IPNC3.1 port HELP!
Now i'm porting the IPNC3.1 release to our own board.But have some error .The following isthe boot info :
Please ti engineer to look at.
U-Boot 2010.12-rc2 (May 03 2013 - 17:45:15)
Cores: ARM 297 MHz
DDR:   243 MHz
I2C:   ready
DRAM:  128 MiB
NAND:  256 MiB
Bad block table not found for chip 0
Bad block table written to 0x00000ffe0000, version 0x01
Bad block table written to 0x00000ffc0000, version 0x01
----sensor_init begin----
Net:   Ethernet PHY: GENERIC @ 0x00
DaVinci-EMAC
Hit any key to stop autoboot:  0
BOOTP broadcast 1
DHCP client bound to address 192.168.9.117
Using DaVinci-EMAC device
TFTP from server 192.168.9.188; our IP address is 192.168.9.117
Filename 'uImage_ipnc_dm368'.
Load address: 0x80700000
Loading: #################################################################
done
Bytes transferred = 3092188 (2f2edc hex)
## Booting kernel from Legacy Image at 80700000 ...
   Image Name:   Linux-2.6.18_pro500-davinci_IPNC
   Created:      2013-05-14   2:15:57 UTC
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    3092124 Bytes = 2.9 MiB
   Load Address: 80008000
   Entry Point:  80008000
   Verifying Checksum ... OK
   Loading Kernel Image ... OK
OK
Starting kernel ...
[    0.000000] Linux version 2.6.18_pro500-davinci_IPNC_DM368_3.1.0 (root@ben-desktop) (gcc version 4.2.0 (MontaVista 4.2.0-16.0.32.0801914 2008-08-30)) #1 PREEMPT Tue May 14 10:15:56 CST 2013
[    0.000000] CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=00053177
[    0.000000] Machine: DaVinci DM368 IPNC
[    0.000000] Memory policy: ECC disabled, Data cache writeback
[    0.000000] DaVinci DM0365 variant 0x8
[    0.000000] PLL0: fixedrate: 24000000, commonrate: 121500000, vpssrate: 243000000
[    0.000000] PLL0: vencrate_sd: 27000000, ddrrate: 243000000 mmcsdrate: 97200000
[    0.000000] PLL1: armrate: 297000000, voicerate: 20482758, vencrate_hd: 74250000
[    0.000000] CPU0: D VIVT write-back cache
[    0.000000] CPU0: I cache: 16384 bytes, associativity 4, 32 byte lines, 128 sets
[    0.000000] CPU0: D cache: 8192 bytes, associativity 4, 32 byte lines, 64 sets
[    0.000000] Built 1 zonelists.  Total pages: 12288
[    0.000000] Kernel command line: console=ttyS0,115200n8 noinitrd rw ip=dhcp root=/dev/nfs nfsroot=192.168.9.188:/home/ben/ipnc3.1/Source/ipnc_rdk/target/filesys,nolock mem=48M cmemk.phys_start="0x83000000" cmemk.phys_end="0x88000000" cmemk.phys_start_1="0x00001000" cmemk.phys_end_1="0x00008000" cmemk.pools_1="1x28672" cmemk.allowOverlap=1 eth=00:0e:99:02:ce:f4 lpj=1077248 nohz=off highres=off
[    0.000000] TI DaVinci EMAC: kernel boot params Ethernet address: 00:0e:99:02:ce:f4
[    0.000000] PID hash table entries: 256 (order: 8, 1024 bytes)
[    0.000000] Clock event device timer0_0 configured with caps set: 07
[    0.000000] Console: colour dummy device 80x30
[    0.000000] Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
[    0.000000] Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Memory: 48MB = 48MB total
[    0.000000] Memory: 45440KB available (2697K code, 314K data, 180K init)
[    0.000000] Calibrating delay loop (skipped)... 215.44 BogoMIPS preset
[    0.000000] Security Framework v1.0.0 initialized
[    0.000000] Capability LSM initialized
[    0.000000] Mount-cache hash table entries: 512
[    0.000000] CPU: Testing write buffer coherency: ok
[    0.010000] NET: Registered protocol family 16
[    0.010000] DaVinci: 104 gpio irqs
[    0.010000] MUX: initialized GPIO20
[    0.010000] MUX: initialized I2C_SCL
[    0.010000] MUX: initialized GPIO87
[    0.020000] Generic PHY: Registered new driver
[    0.020000] ch0 default output "COMPOSITE", mode "NTSC"
[    0.020000] VPBE Encoder Initialized
[    0.030000] SCSI subsystem initialized
[    0.030000] NET: Registered protocol family 2
[    0.120000] IP route cache hash table entries: 512 (order: -1, 2048 bytes)
[    0.120000] TCP established hash table entries: 2048 (order: 1, 8192 bytes)
[    0.120000] TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
[    0.120000] TCP: Hash tables configured (established 2048 bind 1024)
[    0.120000] TCP reno registered
[    0.140000] VFS: Disk quotas dquot_6.5.1
[    0.140000] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.150000] squashfs: version 3.1 (2006/08/19) Phillip Lougher
[    0.150000] JFFS2 version 2.2. (NAND) (C) 2001-2006 Red Hat, Inc.
