Other Parts Discussed in Thread: OMAP3530
ISPCCDC_SYN_MODE : 0x204a0
ISPCCDC_COLPTN : 0x0
ISPCCDC_BLKCMP : 0x0
ISPCCDC_FPC : 0x0
ISPCCDC_FMTCFG : 0x4000
ISPCCDC_LSC_CONFIG : 0x6600
ISPCCDC_CLAMP : 0x10
ISPCCDC_PIX_LINES : 0x0
ISPCCDC_HD_VD_WID : 0x0
ISPCCDC_CFG : 0x0
ISPCCDC_REC656IF : 0x0
ISPCCDC_SDR_ADDR : 0x0
ISPCCDC_HSIZE_OFF : 0x480
ISPCCDC_SDOFST : 0x0
ISPCCDC_FMT_HORZ : 0x0
ISPCCDC_FMT_VERT : 0x0
ISPCCDC_VP_OUT : 0x0
root@cm-t3730:/#media-ctl -f '"OMAP3 ISP CCDC":1 [SGRBG10 4096x4096]'
Video bytespreline = 1280
Unable to handle kernel NULL pointer dereference at virtual address 00000000
pgd = ce4e0000
[00000000] *pgd=8e5af831, *pte=00000000, *ppte=00000000
Internal error: Oops: 17 [#1] PREEMPT
Modules linked in:
CPU: 0 Not tainted (3.0.68-cm-t3730 #242)
PC is at ccdc_set_stream+0x5a4/0xce8
LR is at 0x8
pc : [<c03902a8>] lr : [<00000008>] psr: 60000013
sp : ce91d8b0 ip : cf3c6a60 fp : 00000000
r10: 00000001 r9 : ce91d990 r8 : 00000001
r7 : cf3c66f8 r6 : cf3c0000 r5 : cf3c0000 r4 : 00000000
r3 : 00000000 r2 : cf365880 r1 : 00000000 r0 : 00000000
Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
Control: 10c5387d Table: 8e4e0019 DAC: 00000015
Process capturer_mmap (pid: 1103, stack limit = 0xce91c2f0)
Stack: (0xce91d8b0 to 0xce91e000)
d8a0: 00000000 00000020 00404000 00000000
d8c0: 08406000 00000000 00000000 60000093 00000000 00000000 ce91c000 60000093
d8e0: 00000000 00000000 ce91d990 cf3c6e6c 00000001 c009f370 00000001 00000080
d900: 00000000 c038676c 00000000 60000093 cf3c6e5c 00000000 cf3c6e5c 20000013
d920: cf3c6ef0 00000001 cf3c6e5c 20000013 cf3c6e5c cf3c66f8 cf3c0000 cf3c6e5c
d940: 00000000 00000001 ce91d990 cf3c0000 ce92e200 c03867f4 cf3c6e5c 00000001
d960: ce92e218 cf3c6ef0 cf3c6e5c c0386c3c cf3c6ef0 00000000 cf3c6b20 c038afbc
d980: 00000000 cf3c6ea4 00000022 00000000 00000001 00000000 00001000 00001000
d9a0: 0000300a 00000001 00000008 00000000 00000000 00000000 00000000 00000000
d9c0: 00000000 00000000 00000000 00000000 cf3c6b20 00050000 cea1f2c0 00000000
d9e0: 00000000 00000000 ce92e200 cf163200 00096000 c00639a0 00096000 00050000
da00: 00000000 ffffffff 000000d2 cea1f2c0 00000000 ce92e26c ce91c000 60000013
da20: c0389204 c06a67ac ce92e26c c04aa340 00000096 00000000 00000096 ce92e218
da40: ce92e26c cead8a80 d0bfa000 c0389204 ce91c000 60000013 c0388b9c c06a67ac
da60: ce92e26c c04aa340 00000000 04f27ac0 ce91de48 ce92e200 00000000 00000001
da80: ce4851c0 00000000 c04e1e44 00000000 cf3c6b20 c0374670 00000001 c009f370
daa0: 00000001 00000080 00000000 c02e6e5c 00000000 80000013 ce91dc64 ce91dc98
dac0: ce91dc44 0000001a 00000014 0000000e c068e068 80000013 ce91dc84 ce91db04
dae0: c068e068 ce91dcce ce91dc44 c068e054 ce91dc84 ce91dcce cc9ccc9c c02e6f3c
db00: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
db20: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000060
db40: 30018000 00010180 00000000 00000002 00000000 00000000 00000000 00000000
db60: ce91c000 60000113 00000002 00000000 ce91c000 c067a728 00000001 c009f370
