HI
i was trying to run encoder_create below decoder inside sv04 example
and i found that if i do alg_create than previously running decoder is also not running
I tried same, sometime before and i provided scratch memory in different section in encoder create and decoder create.
i have attached siuVctMemMgr.c, where alg_alloc function is not re entrant.
/* NAME */
/* alg_malloc.c */
/* DESCRIPTION */
/* This module implements an algorithm memory management "policy" in which */
/* no memory is shared among algorithm objects. Memory is, however */
/* reclaimed when objects are deleted. */
/* preemption sharing object deletion */
/* yes(*) none yes */
/* Note 1: this module uses run-time support functions malloc() and free() */
/* to allocate and free memory. Since these functions are *not* reentrant, */
/* either all object creation and deletion must be performed by a single */
/* thread or reentrant versions of these functions must be created. */
/* Copyright (c) 2001-2003 Texas Instruments Incorporated.
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the
* distribution.
* Neither the name of Texas Instruments Incorporated nor the names of
* its contributors may be used to endorse or promote products derived
* from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
* "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
* LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
* A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
* OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
* SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
* DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
* THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
* OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
#include "common/siuloc.h"
#include <ti/bios/include/std.h> /* Take from Bios*/
#include <ti/xdais/ialg.h>
#include <stdio.h>
#include <stdlib.h> /* malloc/free declarations */
#include <string.h> /* memset declaration */
#define INTERNAL_DATA_MEM_SIZE (0x45D00) // Need: 0x81C34
#define INTERNAL_PERSIST_MEM_SIZE (0x02500)
#define INTERNAL_SCRATCH_MEM_SIZE (0x43800)
/* list of some parameters macros for worst case memory allocation in external memory */
#define EXTERNAL_DATA_MEM_SIZE (16*1920*1088) //Need: 0xA7F520
#pragma DATA_SECTION( ExternalGlobalMemCore0, ".testCodecExtMemCore0");
#pragma DATA_SECTION( ExternalGlobalMemCore1, ".testCodecExtMemCore1");
#pragma DATA_SECTION( ExternalGlobalMemCore2, ".testCodecExtMemCore2");
#pragma DATA_SECTION( ExternalGlobalMemCore3, ".testCodecExtMemCore3");
#pragma DATA_SECTION( ExternalGlobalMemCore4, ".testCodecExtMemCore4");
#pragma DATA_SECTION( ExternalGlobalMemCore5, ".testCodecExtMemCore5");
#pragma DATA_SECTION( ExternalGlobalMemCore6, ".testCodecExtMemCore6");
#pragma DATA_SECTION( ExternalGlobalMemCore7, ".testCodecExtMemCore7");
//#pragma DATA_SECTION( internalDataMemory, ".testCodecIntMem");
//#pragma DATA_SECTION( pInternalDataMemory, ".testCodecIntMemInit");
//#pragma DATA_SECTION( internalDataMemorySize, ".testCodecIntMemInit");
#pragma DATA_SECTION( internalPersistMemory, ".testCodecIntMem");
#pragma DATA_SECTION( pInternalPersistMemory, ".testCodecIntMemInit");
#pragma DATA_SECTION( internalPersistMemorySize, ".testCodecIntMemInit");
#pragma DATA_SECTION( internalScratchMemory, ".testCodecIntMem");
#pragma DATA_SECTION( pInternalScratchMemory, ".testCodecIntMemInit");
#pragma DATA_SECTION( internalScratchMemorySize, ".testCodecIntMemInit");
unsigned char ExternalGlobalMemCore0[EXTERNAL_DATA_MEM_SIZE];
unsigned char *ExternalGlobalMemPool = ExternalGlobalMemCore0;
unsigned int externalDataMemorySize = EXTERNAL_DATA_MEM_SIZE;
unsigned char ExternalGlobalMemCore1[EXTERNAL_DATA_MEM_SIZE];
