where is dsplink logs?
Other Parts Discussed in Thread: OMAPL138
HI,
    I am using omapl138 and TI DVSDK 4.3.0.6.
 I have changed "CFG_OMAPL138SHMEM.c" in folder  " ${DSPLINK}/config/all "  as below
STATIC LINKCFG_Log  LINKCFG_logObject = {
    TRUE,             /* GDMSGQPUT         : GPP->DSP MSG Transfer  -
MSGQ_put call */
    TRUE,             /* GDMSGQSENDINT     : GPP->DSP MSG Transfer  - GPP
sends interrupt */
    TRUE,             /* GDMSGQISR         : GPP->DSP MSG Transfer  - DSP
receives interrupt */
    TRUE,             /* GDMSGQQUE         : GPP->DSP MSG Transfer  -
Message queued at DSP */
    TRUE,             /* DGMSGQPUT         : DSP->GPP MSG Transfer  -
MSGQ_put call */
    TRUE,             /* DGMSGQSENDINT     : DSP->GPP MSG Transfer  - DSP
sends interrupt */
    TRUE,             /* DGMSGQISR         : DSP->GPP MSG Transfer  - GPP
    TRUE,             /* DGMSGQQUE         : DSP->GPP MSG Transfer  -
Message queued at GPP */
    FALSE,             /* GDCHNLISSUESTART  : GPP->DSP CHNL Transfer -
Entering inside ISSUE call */
    FALSE,             /* GDCHNLISSUEQUE    : GPP->DSP CHNL Transfer -
ISSUE: Buffer is queued in internal structure on GPP */
    FALSE,             /* GDCHNLISSUECOMPL  : GPP->DSP CHNL Transfer -
ISSUE call completed */
    FALSE,             /* GDCHNLXFERSTART   : GPP->DSP CHNL Transfer -
Initiating a buffer transfer by GPP */
    FALSE,             /* GDCHNLXFERPROCESS : GPP->DSP CHNL Transfer -
Actual transfer of buffer is going to take place */
    FALSE,             /* GDCHNLXFERCOMPL   : GPP->DSP CHNL Transfer -
Buffer transfer is complete */
    FALSE,             /* GDCHNLRECLSTART   : GPP->DSP CHNL Transfer -
Entering RECLAIM call */
    FALSE,             /* GDCHNLRECLPEND    : GPP->DSP CHNL Transfer -
RECLAIM: Wait on a semaphore */
    FALSE,             /* GDCHNLRECLPOST    : GPP->DSP CHNL Transfer -
RECLAIM: Posting the Semaphore */
    FALSE,             /* GDCHNLRECLCOMPL   : GPP->DSP CHNL Transfer -
RECLAIM call completed */
    FALSE,             /* DGCHNLISSUEQUE    : DSP->GPP CHNL Transfer -
ISSUE: Buffer is queued in internal structure on DSP */
    FALSE,             /* DGCHNLXFERSTART   : DSP->GPP CHNL Transfer -
Initiating a buffer transfer by DSP */
    FALSE,             /* DGCHNLXFERPROCESS : DSP->GPP CHNL Transfer -
    FALSE,             /* DGCHNLXFERCOMPL   : DSP->GPP CHNL Transfer -
    FALSE,             /* DGCHNLRECLPEND    : DSP->GPP CHNL Transfer -
    FALSE,             /* DGCHNLRECLPOST    : DSP->GPP CHNL Transfer -
    10,                /* MSGIDRANGESTART   : MSG ID range: lower limit */
    20                 /* MSGIDRANGEEND     : MSG ID range: upper limit */
what is this LINKCFG_logObject?
what happen when i change from FALSE to TRUE?
Where can i get information about it?
