FAXLIB, "Network jitter buffer overflow"
Hello guys,
    When i use fiu component to receive fax emails, it warns "Network jitter buffer overflow" and "Loss of data: number of lost packets", details as follows :
[DSP] X(+43770ms)GW:FIU~ Loss of data: number of lost packets = 5
[DSP] X(+43770ms)GW2:FIU~ iffax_FP_FM_DATA numBytes: 36 data[0]: 223
[DSP] X(+43770ms)GW2:FIU~ iffax_FP_FM_DATA numBytes: 36 data[0]: 255
[DSP] X(+43770ms)GW2:FIU~ iffax_FP_FM_DATA numBytes: 36 data[0]: 168
[DSP] X(+43770ms)GW2:FIU~ iffax_FP_FM_DATA numBytes: 36 data[0]: 164
[DSP] X(+45629ms)GW1:FIU~ iffax_FP_FM_DATA numBytes: 36 data[0]: 23
[DSP] X(+45629ms)GW1:FIU~ iffax_FP_FM_DATA numBytes: 36 data[0]: 125
[DSP] X(+45630ms)GW:FIU~ Loss of data: number of lost packets = 38
[DSP] X(+45630ms)GW:FIU~ Network jitter buffer overflow
[DSP] Chan 1 Maximum depth of the jitter buffer: 50.
[DSP] Chan 1 Maximum depth of the network Rx queue: 40.
[DSP] Chan 1 Number of jitter buffer overflows (lost data): 8.
[DSP] Chan 1 Number of NetRxQ overflows: 0.
[DSP] Chan 1 Number of invalid packets received: 0.
[DSP] Chan 1 Number of packets dropped due to out-of-sequence: 0.
[DSP] Chan 1 Total number of packets sent to the network: 119.
[DSP] Chan 1 Number of FAX packets dropped due to busy network interface: 0.
[DSP] Chan 1 Total number of packets received from the network: 578.
[DSP] Chan 1 Number of lost packets: 363.
[DSP] Chan 1 Most recent high-speed modulation: 12.
[DSP] Chan 1 Number of complete pages transfered: 0.
[DSP] Chan 1 If ECM was used: 0.
[DSP] Chan 1 Maximum depth of sendIn queue: 1.
[DSP] Chan 1 Maximum depth of receiveIn queue: 0.
[DSP] Chan 1 Maximum usage of high-speed buffers: 53.
[DSP] Chan 1 Number of sendIn queue overflows: 0.
[DSP] Chan 1 Number of receiveOut queue overflows: 0.
[DSP] Chan 1 Whether local FTE is ORG or DEST: 1.
[DSP] Chan 1 Received NSF data: 65535 65535.
[DSP] Chan 1 Packet bytes received from the network: 69931.
[DSP] Chan 1 Packet bytes sent toward the network: 1810.
[DSP] Chan 1 Call compltetion information: 0.
[DSP] X(+45630ms)GW:FIU~ FIU is closed
[DSP] X(+45178ms)GW:FIU~ Loss of data: number of lost packets = 8
[DSP] X(+45178ms)GW2:FIU~ iffax_FP_FM_DATA numBytes: 36 data[0]: 65
[DSP] X(+45178ms)GW2:FIU~ iffax_FP_FM_DATA numBytes: 36 data[0]: 255
[DSP] X(+45178ms)GW2:FIU~ iffax_FP_FM_DATA numBytes: 36 data[0]: 112
[DSP] X(+45178ms)GW2:FIU~ iffax_FP_FM_DATA numBytes: 36 data[0]: 242
[DSP] Chan 2 Maximum depth of the jitter buffer: 37.
[DSP] Chan 2 Maximum depth of the network Rx queue: 22.
[DSP] Chan 2 Number of jitter buffer overflows (lost data): 0.
[DSP] Chan 2 Number of NetRxQ overflows: 0.
[DSP] Chan 2 Number of invalid packets received: 0.
[DSP] Chan 2 Number of packets dropped due to out-of-sequence: 0.
[DSP] Chan 2 Total number of packets sent to the network: 119.
[DSP] Chan 2 Number of FAX packets dropped due to busy network interface: 0.
[DSP] Chan 2 Total number of packets received from the network: 531.
[DSP] Chan 2 Number of lost packets: 261.
[DSP] Chan 2 Most recent high-speed modulation: 12.
[DSP] Chan 2 Number of complete pages transfered: 0.
[DSP] Chan 2 If ECM was used: 0.
[DSP] Chan 2 Maximum depth of sendIn queue: 1.
[DSP] Chan 2 Maximum depth of receiveIn queue: 0.
[DSP] Chan 2 Maximum usage of high-speed buffers: 45.
[DSP] Chan 2 Number of sendIn queue overflows: 0.
[DSP] Chan 2 Number of receiveOut queue overflows: 0.
[DSP] Chan 2 Whether local FTE is ORG or DEST: 1.
[DSP] Chan 2 Received NSF data: 65535 65535.
[DSP] Chan 2 Packet bytes received from the network: 64103.
[DSP] Chan 2 Packet bytes sent toward the network: 1810.
[DSP] Chan 2 Call compltetion information: 0.
[DSP] X(+45178ms)GW:FIU~ FIU is closed
It confused me. Can you tell me why?
Buga