db80: 00000001 0a0504d6 cea313e0 cf188540 000200da c00cab98 00000041 0000d1b7
dba0: 00000000 c00ccb70 00000041 00000040 64340000 00000003 00000000 00000000
dbc0: 000200da c06a4010 00000000 00000000 00000000 00000000 ce91c000 00000000
dbe0: 00000000 00000080 30018000 1a010180 ce91c000 00000002 00000000 00000000
dc00: ce91de3e 00000000 ce91c000 60000113 00000002 00000000 ce91c000 c067a728
dc20: 00000001 c009f370 00000001 0a05ffff cea313e0 cf188540 00000000 cea403f8
dc40: c068e068 00000000 00000000 cf349400 00000000 0700050a 00000000 ce91c000
dc60: 00000000 c0458350 ce91dcd8 ce91dcf8 00000001 c009f370 00000001 00000001
dc80: ce91dcf8 ce91dcd8 cf188540 cf188554 00340000 ce91dcd8 c069f61c cf349400
dca0: ffffff8f ce91de48 40045612 ce4851c0 00000000 ce92e200 00000001 00000000
dcc0: c0418c04 c009f370 00000001 c069db80 0000000a cf154040 00000000 00000003
dce0: 00000000 00000000 c0679648 ffff050a 0700050a 0000d008 fd010008 00000040
dd00: 80406000 00000006 cea03680 00000000 00000000 00000040 80406000 00000006
dd20: ce91c000 00000000 00000000 00000000 00000001 00000000 ce91c000 60000193
dd40: 00000000 00000000 00000001 cf35b51c 00000001 c009f370 00000001 00000080
dd60: 00000000 c0334b78 00000000 cf35b4c0 cf35b50c 00000000 cf35b50c 60000113
dd80: 00000060 cf35b4c0 cf35b50c 60000113 01000200 00000060 cf35b4c0 00000001
dda0: cf35b50c c04ac5c0 cf35b50c cf35b50c 60000113 c0334ba0 fb052018 00000001
ddc0: 00000010 cf35b5d0 0000012c c06a4100 ffff99c9 00000102 c06a4108 c03fb600
dde0: 00000000 ce91c000 cf09798c 00000001 0000000c 00000040 80406000 00000006
de00: c06b6cc8 00000000 00000000 c0074110 000000e1 00000000 00000000 40045612
de20: ce4851c0 00000000 bed33c68 00000000 ce91de48 c03732ec 00000001 c03736f4
de40: 00000001 00000000 00000001 00000001 00000000 00000000 00000000 00000000
de60: 00000000 00000000 00000000 00000000 00000000 00000000 00000001 00000000
de80: 00000000 00000000 00000000 00000080 00000000 c00e8be8 00000000 c06a67ac
dea0: 60000013 00000000 00000257 000001c2 ce4a8128 ce4a80f8 c06a67ac 00000000
dec0: 00000000 00000000 c00ea054 cf3c6b20 ce4851c0 40045612 bed33c68 ce4851c0
dee0: ce91c000 00000000 00011ca8 c03723e4 00000003 ce4851c0 bed33c68 00000003
df00: ce4851c0 c010df34 00000000 c010e230 00000000 c00ea808 ce4a8144 00000000
df20: ceacbbd8 60000013 00000000 00096000 ce91c000 ceacbbd8 00011ca8 c04abe40
df40: 00000001 00000000 c0278854 ce4a8144 ceacbbd8 60000013 ce4851c0 ce91c000
df60: 40522000 00000000 bed33c68 40045612 00000003 ce4851c0 ce91c000 00000000
df80: 00011ca8 c010e7e8 ceacbb80 00000000 bed33c68 40045612 00000003 00000036
dfa0: c00451e8 c0045040 bed33c68 40045612 00000003 40045612 bed33c68 bed33b74
dfc0: bed33c68 40045612 00000003 00000036 00000000 00009598 00000000 00011ca8
dfe0: 00000001 bed32fc0 000092d4 401cc1cc 60000010 00000003 00000000 00000000
[<c03902a8>] (ccdc_set_stream+0x5a4/0xce8) from [<c03867f4>] (isp_pipeline_enable+0xa0/0x1ac)
[<c03867f4>] (isp_pipeline_enable+0xa0/0x1ac) from [<c0386c3c>] (omap3isp_pipeline_set_stream+0x28/0x34)