[    0.150000] Initializing Cryptographic API
[    0.150000] io scheduler noop registered
[    0.150000] io scheduler anticipatory registered (default)
[    0.150000] io scheduler deadline registered
[    0.150000] io scheduler cfq registered
[    0.200000] CSL: Module install successful, device major num = 253
[    0.200000] CSL: Module version 0.10.00, built on May 14 2013 10:00:02
[    0.200000] I2C: Module install successful, device major num = 252
[    0.200000] DMA: Module install successful, device major num = 251
[    0.200000] DRV: Module install successful
[    0.200000] DRV: Module built on May 14 2013 10:00:07
[    0.200000] DRV: EDMACC.QUEPRI  = 00002777
[    0.200000] DRV: SYSTEM.MSTPRI0 = 00440011
[    0.200000] DRV: SYSTEM.MSTPRI1 = 00000444
[    0.200000] DRV: ISP.BCR        = 00000002
[    0.200000] DRV: SYSTEM.MISC    = 00000399
[    0.200000] EDMAK module: built on May 14 2013 at 09:59:23
[    0.200000]   Reference Linux version 2.6.18
[    0.200000]   File /home/ben/ipnc3.1/Source/dvsdk_ipnctools/linuxutils_2_24_03/packages/ti/sdo/linuxutils/edma/src/module/edmak.c
[    0.200000] IRQK module: built on May 14 2013 at 09:59:25
[    0.200000]   File /home/ben/ipnc3.1/Source/dvsdk_ipnctools/linuxutils_2_24_03/packages/ti/sdo/linuxutils/irq/src/module/irqk.c
[    0.200000] irqk initialized
[    0.200000] CMEMK module: built on May 14 2013 at 09:59:19
[    0.200000]   File /home/ben/ipnc3.1/Source/dvsdk_ipnctools/linuxutils_2_24_03/packages/ti/sdo/linuxutils/cmem/src/module/cmemk.c
[    0.210000] allocated heap buffer 0xc4000000 of size 0x5000000
[    0.210000] CMEM Range Overlaps Kernel Physical - allowing overlap
[    0.210000] CMEM phys_start (0x1000) overlaps kernel (0x80000000 -> 0x83000000)
[    0.210000] cmemk initialized
[    0.210000] Serial: 8250/16550 driver $Revision: 1.90 $ 2 ports, IRQ sharing disabled
[    0.210000] serial8250.0: ttyS0 at MMIO map 0x1c20000 mem 0xfbc20000 (irq = 40) is a 16550A
[    0.230000] serial8250.0: ttyS1 at MMIO map 0x1d06000 mem 0xfbd06000 (irq = 41) is a 16550A
[    0.240000] RAMDISK driver initialized: 1 RAM disks of 32768K size 1024 blocksize
[    0.250000] Davinci EMAC MII Bus: probed
[    0.250000] MAC address is 00:0e:99:02:ce:f4
[    0.260000] TI DaVinci EMAC Linux version updated 4.0
[    0.270000] Linux video capture interface: v2.00
[    0.270000] Trying to register davinci display video device.
[    0.280000] layer=c0546c00,layer->video_dev=c0546d60
[    0.280000] Trying to register davinci display video device.
