I am trying to do an EDMA transfer between 2 arrays. All the data resides in DDR3 memory. When the arrays are of type "int", the transfer is working fine and i am not getting any errors. But, when the arrays are made to type "float", after transfer, i am getting some errors. Is there any special care that has to be taken when transferring floating point data??. Please find attached the codes for EDMA transfer with both "int" and "float" arrays. Kindly let me know my mistake.
The file EDMA_test_int.c contains EDMA transfer for integer data in which verify transfer function is not giving any errors.
The file EDMA_test_float.c contains EDMA transfer for floating point data in which verify transfer function is giving errors.
Thanks & Regards
Varun V
* @file edma_test.c
* @brief
* This is the Example test code for the EDMA CSL Functional layer.
* \par
* NOTE:
* (C) Copyright 2009 Texas Instruments, Inc.
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the
* distribution.
* Neither the name of Texas Instruments Incorporated nor the names of
* its contributors may be used to endorse or promote products derived
* from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
* "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
* LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
* A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
* OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
* SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
* DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
* THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
* OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
#include <stdio.h>
#include <ti/csl/csl_edma3.h>
#include <ti/csl/csl_edma3Aux.h>
#include <ti/csl/csl_cacheAux.h>
************************** Global Variables **************************
/* Global Variables which are used to dump the TPCC register overlay in the
* debugger... */
CSL_TpccRegs* gEDMACC2Regs = (CSL_TpccRegs*)CSL_EDMA2CC_REGS;
/* Global Buffers (Source and Destination) for PING-PONG */
int srcBuff1[512];
int dstBuff1[512];
CSL_Edma3Handle hModule;
CSL_Edma3Obj edmaObj;
CSL_Edma3ParamHandle hParamPing;
CSL_Edma3ChannelObj chObj;
CSL_Edma3CmdIntr regionIntr;
CSL_Edma3ChannelHandle hChannel;
CSL_Edma3ParamSetup myParamSetup;
CSL_Edma3Context context;
CSL_Edma3ChannelAttr chAttr;
CSL_Status status;
Uint32 loopIndex;
************************ EDMA TEST FUNCTIONS *************************
* @b Description
* @n
* This is utility function used by the EDMA example to verify the
* Data transfer.
* @retval
* Success - TRUE
* @retval
* Error - FALSE
static Bool Verify_Transfer
Uint16 aCnt,
Uint16 bCnt,
Uint16 cCnt,
Uint16 srcBIdx,
Uint16 dstBIdx,
Uint16 srcCIdx,
Uint16 dstCIdx,
int *srcBuff,
int *dstBuff,
Bool abSync
Uint32 loopIndex1;
Uint32 loopIndex2;
Uint32 loopIndex3;
int* srcArrayPtr = (int*)srcBuff;
int* dstArrayPtr = (int*)dstBuff;
int* srcFramePtr = (int*)srcBuff;
int* dstFramePtr = (int*)dstBuff;
Uint16 key;
/* Invalidate the cache before verification */
/* Disable Interrupts */
key = _disable_interrupts();
CACHE_invL1d ((void *)srcBuff, 512*sizeof(int), CACHE_WAIT);
CACHE_invL2 ((void *)srcBuff, 512*sizeof(int), CACHE_WAIT);
CACHE_invL1d ((void *)dstBuff, 512*sizeof(int), CACHE_WAIT);
CACHE_invL2 ((void *)dstBuff, 512*sizeof(int), CACHE_WAIT);
_mfence();
/* Re-enable Interrupts. */
_restore_interrupts(key);
for (loopIndex1 = 0; loopIndex1 < cCnt; loopIndex1++) {
for (loopIndex2 = 0; loopIndex2 < bCnt; loopIndex2++) {
for (loopIndex3 = 0; loopIndex3 < aCnt; loopIndex3++)
if (srcArrayPtr[loopIndex3] != dstArrayPtr[loopIndex3])
printf("Not Working at %d\n",loopIndex3);
return FALSE;
srcArrayPtr = srcArrayPtr + srcBIdx;
dstArrayPtr = dstArrayPtr + dstBIdx;
if (abSync) {
srcFramePtr = srcFramePtr + srcCIdx;
srcArrayPtr = srcFramePtr;
dstFramePtr = dstFramePtr + dstCIdx;
dstArrayPtr = dstFramePtr;
else {
srcFramePtr = srcArrayPtr + srcCIdx - srcBIdx;
dstFramePtr = dstArrayPtr + dstCIdx - dstBIdx;
return TRUE;
* @b Description
* @n
* This is the example routine which perform EDMA ping pong buffer transfer
* where channel is open in the global region.
* It implements following steps
* - Intializes and Opens the EDMA Module .
* - Sets up the interrupt for the EDMA global region.