[<c0386c3c>] (omap3isp_pipeline_set_stream+0x28/0x34) from [<c038afbc>] (isp_video_streamon+0x460/0x4cc)
[<c038afbc>] (isp_video_streamon+0x460/0x4cc) from [<c0374670>] (__video_do_ioctl+0xf7c/0x643c)
[<c0374670>] (__video_do_ioctl+0xf7c/0x643c) from [<c03732ec>] (video_usercopy+0x12c/0x4c8)
[<c03732ec>] (video_usercopy+0x12c/0x4c8) from [<c03723e4>] (v4l2_ioctl+0x74/0x128)
[<c03723e4>] (v4l2_ioctl+0x74/0x128) from [<c010df34>] (vfs_ioctl+0x30/0x44)
[<c010df34>] (vfs_ioctl+0x30/0x44) from [<c010e230>] (do_vfs_ioctl+0x6c/0x5b0)
[<c010e230>] (do_vfs_ioctl+0x6c/0x5b0) from [<c010e7e8>] (sys_ioctl+0x74/0x7c)
[<c010e7e8>] (sys_ioctl+0x74/0x7c) from [<c0045040>] (ret_fast_syscall+0x0/0x30)
Code: e5832054 ebff859a e597341c e1a01000 (e5900000)
cm-t3730 Intern---[ end trace 7b69f96205090b06 ]---
cm-t3730 Process capturer_mmap (pid: 1103, stack limit = 0xce91c2f0)
cm-t3730 Stack: (0xce91d8b0 to 0xce91e000)
cm-t3730 d8a0: 00000000 00000020 00404000 00000000
cm-t3730 d8c0: 08406000 00000000 00000000 60000093 00000000 00000000 ce91c000 60000093
cm-t3730 d8e0: 00000000 00000000 ce91d990 cf3c6e6c 00000001 c009f370 00000001 00000080
cm-t3730 d900: 00000000 c038676c 00000000 60000093 cf3c6e5c 00000000 cf3c6e5c 20000013
cm-t3730 d920: cf3c6ef0 00000001 cf3c6e5c 20000013 cf3c6e5c cf3c66f8 cf3c0000 cf3c6e5c
cm-t3730 d940: 00000000 00000001 ce91d990 cf3c0000 ce92e200 c03867f4 cf3c6e5c 00000001
cm-t3730 d960: ce92e218 cf3c6ef0 cf3c6e5c c0386c3c cf3c6ef0 00000000 cf3c6b20 c038afbc
cm-t3730 d980: 00000000 cf3c6ea4 00000022 00000000 00000001 00000000 00001000 00001000
cm-t3730 d9a0: 0000300a 00000001 00000008 00000000 00000000 00000000 00000000 00000000
cm-t3730 d9c0: 00000000 00000000 00000000 00000000 cf3c6b20 00050000 cea1f2c0 00000000
cm-t3730 d9e0: 00000000 00000000 ce92e200 cf163200 00096000 c00639a0 00096000 00050000
cm-t3730 da00: 00000000 ffffffff 000000d2 cea1f2c0 00000000 ce92e26c ce91c000 60000013
cm-t3730 da20: c0389204 c06a67ac ce92e26c c04aa340 00000096 00000000 00000096 ce92e218
cm-t3730 da40: ce92e26c cead8a80 d0bfa000 c0389204 ce91c000 60000013 c0388b9c c06a67ac
cm-t3730 da60: ce92e26c c04aa340 00000000 04f27ac0 ce91de48 ce92e200 00000000 00000001
cm-t3730 da80: ce4851c0 00000000 c04e1e44 00000000 cf3c6b20 c0374670 00000001 c009f370
cm-t3730 daa0: 00000001 00000080 00000000 c02e6e5c 00000000 80000013 ce91dc64 ce91dc98
cm-t3730 dac0: ce91dc44 0000001a 00000014 0000000e c068e068 80000013 ce91dc84 ce91db04
cm-t3730 dae0: c068e068 ce91dcce ce91dc44 c068e054 ce91dc84 ce91dcce cc9ccc9c c02e6f3c
cm-t3730 db00: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
cm-t3730 db20: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000060
cm-t3730 db40: 30018000 00010180 00000000 00000002 00000000 00000000 00000000 00000000
cm-t3730 db60: ce91c000 60000113 00000002 00000000 ce91c000 c067a728 00000001 c009f370
cm-t3730 db80: 00000001 0a0504d6 cea313e0 cf188540 000200da c00cab98 00000041 0000d1b7
cm-t3730 dba0: 00000000 c00ccb70 00000041 00000040 64340000 00000003 00000000 00000000