[    0.290000] layer=c0546a00,layer->video_dev=c0546b60
[    0.300000] davinci_init:DaVinci V4L2 Display Driver V1.0 loaded
[    0.300000] i2c /dev entries driver
[    0.310000] nand_davinci nand_davinci.0: Using 4-bit hardware ECC
[    0.320000] NAND device: Manufacturer ID: 0x2c, Chip ID: 0xda (Micron NAND 256MiB 3,3V 8-bit)
[    0.330000] Bad block table not found for chip 0
[    0.340000] Scanning device for bad blocks
[    0.440000] Creating 6 MTD partitions on "nand_davinci.0":
[    0.440000] 0x00000000-0x00300000 : "bootloader"
[    0.450000] 0x00300000-0x00500000 : "params"
[    0.460000] 0x00500000-0x00900000 : "kernel"
[    0.460000] 0x00900000-0x02100000 : "filesystem"
[    0.470000] 0x02100000-0x02300000 : "data1"
[    0.480000] 0x02300000-0x10000000 : "data2"
[    0.480000] nand_davinci nand_davinci.0: hardware revision: 2.3
[    0.490000] MUX: initialized SPI0_SCLK
[    0.490000] MUX: initialized SPI0_SDO)
[    0.490000] MUX: initialized SPI0_SDENA0
[    0.500000] dm_spi.0: davinci SPI Controller driver at 0xc386e000 (irq = 42) use_dma=0
[    0.520000] rtc_davinci_dm365 rtc_davinci_dm365.0: rtc intf: proc
[    0.520000] rtc_davinci_dm365 rtc_davinci_dm365.0: rtc intf: dev (254:0)
[    0.530000] rtc_davinci_dm365 rtc_davinci_dm365.0: rtc core: registered rtc_davinci_dm365 as rtc0
[    0.540000] Advanced Linux Sound Architecture Driver Version 1.0.12rc1 (Thu Jun 22 13:55:50 2006 UTC).
[    0.550000] ASoC version 0.13.1
[    0.550000] CQ0093 Voice Codec 0.1
[    0.560000] asoc: cq93vc <-> davinci-vcif mapping ok
[    0.570000] ALSA device list:
[    0.570000]   #0: On-chip voice codec (cq93vc)
[    0.580000] IPv4 over IPv4 tunneling driver
[    0.580000] TCP bic registered
[    0.590000] NET: Registered protocol family 1
[    0.590000] NET: Registered protocol family 17
[    0.600000] rtc_davinci_dm365 rtc_davinci_dm365.0: setting the system clock to 2000-01-01 00:00:00 (946684800)
[    0.610000] Time: timer0_1 clocksource has been installed.
[    0.640000] 1:01 not found
[    0.640000] 1:02 not found
[    0.640000] 1:03 not found
[    0.650000] 1:04 not found
[    0.650000] 1:05 not found
[    0.650000] 1:06 not found
[    0.650000] 1:07 not found
[    0.660000] 1:08 not found
[    0.660000] 1:09 not found
[    0.660000] 1:0a not found
[    0.670000] 1:0b not found
[    0.670000] 1:0c not found
[    0.670000] 1:0d not found
[    0.670000] 1:0e not found
[    0.680000] 1:0f not found
[    0.680000] 1:10 not found
[    0.680000] 1:11 not found
[    0.680000] 1:12 not found
[    0.690000] 1:13 not found
[    0.690000] 1:14 not found
[    0.690000] 1:15 not found
[    0.700000] 1:16 not found
[    0.700000] 1:17 not found
[    0.700000] 1:18 not found
[    0.700000] 1:19 not found
[    0.710000] 1:1a not found
[    0.710000] 1:1b not found
[    0.710000] 1:1c not found
[    0.710000] 1:1d not found
[    0.720000] 1:1e not found
[    0.720000] 1:1f not found
[    0.740000] Sending DHCP requests ..., OK
[    8.100000] IP-Config: Got DHCP answer from 0.0.0.0, my address is 192.168.9.117
[    8.100000] IP-Config: Complete:
[    8.110000]       device=eth0, addr=192.168.9.117, mask=255.255.255.0, gw=192.168.9.1,
[    8.110000]      host=192.168.9.117, domain=, nis-domain=(none),
[    8.120000]      bootserver=0.0.0.0, rootserver=192.168.9.188, rootpath=
[    8.130000] Looking up port of RPC 100003/2 on 192.168.9.188
[    8.150000] Looking up port of RPC 100005/1 on 192.168.9.188
[    8.160000] VFS: Mounted root (nfs filesystem).