unsigned char ExternalGlobalMemCore2[EXTERNAL_DATA_MEM_SIZE];
unsigned char ExternalGlobalMemCore3[EXTERNAL_DATA_MEM_SIZE];
unsigned char ExternalGlobalMemCore4[EXTERNAL_DATA_MEM_SIZE];
unsigned char ExternalGlobalMemCore5[EXTERNAL_DATA_MEM_SIZE];
unsigned char ExternalGlobalMemCore6[EXTERNAL_DATA_MEM_SIZE];
unsigned char ExternalGlobalMemCore7[EXTERNAL_DATA_MEM_SIZE];
//unsigned char internalDataMemory[ INTERNAL_DATA_MEM_SIZE];
//unsigned char *pInternalDataMemory = internalDataMemory;
//unsigned int internalDataMemorySize = INTERNAL_DATA_MEM_SIZE;
unsigned char internalPersistMemory[INTERNAL_PERSIST_MEM_SIZE];
unsigned char *pInternalPersistMemory = internalPersistMemory;
unsigned int internalPersistMemorySize = INTERNAL_PERSIST_MEM_SIZE;
unsigned char internalScratchMemory[INTERNAL_SCRATCH_MEM_SIZE];
unsigned char *pInternalScratchMemory = internalScratchMemory;
unsigned int internalScratchMemorySize = INTERNAL_SCRATCH_MEM_SIZE;
extern int errorNumber;
Bool
_ALG_allocMemory(IALG_MemRec memTab[], Int n);
Void
_ALG_freeMemory(IALG_MemRec memTab[], Int n);
void *
memAlignVc(size_t alignment, size_t size)
return malloc(size);
} /* memAlignVc */
int
allocateMemTabRequest(IALG_MemRec *memTab)
if (memTab->space == IALG_EXTERNAL)
unsigned int alignBytes;
alignBytes = (((unsigned int) ExternalGlobalMemPool
+ (memTab->alignment - 1)) & (~(memTab->alignment - 1)));
alignBytes -= (unsigned int) ExternalGlobalMemPool;
ExternalGlobalMemPool += alignBytes;
externalDataMemorySize -= alignBytes;
if (externalDataMemorySize >= memTab->size)
/* allocate memory */
memTab->base = ExternalGlobalMemPool;
ExternalGlobalMemPool += memTab->size;
externalDataMemorySize -= memTab->size;
else
memTab->base = 0;
else
/* internal memory request */
#if 0
alignBytes = (((unsigned int) pInternalDataMemory + (memTab->alignment - 1)) & (~ (memTab->alignment - 1)));
if(alignBytes!=0)
alignBytes -= (unsigned int) pInternalDataMemory;
pInternalDataMemory += alignBytes;
internalDataMemorySize -= alignBytes;
if(internalDataMemorySize >= memTab->size)
memTab->base = pInternalDataMemory;
pInternalDataMemory += memTab->size;
internalDataMemorySize -= memTab->size;
else
memTab->base = 0;
#endif
switch (memTab->attrs)
case IALG_SCRATCH:
alignBytes = (((unsigned int) pInternalScratchMemory
if (alignBytes != 0)
alignBytes -= (unsigned int) pInternalScratchMemory;
pInternalScratchMemory += alignBytes;
internalScratchMemorySize -= alignBytes;
if (internalScratchMemorySize >= memTab->size)
memTab->base = pInternalScratchMemory;
pInternalScratchMemory += memTab->size;
internalScratchMemorySize -= memTab->size;
else
memTab->base = 0;
break;
case IALG_PERSIST:
case IALG_WRITEONCE:
alignBytes = (((unsigned int) pInternalPersistMemory
alignBytes -= (unsigned int) pInternalPersistMemory;
pInternalPersistMemory += alignBytes;
internalPersistMemorySize -= alignBytes;
if (internalPersistMemorySize >= memTab->size)
memTab->base = pInternalPersistMemory;
pInternalPersistMemory += memTab->size;
internalPersistMemorySize -= memTab->size;
else
memTab->base = 0;
break;
default:
memTab->base = 0;
return 0;
} /* allocateMemTabRequest */
int
freeMemTabRequest(IALG_MemRec *memTab)
memTab->base = 0;
switch (siuContext.coreId)
case 0:
break;
default:
ExternalGlobalMemPool = ExternalGlobalMemCore1;
break;
case 2:
ExternalGlobalMemPool = ExternalGlobalMemCore2;
break;
case 3:
ExternalGlobalMemPool = ExternalGlobalMemCore3;
break;
case 4:
ExternalGlobalMemPool = ExternalGlobalMemCore4;
break;
case 5:
ExternalGlobalMemPool = ExternalGlobalMemCore5;
break;
case 6:
ExternalGlobalMemPool = ExternalGlobalMemCore6;
break;
case 7:
ExternalGlobalMemPool = ExternalGlobalMemCore7;
break;
