No video output on DM385-AR0331 (IPNC EVM)
Other Parts Discussed in Thread: DM385, TPS65910, TVP5158
I'm using DM385-AR0331 (IPNC EVM) and trying to follow IPNC_RDK_InstallGuide.pdf using pre-built images with 3.2.0 and 3.5.0.
I confirmed there is Video output on HDMI and CVBS using Color bar test. But, I can't get video using Streaming Demo on Web Browser. Already asked to Appro, but they couldn't find any issue with below log. If there is no issue on below log, please let me know how to check video pass in detail.
Please help to check what is problem on below log for download pre-built image (Full Feature) and boot using IPNC_RDK 3.2.0.
Please also check the attached log with pre-built image (Low Power) using IPNC_RDK 3.2.0. The result is same with Full Feature mode.
7418.IPNC_RDK_3.2.0_Low Power_No video output on PC.txt
DM385_IPNC#mw.b 0x81000000 0xff 0x20000
DM385_IPNC#tftp 0x81000000 u-boot.min.nand
phy info reg 0x1e addr 0 val 2
phy info reg 0x1e addr 0 val a
Auto negotitation failed
*** ERROR: `serverip' not set
DM385_IPNC#dhcp
BOOTP broadcast 1
BOOTP broadcast 2
link up on port 0, speed 1000, full duplex
BOOTP broadcast 3
DHCP client bound to address 192.168.10.113
Using cpsw device
TFTP from server 192.168.10.15; our IP address is 192.168.10.113
Filename 'u-boot.min.nand'.
Load address: 0x81000000
Loading: *##################
done
Bytes transferred = 91916 (1670c hex)
DM385_IPNC#nand erase 0x0 0x20000
NAND erase: device 0 offset 0x0, size 0x20000
Erasing at 0x0 -- 100% complete.
OK
DM385_IPNC#nand write.i 0x81000000 0x0 0x20000
NAND write: device 0 offset 0x0, size 0x20000
131072 bytes written: OK
DM385_IPNC#mw.b 0x81000000 0xFF 0x40000
DM385_IPNC#tftp 0x81000000 u-boot.bin
Using cpsw device
Filename 'u-boot.bin'.
Loading: *link up on port 0, speed 1000, full duplex
T ########################################
done
Bytes transferred = 201668 (313c4 hex)
Using cpsw device
Loading: *T link up on port 0, speed 1000, full duplex
done
DM385_IPNC#nand erase 0x20000 0x60000
NAND erase: device 0 offset 0x20000, size 0x60000
Erasing at 0x20000 -- 33% complete.Erasing at 0x40000 -- 66% complete.Erasing at 0x60000 -- 100% complete.
OK
DM385_IPNC#nand write.i 0x81000000 0x20000 0x60000
NAND write: device 0 offset 0x20000, size 0x60000
393216 bytes written: OK
DM385_IPNC#tftp 0x81000000 uImage
Using cpsw device
Filename 'uImage'.
T #################################################################
done
Bytes transferred = 2350764 (23deac hex)
DM385_IPNC#nand erase 0x00280000 0x00300000
NAND erase: device 0 offset 0x280000, size 0x300000
Erasing at 0x280000 -- 4% complete.Erasing at 0x2a0000 -- 8% complete.Erasing at 0x2c0000 -- 12% complete.Erasing at 0x2e0000 -- 16% complete.Erasing at 0x300000 -- 20% complete.Erasing at 0x320000 -- 25% complete.Erasing at 0x340000 -- 29% complete.Erasing at 0x360000 -- 33% complete.Erasing at 0x380000 -- 37% complete.Erasing at 0x3a0000 -- 41% complete.Erasing at 0x3c0000 -- 45% complete.Erasing at 0x3e0000 -- 50% complete.Erasing at 0x400000 -- 54% complete.Erasing at 0x420000 -- 58% complete.Erasing at 0x440000 -- 62% complete.Erasing at 0x460000 -- 66% complete.Erasing at 0x480000 -- 70% complete.Erasing at 0x4a0000 -- 75% complete.Erasing at 0x4c0000 -- 79% complete.Erasing at 0x4e0000 -- 83% complete.Erasing at 0x500000 -- 87% complete.Erasing at 0x520000 -- 91% complete.Erasing at 0x540000 -- 95% complete.Erasing at 0x560000 -- 100% complete.
OK
DM385_IPNC#nand write.i 0x81000000 0x00280000 0x300000
NAND write: device 0 offset 0x280000, size 0x300000
3145728 bytes written: OK
DM385_IPNC#nand scrub 0x006C0000 0xB940000
NAND scrub: device 0 offset 0x6c0000, size 0xb940000
Warning: scrub option will erase all factory set bad blocks!
There is no reliable way to recover them.
Use this command only for testing purposes if you
are sure of what you are doing!
Really scrub this NAND flash? <y/N>