[    8.170000] Freeing init memory: 180K
INIT: version 2.86 booting
mknod: /dev/spidev0.0: File exists
Creat queue id:0
queue id:0
FileMngThread created
Creat queue id:32769
queue id:32769
queue id:32769
AlramThread created
Share memory init success
queue id:65538
Creat queue id:65538
queue id:65538
Creat queue id:98307
queue id:98307
[   10.900000] nfs: RPC call returned error 101
[   10.910000] nfs: RPC call returned error 101
[   10.920000] nfs: RPC call returned error 101
[   10.930000] nfs: RPC call returned error 101
[   10.940000] nfs: RPC call returned error 101
[   10.950000] nfs: RPC call returned error 101
[   10.960000] nfs: RPC call returned error 101
[   10.970000] nfs: RPC call returned error 101
[   10.980000] nfs: RPC call returned error 101
[   10.990000] nfs: RPC call returned error 101
[   11.000000] nfs: RPC call returned error 101
[   11.010000] nfs: RPC call returned error 101
[   11.020000] nfs: RPC call returned error 101
[   11.030000] nfs: RPC call returned error 101
[   11.040000] nfs: RPC call returned error 101
[   11.050000] nfs: RPC call returned error 101
[   11.060000] nfs: RPC call returned error 101
[   11.070000] nfs: RPC call returned error 101
[   11.080000] nfs: RPC call returned error 101
[   11.090000] nfs: RPC call returned error 101
[   11.100000] nfs: RPC call returned error 101
echo: error while loading shared libraries: libcrypt.so.1: cannot open shared ob[   11.110000] nfs: RPC call returned error 101
ject file: Error 101
/opt/ipnc/beforeloadkmodule.sh: /opt/ipnc/beforeloadkmodul[   11.120000] nfs: RPC call returned error 101
e.sh: 2: /opt/ipnc/modules/init.d_ins/portmap: N[   11.130000] nfs: RPC call returned error 101
etwork is unreac[   11.130000] nfs: RPC call returned error 101
hable
/opt/ipnc[   11.140000] nfs: RPC call returned error 101
/beforeloadkmodu[   11.140000] nfs: RPC call returned error 101
le.sh: /opt/ipnc/beforeloadkmodu[   11.150000] nfs: RPC call returned error 101
le.sh: 3: /opt/i[   11.150000] nfs: RPC call returned error 101
pnc/modules/init[   11.160000] nfs: RPC call returned error 101
.d_ins/mountall.[   11.170000] nfs: RPC call returned error 101
sh: Network is u[   11.170000] nfs: RPC call returned error 101
nreachable
/opt[   11.180000] nfs: RPC call returned error 101
/ipnc/beforeload[   11.180000] nfs: RPC call returned error 101
kmodule.sh: /opt[   11.190000] nfs: RPC call returned error 101
/ipnc/beforeload[   11.200000] nfs: RPC call returned error 101
kmodule.sh: 4: /[   11.200000] nfs: RPC call returned error 101
opt/ipnc/modules/init.d_ins/hotp[   11.210000] nfs: RPC call returned error 101
lug: Network is [   11.210000] nfs: RPC call returned error 101
unreachable
/op[   11.220000] nfs: RPC call returned error 101
t/ipnc/beforeloa[   11.220000] nfs: RPC call returned error 101
dkmodule.sh: /op[   11.230000] nfs: RPC call returned error 101
t/ipnc/beforeloa[   11.240000] nfs: RPC call returned error 101
dkmodule.sh: 5: [   11.240000] nfs: RPC call returned error 101
insmod: Network [   11.250000] nfs: RPC call returned error 101
is unreachable
/opt/ipnc/before[   11.260000] nfs: RPC call returned error 101
loadkmodule.sh: [   11.260000] nfs: RPC call returned error 101
/opt/ipnc/before[   11.270000] nfs: RPC call returned error 101
loadkmodule.sh: 6: insmod: Network is unreachable
/opt/ipnc/bef[   11.280000] nfs: RPC call returned error 101
oreloadkmodule.sh: /opt/ipnc/beforeloadkmodule.sh: 7: insmod: Network is unreach[   11.290000] nfs: RPC call returned error 101
able
/opt/ipnc/beforeloadkmodule.sh: /opt/ipnc/[   11.300000] nfs: RPC call returned error 101
beforeloadkmodul[   11.310000] nfs: RPC call returned error 101
e.sh: 8: insmod:[   11.310000] nfs: RPC call returned error 101