cm-t3730 dbc0: 000200da c06a4010 00000000 00000000 00000000 00000000 ce91c000 00000000
cm-t3730 dbe0: 00000000 00000080 30018000 1a010180 ce91c000 00000002 00000000 00000000
cm-t3730 dc00: ce91de3e 00000000 ce91c000 60000113 00000002 00000000 ce91c000 c067a728
cm-t3730 dc20: 00000001 c009f370 00000001 0a05ffff cea313e0 cf188540 00000000 cea403f8
cm-t3730 dc40: c068e068 00000000 00000000 cf349400 00000000 0700050a 00000000 ce91c000
cm-t3730 dc60: 00000000 c0458350 ce91dcd8 ce91dcf8 00000001 c009f370 00000001 00000001
cm-t3730 dc80: ce91dcf8 ce91dcd8 cf188540 cf188554 00340000 ce91dcd8 c069f61c cf349400
cm-t3730 dca0: ffffff8f ce91de48 40045612 ce4851c0 00000000 ce92e200 00000001 00000000
cm-t3730 dcc0: c0418c04 c009f370 00000001 c069db80 0000000a cf154040 00000000 00000003
cm-t3730 dce0: 00000000 00000000 c0679648 ffff050a 0700050a 0000d008 fd010008 00000040
cm-t3730 dd00: 80406000 00000006 cea03680 00000000 00000000 00000040 80406000 00000006
cm-t3730 dd20: ce91c000 00000000 00000000 00000000 00000001 00000000 ce91c000 60000193
cm-t3730 dd40: 00000000 00000000 00000001 cf35b51c 00000001 c009f370 00000001 00000080
cm-t3730 dd60: 00000000 c0334b78 00000000 cf35b4c0 cf35b50c 00000000 cf35b50c 60000113
cm-t3730 dd80: 00000060 cf35b4c0 cf35b50c 60000113 01000200 00000060 cf35b4c0 00000001
cm-t3730 dda0: cf35b50c c04ac5c0 cf35b50c cf35b50c 60000113 c0334ba0 fb052018 00000001
cm-t3730 ddc0: 00000010 cf35b5d0 0000012c c06a4100 ffff99c9 00000102 c06a4108 c03fb600
cm-t3730 dde0: 00000000 ce91c000 cf09798c 00000001 0000000c 00000040 80406000 00000006
cm-t3730 de00: c06b6cc8 00000000 00000000 c0074110 000000e1 00000000 00000000 40045612
cm-t3730 de20: ce4851c0 00000000 bed33c68 00000000 ce91de48 c03732ec 00000001 c03736f4
cm-t3730 de40: 00000001 00000000 00000001 00000001 00000000 00000000 00000000 00000000
cm-t3730 de60: 00000000 00000000 00000000 00000000 00000000 00000000 00000001 00000000
cm-t3730 de80: 00000000 00000000 00000000 00000080 00000000 c00e8be8 00000000 c06a67ac
cm-t3730 dea0: 60000013 00000000 00000257 000001c2 ce4a8128 ce4a80f8 c06a67ac 00000000
cm-t3730 dec0: 00000000 00000000 c00ea054 cf3c6b20 ce4851c0 40045612 bed33c68 ce4851c0
cm-t3730 dee0: ce91c000 00000000 00011ca8 c03723e4 00000003 ce4851c0 bed33c68 00000003
cm-t3730 df00: ce4851c0 c010df34 00000000 c010e230 00000000 c00ea808 ce4a8144 00000000
cm-t3730 df20: ceacbbd8 60000013 00000000 00096000 ce91c000 ceacbbd8 00011ca8 c04abe40
cm-t3730 df40: 00000001 00000000 c0278854 ce4a8144 ceacbbd8 60000013 ce4851c0 ce91c000
cm-t3730 df60: 40522000 00000000 bed33c68 40045612 00000003 ce4851c0 ce91c000 00000000
cm-t3730 df80: 00011ca8 c010e7e8 ceacbb80 00000000 bed33c68 40045612 00000003 00000036
cm-t3730 dfa0: c00451e8 c0045040 bed33c68 40045612 00000003 40045612 bed33c68 bed33b74
cm-t3730 dfc0: bed33c68 40045612 00000003 00000036 00000000 00009598 00000000 00011ca8
cm-t3730 dfe0: 00000001 bed32fc0 000092d4 401cc1cc 60000010 00000003 00000000 00000000
cm-t3730 Code: e5832054 ebff859a e597341c e1a01000 (e5900000)