else
/* internal memory free request. XXX see the code below
* for the dangers of calling them as normal mallocs. Free is faked!!! */
memTab->base = 0;
return 0;
} /* freeMemTabRequest */
* ======== ALG_exit ========
Void
ALG_exit( Void)
* ======== ALG_init ========
Void
ALG_init( Void)
* ======== _ALG_allocMemory ========
Bool
Int i;
case 0:
break;
case 1:
break;
case 2:
break;
case 3:
break;
case 4:
break;
case 5:
break;
case 6:
break;
case 7:
break;
for (i = 0; i < n; i++)
allocateMemTabRequest(&memTab[i]);
if (memTab[i].base == NULL)
_ALG_freeMemory(memTab, i);
return (FALSE);
memset(memTab[i].base, 0, memTab[i].size);
printf(
"algAlloc supplied: Buffer %d: space = %d, attr = %d, size = %ld \n",
i, memTab[i].space, memTab[i].attrs, memTab[i].size);
return (TRUE);
* ======== _ALG_freeMemory ========
Void
Int i;
if (memTab[i].base != NULL)
/* XXX changing code here too. to take care of internal memory
* allocatiuons */
freeMemTabRequest(&memTab[i]);
* ======== ALG_create ========
#include <stdio.h>
#include <stdlib.h>
#define SIUVCT_MAX_NUM_ALG_BUFFS 64
static int iVideo = 0;
char memTabMemory_local[SIUVCT_MAX_NUM_ALG_BUFFS * sizeof(IALG_MemRec)*2]; //969
IALG_Handle
ALG_create(IALG_Fxns *fxns, IALG_Handle p, IALG_Params *params)
IALG_MemRec *memTab;
Int i, n, ret;
IALG_Handle alg;
IALG_Fxns *fxnsPtr;
printf("FYI: Attrs | Val \n");
printf(" SCRATCH | %d \n", IALG_SCRATCH);
printf(" PERSIST | %d \n", IALG_PERSIST);
printf(" WRITEONCE | %d \n", IALG_WRITEONCE);
if (fxns != NULL)
errorNumber = iVideo + 100;
n = ((fxns->algNumAlloc != NULL) ? fxns->algNumAlloc() : IALG_DEFMEMRECS);
/* The cores cannot share memtab memory */
//memTab = (IALG_MemRec *)memTabMemory;
memTab = (IALG_MemRec *) memTabMemory_local
+ (SIUVCT_MAX_NUM_ALG_BUFFS * sizeof(IALG_MemRec) * iVideo);
if (memTab != NULL)
n = fxns->algAlloc(params, &fxnsPtr, memTab);
printf("Num. buffs requested = %d \n", n);
if (n <= 0)
errorNumber = -81;
printf("Num buffs requested is less than or equal to zero!\n");
return (NULL);
//errorNumber = 90;
if (n > SIUVCT_MAX_NUM_ALG_BUFFS)
printf(
"Num buffs requested (%d) is greater than number of supported buffers (%d)!\n",
n, 40);
errorNumber = -82;
return (NULL);
printf(
"algAlloc req. Buffer %d: space = %d, attr = %d, size = %ld \n",
fflush(stdout);
if (!iVideo)
if (_ALG_allocMemory(memTab, n) != FALSE)
alg = (IALG_Handle) memTab[0].base;
alg->fxns = fxns;
if ((ret = fxns->algInit(alg, memTab, p, params)) == IALG_EOK)
return (alg);
printf("algInit() returned error! %d\n", ret);
fxns->algFree(alg, memTab);
_ALG_freeMemory(memTab, n);
else
errorNumber = -83;
printf("Could not allocate memory\n");
iVideo++;
return (NULL);
* ======== ALG_delete ========
Void
ALG_delete(IALG_Handle alg)
Int n;
IALG_Fxns *fxns;
char memTabMemory_local[SIUVCT_MAX_NUM_ALG_BUFFS * sizeof(IALG_MemRec)];
if ((alg != NULL) && (alg->fxns != NULL))
fxns = alg->fxns;
memTab = (IALG_MemRec *) memTabMemory_local;
if (memTab != NULL)
memTab[0].base = alg;
n = fxns->algFree(alg, memTab);
* ======== ALG_control ========
Int
ALG_control(IALG_Handle alg, IALG_Cmd cmd, IALG_Status *statusPtr)
if ((alg) && (alg->fxns->algControl))
return (alg->fxns->algControl(alg, cmd, statusPtr));
return (IALG_EFAIL);
/* nothing past this point */
i think _ALG_allocMemory have one pointer that is allocated again pInternalScratch Memory is initialized again,
if it has been initialized only once then if there is memory left in scratchMemory section then it work fine if not then it give error
not courrupt memory.
i dont if encoder and decoder can use same memory, i have an observation that 2 instance of encoder work on same memory but encoder and decoder dont work simunaneously
thanks
anshul