 Network is unre[   11.320000] nfs: RPC call returned error 101
achable
/opt/ipnc/beforeloadkmo[   11.320000] nfs: RPC call returned error 101
dule.sh: /opt/ipnc/beforeloadkmodule.sh: 10: ins[   11.330000] nfs: RPC call returned error 101
/opt/ipnc/beforeloadkmodule.sh: /opt/ipnc/beforeloa[   11.340000] nfs: RPC call returned error 101
dkmodule.sh: 11: insmod: Network is unreachable
/etc/init.d/rcS: /etc/init.d/rc[   11.360000] nfs: RPC call returned error 101
[   11.370000] nfs: RPC call returned error 101
[   11.380000] nfs: RPC call returned error 101
[   11.390000] nfs: RPC call returned error 101
[   11.400000] nfs: RPC call returned error 101
[   11.410000] nfs: RPC call returned error 101
[   11.420000] nfs: RPC call returned error 101
[   11.430000] nfs: RPC call returned error 101
[   11.440000] nfs: RPC call returned error 101
[   11.450000] nfs: RPC call returned error 101
[   11.460000] nfs: RPC call returned error 101
[   11.470000] nfs: RPC call returned error 101
[   11.480000] nfs: RPC call returned error 101
[   11.490000] nfs: RPC call returned error 101
[   11.500000] nfs: RPC call returned error 101
[   11.510000] nfs: RPC call returned error 101
[   11.520000] nfs: RPC call returned error 101
[   11.530000] nfs: RPC call returned error 101
[   11.540000] nfs: RPC call returned error 101
[   11.550000] nfs: RPC call returned error 101
[   11.560000] nfs: RPC call returned error 101
[   11.570000] nfs: RPC call returned error 101
[   11.580000] nfs: RPC call returned error 101
[   11.590000] nfs: RPC call returned error 101
[   11.600000] nfs: RPC call returned error 101
[   11.610000] nfs: RPC call returned error 101
[   11.620000] nfs: RPC call returned error 101
[   11.630000] nfs: RPC call returned error 101
[   11.640000] nfs: RPC call returned error 101
[   11.650000] nfs: RPC call returned error 101
[   11.660000] nfs: RPC call returned error 101
[   11.670000] nfs: RPC call returned error 101
[   11.680000] nfs: RPC call returned error 101
[   11.690000] nfs: RPC call returned error 101
[   11.700000] nfs: RPC call returned error 101
[   11.710000] nfs: RPC call returned error 101
[   11.720000] nfs: RPC call returned error 101
[   11.730000] nfs: RPC call returned error 101
[   11.740000] nfs: RPC call returned error 101
[   11.750000] nfs: RPC call returned error 101
[   11.760000] nfs: RPC call returned error 101
[   11.770000] nfs: RPC call returned error 101
[   11.780000] nfs: RPC call returned error 101
[   11.790000] nfs: RPC call returned error 101
[   11.800000] nfs: RPC call returned error 101
[   11.810000] nfs: RPC call returned error 101
[   11.820000] nfs: RPC call returned error 101
[   11.830000] nfs: RPC call returned error 101
[   11.840000] nfs: RPC call returned error 101
[   11.850000] nfs: RPC call returned error 101
[   11.860000] nfs: RPC call returned error 101
[   11.870000] nfs: RPC call returned error 101
[   11.880000] nfs: RPC call returned error 101
[   11.890000] nfs: RPC call returned error 101
[   11.900000] nfs: RPC call returned error 101
[   11.910000] nfs: RPC call returned error 101
[   11.920000] nfs: RPC call returned error 101
[   11.930000] nfs: RPC call returned error 101
[   11.940000] nfs: RPC call returned error 101
[   11.950000] nfs: RPC call returned error 101
[   11.960000] nfs: RPC call returned error 101
[   11.970000] nfs: RPC call returned error 101
[   11.980000] nfs: RPC call returned error 101
[   11.990000] nfs: RPC call returned error 101
[   12.000000] nfs: RPC call returned error 101
[   12.010000] nfs: RPC call returned error 101
[   12.020000] nfs: RPC call returned error 101
[   12.030000] nfs: RPC call returned error 101
[   12.040000] nfs: RPC call returned error 101