yErasing at 0x6c0000 -- 0% complete.Erasing at 0x880000 -- 1% complete.Erasing at 0xa60000 -- 2% complete.Erasing at 0xc40000 -- 3% complete.Erasing at 0xe20000 -- 4% complete.Erasing at 0x1000000 -- 5% complete.Erasing at 0x11c0000 -- 6% complete.Erasing at 0x13a0000 -- 7% complete.Erasing at 0x1580000 -- 8% complete.Erasing at 0x1760000 -- 9% complete.Erasing at 0x1940000 -- 10% complete.Erasing at 0x1b20000 -- 11% complete.Erasing at 0x1ce0000 -- 12% complete.Erasing at 0x1ec0000 -- 13% complete.Erasing at 0x20a0000 -- 14% complete.Erasing at 0x2280000 -- 15% complete.Erasing at 0x2460000 -- 16% complete.Erasing at 0x2620000 -- 17% complete.Erasing at 0x2800000 -- 18% complete.Erasing at 0x29e0000 -- 19% complete.Erasing at 0x2bc0000 -- 20% complete.Erasing at 0x2da0000 -- 21% complete.Erasing at 0x2f80000 -- 22% complete.Erasing at 0x3140000 -- 23% complete.Erasing at 0x3320000 -- 24% complete.Erasing at 0x3500000 -- 25% complete.Erasing at 0x36e0000 -- 26% complete.Erasing at 0x38c0000 -- 27% complete.Erasing at 0x3a80000 -- 28% complete.Erasing at 0x3c60000 -- 29% complete.Erasing at 0x3e40000 -- 30% complete.Erasing at 0x4020000 -- 31% complete.Erasing at 0x4200000 -- 32% complete.Erasing at 0x43e0000 -- 33% complete.Erasing at 0x45a0000 -- 34% complete.Erasing at 0x4780000 -- 35% complete.Erasing at 0x4960000 -- 36% complete.Erasing at 0x4b40000 -- 37% complete.Erasing at 0x4d20000 -- 38% complete.Erasing at 0x4ee0000 -- 39% complete.Erasing at 0x50c0000 -- 40% complete.Erasing at 0x52a0000 -- 41% complete.Erasing at 0x5480000 -- 42% complete.Erasing at 0x5660000 -- 43% complete.Erasing at 0x5840000 -- 44% complete.Erasing at 0x5a00000 -- 45% complete.Erasing at 0x5be0000 -- 46% complete.Erasing at 0x5dc0000 -- 47% complete.Erasing at 0x5fa0000 -- 48% complete.Erasing at 0x6180000 -- 49% complete.Erasing at 0x6340000 -- 50% complete.Erasing at 0x6520000 -- 51% complete.Erasing at 0x6700000 -- 52% complete.Erasing at 0x68e0000 -- 53% complete.Erasing at 0x6ac0000 -- 54% complete.Erasing at 0x6ca0000 -- 55% complete.Erasing at 0x6e60000 -- 56% complete.Erasing at 0x7040000 -- 57% complete.Erasing at 0x7220000 -- 58% complete.Erasing at 0x7400000 -- 59% complete.Erasing at 0x75e0000 -- 60% complete.Erasing at 0x77c0000 -- 61% complete.Erasing at 0x7980000 -- 62% complete.Erasing at 0x7b60000 -- 63% complete.Erasing at 0x7d40000 -- 64% complete.Erasing at 0x7f20000 -- 65% complete.Erasing at 0x8100000 -- 66% complete.Erasing at 0x82c0000 -- 67% complete.Erasing at 0x84a0000 -- 68% complete.Erasing at 0x8680000 -- 69% complete.Erasing at 0x8860000 -- 70% complete.Erasing at 0x8a40000 -- 71% complete.Erasing at 0x8c20000 -- 72% complete.Erasing at 0x8de0000 -- 73% complete.Erasing at 0x8fc0000 -- 74% complete.Erasing at 0x91a0000 -- 75% complete.Erasing at 0x9380000 -- 76% complete.Erasing at 0x9560000 -- 77% complete.Erasing at 0x9720000 -- 78% complete.Erasing at 0x9900000 -- 79% complete.Erasing at 0x9ae0000 -- 80% complete.Erasing at 0x9cc0000 -- 81% complete.Erasing at 0x9ea0000 -- 82% complete.Erasing at 0xa080000 -- 83% complete.Erasing at 0xa240000 -- 84% complete.Erasing at 0xa420000 -- 85% complete.Erasing at 0xa600000 -- 86% complete.Erasing at 0xa7e0000 -- 87% complete.Erasing at 0xa9c0000 -- 88% complete.Erasing at 0xab80000 -- 89% complete.Erasing at 0xad60000 -- 90% complete.Erasing at 0xaf40000 -- 91% complete.Erasing at 0xb120000 -- 92% complete.Erasing at 0xb300000 -- 93% complete.Erasing at 0xb4e0000 -- 94% complete.Erasing at 0xb6a0000 -- 95% complete.Erasing at 0xb880000 -- 96% complete.Erasing at 0xba60000 -- 97% complete.Erasing at 0xbc40000 -- 98% complete.Erasing at 0xbe20000 -- 99% complete.Erasing at 0xbfe0000 -- 100% complete.
OK
DM385_IPNC#mw.b 0x81000000 0xFF 0x5000000
DM385_IPNC#tftp 0x81000000 ubifs_ipnc_full_feature.bin
Using cpsw device
Filename 'ubifs_ipnc_full_feature.bin'.
32 MB received
done
Bytes transferred = 39059456 (2540000 hex)
DM385_IPNC#nand erase 0x006C0000 0xB940000
NAND erase: device 0 offset 0x6c0000, size 0xb940000
OK
DM385_IPNC#nand write 0x81000000 0x006C0000 0x5000000
NAND write: device 0 offset 0x6c0000, size 0x5000000
83886080 bytes written: OK
DM385_IPNC#setenv bootcmd 'ipnc_ff_init 1;nboot 0x81000000 0 0x280000; bootm';saveenv
Saving Environment to NAND...
Erasing Nand...
Warning: Erase size 0x00002000 smaller than one erase block 0x00020000
Erasing 0x00020000 instead
Erasing at 0x260000 -- 100% complete.
Writing to Nand... done
DM385_IPNC#setenv bootargs 'console=ttyO0,115200n8 rootwait=1 rw ubi.mtd=4,2048 rootfstype=ubifs root=ubi0:rootfs init=/init mem=80M vram=4M notifyk.vpssm3_sva=0xBFD00000 ip=dhcp eth=00:0C:0C:02:39:A0 cmemk.phys_start=0x85000000 cmemk.phys_end=0x89000000 cmemk.allowOverlap=1 earlyprintk';saveenv
Erasing Nand...
DM385_IPNC#
U-Boot 2010.06 (Oct 09 2012 - 21:10:09) DM385_IPNC_3.20.00
DM385-GP rev 1.0
ARM clk: 600MHz
DDR clk: 533MHz
L3 clk: 200MHz
IVA clk: 450MHz
ISS clk: 400MHz
DSP Default OFF
DSS Default OFF
DRAM: 1 GiB
NAND: HW ECC BCH8 Selected
256 MiB
Using default environment
The 2nd stage U-Boot will now be auto-loaded
Please do not interrupt the countdown till DM385_IPNC prompt if 2nd stage is already flashed
