Hello Sir/Mam, i got a problem to solve.....Please let me know..........i am new to this concept
usb 3g modem am using is Huawei e173......
i placed my file in the following directory:
system ->xbin->usb_modeswitch-1.1.9-arm-static.bz2(exe-file)
system->xbin->usb_modeswitch.conf
system->xbin->chat(exe-file)
system->etc->ppp->airtel.chat(script file)
when i used to run the commands it shows me like this:
1. mount -t usbfs usbfs /proc/bus/usb
2. /system/xbin/usb_modeswitch -I -W -c /system/xbin/usb_modeswitch.conf
Reading config file: /system/xbin/usb_modeswitch.conf
* usb_modeswitch: handle USB devices with multiple modes
* Version 1.1.9 (C) Josua Dietze 2011
* Based on libusb0 (0.1.12 and above)
! PLEASE REPORT NEW CONFIGURATIONS !
DefaultVendor= 0x12d1
DefaultProduct= 0x1446
TargetVendor= 0x12d1
TargetProduct= 0x1436
TargetClass= not set
TargetProductList=""
DetachStorageOnly=0
HuaweiMode=0
SierraMode=0
SonyMode=0
GCTMode=0
KobilMode=0
SequansMode=0
MobileActionMode=0
CiscoMode=0
MessageEndpoint=0x01
MessageContent="55534243123456780000000000000011062000000100000000000000000000"
NeedResponse=0
ResponseEndpoint= not set
Interface=0x00
InquireDevice disabled
Success check enabled, max. wait time 20 seconds
System integration mode disabled
usb_set_debug: Setting debugging level to 15 (on)
usb_os_find_busses: Found 001
usb_os_find_busses: Found 002
usb_os_find_devices: Found 005 on 001
usb_os_find_devices: Found 004 on 001
usb_os_find_devices: Found 003 on 001
skipped 1 class/vendor specific interface descriptors
usb_os_find_devices: Found 002 on 001
usb_os_find_devices: Found 001 on 001
error obtaining child information: Inappropriate ioctl for device
usb_os_find_devices: Found 001 on 002
Looking for target devices ...
searching devices, found USB ID 12d1:1446
found matching vendor ID
searching devices, found USB ID 1a40:0101
searching devices, found USB ID 15d9:0a37
searching devices, found USB ID 1d6b:0002
No devices in target mode or class found
Looking for default devices ...
found matching product ID
adding device
Found devices in default mode, class or configuration (1)
Accessing device 005 on bus 001 ...
Getting the current device configuration ...
OK, got current device configuration (1)
Using endpoints 0x01 (out) and 0x81 (in)
USB description data (for identification)
Manufacturer: HUAWEI Technology
Product: HUAWEI Mobile
Serial No.: not provided
Looking for active driver ...
OK, driver found ("usb-storage")
OK, driver "usb-storage" detached
Setting up communication with interface 0
Using endpoint 0x01 for message sending ...
Trying to send message 1 to endpoint 0x01 ...
OK, message successfully sent
Resetting response endpoint 0x81
USB error: could not clear/halt ep 129: Protocol error
Could not reset endpoint (probably harmless): -71
Resetting message endpoint 0x01
USB error: could not clear/halt ep 1: Protocol error
Checking for mode switch (m[ 917.817687] usb 1-1.4.2: USB disconnect, device n5
ax. 20 times, once per second) ...
Searching for target devices ...
[ 921.890716] usb 1-1.4.2: new high-speed USB device number 6 using musb-hdrc
[ 921.992523] usb 1-1.4.2: New USB device found, idVendor=12d1, idProduct=1436
[ 921.999877] usb 1-1.4.2: New USB device strings: Mfr=4, Product=3, SerialNum0
[ 922.007720] usb 1-1.4.2: Product: HUAWEI Mobile
[ 922.012451] usb 1-1.4.2: Manufacturer: HUAWEI Technology
[ 922.023010] option 1-1.4.2:1.0: GSM modem (1-port) converter detected
[ 922.030273] usb 1-1.4.2: GSM modem (1-port) converter now attached to ttyUSB0
[ 922.043518] cdc_ether 1-1.4.2:1.1: wwan0: register 'cdc_ether' at usb-musb-h0
[ 922.061798] option 1-1.4.2:1.3: GSM modem (1-port) converter detected
[ 922.068969] usb 1-1.4.2: GSM modem (1-port) converter now attached to ttyUSB1
[ 922.077911] option 1-1.4.2:1.4: GSM modem (1-port) converter detected
[ 922.085083] usb 1-1.4.2: GSM modem (1-port) converter now attached to ttyUSB2
[ 922.100006] scsi5 : usb-storage 1-1.4.2:1.5
[ 922.106597] scsi6 : usb-storage 1-1.4.2:1.6
[ 923.102233] scsi 5:0:0:0: CD-ROM HUAWEI Mass Storage 2.31 P2
[ 923.112335] scsi 5:0:0:0: Attached scsi generic sg0 type 5
[ 923.132232] scsi 6:0:0:0: Direct-Access HUAWEI SD Storage 2.31 P2
usb_os_find_busses: Found 001[ 923.146087] sd 6:0:0:0: Attached scsi generic s0
usb_os_find_devices: Found 006 on 001
skipping descriptor 0xB
skipped 1 class/vendor specific endpoint descri[ 923.164215] sd 6:0:0:0: [sda]k
ptors
skipped 3 class/vendor specific interface descriptors
searching devices, found USB ID 12d1:1436
adding device
Found target device, now opening
Found target device 006 on bus 001
Target device description data
Found correct target device
Mode switch succeeded. Bye.
3. /system/bin/pppd /dev/ttyUSB0 115200 persist defaultroute usepeerdns updetach crtscts noauth debug connect "/system/xbin/chat -v -s -f /system/etc/ppp/airtel.chat"
timeout set to 10 seconds
abort on (BUSY)
abort on (NOANSWER)
abort on (ERROR)
StartingGPRSconnectscript
send (ATZ^M)
SettingAPN
expect (OK)
^M
^BOOT:1141512,0,0,0,20^M
^M
OK
-- got it
send (AT+CGDCONT=1,"IP","airtelgprs.com"^M)
abort on (NOCARRIER)
Dialing...
expect (OK)
^M
AT+CGDCONT=1,"IP","airtelgprs.com"^M^M
OK
-- got it
send (ATD*99***1#^M)
expect (CONNECT)
^M
ATD*99***1#^M^M
CONNECT
-- got it
abort on (BUSY)
abort on (NOANSWER)
abort on (ERROR)
send (ATZ^M)
SettingAPN
expect (OK)
ATZ^M^M
OK
-- got it
Dialing... +-----------------------------+
expect (OK) | |
^M | Cannot open /dev/ttyUSB2! |
AT+CGDCONT=1,"IP","airtel| |
OK +-----------------------------+
-- got it
expect (CONNECT)
^M
ATD*99***1#^M^M
NO CARRIER^M
^M
alarm
Failed
4.Finally,what is primary and secondary dns server IPs?