[   12.050000] nfs: RPC call returned error 101
[   12.060000] nfs: RPC call returned error 101
[   12.070000] nfs: RPC call returned error 101
[   12.080000] nfs: RPC call returned error 101
[   12.090000] nfs: RPC call returned error 101
[   12.100000] nfs: RPC call returned error 101
[   12.110000] nfs: RPC call returned error 101
[   12.120000] nfs: RPC call returned error 101
[   12.130000] nfs: RPC call returned error 101
[   12.140000] nfs: RPC call returned error 101
[   12.150000] nfs: RPC call returned error 101
[   12.160000] nfs: RPC call returned error 101
[   12.170000] nfs: RPC call returned error 101
[   12.180000] nfs: RPC call returned error 101
[   12.190000] nfs: RPC call returned error 101
[   12.200000] nfs: RPC call returned error 101
[   12.210000] nfs: RPC call returned error 101
[   12.220000] nfs: RPC call returned error 101
[   12.230000] nfs: RPC call returned error 101
[   12.240000] nfs: RPC call returned error 101
[   12.250000] nfs: RPC call returned error 101
[   12.260000] nfs: RPC call returned error 101
[   12.270000] nfs: RPC call returned error 101
[   12.280000] nfs: RPC call returned error 101
[   12.290000] nfs: RPC call returned error 101
[   12.300000] nfs: RPC call returned error 101
[   12.310000] nfs: RPC call returned error 101
[   12.320000] nfs: RPC call returned error 101
[   12.330000] nfs: RPC call returned error 101
[   12.340000] nfs: RPC call returned error 101
[   12.350000] nfs: RPC call returned error 101
[   12.360000] nfs: RPC call returned error 101
[   12.370000] nfs: RPC call returned error 101
[   12.380000] nfs: RPC call returned error 101
[   12.390000] nfs: RPC call returned error 101
[   12.400000] nfs: RPC call returned error 101
[   12.410000] nfs: RPC call returned error 101
[   12.420000] nfs: RPC call returned error 101
[   12.430000] nfs: RPC call returned error 101
[   12.440000] nfs: RPC call returned error 101
[   12.450000] nfs: RPC call returned error 101
[   12.460000] nfs: RPC call returned error 101
[   12.470000] nfs: RPC call returned error 101
[   12.480000] nfs: RPC call returned error 101
[   12.490000] nfs: RPC call returned error 101
[   12.500000] nfs: RPC call returned error 101
[   12.510000] nfs: RPC call returned error 101
[   12.520000] nfs: RPC call returned error 101
[   12.530000] nfs: RPC call returned error 101
[   12.540000] nfs: RPC call returned error 101
[   12.550000] nfs: RPC call returned error 101
[   12.560000] nfs: RPC call returned error 101
[   12.570000] nfs: RPC call returned error 101
[   12.580000] nfs: RPC call returned error 101
[   12.590000] nfs: RPC call returned error 101
[   12.600000] nfs: RPC call returned error 101
[   12.610000] nfs: RPC call returned error 101
[   12.620000] nfs: RPC call returned error 101
[   12.630000] nfs: RPC call returned error 101
[   12.640000] nfs: RPC call returned error 101
[   12.650000] nfs: RPC call returned error 101
[   12.660000] nfs: RPC call returned error 101
[   12.670000] nfs: RPC call returned error 101
[   12.680000] nfs: RPC call returned error 101
[   12.690000] nfs: RPC call returned error 101
[   12.700000] nfs: RPC call returned error 101
[   12.710000] nfs: RPC call returned error 101
[   12.720000] nfs: RPC call returned error 101
[   12.730000] nfs: RPC call returned error 101
[   12.740000] nfs: RPC call returned error 101
[   12.750000] nfs: RPC call returned error 101
[   12.760000] nfs: RPC call returned error 101
[   12.770000] nfs: RPC call returned error 101
[   12.780000] nfs: RPC call returned error 101
[   12.790000] nfs: RPC call returned error 101
[   12.800000] nfs: RPC call returned error 101
[   12.810000] nfs: RPC call returned error 101
[   12.820000] nfs: RPC call returned error 101