Hit any key to stop autoboot: 2
DM385-GP rev 1.0
ARM clk: 600MHz
DDR clk: 533MHz
L3 clk: 200MHz
IVA clk: 450MHz
ISS clk: 400MHz
DSP Default OFF
DSS Default OFF
DRAM: 1 GiB
256 MiB
Hit any key to stop autoboot: 2 1 0
NAND read: device 0 offset 0x20000, size 0x40000
262144 bytes read: OK
## Starting application at 0x81000000 ...
U-Boot 2010.06 (Oct 09 2012 - 21:10:54) DM385_IPNC_3.20.00
DM385-GP rev 1.0
ARM clk: 600MHz
DDR clk: 533MHz
L3 clk: 200MHz
IVA clk: 450MHz
ISS clk: 400MHz
DSP Default OFF
DSS Default OFF
I2C: ready
DRAM: 1 GiB
256 MiB
MMC: OMAP SD/MMC: 0, ON-BOARD SDIO: 1
@@ @@@ @. @. @@@@ @@@@ G@@@@@@ @@
@@ @@@@@ L@@ @@@ @@@@@@ @@@@@i @@@@@@ @@
@@ @@ @@ @@@ @@@ @@@@ @@;@@: C@@@@@. @@
@@ @@ @@ @@@.l@L@ G@@@ ,@@@@ @@@ @@ @@
@@ @@ @@ l@ @@@@ @. l@@ @@ L@@ @ G@ @@
@@ @@ @@ @@ @@@@ @@ @@ C@ @@ @@ @@
@@ @@ ,@C @@ @@@ @@ @i @@ C@ @@ @@ @@ @@
@@ @@@@@@@ @@ @@ @@ @@@@@l @@@@@@ L@@@@@ @@
@@ @@@@@ @ @ @ L@@ @@@, ,@@G @@
Date: 2012-11-09 (Friday) Time: 19:36:02
Net: Ethernet clocking: 0x52
Detected MACID:38:34:3a:37:65:3a
cpsw
Hit any key to stop autoboot: 3 2 1 0
Loading from nand0, offset 0x280000
Image Name: Linux-2.6.37_DM385_IPNC_3.20.00
Created: 2012-10-09 15:51:21 UTC
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 2350700 Bytes = 2.2 MiB
Load Address: 80008000
Entry Point: 80008000
## Booting kernel from Legacy Image at 81000000 ...
Verifying Checksum ... OK
Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
Linux version 2.6.37_DM385_IPNC_3.20.00 (a0875405@bangvideoapps01) (gcc version 4.3.3 (Sourcery G++ Lite 2009q1-203) ) #1 Tue Oct 9 21:21:13 IST 2012
CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c53c7f
CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine: dm385ipnc
vram size = 4194304 at 0x0
bootconsole [earlycon0] enabled
ti81xx_reserve: ### Reserved DDR region @84f00000
reserved size = 4194304 at 0x0
FB: Reserving 4194304 bytes SDRAM for VRAM
Memory policy: ECC disabled, Data cache writeback
OMAP chip is DM385 1.0
SRAM: Mapped pa 0x402f1000 to va 0xfe400000 size: 0xf000
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 19040
Kernel command line: console=ttyO0,115200n8 rootwait=1 rw ubi.mtd=4,2048 rootfstype=ubifs root=ubi0:rootfs init=/init mem=80M vram=4M notifyk.vpssm3_sva=0xBFD00000 ip=dhcp eth=00:0C:0C:02:39:A0 cmemk.phys_start=0x85000000 cmemk.phys_end=0x89000000 cmemk.allowOverlap=1 earlyprintk
cpsw: kernel boot params Ethernet address: 00:0C:0C:02:39:A0
PID hash table entries: 512 (order: -1, 2048 bytes)
Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Memory: 74MB 1MB = 75MB total
Memory: 70952k/70952k available, 10968k reserved, 0K highmem
Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
DMA : 0xffc00000 - 0xffe00000 ( 2 MB)
vmalloc : 0xc5800000 - 0xf8000000 ( 808 MB)
lowmem : 0xc0000000 - 0xc5000000 ( 80 MB)
pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
.init : 0xc0008000 - 0xc003d000 ( 212 kB)
.text : 0xc003d000 - 0xc0478000 (4332 kB)
.data : 0xc0478000 - 0xc04b7080 ( 253 kB)
SLUB: Genslabs=11, HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
NR_IRQS:375
IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts
Total of 128 interrupts on 1 active controller
GPMC revision 6.0
Trying to install interrupt handler for IRQ368
Trying to install interrupt handler for IRQ369
Trying to install interrupt handler for IRQ370
Trying to install interrupt handler for IRQ371
Trying to install interrupt handler for IRQ372
Trying to install interrupt handler for IRQ373
Trying to install interrupt handler for IRQ374
Trying to install type control for IRQ375
Trying to set irq flags for IRQ375
OMAP clockevent source: GPTIMER1 at 20000000 Hz
Console: colour dummy device 80x30
Calibrating delay loop... 599.65 BogoMIPS (lpj=2998272)
pid_max: default: 32768 minimum: 301
Security Framework initialized
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
devtmpfs: initialized
TI81XX: Map 0x84f00000 to 0xfe500000 for dram barrier
TI81XX: Map 0x40300000 to 0xfe600000 for sram barrier
omap_voltage_early_init: voltage driver support not added
regulator: core version 0.5
regulator: dummy:
NET: Registered protocol family 16
omap_voltage_domain_lookup: Voltage driver init not yet happened.Faulting!
omap_voltage_add_dev: VDD specified does not exist!
OMAP GPIO hardware version 0.1
omap_mux_init: Add partition: #1: core, flags: 4
Cannot clk_get ck_32
Debugfs: Only enabling/disabling deep sleep and wakeup timer is supported now
registered ti81xx_vpss device
registered ti81xx_vidout device
registered ti81xx on-chip HDMI device
registered ti81xx_fb device
PWM0 init success.
PWM1 init success.
bio: create slab <bio-0> at 0
SCSI subsystem initialized
omap2_mcspi: probe of omap2_mcspi.3 failed with error -2
omap2_mcspi: probe of omap2_mcspi.4 failed with error -2
USBSS revision 4ea2080b
registerd cppi-dma Intr @ IRQ 17
Cppi41 Init Done
omap_i2c omap_i2c.1: bus 1 rev4.0 at 100 kHz
regulator: VRTC: 1800 mV
regulator: VIO: 1500 mV
regulator: VDD1: 600 <--> 1500 mV at 1150 mV
regulator: VDD2: 600 <--> 1500 mV at 1350 mV
regulator: VDDCTRL: 600 <--> 1400 mV at 1350 mV
regulator: LDO1: 1100 <--> 3300 mV at 1800 mV
regulator: LDO2: 1100 <--> 3300 mV at 1800 mV
regulator: LDO3: 1100 <--> 3300 mV at 3300 mV
regulator: LDO4: 1100 <--> 3300 mV at 1800 mV
regulator: LDO5: 1100 <--> 3300 mV at 3300 mV
regulator: LDO6: 1100 <--> 3300 mV at 3300 mV
regulator: LDO7: 1100 <--> 3300 mV at 3300 mV
regulator: LDO8: 1100 <--> 3300 mV at 1800 mV
tps65911-rtc tps65911-rtc: rtc core: registered tps65911-rtc as rtc0
tps65910 1-002d: No interrupt support, no core IRQ
Advanced Linux Sound Architecture Driver Version 1.0.23.