* - Sets up the EDMA module using the API csl_edma3Hwsetup ()
* - Enables the EDMA global region
* - Opens the channel 'channelNum' get the param handle for PARAM 1, 2
* - PING is mapped to PARAM Entry 1
* - PONG is mapped to PARAM Entry 2
* - PING is Linked with PONG...
* - Enables the EDMA interrupt using CSL_EDMA3_CMD_INTR_ENABLE.
* - Enables Interrupt (Bit 0-2) for the global region interrupts
* - Manually triggers the DMA channel 'channelNum'(This should be PING)
* - Polls on IPR bit 0 (Since TCC for PING is 0)
* - Clear the pending bit
* - Manually triggers the channel 'channelNum' (This should be PONG)
* - Polls on IPR bit 1 (Since TCC for PONG is 1)
* - Clears the pending bit
* - Compares the data in the destination buffer is proper or not.
* - Closes the EDMA module and channel.
* @param[in] instNum
* EDMA Instance Number on which the test is executed.
* @param[in] channelNum
* EDMA Channel Number on which the test is executed
* @retval
* Success - 0
* @retval
* Failure - <0
static Int32 edma_ping_pong_xfer_gbl_region_init (Int32 instNum, Uint8 channelNum)
/* Start the EDMA PING-PONG test over the Global Region. */
printf ("Debug: Testing EDMA(%d) Ping-Pong Test (Global) Region for Channel %d...\n", instNum, channelNum);
/* Initialize data */
for (loopIndex = 0; loopIndex < 512; loopIndex++)
srcBuff1[loopIndex] =(int) loopIndex;
dstBuff1[loopIndex] = 0;
/* Module initialization */
if (CSL_edma3Init(&context) != CSL_SOK)
printf ("Error: EDMA module initialization failed\n");
return -1;
/* Open the EDMA Module using the provided instance number */
hModule = CSL_edma3Open(&edmaObj, instNum, NULL, &status);
if ( (hModule == NULL) || (status != CSL_SOK))
printf ("Error: EDMA module open failed\n");
return -1;
/* Channel open */
chAttr.regionNum = CSL_EDMA3_REGION_GLOBAL;
chAttr.chaNum = channelNum;
hChannel = CSL_edma3ChannelOpen(&chObj, instNum, &chAttr, &status);
if ((hChannel == NULL) || (status != CSL_SOK))
printf ("Error: Unable to open EDMA Channel:%d\n", channelNum);
return -1;
if(!instNum)
/* For first EDMA instance there are only 2 TCs and 2 event queues
* Modify the channel default queue setup from 0 to 1
if (CSL_edma3HwChannelSetupQue(hChannel,CSL_EDMA3_QUE_1) != CSL_SOK)
printf ("Error: EDMA channel setup queue failed\n");
return -1;
else
/* For EDMA instance 1 and 2 maximum of 4 TCs and 4 event queues are supported
* Change Channel Default queue setup from 0 to 3
if (CSL_edma3HwChannelSetupQue(hChannel,CSL_EDMA3_QUE_3) != CSL_SOK)
return -1;
hParamPing = CSL_edma3GetParamHandle(hChannel, 2, &status);
if (hParamPing == NULL)
printf ("Error: EDMA Get Parameter Entry failed for 2.\n");
return -1;
/* Setup the parameter entry parameters (Ping buffer) */
myParamSetup.option = CSL_EDMA3_OPT_MAKE(CSL_EDMA3_ITCCH_DIS, \
CSL_EDMA3_TCCH_DIS, \
CSL_EDMA3_ITCINT_DIS, \
CSL_EDMA3_TCINT_EN, \
0, CSL_EDMA3_TCC_NORMAL,\
CSL_EDMA3_FIFOWIDTH_NONE, \
CSL_EDMA3_STATIC_DIS, \
CSL_EDMA3_SYNC_A, \
CSL_EDMA3_ADDRMODE_INCR, \
CSL_EDMA3_ADDRMODE_INCR );
myParamSetup.srcAddr = (Uint32)srcBuff1;
myParamSetup.aCntbCnt = CSL_EDMA3_CNT_MAKE(512*sizeof(int),1);
myParamSetup.dstAddr = (Uint32)dstBuff1;
myParamSetup.srcDstBidx = CSL_EDMA3_BIDX_MAKE(1,1);
myParamSetup.linkBcntrld= CSL_EDMA3_LINKBCNTRLD_MAKE(CSL_EDMA3_LINK_NULL,0);
myParamSetup.srcDstCidx = CSL_EDMA3_CIDX_MAKE(0,1);
myParamSetup.cCnt = 1;
/* Interrupt enable (Bits 0-1) for the global region interrupts */
regionIntr.region = CSL_EDMA3_REGION_GLOBAL;
