, ep_desc);
		if (status < 0)
			ERROR(cdev, "Enable endpoint FAILED!\n");
			goto fail;
		hidg->in_ep->driver_data = hidg;
fail:
	return status;
const struct file_operations f_hidg_fops =
	.open           = f_hidg_open,
	.release        = f_hidg_release,
	.write          = f_hidg_write,
	.read           = f_hidg_read,
	.poll           = f_hidg_poll,
static int __init hidg_bind(struct usb_configuration *c, struct usb_function *f)
	struct usb_ep           *ep;
	int                     status;
	dev_t                   dev;
	/* allocate instance-specific interface IDs, and patch descriptors */
	status = usb_interface_id(c, f);
	if (status < 0)
		goto fail;
	hidg_interface_desc.bInterfaceNumber = status;
	/* allocate instance-specific endpoints */
	status = -ENODEV;
	ep = usb_ep_autoconfig(c->cdev->gadget, &hidg_hs_in_ep_desc1);
	if (!ep)
	goto fail;
	ep->driver_data = c->cdev;      /* claim */
	hidg->in_ep = ep;
	/* preallocate request and buffer */
	status = -ENOMEM;
	hidg->req = usb_ep_alloc_request(hidg->in_ep, GFP_KERNEL);
	if (!hidg->req)
		goto fail;
	hidg->req->buf = kmalloc(hidg->report_length, GFP_KERNEL);
	if (!hidg->req->buf)
		goto fail;
	/* copy descriptors */
	f->descriptors = usb_copy_descriptors(hidg_fs_descriptors);
	if (!f->descriptors)
		goto fail;
	hidg->hs_in_ep_desc = usb_find_endpoint(hidg_fs_descriptors, f->descriptors, &hidg_hs_in_ep_desc1);
	if (gadget_is_dualspeed(c->cdev->gadget))
		hidg_hs_in_ep_desc1.bEndpointAddress = hidg_fs_in_ep_desc1.bEndpointAddress;
		f->hs_descriptors = usb_copy_descriptors(hidg_hs_descriptors);
		if (!f->hs_descriptors)
			goto fail;
		hidg->hs_in_ep_desc = usb_find_endpoint(hidg_hs_descriptors, f->hs_descriptors, &hidg_hs_in_ep_desc1);
	else
		hidg->hs_in_ep_desc = NULL;
	mutex_init(&hidg->lock);
	spin_lock_init(&hidg->spinlock);
	init_waitqueue_head(&hidg->write_queue);
	init_waitqueue_head(&hidg->read_queue);
	/* create char device */
	cdev_init(&hidg->cdev, &f_hidg_fops);
	dev = MKDEV(major, hidg->minor);
	status = cdev_add(&hidg->cdev, dev, 1);
	if (status)
		goto fail;
	device_create(hidg_class, NULL, dev, NULL, "%s%d", "hidg", hidg->minor);
	return 0;
fail:
	ERROR(f->config->cdev, "hidg_bind FAILED\n");
	if (hidg->req != NULL)
		kfree(hidg->req->buf);
			usb_ep_free_request(hidg->in_ep, hidg->req);
	usb_free_descriptors(f->hs_descriptors);
	usb_free_descriptors(f->descriptors);
	return status;
static void hidg_unbind(struct usb_configuration *c, struct usb_function *f)
	device_destroy(hidg_class, MKDEV(major, hidg->minor));
	cdev_del(&hidg->cdev);
	/* disable/free request and end point */
	usb_ep_dequeue(hidg->in_ep, hidg->req);
	/* free descriptors copies */
	kfree(hidg->report_desc);
	kfree(hidg->set_report_buff);
	kfree(hidg);
/*                                 Strings                                 */
#define CT_FUNC_HID_IDX 0
static struct usb_string ct_func_string_defs[] =
	[CT_FUNC_HID_IDX].s     = "HID Interface",
	{},                     /* end of list */
static struct usb_gadget_strings ct_func_string_table =
	.language       = 0x0409,       /* en-US */
	.strings        = ct_func_string_defs,
static struct usb_gadget_strings *ct_func_strings[] =
	&ct_func_string_table,
	NULL,
/*                             usb_configuration                           */
int __init hidg_bind_config(struct usb_configuration *c, struct hidg_func_descriptor *fdesc, int index)
	int status;
	if(index >= minors)
		return -ENOENT;		// No such file or directory
	/* maybe allocate device-global string IDs, and patch descriptors */
	if(ct_func_string_defs[CT_FUNC_HID_IDX].id == 0)
		status = usb_string_id(c->cdev);
		if (status < 0)
			return status;
		ct_func_string_defs[CT_FUNC_HID_IDX].id = status;
		hidg_interface_desc.iInterface = status;
	/* allocate and initialize one new instance */
	hidg = kzalloc(sizeof *hidg, GFP_KERNEL);
	if(!hidg)
		return -ENOMEM;
	hidg->minor = index;
	hidg->bInterfaceSubClass = fdesc->subclass;
	hidg->bInterfaceProtocol = fdesc->protocol;
	hidg->report_length = fdesc->report_length;
	hidg->report_desc_length = fdesc->report_desc_length;
	hidg->report_desc = kmemdup(fdesc->report_desc, fdesc->report_desc_length, GFP_KERNEL);	// A SEGMENTATION FAULT is generally an attempt to access memory that the CPU cannot physically address
												// 'GFP_KERNEL' is a normal allocation and might block. This is the flag to use in process context code when it is safe to sleep
	if (!hidg->report_desc)
		kfree(hidg);
		return -ENOMEM;
	hidg->func.name    = "hid";
	hidg->func.strings = ct_func_strings;
	hidg->func.bind    = hidg_bind;
	hidg->func.unbind  = hidg_unbind;
	hidg->func.set_alt = hidg_set_alt;
	hidg->func.disable = hidg_disable;
	hidg->func.setup   = hidg_setup;
	status = usb_add_function(c, &hidg->func);
	if (status)
		kfree(hidg);
	return status;
int __init ghid_setup(struct usb_gadget *g, int count)
	int status;
	dev_t dev;
	hidg_class = class_create(THIS_MODULE, "hidg");
	status = alloc_chrdev_region(&dev, 0, count, "hidg");
	if (!status)
		major = MAJOR(dev);
		minors = count;
	return status;
void ghid_cleanup(void)
	if (major)
		unregister_chrdev_region(MKDEV(major, 0), minors);
		major = minors = 0;
	class_destroy(hidg_class);
	hidg_class = NULL;