Switching to clocksource gp timer
musb-hdrc: version 6.0, peripheral, debug=0
musb-hdrc musb-hdrc.0: dma type: dma-cppi41
MUSB controller-0 revision 4ea20800
usb2phy: computed values rxcalib(15)DACs(33 15 17)
usb2phy: override computed values rxcalib(15)DACs(33 15 17)
usb2phy_config: musb(0) rxcalib done, rxcalib read value 6f70df8e
musb-hdrc musb-hdrc.0: USB Peripheral mode controller at c581e000 using DMA, IRQ 18
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 4096 (order: 3, 32768 bytes)
TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
TCP reno registered
UDP hash table entries: 256 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
NetWinder Floating Point Emulator V0.97 (double precision)
PMU: registered new PMU device of type 0
omap-iommu omap-iommu.0: ducati registered
omap-iommu omap-iommu.1: sys registered
JFFS2 version 2.2. (NAND) ⓒ 2001-2006 Red Hat, Inc.
msgmni has been set to 138
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
CMEMK module: built on Oct 9 2012 at 21:12:34
Reference Linux version 2.6.37
File /data/datalocal_videoapps01/user/kudva/DM812x/IPNetCam/ti_tools/linuxutils_3_22_00_02/packages/ti/sdo/linuxutils/cmem/src/module/cmemk.c
allocated heap buffer 0xc7000000 of size 0x4000000
cmemk initialized
Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
omap_uart.0: ttyO0 at MMIO 0x48020000 (irq = 72) is a OMAP UART0
console [ttyO0] enabled, bootconsole disabled
omap_uart.1: ttyO1 at MMIO 0x48022000 (irq = 73) is a OMAP UART1
omap_uart.2: ttyO2 at MMIO 0x48024000 (irq = 74) is a OMAP UART2
brd: module loaded
loop: module loaded
omap2-nand driver initializing
NAND device: Manufacturer ID: 0x2c, Chip ID: 0xba (Micron )
Creating 8 MTD partitions on "omap2-nand.0":
0x000000000000-0x000000020000 : "U-Boot-min"
0x000000020000-0x000000260000 : "U-Boot"
0x000000260000-0x000000280000 : "U-Boot Env"
0x000000280000-0x0000006c0000 : "Kernel"
0x0000006c0000-0x000006fc0000 : "File System"
0x000006fc0000-0x000007bc0000 : "Data"
0x000007bc0000-0x00000b0c0000 : "File System2"
0x00000b0c0000-0x000010000000 : "Reserved"
UBI: attaching mtd4 to ubi0
UBI: physical eraseblock size: 131072 bytes (128 KiB)
UBI: logical eraseblock size: 126976 bytes
UBI: smallest flash I/O unit: 2048
UBI: sub-page size: 512
UBI: VID header offset: 2048 (aligned 2048)
UBI: data offset: 4096
UBI: max. sequence number: 0
UBI: volume 0 ("rootfs") re-sized from 826 to 828 LEBs
UBI: attached mtd4 to ubi0
UBI: MTD device name: "File System"
UBI: MTD device size: 105 MiB
UBI: number of good PEBs: 840
UBI: number of bad PEBs: 0
UBI: number of corrupted PEBs: 0
UBI: max. allowed volumes: 128
UBI: wear-leveling threshold: 4096
UBI: number of internal volumes: 1
UBI: number of user volumes: 1
UBI: available PEBs: 0
UBI: total number of reserved PEBs: 840
UBI: number of PEBs reserved for bad PEB handling: 8
UBI: max/mean erase counter: 1/0
UBI: image sequence number: 649601052
UBI: background thread "ubi_bgt0d" started, PID 37
davinci_mdio davinci_mdio.0: davinci mdio revision 1.6
davinci_mdio davinci_mdio.0: detected phy mask fffffffe
davinci_mdio.0: probed
davinci_mdio davinci_mdio.0: phy[0]: device 0:00, driver unknown
mice: PS/2 mouse device common for all mice
i2c /dev entries driver
Linux video capture interface: v2.00
OMAP Watchdog Timer Rev 0x00: initial timeout 60 sec
notify_init : notify drivercreated for remote proc id 2 at physical Address 0xbfd00000
cm: Module associated with clock hdmi_i2s_fck didn't enable in 100000 tries
asoc: tlv320aic3x-hifi <-> davinci-mcasp.1 mapping ok
asoc: HDMI-DAI-CODEC <-> hdmi-dai mapping ok
ALSA device list:
#0: TI81XX EVM
TCP cubic registered
NET: Registered protocol family 17
Registering the dns_resolver key type
VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
omap_voltage_late_init: Voltage driver support not added
Power Management for TI81XX.
Detected MACID=0:c:c:2:39:a0
tps65911-rtc tps65911-rtc: setting system clock to 2012-11-09 19:36:11 UTC (1352489771)
CPSW phy found : id is : 0x4dd074
PHY 0:01 not found
Sending DHCP requests ..
PHY: 0:00 - Link is Up - 1000/Full
., OK
IP-Config: Got DHCP answer from 192.168.10.15, my address is 192.168.10.135
IP-Config: Complete:
device=eth0, addr=192.168.10.135, mask=255.255.255.0, gw=192.168.10.1,
host=192.168.10.135, domain=example.org, nis-domain=(none),
bootserver=192.168.10.15, rootserver=192.168.10.15, rootpath=
UBIFS: start fixing up free space
UBIFS: free space fixup complete
UBIFS: mounted UBI device 0, volume 0, name "rootfs"
UBIFS: file system size: 103612416 bytes (101184 KiB, 98 MiB, 816 LEBs)
UBIFS: journal size: 9023488 bytes (8812 KiB, 8 MiB, 72 LEBs)
UBIFS: media format: w4/r0 (latest is w4/r0)
UBIFS: default compressor: lzo
UBIFS: reserved for root: 0 bytes (0 KiB)
VFS: Mounted root (ubifs filesystem) on device 0:13.
devtmpfs: mounted
Freeing init memory: 212K
Failed to execute /init. Attempting defaults...
INIT: version 2.86 booting
Error opening /dev/fb0: No such file or directory
Please wait: booting...
Starting udev
udevd (76): /proc/76/oom_adj is deprecated, please use /proc/76/oom_score_adj instead.
udevd-event[106]: error changing netif name eth0 to eth13: Device or resource busy
Root filesystem already rw, not remounting
Caching udev devnodes
Populating dev cache
Configuring network interfaces... udhcpc (v1.13.2) started
Sending discover...
Sending select for 192.168.10.111...
Lease of 192.168.10.111 obtained, lease time 600
done.
Setting up IP spoofing protection: rp_filter.