regionIntr.intr = 0x3;
regionIntr.intrh = 0x0000;
CSL_edma3HwControl(hModule,CSL_EDMA3_CMD_INTR_ENABLE,®ionIntr);
regionIntr.intr = 0;
regionIntr.intrh = 0;
/* Map the DMA Channel to PARAM Block 2. */
CSL_edma3MapDMAChannelToParamBlock (hModule, channelNum, 2);
return 0;
static Int32 edma_ping_pong_xfer_gbl_region (Int32 instNum, Uint8 channelNum)
/* Ping setup */
if (CSL_edma3ParamSetup(hParamPing,&myParamSetup) != CSL_SOK)
printf ("Error: EDMA Parameter Entry Setup failed\n");
return -1;
/* Trigger channel */
CSL_edma3HwChannelControl(hChannel,CSL_EDMA3_CMD_CHANNEL_SET,NULL);
/* Poll on IPR bit 0 */
do {
CSL_edma3GetHwStatus(hModule,CSL_EDMA3_QUERY_INTRPEND,®ionIntr);
} while (!(regionIntr.intr & 0x1));
/* Clear the pending bit */
CSL_edma3HwControl(hModule,CSL_EDMA3_CMD_INTRPEND_CLEAR,®ionIntr);
/* The test passed. */
return 0;
int verify_transfer_pingpong(){
/* Check transfer by comparing the source and destination buffers */
if(Verify_Transfer( 512, 1, 1, 0, 0, 0, 0, srcBuff1, dstBuff1, TRUE) == FALSE)
printf ("Error: Verification (Source1/Destination1) Failed\n");
return -1;
return 0;
close_EDMA(){
/* Close channel */
if (CSL_edma3ChannelClose(hChannel) != CSL_SOK)
printf("Error: EDMA Channel Close failed\n");
/* Close EDMA module */
if (CSL_edma3Close(hModule) != CSL_SOK)
printf("Error: EDMA Module Close failed\n");
void main (void)
Uint8 channelNum=0;
Uint8 instNum = 0;
int i;
if (edma_ping_pong_xfer_gbl_region_init(instNum, channelNum) < 0)
printf ("Error: Init EDMA(%d) Channel %d FAILED\n", instNum, channelNum);
return;
printf ("Debug: Init EDMA(%d) Ping-Pong Test (Global) Region for Channel %d Passed\n", instNum, channelNum);
for(i=0;i<10;i++)
if (edma_ping_pong_xfer_gbl_region(instNum, channelNum) < 0)
printf ("Error: EDMA(%d) Channel %d FAILED\n", instNum, channelNum); return;
if (verify_transfer_pingpong() == 0)
printf ("Debug: Testing EDMA(%d) Ping-Pong Test (Global) Region for Channel %d Passed\n", instNum, channelNum);
close_EDMA();
return;
* @file edma_test.c
* @brief
* \par
* NOTE:
* are met:
* distribution.
#include <stdio.h>
* debugger... */
float srcBuff1[512];
float dstBuff1[512];
CSL_Status status;
Uint32 loopIndex;
* @b Description
* @n
* Data transfer.
* @retval
* Success - TRUE
* @retval
* Error - FALSE
Uint16 aCnt,
Uint16 bCnt,
Uint16 cCnt,
Uint16 srcBIdx,
Uint16 dstBIdx,
Uint16 srcCIdx,
Uint16 dstCIdx,
float *srcBuff,
float *dstBuff,
Bool abSync
Uint32 loopIndex1;
Uint32 loopIndex2;
Uint32 loopIndex3;
float* srcArrayPtr = (float*)srcBuff;
float* dstArrayPtr = (float*)dstBuff;
float* srcFramePtr = (float*)srcBuff;
float* dstFramePtr = (float*)dstBuff;
Uint16 key;
CACHE_invL1d ((void *)srcBuff, 512*sizeof(float), CACHE_WAIT);
CACHE_invL2 ((void *)srcBuff, 512*sizeof(float), CACHE_WAIT);
CACHE_invL1d ((void *)dstBuff, 512*sizeof(float), CACHE_WAIT);
CACHE_invL2 ((void *)dstBuff, 512*sizeof(float), CACHE_WAIT);
_mfence();
return FALSE;
if (abSync) {
else {
return TRUE;
* @b Description
* @n
* @retval
* Success - 0
* @retval
* Failure - <0
return -1;
return -1;
/* Channel open */
return -1;
if(!instNum)
return -1;
else
return -1;
return -1;
CSL_EDMA3_SYNC_A, \
myParamSetup.aCntbCnt = CSL_EDMA3_CNT_MAKE(512*sizeof(float),1);
return 0;
/* Ping setup */
return -1;
do {
return 0;
return -1;
return 0;
close_EDMA(){
/* Close channel */
void main (void)
Uint8 channelNum=0;
Uint8 instNum = 0;
int i;
return;
for(i=0;i<10;i++)
close_EDMA();
return;