[   12.830000] nfs: RPC call returned error 101
[   12.840000] nfs: RPC call returned error 101
[   12.850000] nfs: RPC call returned error 101
[   12.860000] nfs: RPC call returned error 101
[   12.870000] nfs: RPC call returned error 101
[   12.880000] nfs: RPC call returned error 101
[   12.890000] nfs: RPC call returned error 101
[   12.900000] nfs: RPC call returned error 101
[   12.910000] nfs: RPC call returned error 101
[   12.920000] nfs: RPC call returned error 101
[   12.930000] nfs: RPC call returned error 101
[   12.940000] nfs: RPC call returned error 101
[   12.950000] nfs: RPC call returned error 101
[   12.960000] nfs: RPC call returned error 101
[   12.970000] nfs: RPC call returned error 101
[   12.980000] nfs: RPC call returned error 101
[   12.990000] nfs: RPC call returned error 101
[   13.000000] nfs: RPC call returned error 101
[   13.010000] nfs: RPC call returned error 101
[   13.020000] nfs: RPC call returned error 101
[   13.030000] nfs: RPC call returned error 101
[   13.040000] nfs: RPC call returned error 101
[   13.050000] nfs: RPC call returned error 101
[   13.060000] nfs: RPC call returned error 101
[   13.070000] nfs: RPC call returned error 101
[   13.080000] nfs: RPC call returned error 101
[   13.090000] nfs: RPC call returned error 101
[   13.100000] nfs: RPC call returned error 101
[   13.110000] nfs: RPC call returned error 101
[   13.120000] nfs: RPC call returned error 101
[   13.130000] nfs: RPC call returned error 101
[   13.140000] nfs: RPC call returned error 101
[   13.150000] nfs: RPC call returned error 101
[   13.160000] nfs: RPC call returned error 101
[   13.170000] nfs: RPC call returned error 101
[   13.180000] nfs: RPC call returned error 101
[   13.190000] nfs: RPC call returned error 101
[   13.200000] nfs: RPC call returned error 101
[   13.210000] nfs: RPC call returned error 101
[   13.220000] nfs: RPC call returned error 101
[   13.230000] nfs: RPC call returned error 101
[   13.240000] nfs: RPC call returned error 101
[   13.250000] nfs: RPC call returned error 101
[   13.260000] nfs: RPC call returned error 101
[   13.270000] nfs: RPC call returned error 101
[   13.280000] nfs: RPC call returned error 101
[   13.290000] nfs: RPC call returned error 101
[   13.300000] nfs: RPC call returned error 101
[   13.310000] nfs: RPC call returned error 101
[   13.320000] nfs: RPC call returned error 101
[   13.330000] nfs: RPC call returned error 101
[   13.340000] nfs: RPC call returned error 101
[   13.350000] nfs: RPC call returned error 101
[   13.360000] nfs: RPC call returned error 101
[   13.370000] nfs: RPC call returned error 101
[   13.380000] nfs: RPC call returned error 101
[   13.390000] nfs: RPC call returned error 101
[   13.400000] nfs: RPC call returned error 101
[   13.410000] nfs: RPC call returned error 101
[   13.420000] nfs: RPC call returned error 101
[   13.430000] nfs: RPC call returned error 101
[   13.440000] nfs: RPC call returned error 101
[   13.450000] nfs: RPC call returned error 101
[   13.460000] nfs: RPC call returned error 101
[   13.470000] nfs: RPC call returned error 101
[   13.480000] nfs: RPC call returned error 101
[   13.490000] nfs: RPC call returned error 101
[   13.500000] nfs: RPC call returned error 101
[   13.510000] nfs: RPC call returned error 101
[   13.520000] nfs: RPC call returned error 101
[   13.530000] nfs: RPC call returned error 101
[   13.540000] nfs: RPC call returned error 101
[   13.550000] nfs: RPC call returned error 101
[   13.560000] nfs: RPC call returned error 101
[   13.570000] nfs: RPC call returned error 101
[   13.580000] nfs: RPC call returned error 101
[   13.590000] nfs: RPC call returned error 101
[   13.600000] nfs: RPC call returned error 101