rm: cannot remove '/tmp': Device or resource busy
inside finish.sh
UBI: attaching mtd5 to ubi1
UBI: empty MTD device detected
UBI: create volume table (copy #1)
UBI: create volume table (copy #2)
UBI: attached mtd5 to ubi1
UBI: MTD device name: "Data"
UBI: MTD device size: 12 MiB
UBI: number of good PEBs: 96
UBI: number of user volumes: 0
UBI: available PEBs: 90
UBI: total number of reserved PEBs: 6
UBI: number of PEBs reserved for bad PEB handling: 2
UBI: max/mean erase counter: 0/0
UBI: image sequence number: 778500090
UBI: background thread "ubi_bgt1d" started, PID 1070
UBI device number 1, total 96 LEBs (12189696 bytes, 11.6 MiB), available 90 LEBs (11427840 bytes, 10.9 MiB), LEB size 126976 bytes (124.0 KiB)
Set volume size to 11427840
Volume ID 0, size 90 LEBs (11427840 bytes, 10.9 MiB), LEB size 126976 bytes (124.0 KiB), dynamic, name "ubifs_volume", alignment 1
UBIFS: default file-system created
UBIFS: mounted UBI device 1, volume 0, name "ubifs_volume"
UBIFS: file system size: 10285056 bytes (10044 KiB, 9 MiB, 81 LEBs)
UBIFS: journal size: 1015809 bytes (992 KiB, 0 MiB, 6 LEBs)
UBIFS: reserved for root: 485787 bytes (474 KiB)
UBI: attaching mtd7 to ubi2
UBI: max. sequence number: 8
UBI: attached mtd7 to ubi2
UBI: MTD device name: "Reserved"
UBI: MTD device size: 79 MiB
UBI: number of good PEBs: 634
UBI: total number of reserved PEBs: 634
UBI: number of PEBs reserved for bad PEB handling: 6
UBI: max/mean erase counter: 2/0
UBI: image sequence number: 1755906874
UBI: background thread "ubi_bgt2d" started, PID 1089
UBI device number 2, total 634 LEBs (80502784 bytes, 76.8 MiB), available 0 LEBs (0 bytes), LEB size 126976 bytes (124.0 KiB)
UBIFS: recovery needed
UBIFS: recovery completed
UBIFS: mounted UBI device 2, volume 0, name "ubifs_volume"
UBIFS: file system size: 78090240 bytes (76260 KiB, 74 MiB, 615 LEBs)
UBIFS: journal size: 3936256 bytes (3844 KiB, 3 MiB, 31 LEBs)
UBIFS: reserved for root: 3688395 bytes (3601 KiB)
./init.sh: line 5: -f: not found
numid=1,iface=MIXER,name='PCM Playback Volume'
; type=INTEGER,access=rw---R--,values=2,min=0,max=127,step=0
: values=127,127
| dBscale-min=-63.50dB,step=0.50dB,mute=0
[c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[m3video] Remote Debug Shared Memory @ 0xbff05020
[m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
SysLink version : 2.10.07.31
SysLink module created on Date:Oct 9 2012 Time:21:22:11
Trace enabled
Trace SetFailureReason enabled
/dev/mem opened.
Phy Addr : 0x48181560 Data : 0x00000002
Unhandled fault: external abort on non-linefetch (0x1018) at 0x402da0e4
Phy Addr : 0x48180f10 Data : 0x00000000
Phy Addr : 0x48180508 Data : 0x00000302
Phy Addr : 0x48180520 Data : 0x00000002
Phy Addr : 0x48180524 Data : 0x00000002
Phy Addr : 0x48180528 Data : 0x00000002
Phy Addr : 0x4c0000e4 Data : 0x00170208
Bus error
Creat queue id:0
queue id:0
FileMngThread created
Creat queue id:32769
queue id:32769
AlramThread created
Share memory init success
[host] Setting DMM priority for [HDVICP0 ] to [1] ( 0x4e000634 = 0x00000009 )
[host] Setting DMM priority for [ISS ] to [0] ( 0x4e000634 = 0x00800000 )
Creat queue id:65538
queue id:65538
Creat queue id:98307
queue id:98307
[host] Setting L3 bandwidth regulator for [HDVICP0 ] to [press=[0,0] BW=900, WM Cycles=2500]
queue id:32769
Initialize IPNC Default Values
[host] Attached to slave procId 2.
[host] Attached to slave procId 1.
[host] Loaded file ./firmware/ipnc_rdk_fw_m3vpss.xem3 on slave procId 2.
[host] Started slave procId 2.
[host] After Ipc_loadcallback status [0x00000000]
[host] Loaded file ./firmware/ipnc_rdk_fw_m3video.xem3 on slave procId 1.
[host] Started slave procId 1.
[m3video] ***** SYSTEM : Frequency <ORG> - 200000000, <NEW> - 200000000
[m3vpss ] ***** SYSTEM : Frequency <ORG> - 200000000, <NEW> - 200000000
[m3video]
[m3vpss ] notify_attach rtnVal 0
[m3video] *** UTILS: CPU KHz = 400000 Khz ***
[m3video]
[m3video] 48: SYSTEM : System Common Init in progress !!!
[m3video] 49: SYSTEM: IPC init in progress !!!
[m3video] 49: SYSTEM: Attaching to [HOST] ...
[m3vpss ] initProxyServer rtnVal 0
[m3vpss ]
[m3vpss ] *** UTILS: CPU KHz = 400000 Khz ***
[m3vpss ]
[m3vpss ] 88: SYSTEM : System Common Init in progress !!!
[m3vpss ] 88: SYSTEM: IPC init in progress !!!
[m3vpss ] 88: SYSTEM: Attaching to [HOST] ...
[host] After Ipc_startcallback status [0x097d2000]
[m3video] 1048: SYSTEM: Attaching to [HOST] ...
[m3vpss ] 1088: SYSTEM: Attaching to [HOST] ...
[m3video] 1052: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
[m3vpss ] 1091: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
[m3video] 1052: SYSTEM: Attaching to [VPSS-M3] ...
[m3vpss ] 1091: SYSTEM: Attaching to [VIDEO-M3] ...
[m3video] 2051: SYSTEM: Attaching to [VPSS-M3] ...
[m3vpss ] 2091: SYSTEM: Attaching to [VIDEO-M3] ...
[m3video] 2092: SYSTEM: Attaching to [VPSS-M3] ... SUCCESS !!!
[m3vpss ] 2092: SYSTEM: Attaching to [VIDEO-M3] ... SUCCESS !!!
[m3video] 2092: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[m3vpss ] 2092: SYSTEM: Creating MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[m3vpss ] 2092: SYSTEM: Creating MsgQ [VPSS-M3_MSGQ] ...
[m3vpss ] 2092: SYSTEM: Creating MsgQ [VPSS-M3_ACK_MSGQ] ...
[m3vpss ] 2095: SYSTEM: Notify register to [HOST] line 0, event 12 ...
[m3vpss ] 2095: SYSTEM: Notify register to [VIDEO-M3] line 0, event 12 ...
[m3vpss ] 2095: SYSTEM: IPC init DONE !!!
[m3vpss ] Received character 's'
[m3vpss ] 2104: MEM: Shared Region 2: Base = 0xb8000000, Length = 0x06900000 (105 MB)
[m3vpss ] 2104: MEM: Shared Region 1: Base = 0x89000000, Length = 0x03c00000 (60 MB)
[m3vpss ] 2107: SYSTEM : System Common Init Done !!!
[m3video] 3092: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[m3video] 3093: SYSTEM: Creating MsgQ [VIDEO-M3_MSGQ] ...
[m3video] 3093: SYSTEM: Creating MsgQ [VIDEO-M3_ACK_MSGQ] ...
[m3video] 3095: SYSTEM: Notify register to [HOST] line 0, event 12 ...
[m3video] 3095: SYSTEM: Notify register to [VPSS-M3] line 0, event 12 ...
[m3video] 3095: SYSTEM: IPC init DONE !!!
[m3video] 3105: MEM: Shared Region 2: Base = 0xb8000000, Length = 0x06900000 (105 MB)
[m3video] 3105: MEM: Shared Region 1: Base = 0x89000000, Length = 0x03c00000 (60 MB)
[m3video] 3108: SYSTEM : System Common Init Done !!!
[m3video] Received character 's'
queue id:65538
Error: SemWait: Invalid Semaphore handler
Error: SemRelease: Invalid Semaphore handler
CPU is TI812x
IPNC BUILD VERSION: DM385 IPNC RDK VERSION 03.20.00.08
./bin/ipnc_rdk_mcfw.out TRISTREAM TRIPLE_H264 TI2A AEWB 1080P_D1 H264 HIGH_SPEED1 H264 HIGH_SPEED2 MJPEG 80 &
[m3vpss ] 3206: SYSTEM : System VPSS Init in progress !!!
[m3vpss ] === I2C0/2 Clk is active ===
[m3vpss ] 3225: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_0] in region 0 ...
[m3vpss ] 3225: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_0] in region 0 ...
[m3vpss ] 3225: SYSTEM: ListElem Shared Addr = 0xbe983e00
[m3vpss ] 3228: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_1] in region 0 ...
[m3vpss ] 3228: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_1] in region 0 ...
[m3vpss ] 3228: SYSTEM: ListElem Shared Addr = 0xbe986f00
[m3vpss ] 3243: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_23] in region 0 ...
[m3vpss ] 3243: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_23] in region 0 ...
[m3vpss ] 3243: SYSTEM: ListElem Shared Addr = 0xbe98a000
[m3vpss ] 3246: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_24] in region 0 ...
[m3vpss ] 3246: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_24] in region 0 ...
[m3vpss ] 3247: SYSTEM: ListElem Shared Addr = 0xbe9a9600
[m3vpss ] 3249: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_25] in region 0 ...
[m3vpss ] 3250: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_25] in region 0 ...
[m3vpss ] 3250: SYSTEM: ListElem Shared Addr = 0xbe9c8c00
[m3vpss ] 3257: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_28] in region 0 ...
[m3vpss ] 3257: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_28] in region 0 ...
[m3vpss ] 3257: SYSTEM: ListElem Shared Addr = 0xbe9e8200
[m3vpss ] 3260: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_29] in region 0 ...
[m3vpss ] 3260: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_29] in region 0 ...
[m3vpss ] 3261: SYSTEM: ListElem Shared Addr = 0xbea01a80
[m3vpss ] 3263: SYSTEM : HDVPSS Drivers Version: HDVPSS_01_00_01_37
[m3vpss ] 3263: SYSTEM : FVID2 Init in progress !!!
[m3video] 3307: SYSTEM : System Video Init in progress !!!
[m3video] 3307: SYSTEM : System Video Init Done !!!
[m3video] 3308: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_0] in region 0 ...
[m3video] 3308: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_0] in region 0 ...
[m3video] 3308: SYSTEM: ListElem Shared Addr = 0xbea1b300
[m3video] 3311: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_1] in region 0 ...
[m3video] 3311: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_1] in region 0 ...
[m3video] 3311: SYSTEM: ListElem Shared Addr = 0xbea1e400
[m3video] 3323: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_28] in region 0 ...
[m3vpss ] 3323: SYSTEM : FVID2 Init in progress DONE !!!
[m3video] 3323: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_28] in region 0 ...
[m3vpss ] 3323: SYSTEM : Device Init in progress !!!
[m3video] 3323: SYSTEM: ListElem Shared Addr = 0xbea21500
[m3vpss ] Iss_init called !!!!!!
[m3video] 3326: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_29] in region 0 ...
[m3vpss ] CPIS_init DONE !!!!!!
[m3video] 3326: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_29] in region 0 ...
[m3video] 3327: SYSTEM: ListElem Shared Addr = 0xbea3ad80
[m3vpss ] initPrms.isI2cInitReq = 1
[m3video] 3329: HDVICP: Doing PRCM for IVAHD[0] ...
[m3video] 3329: HDVICP: PRCM for IVAHD[0] ... DONE.
[m3video] 3330: SYSTEM : Initializing Links !!!
[m3video] 3330: SYSTEM : FREE SPACE : System Heap = 2089288 B, Mbx = 10240 msgs)
[m3video] 3396: SYSTEM : Initializing Links ... DONE !!!
[m3vpss ] 3439: SYSTEM : Device Init in progress DONE !!!
[m3vpss ] 3509: SYSTEM : System VPSS Init Done !!!
[m3vpss ] 3509: UTILS: DMA: HWI Create for INT62 !!!
[m3vpss ] 3509: SYSTEM : Initializing Links !!!
[m3vpss ] 3509: SYSTEM : FREE SPACE : System Heap = 868472 B, Mbx = 10240 msgs)
[m3vpss ] 3509: SYSTEM : FREE SPACE : SR0 Heap = 15383552 B (14 MB)
[m3vpss ] 3509: SYSTEM : FREE SPACE : Frame Buffer = 105790336 B (100 MB)
[m3vpss ] 3510: SYSTEM : FREE SPACE : Bitstream Buffer = 62914432 B (59 MB)
[m3vpss ] 3510: SYSTEM : FREE SPACE : Tiler Buffer = 127 B (0 MB) - TILER OFF
[m3vpss ] 3631: SYSTEM : Initializing Links ... DONE !!!
[m3vpss ] Received character 't'
[m3video] Received character 't'
DMA: Module install successful, device major num = 247
DRV: Module install successful
DRV: Module built on Oct 9 2012 21:38:41
HDMI W1 rev 4.0
HDMI CEC Spec version 1.2
I2C No Ack
[host]
[host] ORG 0x46c00524: 0
[host] NEW 0x46c00524: 2
[host]
[host] Application Start Completed
[host] Vsys_allocBuf - addr = 0x40c80000,size DMA: ChannelID allocated:4
= 65011712
DMA: ChannelID allocated:9
[host] MCFW_IPCBITS:App_streamSysInit:virt addr of 85000000 cir buffer is 40c80000
##########pInfo->totalsize 63963136
[host] MemMng_memcpy_open:OSA_dmaOpen passed with ch id = 4
[host] CacheMng_MemCpy_open:OSA_dmaOpen passed with ch id = 9
Creat queue id:131076
queue id:131076
queue id:65538
[host] MCFW_IPCBITS:App_ipcBitsRecvStreamFxn:Entered...
[host] MCFW_IPCFRAMES:App_ipcFramesSendRecvFxn:Entered...
[host] 0: SYSTEM: System Common Init in progress !!!
[host] 0: SYSTEM: IPC init in progress !!!
[host] 32: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[host] 35: SYSTEM: Creating MsgQ [HOST_MSGQ] ...
[host] 37: SYSTEM: Creating MsgQ [HOST_ACK_MSGQ] ...
[host] 39: SYSTEM: Opening MsgQ [VIDEO-M3_MSGQ] ...