[   13.610000] nfs: RPC call returned error 101
[   13.620000] nfs: RPC call returned error 101
[   13.630000] nfs: RPC call returned error 101
[   13.640000] nfs: RPC call returned error 101
[   13.650000] nfs: RPC call returned error 101
[   13.660000] nfs: RPC call returned error 101
[   13.670000] nfs: RPC call returned error 101
[   13.680000] nfs: RPC call returned error 101
[   13.690000] nfs: RPC call returned error 101
[   13.700000] nfs: RPC call returned error 101
[   13.710000] nfs: RPC call returned error 101
[   13.720000] nfs: RPC call returned error 101
[   13.730000] nfs: RPC call returned error 101
[   13.740000] nfs: RPC call returned error 101
[   13.750000] nfs: RPC call returned error 101
[   13.760000] nfs: RPC call returned error 101
[   13.770000] nfs: RPC call returned error 101
[   13.780000] nfs: RPC call returned error 101
[   13.790000] nfs: RPC call returned error 101
[   13.800000] nfs: RPC call returned error 101
[   13.810000] nfs: RPC call returned error 101
[   13.820000] nfs: RPC call returned error 101
[   13.830000] nfs: RPC call returned error 101
[   13.840000] nfs: RPC call returned error 101
[   13.850000] nfs: RPC call returned error 101
[   13.860000] nfs: RPC call returned error 101
[   13.870000] nfs: RPC call returned error 101
[   13.880000] nfs: RPC call returned error 101
[   13.890000] nfs: RPC call returned error 101
[   13.900000] nfs: RPC call returned error 101
[   13.910000] nfs: RPC call returned error 101
[   13.920000] nfs: RPC call returned error 101
[   13.930000] nfs: RPC call returned error 101
[   13.940000] nfs: RPC call returned error 101
[   13.950000] nfs: RPC call returned error 101
[   13.960000] nfs: RPC call returned error 101
[   13.970000] nfs: RPC call returned error 101
[   13.980000] nfs: RPC call returned error 101
[   13.990000] nfs: RPC call returned error 101
[   14.000000] nfs: RPC call returned error 101
[   14.010000] nfs: RPC call returned error 101
[   14.020000] nfs: RPC call returned error 101
[   14.030000] nfs: RPC call returned error 101
[   14.040000] nfs: RPC call returned error 101
[   14.050000] nfs: RPC call returned error 101
[   14.060000] nfs: RPC call returned error 101
[   14.070000] nfs: RPC call returned error 101
[   14.080000] nfs: RPC call returned error 101
[   14.090000] nfs: RPC call returned error 101
[   14.100000] nfs: RPC call returned error 101
[   14.110000] nfs: RPC call returned error 101
[   14.120000] nfs: RPC call returned error 101
[   14.130000] nfs: RPC call returned error 101
[   14.140000] nfs: RPC call returned error 101
[   14.150000] nfs: RPC call returned error 101
[   14.160000] nfs: RPC call returned error 101
[   14.170000] nfs: RPC call returned error 101
[   14.180000] nfs: RPC call returned error 101
[   14.190000] nfs: RPC call returned error 101
[   14.200000] nfs: RPC call returned error 101
[   14.210000] nfs: RPC call returned error 101
[   14.220000] nfs: RPC call returned error 101
[   14.230000] nfs: RPC call returned error 101
[   14.240000] nfs: RPC call returned error 101
[   14.250000] nfs: RPC call returned error 101
[   14.260000] nfs: RPC call returned error 101
[   14.270000] nfs: RPC call returned error 101
[   14.280000] nfs: RPC call returned error 101
[   14.290000] nfs: RPC call returned error 101
[   14.300000] nfs: RPC call returned error 101
[   14.310000] nfs: RPC call returned error 101
[   14.320000] nfs: RPC call returned error 101
[   14.330000] nfs: RPC call returned error 101
[   14.340000] nfs: RPC call returned error 101
[   14.350000] nfs: RPC call returned error 101
[   14.360000] nfs: RPC call returned error 101
[   14.370000] nfs: RPC call returned error 101
[   14.380000] nfs: RPC call returned error 101