[host] 40: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
[host] 41: SYSTEM: Notify register to [VIDEO-M3] line 0, event 12 ...
[host] 42: SYSTEM: Notify register to [VPSS-M3] line 0, event 12 ...
[host] 43: SYSTEM: IPC init DONE !!!
[host] 48: SYSTEM: Creating ListMP [HOST_IPC_OUT_28] in region 0 ...
[host] 51: SYSTEM: Creating ListMP [HOST_IPC_IN_28] in region 0 ...
[host] 53: SYSTEM: ListElem Shared Addr = 0x45d75600
[host] 54: SYSTEM: Creating ListMP [HOST_IPC_OUT_29] in region 0 ...
[host] 57: SYSTEM: Creating ListMP [HOST_IPC_IN_29] in region 0 ...
[host] 59: SYSTEM: ListElem Shared Addr = 0x45d8ee80
[host] 61: SYSTEM: Creating ListMP [HOST_IPC_OUT_23] in region 0 ...
[host] 63: SYSTEM: Creating ListMP [HOST_IPC_IN_23] in region 0 ...
[host] 65: SYSTEM: ListElem Shared Addr = 0x45da8700
[host] 67: SYSTEM: Creating ListMP [HOST_IPC_OUT_24] in region 0 ...
[host] 69: SYSTEM: Creating ListMP [HOST_IPC_IN_24] in region 0 ...
[host] 71: SYSTEM: ListElem Shared Addr = 0x45dc7d00
[host] 73: SYSTEM: Creating ListMP [HOST_IPC_OUT_25] in region 0 ...
[host] 76: SYSTEM: Creating ListMP [HOST_IPC_IN_25] in region 0 ...
[host] 78: SYSTEM: ListElem Shared Addr = 0x45de7300
[host] 78: SYSTEM: System Common Init Done !!!
[host]
********** FULL FEATURE USECASE ********
[host] ********* Entered Tri Streaming usecase - H264 1080p @60fps + H264 D1 @30fps + MJPEG 1080p @5fps ********
[host] 80: MCFW : CPU Revision [ES1.0] !!!
[host] 81: MCFW : Detected [4x TVP5158 VS] Board !!!
[host] 81: MCFW : Base Board Revision [REV A] !!!
[host] 81: MCFW : Daughter Card Revision [REV A] !!!
[m3vpss ] 4790: CAMERA: Create in progress !!!
[m3vpss ] 4791: CAMERA: VIP0 PortA camera mode is [ 8-bit, Non-mux Embedded Sync] !!!
[m3vpss ] 4791: CAMERA: VIP 0: VID DEC 268436737 (0x10): bebebebe:bebebebe:0002, AUD_STATUS -1901494832
[m3vpss ] Stream ID 0: chId = 0 VpsUtils_queCreate.
[m3vpss ] Stream ID 1: chId = 0 VpsUtils_queCreate.
[m3vpss ] 5051: CAMERA: Create Done !!!
[m3vpss ] 5162: CAMERA: Detect video in progress !!!
[m3vpss ] 5162: CAMERA: Detect video Done !!!
[m3vpss ] 5254: DUP : Create Done !!!
[m3vpss ] 5255: NSF: Create in progress !!!
[m3vpss ] NSF::HEAPID:0 USED:128
[m3vpss ] NSF::HEAPID:1 USED:4928
[m3vpss ] 5360: NSF: Create Done !!!
[m3vpss ] 5366: DUP : Create Done !!!
[m3vpss ] 5372: DUP : Create Done !!!
[m3vpss ] 5374: MERGE : Create Done !!!
[m3vpss ] {SWOSD} edma3Handle->tccVal = 34
[m3vpss ] {SWOSD} edma3Handle->chId = 34
[m3vpss ] {SWOSD} edma3Handle->tccVal = 35
[m3vpss ] {SWOSD} edma3Handle->chId = 35
[m3vpss ] {SWOSD} edma3Handle->tccVal = 36
[m3vpss ] {SWOSD} edma3Handle->chId = 36
[m3vpss ] 5349: SWOSD : Create Done !!!
[m3vpss ] DCC server task running
[m3vpss ] 5439: SCLR: Create in progress !!!
[m3vpss ] 5444: SCLR : Loading Up-scaling Co-effs ...
[m3vpss ] 5444: SCLR : Co-effs Loading ... DONE !!!
[m3video] 5451: IPC_IN_M3 : Create in progress !!!
[m3video] 5451: SYSTEM: Opening ListMP [VPSS-M3_IPC_OUT_0] ...
[m3vpss ] SCLR:HEAPID:0 USED:64
[m3video] 5452: SYSTEM: Opening ListMP [VPSS-M3_IPC_IN_0] ...
[m3vpss ] SCLR:HEAPID:1 USED:5952
[m3video] 5453: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
[m3vpss ] 5444: SCLR: Create Done !!!
[m3video] 5455: IPC_IN_M3 : Create Done !!!
[m3vpss ] 5363: FD : Alg Create Done !!!
[m3video] 5456: ENCODE: Create in progress ... !!!
[m3vpss ] 5363: FD : Create Done !!!
[m3vpss ] 5450: IPC_OUT_M3 : Create in progress !!!
[m3vpss ] 5451: IPC_OUT_M3 : Create Done !!!
[m3video] 5582: ENCODE: Creating CH0 of 1920 x 1080, pitch = (2048, 2048) [PROGRESSIVE] [NON-TILED ], bitrate = 2000 Kbps ...
[m3video] ENCLINK_H264:HEAPID:0 USED:13808
[m3video] 5689: ENCODE: Creating CH1 of 720 x 480, pitch = (720, 720) [PROGRESSIVE] [NON-TILED ], bitrate = 2000 Kbps ...
[host] IpcBitsInLink_tskMain:Entered
[host] 1077: IPC_BITS_IN : Create in progress !!!
[host] 1077: IPC_BITS_IN : ListMPOpen start !!!
[host] 1077: SYSTEM: Opening ListMP [VIDEO-M3_IPC_OUT_28] ...
[host] 1079: SYSTEM: Opening ListMP [VIDEO-M3_IPC_IN_28] ...
[host] 1081: IPC_BITS_IN : ListMPOpen done !!!
[host] 1084: IPC_BITS_IN : System_linkGetInfo done !!!
[host] 1084: IPC_BITS_IN : Create Done !!!
[host] USECASE SETUP DONE
[m3video] ENCLINK_H264:HEAPID:0 USED:11912
[m3vpss ] 5814: DISPLAY: Create in progress !!!
[m3video] 5796: ENCODE: Creating CH2 of 1920 x 1080, pitch = (2048, 2048) [PROGRESSIVE] [NON-TILED ], bitrate = 100 Kbps ...
[m3vpss ] 5815: DISPLAY: Create Done !!!
[m3vpss ] 5815: DISPLAY: Create in progress !!!
[m3vpss ] 5816: DISPLAY: Create Done !!!
[m3video] ENCLINK_JPEG:HEAPID:0 USED:2176
[m3vpss ] 5818: DISPLAY: Start in progress !!!
[m3video] 5797: ENCODE: All CH Create ... DONE !!!
[m3video] ENCLINK:HEAPID:0 USED:28056
[m3video] 5800: ENCODE: Create ... DONE !!!
[m3video] 5753: VSTAB : Alg Create Done !!!
[m3video] 5753: VSTAB : Create Done !!!
[m3video] 5801: IPC_BITS_OUT : Create in progress !!!
[m3video] 5804: IPC_BITS_OUT : Create Done !!!
[m3vpss ] 5877: DISPLAY: Start Done !!!
[m3vpss ] 5877: DISPLAY: HDDAC(BP0) : 33 fps, Latency (Min / Max) = ( 255 / 0 ), Callback Interval (Min / Max) = ( 255 / 0 ) !!!
[m3vpss ] 5877: DISPLAY: UNDERFLOW COUNT: HDMI(BP0) 1, HDDAC(BP0) 1, DVO2(BP1) 1, SDDAC(SEC1) 0
[m3vpss ] 5877: SYSTEM : FREE SPACE : System Heap = 357896 B, Mbx = 10237 msgs)
[m3vpss ] 5877: SYSTEM : FREE SPACE : SR0 Heap = 14788864 B (14 MB)
[m3vpss ] 5878: SYSTEM : FREE SPACE : Frame Buffer = 2326272 B (2 MB)
[m3vpss ] 5878: SYSTEM : FREE SPACE : Bitstream Buffer = 42587008 B (40 MB)
[m3vpss ] 5878: SYSTEM : FREE SPACE : Tiler Buffer = 123 B (0 MB) - TILER OFF
[m3vpss ] 5878: DISPLAY: Start in progress !!!
[m3vpss ] 5929: DISPLAY: Start Done !!!
[m3vpss ] 5929: DISPLAY: SDDAC(SEC1): 19 fps, Latency (Min / Max) = ( 255 / 0 ), Callback Interval (Min / Max) = ( 255 / 0 ) !!!
[m3vpss ] 5844: CAMERA: Start in progress !!!
[m3vpss ] 5844: CAMERA: Start Done !!!
[host]
Application Run Completed
inside autorun
INIT: Entering runlevel: 5
[host] ITT server task running !!!
[host]
ITT ittServer_run
[host] ITT Server Message initialization successful
[host]
ITT capture task created
[host] DCC server Message ques is open succefully
[host] Setting cmd <1> in message <45c24c80>
[host] Posting message <45c24c80> in QId <2 sbulla: unknown partition table
0002>
[host] Response from M3 is : 1
[m3vpss ] Command 1 recived from HOST A8
[m3vpss ] Command 2 recived from HOST A8
[host] Default parameters were sent sucessfully
[host] Server Socket created with ID <22>
[m3vpss ] New DCC data of size <33603>
[m3vpss ] Call to VNF_LINK_CMD_UPDATE_DCC -1
Starting system message bus: FAT: bogus number of reserved sectors
VFS: Can't find a valid FAT filesystem on dev sbulla.
dbus.
Starting telnet daemon.
Starting syslogd/klogd: done
root@dm814x-evm:~# mkdosfs 2.11 (12 Mar 2005)
unable to get drive geometry, using default 255/63/dev/sbulla has 255 heads and 63 sectors per track,
logical sector size is 512,
using 0xf8 media descriptor, with 1024 sectors;
file system has 2 12-bit FATs and 4 sectors per cluster.
FAT size is 1 sector, and provides 247 clusters.
Root directory contains 512 slots.
Volume ID is 509d5b49, no volume label.
g_file_storage gadget: No serial-number string provided!
g_file_storage gadget: File-backed Storage Gadget, version: 1 September 2010
g_file_storage gadget: Number of LUNs=1
g_file_storage gadget-lun0: ro=0, nofua=0, file: /dev/sbulla
Simple mixer control 'PGA',0
Capabilities: cvolume cswitch penum
Capture channels: Front Left - Front Right
Limits: Capture 0 - 119
Front Left: Capture 80 [67%] [40.00dB] [on]
Front Right: Capture 80 [67%] [40.00dB] [on]
queue id:0
ApproDrvInit: 3
queue id:131076
queue id:0
queue id:32769
queue id:0
ApproDrvInit: 7
queue id:131076
TimeOut occure in boot_proc.
Program exit.
Program exit.
[host]
Usecase is Active !!!
ApproDrvExit: 7
Error: WaitStreamReady Fail.
[host]
Force IDR on Channel: 0
[host]
Force IDR on Channel: 1Error: SemRelease: Invalid Semaphore handler
SystemInit success
Schedule manager init success
Dmva Schedule manager init success
umount: /mnt/mmc: not mounted
killall: dhcpcd: no process killed
net_search_gateway:eth0, AA8C0, 0, 1
net_search_gateway:eth0, 0, 10AA8C0, 3
dns=192.168.10.15
[09/Nov/2012:19:36:43 +0000] boa: server version Boa/0.94.13
[09/Nov/2012:19:36:43 +0000] boa: server built Oct 9 2012 at 21:31:11.
[09/Nov/2012:19:36:43 +0000] boa: starting server pid=1388, port 80
queue id:0
UDPString=uuid:Upnp-TVEmulator-1_0-00_0036196441</UDN>
Upnp port is 0
UPnP Initialized OK ip=192.168.10.135, port=0
desc_doc_url = http://192.168.10.135/tvdevicedesc.xml
UpnpRegisterRootDevice failure.
error code = -107
device advertisement failure.
ApproDrvInit: 10
queue id:131076
Initializing...
ApproDrvInit: 6
queue id:131076
Initializing...
...done initializing
Play this stream using the URL:
rtsp://192.168.10.135:8554/PSIA/Streaming/channels/1?videoCodecType=MPEG4
(We use port 8301 for optional RTSP-over-HTTP tunneling.)
ApproDrvInit: 2
queue id:131076
Initializing...
rtsp://192.168.10.135:8553/PSIA/Streaming/channels/1?videoCodecType=MPEG4
(We use port 8300 for optional RTSP-over-HTTP tunneling.)
ApproDrvInit: 8
queue id:131076
Initializing...
rtsp://192.168.10.135:8555/PSIA/Streaming/channels/0?videoCodecType=MJPEG
(We use port 8302 for optional RTSP-over-HTTP tunneling.)
ApproDrvInit: 9
queue id:131076
Initializing...
rtsp://192.168.10.135:8556/PSIA/Streaming/channels/2?videoCodecType=H.264
(We use port 8303 for optional RTSP-over-HTTP tunneling.)
rtsp://192.168.10.135:8557/PSIA/Streaming/channels/2?videoCodecType=H.264
(We use port 8304 for optional RTSP-over-HTTP tunneling.)
[host]
[host]
[host]
Shaka
